Author Topic: silkscreen underneath SMT components...  (Read 6150 times)
Online westfwTopic starter
« on: February 10, 2013, 10:13:55 am »
I'd like to put some identifying silkscreen "underneath" SMT components so that I can easily identify the type of component (assuming, say, otherwise identical 0805 SMT pads) on the completed board.  Will this work, or will the thickness of the silkscreen interfere with SMT component placement?  (assume for the moment that the symbols will be possible to read; these are relatively large components...)
Here's a picture of what I had in mind:
Offline jaqie
  • Genuine Girl Techie
Re: silkscreen underneath SMT components...
« Reply #1 on: February 10, 2013, 10:18:41 am »
if their height may interfere, what about making it a negative instead so that the height isn't unpredictable and uneven?  basically a solid silkscreen color for the entire underside of the part, with the text you want missing from that solid color?  that could give it a solid platform to sit on instead of a possible teeter totter effect?
Offline fcb
    • Electron Plus
« Reply #2 on: February 10, 2013, 11:37:46 am »
Don't do it for passives - you'll risk having misaligned silk on the pads and if they use a thick ink the part may ride up and encourage tombstoning. Your probably OK with the SOIC, although I put a box round the outside.
If I'm hand-building small runs of boards I just print out multiple copies of the top silk and colour in the parts, so I end up with flip-book (page for 10K's, page of 100n's, etc...).
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: February 10, 2013, 05:44:35 pm »
Down to 0805 no problem. Smaller gives risk of tombstoning.
NEVER do this under QFN as it may prevent the pads from wetting during reflow
Offline Kremmen
« Reply #4 on: February 10, 2013, 09:46:21 pm »
Yep, doing it all the time and no problems so far. Down to 0805, SOT23 and similar; iron soldering, heat gun, pizza oven - all work with no probs whatever. 0402 and below could be an issue but i don't do that size so wouldn't know.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline stefanh
« Reply #5 on: February 14, 2013, 12:39:52 am »
The IPC Compliant Footprint Wizard in Altium automatically puts some silkscreen between the pads following the outline of the component providing a minimum length can be achieved.  This works down to 0603 sized components, there is not enough room between the pads of 0402 components for any silkscreen..  I have not had any tomb stoning problems when getting them manufactured.
« Reply #6 on: February 14, 2013, 08:39:02 am »
Thanks everyone!
(Man, you work on those PCBs on the big monitor and everything looks swell, and then you print things out "actual size" and realize that they're a lot smaller than you thought!)
