Does anyone know if there's a simple way to display calculated parameters on the schematic? E.g. I have several resistors with values calculated from a few starting parameters, and I'd like to know what those calculated values are.
The crude way is to add a resistor in series with 1A current source to the sch, make the resistor value = parameter of interest, then add a voltage marker to see the result.
But surely there's a more elegant way to do this?
