Author Topic: Standard drill size?  (Read 628 times)
Offline tppc
« on: June 15, 2021, 08:24:42 am »
Hi there,
I just finished the design of my first PCB on JLCPCB's website.
before placing the order, I was just wondering if there is a standard drill size for
- Through hole 0.25W resistors ?
- Through hole DIP8 sockets ?
what puzzles me, is that available footprints on EasyEDA use strange drill sizes like 0.711mm or 0.914 mm for example.
Does a 0.711 mm drill even exist?
What will happen if I order a PCB with 0.711 mm holes? Will they round it to the next standard size?
BTW, is there a list of standard / recommended hole sizes for classic through hole components?
Thanks for your help.
Kind Regards.
« Last Edit: June 15, 2021, 08:34:17 am by tppc »
Offline evb149
Re: Standard drill size?
« Reply #1 on: June 15, 2021, 08:45:21 am »
Keep in mind what shows up in the part library footprint for a pad is NOT the drill bit size.
It is the finished hole size desired in the pad.  For plated holes that will be slightly smaller (due to the plating thickness)
than the drill bit used to make the hole itself.
So you'd be expecting them to support either metric or english standard drill bit sizes probably among those listed in the articles cited below, and to have finished holes available within their  tolerance range slightly smaller than the given bit sizes.
https://en.wikipedia.org/wiki/Drill_bit_sizes
https://en.wikipedia.org/wiki/List_of_drill_and_tap_sizes
https://jlcpcb.com/capabilities/Capabilities
As you'rel asking what's a common size for those kinds of through hole part leads, I suggest you check some
old texas instruments data sheets or similar from old NXP / Philips parts in DIP to see what they quote the
minimum / nominal / maximum size of DIP pins are for common chips and also what their suggested footprint is.
Once upon a time NXP had a good set of suggested footprints available for most of their packages as PDF files.
Now it seems to be less well organized / maintained, but last I saw you could still search for some package types / names
under their "packaging" menu somewhere in their quality web page or something like that.
Ultimately the resistor and DIP IC footprints and packages should correspond to JEDEC standards for those kinds of components.
So if you find the JEDEC package standard reference number for a 1/4 W axial resistor or 8-DIP or something you may be able
to find the "definitive" JEDEC specification for the cross-vendor package dimensions and lead tolerances.
There are also programs like the following that can help you calculate the IPC compliant dimensions of packages given
their datasheet derived types and tolerances e.g.:
https://www.pcblibraries.com/libraryexpert/pro/
Drill Hole Size (Mechanical)    0.20mm- 6.30mm
Min. drill size is 0.20mm. Max. drill size is 6.30mm.
Drill Hole Size Tolerance    +0.13/-0.08mm    e.g. for the 0.6mm hole size, the finished hole size between 0.52mm to 0.73mm is acceptable.
Hi there,
BTW, is there a list of standard hole sizes for classic through hole components?
Kind Regards.
The following users thanked this post: tppc
Offline evb149
Offline tppc
« Reply #3 on: June 15, 2021, 09:32:04 am »
Hi evb149,
Thank you very much for this very precise and detailed answer.  :-+
hey hey, I found the 0.711 mm & 0.914 mm drill bits from your wikipedia links  ;D
Again, thank you very much for your time.
I am already reading the information on the links you indicated.   ;D
As per the pdf drawing they suggest simply 1 mm holes.
In the case of my first PCB, hole sizes are not critical, I just wanted to use hole sizes that make sense.
Kind regards
Online dunkemhigh
« Reply #4 on: June 15, 2021, 02:22:11 pm »
The following users thanked this post: viji_rookie, tppc
Online asmi
« Reply #5 on: June 15, 2021, 05:55:15 pm »
I don't think any pcb fab still use imperial drills, certainly none in China. They typically take the closest size up.
Offline Feynman
« Reply #6 on: June 15, 2021, 06:20:33 pm »
Many shops have drill bits in 0,05mm steps. Since your specification is considered "finished" by default the shop will pick a slightly bigger drill to account for plating thickness and your tolerances (if specified).
Offline tppc
« Reply #7 on: June 16, 2021, 09:30:05 pm »
Hi guys,
thanks for all this valuable information.
I really do appreciate the high level of expertise, good will and mutual help on this forum.
Kind regards
Offline viji_rookie
  • Country: in
« Reply #8 on: July 12, 2021, 07:41:34 pm »
I agree. Once IPC rolled out Standard packages land pattern for SMD packages. Similar in line thru- hole padstacks got formalised in my companies I worked so far. For an example 0.05mm is considered as step increment (no intermediate values) while defining the drill sizes which are typically more than 1mm . Achieving precise drill size is offered by few suppliers but at the cost consideration.
We used below thumb rule in line with IPC guidelines as below,
Finished drill hole FDH = Max lead size (with tol) + 0.2mm or 0.15mm (based on plating requirements)
Then follow the IPC soldermask definations to attain at least minimum annular ring. Pls check link and attached picture.
IPC-7251 Generic Requirements for Through-Hole Design
https://pdf4pro.com/cdn/ipc-7251-generic-requirements-for-through-hole-design-49ebd1.pdf
Hope this helps.
« Last Edit: July 12, 2021, 07:45:00 pm by viji_rookie »
