A number of things that I would change:
- Don't use the top layer as your +5V layer; keep both copper pours as ground.
- I can see a number of vias that don't seem to be on the same grid reference as the trace they are connected to, I would consider moving them around.
- Speaking of Vias, I can see a couple that will cause the board to fail any DRC checks, I.E. there is one for the crystal that is almost touching the trace next to it. I use octagonal vias (just a personal preference)
- Some of the traces that I can see there seem way over specced for whatever signals are going through them. Most people love to try push down to a 8/8 mil spec for smd stuff, however with a recent board I have designed, I have easily gotten away with 16mil traces throughout, with only one trace slightly larger to "gild the lily". A perfect example is the two SMD components bottom right, they have a thin trace heading to them, yet the trace going to the via is as wide as the component will be.
- You have a number of SMD components both on top side and bottom side. This isn't too bad an issue really, however if you can fit them top side (and looking at the board space you should have no issue here) you should try to, it will make troubleshooting and routing just that little bit easier.
- There is a lot of blank board space there being wasted. surely you could make the board smaller?
I've taken the liberty to show a board that I am working on atm. I would never say that I am the best at PCB layout, but I am proud as to the OCD neatness that I have with this board.
You will note that I have the majority of the SMD stuff on the rear. this helps with routing, as I can run longer straight traces to where I need them, and keep them grouped together. The exception to this naturally is the LED/resistors mounted on the front which are indicators, therefore needed. You will also note that I have a lot of the components that are part of the same function grouped together, to help with troubleshooting.
I have also made the grid visible, which helps a lot in getting things looking good.
I have tried to limit, where possible the protrusions caused by the height of some components on the rear, namely with the SMD capacitors next to the shrouded header connector, as they both will be standing a fair amount off the board.
I hope this gives you some ideas as to what to look at.
-kizzap
Edit: GAH! Can't believe I forgot the most painfully obvious one too, which I believe even Dave has eluded to in his videos. Keep all your interconnects to one board side!!! so if you need to troubleshoot it is easy to simply flip out the board!
