Author Topic: Tented vias - when to use?  (Read 24241 times)
Offline shadewind
« on: August 02, 2011, 12:52:52 pm »
What are the advantages and disadvantages of tented vias? When should I use tented vias and when shouldn't I? What if the vias are only for thermal purposes?
Offline joelby
Re: Tented vias - when to use?
« Reply #1 on: August 02, 2011, 01:29:39 pm »
If you don't want solder to be drawn into the via hole, tenting can help prevent it. If your vias are running underneath something conductive, you can tent them.
The Screaming Circuits Blog (http://blog.screamingcircuits.com/) contains many posts on vias and manufacturability and is well worth a read.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: August 02, 2011, 02:12:50 pm »
I default to using tented vias on the basis that you don't normally need them uncovered. The only reason for not doing it is if you want to be able to use them for test points (or bodge wire conneciton points), although I generally use specific pad types.
For an all SMD assembly it makes little difference, but if the board is flow-soldered, untented vias can add to the number of places that could short due to solder bridges.
Day Job: Mostly LEDs
Offline luky315
  • Country: at
« Reply #3 on: November 26, 2013, 12:21:11 pm »
Tented Vias can cause long term problems because residuals of the processing chemicals COULD remain in the hole and cause problems. I've seen nasty things...
Offline poorchava
  • Troll Cave Electronics!
« Reply #4 on: November 26, 2013, 01:17:11 pm »
Also if you are using some sort of potting or coating that is supposed to be only on one side, the tenting prevents the coating from getting to the other side, which is sometimes unwanted (although for this purpose vias are often plugged, because tenting alone is not strong enough).
Another thing: prototype PCB services usually deal poorly with tenting. Chinese guys (itead, elecrow and such) usually get some vias right (=tented) and some not, even when specifying minimal hole size allowed. I think this is because the soldermask they are using is a thin liquid prior to curing and drips through the via or collapses when it's being cured.
Online NANDBlog
« Reply #5 on: November 26, 2013, 02:34:05 pm »
I always use tented vias, they should be tented from both sides. Via is not the place for testpoint, and it should be covered with soldermask. Both sides. And correctly sized vias.
The only place where I consider untented vias is high current traces.
Offline VK3DRB
« Reply #6 on: January 31, 2014, 01:54:34 pm »
In the days of corrosive fluxes this was quite true. Not so much nowadays.
Offline lorth
« Reply #7 on: January 31, 2014, 07:01:23 pm »
And big companies like Advanced Circuits (had to return 2 batches of boards because of that) or Sierra Circuits (returned after they guaranteed full coverage, and it wasn't...). I was using it as a mechanical isolator, which is not a great of an idea but... specs.
In defense of Advanced Circuits though, they do say (after navigating every single document on their website, not easy to find) they don't fully cover the cooper unless specified ($$$)...
OSHpark does a MUCH MUCH better job tenting vias, usually all fully covered....
« Last Edit: January 31, 2014, 07:05:28 pm by lorth »
