Author Topic: The Living PCB Design Thread share  (Read 2222 times)
Offline ansonbaoTopic starter
  • Country: cn
  • Never stop learning
    • pcbway
« on: April 06, 2017, 08:07:10 am »
Komar ever post The Living PCB Design Thread share in other place,he wants to make this as community-written knowledge base about designing PCBs:
Here I also hope Eevblog engineers can also share anything you know about designing electronics: software, tutorials, theory, etc.Like:
Schematic design:
  • pin- a dash on the schematic which represents an electrical connector in a component, which can be connected to a different pin
  • net-a line representing an electrical connection between 2 or more pins
  • bus - a thicker line representing a logical group of nets
  • label - a name for a net, in EDA software, 2 nets with the same label will usually be treated as connected together, though various types of labels exist in various software (global, hierarchical, sheet labels, etc
PCB design
  • PCB (Printed Circuit Board) - a sheet of sturdy laminate (usually FR-4) with electrical connections made of copper, which are used to conduct current between different components on the board
  • pad - 1. a hole in the PCB surrounded with a copper ring used to mount THT components by putting a pin inside the hole and soldering it to the ring; 2. a shape (usually rectangular) made of copper used to solder pins of SMD components
  • SMT (Surface-Mount Technology) - a technique of mounting components based on soldering their pins onto the surface of the board, on the same side as the component
  • SMD (Surface Mounted Devices) - devices soldered using SMT
Free EDA software:
  • KiCad (http://www.kicad-pcb.org)
  • Eagle (free for up to 100 x 80 mm boards, 2 layers, one schematic sheet)
  • ... write a post to add more, if you've used it and and you like it!
I am PCBWay manager and you can ask me any questions about PCB.
  • Country: cn
    • pcbway
Re: The Living PCB Design Thread share
« Reply #1 on: April 06, 2017, 08:14:32 am »
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #2 on: April 06, 2017, 08:21:55 am »
i am pcbway manager,you can ask to me any questions about pcb  technology.i think eevblog is a good communication place,i am not come for ads,just for learn
i am eevblog reader,you can ask me any questions about typing   technology.i think typing is a important communication  tool,i am not come for punctuation,neither for grammar [sic]
Things I'll add:
- decide if you do one symbol per group (i.e R) or one per type of resistor (120R_1%_0402)
- have a plan for easy reuse of your work
- learn how to do version control and proper backups
- work with the DRC not against it
- learn to use a SPICE simulator, simulate, breadboard, then design
- consider testing and prioritize it for the first revision. Many test pads, many 0R jumpers (to isolate parts of schematic). If it could fail, make sure you have a way around it
I like and use KiCAD for private stuff, and Altium at work. Altium is objectively a whole lot better than any other I've tried - but also much more expensive.
Not sure if this thread is really worth while as each topic is a huge thread in itself. Even something as simple as the pad, it's size, it's solder mask expansion, the paste aperture etc etc.
« Last Edit: April 06, 2017, 08:33:09 am by alexanderbrevig »
