Author Topic: Turn SMT Seeeduino XIAO VIN to Through-hole ?  (Read 1514 times)
Offline philgibTopic starter
« on: August 04, 2022, 10:37:14 am »
Hello,
Making my very first PCB, everything will be on a Through Hole basis.
Is there any easy way to turn the VIN of the Seeeduino Xiao from SMT to Through Whole ?
Thank you  :)
« Last Edit: August 04, 2022, 10:38:49 am by philgib »
Online Ian.M
Re: Turn SMT Seeeduino XIAO VIN to Through-hole ?
« Reply #1 on: August 04, 2022, 10:50:46 am »
No, but as its connected in parallel to the module's VCC (5V) pin, you shouldn't need to.  See the schematic: https://files.seeedstudio.com/wiki/Seeeduino-XIAO/res/Seeeduino-XIAO-v1.0-SCH-191112.pdf
For future reference, one way of tackling hooking up SMT pads on a SMD/Through-hole module, for one-offs and prototypes only, is to fit pin header strips with more pins than the module needs, and run 30AWG kynar wirewrap wire, or thin hookup wire, or even magnet wire between the extra pins and the SMD pads you need to breakout.
« Last Edit: August 04, 2022, 10:56:10 am by Ian.M »
The following users thanked this post: philgib
Online langwadt
« Reply #2 on: August 04, 2022, 10:54:40 am »
look at the schematic, Vin and 5V is the same signal
« Reply #3 on: August 04, 2022, 01:30:16 pm »
I envy you guys to understand the schematic. Pure Chinese too me, although I am trying hard   :-[
I will have to put this XIAO in sleep mode, and I understood that the correct way to do is to input 3.3V and not 5V in order to save milliamps from not kicking in the 5v => 3.3v regulator
Do you guy understand from the schematics that the 3.3V pin out is also on the same as the VIN ?
« Last Edit: August 04, 2022, 01:32:47 pm by philgib »
Offline PeteH
« Reply #4 on: August 04, 2022, 01:37:24 pm »
The on board linear regulator is very low power (sub 10uA) - if you don't care about that level of current during sleep, can use 5V. Otherwise 3.3V does come out to the pin headers as well, but will backfeed the regulator and cause a little bit of loss.
« Reply #5 on: August 06, 2022, 02:02:47 pm »
I am a bit lost...
A CR2032 will power the Seeeduino Xiao, and I will put it in sleep mode every 55 seconds of each minute
Now it will wake up for 5 seconds, the time to read a temp sensor.
The temp sensor has a +,-, and signal
My idea was to put also the temp sensor to sleep every 55 seconds.
How do I put the sensor to sleep since the power is coming in parallel from the Seeeduino Xiao 3.3v pin-out ? Is that through the sensor signal pin-out ?
Thank you
Offline ledtester
« Reply #6 on: August 06, 2022, 02:46:13 pm »
What temp sensor are you using?
