Seriously ? who desings on stripboard ( apart for one off hobby projects ? )
that is not a 'design workflow' and a bad example for a real workflow.
Actually, it is design workflow. It looks like you use the schematic editor from your normal EDA package (Altium, Eagle, DipTrace, KiCad, etc.) then export the NetList and Symbols, which this program picks up so you can design your strip board layout. Any changes can be reimported into your EDA package if desired. Then you can make a real PCB once you're done prototyping.
Personally, I like strip board. They've even got SMD boards that handle various pin pitches. (Though with an Exacto knife you can do SMD on normal strip board.) Next to super glue and copper clad board (Jim Williams style), strip board is my next most useful prototyping tool.
Not everyone is a 25 year veteran with money to burn for overnight quick turns you know. Sometimes for a couple of boards it's easier and cheaper to just hand build them, especially if you can't wait a month for real PCBs.
So yeah, this looks cool. Thanks for the heads up, OP! I'll give it a try. :}
Sent from my Smartphone
