Author Topic: Via aspect ratio in PCB  (Read 2817 times)
Offline joniengr081Topic starter
  • Country: no
« on: December 06, 2023, 08:02:26 am »
The aspect ratio of the via is the ratio of dielectric height to via hole.
Is that true 10:1 has smaller via hole compared to 6:1 ? in 60 mil thick PCB
If yes than manufacturing 10:1 via is more expansive and difficult then 6:1 via, correct ?
Online tszaboo
Re: Via aspect ratio in PCB
« Reply #1 on: December 06, 2023, 09:28:49 am »
Smaller drills wear out faster. But you shouldn't really be concerned with this, today drilling a hole is a free step, and they automatically replace the drills after certain number of holes. You only need to make sure you follow the design guides, and that you don't end up unnecessarily with an HDI board.
  • Country: no
« Reply #2 on: December 06, 2023, 09:44:28 am »
What is an HDI board. I guess this is something related to number of pins in connector or in BGA package per square inch, right ?
Online tszaboo
« Reply #3 on: December 06, 2023, 09:53:40 am »
It's a loosely defined term, meaning High Density Interconnect. Usually it's for boards that have smaller than 0.3mm size vias, less than 0.15mm wide tracks and clearances, blind or buried vias, more than 8 layers. Any of these would place you in the HDI category, which makes the board more expensive.
If you are worried about your vias, just make them larger than 0.3mm hole, and 0.75mm pad, less than a few hundred vias, and most PCB houses will make the board without extra charge.
