Cheap China PCB pool servises ain't capable to do that. Been there, tried that. Even if you specify it, add note in textfile in production files, then again add this specification to order email, they still manage to f*ck it up.
But I believe it's mainly due to high level of automation in preproduction processing. Even if not - what are You expecting at this price point ? It's still superb for prototypes and small one-off runs.
And yep, for Seed studio / Elecrow / Itead - if you ommit silkscreen layers, they will place their marking either in copper or soldermask layer depending on design density - so beware of that !
(That means leave out gerber for silksreen only if you really need that one side of PCB clean, otherwise include all layers, even if there are no appetures.)
And it is not due to saving manufacturing steps - all designs are pooled on big panels, cca 450x600mm and then individual boards are routed-out.
Also - as I see on first post, sharp board edges. Take advantage of fully routed PCB outline ! Make nice rounded corners - it's nicer and practical. It's not once that I have seen cable bundles cut by sharp edge of PCB in some devices.
