Author Topic: (SOLVED) What design program to open .sch and .pcb files?  (Read 5427 times)
Offline vk2amvTopic starter
« on: November 15, 2017, 09:13:09 am »
Hi all,
I am hoping someone can help me identify what program was used to create a schematic and pcb file.
The Github repository of the project I am trying to open is here
https://github.com/BG4TGO/MMDVM
Unfortunatly very little information provided, and the only two important files look to be the .pcb and .sch files.
So far I have been unsucessful opening them trying Kicad, Designspark, and Eagle.
Any help would be muchly appreciated as I am wanting to get some PCB's made of this.
Thanks in advance
« Last Edit: November 15, 2017, 09:38:17 am by vk2amv »
It's only when you look at an ant through a magnifying glass on a sunny day, that you realise how often they burst into flames.
Offline AndyC_772
Re: What design program to open .sch and .pcb files?
« Reply #1 on: November 15, 2017, 09:14:42 am »
.sch and .pcb are used by PADS.
« Reply #2 on: November 15, 2017, 09:38:02 am »
You sir are a saint.
I have been banging my head against the wall all afternoon with this.
Downloaded the PADS viewer and they opened straight up.
Now to work out how to export the files to Kicad or Eagle.
That is the next problem, but the important thing for now is I can view them.
Thanks again
The following users thanked this post: AndyC_772
Offline T3sl4co1l
    • Seven Transistor Labs
Re: (SOLVED) What design program to open .sch and .pcb files?
« Reply #3 on: November 15, 2017, 09:39:55 am »
PADS, Eagle, Protel, etc.
Try opening the file in a text editor, see if there's a text header to identify it?
Seven Transistor Labs, LLC
