Author Topic: What is a PSS simulation?  (Read 1724 times)
Offline steamedhamsTopic starter
« on: June 29, 2021, 09:22:23 am »
For example, when I went to see how a comparator works over a given time frame... what is the PSS simulation showing me exactly??
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
Re: What is a PSS simulation?
« Reply #1 on: June 29, 2021, 11:16:12 am »
I would expect PSS to be periodic steady state. It's related to Harmonic Balance simulations in that it focuses on oscillating structures, or narrow band signals.
It looks at repetitive situations (in a discrete simulation, if all your information at a certain timestep is the same as a number of timesteps ago, you've reached steady state in a sense).
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
The following users thanked this post: steamedhams
