Author Topic: Which EDA Software for high speed project  (Read 11843 times)
Offline funkathustra
Re: Which EDA Software for high speed project
« Reply #25 on: June 30, 2015, 11:23:57 pm »
You'll need a minimum of 6 layers to fan-out most modern BGAs, and if you've got other peripherals or a lot of power domains, you may need a lot more (the i.MX6 REX project is done on 12 layers, for example). If your SoC is smaller than 0.8mm pitch, you'll need via-in-pad technology, laser-drilled microvias, and/or 3mil traces.
Manufacturing and assembling prototype quantities (10 or so) of a 6- or 8-layer board with a custom stack-up, plus assembly and BOM could cost $10k or more, depending on board complexity, turn-around time, and if you're going to China or not. Considering you'll probably need to run two or three prototypes to get the design nailed, you're talking about a $30k investment in materials.
Designing and routing a DDR memory bus by someone new to high-speed routing could take 50 hours or more of engineering time. Budgeting $100/hr, means you're at $5000 in personnel costs, just for the memory bus.
And you're quibbling over the price of an EDA tool that costs less than $10k? Just buy Altium and do it the right way.
Offline AutomationGuyTopic starter
« Reply #26 on: July 04, 2015, 09:23:19 am »
According to this which is a usefull Altium vs Circuit Studio comparison:
http://www.element14.com/community/docs/DOC-76216/l/circuitstudio-by-altium-vs-altium-designer-feature-and-specification-comparison
Circuit Studio has no trace length tuning.
Eagle and KiCAD have this feature.
Altium seems to have a high speed design rule check as well.
