Author Topic: World's worst QFN  (Read 6465 times)
Offline DaixiwenTopic starter
  • Country: no
World's worst QFN
« on: July 01, 2019, 07:42:52 am »
I remember a while ago seeing this twitter post on the world's worst QFN ever:
https://twitter.com/whitequark/status/1106970233485561858
I had a good laugh back then, wondering who would be masochist enough to use that.
Well guess who is going to implement that component on a PCB now...  :-\
Offline Ysjoelfir
Re: World's worst QFN
« Reply #1 on: July 01, 2019, 09:45:10 am »
Don't forget to add the cry for help or some kind of ragequit on the silkscreen layer. Right above the "Detail B" arrow line would be sufficient space. But remember to mirror the text - this is the bottom view.
Greetings, Kai \ Ysjoelfir
The following users thanked this post: I wanted a rude username
Offline coppice
« Reply #2 on: July 01, 2019, 09:47:19 am »
I guess a BGA could be considered the world's worst QFN.  ;)
Offline Ysjoelfir
« Reply #3 on: July 01, 2019, 09:58:20 am »
I would prefer to create a footprint of more or less any standard bga over THAT thing. A BGA is usually at least consistent in spacing and pin numbering.
Offline ataradov
    • Personal site
« Reply #4 on: July 01, 2019, 05:40:05 pm »
This seems like it is designed for easy fan out. It is annoying to create the footprint, of course, but you only have to do that once.
Alex
  • Country: no
« Reply #5 on: July 02, 2019, 06:45:32 am »
It's an application where we can't use BGA's. It's a very low volume PCB and with very expensive components so we'd better get it right on the first try!
It's probably designed this way for easier fanout but there are still a few things I don't get... some differential pairs (but not all) use an oblong pad for one of the signals, and a round one for the other one. And there are 38 unconnected pads. Because of course.
The pin used to hold the chip in powered down state is called COMA_MODE. Probably a good description of the layout engineer when he is finished creating the footprint!
Offline Berni
  • Country: si
« Reply #6 on: July 02, 2019, 07:33:23 am »
Just as I recovered from PTSD from A3P250-QNG132, now I can't unsee this.
And when i thought those dual row QFNs ware evil here you show me a tripple row QFN.
Attached is what blueskulls evil chip looks like.
  • Country: no
« Reply #7 on: February 04, 2020, 07:22:38 am »
 :scared:
Offline daqq
  • Country: sk
    • My site
« Reply #8 on: February 04, 2020, 07:44:41 am »
This is becoming silly. At some point we're gonna have to add another package name to the list, namely "Other", "Arbitrary" or "Because f*ck you, that's why!".
Offline RoGeorge
« Reply #9 on: February 04, 2020, 08:13:17 am »
Rookie complain, those chips were meant for vertical mounting.   ;D
Offline babysitter
  • pushing silicon at work
« Reply #10 on: February 04, 2020, 08:54:58 am »
Pure pr0n.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
« Reply #11 on: February 04, 2020, 09:21:07 am »
Who did that vertical mount? the technician is pure genius
Making products for IOT
Online nctnico
« Reply #12 on: February 04, 2020, 09:55:34 am »
That is pure art!  :clap:
Online mariush
« Reply #13 on: February 04, 2020, 09:58:32 am »
re the image in first post... it looks bad, but in reality it's not THAT bad.
If you pay attention you'll notice it's mirror image (left and right sides, top and bottom), with just some pads being elongated to be 2x the size or something like that.
So you only have to get a quarter of that footprint done and then mirror it twice and then extend some pads and you're done.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #14 on: February 04, 2020, 10:21:35 am »
Worst one I've used, not all that bad but still worthy of an appropriate library name:
3D view in situ: https://www.seventransistorlabs.com/Images/AltiumPlacement.png
« Last Edit: February 04, 2020, 10:25:47 am by T3sl4co1l »
Seven Transistor Labs, LLC
Online Nominal Animal
« Reply #15 on: February 04, 2020, 10:43:08 am »
:scared:  I am at loss for words. :-+
  • Country: in
« Reply #16 on: February 04, 2020, 10:46:24 am »
This one is still OK. Looks symmetric and organized. Not like the random pins of various sizes placed at arbitrary locations. Someone has to be given a nobel prize for these kinds of pinout.
The following users thanked this post: splin
Offline Rerouter
« Reply #17 on: February 04, 2020, 10:51:50 am »
I can handle the really weird pinouts, I hate the stupid assignment of some chips much more,
Oh, you have a 16 bit port left exposed, intended for interfacing to external memory, LCD's or similar, Why... why do they split those pins up as much as humanly possible. the I/O is sequential, so why is this function shotgunned around the pinout... or serial ports with RX half the chip away from TX....
Offline exe
  • self-educated hobbyist
« Reply #18 on: February 04, 2020, 10:57:15 am »
Do you guys draw these components by hands? I wish manufacturers release components as well. To me it feels quite a waste of time and effort to try to replicate what was already done.
The worst part for me is to calculate sizes and distances when only a few dimensions are given. There is also a risk of doing it wrong.
  • Country: in
« Reply #19 on: February 04, 2020, 11:01:03 am »
Most component manufacturers provide footprint data in multiple format these days. So that makes life easier...
One thing I have learnt from QFN parts with different sized pads is that if the centre pad is very large and if the solder paste on that pad is not split into different sections, there is a finite risk of the outer pads not making contacts. This is due to the surface tension of the molten solder causing the package to lift up.
The best option is to split the QFN centre pad to smaller pads so that the footprint can also be split.That makes soldering reliability much better.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #20 on: February 04, 2020, 11:03:03 am »
I suspect the reason they don't (always, some manufacturers do release footprints) is
a) everyone uses different standards and methods of drawing components. So even if they do release components a lot of people don't use them. I have this issue with schematic symbols mostly - some people like drawing schematic symbols as one big block, others like splitting them up. How do you think you should split them up? What pitch between pins? What grouping? etc etc
b) You can't always support every single package out there.
c) footprints tend to change based on technology too - soldermask openings, pad size, hole sizes, how you do your silk, etc.
I do wish the vendors gave me a list of coordinates for each pad sometimes - would be real convenient. What is even worse is if they give all values, but in the 'wrong way' so I need to do the math to convert it to the way I need to imput the data into altium footprint generator or whatever.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
  • Country: no
« Reply #21 on: February 04, 2020, 11:18:29 am »
I suspect another reason they don't give ready made footprints is that they don't want to be held liable in case of manufacturing problems.
I wonder too how the central pad will affect soldering of the other pads, especially with so many rows all around.
Worse case, we finish the soldering process with a heat gun and a hammer  ;D
Offline radar_macgyver
« Reply #22 on: February 04, 2020, 01:16:16 pm »
Well mine is minor compared to some of these examples, but I was forced to re-spin a board because I used the TPS7A4700, which comes in a QFN20 - with 0.65 mm pad spacing instead of the usual 0.5 mm.  |O Oops.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #23 on: February 04, 2020, 01:22:45 pm »
FAB: Do you want additional interconnect layer(s)?
client: No, thanks.
FAB: Ok, don't move the pads around then.
client: fine.
Routing that isn't gonna be any worse than say, any Intel bga, no?
Offline ebastler
« Reply #24 on: February 04, 2020, 01:47:15 pm »
We had this picture before (https://www.eevblog.com/forum/chat/qfn-dead-bug/msg2338626/#msg2338626), but I have not figured out the original source yet. Google image search finds various Twitter posts and other obscure channels. "PS3 hacking" is mentioned somewhere. Does anyone know where/when/why/by whom this was done?
Edit: Ah, this seems close to the source:
https://www.psdevwiki.com/ps3/Syscon_Hardware
« Last Edit: February 04, 2020, 01:48:52 pm by ebastler »
