Author Topic: youtube tutorial on making a coil bobbin in solidworks  (Read 1210 times)
Offline coppercone2Topic starter
« on: August 20, 2020, 05:36:07 am »
I have solidworks and very little experience or patience for learning it,
Does anyone have a youtube video that shows something like a spiral being made, basically I want to use my 3d printer to print something to wind an inductor on. I was hoping for a general shape, so I can just learn to resize it for my purposes to get limited use of out solid works.
I mean a axial inductor, so I want to learn how to make a spiral on a cylinder, or possibly other shape, like a doughnut or wedge (not necessarily a round inductor).
I need something that I can pause and go back on because I am not good at learning 3d cad programs. I did this with a heat sink before, with the video I have some where, I can resize it to make any simple heat sink if I follow the steps and change some numbers, with little fustration in around 30 minutes. I know a heat sink and a inductor bobbin are basically the same thing, but the inductor needs to have a spiral, the heat sink is peice wise unfortunately.
I would prefer to start with one that does not have the dumbell shape, just a simple rod (i.e. ferrite rod antenna).
« Last Edit: August 20, 2020, 05:42:28 am by coppercone2 »
Offline E-Design
  • Hardware Design Engineer
Re: youtube tutorial on making a coil bobbin in solidworks
« Reply #1 on: August 24, 2020, 11:48:27 pm »
Search on Youtube "Solidworks Coil" = ALL kinds of relevant hits..
Such as this random one
Why dont you try out the search feature
« Last Edit: August 24, 2020, 11:53:26 pm by E-Design »
The greatest obstacle to discovery is not ignorance - it is the illusion of knowledge.
« Reply #2 on: August 25, 2020, 01:25:27 am »
because thats a coil and not a coil bobbin with a moon trench for the wire to sit in?
« Last Edit: August 25, 2020, 01:28:59 am by coppercone2 »
