Author Topic: 32 bit CRC - is it standard?  (Read 8598 times)
Offline peter-hTopic starter
« on: July 22, 2021, 09:32:01 pm »
I am programming a 32F417 which has a hardware CRC calculator, but the STM HAL function for it is too convoluted for me to understand. But also I need a version to run "on the other end" which doesn't have a CRC calculator.
So I am looking for a software algorithm. It does not need to be identical to the STM hardware one, which may be this one
https://stm32f4-discovery.net/2015/07/hal-library-10-crc-for-stm32fxxx/ or this one
https://www.st.com/resource/en/application_note/dm00068118-using-the-crc-peripheral-in-the-stm32-family-stmicroelectronics.pdf
It doesn't need to be fast. I would like > 1MB/sec but even one which doesn't use a table should do that (168MHz CPU with a barrel shifter). It needs to take in 1 byte at a time, not a pointer to a buffer and a length (because I will be calculating it over varying amounts of data, and too much to fit into RAM in one go).
But I am finding various algorithms which seem to be different... I've been told that the 32 bit CRC has been standardised.
For example I found this one:
https://stackoverflow.com/questions/21001659/crc32-algorithm-implementation-in-c-without-a-look-up-table-and-with-a-public-li
which is trivially modified for a byte at a time:
static uint32_t crc = 0xFFFFFFFF;  // this value gets the accumulated CRC as you go along
void crc32b(uint8_t input_byte) {
   uint32_t mask, j;
      crc = crc ^ input_byte;
      for (j = 7; j >= 0; j--)
         mask = -(crc & 1);
         crc = (crc >> 1) ^ (0xEDB88320 & mask);
Thank you in advance for any ideas. I have tons of CRC-16 code and have used these many times, some with big tables and pretty fast, but not CRC-32.
« Last Edit: July 22, 2021, 09:51:18 pm by peter-h »
Online oPossum
Re: 32 bit CRC - is it standard?
« Reply #1 on: July 22, 2021, 09:36:58 pm »
There are numerous standards that use a CRC. Some share the same polynomial, initial value and bit order.
List of some common ones here: https://en.wikipedia.org/wiki/Cyclic_redundancy_check#Polynomial_representations_of_cyclic_redundancy_checks
The results for a given CRC (such as those listed) will be the same no matter how it is calculated.
« Last Edit: July 22, 2021, 09:41:02 pm by oPossum »
« Reply #2 on: July 22, 2021, 09:42:25 pm »
OK; thanks. The CRC-32 in that list is probably the one in my code in the 1st post:
Offline SiliconWizard
« Reply #3 on: July 23, 2021, 12:51:51 am »
CRC32 is a CRC on 32 bits. There are many possible polynomials. Refer to the Wikipedia article for the "standard" ones. There are several.
Two things to note: apart from the polynomial, of course you can select the start value. One thing that can vary as well is that the resulting CRC can be negated or not (logical NOT). If you're using a CRC that you control on both sides, picking all 1's for the start value and not negating the result is fine.
The second point is that you can use a pre-built array of 256 32-bit values that can replace the inner loop of 8 iterations. Usually faster (but depending on architecture.)
You can have a look at GCC's implementation to get some ideas: https://github.com/gcc-mirror/gcc/blob/master/libiberty/crc32.c
« Reply #4 on: July 23, 2021, 01:03:01 pm »
That's a nice algorithm. It looks exactly the same CRC32 as my original code, however.
Clearly there are far fewer variations in the 32 bit CRC spectrum. Almost zero, actually :) This seems to be the "Ethernet" CRC, polynomial 0x04c11db7. And it is the same as the STC 32F4 hardware version
One thing which may vary is the byte order stored in the file, or sent in the serial data stream. For example Modbus swaps the two bytes in the CRC-16.
Interestingly this site https://www.lammertbies.nl/comm/info/crc-calculation lists just one CRC-32.
« Last Edit: July 23, 2021, 09:55:09 pm by peter-h »
Offline Siwastaja
« Reply #5 on: July 25, 2021, 07:53:02 am »
Calculating CRC isn't computationally that heavy, even without optimizations. Software implementation is so simple that you can remember it by heart, or just copy paste from an earlier design, or from online. Avoid premature optimization. I have never used the hardware CRC block. It is questionable how much it helps, if any, having to transfer all that data through the bus to the peripheral for a few simple operations.
Use some of the widely used polynomials, and don't forget you need a specific reset value to be compatible with others. If you have control over both sides, resetting to all ones, and using any of the popular polynomials is fine.
« Reply #6 on: July 25, 2021, 08:18:30 am »
In their document ST claim a huge speedup, but that involves feeding their CRC generator with DMA.
In my case I am reading the data (in most cases) from a 21mbps SPI FLASH which limits it to about 2MB/sec anyway. One could do the CRC in parallel with waiting for the SPI but the ST SPI libs are blocking AFAICT (they are incredibly bloated).
« Reply #7 on: July 25, 2021, 03:37:09 pm »
This is less trivial than I thought.
Start here https://www.lammertbies.nl/comm/info/crc-calculation
The CBF43926 appears the right result, looking in other places e.g. here https://crccalc.com/
But... what code produces this result?
Not this one
// CRC-32 - Ethernet version. Polynomial is 0x04c11db7 and it holds it backwards (0xEDB88320).
// This accepts one byte at a time, and returns the CRC in 'g_crc32value'.
// This makes it suitable for calculating a CRC across a joined-up combination of data blocks.
// this value holds the accumulated CRC as you go along - init'd to 0xffffffff by caller
uint32_t g_crc32value;
void crc32(uint8_t input_byte)
      g_crc32value = g_crc32value ^ input_byte;
      for (uint32_t j=0; j<8; j++)
      uint32_t mask = -(g_crc32value & 1);
      g_crc32value = (g_crc32value >> 1) ^ (0xEDB88320 & mask);
which would be the simplest, if not the fastest. All the fast ones use a table, but every one I tried produces a different value.
Edit: I found it in the end. Well, I never found one for CRC-32 which produces CBF43926. I found some which produce the bit inverse of CBF43926 :) Here is my final one:
* CRC-32/JAMCRC.
* Invert the *final* result and you get the more standard CRC-32/ISO-HDLC.
* Returns 0x340BC6D9 or (if final result inverted) 0xcbf43926 from "123456789" (9 bytes).
* Polynomial is 0x04c11db7 and it holds it backwards (0xEDB88320).
* This version accepts one byte at a time, and maintains the CRC in crcvalue. This makes it suitable
* for calculating a CRC across a number of data blocks.
* crcvalue must be initialised to 0xffffffff by caller, and holds the accumulated CRC as you go along
* See e.g. [url]https://crccalc.com/[/url] [url]https://www.lammertbies.nl/comm/info/crc-calculation[/url]
* [url]https://reveng.sourceforge.io/crc-catalogue/17plus.htm#crc.cat-bits.32[/url]
void crc32(uint8_t input_byte, uint32_t *crcvalue)
      uint32_t mask = (input_byte^*crcvalue) & 1;
      *crcvalue>>=1;
      if(mask)
      *crcvalue=*crcvalue^0xEDB88320;
      input_byte>>=1;
« Last Edit: July 25, 2021, 05:24:23 pm by peter-h »
Online oPossum
« Reply #8 on: July 25, 2021, 07:47:07 pm »
static uint32_t crc;
void update_crc(unsigned const x)
    crc ^= (x & 0xFF);
    unsigned bits = 8;
    do {
        if (crc & 1) {
            crc >>= 1; crc ^= 0xEDB88320;
        } else {
            crc >>= 1;
    } while (--bits);
int main(void)
    crc = ~0;
    char const* test = "123456789";
    while (char const c = *test++) update_crc(unsigned(c));
    printf("%08X\n", crc ^ ~0);
This will usually be a little faster...
void update_crc(unsigned x)
    x ^= crc;
    crc >>= 8;
    if (x & 0x01) crc ^= 0x77073096;
    if (x & 0x02) crc ^= 0xEE0E612C;
    if (x & 0x04) crc ^= 0x076DC419;
    if (x & 0x08) crc ^= 0x0EDB8832;
    if (x & 0x10) crc ^= 0x1DB71064;
    if (x & 0x20) crc ^= 0x3B6E20C8;
    if (x & 0x40) crc ^= 0x76DC4190;
    if (x & 0x80) crc ^= 0xEDB88320;
« Reply #9 on: July 25, 2021, 08:37:54 pm »
Interesting that you are inverting the result too
I never found any code which delivered 0xCBF43926 directly, FWIW.
And I always learn something here, like real coders write
crc = ~0;
instead of
crc = 0xffffffff;
Incidentally I got no output with GCC (Cube IDE) unless I used %08lx.
Offline Mr. Wizard
  • We must know. We will know.
« Reply #10 on: July 25, 2021, 08:44:03 pm »
If you control the code on both ends and don’t necessarily need a true CRC but just some kind of error checking, you may wish to consider Adler-32 rather than CRC-32. It was developed by Mark Adler in 1995 as a replacement for CRCs and is the algorithm that the zlib compression library and rsync use. It is much faster and simpler than computing a CRC, with a small tradeoff in reliability.
You could simply copy the zlib implementation of Adler-32 and be done, otherwise the Wikipedia article includes a naïve implementation that’s a bit slower, but very simple:
const uint32_t MOD_ADLER = 65521;
uint32_t adler32(unsigned char *data, size_t len)
    where data is the location of the data in physical memory and
    len is the length of the data in bytes
    uint32_t a = 1, b = 0;
    size_t index;
    // Process each byte of the data in order
    for (index = 0; index < len; ++index)
        a = (a + data[index]) % MOD_ADLER;
        b = (b + a) % MOD_ADLER;
    return (b << 16) | a;
For a rolling implementation, see this answer from StackOverflow.
« Last Edit: July 25, 2021, 08:50:38 pm by Mr. Wizard »
The following users thanked this post: oPossum
Online oPossum
« Reply #11 on: July 25, 2021, 09:35:44 pm »
That specific CRC requires the result to be inverted (XorOut column in the table). There is no other way.
Online oPossum
« Reply #12 on: July 25, 2021, 09:36:57 pm »
LUT version...
    // 0x04C11DB7 reflected
    static uint32_t const crc_tab[1 << 8] = {
        0x00000000, 0x77073096, 0xEE0E612C, 0x990951BA, 0x076DC419, 0x706AF48F, 0xE963A535, 0x9E6495A3,
        0x0EDB8832, 0x79DCB8A4, 0xE0D5E91E, 0x97D2D988, 0x09B64C2B, 0x7EB17CBD, 0xE7B82D07, 0x90BF1D91,
        0x1DB71064, 0x6AB020F2, 0xF3B97148, 0x84BE41DE, 0x1ADAD47D, 0x6DDDE4EB, 0xF4D4B551, 0x83D385C7,
        0x136C9856, 0x646BA8C0, 0xFD62F97A, 0x8A65C9EC, 0x14015C4F, 0x63066CD9, 0xFA0F3D63, 0x8D080DF5,
        0x3B6E20C8, 0x4C69105E, 0xD56041E4, 0xA2677172, 0x3C03E4D1, 0x4B04D447, 0xD20D85FD, 0xA50AB56B,
        0x35B5A8FA, 0x42B2986C, 0xDBBBC9D6, 0xACBCF940, 0x32D86CE3, 0x45DF5C75, 0xDCD60DCF, 0xABD13D59,
        0x26D930AC, 0x51DE003A, 0xC8D75180, 0xBFD06116, 0x21B4F4B5, 0x56B3C423, 0xCFBA9599, 0xB8BDA50F,
        0x2802B89E, 0x5F058808, 0xC60CD9B2, 0xB10BE924, 0x2F6F7C87, 0x58684C11, 0xC1611DAB, 0xB6662D3D,
        0x76DC4190, 0x01DB7106, 0x98D220BC, 0xEFD5102A, 0x71B18589, 0x06B6B51F, 0x9FBFE4A5, 0xE8B8D433,
        0x7807C9A2, 0x0F00F934, 0x9609A88E, 0xE10E9818, 0x7F6A0DBB, 0x086D3D2D, 0x91646C97, 0xE6635C01,
        0x6B6B51F4, 0x1C6C6162, 0x856530D8, 0xF262004E, 0x6C0695ED, 0x1B01A57B, 0x8208F4C1, 0xF50FC457,
        0x65B0D9C6, 0x12B7E950, 0x8BBEB8EA, 0xFCB9887C, 0x62DD1DDF, 0x15DA2D49, 0x8CD37CF3, 0xFBD44C65,
        0x4DB26158, 0x3AB551CE, 0xA3BC0074, 0xD4BB30E2, 0x4ADFA541, 0x3DD895D7, 0xA4D1C46D, 0xD3D6F4FB,
        0x4369E96A, 0x346ED9FC, 0xAD678846, 0xDA60B8D0, 0x44042D73, 0x33031DE5, 0xAA0A4C5F, 0xDD0D7CC9,
        0x5005713C, 0x270241AA, 0xBE0B1010, 0xC90C2086, 0x5768B525, 0x206F85B3, 0xB966D409, 0xCE61E49F,
        0x5EDEF90E, 0x29D9C998, 0xB0D09822, 0xC7D7A8B4, 0x59B33D17, 0x2EB40D81, 0xB7BD5C3B, 0xC0BA6CAD,
        0xEDB88320, 0x9ABFB3B6, 0x03B6E20C, 0x74B1D29A, 0xEAD54739, 0x9DD277AF, 0x04DB2615, 0x73DC1683,
        0xE3630B12, 0x94643B84, 0x0D6D6A3E, 0x7A6A5AA8, 0xE40ECF0B, 0x9309FF9D, 0x0A00AE27, 0x7D079EB1,
        0xF00F9344, 0x8708A3D2, 0x1E01F268, 0x6906C2FE, 0xF762575D, 0x806567CB, 0x196C3671, 0x6E6B06E7,
        0xFED41B76, 0x89D32BE0, 0x10DA7A5A, 0x67DD4ACC, 0xF9B9DF6F, 0x8EBEEFF9, 0x17B7BE43, 0x60B08ED5,
        0xD6D6A3E8, 0xA1D1937E, 0x38D8C2C4, 0x4FDFF252, 0xD1BB67F1, 0xA6BC5767, 0x3FB506DD, 0x48B2364B,
        0xD80D2BDA, 0xAF0A1B4C, 0x36034AF6, 0x41047A60, 0xDF60EFC3, 0xA867DF55, 0x316E8EEF, 0x4669BE79,
        0xCB61B38C, 0xBC66831A, 0x256FD2A0, 0x5268E236, 0xCC0C7795, 0xBB0B4703, 0x220216B9, 0x5505262F,
        0xC5BA3BBE, 0xB2BD0B28, 0x2BB45A92, 0x5CB36A04, 0xC2D7FFA7, 0xB5D0CF31, 0x2CD99E8B, 0x5BDEAE1D,
        0x9B64C2B0, 0xEC63F226, 0x756AA39C, 0x026D930A, 0x9C0906A9, 0xEB0E363F, 0x72076785, 0x05005713,
        0x95BF4A82, 0xE2B87A14, 0x7BB12BAE, 0x0CB61B38, 0x92D28E9B, 0xE5D5BE0D, 0x7CDCEFB7, 0x0BDBDF21,
        0x86D3D2D4, 0xF1D4E242, 0x68DDB3F8, 0x1FDA836E, 0x81BE16CD, 0xF6B9265B, 0x6FB077E1, 0x18B74777,
        0x88085AE6, 0xFF0F6A70, 0x66063BCA, 0x11010B5C, 0x8F659EFF, 0xF862AE69, 0x616BFFD3, 0x166CCF45,
        0xA00AE278, 0xD70DD2EE, 0x4E048354, 0x3903B3C2, 0xA7672661, 0xD06016F7, 0x4969474D, 0x3E6E77DB,
        0xAED16A4A, 0xD9D65ADC, 0x40DF0B66, 0x37D83BF0, 0xA9BCAE53, 0xDEBB9EC5, 0x47B2CF7F, 0x30B5FFE9,
        0xBDBDF21C, 0xCABAC28A, 0x53B39330, 0x24B4A3A6, 0xBAD03605, 0xCDD70693, 0x54DE5729, 0x23D967BF,
        0xB3667A2E, 0xC4614AB8, 0x5D681B02, 0x2A6F2B94, 0xB40BBE37, 0xC30C8EA1, 0x5A05DF1B, 0x2D02EF8D
    crc = (crc >> 8) ^ crc_tab[(x ^ crc) & 0xFF];
Online oPossum
« Reply #13 on: July 26, 2021, 02:16:53 am »
Not this one
That is a clever way to eliminate a conditional jump in the loop. It can be simplified to this...
void update_crc(unsigned const x) { crc ^= (x & 0xFF); unsigned b = 8; do crc = ((0 - (crc & 1)) & 0xEDB88320) ^ (crc >> 1); while (--b); }
« Last Edit: July 26, 2021, 07:40:59 am by oPossum »
« Reply #14 on: July 26, 2021, 08:00:24 am »
That CRC did not however produce any "standard" CRC result that I could find.
I went around this loop recently with 16 bit CRCs. Many years ago I developed some products which used CRCs for comms, and this time I tried to replicate them in C. None of the CRC algorithms I found matched the result of the old ones (which were written in assembler; Z180 and H8/300) and I never bothered to convert the obscure asm code (which I got from some book; I didn't write it) into C.
I suspect this goes on a lot i.e. people are controlling both ends of the link so they never find out.
But also a lot of stuff posted online is garbage :) One algorithm I found was claimed to deliver the 0xcbf43926 (if you google on that value you find loads of hits) but it definitely does not. I do not understand why anybody would do that, but they do...
This is my eventual version of a "rolling" CRC32 which gives you "CRC32/JAMCRC" and if you invert the final result then you get "ISO/HDLC" which I believe is used with Ethernet.
I never found a usable C source for the Ethernet one, despite loads of google hits and lots of people looking for it, although to be fair I was looking for a non-table version because I am using this in a boot loader, don't want to just waste 1k, and don't need the max speed. For all I know it may be this one.
* CRC-32/JAMCRC.
      *crcvalue>>=1;
      if(mask)
      input_byte>>=1;
I am using this site, among others: https://www.lammertbies.nl/comm/info/crc-calculation
// TEST CODE FOR CRC-32
uint8_t crctest[] = { "123456789" };
uint32_t crcvalue = 0xffffffff;
for (int i=0; i<9; i++)
crc32(crctest[i], &crcvalue);
printf("crc32 = %08lx, %08lx", crcvalue, ~crcvalue);
« Last Edit: July 26, 2021, 09:00:45 am by peter-h »
Online oPossum
« Reply #15 on: July 26, 2021, 02:58:55 pm »
Getting the wrong results is usually just a case of wrong bit order (reflection), initial value or final XOR.
Here is a test case for both websites.
void update_crc(uint32_t const x, unsigned bits, uint32_t const poly, unsigned const reflect)
    if (reflect) {
        // Reflected
        crc ^= (x & (0xFFFFFFFF >> (32 - bits)));
        do {
#if 0
            if (crc & 1) {
                crc >>= 1; crc ^= poly;
            } else {
                crc >>= 1;
#else
            crc = ((0 - (crc & 1)) & poly) ^ (crc >> 1);
#endif
        } while (--bits);
    } else {
        // Not reflected
        crc ^= (x << (32 - bits));
        do {
            if (crc & 0x80000000) {
                crc <<= 1; crc ^= poly;
            } else {
                crc <<= 1;
        } while (--bits);
void test_text(char const * const text, uint32_t const poly, uint32_t const init, uint32_t const out, unsigned const reflect)
    crc = init;
    char const* s = text;
    while (char const c = *s++) {
        update_crc(unsigned(c), 8, poly, reflect);
    printf("0x%08X\n", crc ^ out);
void test_text_all(char const* const text)
#if 1
    // 16 bit
    printf("www.lammertbies.nl/comm/info/crc-calculation\n");
    test_text(text, 0x0000A001, 0,          0,          1); // 0x8005 reflected
    test_text(text, 0x0000A001, 0x0000FFFF, 0,          1); // 0x8005 reflected
    test_text(text, 0x10210000, 0xFFFF0000, 0,          0); // lammertbies.nl is incorrect [url]https://cdn.sick.com/media/docs/6/46/846/technical_information_beam_data_for_diagnostics_and_automation_en_im0060846.pdf[/url]
    test_text(text, 0x10210000, 0,          0,          0);
    test_text(text, 0x10210000, 0x1D0F0000, 0,          0);
    test_text(text, 0x00008408, 0,          0,          1); // 0x1021 reflected
    test_text(text, 0x0000A6BC, 0,          0x0000FFFF, 1); // 0x3D65 reflected
    test_text(text, 0xEDB88320, ~0,         ~0,         1); // 0x04C11DB7 reflected
#endif
#if 1
    // 8 bit
    printf("crccalc.com 8 bit\n");
    test_text(text, 0x07000000, 0, 0, 0);
    test_text(text, 0x9B000000, 0xFF000000, 0, 0);
    test_text(text, 0x0000009C, 0, 0, 1); // 0x39 reflected
    test_text(text, 0xD5000000, 0, 0, 0);
    test_text(text, 0x000000B8, 0x000000FF, 0, 1); // 0x1D reflected
    test_text(text, 0x1D000000, 0xFD000000, 0, 0);
    test_text(text, 0x07000000, 0, 0x55000000, 0);
    test_text(text, 0x0000008C, 0, 0, 1); // 0x31 reflected
    test_text(text, 0x000000E0, 0x000000FF, 0, 1); // 0x07 reflected
    test_text(text, 0x000000D9, 0, 0, 1); // 0x9B reflected
#endif
#if 1
    // 16 bit
    printf("crccalc.com 16 bit\n");
    test_text(text, 0x80050000, 0, 0, 0);
    test_text(text, 0xC8670000, 0xFFFF0000, 0, 0);
    test_text(text, 0x80050000, 0x800D0000, 0, 0);
    test_text(text, 0x05890000, 0, 0x00010000, 0);
    test_text(text, 0x05890000, 0, 0, 0);
    test_text(text, 0x3D650000, 0, 0xFFFF0000, 0);
    test_text(text, 0x10210000, 0xFFFF0000, 0xFFFF0000, 0);
    test_text(text, 0x0000A001, 0, 0x0000FFFF, 1); // 0x8005 reflected
    test_text(text, 0x00008408, 0x0000FFFF, 0, 1); // 0x1021 reflected
    test_text(text, 0x00008408, 0x0000554D, 0, 1); // 0x1021 reflected
    test_text(text, 0x8BB70000, 0, 0, 0);
    test_text(text, 0xA0970000, 0, 0, 0);
    test_text(text, 0x00008408, 0x00003791, 0, 1); // 0x1021 reflected
    test_text(text, 0x0000A001, 0x0000FFFF, 0x0000FFFF, 1); // 0x8005 reflected
    test_text(text, 0x00008408, 0x00006363, 0, 1); // 0x1021 reflected
    test_text(text, 0x00008408, 0x0000FFFF, 0x0000FFFF, 1); // 0x1021 reflected
#endif
#if 1
    // 32 bit
    printf("crccalc.com 32 bit\n");
    test_text(text, 0x04C11DB7, ~0, ~0, 0);
    test_text(text, 0x82F63B78, ~0, ~0, 1); // 0x1EDC6F41 reflected
    test_text(text, 0xD419CC15, ~0, ~0, 1); // 0xA833982B reflected
    test_text(text, 0x04C11DB7, ~0, 0, 0);
    test_text(text, 0x04C11DB7,  0, ~0, 0);
    test_text(text, 0x814141AB,  0, 0, 0);
    test_text(text, 0xEDB88320, ~0, 0, 1); // 0x04C11DB7 reflected
    test_text(text, 0x000000AF,  0, 0, 0);
#endif
int main()
    test_text_all("123456789");
« Reply #16 on: July 26, 2021, 03:50:31 pm »
Nice; thanks.
I've been timing mine just now, to see if it needs the table method, and it does the entire 32F417 FLASH (1MB) in 2 seconds. 168MHz.
Might try speeding it up a little because this test will be done at every power-up.
Online oPossum
« Reply #17 on: July 26, 2021, 04:03:52 pm »
Using 32 bit words instead of 8 bit bytes will probably be faster.
void update_crc(uint32_t const x)
    crc ^= x;
    unsigned b = 32; do crc = ((0 - (crc & 1)) & 0xEDB88320) ^ (crc >> 1); while (--b);
void update_crc(uint32_t x)
        x ^= crc
        crc = 0
        if(x & 0x00000001) crc ^= 0xB8BC6765
        if(x & 0x00000002) crc ^= 0xAA09C88B
        if(x & 0x00000004) crc ^= 0x8F629757
        if(x & 0x00000008) crc ^= 0xC5B428EF
        if(x & 0x00000010) crc ^= 0x5019579F
        if(x & 0x00000020) crc ^= 0xA032AF3E
        if(x & 0x00000040) crc ^= 0x9B14583D
        if(x & 0x00000080) crc ^= 0xED59B63B
        if(x & 0x00000100) crc ^= 0x01C26A37
        if(x & 0x00000200) crc ^= 0x0384D46E
        if(x & 0x00000400) crc ^= 0x0709A8DC
        if(x & 0x00000800) crc ^= 0x0E1351B8
        if(x & 0x00001000) crc ^= 0x1C26A370
        if(x & 0x00002000) crc ^= 0x384D46E0
        if(x & 0x00004000) crc ^= 0x709A8DC0
        if(x & 0x00008000) crc ^= 0xE1351B80
        if(x & 0x00010000) crc ^= 0x191B3141
        if(x & 0x00020000) crc ^= 0x32366282
        if(x & 0x00040000) crc ^= 0x646CC504
        if(x & 0x00080000) crc ^= 0xC8D98A08
        if(x & 0x00100000) crc ^= 0x4AC21251
        if(x & 0x00200000) crc ^= 0x958424A2
        if(x & 0x00400000) crc ^= 0xF0794F05
        if(x & 0x00800000) crc ^= 0x3B83984B
        if(x & 0x01000000) crc ^= 0x77073096
        if(x & 0x02000000) crc ^= 0xEE0E612C
        if(x & 0x04000000) crc ^= 0x076DC419
        if(x & 0x08000000) crc ^= 0x0EDB8832
        if(x & 0x10000000) crc ^= 0x1DB71064
        if(x & 0x20000000) crc ^= 0x3B6E20C8
        if(x & 0x40000000) crc ^= 0x76DC4190
        if(x & 0x80000000) crc ^= 0xEDB88320
Offline Nominal Animal
« Reply #18 on: July 26, 2021, 04:47:43 pm »
On Cortex-M4, I would recommend a variant of oPossum's code above,
static const uint32_t  crc32_lookup[32] = {
    0xB8BC6765, 0xAA09C88B, 0x8F629757, 0xC5B428EF,
    0x5019579F, 0xA032AF3E, 0x9B14583D, 0xED59B63B,
    0x01C26A37, 0x0384D46E, 0x0709A8DC, 0x0E1351B8,
    0x1C26A370, 0x384D46E0, 0x709A8DC0, 0xE1351B80,
    0x191B3141, 0x32366282, 0x646CC504, 0xC8D98A08,
    0x4AC21251, 0x958424A2, 0xF0794F05, 0x3B83984B,
    0x77073096, 0xEE0E612C, 0x076DC419, 0x0EDB8832,
    0x1DB71064, 0x3B6E20C8, 0x76DC4190, 0xEDB88320,
static inline uint32_t crc32(uint32_t crc, uint32_t data)
    unsigned int  i = 0;
    data ^= crc;
    crc = 0;
    while (data) {
        crc ^= crc32_lookup[i++] & (~((data & 1) - 1));
        data >>= 1;
    return crc;
The crc32() takes the initial (or current) CRC and the 32-bit data word as parameters, and returns the updated CRC.
The expression (~((data & 1) - 1)) relies on data being an unsigned integer type, here uint32_t.  When its least significant bit is zero, the expression is zero; when the least significant bit is set, the expression is ~(uint32_t)0 (or equivalently (uint32_t)(-1)).
On Cortex-M4, this should compile to an inner loop with five instructions and a branch, with very little setup overhead.
« Reply #19 on: July 26, 2021, 05:39:04 pm »
Won't that while(data) loop go around up to 32 times, and 16 times on average for random data?
There may also be cases where I need to do byte data.
Probably need to look at doing it with a table after all... but they are all 256 x uint32_t i.e. 1kbyte tables.
« Last Edit: July 26, 2021, 05:51:49 pm by peter-h »
« Reply #20 on: July 26, 2021, 08:36:51 pm »
31 times for uniform random data, yes.  One inner loop iteration per bit.  (Since each bit is set at 50% probability, the average loop length is just under 31 iterations.)
Using GCC -O2, it uses 34 32-bit words, or 136 bytes of ROM/Flash for the table.  In comparison, the full byte table takes 256 32-bit words, or 1024 bytes of ROM/Flash:
static const uint32_t  crc32_lookup[256] = {
    0x00000000, 0x77073096, 0xee0e612c, 0x990951ba, 0x076dc419, 0x706af48f, 0xe963a535, 0x9e6495a3,
    0x0edb8832, 0x79dcb8a4, 0xe0d5e91e, 0x97d2d988, 0x09b64c2b, 0x7eb17cbd, 0xe7b82d07, 0x90bf1d91,
    0x1db71064, 0x6ab020f2, 0xf3b97148, 0x84be41de, 0x1adad47d, 0x6ddde4eb, 0xf4d4b551, 0x83d385c7,
    0x136c9856, 0x646ba8c0, 0xfd62f97a, 0x8a65c9ec, 0x14015c4f, 0x63066cd9, 0xfa0f3d63, 0x8d080df5,
    0x3b6e20c8, 0x4c69105e, 0xd56041e4, 0xa2677172, 0x3c03e4d1, 0x4b04d447, 0xd20d85fd, 0xa50ab56b,
    0x35b5a8fa, 0x42b2986c, 0xdbbbc9d6, 0xacbcf940, 0x32d86ce3, 0x45df5c75, 0xdcd60dcf, 0xabd13d59,
    0x26d930ac, 0x51de003a, 0xc8d75180, 0xbfd06116, 0x21b4f4b5, 0x56b3c423, 0xcfba9599, 0xb8bda50f,
    0x2802b89e, 0x5f058808, 0xc60cd9b2, 0xb10be924, 0x2f6f7c87, 0x58684c11, 0xc1611dab, 0xb6662d3d,
    0x76dc4190, 0x01db7106, 0x98d220bc, 0xefd5102a, 0x71b18589, 0x06b6b51f, 0x9fbfe4a5, 0xe8b8d433,
    0x7807c9a2, 0x0f00f934, 0x9609a88e, 0xe10e9818, 0x7f6a0dbb, 0x086d3d2d, 0x91646c97, 0xe6635c01,
    0x6b6b51f4, 0x1c6c6162, 0x856530d8, 0xf262004e, 0x6c0695ed, 0x1b01a57b, 0x8208f4c1, 0xf50fc457,
    0x65b0d9c6, 0x12b7e950, 0x8bbeb8ea, 0xfcb9887c, 0x62dd1ddf, 0x15da2d49, 0x8cd37cf3, 0xfbd44c65,
    0x4db26158, 0x3ab551ce, 0xa3bc0074, 0xd4bb30e2, 0x4adfa541, 0x3dd895d7, 0xa4d1c46d, 0xd3d6f4fb,
    0x4369e96a, 0x346ed9fc, 0xad678846, 0xda60b8d0, 0x44042d73, 0x33031de5, 0xaa0a4c5f, 0xdd0d7cc9,
    0x5005713c, 0x270241aa, 0xbe0b1010, 0xc90c2086, 0x5768b525, 0x206f85b3, 0xb966d409, 0xce61e49f,
    0x5edef90e, 0x29d9c998, 0xb0d09822, 0xc7d7a8b4, 0x59b33d17, 0x2eb40d81, 0xb7bd5c3b, 0xc0ba6cad,
    0xedb88320, 0x9abfb3b6, 0x03b6e20c, 0x74b1d29a, 0xead54739, 0x9dd277af, 0x04db2615, 0x73dc1683,
    0xe3630b12, 0x94643b84, 0x0d6d6a3e, 0x7a6a5aa8, 0xe40ecf0b, 0x9309ff9d, 0x0a00ae27, 0x7d079eb1,
    0xf00f9344, 0x8708a3d2, 0x1e01f268, 0x6906c2fe, 0xf762575d, 0x806567cb, 0x196c3671, 0x6e6b06e7,
    0xfed41b76, 0x89d32be0, 0x10da7a5a, 0x67dd4acc, 0xf9b9df6f, 0x8ebeeff9, 0x17b7be43, 0x60b08ed5,
    0xd6d6a3e8, 0xa1d1937e, 0x38d8c2c4, 0x4fdff252, 0xd1bb67f1, 0xa6bc5767, 0x3fb506dd, 0x48b2364b,
    0xd80d2bda, 0xaf0a1b4c, 0x36034af6, 0x41047a60, 0xdf60efc3, 0xa867df55, 0x316e8eef, 0x4669be79,
    0xcb61b38c, 0xbc66831a, 0x256fd2a0, 0x5268e236, 0xcc0c7795, 0xbb0b4703, 0x220216b9, 0x5505262f,
    0xc5ba3bbe, 0xb2bd0b28, 0x2bb45a92, 0x5cb36a04, 0xc2d7ffa7, 0xb5d0cf31, 0x2cd99e8b, 0x5bdeae1d,
    0x9b64c2b0, 0xec63f226, 0x756aa39c, 0x026d930a, 0x9c0906a9, 0xeb0e363f, 0x72076785, 0x05005713,
    0x95bf4a82, 0xe2b87a14, 0x7bb12bae, 0x0cb61b38, 0x92d28e9b, 0xe5d5be0d, 0x7cdcefb7, 0x0bdbdf21,
    0x86d3d2d4, 0xf1d4e242, 0x68ddb3f8, 0x1fda836e, 0x81be16cd, 0xf6b9265b, 0x6fb077e1, 0x18b74777,
    0x88085ae6, 0xff0f6a70, 0x66063bca, 0x11010b5c, 0x8f659eff, 0xf862ae69, 0x616bffd3, 0x166ccf45,
    0xa00ae278, 0xd70dd2ee, 0x4e048354, 0x3903b3c2, 0xa7672661, 0xd06016f7, 0x4969474d, 0x3e6e77db,
    0xaed16a4a, 0xd9d65adc, 0x40df0b66, 0x37d83bf0, 0xa9bcae53, 0xdebb9ec5, 0x47b2cf7f, 0x30b5ffe9,
    0xbdbdf21c, 0xcabac28a, 0x53b39330, 0x24b4a3a6, 0xbad03605, 0xcdd70693, 0x54de5729, 0x23d967bf,
    0xb3667a2e, 0xc4614ab8, 0x5d681b02, 0x2a6f2b94, 0xb40bbe37, 0xc30c8ea1, 0x5a05df1b, 0x2d02ef8d,
static inline uint32_t  crc32(const void *src, const size_t len, uint32_t crc)
    const unsigned char *const  end = (const unsigned char *)src + len;
    const unsigned char        *ptr = src;
    while (ptr < end)
        crc = (crc >> 8) ^ crc32_lookup[(*(ptr++) ^ crc) & 255];
    return crc;
Using GCC-6.3.1, gcc -Wall -O2 -mcpu=cortex-m4 -S generates essentially
     .text
     .thumb
     .thumb_func
crc32:
     add  r1, r1, r0
     cmp  r0, r1
     bcs  .L1
     push {r4}
     ldr  r4, .arrayptr
     mov  r3, r0
     mov  r0, r2
.L2:
     ldrb r2, [r3], #1
     ldr  r2, [r4, r2, lsl #2]
     cmp  r1, r3
     eor  r0, r0, r2
     bne  .L2
     pop  {r4}
     bx   lr
.L1:
     mov  r0, r2
     bx   lr
     .align    2
.arrayptr:
     .word     crc32_lookup
     .section .rodata
crc32_lookup:
     .word     0
     ; omitted the 255 .word lines
which is extremely efficient (four instructions plus branch per byte); but again, takes more ROM/Flash due to the 1024-byte table.
Edited: There were a couple of bugs, now fixed.  This yields the same CRCs as jamcrc, and is basically identical to oPossum's LUT version above.
To compute the table at runtime, one can use
    for (int i = 0; i < 256; i++) {
        uint8_t   byte = i;
        uint32_t  val = 0;
        for (uint_fast8_t bit = 0; bit < 8; bit++) {
            val = (val >> 1) ^ ((uint32_t)(-((byte ^ val) & 1)) & 0xedb88320);
            byte >>= 1;
        crc32_lookup[i] = val;
« Last Edit: July 26, 2021, 10:35:47 pm by Nominal Animal »
Online oPossum
« Reply #21 on: July 26, 2021, 08:45:48 pm »
    while (ptr < end)
        crc ^= crc32_lookup[*(ptr++)];
Does that really work?
I think is has to be...
    while (ptr < end)
        crc = (crc >> 8) ^ crc32_lookup[(*(ptr++) ^ crc) & 0xFF];
« Reply #22 on: July 26, 2021, 10:42:22 pm »
You're right; I only noticed after doing some basic verification checks.  My table was also off; the one in your LUT post above is the correct one.  I added the snippet needed to precalculate it.  Using GCC-6.3.1 and -O2, it only adds about 62 bytes of ROM/Flash code.
« Reply #23 on: July 27, 2021, 09:21:06 pm »
Here's a C program that can compute any 32-bit CRC lookup table, given the 32-bit integer representing the polynomial.  You can use any C11 or C++11 or later compiler to compile it.  It takes one or more command-line arguments; run without any arguments to see the usage.  The polynomial at hand in this particular thread is x26 + x23 + x22 + x16 + x12 + x11 + x10 + x8 + x7 + x5 + x4 + x2 + x1 + x0, which is represented by 0x04C11DB7 = 79764919.
#include <stdlib.h>
#include <inttypes.h>
#include <string.h>
#include <stdio.h>
#include <errno.h>
static uint32_t  crc32_lookup[256];
void crc32_init(uint32_t poly)
    uint32_t  mask;
    /* mask is poly with inverse bit order. */
    mask = ((poly & 0x55555555) <<  1) | ((poly >>  1) & 0x55555555);
    mask = ((mask & 0x33333333) <<  2) | ((mask >>  2) & 0x33333333);
    mask = ((mask & 0x0F0F0F0F) <<  4) | ((mask >>  4) & 0x0F0F0F0F);
    mask = ((mask & 0x00FF00FF) <<  8) | ((mask >>  8) & 0x00FF00FF);
    mask = ((mask & 0x0000FFFF) << 16) | ((mask >> 16) & 0x0000FFFF);
    for (size_t i = 0; i < 256; i++) {
        uint_fast8_t   byte = i;
        uint_fast32_t  crc = 0;
            crc = (crc >> 1) ^ ((uint32_t)(-((byte ^ crc) & 1)) & mask);
            byte >>= 1;
        crc32_lookup[i] = crc;
uint32_t crc32(const void *src, const size_t len, uint32_t checksum)
    const unsigned char       *ptr = (const unsigned char *)src;
    while (ptr < end)
        checksum = (checksum >> 8) ^ crc32_lookup[(*(ptr++) ^ checksum) & 255];
    return checksum;
static int parse_u32(const char *src, uint32_t *dst)
    if (!src || !*src)
        return -1;
    const char    *end = src;
    unsigned long  val;
    errno = 0;
    val = strtoul(src, (char **)(&end), 0);
    if (errno)
        return -1;
    if (end == src)
        return -1;
    while (*end == '\t' || *end == '\n' || *end == '\v' ||
           *end == '\f' || *end == '\r' || *end == ' ')
        end++;
    if (*end)
        return -1;
    if ((unsigned long)(uint32_t)(val) != val)
        return -1;
    if (dst)
        *dst = val;
    return 0;
int main(int argc, char *argv[])
    uint32_t  poly;
    if (argc < 2 || !strcmp(argv[1], "-h") || !strcmp(argv[1], "--help")) {
        const char *arg0 = (argc > 0 && argv && argv[0] && argv[0][0]) ? argv[0] : "(this)";
        fprintf(stderr, "\n");
        fprintf(stderr, "Usage: %s [ -h | --help]\n", arg0);
        fprintf(stderr, "       %s POLYNOM\n", arg0);
        fprintf(stderr, "       %s POLYNOM STRING [ STRING ... ]\n", arg0);
        fprintf(stderr, "This program calculates the 32-bit CRC based on POLYNOM,\n");
        fprintf(stderr, "a 32-bit unsigned integer representing the polynomial taps.\n");
        fprintf(stderr, "When only POLYNOM is specified, the output is the C array\n");
        fprintf(stderr, "of the 256 coefficients.  When additional parameters are\n");
        fprintf(stderr, "specified, the output is the checksum of those strings.\n");
        return EXIT_SUCCESS;
    if (parse_u32(argv[1], &poly) || !poly) {
        fprintf(stderr, "%s: Not a nonzero 32-bit unsigned integer.\n", argv[1]);
        return EXIT_FAILURE;
    crc32_init(poly);
    if (argc < 3) {
        printf("/* CRC for ");
        const char *sep = "";
        for (int bit = 31; bit >= 0; bit--)
            if (poly & (((uint32_t)1) << bit)) {
                printf("%sx^%d", sep, bit);
                sep = " + ";
        printf(" */\n");
        printf("const uint32_t crc32_lookup[256] = {\n");
            switch (i & 7) {
            case 0:  printf("    0x%08" PRIx32 ", ", crc32_lookup[i]); break;
            case 7:  printf("0x%08" PRIx32 ",\n", crc32_lookup[i]); break;
            default: printf("0x%08" PRIx32 ", ", crc32_lookup[i]); break;
        printf("\n");
        printf("uint32_t crc32(const void *src, const size_t len, uint32_t checksum)\n");
        printf("{\n");
        printf("    const unsigned char       *ptr = (const unsigned char *)src;\n");
        printf("    const unsigned char *const end = (const unsigned char *)src + len;\n");
        printf("    while (ptr < end)\n");
        printf("        checksum = (checksum >> 8) ^ crc32_lookup[(*(ptr++) ^ checksum) & 255];\n");
        printf("    return checksum;\n");
        printf("}\n");
        printf("\n");
    for (int arg = 2; arg < argc; arg++) {
        const char    *src = argv[arg];
        const size_t   len = (src) ? strlen(src) : 0;
        const uint32_t crc = crc32(src, len, 0);
        printf("0x%08" PRIx32 " \"%s\" (%zu chars)\n", crc, src, len);
When the polynomial key is the only command-line parameter, it will output the C implementation for crc32_lookup[256] table and a crc32(src, len, checksum) function returning the updated checksum.
The following users thanked this post: peter-h, DiTBho
« Reply #24 on: July 29, 2021, 06:10:30 am »
Would you be kind enough and post the table for JAMCRC? I don't have a C compiler on my PC right now (yes I should have :) ). Thank you!
Even the code to generate it would be fine because in this application I have plenty of RAM. Presumably the code would be
uint32_t poly=0x04C11DB7;
    uint32_t  mask;
            byte >>= 1;
The rolling CRC is just
uint32_t crc=0xffffffff; // initialisation
uint32_t data_value;
crc = (crc >> 8) ^ crc32_lookup[(data_value ^ crc) & 0xFF];
but I am not sure if data value is uint32_t or uint8_t. The statement
is only going to work on the 8 least significant bits anyway.
« Last Edit: July 29, 2021, 06:49:35 am by peter-h »
