Author Topic: any *good* multi uart miniPCI card for a router?  (Read 105 times)
Online legacy
« on: October 08, 2019, 01:15:51 pm »
I need 8 UART-ports able to run at {115200 .. 1M } bps. I am experimenting with some weird problems with a couple of miniPCI modules, each able to manage up to 4 ports.
One thing I do find irritating: this stuff does not respect the PCI spec concerning how to report resources to BAR, in fact the Linux kernel has to handle the card in the pic via "quirks"  :palm:
The miniPCI card in the pic comes with fixed addresses (not reprogrammable => this violate the "plug and play" mechanism), hence it needs quirks and tricks to avoid collisions.
This is not perfect, and kernel 4.9.* to kernel 4.11.* are *ALL* bugged.
Does anyone happen to know a *good* multi serial miniPCI module? which fully do respect the PCI spec?
Offline NiHaoMike
    • Facebook Page
Re: any *good* multi uart miniPCI card for a router?
« Reply #1 on: October 09, 2019, 01:51:08 am »
Find one to go from miniPCI to USB, then add some USB to serial converters.
Online legacy
« Reply #2 on: October 09, 2019, 06:11:14 am »
do you happen to know where can I find one? EHCI? NEC chip?  :D
Online legacy
« Reply #3 on: October 09, 2019, 06:19:12 am »
with an ugly ( too embarating, so I will never show a pic) hardware and software hack,  it seems you can  partially work-around the problem
PCI: Enabling device 0000:00:05.0 (0000 -> 0003)
0000:00:05.0: ttyS1 at I/O 0x18800800 (irq = 140, base_baud = 460800) is a 16C950/954
0000:00:05.0: ttyS2 at I/O 0x18800808 (irq = 140, base_baud = 460800) is a 16C950/954
0000:00:05.0: ttyS3 at I/O 0x18800810 (irq = 140, base_baud = 460800) is a 16C950/954
0000:00:05.0: ttyS4 at I/O 0x18800818 (irq = 140, base_baud = 460800) is a 16C950/954
PCI: Enabling device 0000:00:0a.0 (0000 -> 0003)
0000:00:0a.0: ttyS5 at I/O 0x18800840 (irq = 140, base_baud = 460800) is a 16C950/954
0000:00:0a.0: ttyS6 at I/O 0x18800848 (irq = 140, base_baud = 460800) is a 16C950/954
0000:00:0a.0: ttyS7 at I/O 0x18800850 (irq = 140, base_baud = 460800) is a 16C950/954
0000:00:0a.0: ttyS8 at I/O 0x18800858 (irq = 140, base_baud = 460800) is a 16C950/954
by forcing the two module to avoid address collisions, thank to a secondary SoC supporting chip, that only adds an offset of { 0x00, 0x40 } depending on how you set a GPIO pin. This is really ugly, but it works. Well, ... it works ... actually, it allows the two cards to avoid collision, but, I cannot solve the shared irq problem, hence this stuff comes with extremely ugly interrupt handler in kernel space  :palm:
