Author Topic: Need help selecting a suitable SBC or similar for my project  (Read 2325 times)
Offline aabillTopic starter
« on: December 10, 2022, 03:51:04 pm »
Hello
My project is a one-off instrument panel for a kit car using a 12.3" 1920 x 720 display panel. I had intended to run RealDash (https://realdash.net/gallery.php on latest Raspbian (Debian Bullseye) on a RPI 4B but have hit a deal-breaker snag. I did not know at time of purchase that RPI hardware does not support suspend-to-RAM / resume (or even hibernate to disk). Two alternatives:
   keep the Pi continuously powered up is no good because when idle it draws 575mA which would too quickly flatten the car battery
   switch off when car not in use is no good because the Pi boot time is too long
I am looking at alternative boards but so far all those I have seen which do support suspend / resume do not support 1920 x 720.
Thoughts? Does anyone know of a suitable board, or have a useful suggestion...?
TIA
Bill A.
Offline Nominal Animal
Re: Need help selecting a suitable SBC or similar for my project
« Reply #1 on: December 11, 2022, 03:21:45 pm »
How about Odroid N2L with eMMC, based on Amlogic S922X SoC?
Or Odroid M1 based on Rockchip RK3568 SoC, with an eMMC module?
Amlogic, Samsung (Exynos), and Rockchip all push their kernel changes upstream to vanilla kernels, so you're not dependant on what the vendor provides.
I do not personally have either, but have been looking at both.  I do have some of the older ones (C1+, C2, HC1), and have had no issues in Linux with them, and I am somewhat familiar with both Amlogic SoCs and Mali GPUs.
(Specifically, I've been looking at both the N2L 4GByte with the 64GByte eMMC module for computation intensive stuff; and the Odroid M1 with a 16GByte eMMC module for media server type stuff.)
In particular, the Odroid M1 consumes only 0.06 watts (60mW, 5mA @ 12VDC) when suspended.  You will want to use an eMMC module for the core OS, even if you use a SATA SSD or a NVMe/PCIe M.2 2280 SSD card, to reduce boot times by bypassing PetitBoot.
For Odroid N2L, the eMMC module will be your boot and storage media, although you can use an USB 3 hard drive (or USB3 to SATA adapter) for external media.
While 1920x720 is not a native HDMI mode, it can be supported by setting the display mode using a custom HDMI/DVI modeset.  You do need the display module timings (or EDID data) to construct a suitable modeline, but that's all.
Moreover, you can use device tree overlays using the same mechanism to set up any SPI, I2C, PWM, or GPIO pins on the 2×20 expansion connector on N2L or M1.  You also probably want to set a custom bootlogo, since that's shown during bootup and wakeup from hibernation.
In any case, if you decide to go for an Odroid, do check both wiki.odroid.com and forum.odroid.com first, for the board.  Consider even registering, and asking there (on the proper sub-forum, possibly Odroid M1 > hardware and peripherals) before buying.  A link to the display module or its EDID information (timings) will be handy there.
A completely different approach would be to use (a custom) Android device instead of a Linux distribution.  The TV boxes (using e.g. Rockchip SoCs) have good hardware video decoding, but usually run from a ramdisk, and cannot suspend (due to lack of RAM) or hibernate (due to lack of storage).  Some of them boot rather quick, though.  Of course, Odroid M1 has images available for both Linux and Android, and you can brew your own for both (although it is quite a steep learning curve; so better start with the provided system images).
All things considered, although I'm only a hobbyist who never does automotive stuff, I'd carefully consider Odroid M1, and the 16GByte (or larger) eMMC module.
« Last Edit: December 11, 2022, 03:23:33 pm by Nominal Animal »
« Reply #2 on: December 12, 2022, 12:09:02 pm »
Many thanks for the info and links and suggestions and the trouble you've taken to respond so thoughtfully. I will look into all of it and will report progress here for the benefit of others.
Rgds, Bill
