TL;DR: At the bottom
It's august and there isn't much to develop at work so i started working again on an idea i had been toying with for some time: to build an automated test machine for our products.
I've put together all the reasonable requirements and most if not all the unreasonable and i'm confident i can do this. It's actually not the first tester i design/build but this time i want it to be Definitive in the sense that it can be expanded in the future.
As the brain of the whole thing i'm going to use a Beaglebone Black i bought a couple of years ago for this very purpose because
- I don't have to design the ADC/DAC structure around it, it's already in there -so no need to debug usb stacks or to use very slow uart links-
- builtin networking and graphics
- the PRUs, because i'll need pattern generators and a ways to send/receive data in non-common protocols. This saves me the pain of dealing with a dedicated decoder/encoder chip (which i can do, but if i don't need to, better.)
- The PRUs will also let me implement >1 pic programmers, without having to deal with the shitty production programmers we have.. they were good until we needed updates to support new pics. We are back on using several pickits.
So, in the past few days i dug out the BBB and after a number of tries with different images installed the latest available. I had to go on to the process of updating kernel and bootloader several times but now i have a truly up to date board.
This is good, because i found that the newer ways to control the hardware are much less confusing and convoluted.
This is bad, because almost all the documentation out there is for older kernels. It took me litterally days to figure out how to enable the pwm.
Also, i have the Exploring Beaglebone Black book, which i found very helpful as i went from ZERO linux experience to a bit of linux experience and once i figured out how to adapt the old ways to the new ones i was able to run all the examples.
I've come to a point where i have configured almost every pin i'll need, i can begin writing the first draft of an application that can run a test (without graphical interface, that will be developed on its own. Interface will call the test program, in case i decide to drop the GUI completely at some point)
but there are some issues i can't get around with, basically for my lack of knowledge of the whole linux thing. I hope that you can help me see the light
SO TO THE QUESTIONS
At this point i'm able to run a script to configure the pins as needed (config-pin command) and i can do that as a regular user.
However, i have to first enable the peripherals (like, as root, echo 0 > export in pwmchip1)
Question 1: How can i export/enable all the peripherals i need at boot?I figure that once they are enabled i can just run different script to map different pinouts. I'm not sure because on the web there are different ways for different kernels and i don't know what is the current way to do it.
Question 2: There is also another issue, the paths to many of the peripherals is different at every boot. Actually, it's the same up to a point. For example now PWM0 control is located at this path
/sys/devices/platform/ocp/48300000.epwmss/48300200.pwm/pwm/pwmchip1but at the next boot it could be at
/sys/devices/platform/ocp/48300000.epwmss/48300200.pwm/pwm/pwmchip4
I'm sure that there's a way to write a script that just enters the folder, as there is only one but i don't know how to do it. A good resource on writing bash scripts for the script rookie?
Question 3: The only (safe) way i know that writes/reads the peripherals is by writing/reading the associated files, my program should also be aware of the path. Would it be a good idea to also create symbolic links to the peripherals so my program just refers to those paths?
Also, is there a better and or faster (but still safe) way to access the peripherals? I know i can directly access the memory but i read this could lead to nasty issues when another process also wants to access the same resource.
Question 4: Obviously i need to be root in order to read/write the peripherals. sigh. However i tested and with chmod i can make it so i can access the files as a regular users. Naturally i have to do it at every boot. Would it be good or bad practice? Is there a better way?
Thank you for any help..
