Author Topic: intel Xscale PXA270 or StrongArm: any dev board?  (Read 2918 times)
Offline DiTBhoTopic starter
« on: May 16, 2025, 01:51:14 pm »
I am developing stuff for the Zaurus SL-C3xxx line, which is based on PXA270.
Unfortnately Sharp made a terrible firmware, interfaces written in Japanese, (after 20 years, still) incomprehensible flash partitions, unknown checksum, only 1.2Mbyte for the bootloader, and a lot of other very annoying stuff to develop.
Not to mention all the mess they made with the voltage regulators, the part of the circuitry that recharges the battery, and the GPIOs
Just to name one: if the microdrive breaks on C3000/C3100/C3200, the firmware won't let you do any updates until you replace the unit
What?!?  does updating the boot partition of the flash have to do with the microdrive? ... :-//
Just to name another, if you don't connect the power cable correctly, and it stays on battery, there are circuits that need special setup, to be done with GPIO lines, and if you don't do it correctly, your PDA will suddenly turn off.
(with a good chance of filesystem curruption)
In short, it's not at all the ideal situation to develop the linux kernel, nor your own bootloader, even working with uboot is very annoying.
It would be much more convenient to have a clean development board, without these annoyances introduced by Sharp.
What can I search on eBay/similar?
Re: intel Xscale PXA270 or StrongArm: any dev board?
« Reply #1 on: May 16, 2025, 01:52:16 pm »
armv5tel <------- xscale
armv4el <------- StrongArm
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #2 on: May 16, 2025, 02:14:23 pm »
it would be quicker to keep the body, display and keyboard and replace them with a RaspberryPi.
Offline langwadt
« Reply #3 on: May 16, 2025, 02:41:31 pm »
how about replace all of it? ;)
Online squadchannel
  • Country: jp
« Reply #4 on: May 16, 2025, 02:53:13 pm »
 :clap: but  :-X
« Reply #5 on: May 16, 2025, 02:59:28 pm »
if I wanted to use an rpi (whose core is >> Arm-v5) I wouldn't have opened the topic about Xscale  :-//
Online coromonadalix
« Reply #6 on: July 21, 2025, 02:24:49 pm »
« Last Edit: July 21, 2025, 02:27:41 pm by coromonadalix »
Offline djsb
« Reply #7 on: July 21, 2025, 02:42:02 pm »
I have one of those Sharp Zaurus SL-C3100 devices, no dev board though. You might have to design one from scratch, similarly to the way that the Pocket386 and weecee were done (x86 based on industrial modules). More info here https://www.vogons.org/viewtopic.php?t=99751&hilit=pocket386
They also discuss using dosbox with the Zaurus elsewhere on the forum.
Hertfordshire, UK
Retired University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V10+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 Operator, Electronics instructor. Credited KiCad French to English translator.
« Reply #8 on: July 21, 2025, 03:26:53 pm »
I know the Zaurus C1K and 3K hw very well, that's the target I am developing for.
There's very little interest, I post every now and then here.
I'm developing a much more flexible bootloader than anything I've seen in the past.
One of the things I really miss about the Zaurus is the ability to use a hardware debugger.
There seem to be JTAG signals, but I don't know anything about them.
That's why I am looking for a dev-board.
Offline Njk
  • Country: ru
« Reply #9 on: November 23, 2025, 06:59:29 am »
Palm Tungsten T3
« Reply #10 on: November 30, 2025, 08:47:58 pm »
Palm Tungsten T3
is there a way to take the control and reprogram the flash?
Offline Njk
  • Country: ru
« Reply #11 on: January 06, 2026, 11:02:50 pm »
There were software tools like JackSprat and JackFlash specifically for flash data manipulation, AFAIR
BTW, the T3 internals: https://www.pspilot.de/ppptun3/ppptun3.html
Actually, it uses PXA260, not exactly PXA270
« Reply #12 on: January 12, 2026, 12:38:05 pm »
Thanks! Super useful!
