Author Topic: Blank upload from PIC16F15376 Curiosity Nano  (Read 1054 times)
Offline PerranOak
« on: October 06, 2021, 01:45:22 pm »
I have tried to upload the memory from the nano board and get only zeros for all SFRs; config bits upload ok. So does the prog memory, I think - it's all in hex!
Any ideas why this would be?
Thanks.
[using Win8.1Pro (32bit), MPLAB X IDE v5.25]
Some light can never be seen!
RJD
Offline JPortici
Re: Blank upload from PIC16F15376 Curiosity Nano
« Reply #1 on: October 06, 2021, 04:52:27 pm »
mm.. what do you want to do exactly? I don't think you can read the ram content from the device, as you can read the program memory once it's programmed
Offline PerranOak
« Reply #2 on: October 08, 2021, 04:52:56 pm »
I just wanted to see if TRIS, ANSEL and so on were as I'd expected.
I thought I could just read them back into MPLAB from the running MCU but apparently you need to be in debug mode.
RJD
Offline JPortici
« Reply #3 on: October 09, 2021, 03:38:14 pm »
Yup, or you can dump the content over UART or something like that
The following users thanked this post: PerranOak
