Author Topic: Cytrence Kiwi - Unique KVM solution  (Read 110 times)
Offline SwiftEchoTopic starter
« on: September 13, 2024, 04:38:40 pm »
Hello Everyone,
We (Cytrence) are a small startup making unique and innovative gadgets. We just launched our first product Cytrence Kiwi! It is an advanced USB KVM solution that basically turns your laptop into the keyboard/mouse/display for your embedded devices.
Kiwi is the perfect companion for your Raspberry Pi 5. You don't need a display, a keyboard and mouse for the Pi any more. And you can take your Pi with you anywhere and not worry about how to connect it to a display.
Compared to traditional KVMs, Kiwi's is more portable, can be set up easily and more straightforward to use. You don't need to press a button to switch computers. You switch to another window on your laptop to use the other computer. And you can always keep an eye on the other computer since its screen is just another window on your laptop.
Compared to remote IP based KVM, Kiwi has better performance, requires no setup at all and is less expensive.
Check out the Kiwi video here: and our  website https://www.cytrence.com for the use cases.
If you're interested, we’re currently running a launch promotion, and you can use the code KIWI-86236510-P5 for an additional 5% off.
« Last Edit: September 13, 2024, 04:52:29 pm by SwiftEcho »
