I was playing around with an ESP32 yesterday, writing some code that communicated with an I2C slave device. I'm using the Arduino IDE and environment, as I couldn't be arsed to install all the ESP-IDF Eclipse toolchain. The slave device has an interrupt output signal that I wanted to handle, so I created an ISR (using Arduino framework attachInterrupt), within which I performed an I2C read of a register in the slave device. But whenever the ISR executed, the ESP32 would crash and reset, with "Guru Meditation Error: Core 1 panic’ed (Interrupt wdt timeout on CPU1)".
All the info I could find with a brief search was related to getting that error when you try to use delay, etc. within an ISR. But I'm not doing so here - just calling a sequence of IDF i2c_* functions. The only relation I can see is that i2c_master_cmd_begin takes a timeout value in ticks. Does that behind the scenes use similar mechanisms that don't work in an ISR?
I don't know anything about the inner workings of the ESP32 RTOS (FreeRTOS, right?), so I don't know how ISRs are actually handled or what mechanisms delay/timeout code would use that are incompatible with that, but I am curious.
