Author Topic: how to get the physical address of an MTD flash device on GNU/Linux?  (Read 4361 times)
Offline DiTBhoTopic starter
The router has a 128Mbyte parallel bus flash.
I can't figure out the memory map from the kernel driver source.
Specifically I can't figure out exactly what physical address the MTD flash is mapped to
Given a running kernel that sees the flash and populates /dev/mtd*
is there a way to figure it out without having to go crazy on layers and layers of unclear sources?
Re: how to get the physical address of an MTD flash device on GNU/Linux?
« Reply #1 on: January 28, 2025, 03:16:56 am »
(I'm writing a standalone bootloader)
Offline Nominal Animal
« Reply #2 on: January 28, 2025, 05:47:04 am »
dmesg (boot log) from a working Linux kernel, booted without quiet and with loglevel=8, should tell it IIRC.
If this is Mikrotik RB532A, then see v2.6.32/arch/mips/rb532/devices.c:plat_setup_devices(), which shows that nand_slot0_res start address is readl(IDT434_REG_BASE + DEV2BASE = 0x18010020), I believe (based on v2.6.32/arch/mips/include/asm/mac-rc32434/rb.h); i.e. described at physical address 0x18010020.  It makes sense that the 64 MiB (0x04000000 bytes) range is aligned, which leaves you with only 64 possible start addresses; and that because we know the RouterBOOT firmware is in ROM (and not Flash), 0x18000000 is the start address for the ROM region.  For a number of reasons, I believe the four (SRAM, Flash, ROM, dual-port memory) 64 MiB ranges are mapped at 0x10000000–0x13FFFFFF, 0x14000000–0x17FFFFFF, 0x18000000–0x1BFFFFFF, and 0x1C000000–0x1FFFFFFF.  Having the full IDT/Renesas RC32434 SoC documentation (for RB532/RB532A) would be quite handy here.  I've only seen the 54-page datasheet, and it only says it has glue logic for SRAM, Flash, ROM, dual-port memory, with four chip selects and a 26-bit address bus (64 M).)
« Reply #3 on: January 28, 2025, 12:38:48 pm »
Unfortunately, it only tells about
- the chip
- the partitions (which are hard-coded into the kernel)
- but not where the MTD is mapped.
RouterBOOT-2.8
What do you want to configure?
   d - boot delay
   k - boot key
   s - serial console
   o - boot device
   u - cpu mode
   f - try cpu frequency
   c - keep cpu frequency
   r - reset configuration
   e - format nand
   g - upgrade firmware <-------------
   i - board info
   p - boot protocol
   t - do memory testing
   x - exit setup
your choice:
The RouterBOOT firmware shows a menu with options.
Acording to option "g - update firmware", the rom0 should be "flash".
Oherwise how could it be reprogrammed to be updated?
(my speculation  :-// )
« Reply #4 on: January 28, 2025, 12:41:26 pm »
 * Boot loader, RouterBOOT, 1Mbit Flash chip
 * Attention, this information may not be correct!!!
This is the note I wrote in the "romdump" module
In the future I'll also implement a de-assembly to do some reverse engineering of (parts of) the firmware
Just because i'm tired of sending emails to the Mikrotik technical department about the various quirks
that their firmware manifests and never having answers.
After all, I started writing the bootloader because i can't boot kernels bigger than 8Mbyte,
neither from CF, nor from tftpboot, and i get strange messages that don't make any sense
Like "out of range" (wtf?!?), when the firmware should have a window of at least 32Mbyte on the ram!
Think my bootloader can alread load from serial (srec-load) up to 62Mbyte in ram without any problem!
Anyway, rom0 is not the problem, I am ready to dump its contents.
RouterBOOT booter 2.8
RouterBoard 532A
CPU frequency: 399 MHz
  Memory size:  64 MB
Press any key within 2 seconds to enter setup..
trying bootp protocol... OK
Got IP address: 192.168.1.41
resolved mac address 00:02:8A:26:B2:1C
transfer started  transfer ok, time=0.05s
setting up elf image... OK
jumping to kernel code
my-mon/mips, v0.1, Jan 2025
sys_mem: 00000000..03fffffc 64M
app_mem: 00400000..0047fffc 512k
# help
help he
ver
regs
halt
reset
memmd5 md5
memsize sz
memdump md
rom0dump ro0d
memtest mt
memedit me
load-srec lo19
# rom0dump
1fc00000: 00 00 00 00 00 00 00 00 07 00 00 10 00 00 00 00 | ................
1fc00010: 00 00 00 00 00 b0 00 00 00 10 00 00 00 00 01 00 | ................
1fc00020: 00 c0 01 00 00 10 00 00 00 68 80 40 00 00 00 00 | .........h.@....
1fc00030: 00 60 02 40 00 00 00 00 18 00 01 3c 24 10 41 00 | .`.@.......<$.A.
1fc00040: 40 10 01 3c 25 10 41 00 00 60 82 40 00 00 00 00 | @..<%.A..`.@....
1fc00050: 00 80 03 40 00 00 00 00 ff ff 01 3c f8 ff 21 34 | ...@.......<..!4
1fc00060: 24 18 61 00 03 00 63 34 00 80 83 40 00 00 00 00 | $.a...c4...@....
1fc00070: eb 04 11 04 00 00 00 00 c0 bf 08 3c 9c 00 08 25 | ...........<...%
1fc00080: ff 1f 01 3c ff ff 21 34 24 40 01 01 00 80 01 3c | ...<..!4$@.....<
1fc00090: 25 40 01 01 09 f8 00 01 00 00 00 00 03 b8 08 3c | %@.............<
1fc000a0: 3c 00 00 ad 16 01 00 10 00 00 00 00 00 00 00 00 | <...............
1fc000b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
1fc000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
1fc000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
« Reply #5 on: January 28, 2025, 12:42:17 pm »
The problems I have is all about the MTD flash
Routerboard 532 Flash Layout
Layer0       Hynix HY27UF081G2M Nand Flash 128MiB
Layer1       mtd0 kernel              mtd1 rootfs
Size         4MiB                     124MiB
Name         Routerboard NAND boot    rootfs
filesystem   YAFFS2                   YAFFS2
« Reply #6 on: January 28, 2025, 12:53:32 pm »
NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 92 at 0x000000b80000
Creating 2 MTD partitions on "gen_nand":
0x000000000000-0x000000400000 : "Routerboard NAND boot"
0x000000400000-0x000008000000 : "rootfs"
kernel 2.6.32
« Reply #7 on: January 28, 2025, 10:57:20 pm »
I fixed a cache issue and made further progress with the development mapping
eth0 is integrated SoC, the Mon seems to receive the mac-addr correctly.
# devinfo eth0
0x18060000..0x18063fff kseg1 size=0x00004000 eth0
# memdump.u32 eth0 0x1000 8
 420e8f01  0000000c  420e8f01  0000000c  420e8f01  0000000c  420e8f01  0000000c
The right macaddr is 00:0C:42:0E:8F:01
« Reply #8 on: January 28, 2025, 11:08:36 pm »
Board Info:
        Board type: 532A
   Firmware version: 2.8
       Memory size: 64 MB
  eth1 MAC address: 00:0C:42:0E:8F:01
  eth2 MAC address: 00:0C:42:0E:8F:02
  eth3 MAC address: 00:0C:42:0E:8F:03
« Reply #9 on: January 28, 2025, 11:17:12 pm »
I understand the coce for { serial, eth0, gpio }, and I can see them as expected, but I don't understand the code for the MTD NAND flash.
It looks like it's not a linearly mapped parallel device but rather something accessed via a registers (like with hard drives).
That lines about latch is not clear for me ...   :-//
I have to download the datasheet.
« Reply #10 on: January 28, 2025, 11:48:39 pm »
Hynix HY27UF081G2M
* mtd-HY27UF081G2M.PDF (481.49 kB - downloaded 153 times.)
« Reply #11 on: January 29, 2025, 12:53:23 am »
Do you have the IDT/Renesas Reference Manual for the IDT/Renesas 79RC32H435 SoC as used on the RB532A?
Renesas has the 54-page datasheet freely available, but the larger User Reference Manual (here) requires registration.  I bet it describes how the external memory is mapped/used.
« Reply #12 on: January 29, 2025, 01:22:41 am »
No i don't have. But I am willing to register there in order to download the UM.
Anyway, it's classic MIPS design, and my mon has no problem addressing { ram, rom0, eth0, gpio, wdt }.
They are all managed in kseg1-space, so { uncached, not mapped to the TLB }.
This stuff works.
The problem is the MTD chip.
According to its datasheet, the Hynix HY27UF081G2M has a complex fsm to multiplex address and data.
« Reply #13 on: January 29, 2025, 01:37:51 am »
Note the level of complexity.
mtd needs special handling, just to let you read its contents.
And then you have Yaffs to handle its contents as a file system.
I would need that mtd flash (mtd1 specifically)
to load a kernel, and to save environment data
like u-boot basically does.
Personally, I hate Yaffs' code quite a bit.
So, I think I'll pause this idea, and go ahead with CF and eth0 as boot devices
and let a working legacy GNU/Linux kernel (2.6.32) put my bootloader into mtd0.
« Reply #14 on: January 29, 2025, 01:53:35 am »
 *  KSEG1 addresses are uncached and are not translated by the MMU.
 *        KSEG1 is the only memory region that can be used at reset
 *        because the MMU and caches on MIPS CPUs must be configured by the boot code,
 *        which must be placed in KSEG1.
 *        KSEG1           0xa0000000
 *        KSEG1ADDR(a)    ( ((a) bitwiseAnd 0x1fffffffU) bitwiseOr KSEG1)
 *  KSEG0 provides an address region for the kernel that is cached,
 *        but not mapped by the MMU.
 *        KSEG0           0x80000000
 *        KSEG0ADDR(a)    ( ((a) bitwiseAnd 0x1fffffffU) bitwiseOr KSEG0)
 *  KSEG2 is used for kernel mode code that is mapped by the MMU and cached.
 *  KUSEG is used for user mode code that is mapped by the MMU and cached.
(app/mem.c, my notes)
# devinfo
0x00000000..0x03ffffff to_kseg1 size=0x04000000 ram
0x1fc00000..0x1fffffff to_kseg1 size=0x00400000 rom0
0x18010020..0x1801002f to_kseg1 size=0x00000010 mtd_latch
0x18058000..0x1805ffff to_kseg1 size=0x00008000 uart0
0x18030030..0x1803003f to_kseg1 size=0x00000010 watchdog
0x18060000..0x180603ff to_kseg1 size=0x00000400 eth0
0x18a10800..0x18a1080f to_kseg1 size=0x00000010 CF
0x18050000..0x1805000f to_kseg1 size=0x00000010 gpio
0x18080000..0x1808ffff to_kseg1 size=0x00010000 pci
The addresses you see here must all be translated to the kseg1 region.
Above you see how to do it with a macro.
The dev-sizes, except the ram one which is correct, need to be reviewed.
« Last Edit: January 29, 2025, 02:19:27 am by DiTBho »
« Reply #15 on: January 29, 2025, 02:49:27 pm »
#include <linux/init.h>
#include <linux/mtd/nand.h>
#include <linux/mtd/mtd.h>
#include <linux/mtd/partitions.h>
#include <linux/delay.h>
#include <asm/io.h>
#include <asm/irq.h>
#include <asm/bootinfo.h>
#define IDT434_REG_BASE ((volatile void *) KSEG1ADDR(0x18000000))
#define GPIOF 0x050000
#define GPIOC 0x050004
#define GPIOD 0x050008
#define GPIO_RDY (1 << 0x08)
#define GPIO_WPX (1 << 0x09)
#define GPIO_ALE (1 << 0x0a)
#define GPIO_CLE (1 << 0x0b)
#define DEV2BASE 0x010020
#define LO_WPX   (1 << 0)
#define LO_ALE   (1 << 1)
#define LO_CLE   (1 << 2)
#define LO_CEX   (1 << 3)
#define LO_FOFF  (1 << 5)
#define LO_SPICS (1 << 6)
#define LO_ULED  (1 << 7)
#define MEM32(x) *((volatile unsigned *) (x))
static void __iomem *p_nand;
extern void changeLatchU5(unsigned char orMask, unsigned char nandMask);
static int rb500_dev_ready(struct mtd_info *mtd)
        return MEM32(IDT434_REG_BASE + GPIOD) & GPIO_RDY;
 * hardware specific access to control-lines
 * ctrl:
 *     NAND_CLE: bit 2 -> bit 3
 *     NAND_ALE: bit 3 -> bit 2
static void rbmips_hwcontrol500(struct mtd_info *mtd, int cmd,
                                unsigned int ctrl)
        struct nand_chip *chip = mtd->priv;
        unsigned char orbits, nandbits;
        if (ctrl & NAND_CTRL_CHANGE) {
                orbits = (ctrl & NAND_CLE) << 1;
                orbits |= (ctrl & NAND_ALE) >> 1;
                nandbits = (~ctrl & NAND_CLE) << 1;
                nandbits |= (~ctrl & NAND_ALE) >> 1;
                changeLatchU5(orbits, nandbits);
        if (cmd != NAND_CMD_NONE)
                writeb(cmd, chip->IO_ADDR_W);
static struct mtd_partition partition_info[] = {
              name:"RouterBoard NAND Boot",
              offset:0,
      size:4 * 1024 * 1024},
              name:"RouterBoard NAND Main",
              offset:MTDPART_OFS_NXTBLK,
static struct mtd_info rmtd;
static struct nand_chip rnand;
static unsigned init_ok = 0;
unsigned get_rbnand_block_size(void)
        if (init_ok)
                return rmtd.writesize;
        else
                return 0;
EXPORT_SYMBOL(get_rbnand_block_size);
int __init rbmips_init(void)
        int *b;
        memset(&rmtd, 0, sizeof(rmtd));
        memset(&rnand, 0, sizeof(rnand));
        printk("RB500 nand\n");
        changeLatchU5(LO_FOFF | LO_CEX,
                      LO_ULED | LO_ALE | LO_CLE | LO_WPX);
        rnand.cmd_ctrl = rbmips_hwcontrol500;
        rnand.dev_ready = rb500_dev_ready;
        rnand.IO_ADDR_W = (unsigned char *)
            KSEG1ADDR(MEM32(IDT434_REG_BASE + DEV2BASE));
        rnand.IO_ADDR_R = rnand.IO_ADDR_W;
        p_nand = (void __iomem *) ioremap((void *) 0x18a20000, 0x1000);
        if (!p_nand) {
                printk("RBnand Unable ioremap buffer");
                return -ENXIO;
        rnand.ecc.mode = NAND_ECC_SOFT;
        rnand.chip_delay = 25;
        rnand.options |= NAND_NO_AUTOINCR;
        rmtd.priv = &rnand;
        b = (int *) KSEG1ADDR(0x18010020);
        printk("dev2base 0x%08x mask 0x%08x c 0x%08x tc 0x%08x\n", b[0],
               b[1], b[2], b[3]);
        if (nand_scan(&rmtd, 1) && nand_scan(&rmtd, 1)
            && nand_scan(&rmtd, 1) && nand_scan(&rmtd, 1)) {
                printk("RBxxx nand device not found\n");
                iounmap((void *) p_nand);
                return -ENXIO;
        add_mtd_partitions(&rmtd, partition_info, 2);
        init_ok = 1;
        return 0;
module_init(rbmips_init);
(driver/mtd/rbmipsnand.c)
This is the old mtd_nand driver used in kernels < 2.6.23
Not mainline, external patch.
See, that bloody nand chip needs latch support + GPIO support to operate.
The following users thanked this post: Nominal Animal
« Reply #16 on: January 30, 2025, 11:37:27 pm »
# cf_info
Checking for any CF drive ...
Sent IDENTIFY .. ready
# devdump cf_buff 0 512
00000000: 84 8a 07 ae 00 00 00 10 00 00 02 40 00 3f 00 1e | ...........@.?..
00000010: 3d 20 00 00 54 53 53 32 30 30 33 32 30 38 30 36 | = ..TSS200320806
00000020: 30 36 30 32 32 38 34 31 00 02 00 02 00 04 32 30 | 06022841......20
00000030: 30 37 31 31 31 36 43 46 20 31 47 42 20 20 20 20 | 071116CF 1GB
00000040: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 |
00000050: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 80 01 |               ..
00000060: 00 00 02 00 00 00 02 00 00 00 00 03 07 ae 00 10 | ................
00000070: 00 3f 3d 20 00 1e 01 00 3d 20 00 1e 00 00 00 00 | .?= ....= ......
00000080: 00 03 00 00 00 00 00 78 00 78 00 00 00 00 00 00 | .......x.x......
00000090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000000a0: 00 00 00 00 00 01 00 00 00 02 00 01 00 00 00 02 | ................
000000b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000000c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000000d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000000e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000000f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000140: 00 00 00 00 00 00 04 92 00 1b 00 00 00 00 00 00 | ................
00000150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
00000190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000001a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000001b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000001c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000001d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000001e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
000001f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 | ................
I had little time today, but I made some progress.
I implemented the low-level part of the CF-pATA driver
which is not documented, and has a few weird things.
Seems working, I mean ...
GNU/Linux identifies the Compact Flash on /dev/sda as "CF 1GB"
# cat /sys/block/sda/device/model
CF 1GB
The SoC doesn't come with any built-in ATA driver.
However, for absurd reasons there seems to be a pATA controller somehow connected to the SoC
which operates in "legacy mode", it's memory mapped, and exports a 512byte buffer at each disk command.
The data is 16bit BigEndian, while the CPU is LittleEndian, so {byte0, byte1} need to be swapped {byte1, byte0}
I still have to clean up the various modules, but now the machine_restart vector also works.
# restart
bye bye
RouterBoard 532A
  Memory size:  64 MB
« Reply #17 on: January 30, 2025, 11:43:45 pm »
I followed this webpage, ATA_PIO_Mode (legacy mode)
Adapted to my use-case.
