Products => Computers => Embedded Computing => Topic started by: simon christo on May 03, 2024, 12:18:29 am
Hi there!!
What's the story, on Grahical Calcultors.Im thinking on purchasing one, and I'm not sure, which one to buy??
Tah, Simon.
I'm not sure if the latest calculators are going to run BASIC. TI has many OLDER calculators (such as the TI89 PLATINUM etc) that run TIBASIC. The latest TI NSPIRE CX CAS runs python. Not sure about other brands.
Thanks, for your reply,
Simon.
The HP-prime has TI-basic
https://youtu.be/FJwkoDKlh8Q
Ill, check it out,
Thanks Simon.
GW-BASIC like? -> SHARP PC-E500
I had a post, a while ago, on USB C connectors not locking in.Some people would have seen it.
Anyway, I found so much dirt and grime in the socket - on the Mobile, that it desperatly needed
a clean-out.After, loosining the dirt, and using Compressed Air (drained from containing Water),
it locks in fine!!
Probally, using a Old Medium Toothbrush, to 'prod' the dirt out, wouldn't go astray.
Tah, Simon.
