Author Topic: NAS, Raspberry or Synology.  (Read 33707 times)
Offline DiTBho
Re: NAS, Raspberry or Synology.
« Reply #100 on: October 23, 2023, 04:43:16 am »
  • let's face it: usb sticks are not reliable, here
  • SSD vs HDD for data security, here
  • Do you trust consumer grade SSD to store back up? here
(topics on EEVblog  :o :o :o )
« Last Edit: October 23, 2023, 04:48:27 am by DiTBho »
Offline Postal2
« Reply #101 on: October 23, 2023, 05:14:07 am »
Thank you father.
I recommend use Seagate 7200.7 for backup.
Offline luiHSTopic starter
« Reply #102 on: November 10, 2023, 06:07:14 pm »
Does anyone know or has tested if transcoding is possible with a Rasbperry Pi 5 used as a NAS to play videos on client devices?
Any recommendations for a cheap commercial NAS (Synology, QNAP...) that does hardware transcoding?
Offline Postal2
« Reply #103 on: November 10, 2023, 09:16:37 pm »
...to play videos on client devices?
... hardware transcoding?
I have a cheapest solution for you.
This cheapest motherboard with J1900 with passive cool (you can onscrew pi5-fan if you love it).
https://aliexpress.com/item/1005005888045324.html
Next device is a cheap hdmi-usb capture like this:
https://aliexpress.com/item/4001010505067.html
That construction will make all you need.
« Last Edit: November 22, 2023, 06:08:42 pm by Postal2 »
