hi
I am writing a monitor program (with a built-in gdb-stub) and would like to use microdrives and parallel ATA disks.
I googled, but I was not able to find comphrensive documentation with detailed "ATA command" and parameters, with use examples if it's possible.
/* ATA device commands */
ATA_CMD_DEV_RESET = 0x08, /* ATAPI device reset */
ATA_CMD_CHK_POWER = 0xE5, /* check power mode */
ATA_CMD_STANDBY = 0xE2, /* place in standby power mode */
ATA_CMD_IDLE = 0xE3, /* place in idle power mode */
ATA_CMD_EDD = 0x90, /* execute device diagnostic */
ATA_CMD_DOWNLOAD_MICRO = 0x92,
ATA_CMD_DOWNLOAD_MICRO_DMA = 0x93,
ATA_CMD_NOP = 0x00,
ATA_CMD_FLUSH = 0xE7,
ATA_CMD_FLUSH_EXT = 0xEA,
ATA_CMD_ID_ATA = 0xEC,
ATA_CMD_ID_ATAPI = 0xA1,
ATA_CMD_SERVICE = 0xA2,
ATA_CMD_READ = 0xC8,
ATA_CMD_READ_EXT = 0x25,
ATA_CMD_READ_QUEUED = 0x26,
ATA_CMD_READ_STREAM_EXT = 0x2B,
ATA_CMD_READ_STREAM_DMA_EXT = 0x2A,
ATA_CMD_WRITE = 0xCA,
ATA_CMD_WRITE_EXT = 0x35,
ATA_CMD_WRITE_QUEUED = 0x36,
ATA_CMD_WRITE_STREAM_EXT = 0x3B,
ATA_CMD_WRITE_STREAM_DMA_EXT = 0x3A,
ATA_CMD_WRITE_FUA_EXT = 0x3D,
ATA_CMD_WRITE_QUEUED_FUA_EXT = 0x3E,
ATA_CMD_FPDMA_READ = 0x60,
ATA_CMD_FPDMA_WRITE = 0x61,
ATA_CMD_NCQ_NON_DATA = 0x63,
ATA_CMD_FPDMA_SEND = 0x64,
ATA_CMD_FPDMA_RECV = 0x65,
ATA_CMD_PIO_READ = 0x20,
ATA_CMD_PIO_READ_EXT = 0x24,
ATA_CMD_PIO_WRITE = 0x30,
ATA_CMD_PIO_WRITE_EXT = 0x34,
ATA_CMD_READ_MULTI = 0xC4,
ATA_CMD_READ_MULTI_EXT = 0x29,
ATA_CMD_WRITE_MULTI = 0xC5,
ATA_CMD_WRITE_MULTI_EXT = 0x39,
ATA_CMD_WRITE_MULTI_FUA_EXT = 0xCE,
ATA_CMD_SET_FEATURES = 0xEF,
ATA_CMD_SET_MULTI = 0xC6,
ATA_CMD_PACKET = 0xA0,
ATA_CMD_VERIFY = 0x40,
ATA_CMD_VERIFY_EXT = 0x42,
ATA_CMD_WRITE_UNCORR_EXT = 0x45,
ATA_CMD_STANDBYNOW1 = 0xE0,
ATA_CMD_IDLEIMMEDIATE = 0xE1,
ATA_CMD_SLEEP = 0xE6,
ATA_CMD_INIT_DEV_PARAMS = 0x91,
ATA_CMD_READ_NATIVE_MAX = 0xF8,
ATA_CMD_READ_NATIVE_MAX_EXT = 0x27,
ATA_CMD_SET_MAX = 0xF9,
ATA_CMD_SET_MAX_EXT = 0x37,
ATA_CMD_READ_LOG_EXT = 0x2F,
ATA_CMD_WRITE_LOG_EXT = 0x3F,
ATA_CMD_READ_LOG_DMA_EXT = 0x47,
ATA_CMD_WRITE_LOG_DMA_EXT = 0x57,
ATA_CMD_TRUSTED_NONDATA = 0x5B,
ATA_CMD_TRUSTED_RCV = 0x5C,
ATA_CMD_TRUSTED_RCV_DMA = 0x5D,
ATA_CMD_TRUSTED_SND = 0x5E,
ATA_CMD_TRUSTED_SND_DMA = 0x5F,
ATA_CMD_PMP_READ = 0xE4,
ATA_CMD_PMP_READ_DMA = 0xE9,
ATA_CMD_PMP_WRITE = 0xE8,
ATA_CMD_PMP_WRITE_DMA = 0xEB,
ATA_CMD_CONF_OVERLAY = 0xB1,
ATA_CMD_SEC_SET_PASS = 0xF1,
ATA_CMD_SEC_UNLOCK = 0xF2,
ATA_CMD_SEC_ERASE_PREP = 0xF3,
ATA_CMD_SEC_ERASE_UNIT = 0xF4,
ATA_CMD_SEC_FREEZE_LOCK = 0xF5,
ATA_CMD_SEC_DISABLE_PASS = 0xF6,
ATA_CMD_CONFIG_STREAM = 0x51,
ATA_CMD_SMART = 0xB0,
ATA_CMD_MEDIA_LOCK = 0xDE,
ATA_CMD_MEDIA_UNLOCK = 0xDF,
ATA_CMD_DSM = 0x06,
ATA_CMD_CHK_MED_CRD_TYP = 0xD1,
ATA_CMD_CFA_REQ_EXT_ERR = 0x03,
ATA_CMD_CFA_WRITE_NE = 0x38,
ATA_CMD_CFA_TRANS_SECT = 0x87,
ATA_CMD_CFA_ERASE = 0xC0,
ATA_CMD_CFA_WRITE_MULT_NE = 0xCD,
ATA_CMD_REQ_SENSE_DATA = 0x0B,
ATA_CMD_SANITIZE_DEVICE = 0xB4,
ATA_CMD_ZAC_MGMT_IN = 0x4A,
ATA_CMD_ZAC_MGMT_OUT = 0x9F,
/* marked obsolete in the ATA/ATAPI-7 spec */
ATA_CMD_RESTORE = 0x10,
(from ata.h, Linux kernel)
The alternative is to extract information from the linux kernel sources, only that they are quite messed up, as usual.
Or from uboot sources, which is inspired by the linux kernel, and therefore the same level of confusion...
#define ATA_CMD_READ_PIO 0x20 // works on Hitachi 4G, CF1G, panics on Seagate 5G!!!!
#define ATA_CMD_READ_PIO_EXT 0x24 // not used
#define ATA_CMD_READ_DMA 0xC8 // not used
#define ATA_CMD_READ_DMA_EXT 0x25 // not used
#define ATA_CMD_WRITE_PIO 0x30 // works on Hitachi 4G, CF1G, panics on Seagate 5G!!!!
#define ATA_CMD_WRITE_PIO_EXT 0x34 // not used
#define ATA_CMD_WRITE_DMA 0xCA // not used
#define ATA_CMD_WRITE_DMA_EXT 0x35 // not used
#define ATA_CMD_CACHE_FLUSH 0xE7 // does not work with MicroDrive Seagate 5Gbyte
#define ATA_CMD_CACHE_FLUSH_EXT 0xEA // not used
#define ATA_CMD_PACKET 0xA0 // not used, wtf?
#define ATA_CMD_IDENTIFY_PACKET 0xA1 // not used, wtf?
#define ATA_CMD_IDENTIFY 0xEC // works!!!
#define ATA_CMD_SPINSDOWN 0xE0 // does nothing?!?
#define ATA_CMD_SPINSUP 0xE1 // does not work with MicroDrive Seagate 5Gbyte
This is what i have already implemented.
