Not as powerful as the RPi Zero 2, for instance, and more expensive. But if you wanna play with a RV64 SoC running Linux, this would look like a fun alternative to the pretty expensive (which admittedly, is a whole other territory) SiFive boards. I do not know of any other, easily available RV64-based board able to run Linux, apart from this and the SiFive ones. If anyone does...
