Author Topic: Sipeed Lichee RV  (Read 2257 times)
Offline SiliconWizardTopic starter
Sipeed Lichee RV
« on: January 15, 2022, 06:35:04 pm »
Available there:
https://www.seeedstudio.com/lichee-RV-Nezha-CM-Allwinner-D1-SoC-1-14-Inch-SPI-LCD-p-5254.html
Can be found on Aliexpress, along with a small base board, for about $30.
https://linux-sunxi.org/D1
Not as powerful as the RPi Zero 2, for instance, and more expensive. But if you wanna play with a RV64 SoC running Linux, this would look like a fun alternative to the pretty expensive (which admittedly, is a whole other territory) SiFive boards. I do not know of any other, easily available RV64-based board able to run Linux, apart from this and the SiFive ones. If anyone does...
