Author Topic: Raspberry Pi's DRM blocks RAM upgrades  (Read 572 times)
Offline madiresTopic starter
  • A qualified hobbyist ;)
« on: October 18, 2026, 06:54:33 pm »
Sources:
- Raspberry Pi puts digital handcuffs on RAM upgrades - https://www.fsf.org/blogs/community/2026-raspberry-pi
- Raspberry Pi Locks Down RAM Upgrades - https://hackaday.com/2026/09/22/raspberry-pi-locks-down-ram-upgrades/
Offline langwadt
Re: Raspberry Pi's DRM blocks RAM upgrades
« Reply #1 on: October 18, 2026, 07:05:30 pm »
and what microscopic number of people is that going to affect?
Offline SiliconWizard
« Reply #2 on: October 18, 2026, 07:14:37 pm »
Yes Jeff Geerling talked about it a while ago. This sounds a bit nasty but it's understandable, as upgrading RAM on RPi boards means reworking them, which would void the warranty anyway, and they were apparently concerned about dodgy resellers doing the rework behind their back and selling the upgraded boards to customers without even mentioning it. And that's fair: it would definitely have happened, it was already happening before they decided to implement this, due to the RAM "crisis".
If we want to avoid this kind of lock on products, our only real bet is to go for products which have fully open-source firmware, which was never the case for the RPi SBCs AFAIK. (They played the open-source game much more nicely with their RP2xxx MCUs.)
Interestingly, most GPU vendors do not implement this kind of lock and most current GPUs can be RAM-upgraded by reworking them and soldering higher-capacity RAM chips. But the work involved and associated cost is much higher than that of upgrading RAM on a RPi SBC, so this is probably a lot less of a real concern.
