Author Topic: This is an armclang bug, isn't it? [It wasn't]  (Read 2808 times)
Offline emece67Topic starter
« on: August 27, 2021, 01:59:51 pm »
« Last Edit: August 19, 2022, 05:56:55 pm by emece67 »
Offline ataradov
    • Personal site
Re: This is an armclang bug, isn't it?
« Reply #1 on: August 27, 2021, 04:39:38 pm »
I'd say this is a bug. I see nothing wrong with this code.
Does it do the same if instead of a literal parameter you create a structure on the stack and pass that?
Alex
« Reply #2 on: August 27, 2021, 07:13:19 pm »
« Last Edit: August 19, 2022, 04:39:24 pm by emece67 »
Offline ataradov
    • Personal site
« Reply #3 on: August 27, 2021, 08:19:14 pm »
What MCU/core you are targeting?
According to this https://www.keil.com/support/man/docs/armclang_ref/armclang_ref_sam1444138667173.htm:
-munaligned-access is the default for architectures that support unaligned accesses to data. This default applies to all architectures supported by Arm Compiler 6, except Armv6‑M, and Armv8‑M without the Main Extension.
So if you are targeting Cortex-M4/M7, then it will default to unaligned access, so it has to be enabled in the core. Or pass -mno-unaligned-access flag.
Alex
The following users thanked this post: emece67, I wanted a rude username, DiTBho
« Reply #4 on: August 27, 2021, 10:32:45 pm »
« Last Edit: August 19, 2022, 04:39:32 pm by emece67 »
