Author Topic: What is the difference between build and compile  (Read 5682 times)
Offline BlogRahulTopic starter
  • Country: in
« on: August 11, 2022, 10:14:35 am »
As I know compiler convert source code into executable code
What is the difference between build and compile in context of this page   https://www.raspberrypi.com/documentation/computers/linux_kernel.html ?
Online tggzzz
Re: What is the difference between build and compile
« Reply #1 on: August 11, 2022, 10:27:54 am »
Gurgle is your friend.
Do you have a more specific question?
The following users thanked this post: BlogRahul
Offline PeterG
« Reply #2 on: August 11, 2022, 10:37:08 am »
This is the best explanation i have found.
"Compiling is the act of turning source code into object code.
Linking is the act of combining object code with libraries into a raw executable.
Building is the sequence composed of compiling and linking, with possibly other tasks such as installer creation."
Source:- https://stackoverflow.com/questions/2650168/building-vs-compiling-java#:~:text=Build%20is%20a%20compiled%20version,the%20program%20can%20be%20executed.
Testing one two three...
Offline gnif
« Reply #3 on: August 11, 2022, 10:37:54 am »
While the RPi is a Microcontroller, you're asking a general operating system/programming question that is not microcontroller specific.
Locking thread, if you still want to ask this, please open it under an appropriate topic in https://www.eevblog.com/forum/general-computing/
The following users thanked this post: pcprogrammer
