I'm using the AdaFruit ILI9341 libraries. with a 240x320 display. Small fonts are fine, however when using for example font size 5, some characters an "X" and "Z" are good example of the blocky apperance.
I tried unsuccessfully to get the PaulStoffregen fonts library working but it does not appear to work at least not with my setup and MKR Zero.
Does anyone know of a working MkrZero / ILI9341 fonts library with nicer looking large fonts or suggestions on a solution.
Much appreciated, Jester
