Electronics => FPGA => Topic started by: nockieboy on October 16, 2019, 01:42:20 pm
Title: FPGA VGA Controller for 8-bit computer
Post by: nockieboy on October 16, 2019, 01:42:20 pm
Hi all,
Don't know if anyone has noticed, but Grant Searle's website (http://searle.hostei.com/grant/z80/ (http://searle.hostei.com/grant/z80/)) seems to have blinked out of existence.
This poses a problem for me as I didn't download the code or related material for his FPGA Multicomp design.  I'm now thinking about my first foray into FPGAs by creating a VGA driver for my DIY computer, but it seems a big 'leg up' has now disappeared from the interweb.  |O
Does anyone have the code for the Multicomp?  I was hoping to sift through it and either adapt or just learn from Grant's implementation of the graphics driver in VHDL.
For clarity, I've got an Altera Cyclone II EP2C5 which I was hoping to use to make a VGA controller, either with enough on-board RAM (or a discrete SRAM memory chip) for a frame buffer in the region of 128 KB, to allow a resolution of (up to) 640x480 with two colours, or down to 160x120 with 256 colours and double-buffering.
I've since ordered a Xilinx Spartan 6 as well, thinking it might be even more overpowered for the job.  ;D
I've seen designs where the controller outputs an RGB signal directly to the VGA connector via resistors, and others where the controller passes data from the frame buffer to a video DAC.  Bearing in mind I'm using 8-bit data (so a maximum of 256 colours unless I start doubling-up on bytes-per-pixel in the frame buffer), the DACs I've seen seem to expect a lot more bits on their inputs...
I'm also wondering about how best to interface to the Z80 computer, too.  Would it be best to send data to the VGA controller via IO calls and let the VGA controller handle the frame buffer?  I'm not a fan of restricting the Z80's access to memory for 75% of its runtime whilst the VGA controller reads from a frame buffer in the Z80's memory space, and dual-port RAM is too expensive for my needs.
Any thoughts, comments etc. appreciated!  I'm not very experienced at this stuff having spent the last two years learning electronics by building a DIY Z80-based computer...
EDIT:
For anyone interested, this topic evolved into a fully developed video card using the EP4CE10 FPGA from Altera.  The github for this project is here: https://github.com/nockieboy/gpu (https://github.com/nockieboy/gpu)
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: SiliconWizard on October 16, 2019, 01:54:57 pm
Does this contain what you need? https://github.com/wsoltys/multicomp
Post by: nockieboy on October 16, 2019, 02:55:18 pm
Ah yes, thanks SiliconWizard!  :-+  That gives me a fair starting point to work from, I think.  As I'm only going to be building the video driver circuit, hopefully I'll be able to make use of some more RAM space.  Will have to go start on some VHDL/FPGA tutorials as I'm starting from scratch with them.
Post by: dferyance on October 16, 2019, 05:43:02 pm
Just a few thoughts / ideas.
The resistor ladder dacs are popular and mostly work fine. However I have run into their limitations in my own work. I've been doing VGA with 256 color, but a palette system out of 24-bit color. I often see obvious color differences due to the limited number of bits in the resistor ladder. If you can live with this, they work great and are simple. It sounds like you are doing 256 bit color without a palette so you should be fine, but if you extend it latter this is a limitation you will run into.
For interfacing the two, do you need framebuffer-level access? For example, the original gameduino outputs VGA but takes in different drawing commands (over SPI). This way you aren't having read and transmit entire framebuffers over a slow bus.
Post by: NorthGuy on October 16, 2019, 08:10:33 pm
Why VGA? It would be more natural to go digital.
Post by: jhpadjustable on October 16, 2019, 08:27:06 pm
Got a back-of-napkin design for that?
Post by: kizmit99 on October 16, 2019, 09:14:56 pm
The CylconeII OP mentioned supports 3.3V LVDS outputs which can (pretty easily) be used to drive an HDMI monitor.  The resolutions OP mentioned would have pixel clocks below the HDMI minimums, so would require pixel replication to get into the supported rates.  But I suspect that some quick math would find something acceptable without blowing past the output speed limit on the FPGA.
Both of these are useful examples:
http://hamsterworks.co.nz/mediawiki/index.php/Minimal_HDMI (http://hamsterworks.co.nz/mediawiki/index.php/Minimal_HDMI)
https://www.fpga4fun.com/HDMI.html (https://www.fpga4fun.com/HDMI.html)
Post by: Canis Dirus Leidy on October 16, 2019, 11:00:09 pm
There were several examples at marsohod.org (in Russian):
Connecting MAXII (EPM240) to a LCD panel with a parallel RGB interface (https://marsohod.org/projects/plata1/172-phframe1)
Driving LVDS interface with MAXII (https://marsohod.org/projects/plata1/173-phframe2) (dirty hack, due to lack of PLL in EPM240, but works).
DIY framebuffer (from old SDRAM) for DIY photoframe (https://marsohod.org/projects/plata1/174-phframe3)
HDMI interface with MAX10 (https://marsohod.org/projects/proekty-dlya-platy-marsokhod3/307-max10-hdmi)
P.S. Also look for "Circuit Design and Simulation with VHDL". In particular, chapters 16 "VHDL Design of DVI Video Interfaces" and 17 "VHDL Design of FPD-Link Video Interfaces".
Post by: jhpadjustable on October 16, 2019, 11:35:23 pm
Well. I learned something today! I had preferred the VGA idea because it's more "tangible" and offers easier-to-read feedback in case of errors, but if it's that easy, objection withdrawn. :-+
Post by: Codex on October 17, 2019, 03:59:37 am
Web Archive has a copy :)
https://web.archive.org/web/20181123194029/http://searle.hostei.com/grant/index.html (https://web.archive.org/web/20181123194029/http://searle.hostei.com/grant/index.html)
He has a mirror here.
http://zx80.netai.net/grant/index.html (http://zx80.netai.net/grant/index.html)
http://searle.wales/ (http://searle.wales/)
twitter for updates and links to the mirror :)
https://twitter.com/zx80nut?lang=en (https://twitter.com/zx80nut?lang=en)
Post by: CJay on October 17, 2019, 05:22:24 am
Hi all,
Bugger.
Wish I'd archived it all now.
Post by: hamster_nz on October 17, 2019, 06:21:39 am
DVI-D is a direct replacement of the VGA signals with streams of bits. It is from the FPGA designers point of view just a little bit bolted onto the end of the video pipeline, rather than the DACs.
The only trick (if you can call it that) I'd the high speed digital signals from the FPGA to the connector, but for standard 640x480 that isn't too exacting, and you can get away with quite a few sins. The raw bit rate is 250Mb/s per channel, so bits are around meter long on the wire (ignoring velocity factors and so on), and the protocol is designed to resist errors.
A few mm of length mismatch or an impedance bump is far less a problem then at 1080p rates.
Post by: nockieboy on October 17, 2019, 01:03:29 pm
Bugger.
Don't panic CJay - Codex has linked to some excellent mirrors and I can personally vouch for the z80.netai.net one, it's all there.  :-+
Post by: nockieboy on October 17, 2019, 01:32:29 pm
A resistor ladder is the simplest way to get a colour output I guess, but it seems a little... inexact... and dependant on resistor tolerances and chosen values, so when I saw an example using a video DAC I thought I'd likely want to give that a try.
I'm not sure I understand colour encoding/generation properly, so would appreciate correction if I'm wrong, but whilst thinking about the frame buffer design the other day I gave some thought to how the data would be stored in the frame buffer.  Storing discrete values for R, G and B channels using a bit (or bits) seems a little wasteful.  If I want 64 colours for example, I could use 2 bits per channel for 6 bits of RGB per pixel, or one byte per pixel (with a couple of bits spare) in the frame buffer.  Thing is, if I want to go to 3 bits per channel or more, I'm looking at two bytes per pixel and doubling the memory requirement for a single frame.
So I hit on the idea of using a look-up table for the colours.  Is that the 'palette system' you're referring to?  Basically, I'd have one byte per pixel in the frame buffer.  Each byte would be a value between 0 and 255, so when the 'pixel' is read from the frame buffer, the value would be used to look up the RGB value in the LUT, which could be anything up to 24-bit values that would get passed out to the DAC...
... would that work?  The other thing is, I don't really know anything about FPGAs - I get the impression they're fast, so using a LUT for the RGB values shouldn't slow the FPGA down so much that it couldn't keep up with the clock?
The FPGA I have currently isn't up to what I want from it, really - it's an Altera Cyclone II EP2C5T144, so doesn't have the RAM I need for a frame buffer for anything more than straight text display.  I'm wondering if using an external SRAM chip would be the way to go for the frame buffer?  Would something with an access time <15ns for example be fast enough?  Alternatively, I'm waiting on a Xilinx Spartan 6 which I'll likely develop on instead. That has a 32MB SDRAM on its board, I might experiment using that for the frame buffer if the RAM in the Spartan isn't enough (though I think I can make the internal RAM dual-port, which is highly desirable for a frame buffer?)
I'm intending to interface the VGA controller with my Z80-based computer running at 8 MHz.   I'm not hung-up on direct frame-buffer access for the Z80 at all - in fact, I'd rather not mess with the Z80's memory space at all if another interface method is fast enough.  Unless anyone here tells me otherwise, I'm going the route of having the Z80 send commands to the FPGA, which it will interpret and modify the frame buffer's contents accordingly.  How the Z80 does that, I haven't decided yet, but I could use a serial connection from the Z80's SIO, I could use my Z80's hardware I2C port, or a more direct connection using OUT commands and the data bus, which I'm erring towards as I feel it will be the quickest of the three.  An SPI interface isn't currently an option, but may be later if I ever finish a hardware SPI interface for my system.
Post by: dferyance on October 17, 2019, 01:40:32 pm
Yes, that is exactly right. The palette is a LUT. A 256 byte LUT can pretty easily fit in a FPGA so the lookup can be quite fast. One common technique used for old DOS VGA games is to modify the palette to do simple animations. This is called palette shifting. So while the palette can be limiting as you can only have 256 colors at a time it can also be handy as well.
Post by: nockieboy on October 17, 2019, 01:52:55 pm
Err, well a couple of reasons really - I'm not very knowledgeable when it comes to electronics (experienced users of the forum who remember my DIY Z80 computer posts will agree!  ;)), and because of that I guess the other reason is that I didn't even know it would be an option!  :o
I guess the concept of VGA is relatively easy for me to grasp, but if I can do HDMI then I most certainly will!
Thanks kizmit - that second link is certainly intriguing and has piqued my interest.
Post by: nockieboy on October 17, 2019, 01:59:57 pm
My goal is to build a computer as good as, if not better than the first computer I ever had (an Amstrad CPC464 back in the 80's).  The only challenge left for me to meet or exceed is the graphics display, so 256 colours at a time may be 'limiting', but it'll blow my old Amstrad out of the water (it had a 27 colour palette)!
My ignorance of FPGAs is limiting my understanding here, though.  How could the palette be modified 'on the fly' in an FPGA?  Oh, unless it's stored in block RAM I suppose?
Post by: Berni on October 17, 2019, 02:40:49 pm
The thing is that R2R DACs built out of just cheap standard tolerance resistors are only really good enough to get you about 4 bits of resolution reliably. Past that the resistor tolerances start becoming a significant enough part of the signal that the non linearity of the steps messes up the least significant bits. So its not really worth it building a 8bit R2R ladder DAC as its performance won't be all that great.
If you want proper 24bit color you are better off buying a proper DAC chip that gives you 8bits per channel. This can be a purpose built VGA DAC or just 3 separate generic 8bit DACs for each color. By the time you have all of this you will essentially have a 24bit RGB bus(Also called DPI bus) feeding it and this is a simple standard video bus and this means you can replace your 24bit VGA DAC chip with a LCD panel and it will work, or you can replace it with a RGB to LVDS or RGB to HDMI converter to drive larger serial LCD panels or display it on a modern TV. Tho this conversion can also be done inside a FPGA, but does tend to need specialized serdes capability to go fast enough for larger resolutions.
And once you have 24bit color you can do palatalized 256 colors nicely because each pallet entry can pick from the 16 Milion available colors that you are now capable of displaying.  Color palettes are just a way of keeping the amount of data down inside the graphics subsystem, its not a way of getting around the limitations of the video output hardware as it still has to be capable of reproducing all the colors the palette would want to ask for, its just a workaround that the graphics hardware is not powerful enough to tell the video output hardware exactly what color it wants, so its job is made easier by having to only pick from 256 colors.
Post by: SiliconWizard on October 17, 2019, 02:56:25 pm
Ideally, you could consider using a dedicated framebuffer (dedicated RAM chip) for the display.
The CPU could for instance access it (to write to it or read from it) via some kind of memory mapping scheme, like maybe in chunks ("windows") of 8KB, and a bank selection mechanism. More efficient than using I/O accesses IIRC. Of course, when the CPU would access the framebuffer, it could only do so when it's not being read by the display controller, but when the CPU is not accessing the framebuffer, it could mind its own business with its own RAM without any penalty.
Post by: nockieboy on October 17, 2019, 03:14:03 pm
I had considered this before - my system's MMU breaks the memory down into 16KB banks with a total of 4 MB of physical memory space.  I could just break out one (or more) of the eight 512 KB chip sockets to dedicate them to being a frame buffer, I suppose.  The only issue is that I'd need to put together some switching logic to isolate their data and address bus from the Z80's whilst the Z80 isn't accessing the frame buffer, and some way of making the Z80 wait until the frame buffer is free before access is allowed to it (I guess I could read an IO port on the FPGA which would go low when the display is in a front porch, for example.)
I guess whether I'd want to go that route, with the additional complexity of creating the 'shared RAM' interface and control logic, would depend on how much mileage I can get out of using an on-board frame buffer on the Spartan 6, or whether just sending commands and data one OUT at a time would be too much of a bottleneck.
EDIT:
Ah, answered my question with a quick Google - the Spartan 6 has up to 18 KB of RAM on board.  Subtract 2 KB for symbol/character set storage (unless ROM is a separate entity to the RAM?) and I'm struggling to do much with it on a resolution larger than 160x120.  Looks like the frame buffer will have to go into the SDRAM and I'll need a way to buffer commands/data from the Z80 whilst the controller waits for a 'porch window' to do what it needs to do with the frame buffer.
Post by: legacy on October 17, 2019, 03:37:49 pm
Shared ram chips, in DIP-package, are about 2 Kbyte.
The alternative is to force the Z80 releasing the bus.
Post by: CJay on October 17, 2019, 03:39:37 pm
Bugger.
Yeah, found them and they're safe now :)
Post by: SiliconWizard on October 17, 2019, 04:24:43 pm
You could also design your MMU so that CPU and video accesses are interleaved. I dunno how fast your CPU is going to run, but if it's a few MHz (as that was back in the day) that should pose no issues.
Any Spartan 6 certainly has more than 18KBytes of embedded RAM. The LX4 (smallest) has 216Kbits (27KBytes), and the LX45, which is still reasonable price-wise, has 2088Kbits (261KBytes!)
You confused the "18Kb" (Kbits) figure for the Spartan 6, which is the individual size of the RAM blocks, certainly not the total available!
Post by: mariush on October 17, 2019, 08:42:20 pm
Any reason you can't use a microcontroller to generate the VGA signal?
There's cheap microcontrollers (under 10$) which exceed 200 Mhz and fast DACs are cheap, if you don't want to use resistors.
Post by: jhpadjustable on October 17, 2019, 11:49:55 pm
Yep, just like almost all the home computers of the 1980s. But that requires some close coupling between the video hardware and the rest of the system, which he said he wanted to try to avoid. With the huge difference in memory bandwidth demand between the CPU and 640*480*8bpp, I can understand that.
Personally I'd have put a Z80 soft core and an SDRAM controller on the FPGA and called it 80% done :D
Any reason you would want to bit bang video, other than to show off for the demoscene (https://www.linusakesson.net/scene/craft/)?
Post by: james_s on October 18, 2019, 01:11:58 am
I use VGA (or composite) for this retro stuff because retro machines just look weird on LCD displays generally and I have a lot more monitors with VGA and only a couple things with HDMI. It's also a lot easier to wire VGA.
I wonder what happened to Grant Searle's website? I have a lot of the code stashed away but there was a ton of cool stuff on there.
Post by: Berni on October 18, 2019, 06:33:04 am
These day its still common to share main system RAM between the CPU and GPU, but its done differently.
Today caches are used on all sorts of CPUs even small ones that run under 100MHz. This means the CPU does not always need to be poking and prodding at RAM in order to execute every single instruction. For code that loops around a lot (this is usually where speed matters the most) all of the instructions end up inside the cache and so the CPU completely stops reading code from RAM while for any temporary calculations there are usually plenty of registers to keep things in. So once things are cached the access to RAM is just to move the final computation results in and out of RAM and even that happens in large blocks of cache writebacks (Dynamic RAM usually loves large burst accesses due to pipelining). All this was required to push CPUs into the 100s of Mhz since main system RAM could not keep up.
So this means you can actually take the RAM away from the CPU for many cycles at a time and it won't even notice. Also modern DRAM can easily be run  at 100MHz or more and the wide burst access nature of caches means you can benefit from having a really wide RAM bus such as 64 bit, 128 bit... etc to get even more speed out of it even tho the CPU might only be 16 or 32bit (In graphics cards 512 bit wide RAM buses are not uncommon because they really need lots of bandwidth).
All of this means plenty of RAM bandwidth can be leftover from the CPU and can be used for the GPU. The bus arbitrator can split the bandwidth however it wants between them (Not the usual fixed 50/50 split that interleaved access did in the old days). But it also means that the video output hardware has to have some cache of its own as it will not be guaranteed RAM access at a moments notice. The CPU might be in the middle of a cache writeback and is taking up the bus for the next say 16 cycles or a DRAM refresh cycle might be happening, so the video hardware must have enough pixels in its own internal buffer to keep outputting the image while it waits to finally get to the RAM and catch up.
If you are after a ton of graphics horsepower you could just give the GPU its own set of RAM chips with a huge wide bus to make sure it really has a firehose worth of guaranteed memory bandwidth and then implement a bus MUX that lets the CPU use the memory when the GPU is idle and video output is in blanking, or have the GPU listen to commands from the CPU of what to put into graphics memory. But for a retro computer project that is way overkill since on a decent FPGA this would have the graphics horsepower surpassing early 3D graphics accelerator cards in PC such as the Voodoo
Post by: nockieboy on October 18, 2019, 08:33:46 am
I guess my motivations may be hard to understand for some as I could achieve all this by just putting it ALL onto the FPGA, but my original intention was to learn how to build a computer from scratch (having been given the desire to do so by stumbling across Grant Searle's page) and learn some electronics skills on the way.  I'm now working with a system I want other people to be able to build who want to go along the same journey I did - although it involves a lot of SMT parts now as my soldering skills have developed and an FPGA graphics card certainly IS overkill, it just seems too good an opportunity for me to miss to be able to just plug my little home-made computer into my living room TV and play Pong on it with the family.
(https://i.ibb.co/P9r24jM/20190730-184211.gif) (https://ibb.co/nnwXfmB)
The CPU runs at 8 MHz (or 4 MHz, if you want to experience true 80's CP/M!).  So you think there would be no noticeable slow-down if I were to shut down memory access for ~73% of the time while the FPGA is accessing the frame buffer to draw the visible area of the screen?  To me, knowing little about this sort of stuff, that equates to slowing the computer down by almost three quarters?
Part of the reason for this post was to discuss the best way to interface the FPGA with the computer - frame buffer in computer RAM, or gated via the FPGA, for example.  Both have positives and negatives, I just don't have the knowledge or experience to understand their weight and balance the options properly, if that makes sense?
Ah, my mistake.  I was a little surprised it was so low actually, considering I was comparing it against an Altera Cyclone II (which I have currently) which is much older and only has a little less.
The LX45 is VERY promising - a little expensive for what I'm trying to do, but would make life VERY easy as I could have an internal dual-port frame buffer that could give me resolutions up to 640x480 with 4 bit colour depth using a LUT, and still have over 100 KB free for the LUT, buffers, character set(s) and even sprites... And the best thing?  It's available in TQFP, which I consider still reasonably easy to solder (have never tried BGA... other than using a frying pan, don't see how it could be done at home). Hmmmm.... thanks SiliconWizard, that's a great suggestion.  :-+
True, VGA was my original intention when I started this post, but having had HDMI suggested as not being impossible, I think it'd be far more future-proof to use that instead.  I'm concerned VGA is diminishing in popularity these days - it will only get harder to get hold of TVs / monitors with VGA inputs, and whilst I've built a 'retro' computer, I'm trying to keep in mind future availability of parts (partly hence the move to SMT components as some are like gold dust in DIP form).
Grant's site seems to have been deleted, according to the site message - so it doesn't look like the domain has expired, it looks more like an intentional removal of the site.  :-//
EDIT:
I made a mistake - the LX4 is NOT available in TQFP, only BGA or wafer, which means I can't use it unfortunately (my SMT-soldering-fu isn't that strong!)  At least, not unless I find a PCB manufacturer who is willing to solder it to the PCB for me as part of the fabrication process.  I tend to use JLCPCB, so I've contacted them to find out if they will do it as part of their new SMT-assembly service.
Post by: Berni on October 18, 2019, 09:52:40 am
With a FPGA you can go as far as you want to go. You can just implement a RAM buffer that gets drawn to the screen if that's what you are after. But you can then add on things like hardware graphics acceleration if you want to have the graphics seen on the 16bit game consoles back in the day. Sound can also be implemented in the same FPGA giving you emulation of the popular chiptune or FM synthesizer chips.
But if you just want to output video from a RAM framebuffer then you can get something like the Solomon Systech SSD1963 in a LQFP128 package:
https://www.buydisplay.com/download/ic/SSD1963.pdf (https://www.buydisplay.com/download/ic/SSD1963.pdf)
While it is called a "LCD Display Controller" its actually outputting a RGB video bus that can be turned into VGA via a DAC or into HDMI via a RGB to HDMI converter chip. The input to it is just a memory bus so you connect it to your Z80 in the same way you would connect SRAM or any other peripheral chip (Tho it is 3.3V so you might need level shifting). The framebuffer is internal inside the chip and it can run at up to 110MHz so any retro CPU will not be too fast for it. Its essentially a video card in a chip.
But the downside of using such a ready made solution is that it can't emulate anything else. So if you have existing software that expects to talk to certain video hardware then it wont work here, but replacing this chip with a FPGA lets you customize its memory mapping and registers in a way that mimics some existing video chip in some retro computer and allows the existing software to run on it.
In a way a FPGA is kinda cheating if you are after the genuine retro computer building experience. Having to breadboard 1 to 10 chips and running 10 to 100s of wires just to add some peripheral to your computers memory bus. But with a FPGA you just edit a few lines of code on your PC and load the new firmware into the FPGA and boom suddenly your computer has 3 extra GPIO ports and a PWM output. Few more lines of code and suddenly you also have a floating point coprocessor in your computer, some more core and you have a separate programmable DSP core in there too. Need more grunt? Okay copy paste 3 more of those DSP cores to now have a quad core DSP on the bus. Doing the same in the 80s would requires a few suitcases worth of boards hanging off your computer, these days its just adding some more code into a FPGA chip sitting on the bus.
Post by: Canis Dirus Leidy on October 18, 2019, 10:07:06 am
And also a programmable palette (in combination with bit planes video RAM ) made life somewhat easier for a programmer, when your target machine (https://zx-pk.ru/content/136-Vektor-06C-sovetski-bog-tcveta-i-zvuka) don't have hardware sprites:
[attach=1] [attach=2] [attach=3]
*cough* MSX (https://www.chibiakumas.com/z80/msx.php) *cough* This standard explicitly prescribed that all access to video memory should be made only through the ports of the video controller.
Well, if you look at PC video chips from EGA/VGA/Early SVGA era (like GD542x family (http://www.s100computers.com/My System Pages/VGA_16_Board (Cirrus)/GD542x Technical Reference Manual.pdf) or ET4000 (http://bitsavers.informatik.uni-stuttgart.de/components/tsengLabs/Tseng_Labs_ET4000_Graphics_Controller_1990.pdf)), you will see that video memory was actually isolated from CPU bus. All that the processor could see was an intermediate buffer and translation logic, creating the illusion of direct access to video memory.
P.S. And talking about resistor-based DACs. Little Chinese trick:
[attach=4]
Instead of R-2R ladder he (or she, or whatever) used SMD resistor arrays for making binary weighted resistors values.
Post by: legacy on October 18, 2019, 10:19:44 am
My Sonoko project uses three VGA LCD-screens, a VGA service card, and a VGA KVM. NEC VGA LCD-screens are 17inc and were bought new. Personally, I do not like HDMI because it consumes too much bandwidth on wires and on the circuit, and products are even more expensive. The HDMI KVM version costs double, cabling is much more expensive. This is a premium if you are on super modern technology, and e.g. the Advoli TA6 is a PCIe GPU card with nothing but HDMI via LAN outputs, but ... this stuff is a no-way unless you are in business with a squad of engineers.
Post by: SiliconWizard on October 18, 2019, 02:49:33 pm
Well, nope. The interleaving suggestion implied that the RAM would actually be accessed faster, so the CPU wouldn't see a difference. To pull that off, you would of course need a fast enough RAM (which should be no problem with a modern SDRAM chip or even SRAM), and clocking the MMU faster. Also, to keep things simple, you'd have to have the CPU and video clock frequencies multiple.
Post by: james_s on October 18, 2019, 04:40:14 pm
If you want to play with (crude) graphics hardware, have a look at some of the early arcade games I've done.
https://github.com/james10952001
I've made them quite modular so you can easily mix & match pieces. The old Atari B&W games are cool because the video hardware is entirely independent of the CPU which just writes into RAM and then the hardware continuously reads these RAM locations and uses them to address object ROMs that result in objects on the screen. Originally this used standard SRAM with data selectors but in some of these I just made it dual ported RAM which makes it super easy to "wire" it up to whatever CPU you want. The object ROMs are easily customized as well to display whatever characters you want, and the schematics for the original hardware are readily available. Hack away.
I should add that these are all targeted to the same $12 FPGA board that Grant used, and in fact if you poke around there's a PCB in that repository for a daughter board that plugs right into that FPGA and has sockets for RAM, keyboard, micro SD, etc.
Post by: nockieboy on October 18, 2019, 07:02:29 pm
Hmm.. if I can get an AY-3-8910 implementation up and running on the same FPGA as the graphics, that'd be great and save me a lot of kerfuffle with the sound card using a genuine chip, which I'm having timing problems with at 8 MHz at the moment.
On that note, I'd like to include a keyboard handler as well - the thought crossed my mind that I might actually be able to include a USB host (or USB-to-go, at least), so that I could plug a USB keyboard in without having to depend on dwindling supplies of PS2 keyboards.  A quick search earlier showed me that an IP is available for USB-to-go for the Spartan, but looks like it could be costly to buy/licence.
...But the downside of using such a ready made solution is that it can't emulate anything else. So if you have existing software that expects to talk to certain video hardware then it wont work here, but replacing this chip with a FPGA lets you customize its memory mapping and registers in a way that mimics some existing video chip in some retro computer and allows the existing software to run on it.
You're right, using an FPGA is cheating - but I might take a look at the video chip you mentioned as an alternative.  My system is highly modular, so I could develop an FPGA-based video/sound/keyboard card AND one based on separate and more authentic discrete chips for those features and leave the choice of which they'd prefer to the person building the system.
[/quote]
(Attachment Link) (Attachment Link) (Attachment Link)
Спасибо - I wish my Russian was better and I could read the writing, but I think I get the idea.
Yes, a friend of mine has been recommending I look at the MSX architecture for tips, I'm starting to see why now.  So passing data via IO calls to the FPGA is a viable proposition then.  I can see this method being quite useful for things like clearing the screen, or drawing rectangles and other basic shapes using only a handful of IO instructions.  I'm going to have to give some serious thought to what sort of instructions I'll want to implement in the video controller.
A gold-standard outcome for me would be to create a video controller that enables my computer to produce graphics for half-decent games.  Initially I see things like Pong and Breakout being easy enough, but I'd like to simulate the kind of 80's games that were commonplace on the 8-bit systems of the day.  As the 80's computers I'm familiar with all used interleaved memory frame buffers, so I'm assuming these sorts of games would still be possible using the MSX method, as the MSX managed it?
Yes, I figured having a buffer would be helpful as the FPGA may not be able to access the frame buffer immediately on receipt of a command without causing tearing.  I'm still not 100% convinced I fully understand how it'll work with the Z80 sending commands/data to the FPGA via an IO port, but I'm sure I'll get my head around it at some point.
CP/M was designed to use VT100 and VT220 terminal, hence the FPGA needs to implement a simple VDU, or the SOC needs to implement a simple serial link with a decent FIFO to use an external VT100.
Yes, I'm intending to emulate the VT100 terminal and handle ANSI-escape codes in the video controller.  Grant's Multicomp VHDL does a good job of that already.
You mean the FPGA would read the 'frame buffer' in the Z80's logical memory space into an internal buffer really quickly, then pass that out as a pixel stream?  Otherwise surely the frame buffer would be sending data at the rate the screen mode requires, which means 73% of the time it would be sending data and locking the Z80 out?  Not sure I understand this fully.
...Hack away.
Ah thanks for that james_s - will take a good look over the weekend. :)
Post by: jhpadjustable on October 18, 2019, 07:39:32 pm
I understand it and respect it, even if I don't personally feel the attraction (anymore).
To paraphrase an old proverb, maybe Daoist, "The man who knows no stories is a fool. The man who knows many stories is wise. The man who knows one story is dangerous." The Old Ones have bequeathed many useful stories to us through their artifacts. I urge you to look at what other designers were doing in the 1980s when tasked to write a display engine. Even a close reading through the programmer's manual of some of these older systems will give you some flavor of their concerns and the clever tricks they used to get (then) high-performance video out of (today) low-performance hardware while holding to an accessible price point.
But you have to know your medium before you can create a useful artifact. Digital design is not a qualitative discipline. There is no substitute for looking at timing diagrams and characteristics tables, establishing cause and effect, looking up propagation delays, and doing the sums. For example,
isn't a very useful question. The better question is, how much slowdown would there be if...? To reckon that, we have to look at the Timing section of the Z80 CPU User Manual, UM0080. For example, if you look at the instruction fetch cycle you'll see that the last 2T of the M1 cycle is spent "refreshing", where the Z80 doesn't care what's on the bus but still drives some of the address pins as a convenience to users of then-new DRAM, and that the Z80's proper business is done at the end of T2. We also know that our memory system can service instruction reads in 2T, and that, if we are using SRAM or a DRAM controller that handles its own refresh, the Z80's refresh cycle is wasted time. What if we simply disconnect those pins from the data bus at T3, hold the read value in a latch for the convenience of the Z80, and let other hardware access the bus instead? You just found a £10 note in the sofa cushions, depending on what kind of deal your company was able to score on DRAM. :)
Back to cases. Having written out some ins and outs, you might then look at I/O read and write machine cycles, and see that they are 4T in length. For I/O writes, we see that all address, control, and data of interest are available in T2. If all our devices are fast enough to have completed the write by the end of T2, we can just disconnect the Z80 from the bus and let the system bus free for other business during TW* (third beat) and T3 (fourth beat). For I/O reads, we see that all the address and control are once again available in T2, but the CPU doesn't read the data until the second half of T3. So, again assuming that our devices are fast enough, we will have our read data by the end of T2 and need only hold it for the CPU through TW and T3. We can then unhook the Z80 from the bus at the end of T2 and go about our other business. Cool, another £10 in the cushions!
Now we look at loads and stores. We see that memory write cycles are 3T in length, and that our snappy little jig has become instruction-dependent math rock. But [attachimg=1]! The Z80, like most other processors of the time, allows bus cycles to be stretched to accommodate slow hardware. We can insert one TW to lengthen the cycle to 4T and keep the rhythm, taking note of the penalty in order to answer our original question. Having done that, we look again at the memory write cycle and see that data and address are valid by the end of T1, but the !WR signal isn't valid until the end of T2. We can assume by the end of T1 that, if !MREQ is asserted and !RD is not, !WR will be asserted by the end of T2, and prepare accordingly. The rest of the write cycle follows that of I/O out cycles with the exception of the wait state we inserted, and we can likewise disconnect the CPU from the bus for TW and T3 without the Z80 any the wiser. £10! As for loads, we see that they too are 3T in length, so to keep the rhythm let's add the wait state and mark the penalty. Looking at our extended read cycle, we once again see that data isn't sampled until the end of T3 (fourth beat, as TW was inserted as the third beat). If our memories are fast enough, we can sample the data at the end of T2 just as we did for the I/O and hold it for the CPU, while we unhook the CPU from the bus and use the last 2T for our own business. £10!
Finally let's look at the interrupt request/acknowledge cycle, which is at minimum 5T long, and now we've gone to playing experimental jazz. But we will know what kind of cycle it is by the end of T1, and know it is an interrupt if we see !M1 asserted and neither !MREQ nor !IORQ asserted. In our system design we have a decision to make: do we want to pass the vector cycle through to the system bus, or handle it off the system bus? If you pass it through, you can treat it much the same as any other memory read cycle but generate the !WAIT signal and hold the received vector for 5T longer than otherwise, which we will mark into the penalty column. If you prefer to handle it off the system bus, you do the same with the !WAIT signal but disconnect the CPU from the bus and supply the vector by your choice of means. Your call. In either case, to keep the rhythm we have to stretch the interrupt cycle out to 8T. A 50p coin is better than nothing. ;D The NMI cycle is just a dummy instruction fetch with a runt pulse on !MREQ in T3 which we can ignore because the CPU would be off the bus anyway. £1!
The overall effect, then, is that we have introduced some ancillary logic to the Z80 so that it can vacate the system bus for 2T out of every 4T, at the cost of memory access by the CPU taking 14.3% longer than theoretically possible, and a modest hit to interrupt latency which in practice may not mean all that much. In doing so we have saved millions of RAM chips and tens of millions of pounds. Going a little bit out of brief, while the video system is not actively fetching frame buffer data, its 2T cycles could be borrowed to service other peripherals, for example, to buffer up sprite data, service disk controllers, or output PCM audio. Going very far afield, it may be evident that, instead of display DMA, we could place a second Z80 with much the same ancillary logic, sync them up, and have them both run at nearly full speed out of the same memory and I/O space, with the usual caveats about multiprocessing. If you were feeling especially naughty, you could pull the wool over the second CPU's data lines and feed it NOP instructions while exploiting its program counter as an address generator for the video output (beware, people have been knighted (https://en.wikipedia.org/wiki/ZX81) for doing this sort of thing).
The word salad I wrote above is a walk through the sort of thinking the Old Ones utilized in many of the 1980s home computer designs, starting with the need to compete vigorously on both BOM cost and performance. The IBM PC, coming from its mainframe background and the culture of modularity, could not engage in this level of coupling. Either approach is certainly feasible. Which one is more desirable is a systems-level decision that depends, in part, on the desired display size and depth, and in turn the desired pixel rate, but also on cost, code size, flexibility, programmer convenience, and so on. "Better than the Amstrad" is an open-ended brief that could encompass anything from the tightly-coupled home computer systems as napkin-designed here, to an ISA bus bridge to a CGA/VGA/EGA/Hercules card rescued from the scrap pile. In any case, there will be side effects which you also have to pursue down the line and decide to live with for your application.
Oh, if you want to play USB host, the SL811HS is a classic choice, which incidentally can also be configured as a device should you wish to link your system to your PC. Be advised that USB HID can be a bit of a hairball.
Post by: Berni on October 18, 2019, 08:09:10 pm
You are worried a bit too much about the FPGA implementation of the memory, framebuffer and access methods.
A lot of the retro ways of doing things in 80s computers are optimizations to get the thing working with as few chips as possible that containin as few transistors as possible in order to make a cost effective computer that a home user could afford. But modern FPGAs are rather large so keeping down the number of gates is not so important while you can now cheaply buy a few megabytes of SRAM with 10ns access time (So a max clock speed of about 100 MHz). This means such optimization tricks to reduce transistor count and memory usage are not required to make the design fit into a reasonably sized FPGA.
So if you connect all your components to the pins of a FPGA you can implement your graphics card in any way you like. The block RAM inside FPGAs is naturally dual port anyway and allows being written to at the same time as its being read out of and can typically run at >100MHz. This means you can implement access to the memory in any way you wish. Infact it would be perfectly possible to have 8 of those Z80s talking to the same RAM inside the FPGA simultaneously, doing read/write access to the same memory locations and all at the full 8MHz speed on each Z80. Due to external modern SRAM having 10ns access times the same is possible even withe external memory chips. But since you have only one Z80 this means that 90% of the available memory bandwidth is left unused and so can be utilized by any of the video or graphics acceleration hardware built in the FPGA without slowing down the Z80 at all.
So just pick whatever graphics architecture you would like to have and implement it in the FPGA. You can also implement multiple ones at the same time, like have a register command based interface and memory mapped simultaniusly, or have multiple modes like PC graphics cards do where you get various text or graphics modes that provide different advantages (Some provide lots of resolution and colors, some very few but take less CPU horsepower to use).
That being said the modern way of handling graphics acceleration in PCs is in the form of "draw calls". The GPU memory is available to read/write from the CPU as it wishes, but GPU memory tends to be in physically separate memory chips for speed reasons, so the GPU just forwards the read/write operations trough to its memory. Then the way that the GPU is made to do work is that the CPU places a list of things to do into its memory, each item on that list is a draw call and its a structure containing information of what you want the GPU to do ranging from "Set pixel 23,500 to color 255,255,255" to "Draw bitmap located at 0x554600 (512x512 RGBA 32bit) into framebuffer at coordinates 84,46 with alpha blending enabled" to "Apply the matrix transformation [0.45,1,1,0,5.4,5.5 .....] to the array of 16384 points in XYZ located at 0x7755000" to "Load the shader script bytecode at 0x5477400 into 128 shader units and run in parallel on the entire framebuffer" and so on and so on.... This list can be as long as you like and is typically built these days by a API like OpenGL or DirectX with the help of the graphics drivers. Once this "cooking recipe" structure is in the GPUs memory it is told to execute it and the GPU will run along on on its own without the CPUs intervention and some miliseconds later the delicious resulting image will be sitting there in another location of video memory. If the video output hardware is also pointing to that location in memory as its framebuffer than the image will also be sent out via HDMI so that your eyes can also enjoy the delicious image the GPU has baked for you.
This draw call approach is by far not the only solution to doing this, but its a solution that fits well on modern computers because the CPU can just throw this few kilobyte large "cooking recipe" and go do something more important while the GPU independantly works hard on baking the recipe without hogging any of the CPUs resources.
Obviously implementing all the draw calls of a modern graphics card is an insanely huge task, but in order to get some impressive graphics going you only need a few simple ones. Things like filling a rectangle with a single color or drawing one bitmap on top of another bitmap, perhaps also with transparency effects and alpha blending. Later on you might want to add support for 2D transformation matrices as that requires little hardware but lets you implement the stuff that for example the SNES can do in Mode 7. All of this can result in graphics that surpass the 16bit console era because you have a unfair advantage of having 10 times more memory bandwidth than they did. But for 8bit games what you will find the most useful is tilemap and sprite support since this requires very little data to be manipulated by the slow CPU, so its very fast even on wimpy old chips.
Oh and you want to avoid things like USB. Yes you can get a USB host IP module for a FPGA but that will only implement the actual USB port and its transfer protocol (glorified UART), it still needs the higher level protocols that initialize USB devices and drivers to talk to them. This will need a CPU to handle, so you will likely end up with a softcore CPU inside your FPGA that's actually more powerful than the Z80 itself, sitting there to run drivers for USB devices. If you want mouse and keyboard stick to the simple PS/2
Post by: nockieboy on October 18, 2019, 09:56:46 pm
For example, if you look at the instruction fetch cycle you'll see that the last 2T of the M1 cycle is spent "refreshing"...
The overall effect, then, is that we have introduced some ancillary logic to the Z80 so that it can vacate the system bus for 2T out of every 4T, at the cost of memory access by the CPU taking 14.3% longer than theoretically possible, and a modest hit to interrupt latency which in practice may not mean all that much...
I suspect I'm going to be reading and analysing what you've written here for months to come.  :o  But from what I can gather, there's the opportunity to steal cycles from the Z80 and open the address and data buses up to peripherals (like the video controller) whilst the Z80 is pausing for breath in the middle of its memory/IO cycles?  That's some major optimisation!!  Did you design these systems back in the 80's?
Haha - yes, I'm aware there's quite a few hacks in the old Sinclair ZX80 and ZX81 (and even in the later Spectrums, I believe) to get them to display video inbetween reading the keyboard, or something? I remember there being a reason why the screen blanks out when you press a key...
That's really what I wanted to know - is there some big reason NOT to go for one approach over another.  I'm thinking for the sake of simplicity, I'll go with the Z80 only having a simple IO connection to the FPGA.  At least in the first instance - I can always change to an alternative method of interfacing later if the need arises, I guess.
Well, I'm aware there's a significant software overhead due to the vast range of HID devices - I would literally just be looking for basic keyboard reading - but perhaps I'll have to stick to PS2 then.
I guess this stems from my lack of experience with FPGAs.  I'm learning quite quickly from this forum that FPGAs are actually blisteringly fast and flexible beyond belief - at least to my inexperienced mind.  :scared:
And that's exactly the kind of answer I needed - perhaps I have been overly concerned about the speed of the design, but that's born out of a lack of knowledge.  I did admit that I'm no expert in this field and have been learning as I've gone along.  ;D  So basically, I should just crack on with my preferred design and see how it goes.  These FPGAs are so fast and flexible that most of the magic will be done in the VHDL?
This was one of the possible options floating around in my head for the IO-based interface.  The Z80 could just send a load of commands and data to the FPGA which would buffer it into a FIFO (if needed - the FPGA will likely not need to buffer much as it's so much quicker, I'm guessing) and the FPGA would perform operations on those commands into the frame buffer whilst it's being read and streamed to the output by the video signal generation part.  That's the other thing I need to remember about FPGAs - they're not one computation block, all their components run in parallel with each other.
Absolutely - I think this will be the biggest area for development then.  The actual architecture of the graphics card sounds like it will be really simple, aside from level converters for the 5v to 3v3 and some basic IO address decoding, there will be little else other than the FPGA and HDMI output.  In fact, I suppose there's no reason why I can't integrate the IO address decoding into the FPGA as well?  This is getting easier by the minute!  ;D
Post by: asmi on October 19, 2019, 12:20:09 am
If you want to learn how to design a computer system from the ground up, start designing your own RISC-V RV32I core. It's got only 37 instructions (if I can count lol), and there is a full-blown gcc compiler for it, so you can use real-deal C/C++! Once you have a core, you can start designing peripherals and figuring out how to connect them to the CPU bus, than at some point you will realize you need DMA controller to send data around without CPU involvement - this will force you to implement a multi-master bus so that peripheral can do bus mastering as well as the CPU core, etc. There is almost no limit to how far you can go with this - implementing multi-core system, adding support for external expansion buses (like PCI, or PCI Express), and so on!
For video I really recommend using HDMI because it's so ridiculously easy to implement in its most basic form (RGB-24bit output, video-only), and lower resolutions aren't very taxing on FPGA performance-wise or layout.
Post by: hamster_nz on October 19, 2019, 12:31:47 am
Just wanting to be clear... Most people are talking about implementing DVI-D, not HDMI, even though they use the same physical architecture and low-level coding scheme. True HDMI is a step up, and involves adding data islands, audio, BCH codes and so on...
Best reference documents for DVI-D are the Digital Display Working Group's specifications.
Post by: jhpadjustable on October 19, 2019, 03:46:44 am
You do have the gist of it correct. You don't need to pay too much mind to the ramblings of an animated professor in a lecture. Try a drier summary: a system bus, designed for 2T bus cycles, can be time-multiplexed into 4T frames of two fixed time slots, each 2T long (one bus cycle). Each slot is dedicated to an independent master(s), each slot which may perform up to one bus cycle every frame. You can place some glue logic between the Z80 bus (or any other master(s) of your choice) and the system bus to connect/disconnect the master's address, data, and control signals to/from the bus at the beginning/end of its time slot, to smooth over timing differences between the 2T system bus and the Z80's 4T cycles, to hold data received from the system bus until the master is ready for it, and to keep the Z80's machine cycles synchronized with its time slot. The 1980s-era home computer, in 127 words.
If you're a visual learner, print out and clip out the timing diagrams from the Timing section of the Z80 data sheet and lay them on a table, with each start of T1 aligned vertically. Use another sheet of paper to cover from the end of T2 onward and observe that you have enough information to start a cycle. Have scissors handy to cut the memory cycles at the beginning of T3 and introduce one TW of space between. Print/cut out another set, maybe in a different color, and lay them out offset by 2T from the first set. Shuffle them around and examine the interplay.
No, I was just a boy at that time, but I gave one of the Amiga designers a ride to San Francisco once. :)  I did have a few of those 8-bit machines and a couple of 16-bit machines, and fell in passionate, enduring love with PEEK and POKE. I followed the demo scene for a bit later on, even tried to write a few screens that turned out nothing to write home about.
You would need to design the multiplexed bus into the system from the beginning. There's always the next machine, right? >:D  If you're using private, single-ported frame buffer RAM, the video system doesn't master the system bus, so time-multiplexing the system bus would be a needless complication, especially if there is already a "normal" DMA controller in the system. Time-multiplexing may still be useful on the private frame buffer side, to arbitrate between the pixel serializer, the graphics coprocessor, and the system bus interface. As powerful as FPGAs are, they're not quite quantum computers and there will still be single resources that must be shared by multiple clients. DRAM chips, even with their multifarious burst modes, still take a moment to close a row and open a new one.
I will call your attention to the timing diagrams for memory vs. I/O accesses, and point out that I/O accesses are 1T longer than memory accesses, by design. That may add up when moving a lot of data from system memory to the frame buffer without DMA. I'll also point out that there are 16-bit load/store instructions which save one or two instruction fetches for every two bytes, and may be more convenient (and faster) for programming, but there are no 16-bit I/O instructions as far as I can tell.
Since you do have the full address bus at the FPGA's disposal, and you prefer not to use a memory-mapped window into frame buffer RAM, I offer the idea of mapping individual registers into a 4kB or so block of address space rather than using a single command/data register pair.
Fair enough. You can add-on USB later if one day you happen to wake up really ambitious and feel like porting code from MSX USBorne project :)  For the SL811HS you need only two addresses in I/O space, eight data lines, and the usual bus handshaking signals, which could fit very easily on an expansion board.
Post by: asmi on October 19, 2019, 04:49:44 am
Isn't all of that stuff optional? My memory on HDMI spec is rather rusty atm.
But whatever - the point is - it works, and fundamentally it's just a couple of counters and few comparators to figure out blanking areas - which incidentally you will need for VGA, the only difference is output SERDES. But on the other hand you get full 24bit color space to work with without a need for any sort of DACs (of which you'll need three for VGA - again if my memory serves me), and you need just 8 pins + few auxiliary ones like HPD and I2C channel, instead of a ton of pins to external parallel DACs. And you get a clear path for upgrade if you ever decide for it - this one is the most important for me (even more so that I'm working on DisplayPort module so that I can go up beyond FullHD).
Post by: legacy on October 19, 2019, 07:19:37 am
With a physical Z80 cpu chip? at 5V? having the FPGA's IO at 3.3V?
Post by: hamster_nz on October 19, 2019, 07:43:22 am
If it doesn't have video guard bands, TERC4 data islands and the data island that defines the display format it isn't HDMI, it's just DVI...
Let me know if you need a hand or advice with DisplayPort. A few years ago I knew the older spec backwards, and got 4k streams going on a few different boards... These might help:
https://github.com/hamsternz/FPGA_DisplayPort
https://github.com/hamsternz/DisplayPort_Verilog
Post by: nockieboy on October 19, 2019, 09:13:10 am
If you want to learn how to design a computer system from the ground up, start designing your own RISC-V RV32I core...
One thing at a time, asmi.  :o ;)
Yes, I'm sold on HDMI and will be building with that end goal in mind.  Plus the Spartan 6 - my FPGA of choice, it seems - appears to have hardware support for HDMI in its IO blocks.
You make it sound so simple...  :o  ;D
Oh wow - I loved my Amiga(s).  I had an A500+ and then upgraded to the A1200 with a hard drive when I went to university.  They were going to rule the world - then the PC happened.  ::)  PEEK and POKE were a couple of the first commands I created for my system's monitor program.  They were like dark magic back when I was a kid in the 80's.
Well, I'll have to wait to get a prototype up and running to see the performance of the IO interface and decide if I need to look at something different.  I'm not a professional games programmer, so I'm not talking about blockbuster graphics, parallax scrolling and FMV when I talk about what I want from game graphics, but I guess it still waits to be seen what the interface will be capable of.  I'm aware that memory access is faster than IO access because of the extra commands and the additional WAIT state that the Z80 inserts into IO cycles, I'm just not sure how that will play out practically - I'm hoping the difference will not be noticeable.
Let me make sure I understand this - any writes to the appropriate memory space would be picked up by the FPGA and read into internal memory which effectively shadows the system's memory 'window'?  Actually, that would be really useful to transport large amounts of data from the system into the GPU.  Rather than using a sequence of, say, (a minimum of) 64 IO writes to create a sprite in the GPU's memory, the whole thing could be copied into the RAM 'window' using the faster memory commands...
Yes, a physical Z80 at 5v and the FPGA at 3.3v.  I did mention earlier that I'd be level-shifting the voltages between the system and GPU, probably using 74LVC buffers or transparent latches or whatever, so don't panic.  ;D
Post by: legacy on October 19, 2019, 09:50:40 am
no panic, just, I did this stuff two years ago, and it consumed a lot of precious time, hence, reconsidering it, I have some regrets about my past choices. Anyway, I am not here to motivate or demotivate people, so do as you wish. Just, if I were in you, I would about to add extra chips on the PCB.
There are 3.3V Z80 compatible cores.
Post by: legacy on October 19, 2019, 10:25:40 am
(https://jeelabs.org/img/2017/DSC_5808b.jpg)
Like this (https://jeelabs.org/article/1714b)  :D
Post by: james_s on October 19, 2019, 05:22:18 pm
There are some CPUs, such as the 6800 for which there are not (at least not open source) any cycle-accurate softcores. The Z80 however already has more than one very well tested softcore that works just like the real thing, no need to have a real phyiscal Z80 in the mix if you already have the FPGA. The softcore can do everything the original can and much more if you wish.
Post by: nockieboy on October 19, 2019, 07:49:11 pm
Well, I'm building this GPU for a hardware Z80 system.  Whilst I appreciate that the FPGA could do everything my hardware system does, that's not the point of this little project.  Perhaps an FPGA is total overkill, though.
I've been looking a little more closely at the Spartan LX45 and it's looking less and less likely that I'll be able to use it, even if I could justify the cost.  I think BGA is a step too far for my soldering skills and equipment at this stage, and the sheer number of pins on those FPGAs will stretch my DipTrace licence past breaking point.  One way around it is to just use one the cheap development boards and plug that straight into my 'GPU card'.  Limited IO, but with the FPGA, SDRAM, clock and programming circuitry done for me...
Post by: ledtester on October 19, 2019, 07:49:50 pm
You might be interested in the video chip being developed for the 8-bit guy's "Dream Machine":
(starts at 9:50)
https://youtu.be/sg-6Cjzzg8s?t=9m50s
Post by: jhpadjustable on October 19, 2019, 08:03:42 pm
Excellent. That gives me a touchstone to explain some things by analogy. By the way, you didn't have anything important to do this weekend, did you? https://archive.org/details/Amiga_Hardware_Reference_Manual_1985_Commodore   >:D  :-DD
Just for interest, you may be aware there are HDL implementations of the Amiga OCS that might be imported directly into your design, with mimimal modifications. A Z80 driving the OCS chip set could make for a pretty wild experiment, even at 1/2 the memory bandwidth.
Digital design is still not a qualitative discipline ;) , but I'll bite anyway. 75% of theoretical bandwidth won't be much noticeable for relatively low-intensity usage like ping-pong or the like. But also see below.
That would be the memory-mapped window into frame buffer RAM I mistakenly believed you disfavored, but yes, I do think it's a very good idea. I'd also be sure it services reads as well. In fact, once it is servicing both reads and writes, you could make the window very large, like a megabyte give or take, and perhaps scrap the bank switching entirely. Then you have something very much like Amiga chip RAM, in that whatever memory isn't being used by the display can be used by the Z80 for general purposes and/or graphics...
But I was actually proposing that you memory- (or I/O-) map the control registers, using the system bus control/address/data signals to more or less directly read/write registers inside the FPGA and control the video hardware, analogous to the common idiom of using 74377 or similar ICs with suitable decoding as byte-wide input-output ports. C pseudocode:
const struct my_video_chip *video = 0xDFF000; /* ;) */
void setpalettecolor_reg(uint8_t index, uint8_t red, uint8_t green, uint8_t blue)
  video->palette[index].red = red;
  video->palette[index].green = green;
  video->palette[index].blue = blue;
void enabledisplay_reg()
  video->displayenable |= 1; /* SET 0, (HL) */
DipTrace
You could always switch horses to KiCAD. #justsayin
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: james_s on October 19, 2019, 08:15:30 pm
The LX45 is a very nice, very large (by hobby standards) FPGA, I would say that for what you are describing it is massively overkill. Just to put things in perspective, an entire 8 bit computer including the CPU (Grant's Multicomp for example) or any of the bronze age arcade games I've recreated fit comfortably within the ancient and tiny (by current standards) EP2C5T144C8 FPGAs which you can get ready to go on a little dev board for around $12. There is lots of middle ground too, if you want Xilinx the LX9 is an inexpensive and very capable part you can get in a reasonably hobbyist friendtly TQFP package. You can also interface a development board directly to your existing Z80 project and use that for prototyping and then once you have a design implemented that you are satisfied with you can look at the consumed resources and select a less expensive FPGA sufficient for your design and build more tidy custom hardware. One of the really awesome things about FPGAs is that it's very easy to make large portions of the code very portable, a lot of my learning was accomplished by porting projects I found from one platform to another.
Post by: rstofer on October 19, 2019, 09:10:21 pm
It might be worthwhile to compare the capabilities of the XL45 and any of the Artix 7 devices, perhhaps even something as small as the 50T
https://www.xilinx.com/support/documentation/selection-guides/7-series-product-selection-guide.pdf (https://www.xilinx.com/support/documentation/selection-guides/7-series-product-selection-guide.pdf)
https://www.xilinx.com/support/documentation/data_sheets/ds160.pdf (https://www.xilinx.com/support/documentation/data_sheets/ds160.pdf)
I think even the Artix 7 50T has more resources than the XL45 and certainly the 100T which is becoming quite common completely dwarfes the XL45.  The 35T is somewhat smaller than the XL45 if that matters.
None of that resources stuff matters much when compared to the fact that the old Spartan 6 devices are not supported by Vivado and the ISE 14.7 version is the last release of ISE and it is no longer supported.  Yes, I still use it for my Spartan 3 projects but, for new stuff, I'm using the Artix 7 chips and Vivado.
Post by: rstofer on October 19, 2019, 09:36:27 pm
Just for a checkpoint, I have the Pacman game running on a Spartan3E 1200 chip
https://www.xilinx.com/support/documentation/data_sheets/ds312.pdf (https://www.xilinx.com/support/documentation/data_sheets/ds312.pdf)
This is much smaller than the XL45
Pacman rolls around like a BB in a bowling alley on that Spartan 3E in terms of logic, see attached PDF
There is a Z80 core, the graphics display and all of the IO pins and it fits easily in the 3E so it will darn sure fit in the XL45
Note, however, that over 2/3 of BlockRAM is used.  This is typical of most cores; we want a lot of RAM.  There a lot going on with the graphics and PROMs.
This is the board I chose to use.  It's pricey for what it was but at the time it was high end.
https://store.digilentinc.com/nexys-2-spartan-3e-fpga-trainer-board-retired-see-nexys-4-ddr/ (https://store.digilentinc.com/nexys-2-spartan-3e-fpga-trainer-board-retired-see-nexys-4-ddr/)
Post by: nockieboy on October 19, 2019, 10:12:24 pm
Not now...  :popcorn:
Ooh, that sounds like the kind of Frankenstein experiment that just might bear some interesting and very warped fruit...  I wouldn't profess to have a tenth the skills required to do something like that, though.  Whilst I cut my teeth programming on the Amiga, it was with Blitz Basic more than anything else and I never got anywhere near the metal, as it were.
That would be the memory-mapped window into frame buffer RAM I mistakenly believed you disfavored, but yes, I do think it's a very good idea...
Well, I disfavoured the idea of a full frame buffer in the Z80's memory space, specifically.  It would have been prohibitively small and/or meant I would have to modify my (basic) MMU and system bus to accommodate multiple masters on the address and data buses.  That was a little further down the rabbit hole than I care to venture at the moment.  However, a simple shadowing of a small amount of memory (e.g. 4 KB as you suggested) into the FPGA would be easy enough to implement and require no modifications to the system buses at all.
That would require some modification of the host system,  but it wouldn't be impossible I guess.  The easiest way for me to do that would be to keep one of the memory sockets empty, which would provide a 512 KB window that the FPGA could intercept the reads and writes to..  Half a meg would be more than big enough for a frame buffer for the resolutions I'm wanting to use, and would allow double-buffering on all the major screen modes if I was able to substitute that window for 512 KB of RAM on the FPGA via SDRAM, for example... hmmm... Tempting...
Using the SDRAM on the FPGA seems to me and my inexperienced mind to be a lot more complicated than using dual-port RAM in the FPGA itself.  Can anyone convince me otherwise?  If I can make use of the SDRAM easily, without any major drawbacks or slowdowns, then I needn't worry about using a big, expensive FPGA with lots of internal RAM...
I thought that was what I was intending to do previously?  My plan was to use IO port calls to address registers in the FPGA?
DipTrace
Oh I've had this discussion with others before.  When I first dipped my toes in the waters of electronics a couple of years ago, to start looking at documenting the tweaks and changes I was making to Grant's simple breadboard computer designs, I tried using KiCAD.  The experience left me comparing it to older versions of Blender.  If you don't know your 3D graphics software, Blender is an open-source 3D software program that can produce professional-quality 3D models, renders, even films and games.  The power it has under the hood is amazing.  But the UI cripples it and puts up an almost vertical learning curve before you even try to do anything.
KiCAD is like that for me - I just cannot get on with it, can't commit the time to learn it.  I found myself spending more time looking up how to do simple things and create patterns for components that weren't there, that I searched around and found DipTrace.  Yes, I'm limited to 500 pins per schematic for DipTrace (I'm on a free 'hobby' licence), but it's so damn easy to use and makes wonderful PCB designs with none of the complexity of KiCAD that I've put up with the pin limit and it's only become a problem now, when I'm looking at FPGAs that potentially use up all that pin count with one part.  I've actually started using EasyEDA now for this GPU design and whilst setting up the schematic is okay, I'm dreading designing the PCB...
Well, the reason I'm looking at something as overkill as the LX45 is primarily for the RAM size.  I need something large enough to hold a frame buffer internally, so that it can be dual-ported and spit out a pixel stream whilst it's being written to (allowing for timed writes so as not to cause screen tearing, obviously).  Now, if someone can tell me that the FPGA could easily use an attached SDRAM chip for the frame buffer and be able to form a coherent pixel stream without slowing writes down so much that performance would suffer over the internal 'dual-port' design, then I'd be all for getting a smaller, older, cheaper FPGA to do the job.  For one, it'd be hand-solderable and easier to integrate into a custom card for my system and two, it'd probably fit within my 500-pin design limit so I could keep the design within software I am happy working with, so I can't over-emphasise how important a design 'win' an SDRAM frame buffer would be.
As it is, anything in a BGA form-factor will either require me to spend a fortune getting it assembled at point of manufacture and limit my choices to chips the PCB manufacturer offers, or restrict me to making an FPGA dev board socketable into my custom PCB for my system, which will cause headaches as it probably won't fit within my stacking PCB form-factor without modification (removal of power sockets from the dev board etc).
Yes, I've been looking at this as the best Spartan 6 I can get in a TQFP package.  Will mean lower-res / less colours, but it'll still be within my design brief.
Well, that's what I'll be doing initially - I'm waiting on an LX16 dev board to arrive from overseas.  I'll be connecting that up to my system via jumpers and a 74LVC-infested breadboard whilst I test the system and develop the VHDL for it.  Once it's done, like you say, I'm not restricted to only using it on LX16s...
I haven't looked at the Artix range - it's handy to note that Spartan 6's aren't supported in the latest development software, though - thanks rstofer.
Post by: nockieboy on October 19, 2019, 10:19:03 pm
(http://www.downthebunker.com/chunk_of/stuff/public/boards/fpga-sp2-150-gb-adv.jpg)
SP2-150, for GameBOY ADV
This one is 5V tollerant, and it's interfaced with a GameBOY ADV.
Is the FPGA 5v tolerant, or have you done the level conversions yourself?  I can't see much in the way of voltage conversion on those boards?
This was another thing that struck me when I start drawing up the schematic with the LX9 that I was unaware of before - it actually requires 3.3v, 1.8v and 1.2v (or similar, I'm running from memory)?
So I can't just run all the address, data and control lines from the Z80 side through some 74LVC components to translate them down to 3.3v?
Post by: legacy on October 19, 2019, 10:42:34 pm
It was made this way because the FPGA is already 5V tolerant. Certain SP2 were, but starting from SP3 they are all 3.3V. The purpose was to simplify stuff, especially the PCB, which is very small.
Voltage level shifters are fine (2), but ... well, that stuff runs at 50Mhz, not so high speed, but enough to cause signal integrity issues(1), and thus requires more cure. There were a couple of bugs with my first batch of PCB. Then I redesigned them.
(1) Ok, today I own a decent MSO, debugging that stuff is easier than years ago.
(2) you can even use a 5V tollerant CPLD as voltage-adapter, it's a good trick, and it might help routing the the PCB. In my case, I used it to adapt 32bit data + 32bit address + 9bit control from a 5V CPU to 3.3V SP3-500. It was a must, because I realy *HATE* every 68020 softcore, hence I wanted an ASIC chip. Now I am using Coldfire v1, and they are already 3.3V. Easy life, less problems, more fun.
Post by: james_s on October 19, 2019, 11:22:05 pm
Using a gigantic FPGA in order to get enough internal block RAM for a framebuffer is not the right way to go about it. Video cards have been using SDRAM and prior to that SRAM and even regular DRAM to implement framebuffers for many, many years. I'm not going to say that it's "easy" but one of the things SDRAM is specifically designed to be good at is pumping in/out blocks of data synchronously which is precisely what video is doing. Look at some video cards from the late 90s to mid 2000's, these are often made with discrete ICs and relatively easy to tell what's going on. Interfacing to external memory is one of the things FPGAs are optimized to do, they have lots of IO pins and some of them even have onboard dedicated SDRAM interfaces.
Post by: asmi on October 20, 2019, 02:55:40 am
Video cards are also known for requiring (and making good use of) very high memory bandwidth. But it just isn't possible in anything other than BGA packages, as it requires a lot of pins - even the very modest (by video card standards) 64-bit interface requires close to 100 pins to implement, but 128/256 bit interfaces are more popular, and even 512 bit ones are not unheard of. Moreover, most GPUs are modular and each submodule has it's own memory controller, so this requires even more pins to implement as each controller needs to have it's own set of address/command pins. For example RTX 2080 Ti has 11 memory controllers (it's actually the cut-down version of a die which has 12 memory controllers)!
Also since BGA packages provide signal integrity that is far superior to any leaded packages, DDR2 and up memory chips are only available in BGA packages.
Now, I personally love reasonable-pitch BGAs and always choose them over any other packages, but I know some people have some sort of anti-BGA religion, which is why I'm bringing this up.
Post by: james_s on October 20, 2019, 03:01:09 am
Are you forgetting that this is being built to work with an 8 bit Z80? I don't think it needs to be anything super fancy, there's no point in making the video card powerful enough to deal with more data than the host CPU is capable of sending to it. We're not talking about modern high power GPUs.
Post by: Berni on October 20, 2019, 07:40:59 am
Using internal block RAM in FPGAs has a range of advantages, so if a big enough FPGA can be had cheaply enough its a good idea to use it.
Firstly the internal RAM blocks are naturaly dual port and that often comes in usefull, then they are separate blocks that slot together like legos to build RAM of various sizes, so you can have multiple smaller memories that can be accessed in parallel rather than one big memory that everyone needs to get multiplexed to. This last part gives it an insanely high memory bandith too. For the DIYer probably the best of all that it doesn't need any external components and so zero pins to hook up.
But if you want lots of resolution and the ability to bitblit bitmaps around in the 'GPU' (You will need that on a 8bit CPU as that thing will be awfuly slow at pushing pixels around manualy) then you will need more RAM than you can get in reasonably priced FPGAs. The easiest option is SRAM since you just throw an address on its pins and the data shows up, and you can buy it up to about 8MB for a reasonable price. When the Z80 wants to access it you just switch over the CPUs memory bus to the SRAM pins and after its done switch it back to the GPU. Perhaps also add a latch on the bus so you can perform access to SRAM at full speed (~100MHz) and quickly return control back to the GPU while the latch holds the current memory translation on the Z80s bus for its casual 8MHz clock to get around to grabbing the data. You can also use SDRAM, DDR, DDR2, DDR3 and such on FPGAs just fine but its a lot more complex. These memories need some initialization and use pipelining (You execute a read on this cycle but get the data 8 cycles later) so they prefer if you access them in large burst operations while needing to be refreshed by the controller to retain data. Also DDR needs proper length matched traces so you can't just wirewrap wire it together. But as a reward for using any of those complex DRAMs you get gigabytes of RAM for cheep.(Not that useful on a 8bit system tho)
However graphics systems in game consoles have often used a combination of external DRAM and RAM internal to the video chip. Since these chips generate the image live as it is being sent out means that they need to look at a lot of things simultaneously to decide on the color of just one pixel. With the typical memory of the time running in the handful of MHz this made it only fast enough to do 1 or 2 read transaction per pixel. To get around this only the large data is kept in external RAM like actual image data, while other things are kept in lots of tiny internal RAMs inside the video chip, this is things like the color pallete, sprite locations, text charactermaps, sometimes tilemaps... Then as years went by and memory got faster and provided enough bandwidth to perform a handful of operations per one pixel we got more color depth, more layers, transparency, parallax scrolling and all that lovely eye candy. These improvements don't put all that much extra burden on the CPU as the GPU is doing the heavy work of throwing the extra pixels around. The CPU is still just giving it a bunch of coordinates where to draw things, so you can get some amazing graphics from a Z80 if you give it a powerful graphics chip.
But yeah for things that you are doing i wouldn't worry about memory bandwidth since modern memory is so much faster that it will be fast enough for anything.
EDIT: Oh and you would most definitely not want to have your graphics memory directly on the Z80 memory bus, not only does that create multi-master whoes its also slows things down while providing seemingly no real benefit. Its much easier to just connect the FPGA pins to the Z80 bus and have it act as a "gatekeeper" to separate graphics RAM. The FPGA will look to the Z80 like just another SRAM chip so it can read and write to it just the same, but since the FPGA is sitting in between it can hand over the RAM to the graphics hardware whenever the CPU is not using it. A small part of this same "RAM window" memory range can also be used to hold the graphics hardware registers and any other peripherals you might want to have (sound, keyboard etc..)
Post by: nockieboy on October 20, 2019, 09:58:08 am
Okay, so SDRAM is a definite possibility then, which opens the field in terms of FPGA options right up.  I can look at a TQFP 5v-tolerant FPGA (there must be a few around still, or perhaps even the odd one still being made?), strap an SDRAM to it and let it rip.
I have nothing against BGA generally, except I've never had to solder one and (at least it looks like) it requires specialist equipment to get the job done with any level of confidence.  I don't have the funds to throw at an IR reflow oven, so the best option I would have is to build my own - the videos on YT don't fill me with confidence, though.  And I'm stepping a looong way away from one of my goals, which was for my computer to be build-able by just about anyone with a little confidence with a soldering iron.
The other issue with BGAs is that I would likely have to switch from 2-layer PCBs to 4-layer if the BGA grid is dense enough, with cost implications there too.
Indeed.  I'm designing for an 8 MHz Z80 system, from an era when a single DIP-chip would handle the CRT by outputting a composite, UHF or RGB (if you're lucky) signal.  If it can handle vector graphics or a handful of sprites and a bitmap or tiled background on a 320x240 screen so that I can play Pong or Bubble Bobble, I'll be overjoyed.  Anything else will be a bonus.  ;D
This is what I'm intending to do with the GPU - have the CPU pass instructions/coordinates/sprite and bitmap setup data to the GPU, then have the GPU throw the bytes around the frame buffer.
 :-+  Marvellous, that's good to know.
Okay, so how about this for the interface to the GPU?  My current MMU design gives me up to 8x 512 KB chip sockets. Socket 1 is SRAM, Socket 8 is ROM, 2-7 can be anything you want.  If I 'remove' Socket 7 for example, there will be no RAM/ROM in the system trying to reply to the Z80 when it addresses that particular 512KB memory range.  I can then get the FPGA to accept all RD/WRs to that 512 KB window and treat them as direct access to the GPU's frame buffer and registers.  512 KB will only use a tiny fraction of the SDRAM on the other side of the FPGA, but will give the Z80 a huge area to load/assemble bitmaps, sprites, LUTs, symbols into.
Does that sound like a workable plan?
EDIT:
I know this sounds like I'm going back on my original statement that I didn't want a frame buffer in the system memory, but this isn't quite the same thing as an 80's multiplexed frame buffer and all the bus arbitration that would come with it.  This is physically removing a chunk of the system's memory and having the FPGA replace it, if that makes sense?
Post by: Berni on October 20, 2019, 11:29:54 am
EDIT:
Yes exactly the FPGA would act as a memory in that whole 512KB area.
But the FPGA can also do some address decoding of its own to map some hardware control registers into the first 1KB of its 512KB address space while the rest is a window into video RAM. This gives you the area to control the video hardware (Like choosing at what address the framebuffer is for double or tripple buffering, selecting video modes, holding sprite tables etc...). You can also have a register that offsets the 512KB RAM window around letting you roam across 64MB of video memory for example. (Old cartridge based consoles heavily relied on banking to fit the large ROMs into the limited memory space)
Having access to video memory from the CPU is quite useful since you don't need to implement GPU functionality to load images and tables into video memory, instead you just load it in yourself. Also the CPU can use this memory as part of its program. For example if you are making a game you can use the sprite table to hold the position and type of enemy characters on screen rather than keeping this data separate in CPU RAM and then having to update the sprite table in video memory on every frame.
But the main benefit to have video RAM separated and behind a FPGA is that the video RAM can run at full speed. The FPGA can only draw pixels as fast as it can write them to memory so having 10 times faster memory means it can draw 10 times more pixels per second.
Tho the memory bandwidth is more important if you go the modern drawcall route since that tends to keep everything in RAM, rather than the fully hardware based tilemaps and sprites that generate graphics on the fly without writing to RAM at all. On the other hand the drawcall route is more flexible as it can draw any image on to any other image while simultaneously modifying the image, compared to sprites and tilemaps tend to be limited to fixed sizes and grid patterns. But you can still package up tilemap functionality in the form of a draw call like "Draw tilemap(at 0x5000) using tileset(at 0x7200) into framebuffer(at 0x1000 with the offset 944,785)"
As for vector graphics, home game consoles don't use them all that much in 2D. Its usually 3D when vector graphics get hardware acceleration, but at that point the GPU also often ends up having features like matrix math for fast manipulation of 3D points and texture mapping/shading to make those triangles look pretty and textured rather than being flat solid colored triangles. In the past this 3D functionality was hardwired in the GPU (like tilemaps and sprites are hardwires to work in a certain way) as part of its fixed rendering pipeline that takes the 3D models and turns them into a image (like 2D tilemaps turn into a image). Later on this was made flexible by breaking the process up in to steps so the GPU could be asked trough additional drawcalls to do extra fancy eye candy in between the transitional rendering steps. Even later programmable sharers ware introduced and that made GPUs flexible enough to be used as a giant math coprocessor to mine cryptocurencies, encode video and run physics simulations.
So yeah you could generate 3D graphics similar to a N64 on that Z80 if that FPGA had hardware 3D graphics. But getting all of that to work would be a huge project (Doable by a single person but would take a very long time).
Post by: SiliconWizard on October 20, 2019, 03:40:41 pm
I mean the RAM would be accessed alternately from the CPU and the video controller, in like "access slots". The CPU would not be "locked out", since its own access slot would always be available. Sure the video controller would have more slots available than the CPU, but you just need to clock this fast enough so that the slot allocated to the CPU is less than or equal to the minimum memory access time for the CPU (I don't remember about memory access with the Z80, but I'd guess a typical memory access would be more than 1 cycle, thus this should not be hard to get with even a moderately fast RAM chip.)
As I said, to do this in a simple manner, the CPU and video controller clocks should be synchronized and frequencies should be multiple. For instance, if the video controller needs 3 times as much bandwidth, the RAM access would have 4 slots, 1 for the CPU, and 3 for the video controller. The memory access (MMU?) clock would be 4 times the CPU clock here for instance, and the RAM would be accessed at this elevated frequency (which would still not be that fast for a modern RAM chip). Note that it would be relatively easy to do with SRAM, as long as its access time fits the requirements. With typical SDRAM, not so much: implementing such accesses in slots would cause issues because they would typically not be consecutive, introducing possibly unacceptable latencies (yes SDRAM doesn't "like" fully random accesses).
Post by: james_s on October 20, 2019, 06:05:23 pm
I don't think you will find a 5V tolerant TQFP FPGA, but I don't think that is really all that big of a problem. Look at the schematic for the Terasic DE2 board I have, (manual is downloadable) the FPGA it uses is not 5V tolerant but the GPIO can be interfaced to 5V logic without problems. Each IO pin has a dual diode between IOVcc and Gnd followed by a resistor so the diodes prevent the pin from getting pulled too high and the resistor limits the current that can be dissipated by the diodes. It's not as good as proper level shifting but in practice I have used it many times without issues. At the speeds a vintage Z80 runs you can get away with quite a lot.
Post by: langwadt on October 20, 2019, 06:18:59 pm
and afaict the Z80 is TTL input levels so it'll with work with 3.3V input and the usual wimpy TTL high is already limiting the output current, The Xilinx datasheets usually say it is ok to use the ESD diodes for voltage limiting as long as the input current is limited to something like 20mA and the total is less than the sink on that supply
Post by: jhpadjustable on October 20, 2019, 07:46:49 pm
You got this.  :-+
I confess that it is a bit more complicated than using a block RAM, and your system will have to be built to accommodate a response that will take several, possibly varying clock cycles to come back, but that doesn't mean you have to do it all yourself when plenty of open IP cores exist to help you out. Some FPGA design suites will even generate and parametrize DDR/DDR2/DDR3 controllers to your order. Often they will present an interface similar to a synchronous SRAM, but occasionally will be full-fledged bus slaves conforming to whatever standard. Wishbone is common in the open hardware world. It's designed to be modular so that you can simply omit complications that you don't want or need. The Simple Bus Architecture (https://en.wikipedia.org/wiki/Simple_Bus_Architecture) is a minimized version of Wishbone in exactly that vein. Also, the Z80 doesn't do everything all at once, and you don't need to either. Consider using a FIFO inside the FPGA to hold pixel data, maybe even a whole scan line ahead. Pipelining is very much your friend.
KiCAD 4 was a hot mess two years ago, absolutely. The UI wasn't very good or consistent. There were three separate layout toolsets, each with their own particular commands. The library editors were simply awful, which was a real problem in practice. Eagle was far better put together.
Fast forward a couple of years, with the help of the universe-destroyers at CERN and a full-time project manager KiCAD 5 has blossomed quite a bit. The symbol/footprint librarians have been given extra, dearly needed love. There's an interactive push-and-shove router. The three layout toolsets have been unified and rationalized. The whole thing now feels a bit less like a student project and more like a workflow for people to use. Even our gracious host Dave, who worked at Altium by the way, has been moderately impressed with it, even if some of the pro-level conveniences are lacking. If it's been a couple of years since you've had a look, I encourage you to give the latest a fresh hour or two. Be aware that there is still no whole-board autorouter built into KiCAD, and you would need to use an external application for autorouting such as FreeRouting, TopoR, etc. Personally I don't consider that a problem as I prefer more control over where my traces go and how they get there. But, if that's a deal-breaker for you, fair enough, I won't push it.
As a general rule a designer should expect to create their own symbols for any devices out of the ordinary, and treat their presence in the standard or contributed libraries as a happy accident. There are universal librarian softwares and services, who maintain a library of symbols and footprints in a master format and translate them on-demand to whatever eCAD software you have. That doesn't imply that any given universal symbol is well-laid-out or available for that part you need right now. So a decent footprint/symbol editor and librarian is a must.
Disclaimer, I've not used any of the pro-level software, but I cut my teeth on Eagle 4.x and was happy with it until my designs approached the free tier's size/layer/field-of-use restrictions. Now that Autodesk has made Eagle part of a cloud service, it's a hard pass.
Two comments: The delays of an activate-precharge cycle might not be noticed within a 125ns Z80 clock cycle, never mind a 375ns memory cycle. There should be plenty of time even with single data rate SDRAM to complete a burst of 8 or 16 bytes into a pixel FIFO and perform any byte read/write from host or blitter that might or might not be waiting, in a fixed rhythm. Second, the Z80 was designed to make DRAM usage easy, with the row address on the bus early. With some clever SDRAM controller programming, the row address can be likewise passed along early to the SDRAM chip to open the row early, allowing usage of slower DRAM, maybe even the good old asynchronous DRAM chips which are still available, but at closer to $1 per megabyte than $1 per gigabit. Still I think it's overkill for the present application.
Post by: Berni on October 21, 2019, 05:43:31 am
I have been using Altium Designer for quite a few years and despite it being a professional tool and its large library of parts i still end up drawing most of the symbols and footprints myself.
There are certain style guides i want components to conform to, the way they are named, the way i want supplier links for ordering. But above all is how the symbol is drawn. I like to arrange the pins in certain ways to make for a neat schematic, for MCUs i like the peripherals written down on the pin rather than just being called "PB3", sometimes i draw extra things inside the IC rectangle to make it more clear what the chip is doing(Like logic ICs or MUXes or Digital pots etc). So its almost as fast to just draw my own rather than modify there library component to fit my liking.
The important part is that the editors for symbols and footprints are pretty good. I can draw a 100 pin IC in <10 minutes if the pin names can be copy pasted from a pinout table in the datasheet and this includes arranging the pins around to my liking. The footprint for that same chip in TQFP or BGA form takes another 3 minutes because Altium has a footprint generation wizard that supports almost all sensible package types where you just enter about 3 to 10 dimensions from the drawing and it spits out a footprint that includes a 3D model.
Not saying Altium is the best PCB tool because it still does some things badly and sometimes crashes in weird ways, but it does do some things right like library creation (But lets not speak about maintaing large libraries as they have a long way to go there)
Yeah modern SDRAM is so fast the FPGA would be able to present it like its SRAM to the slow 8MHz Z80 since the SDRAM could be clocked so much faster that the FPGA has time to select the appropriate row, execute a read and clock the data trough the pipeline in the time the Z80s read access happens. Or if it got really unlucky and was right in a refresh cycle when that happened maybe the FPGA can pull on the Z80s WAITn line to halt it a bit.
The extra complexity comes in the GPU where to use the full speed of SDRAM it has to be built to cope with the RAMs pipelined fashion. So performing reads and writes in large bursts and making sure it always has something in the pipeline so that it doesn't end up sitting there waiting for data to come in. Yes all modern digital computing is heavily pipelined because its required to get the high clock speeds, but it comes at a price.
Since you probably don't need more than a few megabytes of memory i think SRAM is a safer choice. It is truly random access and has no confusing pipelining.
I have worked with FPGAs here and there and pipelining still hurts my brain as when writing pipelined HDL code its hard to keep track of what register is holding the data for what cycle of the pipeline. I usually tend to have to resort to drawing a timing diagram of the whole thing so that i can visually see how many cycles something is behind or in front of something and then turn that timing diagram into code.
Post by: nockieboy on October 21, 2019, 10:24:11 am
Yes, I really like this idea.  It side-steps the whole issue of using a narrow bottleneck in the IO ports to speak to the GPU and transfer data a byte at a time, and using multiple IO calls to write or read data (setting the register first, then writing or reading from it in the next IO call) and the compulsory WAIT state for each IO transaction.  It also opens up the Z80's 16-bit memory operations.  Not seeing many negatives - I'm sure my little Z80 can handle only having 3.5 MB of 'system' memory space rather than the full 4 MB.  It's a far cry from the 80's when it would only have 64 KB to squeeze a frame buffer and everything else into...  ::)
Nice. Could even copy the character set from ROM in the FPGA to a symbol table in RAM on power-up and allow the Z80 to change it for a customisable symbol set. Lots and lots and lots of possibilities...
Might come back to this further down as the discussion is turning more towards using SRAM instead of SDRAM... not sure there'd be much of a performance penalty for substituting SRAM as it sounds like SDRAM has its shortcomings.  As I'm working with an 8-bit processor running at a modest clock speed, I can't see it needing to make use of the SDRAM's pipelined architecture.  Sure, the FPGA will appreciate it, but with such low screen resolutions and such, I'm thinking SRAM will be a much easier choice for me to deal with.
I think the bandwidth will be important either way, as the sprites, tilemaps and symbol table will all be in RAM rather than ROM.  The symbol table holding the ASCII char set for example, will be read from RAM so that the user can customise the look of it if they desire.  Same with sprites and tile maps - not much use unless they are customisable.
I'm all for keeping this as simple as possible, hence going for the 'memory window' approach rather than interleaving access to shared memory - I've never used SDRAM and know next to nothing about using it, so perhaps the fastest SRAM I can reasonably get hold of would be the best choice for the FPGA's frame buffer?  I use 55ns SRAM for the system memory, would need to be a fair bit faster for the FPGA to improve it's pixel draw rate I guess.
Okay, sounds good.  If the Z80 can talk directly to the FPGA it would make things a fair bit simpler.
I'm using a CMOS Z80 and mostly HCT glue logic, apart from a couple of LS parts in the MMU that the FPGA would be exposed to the outputs from.  That's promising info though - so it could be possible to just connect the FPGA directly to the system's address and data lines?  I have a 3.3v power rail in the system that the FPGA would be powered from.
KiCAD 4 was a hot mess two years ago... Fast forward a couple of years, with the help of the universe-destroyers at CERN and a full-time project manager KiCAD 5 has blossomed quite a bit. The symbol/footprint librarians have been given extra, dearly needed love. There's an interactive push-and-shove router. The three layout toolsets have been unified and rationalized. The whole thing now feels a bit less like a student project and more like a workflow for people to use. Even our gracious host Dave, who worked at Altium by the way, has been moderately impressed with it, even if some of the pro-level conveniences are lacking. If it's been a couple of years since you've had a look, I encourage you to give the latest a fresh hour or two.
Okay, I'll give it another go.  Being limited to 500 pins and 2 layers in my PCB schematic and PCB work is a bit of a bind for me, especially now looking at these FPGAs with pin counts in the hundreds. Heh, I'm even looking at some DIY reflow oven tutorials on YT.  I'm sure I read somewhere that someone used to do BGA soldering with their frying pan?  :o
It's not a deal breaker, but it has been a good reason to stay with DipTrace all this time and work within the licence limits.  I need to really just sit down with an hour or two to spare and put together one of my computer's card schematics in KiCAD and route the PCB and see how it goes.
Of course, and I have been doing that with DipTrace.  The big difference is that I haven't had to do it that often and, when I have, it has been for relatively obscure parts.  The process of creating a new component and its associated footprint is also pretty easy and straightforward.  The only thing that grips me with DipTrace is that it could be slightly more automated in net naming and attaching. Having to manually click on Every. Single. Pin. on a 16-bit address bus and select the next net address line in the list to link to it is a little tedious.  And that's just a 16-bit address bus...  I noticed the other day while playing with EasyEDA that it automatically increments the net name when you click on the next pin - so linking D0-D7 to a RAM chip is as simple as clicking, entering the first net name 'D0', then 6 more clicks on the rest of the data pins and you're done.  Some thought has gone into that UX.
Okay, SRAM it is.  I certainly don't need any extra confusion - I haven't written a single line of VHDL yet, so this is going to be a steep-enough learning curve for me without adding in extra complexity.  :o
Righto, thanks Berni.  Steer clear of SDRAM, got it.  ;) :-+
Post by: migry on October 21, 2019, 04:15:36 pm
Well I have been playing around with hobbiest (read low cost) FPGA boards (both Xilinx and Altera) for the past year, with a particular interest in VGA/video generation and retro computing. So I am going to chip in my 10 cents worth.
Firstly I would recommend visiting YouTube and watching the videos of "Land Boards, LLC" as I think their videos are a perfect fit for answering your questions. I found this channel only recently. They have several videos on implementing Grant Searle's design on a couple of cheap FPGA boards one of which is a Cyclone II board which you might have. They also sell on Tindie and in their videos show a Static RAM expansion board (no idea if this can still be bought). BTW - I have no connection with this company. My interest was the videos they show of the cheap Chinese ZR-Tech Cyclone IV FPGA board. They keep mentioning their GitHub repository, so I think you are likely to find everything you need right there!
Without knowing your level of FPGA, RTL, electronics and video experience/knowledge it is difficult to give accurate advice, but I would suggest start with simple video generation using VGA. There are many text only VGA displays to be found (e.g. OpenCores) which are a great starting point. You will need to get familiar with how video displays work, horizontal and vertical sync and video timings. What is interesting is that todays HDMI "video" is based on the old CRT analogue video standards of yesteryear. Again there is lots of tutorials on the web and YouTube, just one can be found on the FPGA4fun website. Text only video needs little memory so will fit in any FPGA and use internal RAM blocks. VGA allows you to look at the R,G,B and syncs using a scope (if you have one). This can be very educational.
If you want a graphics video solution, then you need frame buffer memory. The problem I faced was that if you want to fit the frame buffer only in internal RAM blocks, this means a very expensive FPGA. Most hobbiest boards use FPGAs with the smallest amount of RAM blocks, to keep the cost low. Adding a fast Static RAM is the easiest way to go, but some FPGA boards don't have enough spare I/O. Some hobbiest FPGA boards have a large SDRAM, but these are not so easy to understand and operate (again check out Hamster's website), and access speed can be an issue. For example one of the retro computer designs (MISTer???) doesn't use the on-board DDR(?)RAM, but adds an external RAM of some kind. So even these clever coders couldn't get the required bandwidth from the on-board memory.
Just FYI, my own solution, is that I designed my own Cyclone II FPGA board/PCB and incorporated a 12ns 128k bytes Static RAM. Even then there were signals crossing multiple clock domains and this caused me a lot of problems  ???  (I am no expert but then I'm no noob).
The "Land Boards" solution added a small daughter PCB with a SRAM for video and CPU memory.
BTW Digilent do a relatively low cost Artix-7 board which has a large fast SRAM, so that's worth a consideration. I have one. FYI, powering this board needs careful attention (otherwise expect lots of USB problems).
Once you have got experience with the "simple" VGA solution, then by all means investigate HDMI. As others have mentioned "Hamster_NZ" has done some excellent work implementing HDMI and his website is a wealth of knowledge. I have re-coded his code in Verilog and ported to a number of different FPGAs. One hurdle is finding a way to hook up the HDMI socket. There are certainly boards which incorporate a HDMI socket but they tend to be more expensive. Some HDMI implementation use LVDS channels from the FPGA directly, but others implement HDMI using an Analogue Devices chip (which might be an easier solution - I do not have one of these boards to try out). I have a board from Numato with HDMI in and out connectors. Also from Numato I bought a HDMI PMOD board, and this has worked well.
The downside of HDMI is that if it doesn't work, it is not so easy to debug. I ported my Verilog to a Cyclone II. I appear to get sync, but the video is wrong. I have run simulations and the channel data packets look correct. I have no idea how to start to debug this! Advice welcomed  :-+
Have fun. and post from time to time with updates or further questions
regards...
--migry
Post by: BrianHG on October 21, 2019, 10:04:54 pm
     Hmmm.   OP:  Can you definitively say what resolution you want for an 8 bit computer?  Earlier you said you wanted XXXkb.  Also, will you have a text mode with addressable modifiable font?  Will the font be dedicated in memory, or use a system memory?  How many colors?  Color palette?  Different video modes on different lines on the screen?  Sprites?
     The problem is with a video controller, you have ram access which is demanding and cannot be part of separate system mory of your 8 bit cpu core, so, is something like a cheap Atari 800 graphics design, the video processor and CPU's memory are intertwined and with a minimum VGA output with X colors, your video output will eat a lot of bandwidth.
     If 64kb is enough, and you want an all internal no ram design, look for a PLD/FPGA with at least 1 megabit internal so it may hold everything with some extra space, otherwise, at the level you seem to be at I strongly recommend buying an existing development eval board for either Altera or Xilinx with a VGA or HDMI out and at least 1 DDR/DDR2 ram chip at minimum.  Make sure the eval board is documented well and not a Chinese only demo code which you cannot dissect to your liking.
Example all in 1, 144pin qfp PLD (no boot prom needed, 1 single supply voltage, I narrowed the selection to 64kbyte and 128kbyte)
https://www.digikey.com/products/en/integrated-circuits-ics/embedded-fpgas-field-programmable-gate-array/696?FV=ii1290240%7C1329%2Cii1677312%7C1329%2Cii691200%7C1329%2C-8%7C696%2C16%7C13077&quantity=0&ColumnSort=1000011&page=1&stock=1&nstock=1&k=max10&pageSize=25&pkeyword=max10 (https://www.digikey.com/products/en/integrated-circuits-ics/embedded-fpgas-field-programmable-gate-array/696?FV=ii1290240%7C1329%2Cii1677312%7C1329%2Cii691200%7C1329%2C-8%7C696%2C16%7C13077&quantity=0&ColumnSort=1000011&page=1&stock=1&nstock=1&k=max10&pageSize=25&pkeyword=max10)
Yes, this is not the cheapest, but it is an all in 1 IC with single supply, no external parts except for video dac (use a 4x74HC574 and resistors if you like) and TTL 3.3v-5v translator IC for data bus, though, you might get away with schottky diode camps and series resistors on the inputs coming from your 5v digital logic.
Post by: nockieboy on October 21, 2019, 11:09:28 pm
Thanks migry, that's a great recommendation - I'll take a look.  :-+
Without knowing your level of FPGA, RTL, electronics and video experience/knowledge it is difficult to give accurate advice...
FPGA level - absolute beginner, never tried programming one (yet)  ;)
RTL level - what's that?  :o
Video experience - I taught my mum and dad how to use their first VHS back in the 80's?  :-\
However, I make up for all that lack of knowledge/experience with a very inquisitive mind, eagerness to learn and able to listen to good advice.  I built my computer (image earlier in this conversation) using those attributes with no prior education or experience in electronics, so I'm confident I might get halfway to achieving my goal of reasonable 8-bit graphics.  That's not to say I think this will be a walk in the park! ;D
...but I would suggest start with simple video generation using VGA. There are many text only VGA displays to be found (e.g. OpenCores) which are a great starting point. You will need to get familiar with how video displays work, horizontal and vertical sync and video timings.
Yes, I've gone through Grant Searle's VHDL code to see how he did his text display and have read up on the video display inner workings - frame rates, pixel clocks, hsync/vsync, back porch/display/front porch, have seen videos on generating a VGA signal using nothing more than 74-series counter logic etc.  I'm hoping I don't annoy everyone here too much that I can't ask questions further down the line on the software (VHDL) aspect of the design.  ;)
Yep, see the screen resolutions table further down this reply - I've calculated how much memory each screen mode will require (though I'm not 100% certain they're totally correct, but I'm a beginner!) All the colour modes are using a colour LUT, so I'm calculating one byte per pixel for a maximum of 256 colours on screen at any one time out of a palette of... lots.
(https://i.ibb.co/5Lm0yst/Untitled.png) (https://imgbb.com/)
Above is a table of screen modes that I calculated I could fit into a relatively small (<64 KB) memory space, if I was going to go with an FPGA of sufficient size and complexity.  Larger memory would allow more colours, but 640x480 is my intended maximum resolution.  The lower resolution modes would be achieved using pixel stretching, or whatever the correct term is for duplicating the same pixel horizontally and the same line vertically to reduce the effective resolution.  The output that the TV would see would always be 640x480 (obviously I'm using PAL timings).
Mode 0 will be the text mode.  This is going to be the first screen mode I try to implement, as there is plenty of VHDL out there doing this already, Grant Searle's code for example.
The text mode, and any subsequent 'non-text' modes which will still be capable of displaying text as well as graphics, will initially use a symbol table in ROM.  My intention as I develop the VHDL design is to copy that table to RAM (if there is sufficient, naturally) at power-up and read it from RAM when displaying text, giving the user the option of changing the design of those symbols (changing fonts, for example, or allowing the use of special characters as graphics tiles).
Currently, it looks as though I'll be using a fast SRAM to store the frame buffer, character tables, colour LUT, sprites etc.  But initially, I'll be using whatever is available in the FPGA as this will be the easiest (and fastest) solution whilst I develop the FPGA design.  Once I have the text mode working, I can start looking to implement a graphics mode in a resolution that will fit in the available FPGA RAM, but will look to move on to using an external dedicated SRAM chip to open up the screen resolutions etc.
The interface will be a 512 KB 'hole' in the system memory, which the FPGA will monitor for read/writes and action accordingly, and provide a few registers at certain memory locations to control things like clearing the screen, text colour etc.
There are two issues with getting an FPGA with a large enough internal memory - otherwise I'd go straight for the Spartan 6 LX45 (or a more modern equivalent) - that's price and, most importantly, the package the FPGA comes in.  I don't have the equipment or skills to reflow a 484-pin BGA onto one of my PCBs.  I'm researching building a reflow oven and learning to use less restrictive (but less user-friendly) design software, but it could be a long time before I have the equipment and confidence to try soldering a £50 BGA onto a home-designed board.
I have a Spartan 6 LX16 dev board on its way with 32 MB SDRAM and a breakout HDMI connector that I can wire to the dev board, so that base is covered.  I already have a VGA connector, as well, so I can try either option whilst experimenting with the FPGA design.
Okay, they're interesting devices...  No, they're not cheap but there's a huge plus straight away - they're hand-solderable LQFP packages and have reasonable amounts of internal RAM... thanks for the suggestion. :)
Post by: BrianHG on October 21, 2019, 11:58:58 pm
For video mode, use a 480p, @ 27Mhz clock for your video out.  This is the standard for all TVs HDMI making outputting that a breeze.  Use the 640x480 for 4:3 centered inside and expand to 720x480 for 16:9.
Go for the 1.28mbit Max10 as it is only 3$ more than the 512kbit.  With this, you will be able to superimpose color text ontop of the 320x240x256 color paletted graphics as well as full vertical height colored sprites.
Remember, you can still store the palette in registers instead of ram, allowing for 1 bank immediate with all the colors being updated during the v-sync for clean pallet animation transitions.
  Internally, run the IC at 4x27Mhz, 108Mhz, (feed it 27mhz and use the internal PLL to 4x or 6x or 8x the source clock, use the PLL output to drive your dac or hdmi transmitter clock)  well within the Max10's 200Mhz+ abilities.  This gives you multiple reads per pixel with the dumbest logic, including the ability to superimpose the text font of 640x480, or 720x480 for 16:9 on top of the 1/4 res 256 color 320x480 graphics mode + multiple colored sprites.
Use internal 2 port ram, 1 read only for video output, having 4-8 reads per pixel at 108Mhz core. (doubling all your video mode specs, otherwise, you have something like 16 read slots per pixel making that read port up to a 16 channel read port with a multiplexed address input and latched data outputs)  An a second read/write port for your CPU access.
In fact, there is enough in this Max 10 to make an entire Atari 130xe with 6502 emulation & graphics and sound...
Post by: langwadt on October 22, 2019, 12:12:10 am
how many are you going to build? when you can get FPGA,RAM,PSU and flash on a board for ~$20 I'd think you'll have to make quite a few to make it cheaper
Post by: asmi on October 22, 2019, 12:18:29 am
Why do you need such a large package? Spartan-7 devices up to S50 are available in a FTGB196 package, which was specifically designed to be fully broken out on a 4 layer board, which are very cheap nowadays. This package has 100 user IO pins (2 banks containing 50 pins each), which should be plenty for your needs. And you can easily solder it using just a hot air gun.
Post by: BrianHG on October 22, 2019, 12:46:11 am
With "effort", that Max10's PLL and LVDS transmitters are fast enough to directly drive 480p DVI. (HDMI compatible, but, no sound or EDID support)  Though, you will still need proper ESD protection on the HDMI port. with load termination resistors to adapt the voltages.
OR:
http://www.ti.com/product/TFP410/samplebuy (http://www.ti.com/product/TFP410/samplebuy)
Post by: asmi on October 22, 2019, 03:23:25 am
Spartan-7 and Artix-7 support TMDS natively, easily outputting 720p and (with some effort) even 1080p on almost any pins (48 out of 50 pins in a bank can be used as differential pairs, and each pair has a pair of ISERDES/OSERDES bound to them).
As for ESD, I love TPD12S521 - it combines ESD protection for main data lanes, and voltage level translator 5 V <-> 3.3 V for DDC, CEC and HPD lines.
Post by: Berni on October 22, 2019, 06:15:16 am
Yep i recommend using the DVI serialiser chip that BrianHG suggested. It makes DVI as simple as VGA since you just put the RGB data into the chip rather than into a DAC, all happening at nice low clockspeed parallel speeds, so its easy to even do 1080p 60Hz
As for memory organization i would recommend you keep the color pallete and character ROM inside the FPGA block RAM. These memories are accessed pretty much on every pixel and are small enough to fit easily fit into it, so it will save you a lot of accesses to external memory. Only keep the large stuff that wont fit inside in the external memory such as framebuffers, tilemaps, drawcall tables...
As for graphics modes id say you could combine modes because you have plenty of bandwidth. Like for example having a 640x480 text mode overlayed across a 640x480 graphics mode with 16 or even 256 colors. Gives you a easy fast way to show text on top of graphics. Tho for any sort of games you probably don't want a oldchool PC CGA like graphics mode anyway as the Z80 might be kinda slow at drawing to it. To make good looking games you probably want tilemap modes like the SNES. The video hardware in that game system has 4 layered tilemaps each using its own color pallete with an additional sprite layer on top. The layers are transparently blended together and can be independently moved around in pixel granularity. This is how the SNES does parallax scrolling that gives 2D platform games the impressive visuals.
EDIT:
Here is a good example of parallax scrolling put to good use: https://www.youtube.com/watch?v=VL7jR1NN4p0&feature=youtu.be&t=837 (https://www.youtube.com/watch?v=VL7jR1NN4p0&feature=youtu.be&t=837)
Its on a Sega Genesis/Megadrive so it has similarly powerful graphics hardware to the SNES but works a bit differently.
The impressive things on the SNES generally use the famed Mode 7: https://www.youtube.com/watch?v=H6u7Nk6_L50&feature=youtu.be (https://www.youtube.com/watch?v=H6u7Nk6_L50&feature=youtu.be)
The hardware behind that is actually not that advanced, its just so called Affine transfromation in the video chip combined with some clever game programming. These transformation just need multiply and addition operations so a FPGA can calculate them in a single clock cycle at high speed using hardware multiplier blocks.
Post by: nockieboy on October 22, 2019, 12:58:33 pm
...Go for the 1.28mbit Max10 as it is only 3$ more than the 512kbit.  With this, you will be able to superimpose color text ontop of the 320x240x256 color paletted graphics as well as full vertical height colored sprites.
Thank you - I appreciate the guidance as one thing I've come to realise during this discussion is that there is so much choice in FPGAs alone, not counting the different ways of interfacing to the system and connecting additional memory, that I'm getting quite confused by it all.
The only question I have about the Max10 is will be able to output direct to HDMI at 720x480?  I know the Spartans I've been looking at have SERDES support built-in.
Well, that's the next thing - with all that space left over, it would be remiss of me NOT to put an AY-3-8910 sound generator (or something else) in there.  That would save me an entire (troublesome) PCB in my system... but where does that stop, I guess?  ::)
A handful initially - one or two, maybe.  The whole thing is a one-off prototype at the moment, but I have intentions down the line to open the design up for people who want to have a go at building it and maybe try to make some of my costs back.
Purely to have enough internal RAM to hold the frame buffer.  If it has the RAM I need and can drive an HDMI output without too much hassle, it sounds like a good idea.
It would be nice to have sound too.  :(
OR:
Okay, so the TFP410 and a MAX FPGA are starting to look like the best option (the issues soldering the Spartan packages are a big hurdle, unfortunately) - will I need something like the TPD12S521 for ESD protection if I'm using a TFP410?
Yes, that makes sense.  I think I'm going to try my best to keep it ALL in the internal block RAM if I can, with a view to expanding into external RAM as I get more experienced and comfortable with the design, VHDL and FPGAs in general.
I think I mentioned several times that I intend to keep the charset in ROM and copy it to RAM when the FPGA is turned on - just to clarify, now I understand a little more about the FPGA architecture, as I understand it the charset will be in RAM anyway, just re-instated to its default data every time the FPGA is turned on, so changing the charset/symbol table will be possible from the get-go.
Yes, that sounds like an achievable goal - though I'm going to take baby steps getting there, building on the basic text-only mode and improving it as I learn.
I thought you were going to link me to something like Shadow of the Beast on the Amiga. ;D  Do you think what I'm designing would be capable of that sort of output (perhaps at a lower resolution?)
That's impressive stuff - some might say almost black magic for a Z80 to be able to pull off?!  (I know it's the power of the FPGA doing the gruntwork, but still, the Z80 would get the credit)  ;)
Post by: Berni on October 22, 2019, 03:33:11 pm
Yeah you will be able to fit it all into internal block RAM no problem as long as you keep framebuffers small since those tend to be the largest. Indeed taking baby steps is the way to go. The VGA using 74xxx series logic is an excellent video to demonstrate how you would also develop video output on a FPGA. First you need to build a video timing generator, then once that is working set up pixel coordinate counters, feed the counters directly into the RGB data lines to make sure they generate the counting color pattern you expect, then hook up some memory between the counters and RGB lines to actually generate some images. Once you have that you essentially have a working video card where you can slowly tack on features such as a text mode, or tilemaps. This sort of progressive workflow is excellent especially for starting out since you will have enough to learn as it is and probably won't be interested in design validation trough simulators and timing analysis from the start. But once you had enough headaches debugging a non working design on real hardware you start to see why HDL simulators and writing test benches are a good idea. But still getting a cheap FPGA devboard and just having at it with simple projects is the best way to start.
As for what is possible, all the videos i have linked are perfectly possible on a Z80 with grunty enough video hardware. This also includes "Shadow of the Beast" for the Amiga, all the pretty multi-layer scrolling is the hard work of the video hardware. Each layer is its own image that is being transparently overlayed by the video chip. Additionally the Amiga has bitblit functionality so this is essentially a crude 2D GPU that can move and draw images in memory on its own while the CPU is free for other tasks. So the CPU here has very little work to do as its only running the game logic, updating positions of all enemies, changing coordinates of the layers to make them move in that sweet parallax way and commanding the bitlit to fill in the edges with more of the level as needed.
This video hardware is the reason why graphics on consoles looked so impressive while PC games looked like crap in comparison despite having faster CPUs. The PCs for a long time had very dumb video hardware that could only barf out a framebuffers contents to the monitor and that's it(ignoring text mode). So the CPU had to work hard and draw every single pixel. To get 3D graphics on PCs they had to cheat in all sorts of ways using raycasting, so early 3D games like Wolfenstein3D, Doom, Quake etc. are not actually rendering in 3D, but is actually a 2D world made to look 3D trough graphics trickery. By the time PCs got fast enough to render proper textured polygon 3D graphics, the consoles already had hardware accelerated 3D chips in the Sony PS1 and Nintendo N64 that could look way better and run smoother. Its when PCs got hardware 3D accelerator cards like the Voodoo, that's when they could finnaly rival console graphics.
Even today graphics cards are the ones driving 3D towards looking ever more impressive. Even as CPUs hit the clock speed barrier 15 year ago they kept getting faster at an exponential rate, mainly thanks to the inherently parallel nature of graphics tasks, while 15 years ago graphics cards might have had 16 processing cores in them today they have >1000 cores being fed data from a huge array of DDR memory chips at terabits per second. For a modern PC to render a beautiful highly detailed 3D scene all the CPU has to do is load in all the models and textures, give it the draw call instruction list and say "Hey GPU please render this for me". A few miliseconds later using trillions of math operations and gigabytes of data moved around out pops the finished image while the CPU was doing absolutely nothing.
EDIT:
Oh and if you wan to learn about the various graphics tricks that are used everywhere this is one of the best youtube channels for it:
https://www.youtube.com/watch?v=nBzCS-Y0FcY&feature=youtu.be&t=2310 (https://www.youtube.com/watch?v=nBzCS-Y0FcY&feature=youtu.be&t=2310)
The linked video is one of his more impressive things where he created a polygonal 3D rendering engine in pure C++ code running on the CPU, so it guides you trough all the ideas and math that are used under the hood to generate 3D graphics. Its completely impractical because its slow, but it shows exactly how it works because its coded from the ground up without any graphics library. In his other videos he goes into all sorts of other really common graphics algorithms that are used everywhere like for example the affine transform, vector drawing, pathfinding, colision detection, game physics, edge detection, image processing... etc
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: jhpadjustable on October 22, 2019, 08:46:03 pm
Two notes as preface: 1. There are MOS 6581 (https://github.com/alvieboy/ZPUino-HDL/tree/master/zpu/hdl/zpuino/contrib/NetSID/src) IP cores available, which you can instantiate just like any other VHDL entity, hook up address/data buses, supply with appropriate clocks, and connect to the DAC of your choice. 2. Back in my home computer days, sound programming was my specialty. Over the course I have developed some Opinions on this matter. :)
The Amiga sound hardware was remarkably simple, and it's worth considering as a guide. Each channel isn't much more than a period down-counter, an address up-counter, a sample length down-counter, and a few double-buffered latches. Being relatively insensitive to latency, a double-buffer for sample data allows you to take your sweet time reading the next sample(s) from memory and simplifies its integration into the system. Very likely you have hardware multipliers on the FPGA for volume control, AM effects, and so on. I2S is a standard interface to audio codecs and is pretty easy to use for just digital output: a continuously-running clock, a shift register, and a word (left/right channel) select is about it.
Remember when I half-jokingly suggested putting a Z80 core on the FPGA? Does that perchance remind you of any Sega console's sound hardware? ;) You wouldn't have to worry about DMA at all, just let the software do it...
You can use those block RAMs as FIFOs very easily (example user guides from Xilinx (https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v12_0/pg057-fifo-generator.pdf), Altera (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_fifo.pdf)). You can stream the entire next raster line from the external RAM into them at the fastest pace it allows then deal with it locally according to the pixel rate, a la hierarchical memory (https://en.wikipedia.org/wiki/Memory_hierarchy). In fact, this allows you to decouple the RAM clock from the pixel clock which makes your job a lot easier, enough that you can incorporate existing DRAM/SDRAM/DDR controller cores to expand the framebuffer (or can we now call it "chip") memory without limit.
Eventually. :)  Multi-playfields are largely about memory organization and bandwidth. One key is to decouple the pixel fetch start/stop timing, memory addressing, and row stride from the display window start/stop timing, so that the former can be moved around independently of the latter, and only require that the CPU redraw the columns/rows that would be revealed in the next frame before moving the pixel start address around. Another key observation is that Amiga etc. video memory was often planar-organized (https://en.wikipedia.org/wiki/Planar_(computer_graphics)) to conserve frame buffer memory and use the memory cycles allocated to the pixel data most efficiently. With bit planes being indexed, addressed, and fetched entirely independently, the addition of a dual-playfield mode requires no modifications to the memory fetching system, only a bit of steering logic in the pixel pipeline and a priority encoder to establish Z-index relationships. Have as many playfields as you like.
Post by: rstofer on October 22, 2019, 10:28:02 pm
For pixel graphics, there is no reason that both sides of the BlockRAM need to have the same word width.  The CPU can read/write in bytes while the graphics controller can grab up some huge number of bits at a time.
https://www.xilinx.com/support/documentation/user_guides/ug473_7Series_Memory_Resources.pdf (https://www.xilinx.com/support/documentation/user_guides/ug473_7Series_Memory_Resources.pdf)  About page 21
In theory, and I concede to never having tried it, you could organize the video side of the BlockRAM word width to be an entire scan line.
Of course, with dual port memory, you don't need to do this but it might be a technique to just grab the entire raster line into the pixel shift register during horizontal retrace.
Post by: BrianHG on October 23, 2019, 12:16:13 am
Understand that DVI transmitter cores are free available.  I'm not sure about HDMI (maybe copyrights, but a public domain transmitter may exist), however when saying sound, this means whatever your sound generator generates, you would need re-sample convert any audio generated to the standard fixed 48Khz audio within the HDMI standard.  Also, HDMI is YUV not RGB like DVI, so, you will also need a color space converter.  (easy peasy as it is nothing more than 3x3 multiply adds...)
Now, the Max10 can run upt to 400Mhz internal and the LVDS serial bus up to 750Mhz.  That means 720p capability, but with only 128kb ram and an 8bit cpu, you are not striving for this...
You have enough logic and hardware multipliers to do the colorspace conversions.
You have the internal dual port ram speed to superimpose translucent text with animated color character fonts.
Enough registers galore to control playfield, sup-pixel video offset of font tiles for smooth scrolling tricks, number of bytes per line with margins.
Also, on your video output mux output layers with translucent colors, don't forget to add pixel / sprite collision detection registers.
In the max10, you should be able to make an enhanced 16 bit version of a 6502 processor running at over 108Mhz, maybe at 8x27Mhz video clock of 216Mhz.  It would make a SNES look like a snail.
You would never have to worry about external Dram access or memory interleave timing.
With all the FPGAs ram as a dual block, one side would be a dedicated video and audio generator while the other would have interrupt free access to an external CUP, or an internal soft-core cpu.
Yes, on my video designs, I have my video read port only side set to 32 bit (note that I have 30bit color video, or 24 bit color with 8bit alpha blend channel) and my other side set to 256bit (I have access to 128bit DDR2 memory modules, yes this speed is needed for a 4 layer 1080p video blender)  In your case, you would want 8bit or 16bit on your read only video output port as you only go up to 256 colors if you want to use 1 byte per pixel.  It also makes access to you font bitmap easily addressable to any byte in ram.   You did say this is for an 8-bit computer.  On the CPU processor side, you can choose 8, 16, 32 bit if you like, but realize you may need to use a byte write enable depending on how your CPU or graphics image processor may move individual bytes around for effects like fill, copy, clear and stencil.
Post by: hamster_nz on October 23, 2019, 01:24:05 am
If the H/W can do DVI-D video, it can also do HDMI with audio. Once you get video working, have a look at this project that implements the HDMI data islands required for proper HDMI video+audio support;
https://github.com/charcole/NeoGeoHDMI
But consider it a stretch goal!
Post by: legacy on October 23, 2019, 05:36:15 am
A thing I would really appreciate is a PCI Video framebuffer, made on neat and fully documented design.
VDU and 2D primitives to support X11 are all it needs to have.
There are PCI bridges to local legacy bus (kind of ISA, 16bit, with fixed address, and IRQ), hence even a simple VGA controller for 8-bit computer can be interfaced.
Not too bad, at all, and this would be seriously appreciated on non-x86 workstations where the only good thing you can do is:
- adding a Matrox M1/M2
- hacking an ATI XL
Both were reverse engineered, hence the support for what the hardware can really do is limited to the 20%
a miniPCI Video Card made on FPGA would be a super premium
ah, sweet dreams ... are made of this :D
Post by: asmi on October 23, 2019, 02:31:02 pm
PCI is quite a simple bus, with full specification publicly available. So I don't see any major obstacles in implementing this. Essentially PCI is nothing more than a DMA channel into the system memory.
Post by: langwadt on October 23, 2019, 03:38:48 pm
afaik HDMI supports both YUV and RGB
Post by: nockieboy on October 23, 2019, 04:00:06 pm
Yeah you will be able to fit it all into internal block RAM no problem as long as you keep framebuffers small since those tend to be the largest. Indeed taking baby steps is the way to go... But still getting a cheap FPGA devboard and just having at it with simple projects is the best way to start.
I think I'm going to make a start fairly soon with my Cyclone II.  Yes it's old, but I should be able to get a VGA text display up and running, perhaps even with some basic graphics, in the short term.  When the Spartan 6 (LX16) dev board turns up, I'll move development to that and start looking at the switch to HDMI and building out the resolutions a little further, with more work on the GPU side to flesh out the graphics capabilities.
As far as the Intel MAX 10 series (https://www.intel.co.uk/content/dam/www/programmable/us/en/pdfs/literature/pt/max-10-product-table.pdf) goes, I agree they're the probably the best I can get in a package that I am (and more importantly, others are) able to solder by hand.  I'm thinking for the sake of another fiver (~$6), I'll get the 10M50 which has over 200 KB of RAM and should give me all the room I need to do what I want with the graphics and sound.
This leads me on to choice of a development board for the 10M50, though.  Sheesh - they're not cheap for a hobbyist at my level!  I've had a look at these two:
AliExpress DE10 Lite 10M50 CPLD Development Board with VGA (https://www.aliexpress.com/item/32842850135.html) - £74
AliExpress 10M50 Eval Kit with HDMI (https://www.aliexpress.com/item/32680316361.html) - £130
Now, out of the two I prefer the 10M50 Eval Kit - yes, it's nearly £50 more expensive, but it has less rubbish on it that I won't use taking up IO pins and it has an HDMI port built-in.
Anyone have any opinions on these or suggestions for alternatives?
...So the CPU here has very little work to do as its only running the game logic, updating positions of all enemies, changing coordinates of the layers to make them move in that sweet parallax way and commanding the bitlit to fill in the edges with more of the level as needed.
I guess there's no reason why the FPGA won't be a graphics co-processor and blitter in one device if I can build those functions into it.  What was it, jhpadjustable?  Agnus, Denise and Paula rolled into one? ;)
Yes, I've found AY-3-891x VHDL code as well, so it looks relatively easy to sort out.  It could just be consideration how I get that audio data down the line to the TV.
Ah, pull up a chair and have a beer.  I may need to pick your brains later on when (if!) I get to the point of sorting out audio in VHDL!! ;)
You make it sound so easy!  :o  I can just about play the theme tune to Red Dwarf on a keyboard.  There endeth my knowledge and skills on the subject of audio and music!  ;D  I2S? Audio codecs? Digital output?  So I could output in MP3 or something?
Okay, that's an interesting idea for when/if I get round to using external RAM (it'd make the FPGA choice a lot cheaper!)  Set up a couple of pixel stream FIFOs in internal RAM and use the external SDRAM to burst-read into the one not being read from at that moment, so access to the external RAM would be in short bursts to read the contents, allowing the GPU to access it for data writes etc. in-between?
There's a heck of a lot of jargon in there I just don't understand - "pixel fetch start/stop timing", "row stride", "display window start/stop timing"... so much to learn.  Is there a book on this stuff anywhere, or a website, or more YT videos?  I have yet to sit down with some spare time and go through some of the linked videos in the YT links people have made in previous replies, though...
Just clear up a little confusion for me - DVI sort of equals HDMI?  Would I be able to use an HDMI connection to a TV with a DVI IP core?
The colour space converter sounds like a simple bit of VHDL to add to the project, but what about the audio conversion?  Are there IP cores for that sort of thing?
That'll come later, but yes I'll need to think about how to add collision detection etc.
I do like the sound of that.  It's just a high price to pay and I can see that I'll want to try to overcome the issues with external RAM so that I can use a smaller/cheaper FPGA.
...but realize you may need to use a byte write enable depending on how your CPU or graphics image processor may move individual bytes around for effects like fill, copy, clear and stencil.
Huh? Sorry, I don't follow.  Could you expand on this a little, please?   :-\
Post by: legacy on October 23, 2019, 05:44:18 pm
I mean, if someone develops a simple video card for 8-bit computer, I know to add a PCI interface to it: via PLX chip. Already done, my team has the know/how and a dev-board to manage it.
Post by: Berni on October 23, 2019, 06:02:05 pm
Yes having the video output hardware and blitter in the same FPGA makes a lot of sense since both need access to graphics RAM. Its not all that difficult to MUX the memory bus inside the FPGA around to different parts that need it. That blitter will let you move things around in RAM at easily >10 times higher speed than the Z80 could.
In fact you can even use the same graphics RAM to hold audio data too. Typically memory is not needed for that since the audio from the 8bit era tend to be just chiptune like for example the Commodore SID chip. But later on MOD music became popular since it had the flexibility of wave files but was still small in size. This does need a memory to hold the audio samples in RAM for quick access and would be quite a lot of work for a Z80 to turn into wave audio to send to a DAC. So if you want an audio chip that can play pretty much anything you might want to have a MOD player in a FPGA that can play these files from memory without the CPUs intervention. But for a start its best to stick to some basic analog synthesis to generate beeps when you write to its register since that can be written and tested in HDL in a few hours if you know what you are doing.
For audio output out of the FPGA i would just simply have it generate a fast PWM signal that gets smoothed by a RC filter into analog audio. It only takes about 5 lines of code to write a PWM generator in HDL and everyone has a spare resistor and capacitor laying around. Makes for surprisingly high quality audio when the PWM is running fast enugh. But if you want proper hifi quality audio you can always add a I2S DAC chip to the pins. The I2S bus is almost the same as SPI so its really easy to generate in HDL too. You still could not play back MP3 tho because decoding MP3 requires quite a bit of floating point math and im sure your poor Z80 wouldn't enjoy that. It could be possible if you also added a floating point math coprocessor to the FPGA so that the math could run nice and fast, but this is really pushing the Z80 into things its really not meant to do.
As for HDMI and DVI. Pretty much DVI is part of the HDMI feature set. It uses the same 3 data + 1 clock diff pair with the same signaling levels and uses the same TDMS encoding to AC balance the signal and provide error correction. Both DVI and HDMI support the RGB color format, but HDMI can additionally also handle YUV. Its all still just glorified LVDS video with fancy encoding on top. What HDMI does differently is sneaking extra data into the video blanking periods, this is where audio and other stuff is sent, and there is support for encrypting the whole video stream via HDCP (This is just the movie industry trying to keep people from pirating stuff, but its hilariously ineffective). But all this is why you can create a DVI to HDMi adapter by simply cutting apart two cables and splicing together the right pairs, both are almost the same thing just on a different connector.
Id say for a start stick to raw VGA directly from the pins so that you can learn all about video timings in a way that is easy to look at with a scope. Its easy to then turn that into DVI by pretty much just running the exact same signals into a DVI serializer/encoder block rather than straight out the pins. Just get a cheap FPGA board and play around rather than worrying about it. You can always buy a bigger board later on. Just keep in mind that porting code between two FPGAs of the same vendor is pretty easy, porting it to a FPGA from a different vendor is usually not easy at all (The HDL code is perfectly portable but any hardware specific blocks like block RAM and FIFOs are not) and you have to relearn a completely different IDE.
Post by: asmi on October 23, 2019, 06:18:16 pm
If the only thing you want from the card is to hold a bitmap and output it via some interface, this can be done using Vivado with zero HDL code: MIG to interface with framebuffer memory, PCIE to AXI bridge to read/write data to the framebuffer from the host, "Video Frame Buffer Read" to stream frame from memory, VIC and PHY of your choice to actually output the video to the interface of your choice.
But a video card is far from being only "framebuffer adapter". In addition to all of above it needs to provide some kind of drawing and composition functions. This is even more important if your CPU is very slow. And this is the hard part.
Post by: jhpadjustable on October 23, 2019, 07:06:02 pm
Eventually ;) Paula's duties included ADCs for the game port, DACs for audio, the UART (you probably already have one) and floppy disk I/O (you probably don't have one). Those don't directly translate to the FPGA model, but she can be there in spirit.
I'm more of a Verilog guy but cheers, I'll keep an eye out and help out where I can. :)
Not even Popcorn? For shame! Anyway... codec has an archaic definition of a full-duplex digital-analog converter, an ADC and DAC in one package, usually with a common clock and common framing signals. I should have said ADC/DAC or something like that. MP3 output would be possible, but doesn't seem very interesting due to the lack of direct output devices and the latency, and the rather large number of gates required. TOSlink might be cool, if you have a use for it. The nice thing about all this extra hardware is that you can place footprints on the board for it and not stuff them, or stuff them and just not hook your HDL up to them, leaving them as exercises for the experimenter.
Better than that, you can use a single FIFO and fill it whenever you feel like it and there's room. You don't need to double buffer because they're inherently semi-dual ported. But you've got the general idea right.
The Amiga HRM I linked earlier is an excellent, accessible resource that's fit for people with basic programming and hardware knowledge. While they won't tell you much about the gate-level implementation, Chapter 3, Playfield Hardware, describes the general concepts of raster video display in the context of the specific case of the Amiga OCS. Translating from my language to theirs, pixel fetch is called data fetch, row stride is approximately equivalent to playfield width, and display window is display window.
I believe he's referring to the rather common possibility that an external RAM chip's external data bus is more than one byte wide, and therefore has a few extra byte-select signals that need to be considered when writing only part of its total width. I think you'll find this ISSI pseudo-static RAM in a hobbyist-friendly TSOP-II package (https://www.digikey.com/products/en?mpart=IS66WV51216EBLL-55TLI&v=706) and its datasheet accessible and interesting. Its byte write enables are UB# and LB#. They're much like an extra set of chip enables for each separate byte, so that only the desired byte parts of the two-byte-wide bus are driven or sampled. The truth table on datasheet page 3 and timing diagrams throughout may help.
As someone who is not completely unknown to the exotica branches of the Amiga audio community... Hard-coding the MOD format in HDL? Just... no. It will only get in the way. I would strongly suggest, for simplicity, borrowing the Amiga's audio architecture whole, and letting the main CPU be interrupted at however many ticks per second to adjust the DMA/pitch/volume registers as needed. That way it's much easier to borrow channels for sound effects over/under the music (if desired), and allows for 16-bit samples, various packed tracker module formats or multichannel formats like FastTracker, and formats that are not reducible to the drum-machine tracker paradigm, such as TFMX. We've got to give the poor Z80 something to do, haven't we? ;D
Since this isn't for a proprietary product, IMHO it's worth leveraging any open IP cores that can help rather than do all that from scratch. I think MP3 needs more than a floating point coprocessor, probably closer to a complex math accelerator with its own (small) program store to do IDCTs and such.
But most logic synthesizers will be able to infer memory from HDL, perhaps with a bit of coaxing, and FIFOs are just control logic around those memories, no? At the speeds of interest, fabric implementation of FIFO functionality would do, no?
CGA outputs video. It's in the form of a card. What exactly are you insinuating here?   :box:
Post by: Berni on October 23, 2019, 07:39:37 pm
Well i didn't mean a fully autonomous MOD file format player that could read a .mod file byte by byte. Just audio hardware that is well suited for playing it back like having the ability to play back various wave samples from memory at various pitch with multiple channels. Makes it easy to have very impressive sound without a ton of HDL code or a lot of CPU effort to play it.
Yeah its possible for the compiler to infer block RAM into a design, but i never really trusted it with doing that since small details in the way you implement it in HDL can make the compiler refuse to do it because it might not look similar enough to the hardware block. But it is not only for block ram, similar goes for other hardware features like PLLs, hardware assisted serdes, DDR pin drivers, retiming flipflops inside IO pin logic etc... So offten the way it is done for block RAM is that an abstraction layer is put in place where a HDL file holds the implementation module for the block RAM and upon porting it you are supposed to replace the implementation with your vendors one and implement any logic around it to get it to provide the same signals (Like flip some lines around, add a latch if it needs it, make the reset work the same way...).
And overall the vendors tools often provide a sizable collection of useful auto generated building blocks. This ranges from simple stuff like a RAM or FIFO to interfaces like DDR2 memory controllers to stuff like heavily chip optimized FFT, DDS, FIR filters etc... And goes on to even broader tools that generate entire systems like Altera Qsys that automatically generates memory and streaming buses to connect components such as softcores, memory, peripherals etc... magically taking care of stuff like bus width and timing adaption, multimaster bus arbitration, addressing etc... (I actually quite miss that tool when working with Lattice chips)
Post by: legacy on October 23, 2019, 09:53:28 pm
PCI, not PCIe, and I want to the PCI stuff done via PLX. I don't want anything done in FPGA regarding the PCI. I have a lot of experience with PCI, and not a thing I want to handle in FPGA.
Post by: jhpadjustable on October 23, 2019, 09:54:13 pm
That I can absolutely agree with. As I mentioned to nockieboy upthread, each channel isn't much more than a handful of down-counters and double-buffers attached to a DMA channel. Then multiply, sum, and ship to the DAC.
All very good points.
I haven't played very deeply in the extra tools of Quartus and never even opened up Platform Designer. That looks really handy. Next time I have an FPGA project in front of me I'm going to have to play with that. This is why I come here  :-+
Post by: legacy on October 23, 2019, 09:56:24 pm
I said with the minimal 2D functions to support X11.
Post by: legacy on October 24, 2019, 02:48:54 am
The SEGA Geneis (Megadrive) uses a similar idea with the uPD41264 chip made by NEC :D
Post by: BrianHG on October 24, 2019, 04:32:41 am
Ok, understand that the biggest cheat you have going for you when using the MAX10 internal static ram block is that on one side, for your dedicated video graphics and sprites and audio output, you will use an 8 bit port with an address which points to each individual byte.  You can get 1 new byte read 216 million times a second while only needing 1/8 for a true 256 color paleted image, another access cycle for a font byte image lookup, another for a sprite and another 4 or so once every H-sync for audio data.  Sorta like the Amiga Paula and Denise.
(This is separate of you global screen offset controls generally used for oversized image scrolling)  Now, if you also want a Blitter like the Amiga Agnus, this would involve reading a reference graphic and reading the destination display memory, working out the source image transparent stencil bits, within logic registers, paste over the destination read source memory so you are effectively singling out individual bits, then writing that logic register's result back into the destination display memory.  This is the hassle of pasting graphics with transparent bits where you also may want to shift left and right the bits of the source image data to move a pasted graphic 1 pixel at a time onto a bitplane style graphics.  Having this hardware blitter remover you 8 bit CPU from doing this manually when you want to paint brush images onto a bitplane style display.  You have the luxury because of the Max10's speed, logic density, and that dual port ram's nature to place such an image blitter on the 8 bit port side, or on the CPU read/write port side, or even half and half.
In 256 color, byte per pixel mode, just read the source rectangle graphic data and only write the pixel bytes to the destination if the stencil isn't transparent.  Wow, so much simpler but you need a whole lot of video memory to keep every pixel a single byte.  (This would make an insane arcade machine for 20 years ago, but you would want at least 2 full video page memories.)  (I wish the Amiga 1000 had 2mb chipram with an allowable 8 ram and worked with 8bit and 16bit pixels only, no bitplane rubbish, it would have flown except for the slow logic of the 1984 era when it was engineered, all they had to do was get the ram working at 28.6Mhz instead of 14.3Mhz, and 2mb of it the cpu didn't need to go any faster.  The price of memory would have been the killer.)
On the other side of you dual port memory you may also use a wider bus like 16 bits to interface with your CPU, however, what I am saying is if you do so, in Altera's/Intel's dual port memory configuration tool, you have a byte-enable feature which allows when writing to your dual-port ram's 16 bit side, writing to only the high or low 8 bits, or both.  This write-masking is necessary for CPUs doing an 8 bit write accessing a 16 bit wide ram.  Otherwise, your CPU will need to do a 'Read-Modify-Write' to write only 8 bits on that side.
Now everything I'm telling you is possible with relative ease since you do not have to wait for any external ram cycles and having to cache read and write bursts from external dram and it's controller.  You do not need to pipe anything at all.  However, going the other route with large external memory and speed, you can always simulate a bitplane display for your 8 bit cpu and just have 16 bit word pixels and do everything like a software emulator which grants you some enormous flexibility, but you will always be refresh generating a display, a page behind with dedicated buffers to cache memory with tons of wasted dram reads to address single bytes in the middle of larger bursts just to get to those single key important bytes whenever you need random access.  Otherwise, you will be either engineering a smart cache mechanism, or slowing everything down to even faster DDR memory's precharge and post charge cycles.   Normal DRam in some cases wont be any faster, but sequential bursts will be like lightning in comparison.  Other than painting a line of video,  how often does that happen in a 8 bit cpu world which has no smart cache.
Post by: BrianHG on October 24, 2019, 07:11:53 am
Just so we are clear, there exist cheaper FPGAs with more than 1 megabit pr internal ram out there, but, you would need a VCCIO and VCC core supply & bootprom.  Example:
1.9 megabit core for 16$  (Good for animated 360x240x256colors with 2 fame buffers for animation plus another 80kb for software)
It also has double the logic elements...
https://www.digikey.com/product-detail/en/lattice-semiconductor-corporation/LFE5U-45F-6BG256C/220-2198-ND/9553911 (https://www.digikey.com/product-detail/en/lattice-semiconductor-corporation/LFE5U-45F-6BG256C/220-2198-ND/9553911)
https://www.mouser.com/ProductDetail/Lattice/LFE5U-45F-6BG256C?utm_term=LFE5U-45F&qs=w%2Fv1CP2dgqpblS%252b2xYE99A%3D%3D&utm_campaign=LFE5U-45F-6BG256C&utm_medium=aggregator&utm_source=findchips&utm_content=Lattice (https://www.mouser.com/ProductDetail/Lattice/LFE5U-45F-6BG256C?utm_term=LFE5U-45F&qs=w%2Fv1CP2dgqpblS%252b2xYE99A%3D%3D&utm_campaign=LFE5U-45F-6BG256C&utm_medium=aggregator&utm_source=findchips&utm_content=Lattice)
Eval board is expensive since it comes with a 3.8Megabit FPGA, but, it gives you play room.
Also, the serdes on this Lattice part is fast enough to directly drive DVI/HDMI 1080p.
You'll be using so few IOs that a 4 layer PCB would be fine.
And you can still place a single DDR2/3 ram chip on the PCB if you like...
Post by: jhpadjustable on October 24, 2019, 04:56:46 pm
Nope, no SERDES on that part. Anyway, Lattice requires a subscription license to use SERDES-enabled chips so it would be useless to open-hardware hobbyists if it did. The BGA package is also a bit impractical, the comparatively generous 0.80mm pitch notwithstanding.
Post by: SiliconWizard on October 24, 2019, 05:07:29 pm
Yes. The only ECP5 parts that have SERDES are the LFE5UMxx.
http://www.latticesemi.com/en/Products/FPGAandCPLD/ECP5 (http://www.latticesemi.com/en/Products/FPGAandCPLD/ECP5)
One way of evaluating it AND get a free license for this part is to buy a VERSA kit: http://www.latticesemi.com/en/Products/DevelopmentBoardsAndKits/ECP55GVersaDevKit (http://www.latticesemi.com/en/Products/DevelopmentBoardsAndKits/ECP55GVersaDevKit)
(I think the license is restricted to the part used on this board:  LFE5UM5G-45F, but a lot can be done with it!)
There are promotional prices on those boards on a regular basis. I bought the VERSA board for the ECP3 a few years ago for $99. The VERSA ECP5 is about $250 and occasionally can be had for $99 too.
Post by: BrianHG on October 24, 2019, 08:17:11 pm
I'm sorry, yes, you are correct for getting the 3 gigabit to work, so, 1080p is out.  But for 480p, the standard DQs are fast enough, especially if you user DDR IOs, and the earlier posted verilog DVI/HDMI out serialiser is manually written which does not require the use of Lattice's embedded serdes function.  All it requires is 4 parallel balanced DQ ports which can serial shift at 216Mhz (108Mhz DDR) from a single bank clock.  The chip I listed can handle that with ease.
Post by: SiliconWizard on October 24, 2019, 08:50:13 pm
Oh, yeah. I guess maybe even lower-end Lattice FPGAs could do this.
Post by: asmi on October 24, 2019, 09:08:08 pm
AFAIK HDMI requires a pixel clock to be at least 25 MHz, which corresponds to 250 Mbps per data lane (1:10 serialization). So 216 Mbps is not going to be enough.
Post by: BrianHG on October 24, 2019, 09:21:12 pm
Ok, 270Mhz then, still well within the Lattice part I mentioned which can do 500Mhz serial data on the DDR pins.
Generic DDRX1 Outputs With Clock and Data Aligned at Pin (GDDRX1_TX.SCLK.Aligned) Using PCLK Clock Input - Figure 3.9: All Devices — -8 500 — -7 500 — -6 500 Mb/s...
Post by: Berni on October 25, 2019, 05:58:09 am
Yeah Lattice are the most cost effective FPGAs that you can still easily buy and get proper software for. The  nice bank per buck ECP5 family is fast enough to do it.
The HDMI spec calls for a pixel clock of at least 25 Mpixels/s. For 24bit RGB this means each of the 3 diff pairs carries 8 bits per pixel but the encoding increases that to 10bit so the minimum bitrate of a HDMI link is 25M*100 = 250 Mbit
In general a lot of FPGAs will have some form of "baby serdes" on some or most pins. These are sometimes just a DDR buffer but more often are 1:4 serdes. This brings the bitrate down to only being 1/8 per signal in the FPGA fabric as that requires the signals to be generally under about 200MHz. The ECP5 family does include this functionality on the left and right banks and according to the datasheet will run at between 624Mbit and 800Mbit (depends on speed grade). So this means its 2 or 3 times faster than the minimum HDMI spec.
Even if you don't use the right bank to get this functionality you still get DDR buffers on all banks in the ECP5 and those get 500Mbit (regardless of speed grade) but as a downside you only get 1:2 reduction in signal speed so you have to deal with two 250MHz SDR streams in the FPGA fabric and that does take some careful design to run fast enough. Its possible that maybe the code generator in the Lattice Diamond IDE can add a larger ratio sredes in the logic fabric, but i think the code generator always wants the nice pin with hardware 1:4 and 1:7 reduction.
I think the Lattice Crosslink family has some even faster buffers in the IO pins.
So for low resolutions not a problem. Its things like 1080p that would be a problem since the lowest you can get away with is 130MHz pixel clock and this means 1.3Gbit per lane. Im pretty sure no FPGA out there can do that with regular IO functionality so proper dedicated serdes is a must for that and yeah the prices of those FPGAs tend to be ridiculous.
Post by: asmi on October 25, 2019, 06:31:57 am
Xilinx 7 series at speed grade of 2 and above can officially do 1250 Mbps, and unofficially does 1080p@60 (1480 Mbps or something like that). "High performance" banks can go to 1600 Mbps, but it only supports Vccio of 1.8V and below.
I think Xilinx did a right thing to integrate up to 1:8 SERDES (can be increased up to 1:14 by cascading) into each and every IO pin tile, as users can pick pins which are more convenient from layout point of view, instead of reading through manual to figure out which ones are they supposed to use.
Post by: Berni on October 25, 2019, 06:51:39 am
Oh that's certainly a nice development from Xilinix. I haven't seen such high IO speeds from reasonably priced FPGAs before.
Anyway my point was that most modern FPGAs out there have enough IO performance to easily meet the minimum HDMI speed.
Post by: Canis Dirus Leidy on October 25, 2019, 08:54:32 am
By the way. ZX Evolution (http://nedopc.com/zxevo/zxevo_eng.php): FPGA (ACEX 1K) assisted ZX Spectrum compatible computer with enhanced graphic modes and VGA-compatible (due to internal scandoubler) video output. Copying it exactly makes no sense (unless Mr. Wells lends his time machine), but a glimpse into the Verilog code (http://svn.zxevo.ru/listing.php?repname=pentevo) may be useful.
Post by: nockieboy on October 25, 2019, 10:06:58 am
Right, so... just to clear up any confusion (on my part!  :o) and to reach a general consensus amongst the professionals (you guys!  ;D), can we agree on an FPGA I should choose, bearing in mind my wish-list (listed below for clarity, in order of priority)?
MUST:
NICE TO HAVE:
The MAX 10 (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf) is looking like a good option, but with all this talk of Lattice and knowing there are even more manufacturers out there, I'd like to get a good indication of which one you think will fit the bill for me?  :-+
Post by: Berni on October 25, 2019, 11:15:11 am
Yeah Lattice is the 3rd biggest player in the FPGA market. They specialize in being lower cost than the big leading two. Tho the tools on Lattice are not quite as good while still flowing the same free basic version and expensive as hell full version scheme.
Since the cost of the chip is not that high of a priority for you you better stick to Intel or Xilinx as they have better tools. Personally i enjoy Intel/Altera tools the most and i really like the Qsys/SOPC builder tool that wires up your digital computing systems auto-magically.
Previous Altera MAX series tended to be 5V tolerant but the MAX10 not anymore. Then again if your chips are TTL it will all work on 3.3V signals just fine as long as there are resistors to limit current, or you can just use a single 8bit logic buffer to do it proper since the data bus is only 8 bits wide anyway. You still get the around 600 to 700Mbit serial IO performance so HDMI should be just fine, but having 90KB of internal block RAM is going to be quite expensive on it.
For a start just look around at what dev boards you can get from the vendor you like. Be prepared to pay $50 and up for a decent one (But sometimes >$100). The decently sized boards always have some form of SRAM or SDRAM or DDR2 on them. HDMI tends to be rare but if it has VGA its probably good enough for now as you can likely add your own HDMI port later on. (Remember you want to first learn how to use these FPGAs so start simple)
Post by: SiliconWizard on October 25, 2019, 02:54:18 pm
If this is your first such development, I would personally still start with VGA first. And maybe consider HDMI later on, when all the rest works and I've gotten more proficient. VGA is still easier to implement, and easier to debug. Some people seem to make it look as though HDMI is just a picnic, but they fail to tell you that they probably spent hours getting it right back when they started. And now of course it all looks very easy. Just saying, do as you wish and don't mind me. Now if the HDMI spec is mainly to select an appropriate FPGA that you know will allow you to do HDMI later on, that's a valid point.
Post by: nockieboy on October 25, 2019, 04:38:07 pm
Absolutely it is.  I don't want to mess around too much swapping FPGAs as I develop - I'd rather get the 'end game' FPGA, and learn from the ground-up on that.  I'm assuming, of course, that there's no real reason I can't develop a VGA output on a dev board with HDMI fitted?  Or offer VGA AND HDMI as outputs on the final version, for example?
Purely out of interest, is there anything on the expensive-as-hell full version software that a beginner like me would want?
The cost is still a priority, just not quite as high as the factors before it in the list.  ;)
The only thing holding me back from the MAX 10 series is the cost of the evaluation board, but I can stretch to it if needs be - I just want to make sure no-one's going to pipe up after I've ordered one with a comment along the lines of, "Haven't you checked out the Costmin LogicBlaster IV?  It does everything you want, packs 200KB of RAM, makes the tea and takes your dog for a walk and the dev board includes HDMI and VGA and only costs £50..."  Because that would make me cry...  ;D
Oh, I also meant to say that I have no preference for VHDL over Verilog at all - it's just that the only exposure I've had to FPGA code is via Grant Searle's Multicomp code, which is in VHDL, hence I've spoken about VHDL in this discussion but don't mean to exclude Verilog.  I'm right at the start with this project, so I am ultimately extremely flexible in which path I take.
System Interface Considerations:
ALL the chips in my computer that would connect to the FPGA are either 74HCT buffers for data / address / most command signals, or the CMOS Zilog Z80 itself for a couple of control signals (and these will be going TO the Z80 FROM the FPGA and are active-low with 5v pull-ups on them).
The only area for potential variation is in the address bus (from the MMU), which may have HCT, HC or LS logic driving the extended address lines.
The 10M50 (https://www.intel.co.uk/content/dam/www/programmable/us/en/pdfs/literature/pt/max-10-product-table.pdf) is the most attractive proposition, I think, with 200 KB of RAM in it.
Well, the 10M50 is available on a dev board with HDMI on it.  That would provide me with a good hardware example to work from and all I'd need to worry about would be getting the FPGA set up properly to display something on it.  I could always wire up a VGA socket as well and go that path first.  It's darn expensive (https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-max-10m50-evaluation.html) though.  :palm:
Post by: Canis Dirus Leidy on October 25, 2019, 05:34:34 pm
Come to the Cyclone 10 side, we have cookies (https://www.aliexpress.com/item/33050240958.html)!  >:D (and QFP package (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pt/cyclone-10-lp-product-table.pdf))
P.S. But HDMI have another problem: high-speed signals PCB routing.
Post by: Berni on October 25, 2019, 05:48:13 pm
The premium features tend to be the same with all the vendors. Things like faster compilation trough the use of more cores and partial recompilation (This is more useful than it sounds because even simple designs can sometimes compile for minutes even on a fast PC) and it usually also unlocks a large set of IP blocks for full use. The free version also usually will not compile for the ridiculously large FPGAs that cost 1000s of dollars per chip.
The set of IP blocks mentioned before tend to  be available in the free version in there crippled form with a "death timer". This is a counter buried deep inside the encrypted IP block that is set to run out in abut 2 hours of running at typical clock speeds. Once it runs out it kills the IP block and renders it unusable. This is nice in that it lets you use it, but not so nice that the FPGA has to be rebooted to get it to work again after the timer runs out. Unluckily the DDR2 controller tends to be once of these crippled premium IPs.
That dev board you linked is actually a pretty good deal. The MAX10 chip on that board is very expensive, i couldn't find the price for the exact part but the slower speed grade version of that chip costs 135 USD if you ware to buy a single one off DigiKey as a mere mortal, so the exact one should be even more expensive. Its actually cheaper to buy the board and desolder the chip rather than buying the chip new(go ahead and try to buy this chip). Tho if you are a commercial costumer and have good relations with Intel they will give you way way cheaper deals directly, especially if you ask for 1000 of them (They likely won't even respond if you ask anything under 100). This is why i brought up that chips with this much memory are expensive, but is also a very powerful chip. For integer math speed it could rival the performance of modern CPUs in PCs (This is why FPGAs got used for cryptocurency mining before GPU compute and ASICs came around). And yet this is actually still a low "low cost FPGA" compared to the other chips they make.
Verilog or VDHL it does not matter. Both are supported by all vendors. I personally prefer Verilog because its simpler and involves less fancy syntax typing. Not that one or the other is better, just my taste went with Verilog after trying one and the other. You can mix VHDL and Verilog in the same project and compile it together anyway.
As for having ready to go hardware, yes that is very useful with FPGAs as they often have a lot of support circuitry (Gazilion power rails, boot memory, config pins) and you always get a JTAG programmer on dev board included. Often this JTAG programmer can be rewired to connect to an external FPGA to turn the dev board into a universal programmer for that vendors chips.
Its your decision what you want to spend the money on but that MAX10 dev board is a pretty good deal for what you get. You can always add a VGA port onto the IO headers to start off there and PWM audio output via a single pin. Believe me you will want to take things slowly because getting into FPGAs is quite a learning curve(Id say significantly more so than with MCUs) but lucky for you that VGA video generation is one of the very nice beginner projects. This is mainly because you can slowly build on it in steps and each incremental step is simple enough to debug purely using a logic analyzer and no simulation.
Post by: Canis Dirus Leidy on October 25, 2019, 06:04:48 pm
Ahem. Due to these
Package type - NOT BGA where possible due to hand-soldering requirement
you can forget about this IP restriction.
Post by: BrianHG on October 25, 2019, 09:46:43 pm
The internal ram bits on that Cyclone10 are too few for the OP to completely contain his project.  If the OP wanted a SDRam version, then that dev board would be fine, but when developing the opensource graphics board, he would need a FPGA with enough IOs for the SDRam and other stuff which may not be possible when porting his project to the 144pin TQFP version of the Max10.  With such a setup, the op will need to engineer a multiport SDRam controller which cache banks for display refresh.
Post by: BrianHG on October 25, 2019, 10:04:54 pm
Your right, I have too many years of experience in FPGA video and make it seem too easy.
I also picked the MAX10 144pin with all ram inside since the OP's development of a display controller can operate 100% internally without worries about Dram interface errors and logic.
The design is simple enough that the user can make 5 of his own 2$ dev boards PCBs from JLPCB, but yet again, I'm talking from experience I have with Intel chips.
One thing about FPGA analog VGA video out, remember, use a 5V TTL level shifter/line driver when sending the HS and VS!!!  Some monitors work fine feeding 3.3v TTL on these 2 signals, some just wont even turn on, and some monitors sit on the edge turning on, then off, or the syncs go haywire.  The OP wont know what hit him if he makes the mistake of using 3.3v for HS and VS outputs then many third party users start experiencing problems...  |O   A 5v powered 74HCT04 with 3 outputs paralleled for extra drive current for each sync signal should work fine.  At the inputs of the '04, I usually add a single 470ohm pullup to 3.3v since Altera's high drive on their IO pins have an unusual current pull curve as they reach the VCCIO and this just cleans that up a little when driving 3 cmos inputs in parallel on a 5v CMOS part.
Post by: BrianHG on October 25, 2019, 10:18:53 pm
For the HDMI interface, the Max10 dev board used this IC when interfacing with the HDMI for ESD protection and to deal with the 5V DDC signals:
https://www.digikey.com/product-detail/en/texas-instruments/TPD12S016PWR/296-29690-1-ND/2762248 (https://www.digikey.com/product-detail/en/texas-instruments/TPD12S016PWR/296-29690-1-ND/2762248)
It does the ESD protection and level shifts/converts the 5v DDC I2C signals from the HDMI to the FPGA's 3.3v.
It is used in the Max 10 DEV board mentioned above.
Post by: mariush on October 25, 2019, 11:03:34 pm
I don't know why you guys keep stressing about 1080p
I'd suggest setting the maximum to 1280x720 or 1366x768 (HD Ready resolution on cheap TVs)
720p is a standard resolution that should be accepted by everything, and you'd have both 16:9 or 4:3 resolutions, and you can double pixels to do 640x360, or 4 pixels blocks to get 320x180 ... scaling by 1.5x gets 960x720 to stretch 640x480...
Could you maybe use something like SiI8784 https://www.semiconductorstore.com/pages/asp/DownloadDirect.asp?sid=1572019820392 (https://www.semiconductorstore.com/pages/asp/DownloadDirect.asp?sid=1572019820392) - to convert an analogue signal to HDMI ?
You could use a fast microcontroller and 3 r2r dacs to produce the rgb/ypbpr signal/ and output to the sil chip which then converts to hdmi.
or SiI9136 ... takes up to 36 bit per pixel digital signal and output hdmi : datasheet (https://www.latticesemi.com/view_document?document_id=51622)
edit : this last 9136 chip is used in some cheap 20$ devices (https://www.amazon.com/Color3-Advanced-Processing-Device-010000-002/dp/B00BUUV4X6) and someone made a blog about it : https://hackaday.io/project/122480-eecolor-color3 (https://hackaday.io/project/122480-eecolor-color3)
and this board uses the 9136 and the download on the page has lots of cool documentation and code for 9136 : https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&No=1067&PartNo=4 (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&No=1067&PartNo=4)
Post by: asmi on October 26, 2019, 03:12:30 am
I prefer TPD12S521 (http://www.ti.com/product/TPD12S521) chip - it does the same thing, but it support "flow-through" routing to avoid having any stubs thus improving signal integrity (see attachment).
Post by: BrianHG on October 26, 2019, 03:37:14 am
The TPD12S521 (http://www.ti.com/product/TPD12S521) chip does not level voltage translate the I2C DDC lines, at least, it is not mentioned anywhere at all in it's data sheets.
The TPD12S016PWR specifically describes the logic shifter gates with their internal wiring and specs.  The data sheet of the TPD12S521only shows a mosfet inside it, though there is one sentence which says:
"To begin the design process the designer needs to know the 5V_SUPPLY voltage range and the logic level, LV_SUPPLY, voltage range."
But, nothing else...  Typical TexasInstruments crummy modern data sheets...
BTW, the TPD12S016PWR specifically says:
"Auto-direction Sensing I2C Level Shifter with One-shot Circuit to Drive a Long HDMI Cable (750-pF Load)"
With a specific image of this internal logic at the bottom of page 14 in the data sheet.
To be safe, without any mention from TI, I would feel better with my FPGA using the TPD12S016PWR unless I get a letter from TI guaranteeing the same function in the TPD12S521.
Post by: jhpadjustable on October 26, 2019, 03:50:38 am
Description, second paragraph, first sentence. "The low-speed control lines offer voltage-level shifting to eliminate the need for an external voltage level-shifter IC."
Yes, that's a bidirectional level shifter. See NXP app note AN10441 (https://www.nxp.com/docs/en/application-note/AN10441.pdf) for a detailed explanation.
Post by: BrianHG on October 26, 2019, 04:03:58 am
Your correct, sorry....
It's odd that on page 7 they only show an upward facing FET like symbol.
Post by: asmi on October 26, 2019, 04:19:35 am
I actually use it on my FPGA board:
https://i.imgur.com/RVsPWrI.jpg
I can assure you that it really works just fine :-+ Moreover, it also provides a current limiter for HDMI port's power line, also the destination voltage (on the FPGA side) for DDC/HPD/CEC lines doesn't have to be 3.3 V - it can be any voltage from 1 to 3.3 V.
Post by: jhpadjustable on October 26, 2019, 05:14:09 am
But that really is all there is to it. Select an NMOS with (Vgs(on) < Vcclow - margin) and (Vds(max) > Vcchigh). Connect the gate to Vcclow, the source to the low-voltage signal, and the drain to the high-voltage signal. Add pull-ups to the respective Vcc on each signal input. You have just completed a bidirectional digital level shifter, perfectly sufficient for several hundreds of kilohertz. Feel free to work out what happens when neither side is pulling low, when the drain side is pulled low, and when the source side is pulled low. It's genius.
Post by: nockieboy on October 26, 2019, 05:05:15 pm
https://i.imgur.com/RVsPWrI.jpg (https://i.imgur.com/RVsPWrI.jpg)
Very impressive, asmi  :-+ - how did you make that board?  I presume it was done in a reflow oven?  Is it 4-layer?  Done in KiCAD or something professional?
As for the TPD12S521, will I need this with a TFP410 (http://www.ti.com/lit/ds/slds145c/slds145c.pdf)?
Post by: BrianHG on October 26, 2019, 08:42:13 pm
??? Your link is for the wrong datasheet.  Get the right one from TIs website and see what it says...
Post by: BrianHG on October 26, 2019, 08:55:55 pm
 Use this NXP ic if you want HDMI with digital audio support:
https://www.digikey.com/product-detail/en/nxp-usa-inc/TDA19988BHN-C1551/568-12058-ND/2780351 (https://www.digikey.com/product-detail/en/nxp-usa-inc/TDA19988BHN-C1551/568-12058-ND/2780351)
Post by: nockieboy on October 26, 2019, 09:27:20 pm
Darn it, pasted the wrong link, sorry.  |O
Post by: jhpadjustable on October 26, 2019, 10:32:24 pm
Note, external HDMI transmitters are almost useless to the hobbyist due to NDA and licensing restrictions, unless you are fortunate enough to find a leak with enough information (https://github.com/torvalds/linux/blob/master/drivers/gpu/drm/i2c/tda998x_drv.c) to get started.
Post by: BrianHG on October 26, 2019, 11:40:51 pm
The chip I listed which is freely available without NDA as well as the data sheet doesn't have HDCP, the true roadblock for hobbyists.  HDMI transmitters with and without audio is allowed.  The hobbyist just isn't allowed to use HDMI's logo or claim authenticated HDMI output in their documentation.
I've never had problems with getting such ICs unless HDCP was built in, however, I've been using Analog Devices HDMI transmitters.  NXP may require a license.
Post by: asmi on October 27, 2019, 12:50:39 am
This specific one is a six layer board, manufactured by WellPCB for $145 for 10 boards. There is 512 Mbytes of DDR3L memory onboard. I've designed it in Orcad Professional, but it should be possible to do it in KiCAD. I'm actually working on a board for Spartan-7 FPGA and DDR2 memory in KiCAD - the goal is to do it in 4 layers, as this project is meant for beginners - I'm going to publish all sources once I actually make the board and verify that it works. I will also place HDMI out connector on this board because Spartan-7 can also drive HDMI out directly.
I didn't need it because Artix FPGA that I have on this board is capable of driving HDMI interface directly.
Post by: legacy on October 27, 2019, 02:52:05 pm
DDR3L
DDR3, the most complex stuff to be designed and handled, especially for beginners.
Post by: asmi on October 27, 2019, 05:51:48 pm
That's what I thought too in the past. But once I actually tried that, it turned out be much easier than I ever expected it to be.
Post by: BrianHG on October 27, 2019, 06:16:43 pm
Ignoring some of the advanced features and if you don't care about shaving every last half clock latency cycle and running them at full tilt speed possible, your controller just about the same as a DDR2 controller.
Post by: jhpadjustable on October 27, 2019, 06:33:06 pm
DDR3L? Isn't that the stuff that explodes if you turn it off wrong?
Post by: asmi on October 27, 2019, 06:49:44 pm
I meant from the HW design standpoint. At least for me DDR3 layout seemed much harder than it actually turned out to be. At least for lower speeds (400 MHz is rather low for DDR3), which is what Spartan-7 and Artix-7 support. Going higher requires using Kintex-7, which is significantly more expensive.
For controller I just use MIG (Memory Interface Generator) - it's free and easy to work with.
Post by: asmi on October 27, 2019, 06:51:42 pm
Well it didn't explode on me...yet ;D
Post by: BrianHG on October 27, 2019, 11:51:32 pm
Ok, we at at a point where the OP, 'nockieboy' has enough info to make a decision:
A: project must not have BGA, or it can have BGA.
If it cant have BGA, the OP must select to either go with a low cost older FPGA with DRAM, or an all in 1 IC solution like the MAX10 144pin QFP.
When using the older FPGA and DRAM, the op must contend with a more complex PCB, multiple power supply voltages, ram chips and bootprom.
B: Price sensitivity.  If 1 BGA IC is allowed, the Lattice 16$ for 1 chip IC with almost 2 megabit internally pretty much kills everything else in logic density and memory.  Lattice being the third largest FPGA vendor still has relatively decent toolset.  However, you would still need a bootprom and a second regulator for the VCC core voltage.
C: design complexitity.
The TFP410 DVI Transmitter solves the headache of creating and testing his own DVI output serializer core (I realize that home made verilog examples of such a core already exist, but this can be extra work).
Now, with the video modes mentioned, anything he chooses will work, it the development effort and needed and if there will be room for special treats.
If I want a tiny PCB, 1 main IC and HDMI plug, the MAX10 eliminates a lot of complexity and may be possible to be done on a 5$ for 10x 2 layer PCB***. (You really need to know what you are doing and basically the bottom layer is basically a flood-fill GND with a few short trace jumps)
I would make this board a stand alone with a connector for the 8bit MCU board.  I would also offer to make the IC's onboard ram useable as the 8bit cpu's system memory.
If the op went with the larger 2mbit Lattice part, he has the density and speed to offer something like 12 new 256 color sprites, any width up to the width of the screen, with a translucent colors, on every new line of video, from anywhere within the block of system memory, in real time without any overhead.  With the max 10, he could get away with something like 8 sprites at the 180/or/160x240 mode.
For such a project, I would personally recommend using the standard SMPTE 480p base mode of 720x480, 16:9, 27Mhz reference clock as it will work on any PC monitor as well as any TV sold today.  If the op wants 640x480, just center crop the image. (make a black bar an the left and right of the image.)  Also, this standard mode makes integrating the standard HDMI embedded 48Khz stereo audio easy as the exact standard specs are well defined.  Using the 25Mhz VGA 640x480 will add an obstacle upgrade path for embedded audio in the future.
This project is nothing more than a large number of start and stop sequence counters, driving another set of counters look-up memory, use the contents to look up more memory to point to alternate contents of same chunk of memory, and shift the right final content to a palette memory then to feed the DVI transmitter, or feed the internal DVI serializer.
This is why I said in an earlier post, run the internal display memory at 16x the speed of the output pixel feed, you you can read and use each read address to point to another place in ram, 15 times before creating your final resulting pixel.  You may want to make your video memory 16 bits wide so you can access 16 bit words each time allowing a 16bit palette to be stored withing system memory instead of special dedicated registers or memory block.
Post by: jhpadjustable on October 28, 2019, 08:03:58 am
A x16 pseudo-static RAM is not especially layout-sensitive, any more than an SRAM, and is fine running at 3.3V at several tens of megahertz.
Sort of true. A 25 series SPI flash and a dozen pins of header should be plenty, and makes it easy to plug in a USBasp or similar SPI master.
But the TFP410 doesn't. Where does the audio go in?
16-bit palette
There's a point at which one can and should say "screw palettes, we have enough color bits." 4k colors is about that point. More important, it's about as much data as you'd want to push around with a Z80 and a blitter.
There's also a point at which a designer learns that there are a crapload of tradeoffs to be made, and (hopefully) to avoid the second-system effect.  ;)
Post by: nockieboy on October 28, 2019, 05:46:55 pm
I'm still waiting on my Spartan 6 dev board, but realise it has SDRAM, not DRAM, on board.  I'd like to be able to test out some DRAM to see how difficult it would be to use it as video RAM in place of internal RAM blocks in the FPGA... If it is viable (both from a complexity AND performance standpoint) then it would be preferable to getting an expensive FPGA with loads of internal RAM.
The MAX10 is tempting, but it's very expensive.  :-\
I have no issue with adding RAM chips and bootprom, even multiple supply voltages so long as it doesn't get TOO complicated (which is highly subjective, I know).  It looks like I'm going to have to switch to KiCAD to design the board no matter what FPGA package / GPU design I go for, as DipTrace's 500 pin/2-layer limit won't cut it with this project.  :o
BGA is definitely out, though, unless/until I build a suitable reflow oven and get the process stable enough to risk running BGA chips through it.
Sorry, not sure I read that right - Lattice do a $16 FPGA with 2 megabit internal RAM?!?!? :wtf:  That changes the game entirely - if that's correct, I'll get started on a reflow oven straight away and would offer the PCB with the FPGA already soldered if I ever put it into production! :o
Have you mentioned this part already in the conversation?  If so, forgive me as I must have missed the specs (and thus the implications) for it.
Yeah, okay, so I'm seeing that I should really get a grip of this fear of BGA soldering and tackle it head on.
Sounds reasonable to me.  Naive/stupid question - would getting a 27MHz clock from a 25MHz clock source be non-trivial?  All the dev boards I've seen have a 25MHz clock source.
You make it sound so easy...  :o
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: nockieboy on October 28, 2019, 07:24:43 pm
Yes of course, this is still a consideration - there must be alternatives that will integrate an audio source into the data stream, though?
16-bit palette
Yes, I was starting to wonder if it wouldn't just be easier to shunt around 2-bytes-per-pixel if I have the memory space for a 4-bit colour space unrestricted by a palette size.  Of course, using internal RAM in the FPGA will still limit my memory size, and doubling the size of the required video RAM will likely either restrict my maximum resolution for 4-bit colour or restrict me to a colour LUT for the screen resolutions that don't have the memory space for 4-bit colour.  Just not sure about the practicalities of using both methods in an FPGA?
I'm hoping to avoid the second-system effect - although, as I'll be learning as I go, there's bound to be improvements and embellishments I can make by going back over old code - but I do, however, have a pretty clear end goal in mind.  :phew:
Post by: BrianHG on October 28, 2019, 09:41:20 pm
$15.86 for 1, $13.94 each for 25, $13.36 each for 100.
A few pages ago: https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2752240/#msg2752240 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2752240/#msg2752240)
With only 1 small BGA chip (14mm X 14mm), and you using the outer pads only, you can make this work on a 4 layer board and with tinned pads, and because the IC is so small, you can get away with only a good quality hot air gun and a syringe of flux, no oven needed.  Watch a few of Louis Rossman repairs of mac-books where he re-solders small BGA chips.  As long as you have a PCB with solder mask, you can do it easily this way.  (Now, I don't mean populate your PCB with small BGA ICs all over the place.  Dealing with 1 small IC on each PCB will be easy enough with a healthy tube of flux and a hot air gun will be manageable unless you are building 100s of them.  Then use a solder paste stencil and toaster oven...)
As for easy, you really need to plan thing out ahead and choose an HDL and stick with it.  I personally use System Verilog and keep my modules simple stupid enough that they would still work under any compiler, even those which are regular Verilog.
As for the crux of your system, I'll make a reply tonight and you'll laugh as 33% of your problems vanish with around 2 paragraphs of words...
Post by: jhpadjustable on October 28, 2019, 10:50:19 pm
Rational clock synthesis isn't that bad. Most PLLs on FPGAs can do it just by configuring and instantiating a module. Here's an example from FPGA4FUN's HDMI (really DVI-D) project, which declares an instance of the Xilinx digital clock manager (https://www.xilinx.com/support/documentation/ip_documentation/dcm_module.pdf) and configures it to multiply the pixel clock by 10, then declares a clock buffer to force the result onto the chip's low-skew clock distribution networks. You could add a .CLKFX_DIVIDE parameter likewise, replacing the default of 1 to achieve a non-integer overall ratio.
DCM_SP #(.CLKFX_MULTIPLY(10)) DCM_TMDS_inst(.CLKIN(pixclk), .CLKFX(DCM_TMDS_CLKFX), .RST(1'b0));
BUFG BUFG_TMDSp(.I(DCM_TMDS_CLKFX), .O(clk_TMDS));  // 250 MHz
Some of the lower end FPGAs that don't have onboard clock synthesizers can make use of an offboard clock synthesizer, such as the Si5351, but those can be harder to configure and you must account for delays to and from the synthesizer manually. In either case, clock domain crossing can be a bit tricky if you need other buses to get things done promptly on command. FIFOs, even in their degenerate case of double-buffering with an S-R latch, are an easy and sometimes cheap, but limited and not necessarily prompt way to get clock domain crossing done.
There's a bit of confusion in the thread on DVI-D vs. HDMI. DVI-D is a digital video standard, and basically open and well-documented. HDMI is a superset of DVI-D that includes in-band packets to set color spaces, send audio data, communicate remote control data, defend Hollywood against their customers, etc. and basically proprietary and NDA-infested. HDMI and DVI-D are basically identical at the electrical level. DVI-D transmitters won't generate the packets you need for audio, and HDMI transmitter public data sheets are intentionally incomplete. To my mind, that means you would need to build (or borrow) a transmitter on board the FPGA so that you can generate those packets, glean data about the register configuration for an HDMI transmitter chip from public leaks such as Linux kernel drivers, OR give up on HDMI audio and settle for an analog or S/PDIF output.
It's just an if-then statement that turns into a mux. When you're more conversant with HDL, you'll see. :)
On that note I would strongly caution that you not make any more design or feature decisions until you have hands-on experience with the medium in which you are working. Even then I would wait until I have first picture coming out of the board to decide how to get from spec to implementation. There are subtleties that you might not be considering, such as that block RAMs are still just dozens of individual separate blocks spread over the chip and you (or the synthesis tool) have to use logic and routing to aggregate them, which can get very expensive (in the sense of latency and  logic resources consumed) for a large array.
fpga4fun.com has much fine introductory reading on FPGAs and some gratifying beginner projects. As a reward you can work all the way through the interfacing material to their HDMI example (really just DVI-D, but enough that you would probably understand where to inject logic for audio and so on once you have the spec) and SDRAM. You could even get a head start as most FPGA software has a (limited) simulator suite available, which you can use to display the output waveforms of your design without a board in hand. You'll also want to know how to build virtual test benches for your design to provide stimuli to your design in simulation, say, fake CPU bus cycles or outside clock sources.
Post by: hamster_nz on October 28, 2019, 11:23:45 pm
This problem can be pretty trivial with a bit of planning.
If you have a 25MHz source, you multiply it by 54 to get a VCO frequency of 1350Mhz, which is in the allowable range of 800MHz to 1600Mhz.
- Divide the VCO by 50 to get 27MHz for your pixel clock
- Divide the VCO by 10 to get your clock to drive the serializers the for DVI-D outputs (using DDR mode).
Oh, it seems that the HDMI spec owners are sending out takedown notices: https://glenwing.github.io/docs/HDMI-1.4b.pdf
Might pay to look for "hdmi specification 1.4 filetype:pdf" in everybody's favorite web search engine while you can, just for future reference.
Post by: BrianHG on October 29, 2019, 02:45:06 am
If the OP is making his own board, or is expecting to, he can always change the crystal oscillator from 25Mhz to 27Mhz.
This may allow for slower core PLLs on different FPGA, however, if he uses the PLL setup wizard, he would just type in the wizard the source clock frequency and the desired output clocks & the wizard would handle this all on it's own.
Post by: hamster_nz on October 29, 2019, 03:58:51 am
I must be old school. I find the wizards are:
- slow to use - a simple change takes a long time
- somewhat inconsistent on their output esp between tool versions.
- very sensitive to inputs (esp when your desired frequencies are a nice decimal number)
- The generated code need tweaking if you use the generated clocks to do something special (e.g. drive SERDES) as you have to add or remove clock buffers, and when you do this you can't use the wizard to regenerate the code
- unless you know what output constraints you have within the clocking resources of the FPGA you just end up trying things and seeing if you get lucky. It isn't a recipe for a well-engineered design
- for me, they often seem to have different ideas of what a "close enough" solution is. Usually a better "close enough" solution exists
But my biggest grip is that they fill your code base with code that is "(c) Vendor X" with an explicit license, that isn't compatible with open projects:
Do a quick search for for
    site:github.com "Copyright(C)" "by Xilinx, Inc"
Here's an example:
-- System Generator version 11.1 VHDL source file.
 -- Copyright(C) 2009 by Xilinx, Inc.  All rights reserved.  This
 -- text/file contains proprietary, confidential information of Xilinx,
 -- Inc., is distributed under license from Xilinx, Inc., and may be used,
 -- copied and/or disclosed only pursuant to the terms of a valid license
 -- agreement with Xilinx, Inc.  Xilinx hereby grants you a license to use
 -- this text/file solely for design, simulation, implementation and
 -- creation of design files limited to Xilinx devices or technologies.
 -- Use with non-Xilinx devices or technologies is expressly prohibited
 -- and immediately terminates your license unless covered by a separate
 -- agreement.
Post by: asmi on October 29, 2019, 04:20:17 am
You don't need to actually generate any code with the wizard. I use clocking wizard to calculate all coefficients, and then just place them into my own MCMM/PLL instantiation code. I just couldn't be bothered to calculate this stuff myself ::)
Post by: asmi on October 29, 2019, 04:21:35 am
Or just add a second (third, fourth, you get the point) oscillator on a board. This is an advantage of making your own board - you can place whatever stuff you need (or you think you need :) ).
Post by: hamster_nz on October 29, 2019, 04:22:47 am
This is most likely the optimal way to use the clocking wizard.  ;)
Post by: hamster_nz on October 29, 2019, 04:26:31 am
Just make sure it is connected to a clock-capable pin.   |O
Planning for high speed transceiver reference clocks is the biggest pain. It pays to build a shell of a design just to prove that your desired clocking structure and channel bonding will work.
Post by: asmi on October 29, 2019, 05:02:01 am
This is the mistake I made on my very first FPGA board :-DD And never again after that 8)
If you mean MGTs, it's actually quite easy as there are only so many ways to do it. Things get a bit "interesting" with Kintex because their transceivers are arranged in a column, as opposed to top and bottom sides of a die which have dedicated routes between each other. On Kintex you can only route clock one quad above or below the one which have clock source connected to. This is why it's impossible to implement PCIE x16 on Kintex devices - only 12 MGTs can be reached by a single clock. At least it's possible to implement a PCIE 3.0 x8 interface (with a bit of a soft logic as hardIP only supports PCIE 2.x speed).
Post by: nockieboy on October 29, 2019, 09:46:57 am
Wow, okay, sounds like I need to do some research into this then! Thanks BrianHG!  :-+
Sounds great!  :popcorn:
Haha! Fair enough, so it's not HDMI I'm going for but DVI-D. Looks like I'll have to handle sound through an analogue or S/PDIF output then.
I'm keen to get started on the practical aspects of the project, but at the moment work and home life are preventing me from having any major blocks of time where I can make a start, so in the meantime I like to glean as many pearls of wisdom from you guys here as possible.  I've got an Altera Cyclone II EP2C5T144 board, I guess I can make a start on that?  The code should transfer to a Spartan 6, or MAX 10 or Lattice chip without major issues at this stage as the code will be VERY basic, and future FPGAs that I transfer the code to will have more resources rather than less.
Marvellous, thanks hamster_nz.  This is only an issue whilst I'm developing the design on an eval/dev board as the clock source is fixed (to 25MHz usually).  When I make my own custom board, I'll use a 27MHz clock source.
Well spotted - thanks for that.  I've got a copy of the specs now.  :-+
Of course - and that's my plan, but before I get to the stage of making my own board, I'll be using an eval/dev board which has the 25MHz clock source. Probably. :)
EDIT:
Thinking back to BrianHG's comments about using the outer pins of the Lattice chip, I thought it might be a good idea to work out how many IO pins I'm going to need..
System side:
Video side:
GPU utility:
That's an bare minimum of 80 I/O pins, not including external GPU memory connections and clock sources for the FPGA.  Is that about right?
Post by: jhpadjustable on October 29, 2019, 11:59:31 pm
For now. If you transmit TMDS directly from the FPGA rather than use an external TMDS transmitter, you leave your audio options open.
Ah, but what have you done with the Cyclone 2 board so far? You don't need a very great block of time to get a blinky up. :) You don't need more than a few not-very-great blocks of time to get the system bus-side interface up, maybe map a block RAM or two onto the bus. These are things you can work on without any external RAM or video connections.
System side: looks alright. If you monitor the Z80's multiplexed bus directly, maybe you could narrow the address bus requirement by 8 pins or more. You could also replace a few address lines if you let the memory board do your decoding and run a lead from the unused socket's !CS to the GPU, or mirror the same decoding function on the GPU board. It might go against the spirit of maximum integration, but when you're pin-limited a touch of off-chip logic is sometimes the best approach.
It would be much better if we knew exactly how you were getting a 22-bit address space out of a 16-bit CPU address space. I'm going to wildly guess: you're using an 8-bit writable latch, with its own memory addressing, to choose a 16k block of the 4MB RAM/ROM space to map into a preset 16k of the Z80's address space, with peripherals and/or a BIOS-like ROM fixed-mapped into the rest of the Z80 address space. Would you be better off allocating another 16k or so of the flat Z80 address space to implement an independent bank switching scheme inside the GPU?
Video-audio: 3 is enough for audio output. One clock, one data, one word-select. One pin if you decide to do S/PDIF transmission on the chip.
If using an external transmitter, you also need a pixel clock output. You also might gain from cutting back on the bits per channel. Choose some photos, process them with a posterize filter, and see how few bits you can tolerate. RGB565 is the compromise I'd choose: photos still look very good, fits neatly into 16 bits, not too anachronistic. If you find the slight greening of some greys objectionable, maybe you can drop one of the green bits. The unused LSBs can be tied high or low.
GPU utility: JTAG and boot PROM pins are usually dedicated and not movable. In the final version you will only need one or the other. If using a four-layer board you might be able to escape-route them between power planes on the power layer since they're relatively non-critical. A serial configuration memory is usually a 25 series SPI flash so you only need four signals. Depending on the FPGA chosen, you may need pullups or straps to configuration pins to choose the configuration source. You may be able to treat some or all of the config pins as supply pins, which could keep the layout process (and the layout artist) that much saner.
DRAM: Figure 11 or 12 pins for DRAM addressing, 4, 8, or 16 pins for data, 4-6 for control, and 0-4 for clocking, depending on the particular DRAM technology you use.
Post by: BrianHG on October 30, 2019, 03:48:48 am
Video side:
  • 26x VSYNC/HSYNC/RGB output (much less if the FPGA is going to produce the DVI-D stream itself)
  • 4?x audio output
Only use 12 or 16 IO for RGB, 15 bit color, you will need a ENABLE out if you will be using the TI TFP410 for DVI.  it accepts multiplexed data meaning you can feed 24 bit color on 12 outputs.  To transmit HDMI direct, you need 8 outputs (4 balanced pairs) plus another 5 IOs for the DDC and hot plug detect features.
If you have a 'Cyclone II EP2C5T144', today, you should already have your master sync generator and VGA output generating a frame where you can make a dummy test pattern.
It already has enough internal ram for you to replicate an Atari 400 video generator with all it's graphics capabilities, however, due to simplicity, I would at least make a text mode generator.
Begin by making you raster generator with programmable window margins and a 2 color monochrome text mode.
Here is my first bit of help:
#1 make a sync generator which can make a programmable raster, programmable HS, Programmable VS, + Horizontal enable and vertical enable + the 2 combined for you active video region enable.
#2 I've attached a small character generator I one made.  It uses 20kbit.  Has an Atari 800 font with display ram.  The output is an enable signal for superimposing the image on an existing background plus a 3 bit color image (2 bit for font and 1 bit for higher colors, you may shrink the design to a 1 bit font with a little effort saving you ram bits).  I have not included the external palette.v and video mixer.v as they are 30bit color examples for a larger chip.  Also, I have not included my programable sync generator as I need to re-install quartus to verify I'm giving you the right files.
(I only work in Verilog)
Start with your 640x480, or 720x480 raster generator and look at my osd routine and within quartus, you should be able to generate a symbol file for my osd.....v which you can paste into your block diagram.  Until you wish to write to the text display memory, you can GND those signals.  The included memory initialization files have the OSD Font and a test text dump for the display memory.
Post by: Berni on October 30, 2019, 06:49:58 am
Yes that Cyclone II board is definitely a good place to start if you already have it.
Just bodge wire together a R2R DAC to one of those IO headers and connect it to a SubD 15 connector so that you can plug it into VGA. Believe me you will learn a lot by the time you have a picture on your monitor.
Once you have that you can also bodge wire your Z80 memory bus onto more pins so that you can actually draw on the screen in software, then just build up from there. You will have a much easier time designing the rest of your system once you see what the strong and weak points of FPGAs are.
Post by: nockieboy on October 30, 2019, 11:41:45 am
Funny you should mention that - after mentioning that I'd got a Cyclone 2 board yesterday, I thought I should actually get the thing out of its packaging and try using it!  I got a blinky up and running last night.  Was a worthwhile exercise, too - there were a couple of hurdles to overcome with silly things like installing the right USB drivers for the Blaster and working out fiddly stuff like how to use the pin manager software, but once that was done I progressed from a single blinking light to a 3-bit counter display in a minute or two (the board only has 3 LEDs).
Going to start working through the fpga4fun tutorials over the next couple of days.  :-+
Absolutely.  As part of my mantra of starting small and building up from there, this is where I'll start out - and funnily enough, I was looking at the memory board on my Microcom earlier this morning, daydreaming whilst the PC booted up (as you do), and looking at the empty memory chip socket and the thought occurred that I could run all the connections I'd need for the initial FPGA designs straight from the empty memory socket - that'd cut the system-side IO pins down to 30 at most as I'd only need A0-A18 for the 512KB window.
Almost. :-+ My MMU addresses up to 4 MB of memory by intercepting A14 & A15 from the Z80, replacing them with EA14 & EA15 and a further 6 address lines, EA16-EA21, using two 74HCT670 4x4 register files, which means I can map ANY 16 KB physical memory bank into any of the four 16KB areas in the Z80's logical 64 KB memory space.  The bootstrap ROM has to be in the topmost chip socket (due to pull-ups on the EA address lines as the system's initial power-on state is with the MMU off), so at power-on the topmost 16KB bank of physical memory is copied across the entire 64 KB logical memory space.  That's more than enough for the Z80 to execute some bootstrap code, which maps some RAM banks into the logical memory space for the bootstrap to make use of, then turns the MMU on.
My memory cards have four 'sockets' on them for chips that are selected by EA19 & EA20 (well, three as the first one is an SMD SRAM chip as RAM is sort of compulsory in most computer systems).  The other three are DIP sockets.  Each socket can take up to 512 KB chips, so one memory card gives a potential of 2 MB memory space.  I can add an identical memory card to the system which adds another 4 'sockets' and pull a jumper, which allows EA21 to select the memory card, giving 4 MB memory space.
Don't think so - I can allocate anything up to 512KB to the GPU - unless I add DRAM or SRAM as external memory for the GPU, I can't see me needing all that space to access the GPU's internal video RAM...?
Grant Searle has an entire Z80/6809 computer AND VGA output that fits into one of these devices.  I was toying with the idea of taking his code and stripping everything but the VGA generation parts out and tweaking it to take external input via a serial interface initially, so that I can play with the generation of characters etc. and get a working video output for my Microcom very quickly that I can then build upon, as Grant's code implements VT-100 emulation, it should be quite flexible and may be a good base to learn from?
This is key to having various screen modes and is certainly on my to-do list!  :-+
You have? I can't find it? :-//
Thank you very much for your help.  I'm very much a visual learner and having an example I can see working helps my understanding massively.  I'm not precious over Verilog/VHDL to be honest, will likely go with whichever seems most logical to me.
Thanks again - it's immensely valuable just seeing how these projects fit together at the moment, so anything like this is a great help.  :phew:
There are weak points to FPGAs?  :o ;)
Well, that's the plan.  I'm hoping I can make some progress over the next few days - will post some pics if I can.  ;D
Post by: BrianHG on October 30, 2019, 12:13:18 pm
Just click on the link at the bottom of my post, it says " * Altera_OSD_20kbit.zip (12.86 kB - downloaded 0 times.) "
Stick with 1 video mode of 720x480.  Your different video modes will just be different pixel multiples sitting on top of that master reference mode.
Also, write your own VGA raster generator in Verilog from scratch.  You will need the learning experience and there will be special additions you will need to make for you 8bit bitplane video modes and things like sprites in the future which will be nothing but headaches if you are trying to dissect someone else coding style while sticking/adding your own stuff  on top.
A VGA generator is so simple that you should be posting you code if you have problems here on this forum asking for help and recommendations.
The OSD generator I gave you illustrates a simple level of using Altera's dual port memories & the effort I went through to deal with the fact that to get the top clock or FMAX capabilities, you need to clock latch the address going into the ram as well as clock the data coming out making a 2 clock delay from address to valid data. You will see I have additional delay latches along the video pipe to synchronize the control signals coming in to a new set of output delayed controls which are parallel with the font generated image.
The OSD generator I made is just to give you a boost and play.  You will be remaking your own eventually using 1 huge block of memory where you can selectively choose the base memory for the font as well as where each line of the display output points to in the same huge chunk of memory.
Note in my osg_generator.v code, the HS it takes in needs to be only 1 pixel wide, and the generator will start spitting out pixels within 5 clocks.  This means that within your VGA sync generator, you need to have a dedicated horizontal pulse output just for the OSD generator.  This pulse should be in the middle of the active video display window, not at the beginning of the actual horizontal sync. Same goes for the VS signal on my OSD generator input.  It should pulse for 1 line of video prior to the beginning of the line you want your display output.  I recommend you make these 2 horizontal and vertical pulse position programmable so you can move my test box around the screen with just the beginning 2 coordinates.
As you add sprites, other video modes and potential programmable vertical interrupts, these will just be additional dedicated programmable X and Y coordinates which will be nothing more than and equality compare of your VGA sync generator's horizontal and vertical counters to a set of registers which your CPU can address and write new figures into.
I assume you are designing you own video generator and not trying to perfectly replicate an old EGA video card, correct?
Post by: Berni on October 30, 2019, 12:41:57 pm
That they are expensive, complicated things that are a pain in the ass to program for.
But in exchange for that they can do some digital jobs that no other kind of chip out there can do. That's why FPGAs are only used in cases where the thing cant be done using a MCU or special digital chip. And your application of a custom video card certainly is something that only a FPGA can do.
Post by: legacy on October 30, 2019, 01:11:30 pm
O.T.
does anyoneone happen to have doc regarding the timing of CGA frames?
it's for a crazy project, currently suspended, about interfacing a CGA-tube to a VDU on FPGA
VDU means "text only" display.
Post by: BrianHG on October 30, 2019, 01:24:23 pm
O.T.
I believe they match 240p RGB.  Same as 240p NTSC.
https://en.wikipedia.org/wiki/Color_Graphics_Adapter (https://en.wikipedia.org/wiki/Color_Graphics_Adapter)
Use a pixel clock of 14.31818Mhz and copy the line size, HS and VS timing of NTSC.
I think it's 910 horizontal and 262 lines vertical.  You would need to search NTSC's display window region and place you picture inside that...
Post by: nockieboy on October 30, 2019, 02:47:49 pm
I must be going mad then, because I'm sure it wasn't there when I looked last time!  :-DD
Yes, fair point.  I've got some tutorials to work through first to learn the basics of VHDL/Verilog, but also doing this myself (mostly - will likely need some advice on the way!) will also be more of an achievement, too.  You can't beat knowing your code inside out.
Thanks for the boost and all the help so far in this thread. I feel like I've got the spec for the goal I want to achieve, I just need to learn to play football now.  ;D
Definitely just designing my own video generator - I have no intentions of trying to replicate any other type of video card (unless it's a good design that would be foolish to ignore).
Post by: legacy on October 30, 2019, 06:39:18 pm
@BrianHG
thanks!  :D
Post by: jhpadjustable on October 31, 2019, 10:11:56 am
Well done.  :clap:
512kB of video memory should be plenty.
Post by: nockieboy on October 31, 2019, 10:58:01 am
Okay, some code...  Not sure how after all this talk of VHDL, but I've ended up writing this in Verilog!  :-DD
I've made a stab at writing the HSYNC and VSYNC counter, attached below.  Obviously, on its own it won't do anything but I'm working on the topmost component at the moment - I just want to check I'm going down the right lines and using the right timing values.  :)
EDIT:
Also, with all the tutorials and projects floating around on the internet, it's almost impossible to make this 100% my own work - which clearly this isn't - but at least I understand what I'm doing at the moment and am picking up the Verilog syntax.   ^-^
Post by: legacy on October 31, 2019, 11:11:00 am
For 60Hz VGA pix_clk should be 25.175MHz, but 25MHz should work?
Usually yes. VGA monitors are tollerant.
Post by: Berni on October 31, 2019, 12:28:14 pm
That verilog code looks pretty good for being your first time into it.
My only complaint is how reset is done. "if(reset)" should also have en else block under it so that it stops everything else from happening during reset. With these <= assignments only the last one  is executed, so high "pix_clk" signal would ignore reset. Also generally reset is also included in the sensitivity list on the always @ () to make it a asynchronous reset (This means reset works even when the clock is not running)
Also i would not give "pix_clk"  that name as it is not a clock. If you leave pix_clk high for more than 1 clock cycle you end up moving more than one pixel. So its behavior is more akin to a enable signal. I would call that something like pix_enable or pix_valid or pix_increment. Also the module name could be a bit more descriptive such as "sync_gen_640x480" or just call it "sync_generator" and turn the relevant "localparam" into "parameter". That way it will be 640x480 by default but upon instantiating the module you can add "#(320,240)" on the end and it will reconfigure it for that resolution without changing any code in this file. This is formally called a parameterized module.
In general old CRTs will take pretty much any timing you throw at it, be it weird porch times or a framerate of 98,777366 Hz it will display it all. Just as long as your timings are within reason for the CRTs cirucitry. So no things like frame rates of 5Hz or 1000Hz or having 10 or 10000 lines. Modern LCDs on the other hand will be quite picky on what you feed them as they have crappy upscalers that only know how to upscale certain resolutions properly and the LCD controller might get upset about unreasonably fast or slow timings a lot easier.
Post by: asmi on October 31, 2019, 01:23:19 pm
It is a very bad idea to "generally" do that in FPGA designs because many internal blocks only have synchronous resets. I have seen many designs fail timing only because of these asynchronous resets!  Only do it when you absolutely need, and you know what you're going and are aware of consequences!
Post by: nockieboy on October 31, 2019, 01:27:00 pm
Thanks Berni, but I can't claim all the credit - I've referred to a couple of different sources to put this code together.
As okay, I understand.  I just intended reset to zero the counters, but I guess stopping everything from happening whilst reset is active will completely clear the display too for some feedback to the user.  reset is active low on the board, but I'm inverting it in the top-level module before it gets to the sync generator code here.
Thanks  :-+. It's tips like this I wouldn't otherwise pick up until something went wrong.
All good points and the code is amended accordingly (updated file attached).
Yeah, I'll be testing the FPGA out with an LCD screen so it waits to be seen how picky it is with the timings...  :-BROKE
I've also included the top-level module, vga01.v, for feedback.  Am using ASIC World (http://www.asic-world.com/verilog/index.html) as my Verilog reference.
Aww jeez, Rick! Should I / shouldn't I?  :-//
Post by: asmi on October 31, 2019, 02:07:14 pm
Only use async reset if you need to. At least when working with Xilinx FPGAs. Mosts of their hard blocks (BRAM, DSP, SERDES) only have synchronous resets, so you will have to re-synchronize it internally anyways to reset these blocks. If my memory serves me, the only internal blocks that do have async reset are PLL/MCMM and flip-flops.
Post by: Berni on October 31, 2019, 03:05:32 pm
Copy paste is how most programming is done anyway. As long as you understand what the code does that you copy pasted you are fine. I think learning coding by example is the best way to go
And yes zeroing the counters looks like was your intention, but if the pix_clk is high the reset signal will have no effect if its 1 or 0 because the bottom part of the code will continue counting the registers. Its only when pix_clk is 0 that the reset will actually reset the counters. This is an important thing to know in Verilog since <= and = assignments work in different ways. Tho a reset is not really needed that much here since the counters could initialize in any random state and would eventually get back into its normal counting sequence once it gets to the end. Tho it tend to be good practice to start from a known reset state.
And yes a active high reset is usually used inside FPGAs, unlike the other way around on chips. There are architecture reasons for that and it makes more sense to just write "if(reset)"
Okay i admit i should have been a bit more clear about the reasons behind it.
This syncshornous vs synchronous reset is unfortunately quite chip architecture specific. Yes it is true that a lot of hardware blocks in FPGAs are synchronous reset only, but those are usually instantiated separately outside of always@ blocks and tend to have there reset signal directly connected to whatever your master system reset signal is. As such they don't tend to care what kind of reset it is, but it is strongly recommended that the edge coming out of reset is synchronized to the clock (Makes sure they all come out of reset on the same clock edge), so you will tend to have a reset synchronizer block all the way at the reset signal source to clean it up.
But where it does make a difference is to the logic inside the always@ statement as its behavior is directly affected by what signals are on the sensitivity list inside the (). Because different FPGAs have different LEs (Logic Elements) means that such logic might get implemented in a different way. I will admit i have only worked with Xilinx a few times so i can't say for sure whats best there. But for most of the lineup from Lattice and from Altera, including the Cyclone II they have LE blocks that include asynchronous clear signals. This means that a asynchronous clear has zero cost to the timing margin while a synchronous clear requires a extra AND gate in front. However this only works for clearing registers to zero with a active high reset signal, trying to set them to 1 with a active low reset signal would add extra logic that can slow things down.
But if you are not trying to push the design to high speeds it probably does not matter. But if you ignore the architecture i agree that synchronous resets are the safer way to go.
Post by: nockieboy on October 31, 2019, 08:31:18 pm
Hmm.. I'm obviously missing something from the Quartus II manual, as I'm getting warnings when I try to compile the code I attached earlier.  I'm getting:
Warning (10230): Verilog HDL assignment warning at sync_generator.v(60): truncated value with size 32 to match size of target (10)
Warning (10230): Verilog HDL assignment warning at sync_generator.v(61): truncated value with size 32 to match size of target (10)
Warning (10230): Verilog HDL assignment warning at sync_generator.v(77): truncated value with size 32 to match size of target (10)
Warning (10230): Verilog HDL assignment warning at sync_generator.v(80): truncated value with size 32 to match size of target (10)
... which is referring to these lines:
60: assign x = (h_count < DA_STA) ? 0 : (h_count - DA_STA); // x is zero if current pixel is before display area
61: assign y = (v_count >= VA_END) ? (VA_END - 1) : (v_count); // y is VA_END-1 if v_count is outside display area
77: v_count <= v_count + 1;
80:   h_count <= h_count + 1;
It seems the warning is due to the literal values '0' and '1'?  Any way around that?
I'm getting similar warnings for unsigned ints in vga01.v as well.
Can't seem to bottom-out these warnings though:
Warning (10034): Output port "VGA_R[0]" at vga01.v(12) has no driver
Warning (10034): Output port "VGA_G[0]" at vga01.v(13) has no driver
Warning (10034): Output port "VGA_B[0]" at vga01.v(15) has no driver
I have assigned the signals to pins in the Pin Manager, but I'm clearly missing something else important as well?
Oh, and:
Warning (13024): Output pins are stuck at VCC or GND
Warning (13410): Pin "VGA_R[0]" is stuck at GND
Warning (13410): Pin "VGA_G[0]" is stuck at GND
Warning (13410): Pin "VGA_B[0]" is stuck at GND
I'm Googling for advice as well, but thought I'd pop these here in case anyone following along later comes up against the same problems.
Post by: jhpadjustable on October 31, 2019, 09:01:58 pm
By googling quartus warning 10230 I found Intel recommending (https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06102014_970.html) explicit width specification on constants to suppress the warning.
I consider warnings in a synthesizer as polite FYIs. Unfortunately, that means I have to think when reviewing the warnings to see if they really are a problem, to see if something I really needed got simplified away.
The 10034 might be a real problem. Can we have a look at vga01.v? And your top file? Are you actually driving them? Do you need to drive them? The 13410 will probably not be a real problem of its own, if it resolves once you have provided drivers for that output port, and if you want them "stuck" at 0.
Another note, it helps readability to use the C conventions for the case of constants (all caps) vs. variables (not all caps).
Post by: BrianHG on October 31, 2019, 09:42:41 pm
Although:
// generate sync signals (active low for 640x480)
assign hsync = ~((h_count >= HS_STA) & (h_count < HS_END));
assign vsync = ~((v_count >= VS_STA) & (v_count < VS_END));
Is absolutely correct, however, the >= comparison and < do eat up gates when compiling and your output driving a pin will be a combination unlatched logic equation directly based on your output counter bits.  To get a clean output and better F-Max allowing Quartus's Fitter to better route the logic in your FPGA to meet timing constraints, I would:
A) Make Hsync and Vsync a register.
B) Inside your if (pix_enable), make the logic look like this
if (h_count == HS_STA) begin
    hsync <= 1;
 end else if (h_count == HS_END) hsync <= 0;
if (V_count == VS_STA) begin
    vsync <= 1;
 end else if (h_count == VS_END) vsync <= 0;
Remember, the == only uses 10 xor gates + a 10 input and gate since you are comparing 2 10 bit numbers.  With your GREATER than EQUALS and LESS Than, because of the fixed constants you chose, it may compile to a small number of gates with high efficiency maximum clock frequency (FMAX), but, once you change all your 'localparam's to registers which your CPU can address and change, including default 'reset' parameters, the >= and < will eat up gates and slow down your maximum possible FMAX.  (You may only be thinking about 25Mhz now, however, if you want your core to run at 200Mhz, with you pix_enable running once every 8 clocks, still a 25Mhz pixel, such an optimization will probably be needed further down the road, while just using the resources of your 8bit CPU to do the math when writing these new registers)
*Being registers, this now means that those outputs are delayed by 1 pixel clock, but, those outputs will be cleanly timed to the rising edge of your fpga PLL internal clock as those DFF register outputs don't have any logic gates to go through, those DFF register outputs will feed the IO pin directly.  (Though, I usually add another DFF stage/pipe to all my DAC and sync outputs allowing the compiler/fitter to bury the logic anywhere deep in the FPGA, the use each pins macrocell flipflops registers to drive the pin itself generating the cleanest possible outputs.)
As for your Assign X&Y, again, doing all that realtime arithmetic is not a problem:
// keep x and y bound within the display area
However, like the HSync and Vsync, personally, I make these outputs a single bit which turns on or off using the simple equality == trick I used to generate the Hsync and Vsync.  I rely on my video graphics generator to have an address generator which may increment count every single, every second, or every third/fourth line.
Also, not just that one master image X&Y output enable which is REQUIRED by all DVI transmitters and which may also be used as an image crop mute to protect the video output borders for analog VGA dacs (outside the active video area, the RGB level must be always black), I usually would have something like another 16 programmable of these X&Y on and off output flags which may be used to position sprites or superimposed hardware video windows.  Among these 16, which may be positioned after the active video region output, allotting a time slot which may be used to signal memory access cycles to fill your audio DAC buffer, or signal load a new set of X&Y video memory pointers from memory which change the beginning video read address of the next line of video allowing you to dynamically have a new video address and video mode on each new video line.  (EG like the Atari 800 display list which allows for a few lines of text mode, then a few with graphics, then more text at a different resolution, or Amiga pulldown screens with a vertically scroll-able window on top of another, each with a different graphics mode pointing to somewhere different in memory.)
Also, in my designs, I call the 'pix_enable' pclk_ena, or pena, even though I expect the reset to activate even if the pena is held low.
If you still directly want to use you h_count and v_count as reference pixel counters and get rid of the ensuing subtraction math to improve FMAX, I would move your hsync and vsync to the end of your counters so that 0 through 639 and 0 through 479 are passed through without any math while the blank front & back porches with syncs come at then end after pixel 640 and line 480.  I personally still prefer the 1 bit enables which can actually tell you ensuing logic when to start and stop reading, or when there is free time to read memory for other purposes.  With your current code, your logic will continue reading pixel 0x0 whenever there is no video being outputted.
Post by: Berni on October 31, 2019, 11:34:17 pm
Yeah those are just warnings about a few things.  By default numbers are 32bit so technically you should use the 1'b1 to make a 1bit number, but functionally there is no difference because it gets truncated to 1 bit anyway.
The other warning about no driver is because you are only setting the bit 1 of your RGB output ports while bit 0 is never set to anything. This is usually a mistake so it warns about it. Since it does not know what to do with it it sets them to be 0 and also warns that it did that.
HDL compilers love to spit out warnings about all sorts of things so you usually won't get a zero warning zero error compilation like you tend to strive for in most other programming, If nothing else it will spit out a warning that it is not fully licensed.
Post by: langwadt on November 01, 2019, 12:08:35 am
and it is freaking annoying, because sometimes somewhere  in the ten pages of silly warnings something important is hidden
Post by: BrianHG on November 01, 2019, 03:52:45 am
Hun, yes, with Altera, I turned off the 32bit integer warning, however, when I compile, I get no other warnings.
I used to when I started, but I once I started coding with individual projects for individual .v modules, and I coded for 0 warnings, (only after around 4 years of using Quartus) no more warnings, even when my main project use all the child .v modules into my authentic design.
It's a hassle, but it locks you down to proper coding and using the tool properly.  And now, only important warnings or errors show up in the build log.
Post by: nockieboy on November 01, 2019, 11:32:08 am
Yes, found the same page last night - the code doesn't read as clearly now, but by replacing 1's and 0's with 1'b1s and 1'b0s, the warnings have mostly gone away now.  :-+
Chalk it up to my inexperience in this field, and my not-insignificant OCD when it comes to compilation errors.  |O
Of course, I attached both files earlier in the thread.  I'll probably attach updated copies in this message as well.
The dangers of cut 'n' paste code.  ;)
Although:
    hsync <= 1;
    vsync <= 1;
Okay, I think I follow, although I've had to go off and look at Blocking and Non-Blocking, registers vs wires and all kinds of stuff.  Can't remember who said it, but they were right when they said I'd learn a load of stuff just getting a blank screen to display... I haven't even gotten near wiring this up yet!  Attached at the bottom are the two updated files with all the changes made.
Can I assume that the non-blocking <= assignment operators are okay in the context in which I'm using them?
Sheesh there is so much to learn...  :o
You lost me here.  x and y are wires with 10-bit values.  I can't make them a single on/off bit - unless you're talking about creating a couple more registers to use as single-bit flags to indicate whether we're in the display area or not?
Ah okay, I understand.  Well, I'm trying to crawl before I walk or run, so I'm not going to add in loads of elements that I won't be using for a while, but that's certainly a consideration down the line.
Sure thing - okay, so I've moved the display area to the start of the v_count and h_count range; hopefully I've got the localparams right for the relevant values, I've added a 'blanking' output to the sync_generator which goes high whenever the generator is in the vertical blanking area.  No doubt I'll need to add one for h_count as well to make sure the RGB values are black when in those areas.
EDIT:
Obviously there's errors in the attached files - I'm working through those right now.  ::)
Post by: nockieboy on November 01, 2019, 01:46:01 pm
Updated files without the errors!  :o
Post by: SiliconWizard on November 01, 2019, 04:38:47 pm
Just a thought regarding the CPU part itself. Of course you could consider using a Z80 core in the FPGA you're going to use. But if you still want a true CPU IC, you could consider the Z180 series. They are software compatible with the Z80, but contain many improvements and embedded peripherals, and there are 3.3V versions as well. The Z8L180 is readily available for instance (at least at Mouser)... so unless you really want to go for a true, vintage Z80, that would be sometthing to consider.
https://en.wikipedia.org/wiki/Zilog_Z180
Post by: nockieboy on November 01, 2019, 10:48:21 pm
I still might create a CPU card with the Z180 on it - I've got a couple of Z180's and Z280's lying around with that purpose in mind, but for the moment I'm using a good old-fashioned DIP Z80 chip (a 10MHz one admittedly, but otherwise quite similar to my first computer).
Post by: BrianHG on November 03, 2019, 01:29:34 am
Ok, what the non-blocking statement ( <= ) does and a bit on making optimized fast compact code:  What I'm describing here is a little of whats going on inside the compilers mind, and how it wires gates in the FPGA according to the example verilog code.  Remember, there is no single core math unit in these FPGAs, whatever you write is literally constructed by wiring masses of gates inside the FPGA.  All these wires have lengths, propagation delays, and the gates' inputs have capacitive loads which further slows everything down.  This primer gives you an example of coding technique to be aware of to achieve a minimal gate count FPGA core which is fast as possible and lowest power consuming design.  (If you wanted a central math processing unit, you literally need to code one into existence and wire it up into your design.)
See attached image: (if you got a color printer, print this one)
(https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/?action=dlattach;attach=865642)
There are 3 simplified versions of code in the illustration.
In V1, the 'hsync' is generated just like in the op 'nockieboy' first 'Sync Generator' code.
You have the 10 bit register ''[9:0]''  h_count, which is truly 10 D flipflops.  At the 10 data inputs of the 10 D flipflops, all parallel clocked by the (positive edge of 'clk'), the 10 Q outputs h_count is sent through a bunch of gates added to a fixed 1 bit value of '1', with that new 10 bit result fed back into the 10 D inputs of the 10 D flipflops which is the 10 bit register 'h_count'
Now, to make that 'hsync' wire, those 10 Qs of h_count need to be wired to a set of gates which subtract it from the 10 bit parameter number 'HS_STA' to check to see if the result is not negative, while more wiring of the 10 Qs of 'h_count' are fed into another mass of gates to SIMULTANEOUSLY subtract that same 10 bit 'h_count' with the 10 bit parameter value of 'HS_END' to see if the result is negative, and finally, those 2 comparisons checks are ANDed together, inverted generating a final single WIRE result labeled 'hsync'.
To understand what is happening, the compiler and fitter has to wire up the FPGA with all these gates to make to 2 comparisons as well as the +1 for the counter itself.  Now, find a TTL data book with a 8bit - 8bit adder/subtract with negative flag.  How many gates are there?  The FPGA has to do this 2 fold, with 10 bit numbers each.  (Ignoring the compiler optimizations for now.)  With all that signalling and load, how clean will the 'hsync' wire be if it is driving an IO pin and any other set of logic gates in your design?   Remember, things like load and delay of routing all these wires in the FPGA are taken into account even though you as the programmer aren't specifically told by the compiler other than after a design is compiled, X number of MHz is the best your design will achieve without errors.
In V2, this one is identical to V1 except that I changed 'hsync' from a wire into a register.  The reason why this is an improvement is because, throughout the FPGA, all of the 'D' flipflops clock inputs have a dedicated hard-wiring making sure that all their outputs are parallel.  Example, if your clock is 1 MHz, at the D input of the D flipflop register which is the 'hsync' register, when a clock comes in, the 10 bit 'h_count' with a matched clock will change to it's new value, those 10 bits will go through the mass of gates which are the 2 subtractions and & gate to determine if the number is within 'HS_STA' and 'HS_END', then that result will be presented to the D input of the 'hsync' D flipflop register, however, (and this is the SYNCHRONOUS magic), the Q of the 'hsync' register will not change until the next clock.  This means that after all the number comparing, if the result takes 1ns, 5ns ,6ns,10ns, 15.2ns, 33.8ns, or any number less than 1000ns (I said 1MHz clock as an example), with that mess of gates, that D input may even be filled with glitches/noise/invalid states, as long as the correct result is ready by the next rising clock, that Q output as well as all the Qs of all the registers in your design will all snap to their new values at the same time.
So with this V2, if your 'hsync' register drives an IO pin, or if the 'hsync' is used elsewhere in your design, it will be a fast clean signal which is valid within a fraction of the rising positive edge of the 'clk' signal.  The 1 negative here is that the 'hsync' result is now delayed by 1 clock, but in this case, it is easy enough to subtract 1 from the 'HS_STA' and 'HS_END' parameters.  This change will allow the FPGA compiler to construct a much higher maximum operating frequency for your design, especially if the 'hsync' signal is used elsewhere in your design.
Now in 'V3', the goal here is to make the design operate as fast as possible no mater what the values of  'HS_STA' and 'HS_END'.  The change I made was turn the 'hsync' register into an equivilant clocked SR-Flipflop.  The code I wrote was if the 'h_count' = 'HS_STA', to turn on the 'S' in the flipflop.  Looking above, at the equivilant adder/subtraction and the complex web of gates required for the math, compare all that required to perform an '=' test function which would only be 10 XOR gates whose outputs feed a single 10 input NOR gate.  (This is all it takes to create the function: does 'A=B'?)  That A=B function would run sub nanosecond in the FPGA compared to a 10bit number A minus 10bit number B function, originally requiring 2 of them in parallel.  Just the input load of all those gates in the subtract function slows things down, never mind the delay in each gate as well as the extra length in all the routed wiring.  The second half, if 'h_count' = 'HS_END', turns on the R of the SR-Flipflop clearing it to low.  The load in wiring of this on the FPGA silicon is a fraction of the above code, except for 1 caveat:  If 'h_count' never reaches 'HS_STA', then 'hysnc' will never turn on, or if 'hsync' is on and the 'h_count' never reaches 'HS_END', the 'hsync' will never turn off.
For legibility, the code in the graphic image in plain text:
Many things omitted for simplicity sake but at the top:
module sync_gen ( clk, hsync, hcount );
parameter   HS_STA = 10  ;  //Turn on hsync signal position
parameter   HS_END = 210 ;  //Turn off hsync signal position
input  clk;
output hsync;
output hcount;
V1
reg [9:0]    h_count;
wire         hsync;
always @(posedge clk) begin
    h_count  <=  h_count + 1;  // Without a reset limit, the h_count will run 0 to 1023.
end
V2
reg [9:0]    h_count;
reg          hsync;
    hsync    <=  ~((h_count >= HS_STA) & (h_count < HS_END));
end
V3
reg [9:0]    h_count;
reg          hsync;
  hsync <= 1;
end else if (h_count == HS_END) begin
  hsync <= 0;
end
end
endmodule
Post by: nockieboy on November 03, 2019, 06:35:14 pm
Ok, what the blocking statement ( <= ) does and a bit on making optimized fast compact code:  What I'm describing here is a little of whats going on inside the compilers mind, and how it wires gates in the FPGA according to the example verilog code.  Remember, there is no single core math unit in these FPGAs, whatever you write is literally constructed by wiring masses of gates inside the FPGA.  All these wires have lengths, propagation delays, and the gates' inputs have capacitive loads which further slows everything down.  This primer gives you an example of coding technique to be aware of to achieve a minimal gate count FPGA core which is fast as possible and lowest power consuming design...
Wow - thanks BrianHG!  :clap:
If I'm doing it right, the v3 counter implementation in Quartus II is quoting an Fmax of 217.2 MHz for clk (that's including the vga01.v top level as well).
It still amazes me when I have to keep reminding myself that the code I'm writing has a physical consequence in the FPGA - so what appears to me to be the easiest way of programmatically achieving a task may actually be quite costly in terms of hardware.  :o
I haven't had a lot of time to look at my code or the hardware this weekend as I've been working, but I've got the FPGA connected to one of my LCD monitors via VGA with just GND, HSYNC and VSYNC connected at the moment.  I've messed with the clock timing and tried connecting it at 25 MHz, which showed a corresponding incorrect frequency input on the LCD monitor, but if I get anywhere near the right frequency for VSYNC and HSYNC, the screen is just blank for a few seconds then goes into power saving, so I'm guessing the LCD is (correctly) not detecting any RGB input and is going to sleep as a result.  I was hoping to be able to get the menu up and see what screen resolution was reported, but it seems I need to get RGB signals up and running first.  :-BROKE
Post by: Berni on November 03, 2019, 06:58:22 pm
Sometimes its better to write HDL code from the perspective of circuit design rather than from a perspective of programming.
For example for the given task try to imagine a approximate digital circuit that does this job and then write HDL code that would act like such a circuit. Instead of instruction cycles or operations think of it in terms of logic gates, MUXes, D flip flops, adders, lookup tables...etc Since this is what ends up in the FPGA.
That's a bit odd that the monitor refuses to display a blank signal. But it should be easy to generate some RGB by just outputting the X Y counter values as pixels to get a colorful pattern. Tho take care that you must output black in the blanking periods! Monitors tend to calibrate the black level during blanking and you can get weird colors if you output other things during that (It can be pretty monitor specific).
Post by: BrianHG on November 03, 2019, 09:55:12 pm
Next, now you know what the '<=' function does, basically a bundle of final flipflops latching the outputs of all the synthesized logic gates which are required to perform the boolean algebra on the right of that blocking function, all of them tied to the same dedicated network clock @(posedge...), it's time to take a look at your sync code and what your top hierarchy screenshot within quartus looks like.  (For the top, I still use quartus's block diagram entry for the IO pins and my Veriliog appears as 1 master or multiple wired block diagram modules...)
When your ready, post here your latest syncgen.v when you are ready...
Post by: nockieboy on November 03, 2019, 10:44:52 pm
Not a lot has changed as I've not had much time this weekend to do anything, but here's the latest snapshot of my code attached.
Not sure what you mean by 'top hierarchy screenshot'?  Do you mean the pin assignments? Here's a screenshot of my Quartus II workbench, if that helps:
(https://i.ibb.co/h28bfkc/Untitled.png) (https://ibb.co/NWY5SXr)
I'm not convinced that's what you're after, though.  I haven't used Quartus' block diagram tool to design the hierarchy, I just created the first file (vga01.v) and went from there, creating sync_generator.v and referring to it in vga01.v.  Sorry if I'm being vague or missing an obvious request, it's been a loooong day.  :o
Post by: jhpadjustable on November 03, 2019, 10:56:52 pm
I wonder if the polarity of HSYNC and/or VSYNC are wrong for the chosen resolution.
Post by: hamster_nz on November 04, 2019, 12:45:24 am
I ran up a simulation....
You need to be sure if LINE and SCANLINES are terminal counts, or are the total number. Currently your h_counter goes from  0 to 800 (801 counts), and v_counter goes from 0 to 525 (526 lines).
General suggestion (take them or leave them):
- You need to be clear about what is internal state, and what is exposed. Currently the x & y outputs feel bad.
- Your reset should reset all state (even if it is only for simulation).
- I am not sure why you have "posedge reset" in your always. I don't think it is needed.
Here's what I would do:
- Reset all outputs and state in the reset clause
- keep h_counter and v_counter for internal use only, and change the x & y outputs to be reg not wires.
- Keep LINES and SCANLINES as a total count, so compare to LINES-1 or SCANLINES-1 as the test for resetting the counters/
- Likewise keep HS_STA & HS_END the count where it starts, so remove the "-1" from the localparam and put it in the test.
- Try to avoid ternary operators - usage tends to be very idiomatic, so are a common source of bugs
- Unless you are careful, there is going to be ambiguity about when vsync pulse starts and ends. I suggest you testboth h_count and v_count to decide when to assert vsync. So if you want it to be aligned with the start of the visible pixels use "if (h_count == LINES-1 && v_count == VS_STA-1)" and ""if (h_count == LINES-1 && v_count == VS_END-1)" as the tests when to set the vsync outputs.
This might not give you the fastest design, nor the most compact code, but it will help you avoid lots of subtle bugs.
Post by: BrianHG on November 04, 2019, 03:32:30 am
Note that your code is just as compact and fast as the original because the LINES, VS_STA, VS_END, HS_STA, HS_END,... are all parameters, or constants, so, the compiler works out the -1 ahead of time.  No sweat at all, however, if the OP changes these constants to loadable registers which he can be written to by the Z80 CPU, allowing software defined new video modes, then those '-1' will come into play and add gates to the design.
I feel the same, I believe the sync generator should be 100% positive logic.  Meaning positive hsync / vsync / an active video region output which crops the active visual area (a requirement for most DVI/HDMI serializers), and additional optional signals to trigger video timing specific events which may be fixed to the master h_count and v_count.  Any visual display address / graphics /memory pointers, counters and sub-alignment positioning in the 'active video region' should be in the separate graphics image generator.  Remember, a second new X/Y coordinate counter is only another 20 register flipflops max.
I'm waiting a day, however, I'll make a few suggestions to the ops sync generator which will solve those -1's without a -1 in the code, and solve that 1 clock delay with regards to the other variables, including the picture_enable_h and picture_enable_v signal (together = picture_enable).
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on November 04, 2019, 03:48:52 am
@nockieboy, some questions:
1. Do you have an oscilloscope?
2. Which cyclone II board do you have?
3. Which version of quartus are you using?
4. Are you willing to use Quartus graphics design entry?  (Not for coding, your verilog coding will stay the same, but, just to wire your verilog modules to the IO pins and potentially a few xxxx.v modules together.  This will allow you to easily drop in or take out modules or remove them on the fly and see how your graphics pipe is affected as well as the CPU interface.  It will allow you to easily invert IO pins, or, enable a global PLL.  You can always make a now top hierarchy later-on, or, even tell quartus automatically generate you a top 'MyProject.v' verilog code of your illustrated schematic.  Quartus has a feature to automatically generate a design block of each of your 'xxxx.v' source codes which you may place within your schematic layout, including multiple instances. )
Post by: Berni on November 04, 2019, 06:45:25 am
I do also like to use the graphical schematic entry for the top module since its a bit easier to see where things are going. The user interface on that schematic editor is absolutely terrible (Its directly from the 90s) but that seams to be the case for all the vendors.
By the way there is also a window called the "RTL view" that turns the synthesized HDL back into a schematic:
(https://surf-vhdl.com/wp/wp-content/uploads/2015/11/fir_filter_4_RTL-view.jpg)
This view is a very useful sanity check to see if the compiler understood your code in the way you intended. You can see individual flip flops, adders, muxes etc... and how it wired them up. Its the best place to see what sort of optimization shortcuts the compiler has taken (It loves to reuse blocks/signals, simplify down logic, remove unnecessary logic etc...). Its pretty messy since its auto generated but clear enough to be useful with a bit of highlighting by clicking nets and blocks.
This is however still NOT how it is actually wired inside the FPGA, but simply input to the mapper that crams the functionality in actual FPGA elements. You can get a view of how the FPGA elements are wired up by opening the "Architecture view" to get a similar looking autogenerated schematic but this time with real hardware blocks in it and how they are configured. This makes it a lot more difficult to read so this view is not as useful. An even more bare metal view is the "Chip planner view". It shows you a map of the FPGAs silicon die with all of the elements inside it, allowing you to peek into each one and see how its wired up and configured. It gives you a nice view of whats is going on physically in there but is near impossible to follow signals around. It is however very useful in checking that certain blocks got configured as you expect, most useful for IO blocks in cases where you want to use special IO pin functionality like DDR, reclocking, built in serdes, delay tuning etc...
(http://we.easyelectronics.ru/uploads/images/00/00/60/2011/04/16/045570.png)
Post by: nockieboy on November 04, 2019, 10:16:33 am
Brief update - have wired up the MSB RGB outputs to the VGA connector through 270R resistors to try and get some kind of output (haven't bothered with a resistor ladder to merge the LSB outputs as they're not used yet anyway).  Here's the result:
(https://i.ibb.co/gmQG0Yg/20191104-092002.gif) (https://ibb.co/VJbdF6B)
Clearly an issue with sync pulses or timing somewhere...  The image is a GIF, by the way, so you can see the issue if you click on the image.
Fair point - I've tried the output with reversed polarity on the hsync and vsync outputs and the monitor just goes to sleep, so it would appear the polarity is correct as I do get some sort of output currently...?
Good point, I hadn't noticed that.  This is where I start to make silly mistakes - basic maths.  ::)
Okay, I've tweaked the reset clause to reset hsync and vsync as well - is there anything else I should reset in there?  I'll leave LINE and SCANLINES as they are with the -1 as I'll likely be changing them in the future to regs so they can be changed by the host CPU.
As for the ternary operators comment - so it would be preferable to use full if-else conditionals instead?  Is that purely because of the possibility of user error in writing or interpreting the ternary operators or because of discrepancies in how Quartus II implements them?
I popped the X & Y counters in the sync generator because it seemed like the easiest way to get some sort of graphical output at the time.  Also, that's how the demo code did it that I borrowed from. ;)
 Naturally, I'm literally starting out with Quartus, Verilog and FPGAs in general, so am happy to accept feedback and suggestions on improvements.
 ;D
Yes.  It's barely up to anything (and my skills using it are also pretty poor - remember, I'm not an electronics engineer and this isn't my day job!) but it's a 20 MHz Hitachi V-212.  I got it cheap off eBay a year or two back when I was breadboard-prototyping my Microcom and didn't know that a logic analyser would have been far more useful.   ^-^
One of those cheap ones off eBay.  Here's an example (https://www.ebay.co.uk/itm/ALTERA-FPGA-Cyslonell-EP2C5T144-Minimum-System-Learning-Development-Board/401255830236).
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition.  It was indicated to be the last version that supports the Cyclone II.
I'm certainly happy to give it a go.  I'm fumbling around with Quartus II, trying to learn the ropes as I go, so I'm more than happy to find out about features like this that could help.  :-+
Sounds very useful - I'll see what I can find out about it!  ;D
I have included my full project folder as a .zip archive for info if anyone is playing along at home.  I'm not convinced I fully understand the clock setup and timing / TimeQuest Timing Analysis part of the project very well at all.  :-\
Post by: BrianHG on November 04, 2019, 10:46:57 am
Good enough.  Check the hsync and vsync being sent to your monitor.  Make sure the pulse is clean and at least 4v p-p.  Preferably 5v.  If you are driving your monitor with a 3.3v-3.6v hsync, it may do some funny things...  This is random based on the monitor's internal circuitry.  If the sync it too low, IE you are driving the monitor HS/VS with an FPGA IO directly, there are 2 thing you will need to try.
1> buffer the signal through a 74HC04 inverter, or 74HC245 buffer powered with 5v.  I like to drive the HS and VS into 3 gates each in parallel, and tie each of the 3 outputs in parallel to get a good current output to drive the monitor cable.
2> if the IO on the FPGA is a true 5v output, but the monitor cable load is weakening it too much, a 220Ohm to 330Ohm pullup resistor to 5v may work.
(Option #1 is better, it also separates the FPGA IO from direct connection to a wire on a VGA plug which may blow the FPGA or cause internal malfunction.)
If you use 2 channels, placing 1 probe on hsync and the second on a R/G/B pin, you should see if you get a regular pattern or not.
Also, sync polarity doesn't matter any monitor which can take in VGA with modes as high at 1280x720 or above.  If your mode is not standard with wrong polarity, the monitor should potentially only have bad picture horizontal/vertical size and position unless the sync timing is not associated with the picture.
Post by: nockieboy on November 04, 2019, 11:20:55 am
Aha - that'll be the problem then, I'm driving HSYNC and VSYNC directly from the FPGA pins.  Only R, G and B are going via 220R resistors...  :-BROKE
My scope is showing nice clean signals on HSYNC and VSYNC, but only 3.3v p-p, which is to be expected - so the monitor is picking up some information (i.e. the R, G and B signals) but not necessarily the proper sync signals.  It shows a 640x480x60 screen resolution in the menu, but as you can see from the gif I posted previously, the sync is out.
I don't have too many HC parts lying around, they're all HCT, but I'll see what I can do.
There's definitely a regular pattern - can see that on the monitor, it's just skewed and rolling because of the sync problems.
Post by: Berni on November 04, 2019, 11:23:57 am
That picture does look like it might have some sort of HSYNC issue.
If electronics are not your main thing then you are actually doing pretty well since FPGAs are pretty far from regular programming. An oscilloscope is one of the most useful tools for debugging electronics, no other tool gives the same deal of universal insight into what circuits are doing. You do usually want to have a digital scope for digital circuits so that you can one shot capture communication buses and decode them. But video luckily involves stable repeating patterns so a analog scope can still be quite useful when triggered from vsync or hsync.
But there is a trick with FPGAs. You can build a logic analyzer in the same chip as the cirucit. Quartus has a tool for doing this called SignalTap:
(https://raw.githubusercontent.com/wiki/mist-devel/mist-board/signaltap_2.jpg)
You give it a list of signals you want to monitor and how much memory to use and it generates a logic analyzer for that, taps off those signals and adds it to the design. Next time you compile your design this logic analyzer will be included in the final output and once loaded into the FPGA listens on JTAG. Then you can just click connect in SignalTap and it will allow you to interact with this logic analyzer to start captures, configure triggers etc... In some cases this is more useful than an actual logic analyzer because you have essentially 100s of logic channels available, allowing you to monitor entire counters like a bus. But because its using internal block ram means that you typically won't be making captures longer than a few thousands of samples.
Post by: nockieboy on November 04, 2019, 11:55:35 am
Well, that sorted the problem - thanks BrianHG!  :-+
Clearly my monitor wasn't happy with the 3.3v sync signals - I found a 74AHC541 in my box of bits and am now running the vertical and horizontal sync signals through one of these line drivers powered at 5v and am getting a nice stable output:
(https://i.ibb.co/BfFX87L/20191104-114222.jpg) (https://ibb.co/Zf7nywd)
It's surprising how pleased I am at getting four overlapping squares to display on a monitor!!! Haha!  :-DD
Programming isn't my main thing, either, although I'm much better at it than electronics!  Never let it be said that I don't enjoy a challenge... :o
And the frequency isn't so high either - I had been using the scope originally to debug my breadboard computer running at 4 MHz, these signals are in the KHz ranges which is much more comfortable ground for my old 'scope.  ;)
But there is a trick with FPGAs. You can build a logic analyzer in the same chip as the cirucit. Quartus has a tool for doing this called SignalTap:...
Wow!  That's really useful - specially if you have a decent amount of RAM in the FPGA.  :-+
Work calls again, but when I get some more time to work on this I'll set up a resistor ladder to merge the two bits for R, G and B on the breadboard so I can try out the full colour palette.  ;D
Post by: BrianHG on November 04, 2019, 12:27:28 pm
;)   :clap:  HCT is actually better for converting the FPGA 3.3v to 5v since it's inputs have a trigger threshold at TTL levels instead of mid 5v, or 2.5v.  Any will work, like 74HCT, 74ACT, and other variants.  (You would have never figured this one out without me.  This one nearly destroyed a huge demo I had 10 years ago since my home test monitors were studio grade monitors whose sync inputs would work perfectly with a 0.7vp-p sync...  The cheap PC screens didn't like that 3.3v.)
Take a day to learn how to make a top hierarchy block diagram in quartus.  Make your now functioning project's 2 xxx.v files into 2 separate block and wire them on a block diagram.  (Save your current project and start a new one...)
***Remember when defining the inputs and outputs.  Output bus pins in quartus look like ' Red[7..0] ', not 'Red[7:0] ' like you see in verilog.  It's the only BIG gripe I have with Quartus as its a drawback from their pre-verilog days of quartus 1 ...  Once you are ready, I'll show you a few tricks which will make all your outputs parallel without delays, even as you add modules in-between, like my OSD character generator.  I also recommend going on youtube and searching beginners guide to quartus block diagram entry, or similar to get you going.  Include generating a sheet symbol for verilog source files/code in quartus...
Post by: nockieboy on November 06, 2019, 08:23:50 am
For info, Grant Searle has put his site back up at searle.wales (http://searle.wales).
It seems his ISP took the site down for breach of terms and conditions due to the high traffic it was generating.  :-DD
I'm trying to get my head around hierarchy block diagrams, but it's really slow going.  Initially I was concerned that Quartus II 3.0 sp1 didn't support that feature, but it just seems it's deeply buried somewhere.  Then I got sidetracked looking at character generators (the next big step for my design) and today, hopefully, I'll have some time to work on block diagrams again!!!  :o
Post by: BrianHG on November 06, 2019, 08:47:29 am
You should be thinking of making your own character generator, but first, you need to clean up your sync generator.
In Quartus, making a 'New' block diagram file is a key feature, not a hidden one.
Setting that .bdf (block diagram file) as the top hierarchy is also standard.
Double clicking on the the middle of the file to add pins and generic logic, or even library megafunctions is also standard.
What might be a little hidden is opening your .v file in the directory, then 'Generating sheet symbol' (I think it's called this, it's been a decade...)L:
File>Create/Update>Create symbol files for current file.
The verilog must have no errors for this to work.
Once generated, in your .bdf,  double click in a blank area to add a new symbol/component.  Click on user generated symbols and place the symbol on the sheet.
You should see a symbol labeled with you verilog name with all the input and output pins and buses.
In the furture, if you want to edit your verilog code for that symbol in your block diagram, you may just double click on it's symbol in your block diagram.  If you add inputs or outputs and you want them to appear on that symbol in you block diagramm, you will need to re: ' File>Create/Update>Create symbol files for current file. ' to update the symbol with the new IO pins.
Post by: nockieboy on November 06, 2019, 10:52:59 am
Yes, must try not to get ahead of myself.  :-\
Sure is. Just wasn't obvious to a completely new beginner like me yesterday who only knew about creating .v files!  :scared:
I found a really handy tutorial (https://www.flc.losrios.edu/docs/FLC-Documents/Instruction/Engineering/lab/Lab1%20-%20Quartus%20Tutorials.pdf) (actually a university/college worksheet) with step-by-step instructions on how to create the two types of project (one based on code, the other on a diagram), create blocks for them both and use them both in a top-level project as diagram symbols.  I also learned about creating simulations, too!  ;D
This is as far as I've gotten:
(https://i.ibb.co/N1xghPh/Untitled.png) (https://ibb.co/rbkKPSP)
Not great - I've inputs and outputs on sync_generator that don't connect to anything on vga01, which is annoying.  Will go look at that.
Code for vga01.v and sync_generator.v attached for info, as I've changed vga01.v a bit to show colour bars instead of squares now.
EDIT:
Updated diagram:
(https://i.ibb.co/1b41qGr/Untitled.png) (https://ibb.co/ZNb58zB)
EDIT 2:
From looking at this second diagram, it seems I should move the pix_en generation from vga01 to sync_generator, as it would make more sense for it to be there unless I'm likely to need it in vga01 at any point in the future there?
Post by: nockieboy on November 06, 2019, 01:21:25 pm
Updated diagram:
(https://i.ibb.co/mCy8TRz/Untitled.png) (https://ibb.co/XZ58LWJ)
This is giving me errors, though, when I try to compile:
Info (12128): Elaborating entity "vga01" for hierarchy "vga01:inst"
Error (12014): Net "vga01:inst|x[8]", which fans out to "vga01:inst|vga_r", cannot be assigned more than one value
Error (12015): Net is fed by "vga01:inst|sync_generator:display|x[8]"
Error (12015): Net is fed by "vga01:inst|x[8]"
Error (12014): Net "vga01:inst|x[7]", which fans out to "vga01:inst|vga_g", cannot be assigned more than one value
Error (12015): Net is fed by "vga01:inst|sync_generator:display|x[7]"
Error (12015): Net is fed by "vga01:inst|x[7]"
Error (12014): Net "vga01:inst|x[6]", which fans out to "vga01:inst|vga_b", cannot be assigned more than one value
Error (12015): Net is fed by "vga01:inst|sync_generator:display|x[6]"
Error (12015): Net is fed by "vga01:inst|x[6]"
Error (12014): Net "vga01:inst|inDisplay", which fans out to "vga01:inst|vga_r", cannot be assigned more than one value
Error (12015): Net is fed by "vga01:inst|sync_generator:display|inDisplayArea"
Error (12015): Net is fed by "vga01:inst|inDisplay"
Trying to look these up, but it's not obvious (to me at least) what the problem is.  I'm obviously doing something very stupid...  :-//
Post by: Berni on November 06, 2019, 01:28:39 pm
That error to me looks like there are multiple outputs trying to drive 3 bits of net" x" and "inDisplay". You might have an output or input back to front.
Oh and by the way your inDisplay signal is probably the same as a signal that RGB buses tend to call the DE signal (Display Enable). This is a signal that is high whenever pixels inside the viewing area are being sent. Some LCD panels use that instead of Hsync and Vsync
Post by: BrianHG on November 06, 2019, 01:41:34 pm
Your RGB 2 wire buses are driving output pins are single wires each.  Remove the doubled pins and rename the output pins R[0], G[0], B[0] to:
R[1..0]
G[1..0]
B[1..0]
Quartus will understand that those outputs are a collective of pins grouped as a bus with 2 wires going to 2 pins.
This come in handy when you have an output group, like in my design, I have a 256bit ram data bus.  Could you imagine my block diagram with 256 individual BIDIR IOs instead of one single one labeled RDQ[255..0]...
Also, you do not need to label the buss wires as they will take their name from the output pins automatically.
Post by: nockieboy on November 06, 2019, 02:39:23 pm
Okay, it compiles now - I just had to remove this block from vga01.v:
// create a 640x480 synch and pixel
   sync_generator #(640,480) display(
      .clk(clk),
      .reset(rst),
      .x(x),
      .y(y),
      .DE(DISP_EN)
I forgot to remove that block, so the HDL was trying to set up two connections to vga01 - one in code, the other in the diagram?
 :o Yikes.
Ah okay, thanks - the info I found online (from Intel, no less) stated in one of the steps to label the bus, so I did. Happy to hear about shortcuts, though. ;)
Talking of which, I'm really liking this diagram method of connecting blocks up - seems much less stressful than the code method!  ;D
Post by: nockieboy on November 06, 2019, 03:51:25 pm
 |O  Okay, so it compiles but I'm getting no image - the screen is going into standby.
I've attached the files for vga01 and sync_generator with all the latest modifications I've made - they all compile fine into symbols and as part of the main project, but I'm getting nothing out at the monitor.  Below is a pic of the top-level diagram:
(https://i.ibb.co/fQBpvm6/Untitled.png) (https://ibb.co/vDgPY2y)
I've even tried swapping HSYNC/VSYNC around in case I'd got the pin assignments wrong, but to no avail - I'm not sure what's going wrong to be honest.  Have attached project files in case anyone wants to take a look.
EDIT:
For info, the pin assignments are identical to the project VGA01 - which I've uploaded to the FPGA and tested and that works fine.
Post by: Berni on November 06, 2019, 05:17:41 pm
Instead of looking trough your code for the problem im just going to give you some tips on debugging it.
First choice of action is a oscilloscope. Look at what the pins are doing because this is quick and easy to do, for tracking down the basic mistakes like wonky or missing clocks, swapped signals etc...
Then if it still does not lead you to any findings have a look at that "RTL View" and see what the compiler has compiled. Since you have basicaly put together the same thing in a diferent way means it should also compile into circuitry that is similar. Try to make sense of the connections in there and if there is something weird that can point you into where exactly the issue might be.
Post by: nockieboy on November 06, 2019, 06:31:59 pm
 :palm: :palm: :palm:
Fixed it.  I'd linked the reset line to both blocks, but had only inverted the signal in one of them - forgetting to invert the signal to the other, so one was held in permanent reset.  |O
All working again now.  ;D
Previous image of diagram is still current, more or less, except for the inversions on the reset inputs for each block (I've removed the code inverting reset in sync_generator).  :-+
Post by: BrianHG on November 07, 2019, 09:18:51 am
Here we go, I cleaned up your sync generator.  You had a few bugs.  Now, I don't have Quartus installed anymore and I just typed it in a text editor, so please bear with possible errors.  Once you understand my changes, you may remove anything you don't like:
// (default 640x480) 60Hz VGA Driver
// but can take parameters when initialised
// to output sync signals for any screen
// resolution
//                          |- LINE
//        __________________________ ____|
//       |      DISPLAY AREA        |    |
//       --------------------------------- V_RES
//       ---------------------------- SCANLINES
module sync_generator(
// inputs
input wire pclk, // base pixel clock
input wire reset, // reset: restarts frame
// outputs
output reg pc_ena    // ***** New pixel clock enable ...  For now, you will use pc_ena[0] which divides the clock by 2.
output reg hde, // Horizontal Display Enable - high when in display area (valid drawing area)
output reg vde, // Vertical Display Enable - high when in display area (valid drawing area)
output reg hsync, // horizontal sync
output reg vsync, // vertical sync
output reg [9:0] h_count, // current pixel x position
output reg [9:0] v_count // current line y position
// default resolution if no parameters are passed
parameter H_RES = 640; // horizontal display resolution
parameter V_RES = 480; // vertical display resolution
// no-draw area definitions
// ***** switched to parameters so you can edit these on quartus' block diagram editor.
parameter H_FRONT_PORCH = 16;
parameter HSYNC_WIDTH   = 96;
parameter H_BACK_PORCH  = 48;
parameter V_FRONT_PORCH = 10;
parameter VSYNC_HEIGHT = 2;
parameter V_BACK_PORCH  = 33;
// total screen resolution
localparam LINE = H_RES + H_FRONT_PORCH + HSYNC_WIDTH + H_BACK_PORCH; // complete line (inc. horizontal blanking area)
localparam SCANLINES = V_RES + V_FRONT_PORCH + VSYNC_HEIGHT + V_BACK_PORCH; // total scan lines (inc. vertical blanking area)
// useful trigger points
localparam HS_STA = H_RES + H_FRONT_PORCH - 1; // horizontal sync ON (the minus 1 is because hsync is a REG, and thus one clock behind)
localparam HS_END = H_RES + H_FRONT_PORCH + HSYNC_WIDTH - 1;// horizontal sync OFF (the minus 1 is because hsync is a REG, and thus one clock behind)
localparam VS_STA = V_RES + V_FRONT_PORCH; // vertical sync ON
localparam VS_END = V_RES + V_FRONT_PORCH + VSYNC_HEIGHT; // vertical sync OFF
/*  moved above
reg [9:0] h_count; // line position
reg [9:0] v_count; // SCANLINES position
reg [9:0] z_count; // Frame counter for CPU animation
/* obsolete
assign x = (h_count < H_RES) ? h_count : (H_RES - 1'b1); // x = H_RES-1 if current pixel is after display area
assign y = (v_count < V_RES) ? v_count : (V_RES - 1'b1); // y = VS_END-1 if v_count is outside display area
   // generate a 25 MHz pixel strobe
   //reg [15:0] cnt;
   //reg pix_en;
pc_ena <= pc_ena + 1'b1;  // This is tempoary
// handle signal generation
always @(posedge clk)                    // I removed ', posedge reset)', since it adds a gate to the CLK input of all the registers in your design slowing down that trigger edge
begin
if (reset) // reset to start of frame
begin
h_count <= 1'b0;
v_count <= 1'b0;
hsync   <= 1'b0;
vsync   <= 1'b0;
vde     <= 1'b0;
hde     <= 1'b0;
end
else
begin
if (pc_ena) // once per pixel
begin
if (h_count == H_RES - 1)
begin
HDE <= 1'b0;
end
// check for generation of HSYNC pulse
begin
hsync <= 1'b1; // turn on HSYNC pulse
end
hsync <= 1'b0; // turn off HSYNC pulse
// check for generation of VSYNC pulse
if (v_count == VS_STA)
begin
vsync <= 1'b1; // turn on VSYNC pulse
end
else if (v_count == VS_END)
vsync <= 1'b0; // turn off VSYNC pulse
// reset h_count & increment v_count at end of scanline
if (h_count == LINE - 1) // end of line
begin
h_count <= 1'b0;
HDE     <= 1'b1;  // Turn on horizontal video data enable
if (v_count == SCANLINES - 1) // ****** Now that it's time to increment the H count, this is when you would check if the V-count should be cleared.  End of SCANLINES
begin
v_count <= 1'b0;
VDE     <= 1'b1;   // Turn on vertical video data enable
end
else
begin                                             // ****** If the v_count isn't being cleared, you go ahead and add 1 to the v_count
v_count <= v_count + 1'b1;           // increment v_count to next scanline
if (v_count == V_RES - 1)   VDE <= 1'b0 ; // Turn off  vertical video data enable
end
end
else
h_count <= h_count + 1'b1;           // otherwise, just increment horizontal counter
if (h_count == H_RES - 1)  HDE <= 1'b0 ;  // Turn off  vertical video data enable
/*  ****** BUG *****  Moved into the correct place at the the end of a horizontal line, where you increment the v_count increment, or clear it. see 16 lines above
// reset v_count and blanking at bottom of screen
if (v_count == SCANLINES - 1) // end of SCANLINES
begin
v_count <= 1'b0;
end
*/  ***** End of bug ******
end
end
end
/******* Error ****** this must synchronous with you video clock, however, I recognize this was probably just a last minute patch.
begin
DE <= (h_count < H_RES) && (v_count < V_RES);
end
endmodule
Now, here is a new module to add to your project.  It mutes the RGB data values when the raster is outside the active display area.  (Once again, I just typed it in notepad.)  It belongs just before your output pins.  Again, read comments inside it.
//  This module will force mute mute the RGB video output data outside the active video display area
//  This module will also generate the vid_de_out use by many DVI transmiters
//  This module, as an example, also has all the inputs and outputs used along the pixel pipe
//  it illustrates since there is a pixel delay in the video switch, the syncs and video enables are also delayed
//  making the output picture window perfectly parallel with the vidoe coming in, then being fed out.
module vid_out_stencil(
input wire pclk,
input wire reset,
input wire pc_ena,      // Pixel clock enable
input wire hde_in, // Horizontal Display Enable - high when in display area (valid drawing area)
input wire vde_in, // Vertical Display Enable - high when in display area (valid drawing area)
input wire hs_in, // horizontal sync
input wire vs_in, // vertical sync
input wire [RGB_hbit:0] r_in,
input wire [RGB_hbit:0] g_in,
input wire [RGB_hbit:0] b_in,
output reg hde_out,
output reg vde_out,
output reg hs_out,
output reg vs_out,
output reg [RGB_hbit:0] r_out,
output reg [RGB_hbit:0] g_out,
output reg [RGB_hbit:0] b_out,
output reg vid_de_out      // Actual H&V data enable required by some DVI encoders/serializers
parameter RGB_hbit    = 1;  // 1 will make the RGB ports go from 1 to 0, eg [1:0].  I know others prefer a '2' here for 2 bits
parameter HS_invert   = 0;  // use a 1 to invert the HS output, the invert feature is only for this video output module
parameter VS_invert   = 0;  // use a 1 to invert the VS output, the invert feature is only for this video output module
begin
if (reset) // global reset
begin
// not in use for this module
end
else
begin
begin
hde_out <= hde_in;             // since the this video muting switch algorythm delays the output by 1 pixel clock,
vde_out <= vde_in;             // all the video timing reference signals will also get the 1 pixel delay treatment to keep the output aligned perfectly.
hs_out  <= hs_in ^ HS_invert ; // the invert feature is only for this video output module
vs_out  <= vs_in ^ VS_invert ; // the invert feature is only for this video output module
if ( hde_in && vde_in )
begin
de_out <= 1'b1 ; // turn on video enable for DVI transmitters
r_out  <= r_in ; // copy video input to output
g_out  <= g_in ; // copy video input to output
b_out  <= b_in ; // copy video input to output
end
else
begin
de_out <= 1'b0 ; // turn off video enable for DVI transmitters
r_out  <= 0    ; // Mute video output to black
g_out  <= 0    ; // Mute video output to black
b_out  <= 0    ; // Mute video output to black
end
end
end
end
endmodule
Now, the next thing you need to do is use the IOs from this example, and make a new picture pattern generator which does not use the sync generators H&V counters, but, generates it's own internally using this example IO port setup:
module vid_pattern_generator(
input wire pclk,
input wire reset,
output reg hde_out,
output reg vde_out,
output reg hs_out,
output reg vs_out,
begin
begin
end
else
begin
begin
// ***************  insert generator code here
// ***************  also remember to pass through the hde,vde,hs_out,vs_out
// ***************  in the future, numerous delay sizes may be needed if you are performing functions which take multiple clocks before a true pixel becomes valid
end
end
end // always @clk
endmodule
Let me know when you are done, because, after I've gone over your new pattern generator, your next step is to place either your first text, or, graphics.
Additional: Please place you quartus screenshots on this forum, I'm having trouble with your picture server & since this thread may last long on the forum, it is a good idea to have the photos here.  (If you want a compact picture file size, lossless, use the .png file format...)
***** DON'T forget to update the graphic symbol for the changes I made to you sync generator.  The order of the IO pins have been changes and I changed the available parameters on the block diagram symbol.
Post by: Berni on November 07, 2019, 09:30:37 am
Is there a specific reason why not to reuse the X and Y counters from the sync generator?
You will always need to know the pixel X Y coordinates so why not use a counter that already counts this. Only thing i would add is a "pixel_increment" signal that goes high for 1 clock cycle every time it steps onto the next pixel. This can then pace the pixel generation logic at slower speeds than the clock.
Post by: BrianHG on November 07, 2019, 10:20:49 am
Yes.  The counters are good for generating a pattern, especially in a simple design.  However, there are a few advantages to getting used to having a separate what we could more truly call an address counter generator which doe not rely on multiply and add to point to a position in ram specifically.
First advantage.  You notice I separated the display enables into horizontal and vertical, HDE & VDE.  to create a synchronous new H&V counter, one could approach the counters like this:
hde_out <= hde_in;
vde_out <= vde_in;
if (~vde) begin  // regardless of the display geometry and timing, the new
   vcount <=0 ;  // vertical count clears immediately after a video frame has finished
  end else begin
                  if (~hde_in && hde_out ) vcount <= vcount +1;  // regardless of the display geometry and timing, the new
        // vertical count increments immediately after a video line is finished
        // giving time for address generators to do their math and ram access cycles
                  if (~hde) begin
                     hcount <= 0;
                 end else begin
                      hcount <= hcount +1;
                     end
Now, the hcount and vcount coming out of the sync generator may be re-aligned with reference to the active picture area to re-center position the picture, the above code with minimal gates will always clear and increment you picture coordinates right after the display activity has ended, giving you maximum time to perform additional actions/access within the same block of system memory to do thing like, copy over memory to fill a sprite, copy memory for audio dac, read a display list for what the video mode of the next line of video should be and where it's display memory is located.
Now, this is a preference as I know that such logic will only eat another 24 logic registers for a full 1024x1024.  This will also increase your FMAX as these counters may now be located right at the inputs of your dual port ram which quartus now only has to route HDE and VDE from your sync generator to wherever the ram address may be in the FPGA.
Remember, the current sync generator only generates a vde, hde, vsync, hsync.  Wait till we add
sprite1.thru.8_hstart
sprite1.thru.8_vstart
sprite1.thru.8_vstop
vertical_interrupt1.thru.2
Stopping here already makes 26 x 10 bit number compares on the hcount and vcount to generate their windowed coordinates.  Adding that to using the same counters to generate additional raster coordinates will kill the FMAX in such a slow old FPGA.
I'm targeting a high speed FMAX so that with a simple dual port ram, on the graphics read side, if the ram is operating at 6x the pixel clock speed, say 150Mhz, for each pixel drawn, I can access 6 different words of system ram and still have the second port 100% dedicated to the CPU interface.
With these 6 access, we will for example, read a top ascii text window layer, loop that output into a resolver for the font memory base address and read that letters correct pixel, another access cycle for reading a font color map.  Also, access graphics memory for a graphics mode.  And since these modes usually are bitplane, they'll only eat 1-2 of my access time slots.  The remainder access slots 3-6 will be used for a hardware rectangle read / modify / write command which will accelerate clear, carriage return scroll text, paste a bitplane picture from one location in memory into another with an optional transparent color 0.  With the 2 megabit Lattice part, an 8Mhz Z80 would be able to basically run a simplified Doom type game with all the sorted character graphic images pre-rendered in the OP's 160x120 256 color mode.
Hmmm, the only ugly thing would be a triangle filling engine.  Thankfully, there is another thread here on this FPGA forum covering that exact topic, with source code...  With a core 150Mhz clock and 8MHZ cpu, the dedicated CPU memory access port if free over 95% of the time for sophisticated triangle, rectangle and circle geometry engine.
Post by: nockieboy on November 07, 2019, 10:39:03 am
Thanks!  :-+
Well done, by the way, writing all that in a text editor - there were only a couple of typos in variable names, otherwise it all compiled into symbol files just fine.  ;D
Okay, working on it now...  :-/O
Righto - don't know why I got into the habit of externally-hosting the images, but there's no particular reason I still do it.  :-+
No worries. Will get back to you (hopefully) shortly!  :-/O
Post by: Berni on November 07, 2019, 11:04:44 am
Well yes for counting frame buffer memory addresses you would want to use a separate counter that resets on Vsync. But for other things having X Y tends to be more useful.
For text and tile maps id use grids that are 8 16 32 or something and round the total area to a round power of 2 number so that you can get the index by simply bit shifting and so zero logic is needed to calculate the index from X Y (Yes this wastes memory space but is very useful for smooth scrolling). Also since these are small and often accessed id stick them into separate memory blocks so that you can generate text and color it within a single clock cycle. When deciding about sprites its also common that you need to compare a bunch of registers to the X and Y coordinates. All of it being essentially combinational logic that can work in the background for multiple clock cycles if needed since pixels come out at such a slow rate. You can easily give yourself a 1 pixel head start to it by delaying Hsync output by one pixel so that the pipeline is full and ready when the pixels really start moving out to the monitor.
Anyway many ways to skin a cat, none of them necessarily more correct, just different in there own way.
Post by: nockieboy on November 07, 2019, 11:30:12 am
Okay, vid_pattern_generator.v below for your perusal and criticism.  ;)
I haven't tried it out on the FPGA yet as I'm sure there'll be some feedback and changes I need to make!  I was undecided about how to implement the x, y counters - but the method I've gone with is this one; all the time pc_ena is HIGH (pixels are being drawn), I increment the X and Y counters - so they should range from 0-639 for x and 0-479 for y, or indeed whatever maximum value the current screen resolution goes up to.
As they're counting, the only check that is made is against H_RES to reset x at the end of each scan line.  I don't check y at all as that will stop counting when pc_ena goes LOW and get reset during VSYNC.
As soon as pc_ena goes LOW, the counters no longer increment and when there is a VSYNC pulse, the counters are reset, ready for pc_ena to go HIGH at the start of the next frame and allow them to count again.
Does that sound reasonable, or is there a better way?
input wire pclk,
input wire reset,
output reg hde_out,
output reg vde_out,
output reg hs_out,
output reg vs_out,
// set up x & y position counters
reg [9:0] x, y;
always @(posedge pclk)
begin
begin
// reset position counters
x <= 1'b0;
y <= 1'b0;
end // global reset
else
begin
begin
// Generate some colour bars based on x value
r_out[RGB_hbit] <= x[8];
g_out[RGB_hbit] <= x[7];
b_out[RGB_hbit] <= x[6];
// pass through hde, vde, hs_out, vs_out
hde_out <= hde_in;
vde_out <= vde_in;
hs_out <= hs_in;
vs_out <= vs_in;
// update the position counters
// all the time pc_ena is HIGH, we're in a valid drawing area so
// the counters can be incremented and checked against the
// supplied screen resolution
// reset X & increment Y at end of scanline
if (x == H_RES - 1) // end of line
begin
x <= 1'b0; // reset X
y <= y + 1'b1; // increment Y to next scanline
end
else // not at end of scanline, so just increment X
x <= x + 1'b1;
end // pc_ena
else
begin
// Check for VSYNC and reset X & Y if VSYNC is HIGH
if (vs_in)
begin
x <= 1'b0;
y <= 1'b0;
end
else
begin
// do nothing
end
end // !pc_ena
end // !global reset
end // always @clk
endmodule
Post by: BrianHG on November 07, 2019, 11:54:32 am
Here's a trick:
                 if (~hde_in) begin
                     x <= 0;
                 end else begin
                      x <= x +1;
                     end
OR --- your choice ---
                 if (hde_in) begin
                     x <= x + 1;
                 end else begin
                      x <= 0;
                     end
What's happening here is while the horizontal enable is OFF, the x counter is kept at 0.
When the horizontal enable is high, the x counter counts.  This is elegant since the X position is 0 right after the display is disabled and goes to 1 right at the second active pixel while continuing to count up.
Vertical has 1 additional trick...
if (~vde_in) begin
   y <=0 ;  // vertical count=0 after the picture area is finished and stays at 0 while the vertical DE is not enabled
  end else begin
                  if (~hde_in && hde_out ) y <= y +1;  // the trick.... When the horizontal DE line ends by going low, at that 1 pixel
        // while the horizontal DE output is still high since it's delayed
        // by 1 pixel clock, the vertical counter will increment by 1.
        // Using an input  ANDED with a 1 clock delayed copy of that input is
        // is commonly used to trigger a single shot / one shot action every time
        // an input transitions from high to low, or low to high depending on your ~...
  end
What going on here, is that during the first line of the vertical DE, since it was previously cleared, it starts at 0.
It wont increment until the end of the first horizontal line meaning that at the next line, the Y counter will already be at 1.
Operating like this, if you have a variable HDE and VDE window anywhere in your raster at any size, the X and Y counters will be at their next ready valid numerical state immediately after each line has ended and the frame has ended.
Post by: nockieboy on November 07, 2019, 12:14:06 pm
Fantastic - works beautifully and is quite small and neat, a great combination.  ;D
[attach=1]  [attach=2]
One thing I've noticed - there's more colour bars... Is the x counter incrementing properly?
Post by: nockieboy on November 07, 2019, 01:05:25 pm
I'd be hoping that I could just ignore the least significant bits of the x and y counters to get the tile index?  Say my tiles are 8x16 (I was originally planning on 8x8, but it seems it should actually be 8x16? I might just stretch the y-axis by 2 though to keep memory use down initially).  So for example:
tile_x = x[9:4];
tile_y = y[9:5];
Surely that'd be quicker than messing around with bit shifts, or am I misunderstanding what you've written and we're talking about the same thing?
Post by: Berni on November 07, 2019, 01:15:21 pm
tile_x = x[9:4];
tile_y = y[9:5];
Yes this is bit shifting, just rewireing bits with some offset. On a FPGA such a operation is free as its done inside the signal routeing hence why its so useful.
The reason for also keeping the map size a power of 2 is so that you can build the address for the map memory by simply going
assign tilemap_addr = {tile_y,tile_x};
This means that on a 640x480 screen with 8 pixel tiles you would instead of having 80 tiles wide have 128 tiles wide by using a 7bit wide tile_x register. So you waste memory by having more tile memory than is needed to fill the screen, but it also allows the CPU to draw and update tiles outside the visible area. This is how infinite smooth scroling is implemented on most game consoles.
Post by: BrianHG on November 07, 2019, 01:24:30 pm
(Attachment Link)   (Attachment Link)
I think you can now invert the hsync and vsync output to get the standard VGA output sync polarity.  Now with the 5v buffered outputs, your monitor should accept the signal.
As for text, you are correct, take a look at my text generator, though it might need a little touch-up to be wired in place of your video generator.  You'll also note in my code that I am ignoring the LSB on the H&V counters in my code.  This is to make each dot in my 8x8 font 2 pixels wide and 2 pixels tall.
I'll take a look at the code tonight and maybe do a little patch for you.
Post by: nockieboy on November 07, 2019, 02:17:27 pm
Sounds like an effective way to do it, but I might have to leave that for a while until I have an FPGA with enough RAM.   The Spartan 6 arrived today, but I'm still waiting on the cable programmer for it.  ::)
Okay, that's strange.  I've inverted the HSYNC and VSYNC by changing the parameters on vid_out_stencil, and I'm now getting fuzzy edges to the colour bars and screen blanking several times a second.
Post by: BrianHG on November 07, 2019, 02:31:54 pm
Your going to have to check the outputs with your scope.  It sounds like the 5v high isn't reaching or maintaining 5v.  With the shorter pulses of a positive sync, the monitor might see the signal better meaning the signal is still operating at the edge of functionality.  For now, just use a positive sync unless you want to scope your 74xxx CMOS buffer's output.
Do you have you CMOS buffer's output tied 4 in parallel like I recommended to give you a higher current drive?  If you monitor have 75ohm load on the sync signals instead of 1kohm, it also may have a high level of around 4v instead of 5v.
Is your vsync also going through the buffer the same way?
Post by: nockieboy on November 07, 2019, 03:30:23 pm
VSYNC and HSYNC are both unchanged in that they're both going through the buffer as before.
One thing is that I'm only using one output from the buffer for HSYNC and VSYNC.  Might try the multiple-parallel outputs and see if that improves the image with inverted sync signals then!  :-/O
Oh, I'm also dabbling with trying to build a character generator and am fast realising I know nothing about how to interface a block with a memory block etc...  :o
EDIT:
Yes, that sorted it.  I've only used two outputs per sync signal for the moment, but it's working fine inverted now with no misbehaviour.  :-+
Post by: jhpadjustable on November 07, 2019, 03:57:13 pm
You need Verilog's memory syntax. (ETA: oops, it's not a keyword)
reg [7:0] mem [127:0];
always @ (posedge clk) begin
  if (we)
    mem[write_address] <= d;
  q <= mem[read_address]; // q doesn't get d in this clock cycle
end
Note well, that's a non-blocking assignment so adjust your time machine accordingly.
Recommended HDL coding styles handbook (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii51007.pdf), p13 and on, for more examples.
Post by: nockieboy on November 07, 2019, 03:58:14 pm
Okay, so for a character generator, this is what I'm thinking:
Replace the vid_pattern_generator with a vid_char_generator.  It will share all the inputs and outputs of the vid_pattern_generator, but with some extras:
This will allow the vid_char_generator to compute the current tile address from the internally-generated x & y coordinates, send that address to the video memory and receive a character index back.
Then it will compute a pixel address for that character in the character memory, based on the character index and current x & y coordinates, which will return a single bit of information based on whether the current pixel is background- or foreground-coloured depending on the character in that tile....  Does that make sense?  Am I over-complicating it, because there seems like a lot going here?  :scared:
I would load a font file (OSD_FONT.MIF) and LUT (osd_mem.mif) into the character memory and, initially at least, the video memory will be garbage - but populating that with useful data is a few steps away yet.
I'm a little confused looking at osd_generator.v, but then I don't have a good map in my head of what should be happening here anyway, so understanding it is proving difficult.
Post by: jhpadjustable on November 07, 2019, 04:48:51 pm
  • An 8-bit data input from video memory.
  • A xx-bit address to video memory.
  • A CE (chip enable) to video memory.
  • An xx-bit address output to character memory.
  • An 1-bit data input from character memory.
  • A CE to character memory.
CE is only relevant in discrete implementations where the memory needs to be kept from driving a shared bus. Here, memory is always chip-enabled and you just have write-enables and maybe read-enables. Or, if you prefer to have the tool infer memory from generic HDL, you only have write-enables and are always reading every clock. If you want to hold read data, add your own register.
No, that's about the size of it. Now you see why I was encouraging you to do a plain old framebuffer to start :)
Block RAMs are commonly used in synchronous mode, which means you'll have a one-cycle delay through each memory. You can get ahead of it such as by reading the next character index or bitmap ahead of time and buffering the data, or you can push other business back such as by applying a two-clock delay to the display enable to the rest of the display system. If you want to give yourself something other than garbage or nothing to stare at, use an initial task to preload a character bitmap or two and to fill the text memory with something. Writing this from sleep-deprived memory:
initial begin
  integer i;
  for (i=0; i<255; i++) begin
    charmem[0+i*8] = 8'b00010000 ^ {i[0]{8}}; // invert top half according to bit 0 of tile index
    charmem[1+i*8] = 8'b00101000 ^ {i[0]{8}}; // to give you an easy way to see if you're
    charmem[2+i*8] = 8'b01000100 ^ {i[0]{8}}; // actually reading the tile map
    charmem[3+i*8] = 8'b10000010 ^ {i[0]{8}};
    charmem[4+i*8] = 8'b11111110 ^ {i[1]{8}}; // invert bottom half according to bit 1 of tile index
    charmem[5+i*8] = 8'b10000010 ^ {i[1]{8}};
    charmem[6+i*8] = 8'b10000010 ^ {i[1]{8}};
    charmem[7+i*8] = 8'b00000000 ^ {i[1]{8}};
  end
end
initial begin
  integer i;
  integer j;
  for(i=0;i<80;i=i+1)
    for(j=0;j<25;j=j+1)
      tilemap[i] = i + j;
end
I'm using byte-wide memory here because it's easier to illustrate. You can select just one bit of the read port for output by [x[2:0]] bit-selecting the output wire or reg (but not the memory directly, iirc).
Post by: nockieboy on November 07, 2019, 10:33:17 pm
Ah yes, of course - makes sense.
You're not kidding!  ???
I think I understand the concept now though - I just need to get my head around making the right connections in Quartus and setting the memory up properly.  There's a template for new memory objects in the New.. menu, but then on a website I found some code that I've re-purposed into this:
module ROM_font (
input [11:0] address,
output [7:0] data,
input wire read_en
reg [7:0] mem [0:8192];
assign data = (read_en) ? mem[address] : 8'b0;
initial begin
$readmemb("OSD_FONT.MIF", mem);
end
endmodule
This should read a file in the project (borrowed from BrianHG's altera_osd_20kbit files) which contains the character definitions into memory.  Except I don't think it's loading it into memory - I think it's loading into hardware, so it's creating a 'ROM' in the sense that it can't be written to, but I get the feeling it's an extremely wasteful way of doing it.   Please correct me if I'm wrong.  Isn't there a megafunction or wizard of some kind I need to use to create a RAM/ROM area, or does Quartus do this for me by inferring my intentions from the code?
Yes, I could read a file into memory like with the font file above. I thought the RAM would contain random values, so I wouldn't have to load anything initially to see something come out on the screen... is that not the case then?  Is RAM pre-initialised to zeros or something?
Would it be better to return a byte (an entire row from the selected character) and bit-select from that returned value, or configure the 'ROM' to just return the bit in question pointed to by x & y?  What's the difference in terms of the 'ROM' code?  Is it as simple as:
module ROM_font {
    output [7:0] data,
... to return a byte, or:
module ROM_font {
    output data,
... to return a bit?
Post by: BrianHG on November 08, 2019, 03:14:52 am
EDIT:
Ok, if 1 x 74AC/HC CMOS buffer was on the line when using negative sync to drive the monitor cables, and 2 in parallel work with any sync polarity, can you see why I said 2 pages ago, 'USE 3 CMOS BUFFERS in parallel....'  Your monitor appears to have a 75 Ohm termination resistor on it's sync lines and they might be using a schmitt trigger meaning that the drive would need to clear almost 4v by the time it reaches the monitors internal circuitry...  If you are now using 2, go to 3, otherwise, on a warm day, when your 74AC/HC CMOS buffer warms up, and it's drive switch resistance drops a bit, of your 5v power supply may be a still valid 4.75v, you will wonder which your monitor's picture has begun to get interference.  Your other choice is to use a single line driver buffer designed to drive a 25ohm load, or a transistor buffer.  With one of those, the sync signal will reach your monitor with the full 0-5v swing.
Post by: BrianHG on November 08, 2019, 03:26:03 am
Show me your code.  You may have your X&Y counter outside the:
         begin
Meaning it may be running at 50MHz instead of 25MHz.
Post by: jhpadjustable on November 08, 2019, 04:40:43 am
You can use the generic HDL to be portable, or you can instantiate and configure vendor modules to get vendor features, or you can use the megawizard to configure the vendor modules to get vendor features and pointy-clicky satisfaction. Mostly, it's a style matter. Quartus will indeed infer your block RAM intentions if your code walks, talks, and quacks enough like a duck. If not, you can use a ramstyle pragma to specify the style of RAM you want to use. https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#hdl/vlog/vlog_file_dir_ram.htm (https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#hdl/vlog/vlog_file_dir_ram.htm)
That ROM_font module has two big problems: one, it is asynchronous. From p15 of the coding style handbook: "Because memory blocks in the newest devices from Altera are synchronous, RAM designs that are targeted towards architectures that contain these dedicated memory blocks must be synchronous to be mapped directly into the device architecture. For these devices, asynchronous memory logic is implemented in regular logic cells." Two, it is sized incorrectly. Specify memory sizes in words rather than bits, much as you would a two-dimensional array, but mind the off-by-one error. 256 tiles of 16 rows each would be sized as reg [n:0] mymemory [0:(256*16)-1] regardless of the register width n.
I think it's customary that block RAMs are initialized to zero upon power-up unless otherwise specified. In simulation, block RAMs are usually initialized to X so that you can see when you're reading from memory that you haven't written to (whether initially or in your logic) and trace how far the consequences reach.
I suggest byte-wide character bitmap "ROM" and external bit-selection with a look toward the future. If you decide to make the character bitmap block writable by the host, synthesis won't have to try to infer a dual-port RAM with dissimilar widths on each port, and won't have to guess/decide a possibly incorrect bit-endianness, because you will have specified it explicitly in logic. Whether you bit-select inside or outside the ROM_font module is a matter of style. Personally, I'd treat the x8 ROM as a x8 ROM all round and do the assign bit_out = rom_font_data[~xpos[2:0]]; outside of the ROM_font module, in case you might eventually reuse the bit selector for the frame buffer. That said, I've not done HDL projects too much larger than this, so FPGA old hands feel free to roast me if I'm doing it wrong.  :popcorn:
Post by: BrianHG on November 08, 2019, 05:02:38 am
Ok, I've cleaned up my OSD generator, commented on everything and it gives a much better starting point.
We will make changes to make things better and touch up the font into standard 8 bit bytes, but as an introduction, this shows how the basics of how one of Intel's memory function is called and configured.
module osd_generator ( clk, pc_ena, hs_in, vs_in, osd_ena_out, osd_image, hde_out, vde_out, hs_out, vs_out,
wren_disp, wren_font, wr_addr, wr_data );
// To write contents into the display and font memories, the wr_addr[15:0] selects the address
// the wr_data[7:0] contains a byte which will be written
// the wren_disp is the write enable for the ascii text ram.  Only the wr_addr[8:0] are used as the character display is 32x16.
// the wren_font is the write enable for the font memort.  Only 2 bits are use of the wr_dataa[1:0] and wr_addr[12:0] are used.
// tie these ports to GND for now disabling them
input  clk, pc_ena, hde_in, vde_in, hs_in, vs_in ;
output osd_ena_out ;
reg    osd_ena_out ;
output [2:0] osd_image ;
output hde_out, vde_out, hs_out, vs_out;
input wren_disp, wren_font;
input [15:0] wr_addr;
input [7:0] wr_data;
reg   [9:0] disp_x,dly1_disp_x,dly2_disp_x;
reg   [8:0] disp_y,dly1_disp_y,dly2_disp_y;
reg   dena,dly1_dena,dly2_dena,dly3_dena,dly4_dena;
reg   [7:0] dly1_letter, dly2_letter;
reg   [7:0] hde_pipe, vde_pipe, hs_pipe, vs_pipe;
wire [12:0] font_pos;
wire [8:0]  disp_pos;
wire [2:0]  osd_image;
parameter   PIPE_DELAY =  4;   // This parameter selects the number of pixel clocks which the output VDE and syncs are delayed.  Only use 2 through 9.
// LPM_RAM_DP Quartus dual port memory function
wire [7:0] sub_wire0;
wire [7:0] letter = sub_wire0[7:0];
// w access = 'b1100000a aaaaaaaa
altsyncram altsyncram_component_osd_mem ( .wren_a ( wren_disp ), .clock0 (clk), .clock1 (clk), .clocken1 (pc_ena),
.address_a (wr_addr[8:0]), .address_b (disp_pos[8:0]),
.data_a (wr_data[7:0]), .q_b (sub_wire0));
defparam
altsyncram_component_osd_mem.intended_device_family = "Cyclone",
altsyncram_component_osd_mem.operation_mode = "DUAL_PORT",
altsyncram_component_osd_mem.width_a = 8,
altsyncram_component_osd_mem.widthad_a = 9,
altsyncram_component_osd_mem.width_b = 8,
altsyncram_component_osd_mem.widthad_b = 9,
altsyncram_component_osd_mem.lpm_type = "altsyncram",
altsyncram_component_osd_mem.width_byteena_a = 1,
altsyncram_component_osd_mem.outdata_reg_b = "CLOCK1",
altsyncram_component_osd_mem.indata_aclr_a = "NONE",
altsyncram_component_osd_mem.wrcontrol_aclr_a = "NONE",
altsyncram_component_osd_mem.address_aclr_a = "NONE",
altsyncram_component_osd_mem.address_reg_b = "CLOCK1",
altsyncram_component_osd_mem.address_aclr_b = "NONE",
altsyncram_component_osd_mem.outdata_aclr_b = "NONE",
altsyncram_component_osd_mem.ram_block_type = "AUTO",
altsyncram_component_osd_mem.init_file = "osd_mem.mif";
wire [1:0] sub_wire1;
wire [1:0] osd_img = sub_wire1[1:0];
// w access = 'b111aaaaa aaaaaaaa
altsyncram altsyncram_component_osd_font ( .wren_a ( wren_font ), .clock0 (clk), .clock1 (clk), .clocken1 (pc_ena),
.address_a (wr_addr[12:0]), .address_b (font_pos[12:0]),
.data_a (wr_data[1:0]), .q_b (sub_wire1));
defparam
altsyncram_component_osd_font.intended_device_family = "Cyclone",
altsyncram_component_osd_font.operation_mode = "DUAL_PORT",
altsyncram_component_osd_font.width_a = 2,
altsyncram_component_osd_font.widthad_a = 13,
altsyncram_component_osd_font.width_b = 2,
altsyncram_component_osd_font.widthad_b = 13,
altsyncram_component_osd_font.lpm_type = "altsyncram",
altsyncram_component_osd_font.width_byteena_a = 1,
altsyncram_component_osd_font.outdata_reg_b = "CLOCK1",
altsyncram_component_osd_font.indata_aclr_a = "NONE",
altsyncram_component_osd_font.wrcontrol_aclr_a = "NONE",
altsyncram_component_osd_font.address_aclr_a = "NONE",
altsyncram_component_osd_font.address_reg_b = "CLOCK1",
altsyncram_component_osd_font.address_aclr_b = "NONE",
altsyncram_component_osd_font.outdata_aclr_b = "NONE",
altsyncram_component_osd_font.ram_block_type = "AUTO",
altsyncram_component_osd_font.init_file = "osd_font.mif";
//  The disp_x is the X coordinate counter.  It runs from 0 to 512 and stops there
//  The disp_y is the Y coordinate sounter.  It runs from 0 to 256 and stops there
assign disp_pos[4:0]  = disp_x[8:4] ;  // The disp_pos[4:0] is the lower address for the 32 characters for the ascii text.
assign disp_pos[8:5]  = disp_y[7:4] ;  // the disp_pos[8:5] is the upper address for the 16 lines of text
//  The result from the ascii memory component 'altsyncram_component_osd_mem'  is called letter[7:0]
//  Since disp_pos[8:0] has entered the read address, it takes 2 pixel clock cycles for the resulting letter[7:0] to come out.
//  Now, font_pos[12:0] is the read address for the memory block containing the font memory
assign font_pos[12:6] = letter[6:0] ;       //  Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
assign font_pos[2:0]  = dly2_disp_x[3:1] ;  //  select the font X coordinate with a 2 pixel clock DELAYES disp_x address.  [3:1] is used so that every 2 x pixels are repeats
assign font_pos[5:3]  = dly2_disp_y[3:1] ;  //  select the font y coordinate with a 2 pixel clock DELAYES disp_y address.  [3:1] is used so that every 2 y lines are repeats
//  The resulting font image, 2 bits since I made a 2 bit color atari font is assigned to the OSD[1:0] output
//  Also, since there is an 8th bit in the ascii text memory, I use that as a third OSD[2] output color bit.
assign osd_image[1:0] = osd_img[1:0];
assign osd_image[2]   = dly2_letter[7];  // Remember, it takes 2 pixel clocks for osd_img[1:0] data to be valid from read address letter[6:0]
                                         // so, if we want to use letter[7] as an upper color bit, is needs to be delayed 2 pixel clocks so it will be parallel with the osd_img[1:0] read data
always @ ( posedge clk ) begin
if (pc_ena) begin
// *** Create a serial pipe where the PIPE_DELAY parameter selects the pixel count delay for the xxx_in to the xxx_out ports
hde_pipe[0]   <= hde_in;
hde_pipe[7:1] <= hde_pipe[6:0];
hde_out       <= hde_pipe[PIPE_DELAY-2];
vde_pipe[0]   <= vde_in;
vde_pipe[7:1] <= vde_pipe[6:0];
vde_out       <= vde_pipe[PIPE_DELAY-2];
hs_pipe[0]    <= hs_in;
hs_pipe[7:1]  <= hs_pipe[6:0];
hs_out        <= hs_pipe[PIPE_DELAY-2];
vs_pipe[0]    <= vs_in;
vs_pipe[7:1]  <= vs_pipe[6:0];
vs_out        <= vs_pipe[PIPE_DELAY-2];
// This OSD generator's window is only 512 pixels by 256 lines.
// Since the disp_X&Y counters are the screens X&Y coordinates,
// I'm using an extra most significant bit in the counters to determine if the
// OSD ena flag should be on or off
if (disp_x[9] || disp_y[8]) dena <= 0;  // When disp_x > 511 or disp_y > 255, then turn off the OSD's output enable flag
else dena <= 1;                         // otherwise, turn on the OSD output enable flag.
if ( ~vde ) disp_y[8:0] <= 9'b111111111;  // preset the disp_y counter to max while the vertical display is disabled
  else if (hde_in && ~hde_pipe[0]) begin      // isolate a single event at the begining of the active display area
disp_x[9:0] <= 10'b0000000000; // clear the disp_x counter
if (!disp_y[8] | (disp_y[8:7] == 2'b11)) disp_y <= disp_y + 1;  //  only increment the disp_y counter if it hasn't reached it's end
end else if (!disp_x[9]) disp_x <= disp_x + 1;  // keep on addind to the disp_x counter until it reaches it's end.
// *** These delay pipes registers are explaines in the 'assign's above.
dly1_disp_x <= disp_x;
dly2_disp_x <= dly1_disp_x;
dly1_disp_y <= disp_y;
dly2_disp_y <= dly1_disp_y;
dly1_letter <= letter;
dly2_letter <= dly1_letter;
dly1_dena   <= dena;
dly2_dena   <= dly1_dena;
dly3_dena   <= dly2_dena;
dly4_dena   <= dly3_dena;
osd_ena_out  <= dly2_dena; // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown
                           // It needs to be delayes by the number of pixel clocks required for the above memories
end // ena
end // always@clk
endmodule
Before we make changes like addressing 80 columns, addressing anywhere withing a chunk of ram, I'll fetch out my palette and overlay generator which goes with this OSD generator.  This will allow you to simultaneously run your pattern generator and superimpose the OSD generator on top, with a semi transparent layer in the font and a palette for the font colors.  For now, you can just wire the 'OSD[2:0]' output's bits 0 to your r&g&b outputs.
Hint, in the block diagram editor, double click on a blank area and type 'WIRE'.  Place these on your schematic and label on the left the buss name and number of my OSD outputs and on the right place a wire and label your RGB pins names.
Also, for the write memory inputs, on the block diagram editor, double click on a blank area, and type GND, and insert 3 GND symbols and tie them to the inputs on the OSD generator module.
The osd text memory block .mif should contain a display font test text of all the characters.  You and edit the file in quartus to make it say anything you like.
Note: After the palette and we will tackle a true memory address generator which will allow text windows of any Z-size by any Y-size, pointing to any memory base address, with a hidden overscan or any text columns width.  Plus, variable X&Y font size and 16 foreground by 16 background colors, paletted and programable for each letter on the display.  We will also be embedding the font memory into the same memory as the ascii text ram which will also be you main 8bit cpu ram as well.  There should be no problem implementing the 256 color graphics as well, but, the resolution window will be puny and we might need to forgo it's palette.
ALSO: I need to you increase your output pixel bits to 4 for each R,G,B, that's 12 bit color, or,  4096 colors.  Do not erase your pattern generator, we will be still bringing it back soon for additional tests.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on November 08, 2019, 07:36:10 am
Yes, I'm going there.... I just want the OP to take a few steps inbetween since we will soon be having either an 8bit or 16bit wide dual port ram which will be sized to the maximum the FPGA can handle (parameter configurable so larger FPGA will also work), and the display text, font, text color, and a universal graphics mode will have a base pointer in that same ram which is loaded during the v-sync.  A string of bytes from that base pointer will be loaded into control registers containing all the graphics control metrics, updated every h-sync, making a fully programable display pretty much on par with a Super Nintendo, except with support for 640x480 in the text mode and 4 color bitplane graphics mode.  These functions, really just 2 counters with a variable increment at the end of each line, will include text rows/video modes with a programmable width which may be wider than the entire display screen.
First we needed enough to get his project running the pixel clock at 4x, 100MHz, yet with a 25MHz pixel out while verifying the characters and background graphics were scaling correctly without error & his graphics rendering pipe was functional.
In the future, if the OP wishes to upgrade to external DRAM, that 1 memory block will need to be converted into a cache memory for the external ram and the constructed image will need pre-fetching a line of video in advance.  This one gets nasty.
Post by: nockieboy on November 08, 2019, 10:21:35 am
I'm not deliberately ignoring advice, just trying to make do with the bits I have to hand - namely, a shortage of very short linking wires for the breadboard the sync driver is plugged into.  ::)  As usual for a beginner, I made do with two parallel outputs, found it worked and stopped there.  Have upped my game now and got three parallel outputs driving each sync signal now.  :-+
I've also got a bit of a loose connection somewhere... the fuzzy column edges and blinking came back earlier, but I suspect a bad connection on the breadboard around the driver output as some finger poking around that area sorted it.  :-/O  Can't wait for the EP4C dev board to arrive - that has a built-in VGA port and will help me focus entirely on the HDL development.
         begin
Ah yes, the x and y counters were outside the if (p_ena) conditional.  :palm:  I'll attach my code at the bottom of this post anyway, for the sake of having an archive of it if nothing else.
Speaking of which, I've got a string of folders (currently on number 4) for this project, at various stages.  I think I might just run with this current project now and get it onto github.  I had an accident earlier where I deleted a file I thought I didn't need anymore, and it turned out to be the current sync_generator file.  Had to go back to a previous post and use the cleaned-up code you'd posted to re-create the file again.  Repo is up on github (https://github.com/nockieboy/microcom_gpu) if you want the latest files.
No problemo, will stick to generic HDL as much as possible then - I was just getting confused between the output from a wizard and (what appears to me to be) very basic HDL code to create a memory block.
That ROM_font module has two big problems: one, it is asynchronous... Two, it is sized incorrectly. Specify memory sizes in words rather than bits, much as you would a two-dimensional array, but mind the off-by-one error. 256 tiles of 16 rows each would be sized as reg [n:0] mymemory [0:(256*16)-1] regardless of the register width n.
Ah okay, I should go read those documents a little more closely.  I suspect this is a moot point anyway as BrianHG is clearly working to a plan and this will get covered soon.
Thanks again BrianHG - I'll spend some time looking at this today.
Righto, no problem - so I should be able to get this working at 32x16 as it is...  :o
Aye carumba! This is going to be MUCH better than the plain old 'white on black' text mode, maybe with a splash of colour, that I was thinking of...  ;D
Okay, off to go work on this...
Post by: BrianHG on November 08, 2019, 11:30:28 am
Now, for a little more pushing... Once you have integrated my latest OSD generator, and get it working, the next step will be to modify the current 2 bit , 2 color per pixel font memory into a 1 bit color, 8 bit wide font memory.  I've attached a new Atari font which is formatted the way @jhpadjustable likes it.  This means you need to adjust the read addresses, size and location, and at the 8 bit data output, you need to make an immediate 8:1 mux selector to draw the 1bit font image.
The new font files I've attached are in 2 formats.
#1, "osd_font_8x8bit_128char.mif", A quartus .mif format file which is internally used for it's built in LPM_RAM_DP / AltSyncram function.
#2, "osd_font_8x8bit_128char.rom" A raw binary file which is a raw 8 bit binary dump of the Atari font.  Quartus can also use these, however 10 years ago, the feature had bugs so I convert the binaries to .mif and use them that way in quartus.
You will need to change the AltSyncram function I used in the OSD generator.  Read up on Quartus' library function for that memories controls as you need to change everything to 8bit data.  This step will allow us to combine both the character and font memory into 1 large continuous ram block for your Z80 to access.
Show me first the current character generator working, then you will need to modify the font memory into 8bit wide, monochrome color mode and verify that is also working properly.
Your next step after this will be both the merge and making the new ram block have 5 dedicated read ports running at the 25MHz pixel clock speed.  This means the ram is running at 125MHz and you have a 5 muxed address in and 5 muxed/latched datas out while the second port on the ram will now be a read/write port which will be dedicated to the Z80 and way int the future, perhaps some graphics acceleration functions.
VERY Important, each step of the way, keep track of your FMAX!!!  If a piece of code you generate along the way kills it below 150Mhz approximately, find out why and ask questions.  Because, if you go too far with a 75MHz FMAX, it may be tedious to fix the problem lateron.
Post by: BrianHG on November 08, 2019, 11:43:34 am
Nope, even with your current FPGA, you will achieve a font display with 16 foreground + 16 background colors, with 4096 paletted colors and 16 translucency levels! as your text mode will be superimposed on top of the bitplane and 256 color graphics mode which also have a programmable 4096 colors for each of those 256 paletted colors.  Yes, the letters color palette will set different levels of translucency for both the font's foreground and background.  This means 16 stage fading just by manipulating the font's palette.  All this with 80 column x 60 rows, all within 16kb.  Wait a sec, does your FPGA have 16kb?  If not, oh well, we'll use 40x30 mode for now and you will only need 4kb for now.
Each line of text will have X&Y pixel sizes of 1,2,3,4 pixel/line.  Basically a separate X&Y scale size.  Same goes for the bitplane and 256 color graphics modes.  And yes, the graphics have their own separate palette too....
Post by: nockieboy on November 08, 2019, 12:09:39 pm
@BrianHG
Just had to make a couple of corrections to osd_generator to get it to successfully compile a symbol file:
1) hde_in, vde_in added to ports in first line
2) Declared hde_out, vde_out, hs_out and vs_out as regs as they're given blocking assignments in an always in lines 130 onwards
3) Line 160 - if ( ~vde ) - changed to if ( ~vde_in )
I think I've done what you've asked correctly...  ???
But osd_mem.mif should show something, right?  Should show all the ASCII chars on the screen, in theory?  I'm just getting a blank screen - no text at all, all black (at least it's not going into standby)?
Ah, will this cause the issue above then?  I haven't done it yet - my output is restricted to 1-bit colour at the moment as I'm still using the 220R resistors in series with the R, G and B outputs.
Here's my current setup:
[attach=1]
Post by: BrianHG on November 08, 2019, 12:21:42 pm
You forgot to add a buss wires on the:
osd_image[2..0] output, and on that bus, write the label 'osd_image[2..0]'
Quartus will not associate the labels on your wires unless you tie them to a block diagram's IO somewhere with the same name.  It does this since you may name these buss wires anything, not necessarily the internal verilog names.
As for the rgb_in[1], again, you need to add a bus wires on the stencil's input and add rgb_in[1..0]'
Add 3 more wire symbols after the rgb_in[1] wires and add the rgb_in[0] wires shorting the 2 together to generate a full brightness image. Or, you can wire the 'osd_ena_out' into all 3 'rgb_in[0]' instead.  This will generate a differenct luminance located where the the OSD character generator is active.
ALSO, use a different osd_image[ # ] for each red,green,blue.
Post by: nockieboy on November 08, 2019, 12:50:25 pm
Oh wow - yes, got an output now:
[attach=1]
Not sure it's aligned correctly - perhaps needs to move right and down by 3 pixels in each axis?
I'm guessing the vertical bars are because the 32 vertical lines have been exceeded?
D'oh.  I thought Quartus would link the wires on the Wire to the correct block IO, but I guess several blocks could all have the same IO names...
The outputs for r[0]. g[0] and b[0] aren't connected to anything yet.  I'll need to set up a resistor ladder to make use of those outputs.  I'll put that on my to-do list.  ;)
Spot on.  The first time I ran it on the FPGA I just got a white screen.   :-+
Post by: BrianHG on November 08, 2019, 01:01:31 pm
To fix the OSD outline, change the first 3 'WIRE' symbols you have to 2 INPUT AND gates.  Wire 1 input of each and gate to exactly what you have now, and, wire the second of each and gate's input to the OSD generators 'osd_ena_out' signal.
This will mute the OSD output's image when outside the active 32x16 box.
Also, I think your monitor might need the H and V size adjusted.  I thought my OSD generator had perfect alignment.
(This wouldn't be a problem with DVI...)
This originally was a superimposed window as a debug screen for my video enhancer project.
Post by: nockieboy on November 08, 2019, 01:34:18 pm
Looking better already.  ;D
[attach=1]
 :palm:
Of course.. Auto-adjust fixed it straight away. There I was going straight for the complex problems, thinking it was a timing problem...  :-DD
Right, I've put together a 2-bit resistor ladder, so I now have 2-bit RGB output.
Post by: BrianHG on November 08, 2019, 01:52:46 pm
LOL.... Live and learn...
Anyways, the next step.  Now you will need to understand my OSD code.  You will recognize that except for the way I made the 2bit font, it pretty much operates as you figured all along except for those piped delays to match after the first ram's read's contents are ready, the next one being the font image lookup, has it's x&y pointers delayed so they come in parallel with the contents of the text memory.
Now, I want you to change my font ram weird 2 bit color into an 8 bit wide font, now only B&W.  Use the new 8bit wide font I posted 7 messages up.  Try to get it to work properly.  It should fit in easily, though, you will need to mux select 8:1 the output at the right position.  Your output image should now be 2 bit color.  1 bit B&W for the font, and 1 bit for the MSB, bit 7, in the character memory.  Let's see if you can keep everything perfectly pixel aligned.
Also take note of your current FMAX...
Also, copy the osd.c module into a new name and work with that one in the same project so you can swap modules to verify alignment.
Post by: nockieboy on November 08, 2019, 05:17:24 pm
Going to take this slowly, as that's how my mind works..  :o ;D
So here's my first attempt:
module vid_osd_generator ( clk, pc_ena, hde_in, vde_in, hs_in, vs_in, osd_ena_out, osd_image, hde_out, vde_out, hs_out, vs_out,
// the wren_font is the write enable for the font memory.  Only 2 bits are used of the wr_data[1:0] and wr_addr[12:0] are used.
input  clk, pc_ena, hde_in, vde_in, hs_in, vs_in;
output osd_ena_out;
reg    osd_ena_out;
output [2:0] osd_image;
reg hde_out, vde_out, hs_out, vs_out;
wire [9:0] font_pos;
parameter   PIPE_DELAY =  4;   // This parameter selects the number of pixel clocks to delay the VDE and sync outputs.  Only use 2 through 9.
// SCREEN TEXT MEMORY
defparam
altsyncram_component_osd_mem.intended_device_family = "Cyclone II",
// FONT MEMORY
wire [7:0] sub_wire1;
wire [7:0] char_line = sub_wire1;
.address_a (wr_addr[12:0]), .address_b (font_pos[9:0]),
.data_a (wr_data[7:0]), .q_b (sub_wire1));
defparam
altsyncram_component_osd_font.intended_device_family = "Cyclone II",
altsyncram_component_osd_font.width_a = 8,
altsyncram_component_osd_font.width_b = 8,
altsyncram_component_osd_font.widthad_b = 10,
altsyncram_component_osd_font.init_file = "osd_font_8x8bit_128char.mif";
//  The disp_y is the Y coordinate counter.  It runs from 0 to 256 and stops there
// Get the character at the current x, y position
//  Now, font_pos[12:0] is the read address for the memory block containing the character specified in letter[]
assign font_pos[9:3] = letter[6:0] ;       // Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
assign font_pos[2:0] = dly2_disp_y[3:1] ;  // select the font y coordinate with a 2 pixel clock DELAYED disp_y address.  [3:1] is used so that every 2 y lines are repeats
// get the pixel from the x position within the character
//  The resulting 1-bit font image at x is assigned to the OSD[0] output
//  Also, since there is an 8th bit in the ascii text memory, I use that as a second OSD[1] output color bit
assign osd_image[0] = char_line[dly2_disp_x[0]];
assign osd_image[1] = dly2_letter[7];  // Remember, it takes 2 pixel clocks for osd_img[1:0] data to be valid from read address letter[6:0]
if (pc_ena) begin
// Since the disp_X&Y counters are the screens X&Y coordinates, I'm using an extra most
// significant bit in the counters to determine if the OSD ena flag should be on or off.
else
if (~vde_in)
end
// *** These delay pipes registers are explained in the 'assign's above
dly1_dena   <= dena;
// It needs to be delayed by the number of pixel clocks required for the above memories
end // ena
end // always@clk
endmodule
But it wont compile - I'm stuck on this error:
Error (12152): Can't elaborate user hierarchy "vid_osd_generator:inst2|altsyncram:altsyncram_component_osd_font"
EDIT:
Oh hang on.  I've found a few more errors that may clear this up... watch this space.
EDIT 2:
I've changed altsyncram_component_osd_font as follows:
.address_a (wr_addr[9:0]), .address_b (font_pos[9:0]),
Still getting errors:
Error (272006): In altsyncram megafunction, when OPERATION_MODE parameter is set to DUAL_PORT, total number of bits of port A and port B must be the same
Error (287078): Assertion error: The current megafunction is configured for use with the clear box feature and cannot be used when the clear box feature is disabled
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 3 errors, 15 warnings
Error: Peak virtual memory: 4601 megabytes
Error: Processing ended: Fri Nov 08 17:20:59 2019
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02
Error (293001): Quartus II Full Compilation was unsuccessful. 5 errors, 15 warnings
EDIT 3:
Fixed the first error:
wire [7:0] char_line = sub_wire1[7:0];
.data_a (wr_data[7:0]), .q_b (sub_wire1);
All fixed now.  Time to see if it works... ;)
Post by: nockieboy on November 08, 2019, 05:41:19 pm
Yeah, that's not working as intended....
EDIT: Just had a hell of a time trying to attach that image - put it at the bottom in the end instead of inline, as the 'edit message' form was just not working!
Here's the current code:
output osd_ena_out;
reg    osd_ena_out;
defparam
// FONT MEMORY
defparam
altsyncram_component_osd_font.widthad_a = 10,
if (pc_ena) begin
else
if (~vde_in)
end
dly1_dena   <= dena;
end // ena
end // always@clk
endmodule
Post by: Berni on November 08, 2019, 06:52:41 pm
Nice work there
Post by: nockieboy on November 08, 2019, 07:19:58 pm
Okay, I realised I was only passing a single bit to char_line to get the x position within the character, so now it's passing the 8-bit x position value.  But the characters were reversed in the x-axis on the screen, so I made the following change:
assign osd_image[0] = char_line[(8 - dly2_disp_x[2:0])];
... and now I'm getting this:
[attach=1]
It's printing every character twice... with some errors at the right hand edge (the last column of the last character on the screen is duplicated once).
EDIT:
Fixed the right-hand edge duplication of the last character column by adding in another delay for x:
dly3_disp_x <= dly2_disp_x;
Just got to sort the duplication of each character now...
Post by: nockieboy on November 08, 2019, 07:45:10 pm
All sorted.  Just needed me to use bits 3:1 in x rather than 2:0 to prevent the duplication of characters - remembered you'd written something about that in the notes somewhere.  Removed the additional delay as it's no longer needed.  :-+
[attach=1]
Post by: BrianHG on November 09, 2019, 12:33:13 am
Good show  :-+ .  You see all the comments I've added to Verilog code are a must read.
Now:
1) please post the final OSD code so I can proof the working version.
2) Will you be working on the code this weekend? What time?
3) What is you current FMAX?  Which FPGA part# are you using?
Next steps:
1.  Set up the PLL to give you a 125Mhz clock.  This means we will change the PC_ENA coming out of your 'sync_generator' into a 4 bit number with a parameter in the sync generator which selects the maximum count of 4, then resets to 0.  All the attached graphics modules which had 1 wire input PC_ENA will now need PC_ENA[3:0], and all the if (PC_ENA) will change to if (PC_ENA[3:0] == 0).
What we have done here is make you system clock 5x speed, yet divide your pixel clock down to 1/5.  We chose 5 as a magic number and included feeding the PC_ENA full 4 bit phase throughout your design for 2 reasons:
     a) since when you eventually incorporate DVI inside the FPGA, the serial shift out clock is 10x the pixel clock and having the FPGA system feed a DDR IO with 125MHz, you get your 250megabit per second serializer clock with any FPGA, no fancy dedicated hardware serializers.
     b) We will be dedicating memory access time slots during those 5 points, so it is useful to have those 4 bits to allot synchronous events.  Also, the 16$ 2megabit ram lattice part is fast enough to run the entire core at 10x 250MHz, so having the 4 bit PC_ENA, you may just then change that clock divide parameter from 4 to 9 giving you 10 access slots per pixel output.
We should plan what time we are doing this if it is on the weekend...
Next step #2:  Copy and rename the OSD generator to graphics generator.  You will remove both dual port 'altsynccrams' and replace it with a new verilog module 'multiport_gpu_ram.v'.  In your new 'multiport_gpu_ram.v' you will place a single 'altsynccrams' which is 4Kilobytes, and you will make IO registers for:
5 read addressed [20 bit] (Your graphics system will handle a maximum 1 megabyte frame buffer), 5 auxiliary read commands[8bit], 5 data output[8bit], 5 passed through read addresses and 5 passed through auxiliary read commands, all synchronous to the PC_ENA[3:0] position 0, an active pixel cycle.  (WE WILL BEGIN by only specifying the IOs and their functions in the .v module and make sure you understand what everything if for as from this point on, you will be coding everything yourself...)
And IO wires for the second port on the synccram READ/WRITE port for 1 R/W address[20bit] 1 write enable[1 wire], data in[8bit], data out[8bit].  This port is for the Z80, and in future, advanced GPU accelerated processing function (blitter).
Inside the 'multiport_gpu_ram.v', you will have another module 'gpu_dual_port_ram_INTEL.v', where inside that one I'll show you how to configure Quartus' LPM_dualport ram/altsynccram.  This one verilog module, 'gpu_dual_port_ram_INTEL.v'  will change between XILINX & LATTICE as their dual-port memory function blocks have their own setup and parameters written out differently, but function identically.  Other than PLL settings, everything else we have in your GPU project will cross compile in all FPGA vendor 3 ecosystems as our verilog code is 'basement' level.  If the other compilers cant cope with this project, it is their fault...
Post by: jhpadjustable on November 09, 2019, 03:57:59 am
Do you see the off-by-one error in this code? You'd do well to learn the bitwise operators (https://www.nandland.com/verilog/examples/example-bitwise-operators.html) and start thinking in binary. Especially the unary ~ operator, same as in C.
Post by: BrianHG on November 09, 2019, 04:47:49 am
He had 2 errors, 1 was that my routine was setup for every 2 pixels to be the same, so, disp_x[2:0] should have been disp_x[3:1].  Next, the '8-' should have been '7-'.  As for the 'dly2_disp_x[]', it should actually be 'dly4_disp_x[]' as that bit selection is immediately at the final output, yet reading the font memory takes 2 clocks since it's address was presented.  I still need to proof 'nockieboy's' final code to make sure he knows whats going on and the final results aren't a fluke, or, he figured out about the 2 clock read cycle delay.
The next step after switching to 125MHz will be re-doing the ram and making a simultaneous 5 random port read at every new pixel with 1 huge chunk of 8 bit memory.  Then, a replacement of the X&Y counters for a software programmable address generator with vertical and  horizontal increment sizes and individual X&Y size scales of 1, 2, 3, 4 pixels/lines.  Then a 8 bit color map for the text character, 16 foreground and 16 background colors for each character, going through a 16 bit 16 color palette, 4 bit ARGB.  That's 12 bits 4096 RGB colors + 16 transparency levels since the text mode will sit on top of the graphics mode. (Will look like a TV studio text genlock on top of a video source) The text mode will eat 3 of the 5 access cycles.  The next one will be the 256 color graphic pixel / pixels data (sits below the varible transparency text layer) and the final memory one will be up to 16 sprites per line of video.  (These sit on top of the text layer, or below the text layer, but above the graphics layer.)
Post by: BrianHG on November 09, 2019, 05:52:46 am
Yes, I agree, the unary ~ operator instead of the '8-' or '7-' would give the compiler less headaches.
Post by: jhpadjustable on November 09, 2019, 06:06:05 am
I dunno, ~ just seemed more natural to me. "Be the bits you wish to see in the world."
Anyway this is turning out to be an interesting lab/demonstration in pair programming. I'm going to try to sit back as a good audience member and watch quietly. :)
Post by: BrianHG on November 09, 2019, 08:07:08 am
Just personal notes:
The op is currently using a "Cyclone II EP2C5T144".
He has 4608 logic elements / IE 4608 register bits, or, 576 x 8 bit registers.
He has 119808 bits of ram.  Safely, he can make an 8 kilobyte ram plus another 2 kilobyte ram.
Current plan:
Configure main system memory 8 kilobytes.  Contains text, fonts, graphic data & some spare room for CPU in lo-res mode.
        - 1200bytes for 40x30 text mode, or, 4800 bytes for 80x60, or 2400 bytes for 80x30
        - Double the above bytes for text with 16 color foreground and 16 color background.
        - 1024 bytes for 128 character 8x8 font.  2048 bytes for 256 character font.  Double for 8x16 VGA quality font.
        - Additional 16 words by 16 bits for text mode palette.  (This one is small enough to fit in registers if needed.)
        - Additional 256 words by 16 bits for graphics palette.
I hope his next FPGA board is going to have at least 20 kilobytes of ram.  He will be able to make a full VGA grade 16 color text mode, or, 160x120 in 16 color mode.  160x120 in 256 color mode with 32 kilobytes.
The 16$ lattice FPGA can safely be configured to have 192 kilobytes (216kb with a few tricks) of ram (note: 320x240x256color = 75 kilobytes, 640x480x16color = 150kb, 320x240x65k truecolor = 150kb (LOL, an 8 bit computer with a full truecolor desktop background + text based window superimposed)) , plus some spare for palette and a fancy blitter with a command cache.
Post by: nockieboy on November 09, 2019, 10:32:39 am
Absolutely.  The more comments, the better.  ;)
Now:
1) See attachment in this post
2) Likely, yes, but I can't commit to specific times with any certainty, but most likely in the evenings (so anything from 12pm-7pm your time?) - have to placate the missus somehow.  ;D
3) FMAX is currently 182.65 MHz, with a Restricted Fmax of 163.03 MHz.  Apparently limited due to high minimum pulse width violation (tch)?  It was around 200 MHz before the changes yesterday.  :-\
Next steps:
Is this right?
altsyncram altsyncram_component_osd_font ( .wren_a ( wren_font ), .clock0 (clk), .clock1 (clk), .clocken1 (pc_ena[3:0] == 0),
Hmm.. my monitor is saying 'out of range', quoting 19.5 KHz / 24 Hz...  either I've made a typo or there's a clock division error on PC_ENA.  If PC_ENA[3:0] == 0 is dividing  by 8, surely?  Or are my maths out?  That'll give a PC_ENA frequency of 15 MHz?
Using pc_ena[3:2] == 0 gives an output the monitor can understand, though, even though it's a little... wrong.  I think there's a memory timing issue here?
[attach=1]
Post by: nockieboy on November 09, 2019, 10:44:46 am
Yep, I changed this earlier - I knew the 8 - ... was a complete hack, but I didn't have time to look up a better way to do it.  Using ~ didn't occur at the time!  ::)
Post by: BrianHG on November 09, 2019, 10:47:42 am
Ok, in sync_gen.v, the 'pc_ena' should read:
if (pc_ena == PIX_CLK_DIVIED) pc_ena <= 0;
else pc_ena <= pc_ena +1;
Make 'PIX_CLK_DIVIED' a parameter and make the default value 4.
In the ' if (pc_ena[3:2] == 0)   // once per pixel '
it should read:
if (pc_ena[2:0] == 0)     // for now, use [2:0] on your small FPGA...
^^^^ Change this one everywhere!!!
This means a single pixel advance will happen 1 clock after the 'PIX_CLK_DIVIED' value makes pc_ena[3:0] = to 0.
Post by: BrianHG on November 09, 2019, 10:54:04 am
Your PLL clock should have a ratio of X10/2 for 125MHz.
Your current FMAX slowdown is due to this line:
assign osd_image[0] = char_line[(~dly4_disp_x[3:1])];
Though correct, since osd_image[0] is not a register, this is just a mass of gates.  For now, you are clearing 125MHz and we will be fixing this later on.
If 'osd_image[0]' was a register, this would give an additional clock cycle for the bit selector to do select bits 7 through 0, then that output would be shifted off to the and gates and video stencil.
Post by: nockieboy on November 09, 2019, 10:56:26 am
Looking good again.  :)
Fmax has dropped to 162.31 MHz though.
Post by: nockieboy on November 09, 2019, 11:04:53 am
My board's clock is 50 MHz... that would make the PLL clock 250 MHz.  :-//
Post by: BrianHG on November 09, 2019, 11:06:50 am
FMAX going up and down can mean logic has been simplified out due to design change, or errors.
Now, look as my post about the 2 sub modules you need to make:
and
Begin with the ''multiport_gpu_ram.v''.
begin the module with all the inputs and outputs labeled as you like.
Make a second clock and clock enable input for the Z80 cpu port side.  It's nice just to have it there...
Add at least these 1 parameters:
Maximum address bit (name it what you like, this one will configure the maximum size of memory)
As a strategy, keep the address ports all 20bit, even if you configure the memory to 10 bits.  You will bury the address wiring limit inside the ram module only, but you still wan to pass all 20 bits through the module whether you use them or not.
Post by: BrianHG on November 09, 2019, 11:07:54 am
My bad...
Post by: nockieboy on November 09, 2019, 11:22:15 am
Okay, with you so far (I think) - see attached file.
Need to confirm I'm reading this right - you want 5x 20-bit read address buses, 5x 8-bit read buses, 5x 8-bit data buses, and 5x pass-thru address buses and 5x pass-thru command buses???!?!
How does this fit into the dual-port paradigm?  I thought it was bad enough trying to get a dual-port memory chip, let alone a five-port one!
Any chance of some single-syllable clarification on this next step?  :o  ;D
Post by: BrianHG on November 09, 2019, 11:40:26 am
You will only have a  dual port ram which will be inside the ''gpu_dual_port_ram_INTEL.v'' module.
The 'multiport_gpu_ram.v' doesn't have the 'altsyncram_component_gpu_ram' in it, it will have the ''gpu_dual_port_ram_INTEL.v'' called in it where you will unify the that dual memory's IO ports.
What the 'multiport_gpu_ram.'v contains is a 5:1 mux for all those address inputs, each selected during the pena[2:0] 5 phases 0 through 4, then feeds that 1 result address into the read address of 1 read port of the dual port ram hidden inside the ''gpu_dual_port_ram_INTEL.v'' module.  Then take the data coming out and latch that data into the correct 1 of five data output registers which are all parallel represented as 8 x 8bit outputs.
Since our ram will now run at 125MHz, having it's ENA hard wired to 1/ON, we can feed the 5 read address and latch the 5 sequential data outputs into 5 sequential registers making that ram appear to have 5 parallel read ports running at 25MHz.
With you 25MHz pixel port, you can now fetch the character memory, then fetch the font pixel, then feed that output from 1 same block of memory, instead you will now need to deal with different base memory address.  This is the next step after the 5 port ram works.
As for the second dedicated read/write port for the 8 bit CPU, that one will be a pass-through.
Post by: BrianHG on November 09, 2019, 11:48:12 am
Remember, except for the 8bit CPU ports, make all the outputs I specified into separate registers.
The core issue will be the MUX selector and how you parallel delay the piped function to maintain FMAX.
For now, keep it basic and remember to use a register at each point.
This means that the memory which once took 2 clocks from in to out, will now also have additional piped stages for the address and data output to consider, and also all the final results will need to land back on pena[2:0] phase 0.
Post by: nockieboy on November 09, 2019, 12:21:53 pm
Okay, this is where I am so far with multiport_gpu_ram.v:
module multiport_gpu_ram (
input clk, // Primary clk input (125 MHz)
input [3:0] pc_ena, // Pixel clock enable
input clk_host, // Host (Z80) clock input
input hc_ena, // Host (Z80) clock enable
// address buses (input)
input [19:0] address_0,
input [19:0] address_1,
input [19:0] address_2,
input [19:0] address_3,
input [19:0] address_4,
input [19:0] addr_host,
// auxilliary read command buses (input)
input [7:0] aux_read_0,
input [7:0] aux_read_1,
input [7:0] aux_read_2,
input [7:0] aux_read_3,
input [7:0] aux_read_4,
// address buses (pass-thru outputs)
output reg [19:0] addrPT_0,
output reg [19:0] addrPT_1,
output reg [19:0] addrPT_2,
output reg [19:0] addrPT_3,
output reg [19:0] addrPT_4,
// auxilliary read command buses (pass-thru output)
output reg [7:0] auxRdPT_0,
output reg [7:0] auxRdPT_1,
output reg [7:0] auxRdPT_2,
output reg [7:0] auxRdPT_3,
output reg [7:0] auxRdPT_4,
// data buses (output)
output reg [7:0] dataOUT_0,
output reg [7:0] dataOUT_1,
output reg [7:0] dataOUT_2,
output reg [7:0] dataOUT_3,
output reg [7:0] dataOUT_4,
output [7:0] data_host
// dual-port GPU RAM handler
// define the maximum address bit - effectively the RAM size
parameter MAX_ADDR_BIT = 20;
// create a GPU RAM instance
gpu_dual_port_ram_INTEL gpu_RAM(
// TBC
always @(posedge clk) begin
if (pc_ena[2:0] == 0) begin
end // pc_ena
end // always @clk
endmodule
addr_host and data_host are host Z80 buses.
Am I going along the right lines?
Post by: BrianHG on November 09, 2019, 12:35:46 pm
Yes, good work, except, for the first time, you will be working differently with the 'if (pc_ena[2:0] == 0) begin'
Next, make a reg 'address_mux[]' & 'aux_read_mux[]', (use you preferred name) and make those registers run at 125Mhz, serial sequencing through the 5 pc_ena[2:0] stages.
Now, there is one little annoying problem here, a 20+8 bits in total, mux 5:1 may run too slow for 125Mhz, if so, later on as we add new inputs to the ports, you may need to make that muxing algorithm take 3 clocks instead of 1 clock.  Basically 3 parallel 2:1 muxers, those outputs feed another 2 parallel 2:1 muxers, than that last one will feed a final 2:1 muxer.
Post by: nockieboy on November 09, 2019, 12:44:04 pm
Here's the skeleton of the 5:1 mux:
// perform 5:1 mux for all inputs to the dual-port RAM
case (pc_ena[2:0])
3'b011 : ;
3'b100 : ;
3'b101 : ;
3'b110 : ;
3'b111 : ;
end // always @clk
Just trying to work out what to put into the case statements based on your comment about making the data available on the next p_ena[2:0] phase 0...  :o
Ookay, I think that's kind of what I've started to do (running the case statement at 125 MHz).
Post by: BrianHG on November 09, 2019, 12:50:20 pm
Remember, the case for pc_ena[2:0] goes 0,1,2,3,4,0...  Remember, I'm adding in the sync generator and resetting back to 0 after 4, the case of b111 for pc_ena[2:0] will never be reached.
This is not like the 8 bit font where at the left most coordinate of the screen xpos=0 the first pixel in the font's byte is the 7th bit, then 6th bit, then ect...
Post by: nockieboy on November 09, 2019, 12:55:38 pm
Ah yes,  I'd forgotten about the reset after the 5th count, hence the confusion over the bit count in the case statement.
reg address_mux[19:0], aux_read_mux[7:0];
// TBC
case (pc_ena[2:0])
3'b000 : begin
address_mux <= address_0;
aux_read_mux <= aux_read_0;
addrPT_0 <= address_0;
end
3'b001 : begin
address_mux <= address_1;
aux_read_mux <= aux_read_1;
addrPT_1 <= address_1;
end
3'b011 : begin
address_mux <= address_2;
aux_read_mux <= aux_read_2;
addrPT_2 <= address_2;
end
3'b100 : begin
address_mux <= address_3;
aux_read_mux <= aux_read_3;
addrPT_3 <= address_3;
end
3'b101 : begin
address_mux <= address_4;
aux_read_mux <= aux_read_4;
addrPT_4 <= address_4;
end
endcase
end // always @clk
Post by: BrianHG on November 09, 2019, 01:11:26 pm
Ok, next, we will start our  ''gpu_dual_port_ram_INTEL.v'' module.
In that module, you should have an input wire read port with address in , aux in, and pc_ena_in[2:0], data out, address out, aux out, pc_ena out[]  and host port wires and bidir.
Now, the altsyncram is obsolete, so, what you should do is within quartus, block diagram editor, double click on a blank area and insert a megafunction from the LPM_Ram_dp section.  Make sure launch wizard is selected on.
Next configure the memory for 1 read/write port and 1 read only port.  Clock/register the addresses going in and register the data coming out.  Before completing the function, sen me a snapshot of you screen example block diagram.
If it looks good, when finishing the wizard, select 'generate verilog source code/source files'.  Quartus will generate an example verilog.v file where you will copy and paste the LPM_Ram_dp/altsyncram into your ''gpu_dual_port_ram_INTEL.v'' source file where you will wire through the memories ports.
In that ''gpu_dual_port_ram_INTEL.v'', you will also pipe through the read address and aux input to the address output as well as pipe through the pc_ena_in[2:0] to an output pc_ena_out[2:0].
Don't forget about also having a MAX_RAM_ADDRESS parameter in this sub module as well.
Post by: nockieboy on November 09, 2019, 01:21:41 pm
I don't have an LPM_Ram_dp section?
[attachimg=1]
Post by: nockieboy on November 09, 2019, 01:23:39 pm
The post today was interesting, however.  Have received the Cyclone IV EasyFPGA board - has an EP4CE6 on board, with SDRAM and VGA connector (as well as PS2, which will be handy later).
Is it worth me updating to the latest Quartus software to support this chip?  I was using Quartus II 13.0sp1 as it was the last version to support the Cyclone II I was using...
Will mean a delay in proceedings whilst I get it all set up.
Post by: BrianHG on November 09, 2019, 01:27:49 pm
[attachimg=1]
Strange, it should be in the memory compiler section.  Scroll down and expand/shrink the list.  Don't type LPM in the query box, it may just be called ram_dp, dual_port_ram...
Post by: nockieboy on November 09, 2019, 01:30:25 pm
Is it because it's an older Quartus II version?  It may not have the module you're looking for?
[attachimg=1]
Post by: BrianHG on November 09, 2019, 01:35:59 pm
For now, while I'm available, let's work with what you have in hand.  You will need to transfer your project on your own time.
Post by: BrianHG on November 09, 2019, 01:36:35 pm
(Attachment Link)
Try the ram-2port.  It's not the quartus version, I think its that you are using a CycloneII.  It shouldn't matter as the newer FPGA will support all the memory features of the earlier ones.
Post by: nockieboy on November 09, 2019, 01:46:47 pm
Okay, this is where I am currently...
[attachimg=1]
Post by: BrianHG on November 09, 2019, 01:51:31 pm
You got it.  Now, remember the specs.
2 different clocks.
1 port read only.
other port read & write.
8 bits
13 addressees, or, 8192 words.
and clock the input controls as well as the output data.  As you change your options, the illustration will update showing you what you are creating.  send me the final image + the verilog.v example text...
Post by: nockieboy on November 09, 2019, 01:55:02 pm
2 different clocks.
1 port read only.
8 bits
Okay, using dual-clock (separate clocks for A and B ports as opposed to input and output clocks).  Will disable write on port 1 in the code when it produces it (there's no option for that in the wizard), 8-bit data is configured and I've gone for 14 addresses (16384 words), as I'm now using the EP4CE6 (still with Quartus II 13.0sp1) and have ~30KB of RAM to play with.
EDIT:
Do I need rd_en signals for either port?
Post by: BrianHG on November 09, 2019, 01:58:04 pm
2 different clocks.
1 port read only.
8 bits
Unless your EP4CE6 board is ready to run now, we can still get a lot done on the CycloneII board.
Show me the final illustration from the megawizard.
Memory size wont make a difference anyways as your MAX_MEM_ADDR will overwrite what the wizard has filled into the example.v file we will just be using as a guide.
Post by: nockieboy on November 09, 2019, 02:03:08 pm
The EP4CE6 is set up and outputting the video RAM contents as good as anything.  The only downside is that it has 1-bit colour output on the VGA connector.
[attachimg=1]
Post by: BrianHG on November 09, 2019, 02:06:00 pm
Perfect, paste the example into your  ''gpu_dual_port_ram_INTEL.v'' module and wire the ports to the modules IO declarations.
Post by: BrianHG on November 09, 2019, 02:10:00 pm
Now when you are saying 'outputting the video RAM contents', you mean the OSD generator we have written here, correct?
As for the color, you should eventually be able to do something about that.  Remember to choose output pins which are in the same IO bank as the current 1 bit RGB output pins.
Post by: nockieboy on November 09, 2019, 02:20:07 pm
Yes.  Without all these new modules we're working on at the moment.
Yes, just means I'll have to use my breadboard resistor ladder and VGA breakout connector again.  ::)
Post by: nockieboy on November 09, 2019, 02:25:37 pm
Okay, I'm a little confused right now.  I've got a megafunction-generated file, gpu_ram.v, which isn't normally included in the project files as Quartus wants me to leave the source code alone and just use the diagram component.
I've included the gpu_ram.v file so I can get to the code, but do I need to change anything there?  Can't I just wire up the gpu_ram component in the diagram to the multiport_gpu_ram component?
Post by: BrianHG on November 09, 2019, 02:30:19 pm
Not, get the board's schematic as they have a series resistor feeding the analog RGB video, and add a 2x value in series of each resistor to a new IO pin each.  This will give you 2 bit color.  Add a 4x series resistor to the analog VGA on a third IO pin to get 3 bit color...
example:
currently:
Current Red IO --------220ohm-----VGAred
Cheap DAC without the R2R ladder.
Current Red IO --------220ohm--------|--- VGAred
New Red IO2 ----------440ohm--------|
New Red IO3 ----------880ohm--------|
New Red IO4 ---------1760ohm-------|
It should be simple enough to hand wire this addition...
Post by: BrianHG on November 09, 2019, 02:38:44 pm
Nope, just copy and paste it into your  ''gpu_dual_port_ram_INTEL.v'' module.  We will make some changes and pass some parameters.  Don't bother with the Quartus copyright text.  Take a look at how I did it with my altsyncram in my current OSD generator.  It was copied and pasted from the same megawizard as well.
Though you could have read intel's manual on the dual port memory types and all their controls, the wizard just helps give you the basic feature setup visually.  You can always add or remove files from your project at any time.
The ''gpu_dual_port_ram_INTEL.v'' has a few more things than just the ram and you don't want a wizard file which can edit the structure if you place the file or click on the block diagram file.
OH, BTW, obviously delete the memory symbol from your block diagram file.  Your obviously wont be using that one.
Post by: nockieboy on November 09, 2019, 02:42:35 pm
So, this is my gpu_dual_port_ram_INTEL.v file now:
module gpu_dual_port_ram_INTEL (
input clk,
input [2:0] pc_ena_in,
input wr_en_a,
input clk_host,
input [19:0] addr_a,
input [19:0] addr_b,
input [7:0] data_a,
input [7:0] data_b
// Multiport GPU RAM
altsyncram altsyncram_component (
.clock0 (clock_a),
.wren_a (wren_a),
.address_b (address_b),
.clock1 (clock_b),
.data_b (data_b),
.wren_b (wren_b),
.address_a (address_a),
.data_a (data_a),
.q_a (sub_wire0),
.q_b (sub_wire1),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.address_reg_b = "CLOCK1",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_a = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
altsyncram_component.indata_reg_b = "CLOCK1",
altsyncram_component.init_file = "../osd_mem.mif",
altsyncram_component.intended_device_family = "Cyclone IV E",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 16384,
altsyncram_component.numwords_b = 16384,
altsyncram_component.operation_mode = "BIDIR_DUAL_PORT",
altsyncram_component.outdata_aclr_a = "NONE",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_a = "CLOCK0",
altsyncram_component.outdata_reg_b = "CLOCK1",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_port_a = "OLD_DATA",
altsyncram_component.read_during_write_mode_port_b = "OLD_DATA",
altsyncram_component.widthad_a = 14,
altsyncram_component.widthad_b = 14,
altsyncram_component.width_a = 8,
altsyncram_component.width_b = 8,
altsyncram_component.width_byteena_a = 1,
altsyncram_component.width_byteena_b = 1,
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK1";
endmodule
I've just cut 'n' pasted like you said.  Seems to be a lot of clock enables for some reason?  Obviously I'm going to have to prune/sort out the IO assignments.
[attach=1]
Post by: BrianHG on November 09, 2019, 02:55:19 pm
Fill and wire the IO ports.
Add the max address parameter, pass the parameters to the altsyncram's params.
When wiring the ram's address ports, limit the max ram adr inside the wiring there.
And, add a @(posedge clock), for the graphics, delay and pass through the read address, aux data and  pc_ena[3:0] with the same number of clock cycles as the memory's read pipe delay.
Try to think why I want you to do this.  What can these be used for.
Post by: BrianHG on November 09, 2019, 02:59:39 pm
// TBC
end // pc_ena
end // always @clk
endmodule
Change the 'hc_ena' to 'hc_write_ena'.  This is for writing data.  The host can read or write just like normal ram.
Post by: BrianHG on November 09, 2019, 03:03:21 pm
(Attachment Link)
Those have been hardwired to stay always enabled.  Leave them like that.
As for your photo of the 'multiport_gpu_ram', LOL  :-DD  You didn't have to generate a symbol of it....
That's just absurd...
You will obviously just call an instance of it in the OSG graphics generator...
Post by: nockieboy on November 09, 2019, 03:19:37 pm
Time's up for me today - for a while at least.  Here's the latest where I've gotten to with gpu_dual_port_ram_INTEL.v:
// inputs
input clk,
input wr_en_a,
input clk_host,
input wr_en_host,
input [7:0] data_in_a,
input [7:0] data_in_b,
// outputs
output [7:0] data_out_a,
output [7:0] data_out_b
// define delay pipe registers
reg [MAX_ADDR_BIT:0] rd_addr_pipe;
reg [7:0] aux_dat_pipe;
reg [3:0] pc_ena_pipe;
parameter MAX_ADDR_BIT = 14;
.clock0 (clk),
.wren_a (wr_en_a),
.address_b (addr_b[MAX_ADDR_BIT:0]),
.clock1 (clk_host),
.data_b (data_b),
.wren_b (wr_en_host),
.address_a (addr_a[MAX_ADDR_BIT:0]),
.data_a (data_a),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.widthad_a = MAX_ADDR_BIT,
altsyncram_component.widthad_b = MAX_ADDR_BIT,
rd_addr_pipe  <= addr_a;
end
endmodule
Thanks for your help and patience so far!!  ;D
Post by: BrianHG on November 09, 2019, 03:33:54 pm
// inputs
input clk,
input wr_en_a,          *************** Unused
input clk_host,
input wr_en_host,
input [7:0] data_in_a,   **************** Unused
// outputs
// define delay pipe registers  ********** dont forget that these will be output ports as well
reg [19:0] rd_addr_pipe;  ************************* even though the ram may be smaller, we should still pipe through all the 20 address bits.
parameter MAX_ADDR_BITS = 14;   ********************** this is 32k, however, for less confusion, I've changed it to BITS
.clock0 (clk),
.wren_a (wr_en_a),
.address_b (addr_b[MAX_ADDR_BITS-1:0]),           *****************   bits-1
.clock1 (clk_host),
.data_b (data_b),
.address_a (addr_a[MAX_ADDR_BITS-1:0]),               *********************
.data_a (data_a),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.numwords_a = 16384,    ************** fix, needs calculation based on MAX_ADDR_BITS
altsyncram_component.numwords_b = 16384,  ***********    fix, needs calculation based on MAX_ADDR_BITS
altsyncram_component.widthad_a = MAX_ADDR_BITS,                           *************** bits-0
altsyncram_component.widthad_b = MAX_ADDR_BITS,
rd_addr_pipe  <= addr_a;   *********** remember, there are 2 pipe steps before you should output the rd_addr out...
hde_pipe[7:1] <= hde_pipe[6:0];                  ******** unused
hde_out       <= hde_pipe[PIPE_DELAY-2];  ******* unused
end
endmodule
Comments in code with the asterisk ****...
I'll check in later tonight...
Post by: nockieboy on November 09, 2019, 04:47:53 pm
Okay, latest code here:
// inputs
input clk,
input clk_host,
input wr_en_host,
// outputs
output [19:0] addr_out_a,
output [7:0] data_out_b,
output [2:0] pc_ena_out
reg [MAX_ADDR_BITS - 1:0] rd_addr_pipe;
reg [7:0] dat_out_a_pipe;
// Dual-port GPU RAM
// Port A - read only by GPU
// Port B - read/writeable by host system
// Data buses - 8 bits / 1 byte wide
// Address buses - MAX_ADDR_BITS wide (14 bits default)
// Memory word size - 2^MAX_ADDR_BITS (16384 bytes default)
.clock0 (clk),
.wren_a (1'b1),
.address_b (addr_b[MAX_ADDR_BITS - 1:0]),
.clock1 (clk_host),
.data_b (data_in_b),
.address_a (addr_a[MAX_ADDR_BITS - 1:0]),
.data_a (8'b00000000),
.q_a (data_out_a_pipe),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.numwords_a = 2 ** MAX_ADDR_BITS,
altsyncram_component.numwords_b = 2 ** MAX_ADDR_BITS,
altsyncram_component.widthad_a = MAX_ADDR_BITS - 1,
altsyncram_component.widthad_b = MAX_ADDR_BITS - 1,
addr_out_a <= rd_addr_pipe;
//dat_out_a_pipe <= data_out_a;
data_out_a <= dat_out_a_pipe;
pc_ena_pipe <= pc_ena_in;
pc_ena_out <= pc_ena_pipe;
end
endmodule
Not sure I've got the delay pipes set up correctly.  data_out_a is coming straight out of the memory module, so only needs 1 (or actually probably 0?) delays.
Well, the address pass-through and pc_ena signal will arrive at the next module at the same time as the data, so should all be valid at the same time and can thus be used to process the data?
Post by: nockieboy on November 09, 2019, 07:37:53 pm
Why do they need to be output ports?  I've got them outputting their contents into outputs already...?
addr_out_a, data_out_a and pc_ena_out are all outputs?
Post by: BrianHG on November 10, 2019, 01:54:09 am
Ok, when defining a module IO, IE any signal/wires going in and out, all must be labeled as an input, or output, or bidir. (There are a few others, but not all compilers support it.)
Now, I know you have:
However, if you want that reg to be exposed to you function's declared IO port, yes, it will also need to be declared as an output as well.  The one small exception is if when you declare 'INPUT', with nothing else written, it is also automatically considered a 'WIRE' even though you did not specifically write 'input wire'...
To make things easier on you, you should declare you function's IO pins like the way you have it in your first verilog program 'sync_generator.v'.  Writing out each passed wire/bus as an 'input wire', 'output wire', 'output reg', would really clean thing up for coding.  I know my 15 year old OSD code stuffed everything like a 'C' code declaration.
From now on, declare your verilog functions and update your current one like this:
module sync_generator(
// inputs
input wire clk, // base clock
input wire pix_enable, // pixel clock
input wire reset, // reset: restarts frame
// outputs
output reg hsync, // horizontal sync
output reg vsync, // vertical sync
output wire [9:0] x, // current pixel x position
output wire [9:0] y, // current pixel y position
output reg inDisplayArea // high when in display area (valid drawing area)
Now, for the memory data out.  That clocking and registering of that bus is something happening inside quartus' 'altsyncram' function.  From your point of view, that data signal is an 'OUTPUT' of the 'altsyncram' function which you are receiving, so, in your function, it is like you are receiving an input.   You do not want to pass the data out through another clocked register in you code.  It is already delayed 2 clocks behind the address input and putting it through a reg will now make that 3 clocks before the data bus exist your verilog function module.  In your function's declaration, just make a wire:
output wire [7:0] data_out_a,
However, if Quartus does not like this, you might need to declare an internal subwire. This means just above you 'altsyncram' function add this:
wire [7:0] sub_data_out_a;
wire [7:0] data_out_a = sub_data_out_a[7:0];
And in the 'altsyncram' change:
         .q_a (data_out_a),
to:
         .q_a (sub_data_out_a),
In the body of your @(posedge clk), you do not need to touch the read data, it's just a wire right through from ram block to your outer function.
Post by: BrianHG on November 10, 2019, 04:20:22 am
OT: Thread read rankings:
In FPGA, we are #35 out of 285 since the inception of EEVblog forum.
In FPGA, in threads reads for a thread which existed for only the last 3 weeks, we are #1!
Ok, I realize that FPGA is a low read count on this forum...
Cant wait for the OP to get past this synchronous parallel access memory, the programmable memory pointing address generators is the last fancy thing, everything else is nothing more than 2 lookup palette table rams a few conditional A/B stencil switches, and the project will be finished.
Adding internal DVI serializer would be version 1.5 as it needs a routed PCB.
Adding a sophisticated pixel/line/box copy/drawing blitter would be considered next level version #2, though it is just added logic.  I ensured everything else which exists, how it is written in a way which will support the plugin.
Post by: nockieboy on November 10, 2019, 12:49:36 pm
That's my point though, it's just an internal register? The output from the altsyncram function goes into the pipe, which then goes into the output (addr_out_a, or pc_ena_out).  Do I still need to declare the pipe as an out as well then?
Seems to compile with no errors as is - see latest gpu_dual_port_ram_INTEL.v code below.
// inputs
input clk,
input clk_host,
input wr_en_host,
// registered outputs
output reg [19:0] addr_out_a,
output reg [2:0] pc_ena_out,
// direct outputs
output wire [7:0] data_out_b
.clock0 (clk),
.wren_a (1'b1),
.clock1 (clk_host),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
end
endmodule
Okay, the code above should be updated with the changes you've pointed out.  The only area I'm not sure about are the delay pipes - they're internal to the function and don't directly output, hence my reluctance to declare them as outputs.  Let me know if this is wrong and I've misunderstood something!   :popcorn:
Post by: BrianHG on November 10, 2019, 01:19:27 pm
Nope, we just want the final addr_out[] reg exposed.
Note that no matter the configured ram size, we still want to pass through all 20 address bits to the output, even if the ram is configured to only 16 or 17.
// inputs
input clk,
input clk_host,
input wr_en_host,
// direct outputs
.clock0 (clk),
.wren_a (1'b1),
.clock1 (clk_host),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
end
endmodule
Ok, first little error:
Get rid of the '-1' here, Intel is asking for the 'Width' of the port, not what the maximum address wire number is.
Next,
Correct.  You forgot, I asked for an additional auxiliary command to be piped through just like the addr_a in&out pipe.  Call it  'cmd_in' and 'cmd_out' and make it 16 bits ie. [15:0]...
The command is useful for example to direct the destination read to a specific register, or describe a specific pixel type, like bitplane, or 256 color, or, set how many pixels that read pixel should clock for, like a horizontal size/scale.  It can also be used to further expand one or more of our read ports into another 2 through 16 parallel read channels operating below the pixel 25MHz pixel clock speed.  (for example, maybe multichannel audio playback engine...)
Do not worry about all the extra wires, registers, and ports.  The compiler automatically simplifies out any un-wired logic.
Wit the last addition of the cmd in&out pipe, it's time to wire this module into the multiport gpu ram.
Post by: BrianHG on November 10, 2019, 01:25:47 pm
Also, you can optionally change:
input clk_host,
input wr_en_host,
to:
input clk_b
input wr_en_b
If you like....
Note that it is the job of the ''multiport_gpu_ram'' to wire the 2 port memory and wire  port b into the names clk_host, wr_en_host, data_in_host, data_out_host...
remember, you labeled port 2 addr_b, data in B, data out B....
And dont forget to change the:
to:
Post by: nockieboy on November 10, 2019, 02:20:42 pm
Not that no matter the configured ram size, we still want to pass through all 20 address bits to the output, even if the ram is configured to only 16 or 17.
Marvellous, was thinking along the right lines then.
Yes, my memory isn't my strong point.  ::)  Sorted now.
I've made a start on the multiport_gpu_ram already - lots of things going off here though, so can't focus on this at the moment - will be back to it later tonight.
Current multiport_gpu_ram.v:
input clk_b, // Host (Z80) clock input
input write_ena_b, // Host (Z80) clock enable
// address pass-thru bus (output)
output reg [19:0] addr_passthru,
// define the maximum address bits - effectively the RAM size
parameter MAX_ADDR_BITS = 20;
reg [MAX_ADDR_BITS - 1:0] address_mux;
reg [7:0] aux_read_mux;
.clk(clk),
.pc_ena_in(pc_ena),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_a(address_mux),
.addr_b(),
.data_in_b(),
.addr_out_a(addr_passthru),
.pc_ena_out(),
.data_out_a(aux_read_mux),
.data_out_b()
case (pc_ena[2:0])
3'b000 : begin
addr_passthru <= address_0;
end
3'b001 : begin
addr_passthru <= address_1;
end
3'b011 : begin
addr_passthru <= address_2;
end
3'b100 : begin
addr_passthru <= address_3;
end
3'b101 : begin
addr_passthru <= address_4;
end
endcase
end // always @clk
endmodule
Have merged all the pass-through addresses into one bus - otherwise can't see the point of having them in the mux at all?  addr_passthru is the passed-through address, muxed from one of the five input addresses depending on pc_ena value.  Hopefully that's right.   ???
input clk_host,
input wr_en_host,
to:
input clk_b
input wr_en_b
If you like....
to:
Think I've done all that - things have gotten busy here though and I've had to cut this short, so attaching files for perusal, but there may be incomplete bits errors.
gpu_dual_port_ram_INTEL:
// inputs
input clk,
input [3:0] pc_ena_in,
input clk_b,
input wr_en_b,
input [15:0] cmd_in,
output reg [15:0] cmd_out,
// direct outputs
reg [19:0] rd_addr_pipe_a;
reg [15:0] cmd_pipe;
.clock0 (clk),
.wren_a (1'b1),
.address_b (addr_b[MAX_ADDR_BITS:0]),
.clock1 (clk_b),
.wren_b (wr_en_b),
.address_a (addr_a[MAX_ADDR_BITS:0]),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.read_during_write_mode_port_a = "OLD_DATA",they're
// *** Create a serial pipe where the PIPE_DELAY parameter selects the pixel count delay for the xxx_in to the xxx_out ports
cmd_pipe <= cmd_in;
cmd_out <= cmd_pipe;
end
endmodule
Post by: BrianHG on November 10, 2019, 03:00:03 pm
.clk(clk),
.pc_ena_in(pc_ena),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_b(),
.data_in_b(),
.pc_ena_out(),
.data_out_b()
case (pc_ena[2:0])
3'b000 : begin
end
3'b001 : begin
end
3'b011 : begin
end
3'b100 : begin
end
3'b101 : begin
end
endcase
end // always @clk
endmodule
Ok, from what I can see so far:
After initiating the "gpu_dual_port_ram_INTEL gpu_RAM(.....);", you need the:
          defparam
                           gpu_RAM.MAX_ADDR_BITS = MAX_ADDR_BITS ;
     This will pass the module multiport_gpu_ram's MAX_ADDR_BITS parameter into the gpu_dual_port_ram_INTEL's MAX_ADDR_BITS parameter.  It may be useful to pass the 'altsyncram_component.numwords_a&b' since it may be possible to allocate 24kb in the FPGA since it has that much memory, yet not 32kb.
   .addr_out_a(addr_passthru), should change to (addr_passthru_mux) and don't forget to declare it as a wire.
   .data_out_a(aux_read_mux) is also a wire.
   .pc_ena_out(pc_ena_out), is also a wire and an output
   output reg [19:0] addr_out,   There are 5 of these to match the read address ins 0 through 5 in.
 change all these to cmd_in[15:0].  (global search and replace)
change these to cmd_out[15:0]
change to reg [19:0] address_mux;
change to reg [15:0] cmd_read_mux  (global search and replace)
Your missing a few of the new ports for 'gpu_dual_port_ram_INTEL gpu_RAM(...);'
Almost done, next you will resort the read ram contents, the piped through address & cmds into their output registers and sync those to your new delayed 'pc_ena_out[3:0]' coming out of the Intel ram module.
Note that we forgot to wire through the 'pc_ena_out[3:0]' coming out of the Intel ram module thought to the multiport_gpu_ram ( ...) ports, so that the rest of our graphics pipe heading to the output pins will incorporate the delay shift generated by the memory.  (Though we can work around this through sophisticated re-syncing all the ram outputs back to the next pc_ena_in==0 cycle, this ena signal in the FPGA is beginning to drive so much logic limiting our FMAX, this is an opportune point to D-clock pipe the signals for the second half of our graphics pipe.)
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: nockieboy on November 11, 2019, 10:12:38 am
          defparam
Okay, stupid question - altsyncram specifies altsyncram_component.numwords_a (and b) - I had 2 ** MAXSIZE in there, but if they're the number of words, I'll need to divide that by word size (8), otherwise the RAM will (try to be) 8 times larger than what I think I'm specifying?
So, for example, this:
// define the memory size (number of words) - this allows RAM sizes other than multiples of 2
// but defaults to power-of-two sizing based on MAX_ADDR_BITS if not otherwise specified
parameter WORDS = 2 ** MAX_ADDR_BITS;
..needs to be this:
parameter WORDS = (2 ** MAX_ADDR_BITS) / 8;
These should all be present and correct now... I think.  Got a little confused earlier with all the changes, so I'll be double-checking it all, but I think it would benefit from a close look.
They should all be present and correct now.  :D
Have made a bit of a start on this - the 5:1 mux code is modified according to my present understanding.  The read address is passed through to the ram module, the pass-through address is passed out to the appropriate address bus according to the current mux step, as is the data read from memory.
I'm a little unsure about the command bus, though.  It's piped into the memory via cmd_read_mux, but that seems like an unnecessary step as I only have one cmd_in bus (and one cmd_out bus) - should these be increased to 5 as well?  It's possible I've misunderstood your instruction to 'change all these to cmd_in[15:0]'...  ???
Okay, I think I understand - but pc_ena passes through the gpu_dual_port_ram_INTEL module via a register pipe, which will fulfil the need to D-clock the signal, right?
// inputs
input clk,
input clk_b,
input wr_en_b,
output reg [3:0] pc_ena_out,
// direct outputs
.clock0 (clk),
.wren_a (1'b1),
.clock1 (clk_b),
.wren_b (wr_en_b),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.numwords_a = WORDS,
altsyncram_component.numwords_b = WORDS,
cmd_pipe <= cmd_in;
end
endmodule
input [3:0] pc_ena_in, // Pixel clock enable
// outputs
output wire [3:0] pc_ena_out,
output reg [19:0] addr_passthru_0,
output reg [19:0] addr_passthru_1,
output reg [19:0] addr_passthru_2,
output reg [19:0] addr_passthru_3,
output reg [19:0] addr_passthru_4,
output reg [19:0] addr_host_passthru,
// auxilliary read command bus (pass-thru output)
reg [15:0] cmd_read_mux;
wire [19:0] addr_passthru_mux;
wire [7:0] data_mux;
.clk(clk),
.pc_ena_in(pc_ena_in),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_b(),
.data_in_b(),
.cmd_in(cmd_read_mux),
.addr_out_a(addr_passthru_mux),
.cmd_out(cmd_out),
.data_out_a(data_mux),
.data_out_b()
// pass MAX_ADDR_BITS into the gpu_RAM instance
defparam gpu_RAM.MAX_ADDR_BITS = MAX_ADDR_BITS;
// set none-default word size for the RAM (24 KB)
defparam gpu_RAM.WORDS = 24576;  // ************** should this be divided by 8?
// route non-muxed pass-throughs
cmd_read_mux <= cmd_in;
case (pc_ena[2:0])
3'b000 : begin
addr_passthru_0 <= addr_passthru_mux;
dataOUT_0 <= data_mux;
end
3'b001 : begin
addr_passthru_1 <= addr_passthru_mux;
dataOUT_1 <= data_mux;
end
3'b011 : begin
addr_passthru_2 <= addr_passthru_mux;
dataOUT_2 <= data_mux;
end
3'b100 : begin
addr_passthru_3 <= addr_passthru_mux;
dataOUT_3 <= data_mux;
end
3'b101 : begin
addr_passthru_4 <= addr_passthru_mux;
dataOUT_4 <= data_mux;
end
endcase
end // always @clk
endmodule
Post by: BrianHG on November 11, 2019, 10:51:26 am
          defparam
..needs to be this:
Nope, the first one not the divide by 8.
The 1 command bus is inside the INTEL dual port ram module.  Just like the read addresses, it should be piped through in a single file fashion.
On the multiport GPU ram, there should be 5 groups going in, grouped with the 5 read addresses going in, and 5 grouped 16 bit cmd coming out, just like the 5 read datas, 5 read addresses, 5 cmd_outs, all in parallel...
Pipe it just like a read address and the auxiliary 16 bit cmd, delayed by two 125MHz clocks.  The difference is when it comes back through the GPU multiport ram module, there it is not muxed, it's just wired through without delay.
// inputs
input clk,
input clk_b,
input wr_en_b,
// direct outputs
parameter ADDR_SIZE = 14;   **********************************************************
// but defaults to power-of-two sizing based on ADDR_SIZE if not otherwise specified
parameter NUM_WORDS = 2 ** ADDR_SIZE;   **********************************************************
.clock0 (clk),
.wren_a (1'b1),
.address_b (addr_b[ADDR_SIZE-1:0]),   ***************************************************************
.clock1 (clk_b),
.wren_b (wr_en_b),
.address_a (addr_a[ADDR_SIZE-1:0]),   ****************************************************************************
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.numwords_a = NUM_WORDS,
altsyncram_component.numwords_b = NUM_WORDS,
altsyncram_component.widthad_a = ADDR_SIZE,  ********************************************************************
altsyncram_component.widthad_b = ADDR_SIZE,  *********************************************************************
cmd_pipe <= cmd_in;
end
endmodule
// outputs
output reg [15:0] cmd_out,  *************************************  NEED 5x cmd_out0/1/2/3/4 and we also need 5x cmd_in#
parameter NUM_WORDS = 2 ** ADDR_SIZE ;                 *******************************************
.clk(clk),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_b(),
.data_in_b(),
.cmd_out(cmd_out),
.data_out_b()
defparam gpu_RAM.ADDR_SIZE = ADDR_SIZE,    *************************************************************************
                 gpu_RAM.NUM_WORDS = NUM_WORDS ;  // **************  Actual word count
case (pc_ena[2:0])
3'b000 : begin
end
3'b001 : begin
end
3'b011 : begin
end
3'b100 : begin
end
3'b101 : begin
end
endcase
end // always @clk
endmodule
Read all my ********************************************** in the 2 codes above
To make 1 thing clear, I changes the 'MAX_ADDR_BIT' to 'ADDR_SIZE'.  So, 14 = 14 address lines = [13:0]...
Studying the settings you setup in the Megawizard, and analyzing the example dualp...v file it generated should confirm this.
Same for 'WORDS', I changed it to 'NUM_WORDS'.
Check all the new ***************************** as there were one of 2 other items...
Next, re-assemble all the outputs of the INTEL dualport ram into 5 addresses, 5 datas, 5 cmds.
Helpful hint:
Since we want all the 5 outputs to parallel appear, each with the write contents when the input (pc_ena[2:0] == 0), and you have a bunch of delays through this module where you can easily loose count of clocks cycles, especially if you need to make your mux take 2 or 3 clocks instead of 1 to help improve FMAX, make these local params and I'll leave it up to you to figure out how to implement them:
localparam   CLK_CYCLES_MUX  = 1;  // Adjust this parameter to the number of 'clk' cycles it takes to select 1 of 5 muxed inputs
localparam   CLK_CYCLES_RAM  = 2;  // Adjust this figure to the number of clock cycles the DP_ram takes to retrieve a valid data from the read address in.
Im not sure of this one, we will need to send this parameter back to the OSD generator so it know how many pixels to delay the H&V ena, and OSD ena to align the picture.
localparam   CLK_CYCLES_PIXEL  ??? = ;  // Adjust this figure to the number of PIXEL clock cycles it takes the demuxed output data to be ready.
Post by: BrianHG on November 11, 2019, 11:17:02 am
You can only have 1 'defparam' after each module is initiated.  To set multiple parameters, you use the " , " at the end of each parameter and the ' ; ' at the end of the final setting.
When you pass multiple parameters to a sub module, you type it like this:
Post by: nockieboy on November 11, 2019, 11:39:18 am
All done - I've renamed some of the buses as well to make it clearer what's going on with all the pass-throughs etc.
Sorted.  pc_ena is treated the same way as the other delayed signals in the memory module, but passed straight to the output in multiport_gpu_ram.
Thanks - have updated the code accordingly.
Helpful hint:
Since we want all the 5 outputs to parallel appear, each with the write contents when the input (pc_ena[2:0] == 0)...
Ooookay... so all five outputs should be valid when pc_ena[2:0] == 0?  At the moment, addr_out_0, cmd_out_0, data_out_0 will all be valid two or three clock cycles (at least) before addr_out_1, cmd_out_1 and data_out_1, etc. with the delays compounding up to the 5th set of outputs?  Not to mention pc_ena needing to be delayed as well until the 5th outputs of the mux are ready?
Would it work to just route the results of the first 4 mux cycles into registers and then assign all 5 sets of results to the outputs at the end of the 5th mux cycle?  Am I even understanding the issue?
Currently, the mux code is just putting the results onto the multiport outputs as soon as they come in.
...and you have a bunch of delays through this module where you can easily loose count of clocks cycles, especially if you need to make your mux take 2 or 3 clocks instead of 1 to help improve FMAX, make these local params and I'll leave it up to you to figure out how to implement them:
localparams added.  CLK_CYCLES_PIXEL (CLK_CYCLES_PIX in code) needs to be added to the OSD generator code then?
// inputs
input clk,
input clk_b,
input wr_en_b,
// direct outputs
// Address buses - ADDR_SIZE wide (14 bits default)
// Memory word size - NUM_WORDS (16384 bytes default)
.clock0 (clk),
.wren_a (1'b1),
.address_b (addr_b[ADDR_SIZE:0]),
.clock1 (clk_b),
.wren_b (wr_en_b),
.address_a (addr_a[ADDR_SIZE:0]),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.widthad_a = ADDR_SIZE - 1,
altsyncram_component.widthad_b = ADDR_SIZE - 1,
cmd_pipe <= cmd_in;
end
endmodule
input [19:0] addr_in_0,
input [19:0] addr_in_1,
input [19:0] addr_in_2,
input [19:0] addr_in_3,
input [19:0] addr_in_4,
input [19:0] addr_host_in,
input [15:0] cmd_in_0,
input [15:0] cmd_in_1,
input [15:0] cmd_in_2,
input [15:0] cmd_in_3,
input [15:0] cmd_in_4,
// outputs
output reg [19:0] addr_out_0,
output reg [19:0] addr_out_1,
output reg [19:0] addr_out_2,
output reg [19:0] addr_out_3,
output reg [19:0] addr_out_4,
output reg [19:0] addr_host_out,
output reg [15:0] cmd_out_0,
output reg [15:0] cmd_out_1,
output reg [15:0] cmd_out_2,
output reg [15:0] cmd_out_3,
output reg [15:0] cmd_out_4,
output reg [7:0] data_out_0,
output reg [7:0] data_out_1,
output reg [7:0] data_out_2,
output reg [7:0] data_out_3,
output reg [7:0] data_out_4,
output [7:0] data_host_out
// define the maximum address bits and number of words - effectively the RAM size
localparam CLK_CYCLES_MUX = 1; // adjust this parameter to the number of 'clk' cycles it takes to select 1 of 5 muxed outputs
localparam CLK_CYCLES_RAM = 2; // adjust this figure to the number of clock cycles the DP_ram takes to retrieve valid data from the read address in
localparam CLK_CYCLES_PIX = 5; // adjust this figure to the number of PIXEL clock cycles it takes the demuxed output data to be ready
reg [19:0] addr_in_mux;
reg [15:0] cmd_mux_in;
reg [15:0] cmd_mux_out;
wire [19:0] addr_out_mux;
wire [7:0] data_mux_out;
.clk(clk),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_a(addr_in_mux),
.addr_b(),
.data_in_b(),
.cmd_in(cmd_mux_in),
.addr_out_a(addr_out_mux),
.cmd_out(cmd_mux_out),
.data_out_a(data_mux_out),
.data_out_b()
defparam gpu_RAM.ADDR_SIZE = ADDR_SIZE, // pass ADDR_SIZE into the gpu_RAM instance
gpu_RAM.NUM_WORDS = NUM_WORDS; // set non-default word size for the RAM (16 KB)
case (pc_ena[2:0])
3'b000 : begin
addr_in_mux <= addr_in_0;
cmd_mux_in <= cmd_in_0;
addr_out_0 <= addr_out_mux;
cmd_out_0 <= cmd_mux_out;
data_out_0 <= data_mux_out;
end
3'b001 : begin
addr_in_mux <= addr_in_1;
cmd_mux_in <= cmd_in_1;
addr_out_1 <= addr_out_mux;
cmd_out_1 <= cmd_mux_out;
data_out_1 <= data_mux_out;
end
3'b011 : begin
addr_in_mux <= addr_in_2;
cmd_mux_in <= cmd_in_2;
addr_out_2 <= addr_out_mux;
cmd_out_2 <= cmd_mux_out;
data_out_2 <= data_mux_out;
end
3'b100 : begin
addr_in_mux <= addr_in_3;
cmd_mux_in <= cmd_in_3;
addr_out_3 <= addr_out_mux;
cmd_out_3 <= cmd_mux_out;
data_out_3 <= data_mux_out;
end
3'b101 : begin
addr_in_mux <= addr_in_4;
cmd_mux_in <= cmd_in_4;
addr_out_4 <= addr_out_mux;
cmd_out_4 <= cmd_mux_out;
data_out_4 <= data_mux_out;
end
endcase
end // always @clk
endmodule
Post by: BrianHG on November 11, 2019, 12:04:28 pm
Ok, here lies the trick/headache (at least until you figure out how to do it).
Yes, the way you have it written, the outputs are scrambled into the wrong demuxed ports.
Also, remember, I said I want all the demuxed outputs from the gpu_ram module to all become properly valid during the next valid pixel clock (pc_ena[3:0]==0) time slot, and, to hold their contents and all switch during the next valid pixel clock once again.
As an aid, I would move all the :
            addr_out_# <= addr_out_mux;
            cmd_out_# <= cmd_mux_out;
            data_out_# <= data_mux_out;
Outside the case statement.
Here is the hint#1 :
With additional variable sized piped regs will be used to generate the desired output.
Here is hint #2:   (make a buss version of this single bit/wire example)
bla_pipe[0]   <= bla_in;
bla_pipe[7:1] <= bla_pipe[6:0];
out                  <= bla_pipe[PIPE_DELAY-2];
Post by: nockieboy on November 11, 2019, 12:27:23 pm
Right, so I'm now assigning the data returned from the ram module into a register that will hold that data, for each section of the mux.  Outside of the case statement, I've got a check for pc_ena[3:0] == 0 - when that condition is satisfied, all five data paths from the ram module are passed to the multiport's output IOs:
// declare registers to hold data until pc_ena[3:0] == 0 and
// it can be passed to the output IOs
reg [19:0] addr_buf_out_0,
addr_buf_out_1,
addr_buf_out_2,
addr_buf_out_3,
addr_buf_out_4;
reg [15:0] cmd_buf_out_0,
cmd_buf_out_1,
cmd_buf_out_2,
cmd_buf_out_3,
cmd_buf_out_4;
reg [7:0] data_buf_out_0,
data_buf_out_1,
data_buf_out_2,
data_buf_out_3,
data_buf_out_4;
case (pc_ena[2:0])
3'b000 : begin
addr_buf_out_0 <= addr_mux_out;
cmd_buf_out_0 <= cmd_mux_out;
data_buf_out_0 <= data_mux_out;
end
3'b001 : begin
addr_buf_out_1 <= addr_mux_out;
cmd_buf_out_1 <= cmd_mux_out;
data_buf_out_1 <= data_mux_out;
end
3'b011 : begin
addr_buf_out_2 <= addr_mux_out;
cmd_buf_out_2 <= cmd_mux_out;
data_buf_out_2 <= data_mux_out;
end
3'b100 : begin
addr_buf_out_3 <= addr_mux_out;
cmd_buf_out_3 <= cmd_mux_out;
data_buf_out_3 <= data_mux_out;
end
3'b101 : begin
addr_buf_out_4 <= addr_mux_out;
cmd_buf_out_4 <= cmd_mux_out;
data_buf_out_4 <= data_mux_out;
end
endcase
if (pc_ena[3:0] == 0)
begin
addr_out_0 <= addr_buf_out_0;
cmd_out_0 <= cmd_buf_out_0;
data_out_0 <= data_buf_out_0;
addr_out_1 <= addr_buf_out_1;
cmd_out_1 <= cmd_buf_out_1;
data_out_1 <= data_buf_out_1;
addr_out_2 <= addr_buf_out_2;
cmd_out_2 <= cmd_buf_out_2;
data_out_2 <= data_buf_out_2;
addr_out_3 <= addr_buf_out_3;
cmd_out_3 <= cmd_buf_out_3;
data_out_3 <= data_buf_out_3;
addr_out_4 <= addr_buf_out_4;
cmd_out_4 <= cmd_buf_out_4;
data_out_4 <= data_buf_out_4;
end
end // always @clk
Is that going down the right road?  Obviously I haven't given any consideration to pipe delays yet...
Just run this part by me once more - why do I need more delays?  If what I've done above is correct, the results are held in registers until pc_ena[3:0] == 0, where they all get passed out to the output IOs.  What are the additional delay pipes for?
Post by: BrianHG on November 11, 2019, 01:11:55 pm
Ok, not quite.  Your outputs would still be scrambled, not only that, but, now, some of your outputs will be ahead by 1 pixel and the rest will have the correct pixel.
What you have setup has no configuration/adjustment capabilities.
Currently, at pc_ena 0, you may be switching to addr0, but the memory is seeing the previous addr4, while what is coming out of the ram is the previous addr2. but, you are currently snapping that into addr_buf0/data_buf0, and then feeding the previous  holdings of every addr_buf#/data_buf# into addr_out#/data_out#.
At pc_ena 1, you may be switching to addr1, but the memory is seeing the previous addr0, while what is coming out of the ram is the previous addr3. and are currently snapping that into addr_buf1/data_buf1, though the addr_out#/data_out# all hold their new state from when pc_ena0 phase has updated them.
Now, you can see the headache here.  Say you weed out everything as set the delays fixed and you code appears to work good.  What happens after adding some features, you might need to expand your mux for speed by making it collapse in 3 clocks stages instead of the current 1 clock.  What will sorting out the mess look like?
Step 1: Get rid of any and all demuxing in the case statement.
Step 2: Make a easily variable clock delay pipe tap coming out of the gpu_ram.
Example:
reg [9*8+7:0]  data_pipe;   // make a large enough register to store 10 words (words 0 through 9).  In the case of ram data, the width of each word is 8 bits.
Now, inside the always @(posedge clk) place
data_pipe[7:0]                <= data_mux_out[7:0];         // fill the first 8 bit word in the register pipe
data_pipe[9*8+7:1*8]  <= data_pipe[8*8+7:0*8];    // shift over the next 9 words in this 10 word 8 bit wide pipe
   begin
   data_out_0 <= data_pipe[MUX_0_POS*8+7:MUX_0_POS*8];
   data_out_1 <= data_pipe[MUX_1_POS*8+7:MUX_1_POS*8];
   data_out_2 <= data_pipe[MUX_2_POS*8+7:MUX_2_POS*8];
   data_out_3 <= data_pipe[MUX_3_POS*8+7:MUX_3_POS*8];
   data_out_4 <= data_pipe[MUX_4_POS*8+7:MUX_4_POS*8];
end
Now, the key is to workout the values for the 5 'MUX_#_POS' which are a fixed value based of the delays incurred by both   the  CLK_CYCLES_MUX  = 1 and CLK_CYCLES_RAM  = 2, and the tricky one, where each piece of data is in the pipe when the next  pc_ena==0 comes around so that all 5 output regs take the correct pipe position.
Resolve MUX_#_POS using the 2 CLK_CYCLES parameters with the knowledge that pc_ena[] counts from 0-4, and in the future if you may any changes which add additional clocks in the preparation for the memory data, or different clock cycles in the FPGA memory core, or if you wire external static memory, just adjusting the 'CLK_CYCLES' parameters will allow your design to continue to function without re-doing all the individual written hardwired logic.
When calculating the MUX_#_POS may also mean adding a full additional pixel delay if one or more pixels comes in earlier than the rest, or if 1 pixel comes in later than the rest.
Post by: nockieboy on November 11, 2019, 01:57:37 pm
My mind has just melted...  :scared:
Like so?
case (pc_ena[2:0])
3'b000 : begin
end
3'b001 : begin
end
3'b011 : begin
end
3'b100 : begin
end
3'b101 : begin
end
endcase
end // always @clk
Example:
   begin
end
Okay, so we're feeding the data from the RAM into a pipeline which, at the start when pc_ena=0, is passed out to the data outputs and is bit-shifted up the pipe by 8 places on each clk count?
Errrrrr..... I've just had to cold-reset my brain twice.  I have literally lost myself in all this and am almost throwing code at the wall to see what sticks...:
localparam MUX_0_POS = (CLK_CYCLES_RAM + CLK_CYCLES_MUX) * 1;
localparam MUX_1_POS = (CLK_CYCLES_RAM + CLK_CYCLES_MUX) * 2;
localparam MUX_2_POS = (CLK_CYCLES_RAM + CLK_CYCLES_MUX) * 3;
localparam MUX_3_POS = (CLK_CYCLES_RAM + CLK_CYCLES_MUX) * 4;
localparam MUX_4_POS = (CLK_CYCLES_RAM + CLK_CYCLES_MUX) * 5;
data_pipe[7:0] <= data_mux_out[7:0]; // fill the first 8-bit word in the register pipe with data from RAM
data_pipe[9*8+7:1*8] <= data_pipe[8*8+7:0*8]; // shift over the next 9 words in this 10 word, 8-bit wide pipe
begin
end
When calculating the MUX_#_POS may also mean adding a full additional pixel delay if one or more pixels comes in earlier that the rest, or if 1 pixel comes in later that the rest.
Yeah, I'm going to have to walk away and come back to this later in the hope that I can get my head around it from a different angle, because this just isn't going in.   :-\
Post by: BrianHG on November 11, 2019, 02:25:57 pm
Yes, the first part you got right.  Yes, the data_pipe connected to the output of the ram module clocks at 125MHz nonstop, just like the memory itself, and the 5 cycled address going into the ram.
Ok, this should really help, however, you will still need to concentrate a little and print out my little 2 tables on some paper to make what's happening clear.
Lay out these 2 tables on 2 sheets of paper, one side list each reg in the pipe in order, and on the second is a list of how the muxed addresses and screen pixel number is being fed through:
On paper page #1
into data_pipe[8*8+7:8*8]
into data_pipe[7*8+7:7*8]
into data_pipe[6*8+7:6*8]
into data_pipe[5*8+7:5*8]
into data_pipe[4*8+7:4*8]
into data_pipe[3*8+7:3*8]
into data_pipe[2*8+7:2*8]
into data_pipe[1*8+7:1*8]
into data_pipe[0*8+7:0*8]
inside ram 2
inside ram 1
addr to addr-mux
PC_ENA pos0
On paper #2
pc_ena 0 pixel 0
pc_ena 1 pixel 0
pc_ena 2 pixel 0
pc_ena 3 pixel 0
pc_ena 4 pixel 0
pc_ena 0 pixel 1
pc_ena 1 pixel 1
pc_ena 2 pixel 1
pc_ena 3 pixel 1
pc_ena 4 pixel 1
pc_ena 0 pixel 2
pc_ena 1 pixel 2
pc_ena 2 pixel 2
pc_ena 3 pixel 2
pc_ena 4 pixel 2
pc_ena 0 pixel 3
pc_ena 1 pixel 3
pc_ena 2 pixel 3
pc_ena 3 pixel 3
pc_ena 4 pixel 3
Slide paper #2 vertically across paper #1, 5 steps at a time, (paper 2 starts at the bottom, then you slide it vertically upwards) to see where each data is in your output pipe.  Remember, the numbers in red which all have the same pixel number in green are your 5 correct functional MUX_#_POS.  (Use the smallest possible valid pipe).  And every time your shift the paper vertically 5 steps, the next 5 pixels should line up to the same 5 MUX_#_POS.
Subtracting the pixel number at the reg output from the bottom line on page 1, plus 1 gives you to total number of 25MHz screen pixels it takes from address# in on your gpu multiport ram, to data out#.
I hope this helps.  Note that this is the most difficult part of your project.  There may be a few simpler tricks to do this, but, this offers maximum flexibility and upgrade paths as the 5 ports can address anything and all results are given in parallel.
Remember, the 5 'MUX_#_POS' are 5 localparams you will set.
The 5 localparams are identical for the addr_out# & cmd_out# pip selection.  It's only the *8 which will change to *20 for the address_pipe reg and *16 for the cmd_pipe reg.
Post by: BrianHG on November 11, 2019, 03:03:42 pm
To the more advance users out there, yes, all the 5 channel memory buses and shift pipes could be compacted down to a single reg in a single line with just the right expression within two brackets[], latching and shifting muxing, demuxing the entire results.  For example for the 5 data bytes output register, all 40 bits of the grouped buss may be latched on 1 line time with the right 8 bit (1 word) offset from the source pipe.  This could make the multi-port-ram module nothing more than a 3 lines of code for the 3 muxed buss inputs, and another 3 for the 3 bus outputs.  same for the 5x20bit address meaning a 100bit address input and 100 bits out with the right 20bit offset when latching the entire demux pipe.
However, this GPU project is an exercise for beginners and having me just dictate all these compact tricks to tap memory in a sequence pipe, aligning it to a multiphase system clock would not explain:
What I have done.
How it works.
Why it works.
Why I did it that way.
How can I design my own version?
What can I use it for?
Where should I use it?
Well, you should get the idea.
Post by: nockieboy on November 11, 2019, 05:29:01 pm
One empty printer cartridge and sore wrist later...  ;D
Okay, so I'm starting with paper #2 below #1, so the first step brings pc_ena 0 pixel 0 into pc_ena pos 0.
So after 10 steps, I get this:
into data_pipe [5*8+7:5*8] <= pc_ena 0 pixel 0
into data_pipe [4*8+7:4*8] <= pc_ena 1 pixel 0
into data_pipe [3*8+7:3*8] <= pc_ena 2 pixel 0
into data_pipe [2*8+7:2*8] <= pc_ena 3 pixel 0
into data_pipe [1*8+7:1*8] <= pc_ena 4 pixel 0
into data_pipe [0*8+7:0*8] <= pc_ena 0 pixel 1
inside ram 2                        <= pc_ena 1 pixel 1
inside ram 1                        <= pc_ena 2 pixel 1
addr to addr_mux                <= pc_ena 3 pixel 1
pc_ena pos 0                       <= pc_ena 4 pixel 1
So the five correct functional values are:
5,
4,
3,
2,
1??
2 pixels then?  ???
That makes me feel so much better knowing this is the most difficult part.   :o ;D
So my code looks like this:
// outputs
wire [19:0] addr_mux_out;
.clk(clk),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_b(),
.data_in_b(),
.addr_out_a(addr_mux_out),
.data_out_b()
reg [9*20+19:0] addr_pipe;
reg [9*16+15:0] cmd_pipe;
localparam MUX_0_POS = 5;
localparam MUX_1_POS = 4;
localparam MUX_2_POS = 3;
localparam MUX_3_POS = 2;
localparam MUX_4_POS = 1;
// this moves the data up one word at a time, dropping the top most 8 bits
addr_pipe[19:0] <= addr_mux_out;
addr_pipe[9*20+19:1*20] <= addr_pipe[8*20+19:0*20];
cmd_pipe[15:0] <= cmd_mux_out[15:0];
cmd_pipe[9*16+15:1*16] <= cmd_pipe[8*16+15:0*16];
begin
addr_out_0 <= addr_pipe[MUX_0_POS*20+19:MUX_0_POS*20];
addr_out_1 <= addr_pipe[MUX_1_POS*20+19:MUX_1_POS*20];
addr_out_2 <= addr_pipe[MUX_2_POS*20+19:MUX_2_POS*20];
addr_out_3 <= addr_pipe[MUX_3_POS*20+19:MUX_3_POS*20];
addr_out_4 <= addr_pipe[MUX_4_POS*20+19:MUX_4_POS*20];
cmd_out_0 <= cmd_pipe[MUX_0_POS*16+15:MUX_0_POS*16];
cmd_out_1 <= cmd_pipe[MUX_1_POS*16+15:MUX_1_POS*16];
cmd_out_2 <= cmd_pipe[MUX_2_POS*16+15:MUX_2_POS*16];
cmd_out_3 <= cmd_pipe[MUX_3_POS*16+15:MUX_3_POS*16];
cmd_out_4 <= cmd_pipe[MUX_4_POS*16+15:MUX_4_POS*16];
end
case (pc_ena[2:0])
3'b000 : begin
end
3'b001 : begin
end
3'b011 : begin
end
3'b100 : begin
end
3'b101 : begin
end
endcase
end // always @clk
endmodule
CLK_CYCLES_MUX, RAM and PIX aren't used yet?
Post by: BrianHG on November 11, 2019, 11:57:57 pm
Don't threat, I am deliberately pushing to to take big steps, and you are doing fine for such a complex 1st project.
You are doing great.  :-+
Your bulk of code is perfect, though 2 little mistakes:  (I hope Im not making one....  ;) )
You need to push all the pixels on the right up by 1 more since the 'pc_ena pos 0' is the time in 'IF (pc_ena pos == 0)' statement and not a register.  At the beginning of 'pc_ena pos == 0', 'addr to addr_mux's output  should holding the last 'pc_ena 4 pixel 1' and  'pc_ena pos == 0' should be ready to take the next pixel 'pc_ena 0 pixel 2'... This also adds 1 whole pixel to the pixel pipe delay.
Next: (I corrected your offset figures)
localparam MUX_0_POS = 6;
localparam MUX_1_POS = 5;
localparam MUX_2_POS = 4;
localparam MUX_3_POS = 3;
localparam MUX_4_POS = 2;
Is functional, however, there is a smarter way to fill these out and it includes my earlier hint:
localparam   CLK_CYCLES_PCENA  = 5;  // Adjust this figure to the number of clock cycles per pixel.
Currently, in your code, your first mux takes 1 clock and the INTEL altsyncram megafunction takes 2 clocks:
inside ram 2                               2 clock cycles here for INTEL's altsyncram function.
inside ram 1
addr to addr-mux                       1 clock cycle here for you current MUX code.
PC_ENA pos0
Now, also knowing that PC_ENA has 5 positions per pixel, and using those 3 reference 'CLK_CYCLES_xxxx' which describes the # of clocks as each step in your delay pipe, write a formula which fills in all 5 'localparam MUX_#_POS's numbers.
Next, test you formula against a slower addr-mux algorithm which takes 2 clocks instead of 1 clock.
Step 1:Example, fill in 'localparam   CLK_CYCLES_MUX  = 2'
Step 2, change table on page 1 so addr-mux has 2 clock steps:
inside ram 2
inside ram 1
addr to addr-mux        step #2
addr to addr-mux        step #1
PC_ENA pos0
Now verify that you formula generating the 5  'localparam MUX_#_POS's have valid pipe positions.
Do this a few more times with 'CLK_CYCLES_MUX  = 3', 'CLK_CYCLES_MUX  = 4', CLK_CYCLES_RAM  = 3'.
Everything else you wrote looks correct.  :-+
Also, you should realize trying to properly unmux the data stream coming out of the ram could never be done properly any other way without pure luck.  And with luck, if you ever had to increase a number of clock steps in for example the addr-mux stage, or, the FPGA's altsyncram dual port ram function, everything would fall apart and luck again would be needed to hope you get the right output all in parallel.
Post by: BrianHG on November 12, 2019, 05:28:48 am
Ok, next....
You will need to create a 16 kilobyte "gpu_ram_init.mif" file.  This file should contain my Atari font beginning at byte 4'h0800 & the test memory text file beginning at byte 4'h1000.
Next, remove my old 2 alt synccrams from the OSG generator and wire in your new "multiport_gpu_ram.v".
You will need to appropriately cross wire in my old addresses into the 20 bit address, hard wiring the upper addresses to the 2 bases 4h'0800 & 4h'1000.
Also, in my old code, each read took 2 pixel clocks, now each new ram read takes 3 pixel clocks.  (even I might have counted wrong here, but I'm pretty sure it's 3...)
This means touching up inside the OSD:
parameter   PIPE_DELAY =  4;   // This parameter selects the number of pixel clocks which the output VDE and syncs are delayed
//  The disp_x is the X coordinate counter.  It runs from 0 to 512 and stops there
//  The disp_y is the Y coordinate sounter.  It runs from 0 to 256 and stops there
assign disp_pos[4:0]  = disp_x[8:4] ;  // The disp_pos[4:0] is the lower address for the 32 characters wide display ascii text.
assign disp_pos[8:5]  = disp_y[7:4] ;  // the disp_pos[8:5] is the upper address for the 16 lines of text
//  The result from the ascii memory component 'altsyncram_component_osd_mem'  is called letter[7:0]
//  Since disp_pos[8:0] has entered the read address, it takes 2 pixel clock cycles for the resulting letter[7:0] to come out.
//  Now, font_pos[12:0] is the read address for the memory block containing the font memory
assign font_pos[12:6] = letter[6:0] ;       //  Selec the upper font address with the 7 bit letter, note the atari font has only 128 characters.
assign font_pos[2:0]  = dly2_disp_x[3:1] ;  //  select the font X coordinate with a 2 pixel clock DELAYES disp_x address.  [3:1] is used so that every 2 x pixels are repeats
assign font_pos[5:3]  = dly2_disp_y[3:1] ;  //  select the font y coordinate with a 2 pixel clock DELAYES disp_y address.  [3:1] is used so that every 2 y lines are repeats
//  The resulting font image, 2 bits since I made a 2 bit color atari font is assigned to the OSD[1:0] output
//  Also, since there is an 8th bit in the ascii test memory, I use that as a third OSD output color bit.
assign osd_image[1:0] = osd_img[1:0];
assign osd_image[2]   = dly2_letter[7];  // Remember, it takes 2 pixel clocks for osd_img[1:0] data to be valid from read address letter[6:0]
// AND
osd_ena_out  <= dly2_dena; // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown
                           // It needs to be delayed by the number of pixel clocks required for the above memories
You should be able to recreate your last OSD image perfectly.  If so, congratulations, you passed the 50% mark of completing version 1.0!.
If you have time, you should now think about getting 12bit color working as this is coming up next.
Then comes proper dynamic display of any memory as text or graphics at any resolution.
This is the fun part is coming...  You will soon need to think about videos, not just pictures, but, you will need to fill the memory_init file with data for things to happen and you will need to get a Z80 connected with software to achieve anything interesting.
Post by: nockieboy on November 12, 2019, 09:05:28 am
inside ram 1
PC_ENA pos0
localparam MUX_0_POS = 6; // pixel offset positions in their respective synchronisation
localparam MUX_1_POS = 5; // pipelines (where the pixels will be found in the pipeline
localparam MUX_2_POS = 4; // when pc_ena[3:0]==0).
localparam MUX_3_POS = 3; //
localparam MUX_4_POS = 2; //
To get the MUX_x_POS values from those parameters, I've come up with this:
MUX_POS = 2*CLK_CYCLES_MUX + 2*CLK_CYCLES_RAM + 2*CLK_CYCLES_PIX - (POS + 10);
It's not elegant, but seems to do the job and works with parameter changes as far as I can tell.  I've had to add another parameter - POS - which replaces the _x_ in MUX_x_POS...  And I'm not 100% happy with the constant '10' being in there... so I guess what I'm trying to say is that I'm not 100% happy with the formula...  ::)
I know Verilog isn't a programming language, but is there any chance we can replace all those MUX_x_POS parameters with a single array of values and access them using POS as the index?
Yeah, with my luck it'd blow up or something.  :o
Post by: nockieboy on November 12, 2019, 11:47:15 am
Ok, next....
That's done.  File attached (gpu_16K_RAM.mif).
You make it sound so easy... :o
I'm a little confused about how to wire up the 5 batches of address, data and command buses.  Well, actually, completely clueless.   :scared:
So disp_pos is a 9-bit address that needs to go into the new multiport_gpu_ram module, and needs to be shifted to address the display RAM portion of memory starting at 0x1000 in gpu_16K_RAM.mif.  This needs to be put into a 13-bit address value - disp_addr for example:
wire disp_addr[12:0];
disp_addr[12] = 1'b1;    // set 13th bit to 1 to start address at 0x1000
disp_addr[8:0] = disp_pos[8:0];    // map display position address into new memory address
And to get the font data, which uses a 10-bit address, I'll need to map its address into a new 11-bit address for the new memory like so:
wire font_addr[11:0];
font_addr[11] = 1'b1;    // set 12th bit to 1 to start address at 0x800
disp_addr[9:0] = font_pos[9:0];    // map display position address into new memory address
Above is pseudo-Verilog code... I'm writing this from the top of my head at the moment (not a great place to start from!)  ::)
But, in any case, I'm not sure where these values should be going into the multiport_gpu_ram instance and what I should be doing with the masses of unassigned inputs?
// create a multiport GPU RAM handler instance
multiport_gpu_ram gpu_RAM(
.clk(clk),
.pc_ena_in(pc_ena),
.clk_b(),
.write_ena_b(),
.addr_in_0(),
.addr_in_1(),
.addr_in_2(),
.addr_in_3(),
.addr_in_4(),
.addr_host_in(),
.cmd_in_0(),
.cmd_in_1(),
.cmd_in_2(),
.cmd_in_3(),
.cmd_in_4(),
.pc_ena_out(),
.addr_out_0(),
.addr_out_1(),
.addr_out_2(),
.addr_out_3(),
.addr_out_4(),
.addr_host_out(),
.cmd_out_0(),
.cmd_out_1(),
.cmd_out_2(),
.cmd_out_3(),
.cmd_out_4(),
.data_out_0(),
.data_out_1(),
.data_out_2(),
.data_out_3(),
.data_out_4(),
.data_host_out()
Is that second-to-last line of code correct?  Assigning osd_image[1:0] to itself?  (Assuming osd_img is a typo)
// AND
[/code]
Yeah, not quite there yet with the code.  ;)
If you have time, you should now think about getting 12bit color working as this is coming up next.[/code]
Ah okay - will see what I can do.
 ;D
Looking forward to getting the host connected and getting a working video console.  That'll be a big win for me.
Post by: BrianHG on November 12, 2019, 11:51:42 am
inside ram 1
PC_ENA pos0
Ok, I'll give this one to you in a simpler way, but, to do so in a simple way, I've added 1 parameter, PIXEL_PIPE.  PIXEL_PIPE needs to be large enough so that the 'MUX_4_POS' doesn't become a negative number, otherwise, you will get a compile error and need to increase the new 'PIXEL_PIPE' parameter until 'MUX_4_POS' is a positive integer.
parameter   PIXEL_PIPE = 3;  // This externally set parameter defines the number of 25MHz pixels it takes to receive a new pixel from a presented address
localparam CLK_CYCLES_PIX = 5; // adjust this figure to the number of 125MHz clocks there are for each pixel, IE number of muxed inputs for each pixel
//  This parameter begins with the wanted top number of 125Mhz pixel clock headroom for the pixel pipe, then subtracts the additional 125MHz clocks used by the _MUX and _RAM cycles used to arrive at the first pixel out, DEMUX_PIPE_TOP position.
localparam  DEMUX_PIPE_TOP    =  (( (PIXEL_PIPE - 1) * CLK_CYCLES_PIX ) - 1) - CLK_CYCLES_MUX - CLK_CYCLES_RAM;
localparam MUX_0_POS = DEMUX_PIPE_TOP - 0;  // pixel offset positions in their respective synchronisation
localparam MUX_1_POS = DEMUX_PIPE_TOP - 1;   // pipelines (where the pixels will be found in the pipeline
localparam MUX_2_POS = DEMUX_PIPE_TOP - 2;   // when pc_ena[3:0]==0).
localparam MUX_3_POS = DEMUX_PIPE_TOP - 3;   //
localparam MUX_4_POS = DEMUX_PIPE_TOP - 4; //
// Now that we know the DEMUX_PIPE_TOP, we can assign the top size of the 3 pipe regs
reg [DEMUX_PIPE_TOP*8+7:0] data_pipe;
reg [DEMUX_PIPE_TOP*20+19:0] addr_pipe;
reg [DEMUX_PIPE_TOP*16+15:0] cmd_pipe;
// We also need to limit the pipe in the 3 ' <= '
data_pipe[DEMUX_PIPE_TOP*8+7:1*8] <= data_pipe[ (DEMUX_PIPE_TOP-1) *8+7:0*8]; // shift over the next 9 words in this 10 word, 8-bit wide pipe
addr_pipe[DEMUX_PIPE_TOP*20+19:1*20] <= addr_pipe[ (DEMUX_PIPE_TOP-1) *20+19:0*20];
cmd_pipe[DEMUX_PIPE_TOP*16+15:1*16] <= cmd_pipe[ (DEMUX_PIPE_TOP-1) *16+15:0*16];
Post by: BrianHG on November 12, 2019, 12:09:24 pm
First, only mistakes in gpu_dual_port_ram_INTEL.v:
.address_b (addr_b[ (ADDR_SIZE-1) :0]),
.clock1 (clk_b),
.wren_b (wr_en_b),
.address_a (addr_a[ (ADDR_SIZE-1) :0]),
Changed the 'ADDR_SIZE)' to '(ADDR_SIZE-1)'.
Changed the 'ADDR_SIZE - 1' to 'ADDR_SIZE'.
Next comes the 'vid_osd_generator.v'.
Post by: BrianHG on November 12, 2019, 12:39:28 pm
Ok, I know we are 'Jerry' rigging my old disp_x/y addresses into this new algorithm, so temporarily, we will use wires to make this happen and temporarily touch up my OSD code.  The next step will make all of this obsolete, however, for now let's do it like this:
Insert the following into the OSD code:
wire [19:0] read_text_adr;
wire [19:0] read_font_adr;
assign read_text_adr[8:0]   = disp_pos[8:0];
assign read_text_adr[9]      =  1b'0;
assign read_text_adr[19:10] = 1'h4;
assign read_font_adr[9:0]   = font_pos[9:0];
assign read_font_adr[19:10] = 1'h2;
Now, pass  read_font_adr &  read_text_adr into 2 memory address 'addr_in_#()' ports of your liking.
And in the appropriate 'data_out_#()' ports, place the 'letter[7:0]' and 'char_line[7:0]'.
Without any other changes, this should generate a messed up text display as my old pipe delays were designed for 2 pixel clocks on each read, not the new current 3.  To fix this, you need to make the changes I listed in red:
parameter   PIPE_DELAY =  6;   // This parameter selects the number of pixel clocks to delay the VDE and sync outputs.  Only use 2 through 9.
assign font_pos[12:6]= letter[6:0] ;       // Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
assign font_pos[2:0]   = dly3_disp_y[3:1] ;  // select the font x coordinate with a 2 pixel clock DELAYED disp_x address.  [3:1] is used so that every 2 x lines are repeats
assign font_pos[5:3]   = dly3_disp_y[3:1] ;  // select the font y coordinate with a 2 pixel clock DELAYED disp_y address.  [3:1] is used so that every 2 y lines are repeats
assign osd_image[1:0] = osd_image[1:0];  You are working with the wrong version of OSD generator. You already changed this line to convert a 8bit font line into 8 individual pixels, 1 bit color B&W font, remember?
assign osd_image[2] = dly3_letter[7];  // Remember, it takes 2 pixel clocks for osd_img[1:0] data to be valid from read address letter[6:0]
      osd_ena_out  <= dly4_dena;   // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown
Post by: BrianHG on November 12, 2019, 12:53:12 pm
 :palm: There is a bug in your mux (partially my bad...) in the 'multiport_gpu_ram.v', however, we will fix it after you get your garbled text with the current version.  It's one of those 'gotcha' things which would leave many helpless without running a simulator, even so, it would take days to fix depending on the rest of the design.  Don't threat, the real solution is easy if you know what you are doing, we will fix it next.
Post by: nockieboy on November 12, 2019, 01:30:12 pm
Righto - I've pasted that in before the multiport_gpu_ram declaration.
wire [9:0] font_pos;
wire [8:0] disp_pos;
wire [2:0] osd_image;
.clk(clk),
.pc_ena_in(pc_ena),
.clk_b(),
.write_ena_b(),
.addr_in_0(read_font_adr),
.addr_in_1(read_text_adr),
.addr_in_2(),
.addr_in_3(),
.addr_in_4(),
.addr_host_in(),
.cmd_in_0(),
.cmd_in_1(),
.cmd_in_2(),
.cmd_in_3(),
.cmd_in_4(),
.pc_ena_out(),
.addr_out_0(),
.addr_out_1(),
.addr_out_2(),
.addr_out_3(),
.addr_out_4(),
.addr_host_out(),
.cmd_out_0(),
.cmd_out_1(),
.cmd_out_2(),
.cmd_out_3(),
.cmd_out_4(),
.data_out_0(letter[7:0]),
.data_out_1(char_line[7:0]),
.data_out_2(),
.data_out_3(),
.data_out_4(),
.data_host_out()
All done.
Yeah, I'd commented the line out where I'd changed it as you specified 'assign osd_image[1:0] = osd_image[1:0];' in place of 'assign osd_image[1:0] = char_line[(~dly4_disp_x[3:1])];'.  Which should I be using?
      osd_ena_out  <= dly4_dena;   // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown[/code]
Done.  I've also added the extra dly lines.
module vid_osd_generator ( clk, pc_ena, hde_in, vde_in, hs_in, vs_in, osd_ena_out, osd_image, hde_out, vde_out, hs_out, vs_out,
wren_disp, wren_font, wr_addr, wr_data );
// To write contents into the display and font memories, the wr_addr[15:0] selects the address
// the wr_data[7:0] contains a byte which will be written
// the wren_disp is the write enable for the ascii text ram.  Only the wr_addr[8:0] are used as the character display is 32x16.
// the wren_font is the write enable for the font memory.  Only 2 bits are used of the wr_data[1:0] and wr_addr[12:0] are used.
// tie these ports to GND for now disabling them
input clk;
input [3:0] pc_ena;
input hde_in, vde_in, hs_in, vs_in;
output osd_ena_out;
reg    osd_ena_out;
output [2:0] osd_image;
output hde_out, vde_out, hs_out, vs_out;
reg hde_out, vde_out, hs_out, vs_out;
input wren_disp, wren_font;
input [15:0] wr_addr;
input [7:0] wr_data;
reg  [9:0] disp_x,dly1_disp_x,dly2_disp_x,dly3_disp_x,dly4_disp_x;
reg  [8:0] disp_y,dly1_disp_y,dly2_disp_y;
reg  dena,dly1_dena,dly2_dena,dly3_dena,dly4_dena;
reg  [7:0] dly1_letter, dly2_letter;
reg  [7:0] hde_pipe, vde_pipe, hs_pipe, vs_pipe;
.clk(clk),
.pc_ena_in(pc_ena),
.clk_b(),
.write_ena_b(),
.addr_in_2(),
.addr_in_3(),
.addr_in_4(),
.addr_host_in(),
.cmd_in_0(),
.cmd_in_1(),
.cmd_in_2(),
.cmd_in_3(),
.cmd_in_4(),
.pc_ena_out(),
.addr_out_0(),
.addr_out_1(),
.addr_out_2(),
.addr_out_3(),
.addr_out_4(),
.addr_host_out(),
.cmd_out_0(),
.cmd_out_1(),
.cmd_out_2(),
.cmd_out_3(),
.cmd_out_4(),
.data_out_2(),
.data_out_3(),
.data_out_4(),
.data_host_out()
//  The disp_y is the Y coordinate counter.  It runs from 0 to 256 and stops there
// Get the character at the current x, y position
assign disp_pos[4:0]  = disp_x[8:4] ;  // The disp_pos[4:0] is the lower address for the 32 characters for the ascii text.
//  Now, font_pos[12:0] is the read address for the memory block containing the character specified in letter[]
//  The resulting 2-bit font image at x is assigned to the OSD[1:0] output
//  Also, since there is an 8th bit in the ascii text memory, I use that as a third OSD output color bit
always @ ( posedge clk ) begin
if (pc_ena[2:0] == 0) begin
hde_pipe[0]   <= hde_in;
vde_pipe[0]   <= vde_in;
vde_pipe[7:1] <= vde_pipe[6:0];
vde_out       <= vde_pipe[PIPE_DELAY-2];
hs_pipe[0]    <= hs_in;
hs_pipe[7:1]  <= hs_pipe[6:0];
hs_out        <= hs_pipe[PIPE_DELAY-2];
vs_pipe[0]    <= vs_in;
vs_pipe[7:1]  <= vs_pipe[6:0];
vs_out        <= vs_pipe[PIPE_DELAY-2];
// This OSD generator's window is only 512 pixels by 256 lines.
// Since the disp_X&Y counters are the screens X&Y coordinates, I'm using an extra most
// significant bit in the counters to determine if the OSD ena flag should be on or off.
if (disp_x[9] || disp_y[8])
dena <= 0; // When disp_x > 511 or disp_y > 255, then turn off the OSD's output enable flag
else
dena <= 1; // otherwise, turn on the OSD output enable flag
if (~vde_in)
disp_y[8:0] <= 9'b111111111; // preset the disp_y counter to max while the vertical display is disabled
else if (hde_in && ~hde_pipe[0])
begin // isolate a single event at the begining of the active display area
disp_x[9:0] <= 10'b0000000000; // clear the disp_x counter
if (!disp_y[8] | (disp_y[8:7] == 2'b11))
disp_y <= disp_y + 1; // only increment the disp_y counter if it hasn't reached it's end
end
else if (!disp_x[9])
disp_x <= disp_x + 1;  // keep on addind to the disp_x counter until it reaches it's end.
// *** These delay pipes registers are explained in the 'assign's above
dly1_disp_x <= disp_x;
dly2_disp_x <= dly1_disp_x;
dly3_disp_x <= dly2_disp_x;
dly4_disp_x <= dly3_disp_x;
dly1_disp_y <= disp_y;
dly2_disp_y <= dly1_disp_y;
dly3_disp_y <= dly2_disp_y;
dly1_letter <= letter;
dly2_letter <= dly1_letter;
dly3_letter <= dly2_letter;
dly1_dena   <= dena;
dly2_dena   <= dly1_dena;
dly3_dena   <= dly2_dena;
dly4_dena   <= dly3_dena;
end // ena
end // always@clk
endmodule
Post by: BrianHG on November 12, 2019, 01:36:02 pm
'assign osd_image[1:0] = char_line[(~dly4_disp_x[3:1])];' is the right line as your 8bit font ram needs yo be turned into 8 individual pixels.
Since I don't know how quartus deals with a missing clock on a dual port ram, for now, feed a clock here:
      .clk_b(clk),
For all other unused inputs, set them to '0', so at least you are sure they are doing nothing...
Hopefully you can compile the thing and get a first picture.
Post by: nockieboy on November 12, 2019, 01:45:23 pm
Yeah, getting it to compile was problematic - there were a few errors, but nothing insurmountable.
I'm not sure about the fix for this one, though:
Error (10663): Verilog HDL Port Connection error at multiport_gpu_ram.v(75): output or inout port "cmd_out" must be connected to a structural net expression
The lines in question is this one:
reg [15:0] cmd_mux_out;              **** I APPLIED FIX HERE - CHANGED TO 'WIRE'
// create a GPU RAM instance
.clk(clk),
.clk_b(clk_b),
.wr_en_b(wr_en_b),
.addr_b(),
.data_in_b(),
.cmd_out(cmd_mux_out),    *********** THIS LINE IS WHERE THE ERROR POINTS TO
.data_out_b()
As stated in the code sample above, I changed the cmd_mux_out from a REG to a WIRE and it compiles now... Not sure that later breaks something else, though?
Off to see what the output is like on my screen....   :-BROKE
EDIT:
Just getting a black screen...
Here's the data I'm passing to the multiport_gpu_ram module:
.clk(clk),
.pc_ena_in(pc_ena),
.clk_b(clk),
.write_ena_b(1'b1),
.addr_in_2(20'b0),
.addr_in_3(20'b0),
.addr_in_4(20'b0),
.addr_host_in(20'b0),
.cmd_in_0(16'b0),
.cmd_in_1(16'b0),
.cmd_in_2(16'b0),
.cmd_in_3(16'b0),
.cmd_in_4(16'b0),
.pc_ena_out(),
.addr_out_0(),
.addr_out_1(),
.addr_out_2(),
.addr_out_3(),
.addr_out_4(),
.addr_host_out(),
.cmd_out_0(),
.cmd_out_1(),
.cmd_out_2(),
.cmd_out_3(),
.cmd_out_4(),
.data_out_2(),
.data_out_3(),
.data_out_4(),
.data_host_out()
Post by: BrianHG on November 12, 2019, 01:50:07 pm
Does your altsyncram memory have anything in it?
Post by: BrianHG on November 12, 2019, 01:57:59 pm
Something else is off, otherwise the "addr_out" would have a similar error.
Post by: nockieboy on November 12, 2019, 02:25:04 pm
Nope.  :palm:  Was just testing.  ;)
Still getting a black screen, though.  Latest files attached.
That's what I thought, but I can't see any differences that would cause the error for cmd_out and nothing else...
There is another error message after it - this is both together in the compilation report:
Error (12152): Can't elaborate user hierarchy "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM"
Post by: nockieboy on November 12, 2019, 02:38:57 pm
Don't outputs from modules have to be wires?  So cmd_mux_out should be a wire that is assigned to a reg somewhere else?
Have tried this, with cmd_tmp_out being a wire on the cmd_out output of the module, and with the cmd_mux_out <= cmd_tmp_out in the always block, but still getting a black screen.
Post by: BrianHG on November 12, 2019, 02:41:09 pm
Your .mif file is still wrong and it should be in the main file path.
here is what you have now:
      altsyncram_component.init_file = "../osd_mem.mif",
defparam
altsyncram_component.address_reg_b = "CLOCK1",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_a = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
altsyncram_component.indata_reg_b = "CLOCK1",
************************ altsyncram_component.init_file = "../osd_mem.mif",   *************************************
altsyncram_component.intended_device_family = "Cyclone IV E",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.operation_mode = "BIDIR_DUAL_PORT",
altsyncram_component.outdata_aclr_a = "NONE",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_a = "CLOCK0",
altsyncram_component.outdata_reg_b = "CLOCK1",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_port_b = "OLD_DATA",
altsyncram_component.width_a = 8,
altsyncram_component.width_b = 8,
altsyncram_component.width_byteena_a = 1,
altsyncram_component.width_byteena_b = 1,
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK1",
altsyncram_component.init_file = "gpu_16K_RAM.mif";
also, make:
   .write_ena_b(1'b1),
into a
   .write_ena_b(1'b0),
Your not writing anything to ram....
The only difference I could find is this: (See red)
   addr_pipe[DEMUX_PIPE_TOP*20+19:1*20]   <= addr_pipe[(DEMUX_PIPE_TOP-1)*20+19:0*20];
   cmd_pipe[DEMUX_PIPE_TOP*16+15:1*16]      <= cmd_pipe[(DEMUX_PIPE_TOP-1)*16+15:0*16];
Post by: BrianHG on November 12, 2019, 02:42:35 pm
cmd_out is currently not being use, so I'm not worried about that.
Check your compiler reports and see how much 'ram' is being used...
Post by: nockieboy on November 12, 2019, 03:21:47 pm
defparam
Darn it - missed the component.init setting near the top - added another at the bottom.  Beginner's mistake.   :palm:
also, make:
   .write_ena_b(1'b1),
into a
   .write_ena_b(1'b0),
Chalk that one up to confusion over active high/low signals.
Okay, have removed the bit in red, but it's the same for the data_pipe as well (that specifies [7:0] and doesn't generate an error).  Still getting the same error after compilation - must be to do with outputs from the module needing to be wires.
According to the compilation report:
Flow Status                 Successful - Tue Nov 12 15:16:18 2019
Quartus Prime Version       18.1.0 Build 625 09/12/2018 SJ Lite Edition
Family                     Cyclone IV E
Device                     EP4CE6E22C8
Timing Models             Final
Total logic elements     168 / 6,272 ( 3 % )
Total registers             127
Total pins             10 / 92 ( 11 % )
Total virtual pins     0
Total memory bits     8,224 / 276,480 ( 3 % )
Embedded Multiplier 9-bit elements 0 / 30 ( 0 % )
Total PLLs             1 / 2 ( 50 % )
Still just a black screen...  :(
Post by: BrianHG on November 12, 2019, 03:34:11 pm
Family                     Cyclone IV E
Device                     EP4CE6E22C8
Timing Models             Final
Total registers             127
Total memory bits       8,224 / 276,480 ( 3 % ) OOOPSSSS this should be at least 131072....
The memory isn't being allocated...
Try this, all the parameters where you have NUM_WORDS = 2**ADDR_SIZE, change that to NUM_WORDS=16384.
There is another thing to try if this doesn't work.
Inside the 'altsyncram_component', hard wire the ADDR_SIZE to 14 and NUM_WORDS to 16384.
Post by: nockieboy on November 12, 2019, 03:43:30 pm
Okay, nothing happening still.  I've hardwired the values into the ALTSYNCRAM component, still no joy.
Here's my gpu_dual_port_ram_INTEL code:
module gpu_dual_port_ram_INTEL (
// inputs
input clk,
input clk_b,
input wr_en_b,
input [19:0] addr_a,
input [19:0] addr_b,
input [7:0] data_in_b,
// direct outputs
output wire [7:0] data_out_a,
parameter NUM_WORDS = 16384;
// define delay pipe registers
reg [3:0] pc_ena_pipe;
// Dual-port GPU RAM
// Port A - read only by GPU
// Port B - read/writeable by host system
// Data buses - 8 bits / 1 byte wide
altsyncram altsyncram_component (
.clock0 (clk),
.wren_a (1'b0),
.address_b (addr_b[13:0]),
.clock1 (clk_b),
.data_b (data_in_b),
.wren_b (wr_en_b),
.address_a (addr_a[13:0]),
.data_a (8'b00000000),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.init_file = "../gpu_16K_RAM.mif",
altsyncram_component.numwords_a = 16384,
altsyncram_component.numwords_b = 16384,
altsyncram_component.widthad_a = 14,
altsyncram_component.widthad_b = 14,
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK1";
always @(posedge clk) begin
rd_addr_pipe_a <= addr_a;
addr_out_a <= rd_addr_pipe_a;
cmd_pipe <= cmd_in;
pc_ena_pipe <= pc_ena_in;
pc_ena_out <= pc_ena_pipe;
end
endmodule
Reported memory usage is still 8,224 / 276,480 (3%)  :(
Post by: BrianHG on November 12, 2019, 03:47:21 pm
way too few logic elements too:
This is enough just for the sync generator and IO.
What was the logic element count when the project used to display text?
It's time to learn how to read the compiler reports, and see what is being left out.  I have a feeling it may be connected to the odd error where you placed a 'REG' to fix the bug.
Can you zip it and send a copy.  I believe it's a .html file.
Worst case, I may have to install Quartus on one of my PCs.
Post by: nockieboy on November 12, 2019, 03:58:59 pm
Not sure what's going on here in the compilation report:
Warning (14284): Synthesized away the following node(s):
Warning (14285): Synthesized away the following RAM node(s):
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a8"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a9"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a10"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a11"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a12"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a13"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a14"
Warning (14320): Synthesized away node "vid_osd_generator:inst10|multiport_gpu_ram:gpu_RAM|gpu_dual_port_ram_INTEL:gpu_RAM|altsyncram:altsyncram_component|altsyncram_tnf2:auto_generated|ram_block1a15"
Quartus isn't saving the compilaton report as a file - there's probably a setting somewhere for it - although there is an export option in the r/click menu that doesn't seem to work.
Post by: BrianHG on November 12, 2019, 04:19:24 pm
Quartus isn't saving the compilaton report as a file - there's probably a setting somewhere for it - although there is an export option in the r/click menu...
That part is just the rough overview.  You should be able to enter a complete breakdown usage report where the compiler tells you everything it has done with every file in your project.
No memory should have been simplified away.  Something fishy is happening.
Ok, try this one weird thing I used to have to do:
Inside "gpu_dual_port_ram_INTEL.v":
wire [7:0] sub_data_out_a;        // ***NEW***
wire [7:0] data_out_a = sub_data_out_a[7:0];      // ***NEW***
wire [7:0] sub_data_out_b;      // ***NEW***
wire [7:0] data_out_b = sub_data_out_b[7:0];      // ***NEW***
.clock0 (clk),
.wren_a (1'b1),
.address_b (addr_b[ADDR_SIZE - 1:0]),
.clock1 (clk_b),
.wren_b (wr_en_b),
.address_a (addr_a[ADDR_SIZE - 1:0]),
.q_a (sub_data_out_a),      // ***NEW******NEW******NEW******NEW***
.q_b (sub_data_out_b),      // ***NEW******NEW******NEW******NEW***
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
ALSO:  you have not set the ".defparam" for the multiport_gpu_ram gpu_RAM() in the osd generator, though, the sub_modules should have ended up using their default values.
I'm downloading QuartusPrime 18.1 now.  How big is you project in .zip?
Post by: nockieboy on November 12, 2019, 05:11:44 pm
Quartus freaks with those declarations - I've had to change:
as they're already declared as outputs.  Changed them to:
assign data_out_a = sub_data_out_a[7:0];      // ***NEW***
assign data_out_b = sub_data_out_b[7:0];      // ***NEW***
... which compiles, but still to a black screen.
Yes, spotted that earlier but didn't think it'd matter as the sub-modules should use their default values.
Just over 7 MB - too big for the forum, unless I just archive the main files and ignore the sub-folders (db, greybox_tmp, incremental_db, output_files)?
Post by: BrianHG on November 12, 2019, 06:13:31 pm
I've confirmed that the 'gpu_dual_port_ram_INTEL.v' compiles fine as it's own project.  See here:
[attach=4]
[attach=3]
As you can see, Quartus Prime reports 45% of your FPGA ram being used.
Next, I made a stand alone project with 'multiport_gpu_ram.v' as the top in it's own project, with the ''gpu_dual_port_ram_INTEL.v'' being accessed within.  See here:
[attach=2]
[attach=1]
As you can see, Quartus Prime still reports 45% of your FPGA ram being used.  So, there is nothing wrong with the 5 channel multiport module.  Next, I'll try the OSD code.
And this is with the cmd_mux_out as a 'WIRE':
wire [15:0] cmd_mux_out;
Next, I'll try the OSD module.  Things like this usually lie down with a typo, or, you forgot to 'ADD SOURCE FILES' to your project and make the top hierarchy you top .bdf file.
YUP: The error is in the OSD module.  Give me a few minutes...
[attach=5]
[attach=6]
See, we dropped to 3% ram usage.  Now, why?  Something is amiss.
Post by: nockieboy on November 12, 2019, 07:25:02 pm
Clearly something up with the osd module...
I have the project zipped and in a shared dropbox folder - if you pm me your email, I'll add you to it so you can download the entire project.
Post by: BrianHG on November 12, 2019, 07:27:14 pm
Found it!
In the OSD generator, I had:
When it should have been:
assign read_text_adr[19:10] = 10'h4;        // my mistake, I has 1bit instead of 10bits
assign read_font_adr[19:10] = 10'h2;        // my mistake, I has 1bit instead of 10bits
The compiler was shorting all the higher addresses to GND.  This means only the first [9:0] of x&y counters made it to the memory and Quartus said, hey, all other addresses are shorted to GND, so, I only need 8192 bits of ram...
There were a few other little mistakes like:
   //output reg [19:0] addr_host_out,     I never specified this port to be made...
   .wr_en_b(write_ena_b),   // **** error, you wrote (wr_en_b), it should be (write_ena_b)
   .data_out_b(data_host_out)   // ****** error, you had this field empty.
and all this wasn't updated from my earlier post:
I've attached the latest verilog files for you to use.  Also don't forget to update our top block diagram file with the OSD generator's new pipeline delay as it may still be 4.  It might be best to re-generate symbol files and clear & re-insert the OSD generator in you block diagram to clear out any old junk.
There is only the matter of patching your 'mux' in the multiport ram module, however, you should now be getting a picture.  If so, I'll explain the patch and everything should work.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: nockieboy on November 12, 2019, 08:30:30 pm
Found it!
Well done!  :clap:
...I've attached the latest verilog files for you to use.  Also don't forget to update our top block diagram file with the OSD generator's new pipeline delay as it may still be 4.  It might be best to re-generate symbol files and clear & re-insert the OSD generator in you block diagram to clear out any old junk.
No worries, all done.  Was so excited I rushed to see it working and got the black screen again...
Nope - no picture - still just a black screen.  :-\
Post by: BrianHG on November 13, 2019, 07:42:29 am
@nockieboy,  :scared: I'M GONNA MURDER YOU!!!!!!!  |O  :horse:  :rant:  :box:
Ok, you are god damn lucky I still have a Quartus 9.1 full install, with it's built in high speed logic simulator.
Let's begin.
Step 1. Simulate the 'gpu_dual_port_ram_INTEL.v'.
I made a project with only the ram with the .mif file like so:
[attach=1]
I setup a simulation feeding the above inputs to see what the outputs would look like when beginning the read address just before the ASCII text begins where you have stored 0,1,2,3,4,5,...:
[attach=2]
So far, the read of the data looks fine.
Step 2. Simulate the 'multiport_gpu_ram.v'.
I made the project feed the clock, ena, all 4 addresses, all 4 cmds, even the 'host' address & it's read results.  (I used a 484 pin Cyclone III to get the IOs)
See in green the 'host' address wiring is taken from the second addr_in.
[attach=3]
This is what the simulator gave me.
[attach=4]
WTF?  Addr ports 1 and 2 seem read to data out properly, yet, the reading of port addr4' data out has all 0s.  Also, a weird thing, the 'HOST' data out, which is also fed the addr2 reads the right data, BUT, it suddenly goes 'UU' (undefined), then goes back to 0.
Without that 'HOST' data out, seeing the data being erased, I would have never found the bug.
In you code, you have:
.clock0 (clk),
.wren_a (1'b1),  ************************F--K******************
.clock1 (clk_b),
.wren_b (wr_en_b),
.q_a (data_out_a),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
            .wren_a (1'b1),  **********F--K***********
You made the Write Enable for the read address forced on!!!!!!!!
Every address we sent to be read was instead written clear to all 0's.
It gets worse, in you mux algorithm in the 'multiport_gpu_ram.v' module, you did this:
   // perform 5:1 mux for all inputs to the dual-port RAM
   case (pc_ena_in[2:0])
      3'b000 : begin  //******** Excellent, this is state 0 and you made the case 3'b000 which equals 0.
               end
      3'b001 : begin  //******** Excellent, this is state 1 and you made the case 3'b001 which equals 1.
               end
      3'b011 : begin  //******** Hun? What? This is state 2 and you made the case 3'b011 which equals 3?
               end
      3'b100 : begin  //******** Hun? What? This is state 3 and you made the case 3'b100 which equals 4?
               end
      3'b101 : begin  //******** Hun? What? This is state 4 and you made the case 3'b101 which equals 5?
               end
   endcase
After these 2 fixes, the simulation looks like this:
[attach=5]
This is a zoom out of the simulation.  As you can see, I'm reading 5 different ports at 5 different addresses simultaneously, with all the outputs coming in parallel.
[attach=6]
Now, for the last little bit.  When performing the 'mux' the only addition I wanted to do was 'snap' all the address_# and cmd_# inputs at (pc_ena_in==0), then feed those latched results to the ram.  To do this, here is the simple addition I made to your 'case' statement in the 'mux'.
3'b000 : begin
addr_in_mux <= addr_in_0;  // Send the first, #0 addr & cmd to the memory module.
addr_lat_1 <= addr_in_1;  // latch all addr_in_# in parallel
addr_lat_2 <= addr_in_2;
addr_lat_3 <= addr_in_3;
addr_lat_4 <= addr_in_4;
cmd_lat_1  <= cmd_in_1;  // latch all cmd_in_# in parallel
cmd_lat_2  <= cmd_in_2;
cmd_lat_3  <= cmd_in_3;
cmd_lat_4  <= cmd_in_4;
end
3'b001 : begin
addr_in_mux <= addr_lat_1; //  Send the latched, #1 addr & cmd to the memory module.
cmd_mux_in  <= cmd_lat_1;
end
3'b010 : begin
addr_in_mux <= addr_lat_2; //  Send the latched, #2 addr & cmd to the memory module.
cmd_mux_in  <= cmd_lat_2;
end
3'b011 : begin
addr_in_mux <= addr_lat_3; //  Send the latched, #3 addr & cmd to the memory module.
cmd_mux_in  <= cmd_lat_3;
end
3'b100 : begin
addr_in_mux <= addr_lat_4; //  Send the latched, #4 addr & cmd to the memory module.
cmd_mux_in  <= cmd_lat_4;
end
endcase
I've attached the latest source verilog files.  Setting up 2 different Quartus' and preparing the simulation stimulus, plus finding that "Write Enable = 1" was a good 5 hours out of my day.
If you don't get a picture now, I will have no choice but to simulate your entire OSD project.
Post by: BrianHG on November 13, 2019, 08:03:33 am
@nockieboy, go here:
https://www.intel.com/content/www/us/en/programmable/downloads/software/quartus-ii-we/91sp2.html
And download QuartusII V9, sp2 and install it.  Don't worry, you can have 2 different Quartuses in your system at 1 time.
We'll use it's built in 'Quick' simulator tool to create the graphics address generator as we do not want to create the same hidden problem as above.
Note that you'll just use that Quartus to edit and simulate your verilog.v file, selecting a huge IO pincount Cyclone III, while you may use Quartus Prime to build your chip, or, that Quartus as it does support Cyclone IV, just not with simulation support.
I don't have time to teach you how to use the new Modelsim and the old abandoned forgotten built in Quartus simulator is just too fast and easy to setup/manipulate inputs and compile instantly when in 'Functional' logic mode.  Yes, the timing mode is still very quick for a small project like yours.
Post by: BrianHG on November 13, 2019, 08:37:38 am
Ooops, 1 typo: In 'vid_osd_generator.v', fix this one line #99:
         gpu_RAM.PIXEL_PIPE = 2;    // set the length of the pixel pipe to offset multi-read port sequencing
It said gpr_RAM instead of gpu_RAM.
Post by: nockieboy on November 13, 2019, 09:26:43 am
Let's begin...
...You made the Write Enable for the read address forced on!!!!!!!!
:palm: So sorry about the write enable setting.  That's because I'm used to LOWs being the active state with all the Z80 work I've been doing recently - I have to stop and check every time I look at a 1'b0 or 1'b1 now.  ::)   |O
Thank you for persevering and finding the issues.
               end
               end
               end
               end
               end
   endcase
:palm:  I can count in binary, honest!  :-[
It's really difficult for me to maintain a good focus on this when I'm working around it, doing bits here and there, then coming back to it later.  I can only mark this mistake up to some earlier code I'd written when I made case statements for all 8 combinations of the 3-bit pc_ena value, before you reminded me that it resets at 4, and not checking the conditions when I deleted the extra states.
Okay, I've made the additions to the code, fixed the stupid errors, and almost got it to compile.  :o
In vid_osd_generator.v:
defparam gpu_RAM.ADDR_SIZE = 14, // pass ADDR_SIZE into the gpu_RAM instance
I was getting negative indexes in the demux pipe in multiport_gpu_ram.v.  The pipeline wasn't deep enough, so I upped gpu_RAM.PIXEL_PIPE value to 3 and it compiles now.
This is what I'm getting on the screen now...
[attach=1]
Post by: nockieboy on November 13, 2019, 10:25:38 am
Here's my workspace:
[attach=1]
Post by: BrianHG on November 13, 2019, 10:52:11 am
Don't threat too bad, FPGAs are a new experience for those who buy CPU and wire and software program them.
- get used to wiring everything as POSITIVE logic.
- if you want a negative input or output, place an 'EXP' by the final pin.
- if you can't count binary eg " 4'b1010 ", instead use hex " 4'h0A " or decimal " 4'd10' ".
There were numerous other errors.  Today has turned into a non-stop 10 hour debug fest.  Nothing wrong with the architecture, it's just when I correcting what you have written, I have no experience on how you typed everything in.
Here is why your text is scrambled:
   .addr_in_0(read_font_adr[19:0]),
   .addr_in_1(read_text_adr[19:0]),
The text and font was backwards.
This is what my full simulation setup looks like (Yes, full OSD output now.)
[attach=1]
[attach=2]
There were a few other little patches.  Please don't change any of the pixel pipe settings until we get clean text.  A pipe error would just shave a pixel on one side of the letters.
Now, I've attached my Quartus project to see if it opens in Prime.
To make it work on you PCB, all you need to do is change the FPGA to your FPGA IC#, enter the pin numbers. (Delete my test unused IOs), and add a PLL.  You can always install QuartusIIv9sp2 since it supports Cyclone IV, and, it's a lot faster.
Post by: BrianHG on November 13, 2019, 11:08:29 am
I just opened my 'GPU_OSD_Sim_q2v9.zip ' project in Quartus Prime 18.1.
[attach=1]
During the open, it asks you to switch to a Cyclone IV or Max10 FPGA chip.
On the top hierarchy, only the parameter boxes need to be adjusted in size to show all the variables due to the system font being different.
Lets work with this version as it is a clean virgin with no old crap lingering around.
(You can tell by the .zip file size.)
Don't forget to set your IO pins and add a PLL to get 125MHz.
LOL, QuartusIIv9sp2 = 15 seconds for compile.
        Quartus Prime  = 40 seconds for compile.
Post by: BrianHG on November 13, 2019, 12:02:38 pm
Ive added the PLL and changed the project to a Cyclone IV IC, I believe it's the one on your dev board.
You still need to assign the IO pins.
I also setup the timing analyzer so it give you valid results.
Do not worry that I set the clock to 54Mhz, technically, you are just slightly under-clocking the design for now, but the PLL has been setup so that our builds are capable of driving DDR-IOs to transmit a home built HDMI serdes directly.
LOL, my architecture is so well laid out, even though we asked for 135MHz, quartus says it can achieve 238MHz, and this is on a -c8, the slowest version of the FPGA.
LOL, the C6 with my code will run at 315MHz....
Post by: nockieboy on November 13, 2019, 12:06:11 pm
Ookay... switched to the clean project now, added a PLL and just had to change a timing error in the sync generator on line 67:
if (pc_ena[3:2] == 0) // once per pixel
... was too slow for the monitor - changed it to pc_ena[2:0] and I'm getting this picture now:
[attach=1]
Post by: BrianHG on November 13, 2019, 12:27:16 pm
(Attachment Link)
Arrrrgggg this:
Everywhere????
How????
Ok, patching everything...
Here is the patched project.
When uploading you latest xxxx.v files on the forum, please make sure they are actually the latest versions.
I feel as if I'm revisiting errors patched long ago...
Now, I hope the text come out correct.  The simulation on my side has the right horizontal size for the text box.  Only an addressing error on the font address would mean garbled up letters (since I only get an oscilloscope waveform), or, the conversion from the 8bit wide font into a 1 bit pixel.
Post by: BrianHG on November 13, 2019, 12:33:31 pm
(Attachment Link)
Look carefully, your Microcom text is there, it's just the FONT which isn't being rendered properly.
Post by: BrianHG on November 13, 2019, 04:32:52 pm
Again, half old code, half new code error.....
This code was hald the original Atari 2 bit font and half the 8bit atari font code squished together.
assign font_pos[12:6]   = letter[6:0] ;       // Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
It should be this way, and you had it this way since you were able to display the red text:
assign font_pos[9:3]   = letter[6:0] ;       // Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
Please, Please, Please, when doing corrections, please post you latest updates.  It's taking hours to find something I though was already working just to find that the last xxxxx.v source code you posted has bugs in it, yet you had a fine picture back with the 8bit Atari font in red...
Please be more careful in the future.  I should not be fixing these problems as I feel like I'm giving you wrong directions, yet my layout is fine.
From now on, lets star using revision numbers and dates for each verilog module.  The next stuff coming up isn't as huge, but a single mistake to our existing code will lead to hours of debugging not knowing where the problem originates.
(This took hours to proof by simulation....)
Make this attachment your new project and if it works and you are ready, we will tackle the universal pixel pointing read address generator.
(If everything works and you are waiting for me, think about getting the 4 bit RGB dac working...)
Also, install:
https://www.intel.com/content/www/us/en/programmable/downloads/software/quartus-ii-we/91sp2.htmlYour going to need it for engineering the address generator.
Post by: nockieboy on November 13, 2019, 07:03:50 pm
Okay, got the new project working, code is up on github (https://github.com/nockieboy/gpu) - but I'll only update that repo with working commits.
I'm with you on the versioning - it will clear up confusion with all these updates and corrections.
:palm:
 :phew: It works...
[attach=1]
This might have to wait a day or so, depending on how much free time I have tomorrow.
Also, install:
I'm having real trouble downloading that package - seems the download link is broken?  :palm:  I'll keep working at it.
Post by: SiliconWizard on November 13, 2019, 07:16:19 pm
Wow, BrianHG has been really helpful and really patient...
Post by: nockieboy on November 13, 2019, 07:21:05 pm
I feel bad enough as it is.  :'(
Post by: BrianHG on November 14, 2019, 01:59:14 am
Here nockieboy, and to anyone else who wants a copy of '91sp2_quartus_free.exe' install.
91sp2_quartus_free.rar (https://wetransfer.com/downloads/41dd4f099fc3c6d56349c140da21297420191114010918/8874200f4f97784caa401b21626d967620191114010918/a83338)
(The file will be at this link for only 7 days.)
It's the official Windows download version, just after the point when Altera removed the licensing features.
Note that you should still use the new Quartus Prime USB Blaster Drivers especially with Windows 10.
Both Quartus can be installed in one system and they can both run at the same time.
When simulating your verilog code, in QuartusIIv9, you need to select a CycloneIII or earlier FPGA.  Cyclone IV will compile for the chip, but will not simulate.
Making small dedicated projects to test out each xxxx.v core before adding them to your main project is the norm.
Post by: BrianHG on November 14, 2019, 02:10:24 am
For the new year, I'm leaving electronic engineering and heading into management.  I'll never have time left to do electronic ever again.  Since I'm currently at the last of my free time, I figured, I'm going to do 1 last special thing, and 'nockieboy' hit the jackpot.  I don't know who he's going to sell of push this little core to, but, It will be capable of doing more than a SuperNintendo and quite a bit towards a full VGA card, up to 720x480 modes, memory dependent.  I hope he is ready for documenting all the function controls which are coming up next, making a board with HDMI (DVI) out, and perhaps we might have time for stereo 16 channel sound too.  All by January....
Post by: BrianHG on November 14, 2019, 04:35:05 am
Just found a source code for a HDMI serializer with audio support!.
https://www.realdigital.org/doc/189f72e0ee822643d7946fb639754841 (https://www.realdigital.org/doc/189f72e0ee822643d7946fb639754841)
It's good as a guide, but we don't want realdigital.org copyright (We are allowed to use it if we give credit & ask permission), and the final verilog output module uses Xilinx specific serdes function.  It's enough to work with to create a 480p version which uses non-dedicated serdes hardware and will compile on all FPGA vendor suites.
Post by: BrianHG on November 14, 2019, 05:08:03 am
Lattice FPGA part numbers price VS ram:
4 megabit / 512kb for 30$ usd, 26.60$ for 25.  (actual 400 kilobytes realistically.)
LFE5U-85F-6MG285C (https://www.mouser.com/ProductDetail/Lattice/LFE5U-85F-6MG285C?utm_term=LFE5U-85F&qs=Rp3RbKSfAt3i%252b4nmoAgpiw==&utm_campaign=LFE5U-85F-6MG285C&utm_medium=aggregator&utm_source=findchips&utm_content=Lattice)
(LOL, with an added flash card reader port added to the FPGA, your GPU could playback full motion 360x480 video with 65k colors...)
2 megabit / 256kb for 16$ usd.    (actual 200 kilobytes realistically.)
Unfortunately, not pin-pin compatible with the 4mbit version.
LFE5U-45F-6BG256C (https://www.mouser.com/ProductDetail/Lattice/LFE5U-45F-6BG256C?utm_term=LFE5U-45F-6&qs=w%2Fv1CP2dgqpblS%252b2xYE99A%3D%3D&utm_campaign=LFE5U-45F-6BG256C&utm_medium=aggregator&utm_source=findchips&utm_content=Lattice)
(360x240 65k color full motion video possible with an accelerated flash card reader.)
Strangely enough, these are the faster -6 grade, not the slowest -8 grade versions of the chips.
Post by: nockieboy on November 14, 2019, 08:54:41 am
Well, first of all, thank you.  :-+  Secondly, it's a hobby project that started out as an attempt to learn about electronics and broaden my programming skills - it has clearly ballooned into something much bigger than anything I could have wished for at the start.  :o  I'm not intending to sell anything - I seriously doubt I could make a living (or even some pocket money) from what I've developed, but I do want to get my act together and create a website that will document my journey and help anyone else out wanting to try the same thing.
My original end goal, simple as it was (on the face of it  :o ), was to create a little 8-bit system I can plug into my TV and play some games I've written for it, like Pong or a Rogue-like - with better specs than my first computer I had as a kid.  The GPU (and sound, I guess) is the last part of the puzzle, really.
Post by: nockieboy on November 14, 2019, 09:08:31 am
Those Lattice chips are quite tempting. So it looks like I need to start getting my head around designing for and soldering BGA packages, as that's the way the GPU card is going, it seems.  Whilst the MAX10 is very desirable in terms of features and simplicity, the cost is prohibitive.
Sheesh, you're kidding, right?  I knew using an FPGA for the graphics was going to be overkill, but that takes the biscuit!  :-DD
Post by: BrianHG on November 14, 2019, 09:15:00 am
Ok, next step, not only will you want to simulate test, but, you will want to actually modify memory while running the GPU.  Do you have any means of doing this?
Which CycloneIV dev board are you using?  Do you have schematics of it?  Is there a way to interface with it?
Post by: nockieboy on November 14, 2019, 09:22:04 am
I'm using one of these:
[attachimg=1]
Have found some good resources here for it: http://fpga.redliquid.pl (http://fpga.redliquid.pl)
Have attached a file called VGA Schematic.pdf.  It seems to show extra connections for more VGA colour resolution?  Hmm.. seems that's an add-on module, perhaps.  There's certainly no resistor networks on the board...
Post by: BrianHG on November 14, 2019, 10:02:52 am
Next is the address generator/graphics instruction engine.
Here are the targeted controls/capable features:  (We want to make 1 identical algorithm which will be used 4 times.)
1) Enable/disable.  Requires 1 bit.
2) The base/beginning of a memory address which contains either the screen text data, font data, graphics data and sprite data.  (This eats 20 bits since we can address 1 megabyte for this address)
3) Vertical memory increment size.  When beginning a new line, this is the amount added every time to the base address.  (16 bits is fair, maximum 64kb wide picture.)
4) Pixel type.  1bit=8 pixels wide per byte 2 colors per pixel,
                       2bit=4 pixels per byte 4 colors per pixel,
                       4bit=2 pixels per byte 16 colors,
                       8bit=1 pixel per byte, 256 colors,
                      16bit=2 bytes per pixel, 65k true-color
          = 5 settings possible meaning requires 3 bits for this setting.
5)  X scale.  Counts the number of pixels wide each bitmap image pixel will occupy.  1 through 16 (4 bits)
6)  Y scale.  Counts the number of lines each bitmap image line  will occupy.  1 through 16 (4 bits)
7) Sub-pixel starting X&Y coordinates.  This setting vertically & horizontally shifts the image up and to the left by single pixels in text mode and 4/2/1 bit color modes.  IE, smooth scrolling of text horizontally by up to 7/8th of 1 character, then you can change the base memory address by 1 character and reset this setting back to 0 allowing you to move the text pixel by pixel horizontally and vertically. The shift 16 pixels x by 16 pixels y , or 8 bits total.
8 )  Special control for font size.  8x8 pixel bitmap to 16x16 bitmap.  4 bit control.
9)  Total number of video lines to render before loading a new set of the above controls.  This will allow you to switch video modes mid screen, EG: have a window of 40 column text for half the screen, then switch to 80 column text for the bottom half.
Have I missed anything.  The total here is around 14 control bytes, or, we will reserve 16 bytes per address generator and call it safe.
Extra Note: The horizontal and vertical windows and enables for the 16 sprites will be stored separately.  10bit X 10 bit Y.
Palettes also have a dedicated separate set of registers.  A programmable interrupt generator based on a selected line of video will also be added for smooth animation apps.
Post by: nockieboy on November 14, 2019, 10:08:53 am
Okay, so this is the Z80<->GPU interface.  I'll need a block of logic in the GPU that responds to memory reads in the desired address range and passes the data from the GPU RAM to the host, and accepts writes to the desired address range and updates the GPU RAM with the written data.  This may take a little time and trial-and-error to build, but I'll get right on it.
Post by: BrianHG on November 14, 2019, 10:10:39 am
Oh, I see you have RS232.  Good.  Do you have terminal software on you PC?
I can stuff together an ultra stupid bridge to your HOST_ram port so you may set memory contents.
Can you create a dumb utility on your PC to read and write binary to the com port in a format I will describe?
Let's face it, once the stuff I listed above begins to function, immediately, you will want to test and play beyond just seeing a simulation and static tests once every Quartus compile and you can work on a PC making test scripts.
Note if you do not hace any programming language on your PC, if you can program Basic, I have a free 64bit basic compiler which can access the com port.
Post by: nockieboy on November 14, 2019, 10:24:29 am
Here are the targeted controls/capable features:  (We want to make 1 identical algorithm which will be used 4 time.)
2) The base/beginning of a memory address which contains either the screen text data, font data, graphics data and sprite data.  (This eats 20 bits since we can address 20mbytes for this address)
No, it sounds like you've covered everything and more besides.  :o
This (multiple) address generator/graphics instruction engine (let's follow in the footsteps of the Amiga architects and call it MAGGIE - jhpadjustable will be proud  ;D ) - if this is going to handle graphics as well as (tiled) text modes, would this be where we'd want to consider adding hardware-accelerated drawing commands?  i.e. the host could pass a command, say 'FILL', 'LINE', 'BOX' or 'CIRCLE', and a parameter or two and MAGGIE would fill the GPU RAM according to that command and parameters?  If so, is 16 control bytes enough?  Am I getting ahead of myself?
Post by: Berni on November 14, 2019, 10:33:00 am
There is a "JTAG to Avalon MM bus" block provided by Quartus for doing exactly this.
You instantiate the block inside the FPGA and then use TCL scripting in Quartus to issue read and write commands to it. I used it a few times to exercise some peripherals on a bus, but my bus was Avalon based to begin with so it worked out of the box. If you have a different bus type (Like a Z80) you need to build a adapter for it. Also TCL is not that great of a language in my opinion.
Tho building your own UART and a simple protocol parser for it is a pretty good exercise in HDL. It also lets you easily write PC software in any language you like since serial ports are easy to use under Windows or Linux in all the common programing languages. Just make sure that the UART protocol is really simple so that the FPGA can parse it without much work. It will also probably also  come in very useful once you have your Z80 running since you can use it as a debug interface into your GPU, Especially if you write a nice tool that displays the state of memory registers and a hex editor to roam around video RAM.
In principle it could also have the debug interface tell the FPGA to single step the Z80 trough gating its clock or holding the wait line. But if you wanted to live debug the Z80 a better solution is getting some Z80 ICE system to put a "Emulated Z80" into the socket and get all of the real time debugging functionality like seeing all the CPU registers
Post by: nockieboy on November 14, 2019, 10:35:02 am
I use PuTTY to access my Microcom at the moment via a USB-TTL interface (FT232) on the Microcom itself - but I don't have a RS232<->USB adapter, so the RS232 port is a little useless on the FPGA board as I have no way of using it.
I was going to wire up the Microcom to the FPGA and get access to the RAM that way, as it would mostly just require the electrical connection between the two systems and some logic in the FPGA to read the memory accesses from the Microcom.  I could POKE data into the FPGA with no software development necessary, or even get it sending console output to the FPGA with a little tweaking of the BIOS/monitor software.
The FPGA board has a USB connector on it that I use to power the board - not sure that would be a viable alternative route?
Yes - might take a little trial and error, but that's how I program, it seems.  ::)
I use C# in Visual Studio 2017 on the (rare) occasions  I need to do something in a language other than Z80 assembly, PHP or Javascript.
EDIT:  re: the Z80<->GPU interface, the one complicating factor I keep forgetting about is the level conversion.  Going to need a breadboard with a few chips on it to convert between 5v and 3.3v...
Post by: BrianHG on November 14, 2019, 10:49:53 am
     Nope, lateron you might make a graphics co-processor which will share the HOST memory interface.  It should be able to fill or draw 130 million 8 bit pixels a second, or, copy 65 million pixels a second, with a transparent color.  (IE Software sprites)  This one would roast anything the Amiga AGA chipset can do when in 256 color mode, or, any color mode.  Expect the Lattice FPGA to double this speed.  This wont be register control based, rather it would be a script of instructions gathered from system memory.  I would engineer it to operate this way so you may have a compiled script screen elements to render in multiple tight strings of bytes which your CPU can request it to run.
     Realtime scaling of images during the copy is possible, but, you wont get there using simple QuartusIIv9.1 as a simple simulation tool.  You will need to learn how to use Modelsim and deal with M.N floating point math in verilog.  I've done it on my video scaler and you are talking about a serious commitment, like a month or 2 just learning how to use Modelsim effectively, (this will be the most boring month of your life, I avoided it) at your beginner level.   Especially when trying to maintain that high FMAX which is needed to fill pixels as fast as possible.
Post by: BrianHG on November 14, 2019, 11:05:02 am
Ok, so yes, you do have a serial interface.  Yes?  Doesn't matter, as long as you can make your PC talk to the board, right?
If so, let's see what I come up with.
Post by: nockieboy on November 14, 2019, 11:14:31 am
Erm... I thought Quartus II had some way of updating FPGA memory while it was on...?  Found this - not sure if this is of any use at all?
In-System Updating of Memory and Constants (http://ridl.cfd.rit.edu/products/manuals/Altera/In-System%20Memory%20Content%20Editor/qts_qii53012.pdf)
Perhaps it only works with single-port memory, but for the purposes of testing we could scrub the host port to the RAM and give Quartus II access to the RAM that way?
Post by: Berni on November 14, 2019, 11:28:43 am
Yeah you can also do those for editing things that are memory blocks. It looks like its fully TCL scriptable too. Tho it will likely eat up one port on a dual port RAM block, so if you still need them being dual port in your design that might be an issue.
Also you will most likely keep hardware configuration registers as normal register rather than block RAM. Those won't show up in the memory editor. So the best universal way that works for everything is injecting read and write commands just like the Z80 would. It also inherently tests tests things are accessible at the right addresses since its accessing them in the same way the Z80 would.
Or if you want to be really authentically oldschool with this project you can wire up the address bus to switches and have LEDs show bits like it did on the Altair computer. ;D Just joking, some things are best left in the past.
Post by: BrianHG on November 14, 2019, 11:34:32 am
(Attachment Link)
Copy their DAC design, only the top 4 bits of each color, wired to a header where the 12 wires all come from 1 bank if possible.  Take a look at the SEG and DIG resistors R46 to R57, that's 12 bits there (Remove those resistors).  Copy the resistor dac schematic you sent me, the upper 4 bits of each color, and wire in place of R14,R15,R16. by the VGA connector.  Key the current H&V sync wires attached.
Post by: nockieboy on November 14, 2019, 11:40:56 am
Yes, it looks like it uses one of the ports as it says in the document I linked that it only supports single-port RAM, so that's most likely why.
Really?  The only way the Z80 will be able to access the GPU is via a window in its physical memory space where the GPU exposes its own RAM - so a section of the GPU RAM will need to be reserved for configuration, the rest for the GPU RAM itself, and the Z80 will be writing to RAM whether it's setting or reading hardware configuration or screen memory.  What the GPU does with the configuration bits is another matter, but they'll be set in RAM initially.
Yes, and I hope to get some sort of interface with the Z80 up and running as soon as possible for just that reason - maybe at the weekend, if I'm lucky.  I suspect it will require fair bit of debugging to get working - probably another thread's worth, knowing me - but I could just be being pessimistic.  ???
Hahaha - you're a funny guy.  ;)
Post by: BrianHG on November 14, 2019, 11:41:28 am
It's a combination of ram and addressable registers.
I already have a dumb verilog UART to parallel ram read/write debug port.
The interface is a really dumb 1 byte command, 1 response, but, It's idiot proof. (I hope)
I'll fetch it tonight.
It's also good for forcing memory read and writes while the Z80 is wired in.  With 125Mhz dedicated ram port for the HOST, I dont think the speed of the Z80 will ever eat any significant access time.
Post by: Berni on November 14, 2019, 12:31:24 pm
Yeah these dumb, zero configuration, "it just does one thing" kind of peripherals are what i like in FPGAs.
And yes the Z80 will be using it trough a memory window, but its not practical for this memory window to be all block RAM. Its only possible to access one word at a time in block RAM trough one port. This is great for buffers, character maps, lookup tables where you only need to look at one (or a few) locations in memory at a time.
Hardware configuration registers are different. Because these register need to affect the operation of your circuitry means that the bits in those registers are wired out to individually so that there state can affect the input of some logic gate inside the logic circuitry. To make this possible you can build your own RAM with flip flops in the logic fabric. This is usualy what "reg something; something <= 1" ends up being. Since they are individual flip flops means they can be wired up in any way you like. To make these memory mapped you need a tiny local address decoder that selects the correct register when its address is fed in. So perhaps the first 1KB of the Z80 visible memory map might be reserved for hardware registers and the rest is passed trough as a window into block RAM.
These registers are more expensive in terms of FPGA resources so you generally only use them when you need it. They would store things like config bits, status bits, adjustable video timings, pointers to memory... etc that only take a single word to store, not store big things like image data in these.
Post by: nockieboy on November 14, 2019, 12:53:04 pm
Okay, 12-bit DAC is up and running.  Well, aside from the additional outputs from the FPGA - there's no signals to put out yet, but it's ready to go when needed.  :-+
Post by: BrianHG on November 14, 2019, 03:09:23 pm
Ok, I've attached a 12bit color version + with a test RS232 debugger.
Select 2 IOs and use your FTDI TTL RS232 transceiver.
Use 115200 baud, 8N1.  No handshaking, no xon/xoff.  Full duplex.
Go into a terminal software and type.  Your typing should appear on the OSD, plus, it should also be echoed back to your terminal software.  Hitting the reset button will reset the invisible cursor to the home position.
If this works, I'll add the control commands and send you a small basic program with windows compiler which will allow you to read and write any memory addresses.  You can setup the Basic software read or dump files as well.
Post by: SiliconWizard on November 14, 2019, 03:27:23 pm
Congrats!
Get ready for a complete change in your daily activities, and learn to say "no", which is one of the hardest parts of management. (Another one is sometimes being "compressed" between the doers and the deciders. ;D )
Post by: asmi on November 14, 2019, 05:55:18 pm
It's going to be the complete opposite. Sitting your pants off in endless stupid meetings talking about stuff nobody cares about is what's the average manager's work day looks like in a large company. And pretending to be super-busy to his/her boss by sending insane amount of emails that few people read or even care about. So yeah - you'll probably have all the time in the world to think about (and maybe even read about) electronics during those meetings because a lot of them won't even be designed to be useful or productive. I know I had. And you will also have higher-quality spare time because if something in your systems breaks down during off-work time, you won't be the one rushing into the office/firing up your laptop and connecting to your office network and sitting there long past midnight trying to get things to work again.
Just remember one thing - talking about stuff never gets anything done, only doing does. So don't bring your engineers into meetings unless you're absolutely sure this is going to be that unicorn of a meeting where something relevant is going to be discussed and decided (the last part is super-important!).
I used to be a manager, but returned into engineering after I realized what that job was all about, and was bored to death in those meetings, which I now hate with passion and always demand a crystal-clear agenda before I even consider attending one. This does not apply to engineers-only meetings - they tend to be useful, but you won't be participating in them anymore.
Post by: nockieboy on November 14, 2019, 06:27:47 pm
Okay, have downloaded the latest project, put it in a new folder, compiled it, assigned pins to the 12-bit RGB output, clock, reset, hsync and vsync, and connected my USB-TTL lead to the board, connecting Tx and Rx and setting up the serial port in PuTTY according to your instructions.  Have not changed anything else.
Am getting this:
[attach=1]
As you can see, what I'm typing in PuTTY is getting echoed back to the terminal (have tried it with Tx/Rx reversed on the board to make sure it's wired up correctly - obviously nothing comes back at all), but nothing is appearing on the screen.
I'm just hunting through the code to see if there's any obvious reason it's not working for me, but it's going to be something I've done wrong...
EDIT:  Also, just a thought, but isn't the output of the USB-TTL a 5v signal?  If that's the case, isn't there a chance I could be damaging the IO on the board?  (Note: I have only got the Rx/Tx and GND connected to the board - RTS and CTS are 'connected' to inactive (tri-stated) IO pins, as I don't want to pull the connector apart to isolate just Tx, Rx and GND, if that makes sense.
gpu_16K_RAM.mif wasn't included in the list of project files, but since I've added that it hasn't made any difference either.
Post by: jhpadjustable on November 14, 2019, 08:31:24 pm
It's possible. It depends on the USB-to-serial adapter in your hand. Some might be switchable. Some might default to 3.3V. Some might be designed by someone for easy money who just doesn't care. The only way to know for sure is to check it with a meter.
(MAGGIE. I like that. Very Simpsons.  ;D )
Post by: nockieboy on November 14, 2019, 10:24:06 pm
Yeah, it was more of a rhetorical question I guess; I knew the answer before I even wrote it.  I've stopped using the TTL-USB cable, will dig out a TTL-USB board from my box of bits - I know they have a jumper on them to set the voltage to 5v or 3v3.  Will look at trying that tomorrow.  Also, must stop 'writing out loud'...  :-DD
Thought you would.  ;)  And getting the Simpsons reference as well.  ;D ;D
Now if we can name another module 'BART', we're on to something. Blitter And Raster Timer? If we integrate audio into the FPGA, that module will definitely be 'LISA'.  Linear Integrated Stereo Audio?
I'm open to better suggestions.  :popcorn:
Post by: BrianHG on November 14, 2019, 11:37:43 pm
Am getting this:
(Attachment Link)
Funny, with no rs232 text into the board, you should still have the original test text.  Your typing should overwrite the test text as you type.
If your echo is coming from the FPGA you didn't kill your FPGA since the echo of the text I made goes through IP code.
If you see your text still and your terminal software doesn't have local echo enabled, or half duplex enabled, this means my RS232 baud rate is correct and the UART, fifos, status flags are all 100% functional as all these need to work correctly to pass a character through.  It's just for some reason, at least 16k worth of writes somehow made it through the com port erasing your font and everything else.
Test #1, disconnect the 'host_wr_ena' like so:
[attach=1]
This will stop the write and show the original text font test pattern.  Otherwise, something else went wrong.
Your color palette looks wrong.  Could be you need a pull-down resistors on the RGB, or decoupling caps as well, or the RGB ports are wired wrong.  Remember, R(3:0), not R(1:0).  Check your pin assignments as these may be assigned to the wrong pins.
Yes, i just downloaded the 'GPU_12bitcolor_rs232debugger_test.zip' and checked.  The 'gpu_16K_RAM.mif' is in there.
Test #2, put back the 'host_wr_ena' and change this 1 line in my source code: (Line 56, rs232_DEBUGGER.v')
if (ena_rxd_dly) host_addr_reg   <= <= DEBUG_RST_ADR ; //host_addr_reg + 1;
This should stick any writes to cursor position 1, so, every key you hit should only show the new letter pressed at that 1 top left cursor position.  The letter should stay, not blink.  If this works, don't worry, my actual writes will be protected by a setup string preventing + a write enable lock which will be on by default during powerup.
Post by: jhpadjustable on November 15, 2019, 12:22:19 am
Block Area/Alpha Renderer/Rotator and Translator, depending on how far you want to push it.
Paula and other simple sample engines transition instantly between one frame of the sample and the next. The decimation in the time domain and the loop ticks are audible, and may be undesirable (or not). We'll build NCOs (https://en.wikipedia.org/wiki/Numerically-controlled_oscillator), use phase accumulators to set playback rate (like SID), and use the fractional part to Linearly Interpolate between the previous and current value over the sample period. But that's for later. BrianHG appears to be on a deadline and I don't want to get in his way. :)
Post by: BrianHG on November 15, 2019, 12:55:53 am
I've attached 2 dumb terminal programs.  Termite and Hexcom.
Note that in termite, I switched off local echo and append CL/LF in the transmit setting.
Try these guys.  I think Putty may be flushing the com port with junk and as my test software checks nothing at all, all it doe is dump incoming characters to adjacent memory addresses, Putty might have been a bad choice.
Hexcom, written by my friend, allows you to receive view and transmit both ascii and hexadecimal to RS-232 and a UDP port.
Termite is a third party software.
Post by: BrianHG on November 15, 2019, 03:48:49 am
It's going to be the complete opposite. Sitting your pants off in endless stupid meetings talking about stuff nobody cares about is what's the average manager's work day looks like in a large company. And pretending to be super-busy to his/her boss by sending insane amount of emails that few people read or even care about. So yeah - you'll probably have all the time in the world to think about (and maybe even read about) electronics during those meetings because a lot of them won't even be designed to be useful or productive. I know I had. And you will also have higher-quality spare time because if something in your system ;Ds breaks down during off-work time, you won't be the one rushing into the office/firing up your laptop and connecting to your office network and sitting there long past midnight trying to get things to work again.
I'm going to be at the top, with absolute authority & part owner of the new corp.  No one above me except my responsibilities to the investors.   ;D  I'm creating the 'agenda'.
Post by: nockieboy on November 15, 2019, 10:05:48 am
Local echo is 'forced off' in the PuTTY settings.  There's definitely no text appearing on the screen, although it's being echoed back to the terminal.
.... no change.  I've been testing different USB-TTL adapters, trying it without one plugged in at all, checked all the connections to VGA 'ladder',
I've even loaded up the previous version of the GPU project and upped it to 4-bit RGB output, and it appears to be working fine:
[attach=1]
... yes, the colours are out, but I can still see the text so something should be visible on the screen with the new project, especially if the serial port isn't connected.
Yes, they do.  I had arbitrarily wired up the resistor ladder and wasn't expecting perfect colours... I'm using something like 470R, 1.1K, 1.9K, 4K7 values - they were old resistors that I'd tested on my meter years ago and written the values on the sticker strips they were attached to (including the error margin on a couple of them by the looks of it!), but I'm not after colour perfection right now, just a visible output.  As I can see the text on the previous version of the GPU project, I'm more concerned about getting this new version working first.
If I'm going to be using this test bench for an extended length of time, I'll get a PCB made up with some 0802 resistors with proper values (or as close as) and make a proper VGA breakout board - for the moment, trusty breadboard is the medium of choice.  ::)
Haven't tried this one yet as I've stalled on the first test.
Post by: BrianHG on November 15, 2019, 10:15:11 am
For dac, all you need is 1 Kohm and 2Kohm resistors, good quality 1% or better.
For the MSB 3, tie 2x 1k in parallel, the equals 500Ohm.
For the bit    2, it's just a 1k.
For the bit    1, it's just a 2k.
For the LSB  0, it's 2 of the 2k in series, making 4k.
This makes an exact 0.5k, 1k, 2k, 4k resistor dac.
Make sure you removed tho old 1k resistors.  You cannot use different outputs across different IO banks as each bank has different clock delay and even different current ratings for the IO pins.
Post by: BrianHG on November 15, 2019, 10:33:03 am
Here, test this one.  you should see the original debug text plus some echoing characters on PUTTY.
type this exactly, match my case (or copy and paste):
WRI!These 34 letters should displayed.
If that worked then send this:
REA!
Your terminal should receive the next 34 characters which are already on the display after my text message.
If it works, I'll sen you the 4 different arguments and how they work, or let me know, I'll find/remake my old basic development utility which handles the com.
Setting the read/write address requires binary numbers, I just made these commands ascii compatible.
Post by: asmi on November 15, 2019, 03:23:34 pm
Ah, startup, I see. Good luck!
Post by: SiliconWizard on November 15, 2019, 03:59:49 pm
Oh, you won't be plagued with the problems common for middle-managers then.
Just keep in mind that the investors may/will be deciders at some point (it's always rosy at the beginning). But enjoy the ride and good luck! :-+
Post by: nockieboy on November 15, 2019, 04:07:09 pm
I've reversed the RGB connection order and, with the new project, am now getting the text display as previously:
[attach=1]
Okay, here's the result of pasting
WRI!These 34 letters should displayed. into the terminal:
In the terminal, I get:
WRI!▒▒e 34@▒ett▒▒s should ▒▒splayed.
On the screen, I get:
[attach=2]
It's trying to work - seems like a timing problem?  I've just double-checked PuTTY's settings:
115200, 8N1, Flow control: None
REA!
That's more or less what happens, but the text is slightly corrupted.  I received one string with no errors out of about 5 attempts.
Ah!  ;D  Looks like you've made a mistake on altpll0 in the project - you've got a clock source of 54 MHz??  My board is 50 MHz, so that'll throw the baud rate out enough to cause the glitches I'm seeing. Not sure how the display is okay - probably just within tolerances, I guess?
EDIT:
Yep, it's the baud rate that's the problem - I've upped UART_BAUD to 1088 (how does this relate to the clock speed?) in rs232_debugger, and am now getting almost 100% integrity on the Tx/Rx console contents:
[attach=3]
Post by: nockieboy on November 15, 2019, 05:08:13 pm
Further to my last - have gone back to the GPU_test project and changed the PLL settings for a 50 MHz source clock, updated UART_BAUD to 1090 (serial seems 100% stable now) and have re-ordered the RGB outputs.  Am now able to write to the GPU RAM:
[attach=1]
Post by: BrianHG on November 15, 2019, 06:18:51 pm
So, blank text had nothing to do with my code....
Ok, the clk54 shouldn't be a problem as Altera allows huge play on the PLL.  I know you have a 50Mhz clock source and I said 54 in the PLL settings.  All that the FPGA is concerned is that what is coming in will be multiplied by 5 then divided by 2.  And it will do it with a clock anywhere between something like 40 and 65 Mhz with the settings I have made.  The '54' mhz is just so when you compile, Quartus will make sure the project is fast enough for 480p HDMI with audio which would have a 54MHz clock source.
However, yes, the 'baud' might need to be slowed down.  It's a period number.  IE:
Frequency / baudrate.  So, (125000000 / 115200)-1 = 1084.
What number did I have?  Raising the baud number actually slightly slows down the baud rate.
Just checked, there was a bit of it which was hard wired for 27Mhz, and Im running it at 125Mhz in this project....  I'll patch it in the next release.
Note that the UART I used was a home-made 15 year old thing.  In the next update I'm giving you, I'm running the UART debugger section at 50Mhz instead of the 125MHz graphics clock, it was originally designed and used at 27Mhz.
I'm almost finished the PC software, an onscreen - keyboard & mouse point and click memory viewer/editor for the GPU.  It has hex view with ascii, binary, 8 & 16 bit decimal view and entry.  Load/Save memory blocks to binary files.  However, without a GPU, I cant test locally.  Will you be around tomorrow for testing?
With this out of the way, working on the raster memory pointer generator & with this tool, manipulating and testing both display controls and image data in real time will be easy.
Post by: nockieboy on November 15, 2019, 07:35:16 pm
Well I didn't think the RGB order was an issue, as I tested the previous version of the project and it was showing the text just fine (albeit a little off-colour!)  :-//
Ah, fair enough - well, remember I don't have years of experience with this stuff.  I was just pleased that I'd managed to fix the issue.  ::)
You had 1084 - I had to up it to 1090 to get a stable interface.
No worries, I'll know what to do if we have the same problem again.
Jeez BrianHG, you've been busy!!  :o :o :o  Yes, I'll try to be around as much as possible.  Will get up early and see what we can get done - though I've got Christmas shopping duties with the missus at some point, I'll try to keep the morning as clear as possible.  ;)  Out of interest, what are you using to write the PC software?
The serial interface is a pretty big thing for me - but I'm really excited about the next steps as well.  I'm going to keep thanking you constantly for all this help and support - seems Christmas has come early!  ^-^
Post by: BrianHG on November 15, 2019, 07:42:12 pm
Ok, I patched the UART's true baud problem.  I'm also now running the RS232 debugger at 50Mhz instead of 125Mhz.  This means the baud setting is (50000000/115200)-1 = 433.
I turned off the local echo of commands, so you wont see anything in putty unless you copy&paste the
REA!
Or, to print text on the screen, use the:
WRIaThis should work without issue.  I know it's taken much time and hassle, but, we will get there...
What time will you be available tomorrow?
Because the Basic software will need testing, we may need to use 'teamviewer' to debug it.
Post by: BrianHG on November 16, 2019, 12:01:48 am
Preview of GPUtalk.exe.
It's a Win64 application.
Just hit enter when it asks for a com number.
It will work without any GPU connected.
It's a work in progress.
Just need entry, com, and load/save and it will be ready.
Post by: nockieboy on November 16, 2019, 07:58:23 am
It seems to be reading memory, or at least the sample data?
[attach=1]
[attach=2]
Post by: BrianHG on November 16, 2019, 01:19:04 pm
Here we go with the text version.  I've attached the QuartusProject with a version which is compatible with the GPUtalk utility.
The GPUtalk utility for now only copies, displays and edits memory realtime from the GPU.  If it works ok, I'll add the bulk copy routines and fix up the load and save as they currently self erase.
@nockieboy, we will probably need to TeamView for me to certify the GPUtalk and program fixes.
Let me know when you want to hookup.
To make thing as fast as possible, I would recommend installing 'Freebasic' from here:
https://www.freebasic.net/ (https://www.freebasic.net/)
Post by: BrianHG on November 16, 2019, 02:22:27 pm
Ooops,a typo in the GUPtalk, I wasn't setting the read/write address correctly.
Here you go:
I've included a 115200 version in the zip just in case.  Well sort it out when we teamview.
Post by: nockieboy on November 16, 2019, 06:31:42 pm
Here you go:
Hmmm... now it doesn't seem to be reading the GPU memory - has it gone back to reading the demo files?  ???
Post by: BrianHG on November 17, 2019, 04:20:55 pm
Ok @nockieboy, now that the GPU_talk RS232 memory sniffer/debugger is perfectly functional, your work on the controls and features for the GPU begins now.  I'm sending an enhanced version of the GPU_talk with some added smart features for later tonight.
These are the following simple additions are required for your project before we make the address generator:
1.  Modify the core of your sync_gen.v so that the position of the active video image is shifted 16 pixels to the right by 16 lines down.  Remember, you will also need to move the sync signals as well so that the picture still remains centered with reference to the syncs timings.  Make this 2 new parameters called "IMAGE_X_OFFSET" and "IMAGE_Y_OFFSET".
2. To vid_osd_generator.v, add and pass through these parameters:
     A) 'GPU_powerup.mif' file
     B) Memory Address Bits  (take care as we want total bits here.  This means when defining the top bit in a register, it would be this value -1)
     C) Memory Words           (If this field is left empty, it's value should be calculated from (B)'s parameter )
3.  Make a new verilog module called 'GPU_HW_Control_Regs.v'.  This module should be a mass of registers which which are all available in parallel to any other part of the GPU, with an 8 bit data & address[19:0] input write port, a reset input and reset parameters for the first 32 bytes.  This one huge output register should be called GPU_HW_Control_regs[HW_REGS_SIZE*8-1:0].  Module specs:
     a)  All inputs, 8 bit data in, write data enable, 20 bit write address, and reset should be all register latched (yes, latch the reset input, then use that register's output as the module's reset).  This latching offers better FMAX timing fitting if we need to run this module on the alternate slower clock frequency. (IE, 50 Mhz clock).
     b)  A parameter, HW_REGS_SIZE , for the quantity/size bulk of 8 bit registers.  (Note, for your top hierarchy, block diagram design entry, you will place a 'param' which this module will use as it's setting, see attached image as an example.)
     c)  Base write address for the write input.  The module will always take in all 20 address bits, but when writing data to the 8 bit data input port, the upper address wires [19:8] should equal this number for the write to be successful.  If parameter (b) is >256, then the bottom of the upper base write address [8] will be ignored as you will be opening a 512 byte window, and so on.  (Set this default to the base of the last 256 bytes in your system memory.  Yes, it will occupy the same last 256 bytes as your system GPU ram.)
     d)  Reset parameters.  Have 32 8 bit parameter settings which will be forced into the first 32 bytes if the reset signal is sent.  Make the rest of the registers reset to 0.
4.  Place an input for the 'bulk GPU_HW_Control_regs[HW_REGS_SIZE*8-1:0] registers' into the following verilog modules: sync_generator.v, vid_osd_generator.v, vid_out_stencil.v.  Remember, you will need to receive the block diagram parameter into each module to get the right number of wires for the inputs.
5.  Add a new 48 register output to the 'sync_gen.v' called 'raster_HV_trigger[47:0]'.  Make the even 'raster_HV_trigger[47:0]' wires pulse at a horizontal pixel position and the odd wires pulse on a vertical line according to the new 'GPU_HW_Control_regs[HW_REGS_SIZE*8-1:0]' onput wire, organized as 16 bit words, using the first 10 of 16 bits of each 2x2 bytes coming from the new input "GPU_HW_Control_regs[HW_REGS_SIZE*8-1:0]".  You should add a new parameter input to the sync_gen.v which will allow you to shift the beginning byte base (beginning) address of GPU_HW_Controls where the 'raster_HV_trigger' get their 48 settings from.  IE 48x2 bytes = 96 bytes total.  Once done, out on your top block diagram, 'or' these 48 HV triggers outputs together and 'or' tie them to to the upper ro[],go[],bo[] bits of the OSD_img output.  Test with the GPUtalk app.  You should be able to move 24 vertical lines and 24 horizontal lines around the screen, with the first 0-15 coordinates being non-visible as those coordinates are too far to the left and above the top of the picture since we moved the picture window by 16 pixels to the right and down in step (1).  (Once working, mix and combine / change around the 'or' driven ro[]&go[]&bo[] colors VS raster_HV_trigger[47:0] even and odd pairs so each set of coordinate generated lines may generate a different color on the display.)
     Show us your progress.  Do one item at a time.  For the new modules and functions, perform a functional simulation of each one to make sure their controls work before inserting it into your design, otherwise, you are guessing to what functions and what doesn't.  Even show us the simulations as proof of functionality.  (Do this step, and you will have a full GPU working in not time at all.)
     This work is the preparation required for the image raster address generators as they require parallel hardware control registers and and some adjustable trigger events at adjustable locations during the display, including a setup time just before the active display begins.
Post by: BrianHG on November 17, 2019, 05:22:54 pm
Simulation tips:
Make you main GPU folder with a complete final project sub-folder + alternate projects for each verilog.v simulation.
  In each of those alternate folders for the simulation project, make a quartus 9 project with with a cyclone 3 FPGA and make a block diagram entry with clk and reset inputs as well as any other input pins to drive your verilog module.  Add outputs pins you wan to see from the verilog module.
  Add the verilog module by 'Adding' it's file to your quartus 9 project in quartus 9's 'Project/Add remove files in project' from your master Quartus Prime project's folder and add any other required verilog dependencies.  This way you are not copying xxx.v files back and forth.  Quartus 9's simulation will use only the verilog code in you master Quartus Prime's project folder.
  Open the xxx.v file and generate the symbol in Quartus 9, insert and wire the symbol into your simulation design.  Compile.  Create a new .vwf  (vector waveform file) and add the input and output pins, buses and regs you want to see in the simulation.  Go into simulator settings and select 'Simulation mode' "Functional" and Simulator Input "xxxx.vwf". and simulate away.
I can walk you through simulating your 'sync_gen.v' if you are having trouble.
Post by: nockieboy on November 18, 2019, 09:37:13 am
Is this really as simple as this?
// image offset parameters
parameter IMAGE_OFFSET_X = 16;    <----- added parameter
parameter IMAGE_OFFSET_Y = 16;    <----- added parameter
// no-draw area definitions
// defined as parameters so you can edit these on Quartus' block diagram editor
parameter H_FRONT_PORCH = 16;
parameter HSYNC_WIDTH   = 96;
parameter H_BACK_PORCH  = 48;
parameter V_FRONT_PORCH = 10;
parameter VSYNC_HEIGHT = 2;
parameter V_BACK_PORCH  = 33;
parameter PIX_CLK_DIVIED = 4;
// re-calculate back porch values, taking image offset into account
localparam H_ADJ_B_PORCH = H_BACK_PORCH - IMAGE_OFFSET_X;    <----- reduce back porch accordingly
localparam V_ADJ_B_PORCH = V_BACK_PORCH - IMAGE_OFFSET_Y;    <----- reduce back porch accordingly
// total screen resolution
localparam LINE = IMAGE_OFFSET_X + H_RES + H_FRONT_PORCH + HSYNC_WIDTH + H_ADJ_B_PORCH; // complete line (inc. horizontal blanking area)
localparam SCANLINES = IMAGE_OFFSET_Y + V_RES + V_FRONT_PORCH + VSYNC_HEIGHT + V_ADJ_B_PORCH; // total scan lines (inc. vertical blanking area)
// useful trigger points
localparam HS_STA = IMAGE_OFFSET_X + H_RES + H_FRONT_PORCH - 1; // horizontal sync ON (the minus 1 is because hsync is a REG, and thus one clock behind)
localparam HS_END = IMAGE_OFFSET_X + H_RES + H_FRONT_PORCH + HSYNC_WIDTH - 1; // horizontal sync OFF (the minus 1 is because hsync is a REG, and thus one clock behind)
localparam VS_STA = IMAGE_OFFSET_Y + V_RES + V_FRONT_PORCH; // vertical sync ON
localparam VS_END = IMAGE_OFFSET_Y + V_RES + V_FRONT_PORCH + VSYNC_HEIGHT; // vertical sync OFF
Post by: nockieboy on November 18, 2019, 09:57:46 am
Okay, just need some clarification here for A).  You want me to pass a reference to the init file that gpu_RAM uses so the filename can easily be changed in the design view, or you me to pass a new file?
Code including changes for B) and C) is attached.
Post by: nockieboy on November 18, 2019, 10:57:22 am
     c)  Base write address for the write input.  The module will always take in all 20 address bits, but when writing data to the 8 bit data input port, the upper address wires [19:8] should equal this number for the write to be successful...
Okay, still with you so far...  ???
...If parameter (b) is >256, then the bottom of the upper base write address [8] will be ignored as you will be opening a 512 byte window, and so on.  (Set this default to the base of the last 256 bytes in your system memory.  Yes, it will occupy the same last 256 bytes as your system GPU ram.)
Nope - lost me now. :o
So I'm supposed to set the 9th bit [8] to zero if [19:8] is greater than 256?  The bit in parenthesis is totally lost on me.
So we've got 32 hardware control registers that can be written to and are all output from the module.  These write addresses we're discussing here are to address the individual bits of the registers, but something else is going on which I don't understand if the upper 12 bits are above 256?  These registers are separate from the GPU RAM, so I guess the reference to the base address in GPU RAM is to set the HW registers from the values in a 32-byte block in GPU RAM that the host can write to?  Going to need a little more guidance on this one.  Wouldn't it make sense to have the 32 HW registers' shadow the first 32 bytes in GPU RAM?
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on November 18, 2019, 02:30:49 pm
I'll get to your 2 last comments in the next response.
Ok, 2 items:
1) The latest GPUtalk.
-I've added Load and Save dialogs, where you can now choose file names and start memory address and length of memory.  Entering nothing for the start and length automatically uses all the ram buffer.
-I've added 'm' which generates and saves a Quartus .mif Memory Initialization File.
-You can now click on the binary bits to toggle them when editing the data.
-You can now also click on the data and 16bit decimal data to enter a number.
-Using the + and - keys to increment and decrement the selected memory data does it for 2 bytes as a 16 bit word.  Using the wheel mouse to inc and dec the data value is still only 8 bit.
-When not in writing data mode, you can now click on the address to enter an address to directly jump to.
-Now, if you do not enter anything when prompted for the 'COM' number, the program bypasses all RS232 routines making it just as fast as if you were connected.  Pretty much makes it just a hex editor and .mif file generator.
2) 256 character, high res version of the GPU Quartus project.
-It will now has a 256 character font and should be in high res 64x32 characters.
-The font graphics now begin at address 0.
-There is also a Parameter in the OSD to switch to a 8x16 font.
-The .mif still has the Atari 128 character font (in case the attached VGA rom .bin fonts aren't compatible), so you will need to use the GPUtalk to load in the right font, 8x8, or 8x16 depending on the parameter setting into address 0.  Then you can now generate a new .mif file with the best looking font for you.  (Send photos.)
I've included 2 VGA fonts I got from this site:
https://github.com/spacerace/romfont/tree/master/font-bin (https://github.com/spacerace/romfont/tree/master/font-bin) -> Binary files
https://github.com/spacerace/romfont/tree/master/font-images (https://github.com/spacerace/romfont/tree/master/font-images) -> Photos of the fonts
If they work, the others should work too.
See attachments:
Post by: BrianHG on November 18, 2019, 02:59:26 pm
Oh, ok, here is how I would have done it:
localparam LINE = H_RES + H_FRONT_PORCH + HSYNC_WIDTH + H_BACK_PORCH; // complete line (inc. horizontal blanking area)
localparam SCANLINES = V_RES + V_FRONT_PORCH + VSYNC_HEIGHT + V_BACK_PORCH; // total scan lines (inc. vertical blanking area)
localparam VS_STA = IMAGE_OFFSET_X + V_RES + V_FRONT_PORCH; // vertical sync ON
localparam VS_END = IMAGE_OFFSET_X + V_RES + V_FRONT_PORCH + VSYNC_HEIGHT; // vertical sync OFF
and don't forget, you need to push the HDE and VDE screen coordinates in the middle of the code.
If you do not move the image, with your 8bit cpu, if you wan to position an action off the left edge of the screen, you would have to know about the raster width and place that controlled action on the right side of the image X&Y counter.  If you rather do things this way, then, you do not need to change the sync_gen at all.  However, any code for you MCU which uses sprites which can be scrolled off the left side of the screen will require you to place the sprite off the right side of the screen and subtract value.
Basically, though usually fixed, there are a number of settings which will need changing if you change the horizontal and vertical screen resolution where as if the screen was shifted down and to the right according to the reference H&V counter, these settings will always stay the same.
You have a judgement call to make here.  I decided to make the numbers parameters so you may turn the feature off and on lateron depending on the complexity of the horizontal line address generator features.
I'm also forcing you to setup a simulation of the sync_gen.v so you may check if the feature works correctly.
Your going to need this step.  Compile and check will no longer suffice when you need to see if each signal happens on the right pixel exactly.
Post by: BrianHG on November 18, 2019, 03:16:59 pm
Note, the HW_REGS_SIZE should be at least be 256.  Now, you need a parameter 'WRITE_BASE_ADDRESS'.
Now, for example, if we set the base address to $003F00 (16128), when the input address[19:0] = $003F00 through $003FFF, and a write enable comes in, the correct 8 bits will be filled into the right 1 of 256 GPU_HW_Control_regs.  It's basically a ram, but in regs.  Now if you have the HW_REGS_SIZE set to 512 and the 'WRITE_BASE_ADDRESS' set to $003E00 then writes from input address[19:0] = $003E00 through $003FFF would access the 512 x 8bit GPU_HW_Control_regs.  the 'WRITE_BASE_ADDRESS' can be set to anything within the 20 bit address range.  (Don't think about addr > or addr <, think about just the number of address wires in the 'WRITE_BASE_ADDRESS' and the input address[19:0] just need to be equal while the least significant address wires are are not used if addressA==AddressB test.  These low address bits are only used to point to the correct GPU_HW_Control_regs for writing the 8 bit data coming in.
Begin with this much and simulate.
As for the reset, is just like any of the other resets you have already done.  No separate handle needed.
Post by: nockieboy on November 18, 2019, 04:36:34 pm
Marvellous - works really well, thanks!
Okay, so I've changed the 8x8 font using GPUtalk without any issues:
Before:
[attach=1]
After changing to 8x8 font:
[attach=2]
But there's a problem - if I recompile the project with the parameter FONT_8x16 set to 1 in vid_osd_generator.v, I get a slightly corrupted display - which is expected as initially the GPU is powering up with the default 8x8 .mif in memory, but when I start up GPUtalk, it is constantly listing errors and takes a good 10-15 seconds to list the first page of data:
[attach=3]
This only happens when FONT_8x16 is set to 1 in vid_osd_generator...  :-//
Well, it looked like it might be working, but the errors in GPUtalk are preventing a clean bin transfer to the GPU.  I can't imagine what the problem could be, but you might have an idea?
Post by: nockieboy on November 18, 2019, 07:30:09 pm
...and don't forget, you need to push the HDE and VDE screen coordinates in the middle of the code.
Not really sure what you mean here - like this?
// handle signal generation
always @(posedge pclk)
begin
if (reset) // reset to start of frame
begin
h_count <= (H_RES - 2);
v_count <= (SCANLINES - 2);
//z_count <= 1'b0;
hsync   <= 1'b0;
vsync   <= 1'b0;
vde     <= 1'b0;
hde     <= 1'b0;
end
else
begin
if (pc_ena[3:0] == 0) // once per pixel
begin
// Horizontal blanking area - set HDE LOW
if (h_count == IMAGE_OFFSET_X + H_RES - 1)    *******  Added IMAGE_OFFSET_X in here
begin
hde <= 1'b0;
end
// check for generation of HSYNC pulse
if (h_count == HS_STA)
begin
hsync <= 1'b1; // turn on HSYNC pulse
end
else if (h_count == HS_END)
hsync <= 1'b0; // turn off HSYNC pulse
// check for generation of VSYNC pulse
if (v_count == VS_STA)
begin
vsync <= 1'b1; // turn on VSYNC pulse
end
else if (v_count == VS_END)
vsync <= 1'b0; // turn off VSYNC pulse
// reset h_count & increment v_count at end of scanline
if (h_count == LINE - 1) // end of line
begin
h_count <= 1'b0;
hde <= 1'b1;  // Turn on horizontal video data enable
// Now h_count has been zeroed, check if the V-count should be cleared at end of SCANLINES
if (v_count == SCANLINES - 1)
begin
v_count <= 1'b0;
vde <= 1'b1; // Turn on vertical video data enable
end
else
begin // If v_count isn't being cleared, increment v_count
v_count <= v_count + 1'b1; // increment v_count to next scanline
if (v_count == V_RES - 1)
vde <= 1'b0 ; // Turn off vertical video data enable - reached bottom of display area
end
end
else // not at end of scanline, so just increment horizontal counter
h_count <= h_count + 1'b1;
if (h_count == H_RES - 1)
hde <= 1'b0 ;  // Turn off vertical video data enable
end // if (pc_ena)
end // else !reset
end // always @clk
...but not sure about pushing vde - it seems to be fine as it uses triggers that incorporate IMAGE_OFFSET_Y?
This is going to take me a little time to set up and interpret correctly, but I understand that it's an important step.
Post by: nockieboy on November 18, 2019, 09:26:50 pm
Right, I'm with you.  So I can set WRITE_BASE_ADDRESS based off of HW_REGS_SIZE:
parameter HW_REGS_SIZE = 256;
parameter [HW_REGS_SIZE - 1:0] RESET_BYTES;
parameter WRITE_BASE_ADDRESS = 16384 - HW_REGS_SIZE;
Assuming I'm not out by 1 in those calculations - I seem to have real difficulty with when and where I should be subtracting 1 from the figures.  :o  But the above figures will give a WRITE_BASE_ADDRESS of $3F00, according to my trusty Windows calculator..  :-DMM
I guess the above calculation for WRITE_BASE_ADDRESS is fine as long as we always want it at the end of the GPU's RAM space.
So we're not comparing the write address against a range of suitable addresses, but instead checking for WRITE_ADDRESS[19:8] == WRITE_BASE_ADDRESS[19:8]?
Post by: BrianHG on November 18, 2019, 09:42:18 pm
There shouldn't be a problem with the GPUtalk and the 8x16 setting as it has nothing to do with the com at all.
GPU talk says 'received 0 bytes of a read expecting 256 bytes.'.  Now, GPU talk doesn't check if the com port it opened is actually working.  So it may be transmitting data into a 'NULL' port.  This could happen if another app or GPUtalk is open in the background, or, if you remember how Quartus' USB BlasterII wouldn't work when GPUtalk was left running, since USB Blaster also uses a FTDI chip like your USB-TTL RS232 cable, maybe you just need to close the USB Blaster control window, or close and re-open GPUtalk.   It might be useful to check if you USB-RS232 cable has a RXD-TXD LED.  Or, I can add a TXD/RXD Led output signal to my RS232debugger.v and you can tie those to 2 LEDs on you dev board.  Then you can see com activity regardless of the data coming in and out.  (I'm prepping a new .v file with 2 led outputs, RXD and TXD led signals.)
Post by: BrianHG on November 18, 2019, 10:38:40 pm
I've added a LED_txd and LED_rxd to the "rs232_DEBUGGER.v".  These outputs are positive logic, so, if you dev board uses active low leds, then just add the 'exp' gate between the module outputs and the IO pins.
(Note I found a bug with the low baud rate in the rs232_debugger.v, so 1 last fix will be coming after I get a days rest.)
Post by: nockieboy on November 19, 2019, 02:49:12 pm
I know - I don't think the issue is with GPUtalk, though.  :o  Nothing changes with GPUtalk, whether it's talking to the 8x8-build GPU or 8x16-build version.  Is something getting changed somehow in the RS232 module in the 8x16 build?  I know it's just a single parameter that's changing, and it's not even in the RS232 module, but I don't see how GPUtalk can work fine with the 8x8 build but not the 8x16 one.  :-//
But some data is getting through, because after 10 seconds or so the screen updates with data, and I'm able to write to the GPU, albeit not very predictably.  I happen to share the Tx/Rx lines with two of the LEDs on the dev board, so I can see activity on the serial connection at the GPU - I can also see the Tx/Rx LEDs flickering on the USB-TTL converter.
Also, immediately after testing the 8x16 build, I compile and upload the 8x8 version to the GPU and restart GPUtalk and everything works fine.  I'm careful to make sure the programmer isn't still open when I run GPUtalk, and vice-versa.
Though to me, it can't be an issue with GPUtalk as it works fine with the GPU in 8x8 mode - it must be something going wrong with the GPU build somehow?
Post by: BrianHG on November 20, 2019, 01:20:05 pm
I've re-vamped to com and GPUtalk into a generic debugging utility.  Update coming later today.
Meanwhile, create a simulation project for just the sync_gen.v module.  You gotta learn, cause the next steps will get deep...
Post by: nockieboy on November 20, 2019, 03:38:03 pm
Installing 9.1sp2 as I write this.
Were you just trying to keep me motivated earlier when you said we'd hit the hardest part of the project then?  ;)
Post by: BrianHG on November 20, 2019, 08:43:25 pm
It's not that it's hard, it's that you will not succeed without simulation.  You need to see what you code and internal registers are doing when you write code.  You need to test thing which you cannot generate in the real world feeding into your FPGA.  You need to test each verilog module feeding it specific controled inputs to see how it behaves.
    I've renamed to GPU_talk to RS232_Debugger.  I've cleaned up the verilog code and going to soon clean up the HEX Editor / Debugger and post it on a separate thread as it has now become/becoming a viable product all on it's own.  I've removed all the Altera dependencies in the RS232_Debugger.v so it now may work with any FPGA Vendor /  verilog compiler.
     I've also added an additional 8 real-time parallel debug ports.  4x8bit input ports and 4x8bit output ports.  In the new RS232_Debugger.exe, the 4 green ports displayed at the bottom left are real-time always updated refreshed display.  I currently connected the in0[7:0] & in1[7:0] to a new 16bit frame counter in the sync_gen.v module which you can see counting while the RS232_Debugger is running.  As for the output ports,   I tied ports out1[7:0] through out3[7:0] as a color palette selection for you OSD font.  (The foreground text color is set negative values while the background is set positive.)  You can manipulate the colors by clicking on the out1,2,3 bits in the debugger, or, hover the mouse over the out's binary bits and use the mouse wheel to increment/decrement the number.
See attached image for illustration, +, get the new GPU project and RS232_Debugger hex editor.
And if you cant get the 8x16 font working, there is something wrong with your setup, compiler install, corrupt files, or, something else.
Post by: nockieboy on November 21, 2019, 10:19:12 am
[attach=1]
It certainly is a viable product.  It's working perfectly now - not sure what's changed between this project and the last, or this version of GPU_talk/RS232_Debugger and the last, but I'm not getting any problems communicating with the GPU while it's running in 8x16 mode now:
[attach=2]
Sorry about the picture quality in that second one - the sun decided to come out whilst I was trying to take the picture, but you get the idea.  ;D
Yes, I've had some fun playing with the colours before realising I had work to do!  :-\
Post by: BrianHG on November 21, 2019, 12:00:43 pm
See what you can learn of setting up a simulation in QIIv9.1.  I can make myself available on the weekend to walk you through a complete simulation from scratch.  You'll probably need this as existing documentation sucks.
:( Sadly, when Altera decided to ditch their inbuilt simulator, and re-wrote their user interface to the new slower one, we lost a quick code diagnostic tool which helped one didn't want to bother with ModelSim where you could just drop and draw IO pins and registers from your project and see immediate results.
It's funny, even if you wanted to use third party simulators like ModelSim, Quartus' original Vector Waveform editor did allow the generation of vector stimulus files to be used by ModelSim and other third party simulators.  However, in the new QuartusPrime, it's vector file viewer/editor just sucks royal shit in speed and performance and editing/entering/generation waveform features compared to the old QIIv9.1 version which functions like a combined word-processor and Photoshop paint software.
Post by: avogadro on November 21, 2019, 12:10:34 pm
I dont know if anyone mentioned but you can use wayback machine to access the site you're looking for.
https://web.archive.org/web/20190414023118/http://searle.hostei.com/grant/z80/ (https://web.archive.org/web/20190414023118/http://searle.hostei.com/grant/z80/)
Post by: nockieboy on November 21, 2019, 12:53:49 pm
Thanks avogadro, that's all sorted now - there's a few mirror sites, as well as the wayback machine, but Grant Searle has opened another website at http://searle.wales (http://searle.wales) as well.
Absolutely - I'll see what I can do with the limited spare time I have before the weekend, but a walkthrough would be much appreciated.  :-+
Post by: nockieboy on November 21, 2019, 03:15:49 pm
Okay, so while I'm waiting for the weekend to learn about simulation, I thought I'd have a go at writing a host handler to monitor the Z80's address, data and control buses and accept anything written to the 'GPU window' in memory and pass it to the GPU RAM.
I thought I'd pop my code up to be torn apart as I don't really know if I'm going down the right lines with this and would appreciate the feedback.  ;)
Basically, it should monitor the Z80's address bus and memory signals to see if a byte is being written to the window in RAM that the GPU will sit within - this should be the third 512 KB, so 0x180000 to 0x1FFFFF.  When it sees the Z80's MREQ and WR lines go low (I haven't bothered with inverting signals yet, this is purely a code exercise at the moment) and M1 is high (i.e. the Z80 is writing to memory), it checks to see if the Z80 is addressing a byte within its 512 KB window - by checking if host_addr[21:19] == 3'b011.  If it does, then it passes host_addr[18:0] to the vid_osd_generator, along with the data being written and setting h_wr_ena high so that vid_osd_generator will write the data to memory.
I've just thrown this code together really, but the more I think about it the more I worry that there could be timing problems etc.  Should I run the code off of the Z80's 8 MHz clock or the much faster GPU clock?  Are there issues with how I'm setting/resetting h_wr_ena? etc..  :-//
module host_handler (
// input
input wire reset, // GPU reset signal
input wire host_CLK, // Microcom clock signal (8 MHz)
input wire host_M1, // Z80 M1 - active LOW
input wire host_MREQ, // Z80 MREQ - active LOW
input wire host_WR, // Z80 WR - active LOW
input wire host_RD, // Z80 RD - active LOW
input wire [21:0] host_addr, // Microcom 22-bit address bus
input wire [7:0] host_wr_data, // Z80 DATA bus to pass incoming data to GPU RAM
// output
output wire [7:0] h_rd_data, // Z80 DATA bus to return data from GPU RAM to Z80
output reg          h_rd_req, //
output reg          h_wr_ena, // flag HIGH when writing to GPU RAM
output wire [19:0] h_addr, // connect to host_addr in vid_osd_generator to address GPU RAM
output reg  [7:0]  h_wdata // 8-bit data bus to GPU RAM in vid_osd_generator
always @ (posedge host_CLK)
begin
// is a WR memory cycle being executed?
if (!host_M1 && host_MREQ && host_WR) begin
// is the GPU being addressed?
if (host_addr[21:19] == 3'b011) begin // host_addr[21:19] == 3'b011 targets the 512KB 'window' at 0x180000-0x1FFFFF
h_wdata <= host_wr_data;
h_addr <= host_addr[18:0];
h_wr_ena <= 1;
end // gpu addressed
else begin
h_wr_ena <= 0;
end // gpu not addressed
end // memory cycle
else begin
h_wr_ena <= 0;
end
end
Post by: BrianHG on November 21, 2019, 04:33:44 pm
Your doing ok, and for now, maybe you should keep working like this.
But, you are going to need to begin to eventually think along operating in 2 different clock domains.
1) You have a Z80 operating at 8Mhz.  It is sending you impossibly slow read and write requests.
2) Your static ram in an FPGA can operating at 125 Mhz.
3) How can I keep it running that fast and still run the Z80's 8Mhz requests?
This is not difficult.  Working/thinking like this will allow you to keep running the ram's host port at 125MHz.
If you are not sure what you are writing is functional, it is time to simulate...
Your other choice is to not change anything, but, create a separate xxxx.v module bridge to take these slow 8mhz requests and strobe them out at the system 125mhz speed.  This would be wasteful and may introduce additional clock delays.  Remember, if you clock the intel FPGA ram at 8mhz, though the writes may be taken immediately, if you do a read request, you get a response 2 clocks later unless you change the setting on the dual port ram which may kill your FMAX to a point where the GPU cant work.  Also, what happens if you do a write on one clock and a read of that same address on the next clock?  In the FPGA running at 8MHz, an additional clock cycle is required to get the new value.  Same goes for 125Mhz, however, since at 125MHz the write would go through and complete before the next Z80 read, I don't think this could be a problem unless the Z80 ran above 75MHz.
Post by: BrianHG on November 21, 2019, 04:40:08 pm
This is the final RS232_Debugger update before I make it's own dedicated thread.  I've added page read bursts into the communications protocol.  The read and write the the GPU now operate at full speed unhinged.  This means with 128 kilobytes in the GPU, reading or writing the full memory contents should take under 2 seconds.
Let me know if it loads and sends the full 16k any faster...
I've also made the VGA 8x16 font default.
Post by: BrianHG on November 21, 2019, 04:41:36 pm
// input
// output
begin
h_wr_ena <= 1;
else begin
h_wr_ena <= 0;
end // memory cycle
else begin
h_wr_ena <= 0;
end
end
Show me a Z80 data sheet write and read cycle waveform example.
Post by: BrianHG on November 21, 2019, 05:10:57 pm
LOL, here you go:
[attach=1]
[attach=2]
I shoved your GPU project into my 10 year old 15K$  video scaler:
[attach=3]
Your GPU is driving a 30bit color HDMI output, with HDCP encryption... LOL, talk about overkill.  It's using around 2% of the onboard FPGA + -110% of the 2 x 1GB DDR2 sodim modules mounted under the PCB.  My project went from this:
[attach=4]
To now this:
[attach=5]
Post by: lawrence11 on November 21, 2019, 07:14:10 pm
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
Post by: jhpadjustable on November 21, 2019, 09:36:47 pm
Shoved? Shouldn't that be more like thrown? :)
Aloow me to play librarian for a sec...
[attachimg=1]
~M1 (not shown) is an active low instruction fetch cycle type identifier signal. It is asserted during an instruction fetch and negated otherwise.
nockieboy's logic looks alright, without even looking at timing.
Post by: BrianHG on November 21, 2019, 11:26:09 pm
(Attachment Link)
Oh boy, that's a joke easy.  What I was getting at looking at that illustration, create a synchronous 125mhz core clocked interface which looks like a static ram access to the host Z80 cpu, but, only eats a single 125mhz cycle from the FPGA 125mhz ram.  Hint, it pretty much looks like my 5 port design, but without the 5 cycle pixel phase.  Since the Z80 only cycles once every 3 8Mhz clock cycles, there is no need to eat up the FPGA at all.
Write Example:
output regs fpga_mem_addr/data/write_ena... ect
Always @ (posedge 125MHz clock ...) begin
     last_Z80wr <= Z80wr;  // This is part 1 of the secret sauce
//           *** This is part 2 of the secret sauce ***
          if (   (~Z80nwr && last_Z80nwr)    &&  ~Z80mreq  && (good page address)  ) begin    // trap the high to low transition of the Z80wr, for a single 125MHz clock event as soon as the Z80wr input falls
               fpga_mem_addr       <= Z80addr;    // register latch the z80 address and
               fpga_write_data     <= Z80data;    // data only on that falling edge of the Z80wr
               fpga_write_ena      <= 1;           // turn on the ram write request
          end else fpga_write_ena <= 0;      // at the next 125mhz clock cycle, turn off the FPGA memory write request, IE the write pulse is only a 1 clock pulsed cycle
end
(Now, this code works good since 125Mhz runs at least 4 fold faster than the Z80 8MHz buss clock.)
No Z80 clock.  FPGA ram and interface module runs at 125Mhz.  This also leaves the FPGA ram empty for around 45 additional reads or writes in between each Z80 access which will be put to use by my RS232 Debugger and the graphics accelerated drawing hardware lateron.
Now, just like I trapped the falling edge of the Z80we, you can also trap the rising or falling edge of the Z80clk inside the 'IF' as well, or, you can double register ALL the Z80 inputs.  The first set using the Z80 clock, then trigger from those registered inputs at the 125mhz clock with the single pulse transition detection trick.
The read would be a second 'IF()begin' after the write, except you would pulse out a read request to the FPGA ram, latch the data coming back from the FPGA ram.  Only the MREQ and RD, plus valid address range would switch the Z80 data port on the FPGA IO's output enable.
Post by: nockieboy on November 22, 2019, 09:39:59 am
Works fine - yes, seems to load faster than previous version and is pretty darn quick in any case.  :-+
Well, I was thinking of acting on the Z80 write as soon as it came in, setting a flag so as not to act on the write more than once, and writing the data to the GPU RAM, resetting the flag when the Z80's write action completes.  That way, the GPU and its internals would all still run at full speed.
 :wtf:   Aye carumba... :o
Yeah, I can't imagine Brian broke out much of a sweat trying to squeeze my project in there..!  :-DD
(Attachment Link)
Yep - I have to check for the state of ~M1 as I don't want the GPU responding to an instruction fetch cycle - the Z80 won't be running code from the GPU RAM.  Although that's an interesting point.  Maybe I should get the GPU to return NOPs (8'b00000000) in the edge-case that the Z80 does try to read instructions from the GPU memory space?
I guess the only consideration I have to make is that it needs to share the access to the RAM with the RS232 debugger module?
Write Example:
end
Yes - that's kinda what I was planning to do, but yours is a bit more straightforward.  ;)
So I'll just need to create a bus mux for the two write inputs to the host port in the vid_osd_generator, like the multiport_gpu_ram module we have currently, to gate the writes to the second port of the GPU RAM?
That might be necessary to return data to the Z80 for a read request, but I'm liking the simplicity of your example above for the writes.
The Z80 data port on the FPGA is going to need to be bidirectional - bearing in mind my extremely limited experience with FPGAs, will that be a problem or require any special considerations?
Post by: nockieboy on November 22, 2019, 10:45:33 am
Okay, latest update to host_handler below:
// input
input wire GPU_CLK, // GPU clock (125 MHz)
// output
//output wire [7:0]  h_rd_data, // Z80 DATA bus to return data from GPU RAM to Z80
//output reg          h_rd_req, //
output reg          gpu_wr_ena, // flag HIGH when writing to GPU RAM
output reg [19:0] gpu_addr, // connect to host_addr in vid_osd_generator to address GPU RAM
output reg  [7:0]  gpu_wdata // 8-bit data bus to GPU RAM in vid_osd_generator
reg last_Z80_WR = 1'b1;
always @ (posedge GPU_CLK)
begin
// is this the start of a WR memory cycle being executed within the GPU's memory window?
if ((~host_WR && last_Z80_WR) && host_M1 && ~host_MREQ && (host_addr[21:19] == 3'b011))
begin
// yes - pass the address (limited to 512 KB) and data through
gpu_wdata <= host_wr_data;
gpu_addr <= host_addr[18:0];
gpu_wr_ena <= 1'b1;
end // memory cycle
else begin
gpu_wr_ena <= 1'b0;
end
last_Z80_WR <= host_WR;
end
endmodule
I think this is looking quite usable - I moved the last_Z80_WR assignment to the end, otherwise the GPU would always be comparing the current Z80_WR signal with itself (or a few nanoseconds old).  Hope that's right and I haven't misunderstood something.  ???
Post by: BrianHG on November 22, 2019, 12:06:09 pm
Got it right.
     As for the bidirectional port, there is the 'bidir' pin and 'tri' block diagram symbols in Quartus block diagram entry.  Just make add a 'bidir' pin on you block diagram.  Label it 'host_data[7..0]'.  Then add a 'tri' and tie it to the 'bidir' pin.  On the 'bidir' pin side, label that wire 'host_data_in[7..0].  On the other side of the 'tri' symbol, add a buss wire and label it 'host_data_out[7..0]'.  On the top of the 'tri' symbol, just add a single wire and label it 'host_data_oe'.  The rest should be self explanatory.
     I would also make an output pin or 2 from your GPU host interface to control the direction and output enables of the TTL 3.3v to 5v level shifters if you are using them.
Post by: BrianHG on November 22, 2019, 12:15:07 pm
     This is wrong, all the compares inside the 'IF()' are only finalized at the next 'always @ (posedge GPU_CLK)'.  So, as long as the GPU clock isn't faster than the combination of logic in the FPGA, which is spelled out to you by the compiler's FMAX in the compilation report, it doesn't matter where you place the 'last_Z80_WR <= host_WR;' line.  Remember, the compiler is wiring a breadboard with your description.  You aren't telling it where to place the wires and IC logic on that breadboard, being the FPGA fabric.
Post by: BrianHG on November 22, 2019, 01:33:55 pm
Some code cleaning tips:
Quote from: nockieboy on Today at 05:45:33 am
    // input
    // output
    parameter MEMORY_RANGE = 3'b011;  // host_addr[21:19] == 3'b011 targets the 512KB 'window' at 0x180000-0x1FFFFF
    reg last_Z80_WR = 1'b0;  // keep these low on power-up, otherwise a read or write pulse may be triggered.
    reg last_Z80_RD = 1'b0;
    assign mem_window = (host_addr[21:19] == MEMORY_RANGE) ; // Define an active memory range
    assign Z80_mreq = ~host_MREQ && host_M1 ; // Define a bus memory access state
    assign Z80_write = ~host_WR && last_Z80_WR ; // Isolate a single write transaction
    assign Z80_read = ~host_RD && last_Z80_RD ; // Isolate a single read transaction
    assign Write_GPU_RAM = mem_window && Z80_mreq && Z80_write ; // Define a GPU Write action
    assign Read_GPU_RAM = mem_window && Z80_mreq && Z80_read ; // Define a GPU Read action
    assign GPU_data_oe = mem_window && Z80_mreq && ~host_RD ; // Define the time the GPU ouputs data onto the Z80 data bus.
    begin
    if ( Write_GPU_RAM )
    begin
    gpu_wr_ena <= 1'b1;
    end // memory cycle
    else begin
    gpu_wr_ena <= 1'b0;
    end
    end
    endmodule
You should be able to workout the rest.
Post by: BrianHG on November 22, 2019, 04:48:37 pm
Ooops, to prevent compiler warnings, add this 1 line of code to the above code:
wire  mem_window, Z80_mreq, Z80_write, Z80_read, Write_GPU_RAM, Read_GPU_RAM, GPU_data_oe ;
Post by: nockieboy on November 22, 2019, 05:12:05 pm
    // input
    // output
    begin
    begin
    gpu_wr_ena <= 1'b1;
    end // memory cycle
    else begin
    gpu_wr_ena <= 1'b0;
    end
    end
    endmodule
Awesome, thank you.   ;D
Post by: nockieboy on November 22, 2019, 07:47:18 pm
So, something like this?
[attachimg=1]
Post by: BrianHG on November 22, 2019, 08:49:16 pm
(Attachment Link)
LOL..., that's backwards, like this: (Hint, take a look ad the direction of the 'tri' buffer.)
[attachimg=1]
Post by: nockieboy on November 22, 2019, 10:20:20 pm
(Attachment Link)
 :palm:
Attempt 2:
[attachimg=1]
h_data_oe should be HIGH to output data, right?
Post by: BrianHG on November 23, 2019, 06:34:00 am
Yes, always positive logic.
Also, when naming you Z80 ports, or host ports, use caps for the signal control  names an add a lowercase 'n' in front so you know those are deliberate negative logic.  EG:
h_nWR
h_nRD
h_nMREQ
Keep the 'n' wherever the logic is negative, so, inside the verilog module, you may make wires:
input h_nWR...
wire h_wr;
assign h_wr = ~h_nWR;
If a verilog/hdl friendly way of having the '!' or '/' in front of the signal, or having the bar on top of the signal name.
Post by: nockieboy on November 23, 2019, 10:13:48 am
Okay, this is wrong as I'm not sure about delaying the output of data back to the Z80 whilst waiting for the read data to come from the GPU, but this is my first attempt at a 'read' function:
if (Read_GPU_RAM)
begin
gpu_addr <= host_addr[18:0]; // pass address to GPU RAM
// wait a clock cycle?
data_dir <= 1'b1; // switch level converter to -> Z80
host_data_ena <= 1'b1; // drive data outputs
host_data[7:0] <= gpu_r_data[7:0]; // set data to output
end
else begin
data_dir <= 1'b0; // ensure data pins aren't driven when not reading
end
Post by: BrianHG on November 23, 2019, 10:32:33 am
if (Read_GPU_RAM)
begin
end
else begin
end
Missing too much stuff.  Let's see the whole program...
Post by: BrianHG on November 23, 2019, 12:30:45 pm
I've attached the GPU project with the final RS232_Debugger setup.  This version passes the 'ADDR_SIZE' parameter to the RS232_Debugger client on the PC.  I've also attached the updated client as it expects this reading within one of the commands it uses.  Let me know if they work.
Post by: nockieboy on November 23, 2019, 04:19:14 pm
// input
//input wire host_CLK, // Microcom clock signal (8 MHz)
input wire [7:0] gpu_r_data,
// output
output reg data_dir, // control level converter direction for data flow
output reg [7:0] gpu_wdata, // 8-bit data bus to GPU RAM in vid_osd_generator
output reg [7:0] host_data,
output reg host_data_ena // flag HIGH to write data back to Z80
wire mem_window, Z80_mreq, Z80_write, Z80_read, Write_GPU_RAM, Read_GPU_RAM, GPU_data_oe;
assign mem_window = (host_addr[21:19] == MEMORY_RANGE); // Define an active memory range
assign Write_GPU_RAM = mem_window && Z80_mreq && Z80_write; // Define a GPU Write action
begin
if (Write_GPU_RAM) // these compares are finalised on the next GPU_CLK
begin
gpu_wr_ena <= 1'b1;
end // memory cycle
else begin
gpu_wr_ena <= 1'b0;
end
if (Read_GPU_RAM)
begin
end
else begin
end
end
endmodule
There ya go.  :-+
Oh - apologies for the tabs - I've no idea what's going on with my editors and pasting code into other areas, but my tabs are all messed up.  |O
Post by: BrianHG on November 23, 2019, 04:47:31 pm
Now, you need to explain to me why I made these changes and where the pitfalls are:
// input
// output
begin
begin
gpu_wr_ena <= 1'b1;
end // memory cycle
else begin
gpu_wr_ena <= 1'b0;
end
if (Read_GPU_RAM)
begin
gpu_addr <= host_addr[18:0] ; // pass address to GPU RAM
gpu_rd_req <= 1'b1 ;               // Send a read request to GPU.
end else if (gpu_rd_rdy)
begin
gpu_rd_req <= 1'b0;                // End the read request once the read is ready
host_data[7:0]  <= gpu_r_data[7:0]; // Latch the GPU ram read into the output register for the Z80
end
data_dir      <= GPU_data_oe ;
host_data_ena <= GPU_data_oe ;
last_Z80_RD <= host_RD;
end
endmodule
Post by: nockieboy on November 23, 2019, 05:16:43 pm
if (Read_GPU_RAM)
begin
Okay, so this piece of code is triggered on the falling edge of the Z80 RD signal and is effectively executed once per Z80 read cycle.  It passes the requested address through to the GPU RAM and sets gpu_rd_req HIGH to signal a read.  There's no corresponding input in multiport_gpu_ram.v for this 'gpu_rd_req' signal, so I'm guessing this is for some sort of mux with the RS232 input to the GPU RAM?
begin
end
This bit of code above is executed when 'gpu_rd_rdy' is high - again, this isn't defined in the module but must be an input (reg?) from the bus mux which I've yet to create which will gate GPU RAM access between the RS232 module and the Z80 module here.  The gpu_rd_req signal is released (pulled LOW) so the (yet-to-be-created) bus mux can allow the RS232 module access to the GPU RAM again and prevent repeated memory accesses by the Z80 module.  The returned data held in the gpu_r_data registers is passed through to the data output to the Z80.
Finally, at the end of every GPU clock cycle, data_dir and host_data_ena are set high depending on whether a valid memory read access is detected, and the edge-detecting last_Z80_WR and last_Z80_RD flags are updated with the current status of the WR and RD lines from the Z80.
As for pitfalls....  :-\  Erm... gpu_rd_rdy isn't reset in the host_handler - so it must be a wire input from the mux module which would go HIGH when it receives data from the multiport_GPU_RAM module, and be reset by mux module when it detects gpu_rd_req going LOW?  Not really a pitfall, more of an observation.
Hmm.. not sure I know enough about the workings of the system to identify pitfalls?  Is there a chance it will still be driving the data outputs a clock or two after the end of the RD cycle?  That's not really a pitfall either though - at 125 MHz, there should be plenty of time for the data_dir signal to update the buffer on the Z80 data bus and get it to reverse direction before the next memory cycle...
Can I phone a friend or ask the audience?  ;)
EDIT:
Shouldn't gpu_rd_req be assigned LOW at the start?
assign gpu_rd_req = 1'b0;
Post by: BrianHG on November 23, 2019, 06:00:41 pm
You pretty much got it.
The only pitfall to mention is that the new added output reg, gpu_re_req stays high until the incoming confirmation signal gpu_rd_rdy.  Externally, when muxing, or what will be 'priority' selecting access to the gpu's host memory port will need to understand that when the req goes high, it only needs a single read, and it should only make the rdy pulse high after the right address made it through the ram and the ram's output contents are correct, not before.
In the case of having the host ram just tied to this one module alone, you would tie the rdy to 1 (vcc) and ignore the req signal as the ram would always feed the data out correctly within 2 clock cycles of the read address change.
Now, is there any change you can make to ensure no output enable collision between your external bidirectional data buffer and the FPGA tristated IO pins.  There should be a control for outputting data from the IO level translator to the FPGA.  Show me what IC you will be using...
Post by: nockieboy on November 23, 2019, 06:13:07 pm
I'm using a 74LVC245 - datasheet here (http://www.ti.com/lit/ds/symlink/sn74lvc245a.pdf).  It has DIRection and OE pins.
Post by: BrianHG on November 23, 2019, 06:16:42 pm
Remember, all you need is an OE to the FPGA side, or in this case, you just need the 2 control signals setup properly, 'DIR' and 'OE'.  So, I recommend changing your Z80 module's code to just drive those 2 wires.
You will also want to configure the data buss IOs on your FPGA to weak-pullup.  This is for when the buss is in high impedance, your IO's wont float in noise.
BTY, did you like my additions to you gpu core?
Post by: nockieboy on November 23, 2019, 06:19:26 pm
Okay, so that'll just need some similar if...end conditionals like the host_handler module has, that's simple enough.
Well, this is probably how I'll test it initially - I'll disconnect the RS232 interface and just have the host_interface module connected, then add the RS232 back in later when I'm confident the bus muxer is working for the host_interface and RS232 modules.
If the RAM is feeding back data in 2 clock cycles, don't I need to worry about what's on the data bus in the first two cycles then?
Post by: BrianHG on November 23, 2019, 07:07:29 pm
This is what the simulator is for if you wish to visualize what's going on, however, look at this image:
[attachimg=1]
Running you core at 48Mhz would probably do it all the time, never mind your current 125Mhz core.
Post by: nockieboy on November 23, 2019, 07:47:24 pm
If I add a 'data_oe', that can drive the OE pin of the 245 along with data_dir.  Hmm.. going to have to think about how to implement that as it takes a non-trivial amount of time for the 245 to switch direction and enable/disable its outputs, i.e. 4-8ns to enable, 4-7ns to disable outputs under typical conditions.
Fair point, well made.  :-+
 ??? :-\ Erm... rushes off to check the code.  :o  What changes again?  ^-^
(Attachment Link)
Yeah, it's pretty clear to me that timings aren't really an issue when I'm running the FPGA at 125 MHz.  ;)  Looks to me like I have nearly 125ns from MREQ going HIGH (and the FPGA shutting off the data bus output) before the next use of the Z80's data bus.
I just need to work out what I'm doing with the OE and DIR pins of the 245.  data_dir (and the h_data_dir pin) control the direction of the 245.  I need a new data_oe output and pin for the 245 OE and some gubbins in the host_handler for them...
Post by: nockieboy on November 23, 2019, 07:48:25 pm
So I've added a 245_OE pin, from data_oe internally to the host_handler.  It runs an inverted signal (see the design image above), so the Verilog remains active positive whilst the output is active LOW, which matches the chip's logic.  data_oe is set LOW from the outset (see code attached)... but I don't think (as usual) it's 100% right.
// input
input wire gpu_rd_rdy,
// output
output reg host_data_ena, // flag HIGH to write data back to Z80
output reg gpu_rd_req,
output reg data_oe // OE for 245 level translator (active LOW)
assign Z80_mreq = ~host_MREQ && host_M1; // Define a bus memory access state
assign Z80_write = ~host_WR && last_Z80_WR; // Isolate a single write transaction
assign Z80_read = ~host_RD && last_Z80_RD; // Isolate a single read transaction
assign Z80_nread = host_RD && ~last_Z80_RD; // Isolate end of a read transaction
assign Read_GPU_RAM = mem_window && Z80_mreq && Z80_read; // Define a GPU Read action
assign GPU_data_oe = mem_window && Z80_mreq && ~host_RD; // Define the time the GPU ouputs data onto the Z80 data bus
assign data_oe = 1'b0;
begin
begin
data_dir <= GPU_data_oe; // set 245 direction
data_oe <= 1'b1; // enable 245 to allow data through
// ***** I'll need to delay this next bit at least 5ns to allow the 245 to enable its outputs ???
gpu_addr <= host_addr[18:0];A
gpu_wr_ena <= 1'b1;
end // memory cycle
else begin
gpu_wr_ena <= 1'b0;
end
if (Read_GPU_RAM)
begin
gpu_rd_req <= 1'b1; // Send a read request to GPU.
data_dir <= GPU_data_oe; // set 245 direction (TO Z80)
data_oe <= 1'b1; // enable 245 data output
begin
end else if (gpu_rd_rdy && Z80_nread)
begin
// end of read transaction
data_oe <= 1'b0; // disable 245 data output
end
host_data_ena <= GPU_data_oe;
end
endmodule
Oh, and apologies for the ridiculous tabs again - it looks fine on my editor, honest!  ::)
I'm thinking of moving the end of 'read request' signal to the // end of read transaction part of the if block.  That way, the mux can turn off gpu_rd_rdy as well.
Post by: BrianHG on November 23, 2019, 09:50:20 pm
Ok, I see your point about the switch and output enable.  This is not hard to solve, however, first lets see how and when we want the '245 to be engaged.  Including the FPGA output enable.
Look here:
[attachimg=1]
Legend:
White and green areas, the 245 is disabled.
Green = This is where your 1 shot triggers take place.
Red = Your GPU FPGA output enable's data & the 245 is switched on with direction towards the Z80.
Blue = Switch off all output enables & 245.
Purple,  turn on 245 and make it's direction to feed data to the GPU.
Yellow, at least 8ns later, plus say another 20ns for good measure (this is where defining the input tsu/th values in the compiler becomes important to verify proper timing functionality during fitting, but for now, 20ns is extravagant to a point where you can ignore this.), read the FPGA input port data and write it to memory, and you may also then turn off the 245.  Optionally, you can wait another few ns before turning off the 245.
Remember, during the purple, you do not want the 245 to send any output on the Z80 by accident at all, even for a ns.
Same during the red period, you do not want the 245 to accidentally pulse any output on the FPGA data bus at all.
Let's see what you can code to make the second half (memory write cycle) work properly no matter what.
Post by: nockieboy on November 23, 2019, 11:30:07 pm
Okay... here's some code:
// input
input wire gpu_rd_rdy, // one-shot signal from mux that data is ready
// output
reg data_hold = 1'b0; // used to latch the gpu_rd_rdy signal
begin
begin
data_oe <= 1'b1; // 'turn on' 245
gpu_wr_ena <= 1'b1;
end // memory cycle
else begin
gpu_wr_ena <= 1'b0;
end
if (Read_GPU_RAM)
begin
gpu_rd_req <= 1'b1; // flag a read request to the mux which is one-shotted in the mux
end else if (gpu_rd_rdy) // gpu_rd_rdy is a one-shot from the mux, reset after one clock
begin
data_hold <= gpu_rd_rdy; // latch the gpu_rd_rdy signal to keep outputting data until Z80 is done with it
host_data_ena <= 1'b1; // set bidir pins to output
end else if (data_hold && Z80_nread)
begin
// data is being output to Z80, which has signalled end of read transaction
data_oe <= 1'b0; // turn off 245
data_hold <= 1'b0; // reset the latch
host_data_ena <= 1'b0; // set bidir pins to input
end
end
endmodule
Haven't touched the WRITE conditional, so not sure if it's compatible with the 245 controls in the READ conditional (it's probably not).
Okay, brief explanation of what I was hoping to do with the above code.  If Read_GPU_RAM is HIGH, a read transaction from the Z80 has been detected:
Then nothing should happen for a couple of cycles, until gpu_rd_rdy is asserted HIGH for one clock cycle by the mux:
This state is held until the Z80 has read the data and ends the read cycle by setting RD HIGH.  This triggers the last part of the conditional structure:
I think that might work...  ???  But as I said, not sure about the write conditional now.
Post by: Berni on November 24, 2019, 09:00:55 am
Small tip you probably want to distinguish any active low signals with something in the name. Like for example calling "host_RD" instead "host_RDn" or "host_RD_N" or "host_nRD" or whatever. There is no standard convention for it, my personal preference is adding a extra n on the end (I use this on my cirucit schematics too).
As for the bus coming out of there into memory you could consider using one of the FPGA bus standards so that naming of the signals is firmly defined and the documentation for that bus is already written. The bus specification has well thought out rules for how to use the bus in a way that makes it compatible with a wide range of situations and the documentation PDF will have lots of timing diagrams (I find these very useful when programing HDL as i can see exactly what needs to happen on what clock edge).
The standard "open source" FPGA bus is called Wishbone: https://en.wikipedia.org/wiki/Wishbone_(computer_bus) (https://en.wikipedia.org/wiki/Wishbone_(computer_bus))
Altera has its own proprietary spec called the Avalon bus: https://www.intel.com/content/www/us/en/programmable/documentation/nik1412467993397.html (https://www.intel.com/content/www/us/en/programmable/documentation/nik1412467993397.html)
There are plenty of other buses like the AXI AHB...etc that are used in ARM processors and lots more but they are complex due to all the features they have.
Technically there is no clear performance advantage of one bus over another, for basic functionality they all do the same thing. When you are developing for Intel/Altera there is however some advantage to be had in using the Avalon bus. Since its a bus they have developed means that all IP modules (Such as a SDRAM controller) you get from Altera will have this same bus interface and so will be easy to connect to other Avalon buses. Also if you want to use the Quartus Qsys (formerly SOPC Builder) to auto-magicaly generate the memory bus switching fabric, then you need to have Avalon buses on all your blocks. For simple systems Qsys is not that useful, but when you start having many devices connected by a memory bus and multiple masters and all that it can be an amazing help. You just hook up your devices to the bus with a single line and Qsys will figure out how to make that happen under the hood. It works even if the buses are different such as 32bit bus going into a 8bit one, two buses running on different clocks, different latency... etc as it will insert the appropriate bus adapter to convert it. If there are multiple masters on a bus it will automatically insert arbitration logic to make all the masters play nice with each other without the master even knowing about it (bus just looks busy for a unusually long time if another master is using it). It also takes care of all address decoding for you so you simply edit your address map in a table for where in memory each device is supposed to appear.
Making use of Qsys does require a bit of extra work tho. In addition it giving it the .v file of your module you also have to explain to it what pins do what. It needs to know where every pin of the Avalon bus is, how many buses there are (You can have 10 memory buses into one block if you like) and for each bus it needs to know the timing specifications such as what latency the read and write cycles happen on, if it supports burst transfers etc.. For example i did this when i had a board with a OMAP 138L microprocessor(450MHz ARM+DSP) and a FPGA. The processor had a SRAM style bus going out of it that my FPGA sat on as a peripheral much like you are doing here with the Z80. So i wrote a module that converts a SRAM style bus into Avalon and turned it into a Qsys block. Then i could just throw a DDR2 memory controller, some GPIO for LEDs and other peripherals into the bus and so with only a few clicks they would magically appear accessible to the ARM processor in that SRAM memory window.
Post by: BrianHG on November 24, 2019, 10:27:33 am
     I recommended using the 'n' for negative signals as well.  The wishbone is actually a nice choice.  The problem with Avalon is that it's Intel proprietary.  In actually, the Z80 is the project's only interface with an outside third party device and the rest is a register memory bank mentioned in point #3 here : Unified HW-Control Register Bank (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2788698/#msg2788698) and a programmable horizontal and vertical counter mentioned here: Video RAM pointer address Generator & Pixel Size Features (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2783948/#msg2783948) .  Other than 2 small palette rams taking the feed from the core memory output fed by the address generators, this would create a very powerful GPU for an 8 bit Z80.
    This thread is part work, part Verilog learning, part how to sequence, and I trying to get nockieboy and anyone else reading this thread to begin using a simulation tool, if any but a quick one at minimum just to see how important such a tool is, then maybe he will advance to full code style simulators which are well documented like Modelsim.
    In helping nockieboy, I let him begin his idea, suggest some code cleaning techniques & recommendations, then just as thing look to finish, I post a question on how not necessarily make the most useful code, but show how simple it may be to gets as a solution using thing he already learned but in a different way as you will see in my next post.
Post by: BrianHG on November 24, 2019, 10:51:42 am
// input
// output
begin
begin
gpu_wr_ena <= 1'b1;
end // memory cycle
else begin
gpu_wr_ena <= 1'b0;
end
if (Read_GPU_RAM)
begin
begin
begin
end
end
endmodule
  • First, we grab the address and pass it through (to the mux when it's completed)
  • Then, we assert gpu_rd_req to tell the mux we want to get data from the GPU RAM
  • The 245's direction is switched by setting data_dir to GPU_data_oe
  • Finally, data_oe is asserted HIGH, causing the 245's OE to go LOW and enable its output (the output is inverted in the design)
  • data_hold is asserted HIGH to latch the data output to the Z80 for a time
  • gpu_rd_req is cleared LOW to stop any further read requests to the mux (which will ignore them as it's a one-shot signal)
  • host_data_ena is asserted to make the data bidir pins outputs
  • the data from the mux is passed-through to the data output for the Z80 to read
  • data_oe is set LOW, making the 245's data pins tri-state
  • data_hold is set LOW, ready for the next read transaction
  • host_data_ena is set LOW to reset bidir pins to input
Ok, now that you see it may need to sequence a set of events after a detection of a write, let's start by changing your:
begin ....
        ....end
To something like this:
reg [9:0] Z80_write_sequencer;
always
Z80_write_sequencer[0] <= Write_GPU_RAM ;
Z80_write_sequencer[9:1] <= Z80_write_sequencer[8:0] ;
//Next... the new IF()'s
if ( Z80_write_sequencer[#] )    'perform a function, say, select 245 dir
if ( Z80_write_sequencer[#] )    'perform a function, say, make sure FPGA IO is in input mode.
if ( Z80_write_sequencer[#] )    'perform a function, say, turn on 245 OE
if ( Z80_write_sequencer[#] )    'perform a function, say, latch Z80 Write address
if ( Z80_write_sequencer[#] )    'perform a function, say, latch Z80 data bus
if ( Z80_write_sequencer[#] )    'perform a function, say, turn on FPGA ram we
if ( Z80_write_sequencer[#] )    'perform a function, say, turn off FPGA ram we
if ( Z80_write_sequencer[#] )    'perform a function, say, turn off 245 OE
     Remember, the 'Write_GPU_RAM' only pulses high for 1 clock exactly right at the detection of a valid write state.  That pulse will now shift down the 'Z80_write_sequencer[9:0] ' pipe.  Now, if you choose the right #, you can keep everything clean and functional, even if the Z80 is running at a synchronous 1/2 clock speed to you GPU clock.  To make you code really nice, make a parameter something like 'BIDIR_245_Delay_clock_cycles', or, with a little math, instead use 'GPU_CLK_Frequency' and 'BIDIR_245_Delay_ns' to shift those those sequencer[#'s] so your code may auto generate the positions if you wish to run the project at any other frequency like 135MHz, or 250MHz, or 270MHz.
Bonus hint (but not necessary at your clock speed): There is a way to push this entire sequence chain up by one clock cycle sooner, let's see if you can figure this out...
Post by: Berni on November 24, 2019, 11:54:09 am
Well these standard buses (even if proprietary to a FPGA vendor) don't really lock you in to exclusively using that bus. Nobody stopping you in using a Avalon bus in a Xilinx or Lattice FPGA and no special vendor specific IP is needed to make them work. Its mostly just a common convention to make things easily work together. Much like the convention of water taps having hot left and cold right, no reason why it can't be the other way around, but sticking to a standard saves effort by not having to check where is what, it just works.
A pair of similar Wishbone and Avalon buses can sometimes be adapted to each other by simply connecting the right pins together, no logic gates at all. Sometimes it might need a few NOT and AND gates to flip and merge some signals that work differently but that's it. Its only more complex if the buses are very different (mismatched number of bits, incompatible timings, missing byte selects etc..) but for those even connecting two standard Wishbone buses needs an adapter with lots of logic, but so as long as the buses are similar its all mostly directly connected. Even the Z80 bus looks quite similar to one of the possible Wishbone bus configurations (if you rename the signals a bit and split out the bidirectional data bus). What makes adapting the Z80 bus to the internal bus more complex is mostly due to the Z80 bus running at a different clock than the internal bus. So everything needs to be buffered between them, but still not all that hard. Its mostly about using a bus with a offical name so that you can google the bus name and get documentation on how it should work with diagrams and everything. If i make my own bus i know id do a terrible job at documenting it for the future me 5 years later looking at the code and not understanding it.
On Lattice FPGAs i have indeed been sticking to the Wishbone bus because its the most popular non proprietary bus spec. Sticking to the bus spec also helps with simulation, once you have built testbenches for a wishbone master and slave you find that you can reuse those testbenches with little to no modification, exercising most other wishbone enabled modules you write yourself.
Post by: BrianHG on November 24, 2019, 12:44:19 pm
Ok, yes, I do think that 'nockieboy's following bridge interface naming convention could be amended:
[attach=1]
We know it is a Z80 interface specifically with Z80 names and IO symbols on one side which can be confused since his uses 'h_xxx', and the '_xxx' may be confused with the his other 'h_xxx' inside the FPGA.  What belongs where?  And how to use?
The 'h_' connections for the GPU ram should have been just been a GPU_RAM... port.  And his Z80 Verilog bridge should have had Z80_xxx names for each Z80_ signal.  And maybe the 245 buffer controls could have been labeled 'Z80_245buffer_xx'.  OMG, this would end the difficult time I have reading his code & understanding what's being wired where and how it works without needing the block diagram illustrations.
Yes, using the Avalon bus is nice for many.
This project will eventually need read and write simultaneously to the GPU ram with 0 wait states, as this project will have a hardware draw / copy function which shares the Z80's GPU memory port.  And we want to fill/draw/copy as close to the 125Mhz in million pixels per second as possible, minus the 2.7 million possible Z80 transactions a second.  So, for this project, Yes on adopting the Avalon naming scheme if you want, but, we will need to hard wire each specific unidirectional address/data read path, write path channels into a priority encoder/selector, and take the return data into the right registers with acknowledge will be nothing more than a address & read req, or write req on each dedicated address line to the ram.  Coming out will be the read rdy which is just the read_req piped through with the right clk delay of the FPGA memory core.  That's 2 or 3 wires in and 2 or 3 wires out.  (Counting the data and address as 1 wire + the req signal).  There won't be time for any bus arbitration except on this tiny Z80 interface bridge.
     Now, here is the big + for Avalon.  Instead of this Z80 to GPU ram module which is currently being designed, but, if a GPU to Avalon module was being designed instead, and, in the public domain, a Z80 to Avalon bridge exists, as well as 6502 to Avalon, as well as 68000 to Avalon, ect, this may be the perfect spot to use Avalon.  However, once again, on the other side of this Avalon bridge where the GPU ram port resides, we just want those 3 wire interface ports since we want 3 to 5 new high speed parallel channels to access the GPU ram directly as static ram.  The other big + if if someone else want to port this GPU into their project, the Avalon bridge link would help if they are familiar, however, since the 'host' GPU ram interface is only supposed to be and address, data in and data out with a write enable, just using the Avalon correct 4 labels would be enough to function.
     Note that inside the current project, the 5 existing 5 port parallel access to the GPU ram already exists with only 1 address input and 1 data output, and currently unused, a request auxiliary flag input and output as well as passing the address through.
Post by: Berni on November 24, 2019, 01:28:20 pm
Avalon does have the ability to work in a zero wait state configuration that functions a lot like SRAM.
I also tend to write my Wishbone peripherals to be zero wait state for registers since that lets me ignore most of the signals (Its just a MUX controlled by the address bus that puts the correct register out on the bus regardless if its being read or not). If this big pure combinatorial read path ends up being too slow i can always just make it raise its wait line for the first cycle and this turns it into 1 wait state latency.
There are also specs for read-modify-write operations on the bus that could be used to transfer data in both directions simultaneously. As for multiple data on single address can be implemented by concatenating the data buses into one wide data bus. can be 1024 bits wide if needed. If multiple address and multiple data are needed the entire bus could be duplicated as many times as needed.
But yes i agree that RAM will rarely have a zero wait state bus coming out of it. It is possible to do for internal block RAM, but running any sort of external RAM (even just SRAM) will tend to have at least 1 wait state, DRAMs will tend to have even longer wait states. So in order to get full speed out of those pipelined burst transfers must be used and these are supposed by both Wishbone and Avalon. But yeah i would stick with the fast internal block ram for as long as possible because writing pipelined Verilog code that milks every last clock cycle for performance still hurts my brain. Sometimes special requirements do require a special bus, but you can still stick to the naming conventions so that you can know what a signal is for at a glance.
I do agree the usual memory bus arbitration is a poor fit for the critical real time buses inside the GPU where guaranteed bandwidth is required. Using a normal memory bus with multi-master arbitration is better suited on the bus before the GPU where you might have other hardware sitting on it such as the sound card, IO controller, DMA etc.. that all might want to talk to each other in some way and all make use of a single large external memory of a few Megabytes in size.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on November 24, 2019, 02:29:15 pm
This really legitimizes Avalon capabilities...
So many getting into 16/32/64 bit designs always ignore whenever we want to write bytes in the middle only, but our memory necessarily doesn't have byte mask features.  Ir in the case of a GPU, maybe we are using 2 pixels per byte in 16 color mode and you want to hardware accelerate drawing on only one of the 2 pixels.  Read-modify-write, as well as any simple logic done to a pixel like a transparency stencil when copying blocks of memory becomes ever so useful.
Post by: nockieboy on November 24, 2019, 03:28:30 pm
begin ....
        ....end
always
Okay, so I really should be getting used to using pipes by now, but I keep coming at these problems from a programming point of view and this isn't programming.  ;)
So at 125 MHz, one clock cycle takes 8ns - I guess that should be enough for the 245 to enable its outputs and/or change direction, so for the moment I'm using position [1] in the Z80_write_sequencer to get the data from the data bus and pass it to the GPU RAM.  Can always up it to 2 if there's data instability.
Here's the code:
// input
input wire Z80_M1n, // Z80 M1 - active LOW
input wire Z80_MREQn, // Z80 MREQ - active LOW
input wire Z80_WRn, // Z80 WR - active LOW
input wire Z80_RDn, // Z80 RD - active LOW
input wire [21:0] Z80_addr, // Microcom 22-bit address bus
input wire [7:0] Z80_wData, // Z80 DATA bus to pass incoming data to GPU RAM
input wire [7:0] gpu_rData,
// output
output reg [19:0]  gpu_addr, // connect to Z80_addr in vid_osd_generator to address GPU RAM
output reg [7:0]   Z80_rData,
output reg Z80_rData_ena, // flag HIGH to write data back to Z80
parameter MEMORY_RANGE = 3'b011; // Z80_addr[21:19] == 3'b011 targets the 512KB 'window' at 0x180000-0x1FFFFF
parameter DELAY_CYCLES = 1; // number of cycles to delay write for 245
wire mem_window, Z80_mreq, Z80_write, Z80_read, Z80_nRead, Write_GPU_RAM, Read_GPU_RAM, GPU_data_oe;
assign mem_window = (Z80_addr[21:19] == MEMORY_RANGE); // Define an active memory range
assign Z80_mreq = ~Z80_MREQn && Z80_M1n; // Define a bus memory access state
assign Z80_write = ~Z80_WRn && last_Z80_WR; // Isolate a single write transaction
assign Z80_read = ~Z80_RDn && last_Z80_RD; // Isolate a single read transaction
assign Z80_nRead = Z80_RDn && ~last_Z80_RD; // Isolate end of a read transaction
assign GPU_data_oe = mem_window && Z80_mreq && ~Z80_RDn; // Define the time the GPU ouputs data onto the Z80 data bus
assign gpu_rd_req = 1'b0; // default gpu_rd_req to LOW
assign data_oe = 1'b0; // disable 245 output
assign Z80_rData_ena = 1'b0; // set Z80 data pins to input on the FPGA
begin
Z80_write_sequencer[0] <= Write_GPU_RAM;
Z80_write_sequencer[9:1] <= Z80_write_sequencer[8:0];
if (Z80_write_sequencer[0])
begin
// start of Z80 WRite detected
Z80_rData_ena <= 1'b0; // set FPGA pins to input (should be by default)
data_oe <= 1'b1; // enable 245 output
end
else if (Z80_write_sequencer[DELAY_CYCLES]) // at 125 MHz, 1 cycle = 8ns - just enough time for the 245 to change direction & enable outputs
begin
// pass address (limited to 512 KB) and data through to mux
gpu_wdata <= Z80_wData;
gpu_addr <= Z80_addr[18:0];
gpu_wr_ena <= 1'b1;
end
else if (Z80_write_sequencer[DELAY_CYCLES + 1])
begin
// end of write to GPU RAM
gpu_wr_ena <= 1'b0;
data_oe <= 1'b0; // disable 245 output
end
if (Read_GPU_RAM)
begin
gpu_addr <= Z80_addr[18:0];// pass address to GPU RAM
begin
Z80_rData_ena <= 1'b1; // set bidir pins to output
Z80_rData[7:0] <= gpu_rData[7:0]; // Latch the GPU ram read into the output register for the Z80
end else if (data_hold && Z80_nRead)
begin
Z80_rData_ena <= 1'b0; // set bidir pins to input
end
Z80_rData_ena <= GPU_data_oe;
last_Z80_WR <= Z80_WRn;
last_Z80_RD <= Z80_RDn;
end
endmodule
I've had a go making the naming convention a little more consistent, but as always I'm open to advice, recommendations and (constructive!) criticism!  ;)
Post by: BrianHG on November 24, 2019, 04:29:28 pm
Yes, you got the idea, however, please change the naming convention to what I said 2 posts ago.  All of it.
2: I know you love squishing everything into 1 'IF' within it's 'begin' and 'end', for this case, write it out my way without the begin & end like so:
And I'm about to show you why once you pasted the changes back here....
Post by: nockieboy on November 24, 2019, 05:24:19 pm
Err okay, I thought I had?  I've just changed the 245 signal names, but other than that, I'm not sure what else you want changed?  :-//
The inputs from the Z80 all start with 'Z80_', all have an 'n' at the end where they're active low...  :scared:
Okay, have done the above - updated code below.
// input
// output
output reg Z80_245data_dir, // control level converter direction for data flow
output reg Z80_245_oe // OE for 245 level translator (active LOW)
assign Z80_245_oe = 1'b0; // disable 245 output
begin
if ( Z80_write_sequencer[0] )
Z80_245data_dir <= GPU_data_oe; // set 245 dir
Z80_245_oe <= 1'b1; // enable 245 output
if ( Z80_write_sequencer[DELAY_CYCLES] )
gpu_addr <= Z80_addr[18:0]; // latch address bus onto GPU address bus
gpu_wdata <= Z80_wData; // latch data bus onto GPU data bus
gpu_wr_ena <= 1'b1; // turn on FPGA RAM we
if ( Z80_write_sequencer[DELAY_CYCLES + 1] )
gpu_wr_ena <= 1'b0; // turn off FPGA RAM we
Z80_245_oe <= 1'b0; // disable 245 output
if (Read_GPU_RAM)
begin
Z80_245data_dir <= GPU_data_oe; // set 245 direction (TO Z80)
Z80_245_oe <= 1'b1; // 'turn on' 245
begin
begin
end
end
endmodule
Post by: Berni on November 24, 2019, 06:03:10 pm
Actually sorry i looked at the Avalon and Wishbone spec again and the read-modify-write operation is not simultaneous in both directions.
I never used it before as i didn't tend to need it. It turns out that the whole point of the read-modify-write cycle is to lock down any bus arbiters along the path so that you are guaranteed to get the last write part of the operation trough without someone else modifying that location and causing a glitch. This is not all that useful functionality in my opinion.
In theory you could set both write and read signals high on Avalon, but this is probably illegal in the spec?... somehow?...I dunno I haven't seen it specifically mentioned its not legal to do this, but i also haven't seen any timing diagrams that show doing this. Using common sense id say you are probably not supposed to do that. That being said tho most Avalon peripherals that only use internal memory usually have completely separate write logic and separate read logic. So it should work just fine to both read and write to one address, since the two separate sets of logic would simply do there thing as usual. But if you tried to pull this stunt on a memory controller for external memory it would probably refuse to do anything, or do just one of the two, since the data bus is bidirectional so it can't read and write at the same time. I suppose you could pretend this simultaneous read and write functionality is your own custom extension to the Avalon standard and so write your Avalon bus modules in a way where this is guaranteed to always work.
In any case even when using Wishbone or Avalon its good to have some idea what will be connected on the other end of the bus so that you can chose the port configuration that best fits the use. For just setting hardware registers the most basic configuration is good enugh. You want the bit depth of the bus to match up to avoid bus width adapters, if you have a 16 or 32bit bus you might want to support byte enable signals, if the device has a lot of latency you might want to support burst transfers...etc
Avalon also has a specification for streaming interfaces too. This is just a data bus with control signals and no address, usually used for point to point real time streaming of data like perhaps between a ADC controller and a DSP block. Useful for signal processing chains and all of Alteras IP blocks for filters and such use it. Again nothing special about it as there is no single one best way to design a streaming bus, but you can use the naming conventions and timings so that anyone who looks at it understands how the bus works.
Post by: BrianHG on November 24, 2019, 06:13:46 pm
// input
// output
begin
if (Read_GPU_RAM)
begin
begin
begin
end
end
endmodule
Ok, much better.  Now, looking at it this way:
module Z80_bridge (
// input
// output
parameter DELAY_CYCLES = 2; // number of cycles to delay write for 245
begin
Z80_write_sequencer[9:0] <= { Z80_write_sequencer[8:0] , Write_GPU_RAM };
if ( Z80_write_sequencer[0] )                 Z80_245data_dir  <= GPU_data_oe;   // set 245 dir
if ( Z80_write_sequencer[0] )                 Z80_rData_ena    <= 1'b0;           // set FPGA pins to input (should be by default)
if ( Z80_write_sequencer[1] )                 Z80_245_oe       <= 1'b1;           // enable 245 output
if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_addr         <= Z80_addr[18:0]; // latch address bus onto GPU address bus
if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_wdata        <= Z80_wData;      // latch data bus onto GPU data bus
if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_wr_ena       <= 1'b1;           // turn on FPGA RAM we
if ( Z80_write_sequencer[DELAY_CYCLES + 2] )  gpu_wr_ena       <= 1'b0;           // turn off FPGA RAM we
if ( Z80_write_sequencer[DELAY_CYCLES + 2] )  Z80_245_oe       <= 1'b0;           // disable 245 output
if (Read_GPU_RAM)
begin
begin
begin
end
end
endmodule
See how much easier it is for me, or even you to move around the timing / or sequence.  Plus, you need to add an additional clock cycle on top of the delay generated by the 245's OE control.  Remember, there is also a 'tsu' and 'th' (Time setup, and time hold for data inputs with relation to external and internal FPGA clock) figure inside the FPGA which must be met, and, if you are not defining these for your inputs in the compiler and relying on the compiler's 'FMAX' alone, you need to assume the the inputs take 1 entire clock cycle before they get from the input pins to the internal registers.  Operating the FPGA IO's at break-neck speed would require you to set these figure up correctly so the compiler will tell you if your design will receive the correct data, however, with this design, you can easily get away with that cheap 1 additional clock cycle delay as you are running more than 10 clock cycles within a single Z80 clock cycle.  And even then, the Z80 is even holding that data for even longer than 1 clock cycle...
Basically, your time is the switch on delay of the 245, under worst case conditions, not optimum, plus capacitance and trace leads, plus the delay from input pin in the FPGA to it's gpu_wdata[7:0] register.
Post by: BrianHG on November 24, 2019, 06:36:56 pm
Error:
and this:
if (Read_GPU_RAM)
   begin
Should be set to exclusively 1's or 0's, or defined by a parameter if you haven't decided the direction of the IC on your PCB.
The read section could use a little cleaning.  I cant follow it clearly.  It's going to be time to simulate this one to double check things out...
Post by: nockieboy on November 24, 2019, 06:56:55 pm
Yeah, I suppose so - I guess it would be possible to re-write the read if...endif conditional in the same way, but the read flow depends on a couple of different triggers which, I guess, would make the pipeline method undesirable?
Okay, fair enough - so it's looking like the Z80_bridge module is pretty much complete now?  Time to start simulating...?  :-BROKE
Error:
and this:
if (Read_GPU_RAM)
   begin
Sorted.  I've also removed these two lines:
Both those outputs are fully catered for in the write and read code, so I've commented them out.
if (Read_GPU_RAM)
begin
Z80_245data_dir <= 1'b0; // set 245 direction (TO Z80)
So when a Z80 read is detected, we grab the bottom 19 bits of the address and pass that to the mux, along with the gpu_rd_req.  The 245's direction is set TO Z80 and its output is enabled as the Z80 won't be driving the data bus at all during the read operation, and will only sample the data bus at the end of the read op.
begin
data_hold <= 1'b0; // latch the gpu_rd_rdy signal to keep outputting data until Z80 is done with it
So the mux will signal via gpu_rd_rdy for one clock cycle that the GPU RAM data is ready.  When this is detected, data_hold goes HIGH to keep the data output from the FPGA to the Z80, Z80_rData_ena goes HIGH to set bidir pins to output, gpu_rd_req is reset and the data is latched onto the Z80_rData bus.
begin
end
Finally, when the end of the Z80 read cycle is detected by RD going high, the 245's output is disabled, the data_hold latch is reset and the bidir pins are set to input.
Post by: BrianHG on November 24, 2019, 08:31:40 pm
Arrrg, that ' 1 shot ' on the read is nasty looking at the timing chart.  If seem you will need to qualify it on the rising edge of the CPU clock unlike the Z80 write data where we can cheat and trigger on the fall of the Z80 WE exclusively.
Here is how we will need to assign and trigger the read:
assign Read_GPU_RAM_BEGIN   = mem_window && Z80_mreq && ~Z80_RDn && Z80_clk && ~Z80_clk_delay  ;   // Define the beginning of a Z80 read request of GPU Ram.
assign Read_GPU_RAM_END   = Z80_RDn && ~last_Z80_RD;  // Define the time to end a GPU ram read
Z80_clk_delay <= Z80_clk;  // add this to find the rising clock edge.
you only need 2 IF()', 1 for Read_GPU_RAM_BEGIN, and 1 for Read_GPU_RAM_END.
This change must be made since we cannot guarantee which signal will fall first, the Z80_MREQn, or the Z80_RDn.  In the original code, if the 'Z80_RDn' falls before the 'Z80_MREQn', we will not see that cycle as a read & we will ignore the transaction.  We only know that both signals are valid by the time the next rising edge of the CPU clk.  To be constant, you may also qualify the write signal strobe the same way as well.
As for the 'Z80_rData', make 1 if outside everything else an just say:
if (gpu_rd_rdy)  Z80_rData[7:0]   <= gpu_rData[7:0];   // Latch the GPU ram read into the output register for the Z80
And your done...
Post by: nockieboy on November 24, 2019, 10:47:22 pm
And your done...
Okay, I think I've made the changes required above.  I've commented-out changes to data_hold as it appears it's no longer necessary.
module Z80_bridge (
// input
input wire Z80_CLK, // Microcom clock signal (8 MHz)
// output
output reg Z80_245data_dir, // control level converter direction for data flow - HIGH = A -> B (toward FPGA)
wire mem_window, Z80_mreq, Z80_write, Z80_read, Z80_nRead, Write_GPU_RAM, Read_GPU_RAM, GPU_data_oe, Z80_clk_delay;
wire Read_GPU_RAM_BEGIN, Read_GPU_RAM_END;
//reg data_hold = 1'b0; // used to latch the gpu_rd_rdy signal
//assign Read_GPU_RAM = mem_window && Z80_mreq && Z80_read; // Define a GPU Read action
assign Read_GPU_RAM_BEGIN = mem_window && Z80_mreq && ~Z80_RDn && Z80_CLK && ~Z80_clk_delay;   // Define the beginning of a Z80 read request of GPU Ram.
begin
Z80_write_sequencer[9:0] <= { Z80_write_sequencer[8:0], Write_GPU_RAM };
if ( Z80_write_sequencer[0] )                 Z80_245data_dir  <= 1'b1; // set 245 dir toward FPGA
if ( Read_GPU_RAM_BEGIN )
begin
end
if ( gpu_rd_rdy ) // gpu_rd_rdy is a one-shot from the mux, reset after one clock
begin
//data_hold <= 1'b1; // latch the gpu_rd_rdy signal to keep outputting data until Z80 is done with it
Z80_rData[7:0] <= gpu_rData[7:0]; // Latch the GPU RAM read into the output register for the Z80
end
if ( Read_GPU_RAM_END )
begin
//data_hold <= 1'b0; // reset the latch
end
//Z80_245data_dir <= GPU_data_oe;
//Z80_rData_ena <= GPU_data_oe;
Z80_clk_delay <= Z80_CLK;  // find the rising clock edge
end
endmodule
If that's all looking good, I'll get started on setting up a simulation for it tomorrow if I get the time.  What sort of complexity will the mux bring?  Will this be a cut-down version of the multiport_GPU_RAM module?
Post by: BrianHG on November 24, 2019, 11:27:32 pm
Looks Good.
The mux is a 2:1, or 3:1 lateron with the cpu on top and RS232 debugger on bottom.
Other than making that Z80 module's read req into a single pulse instead of always on, the mux will cycle to any available triggered input.  Just a J-K flipflop equivalent selecting 2 address and data sourced, with a 2 clock cycle delayed rd_ready output matching the altsynccram megafunction's 2 clock cycle read delay.
Post by: BrianHG on November 26, 2019, 12:49:16 am
Ok, @nockieboy, now that I know you can simulate code in Quartus, let's take a look at point #3 here:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2788698/#msg2788698 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2788698/#msg2788698)
Now I said I would like to a Verilog guide about initiating memory : https://www.chipverify.com/verilog/verilog-single-port-ram (https://www.chipverify.com/verilog/verilog-single-port-ram) , but I don't like their example.  We only need a block of registers to write to and have continuous parallel access with some instantaneous reset values.  So, take a look at this I threw together:
module r_bank (
input wire rst,
input wire clk,
input wire we,
input wire [7:0] addr_in,
input wire [7:0] data_in,
output reg  [7:0] mem[256]  );
  integer i;
  always @ (posedge clk) begin
  if (rst) begin
mem[0] <= 8'hAA;
mem[1] <= 8'hBB;
mem[2] <= 8'hCC;
mem[3] <= 8'hDD;
    for (i = 4; i < 256; i = i + 1) begin
mem[i] <= 8'h0;
    end
end else begin
if (we)
mem[addr_in] <= data_in;
end
end
endmodule
Now, you will need to re-work it to the specs and controls I laid out for your GPU.  One thing is in Quartus, to use Verilog addressable memory arrays, please set the 'Verilog' language style/version to 'System Verilog'.  Also, to make the block diagram symbol for this example verilog code, you will need to use Quartus Prime as old QuartusIIv9.1 doesn't know how to do it.  Then you can bring that .bsf file back into the older Quartus and simulate it.
Here is an example of what it should look like.
[attachimg=1]
You can see how Altera/Intel labels the ' register memory bank ' differently outside the Verilog module where I fed some of the individual register bytes to a few output pins.
This bank of registers is what will hold and feed all you graphics control settings.  As you can see, you write to them just like ram, but, you have individual access to all their contents at all times.
It's also much reads much easier this way than mem[255*8+7:0*0], and selecting the right sub wires, though, it works out to the same thing.
Post by: BrianHG on November 26, 2019, 02:17:43 am
The RS232_Debugger I created for nockieboy's VGA Controller has become a thread upon it's own here as it has proven functional and has also become a viable product all on it's own:
https://www.eevblog.com/forum/fpga/verilog-rs232-uart-and-rs232-debugger-source-code-and-educational-tutorial/msg2801388/#msg2801388 (https://www.eevblog.com/forum/fpga/verilog-rs232-uart-and-rs232-debugger-source-code-and-educational-tutorial/msg2801388/#msg2801388)
The latest RS232_Debugger.exe HEX editor/filed editor is now located here:
https://www.eevblog.com/forum/fpga/verilog-rs232-uart-and-rs232-debugger-source-code-and-educational-tutorial/?action=dlattach;attach=878982 (https://www.eevblog.com/forum/fpga/verilog-rs232-uart-and-rs232-debugger-source-code-and-educational-tutorial/?action=dlattach;attach=878982)
Post by: nockieboy on November 26, 2019, 10:02:17 am
Now, you will need to re-work it to the specs and controls I laid out for your GPU....
Okay, have done that (thanks for the example - makes my life much easier and assists my understanding no end!) - code below:
module GPU_HW_Control_Regs (
input reg rst,
input reg clk,
input reg we,
input reg [19:0] addr_in,
input reg [7:0] data_in,
output reg  [7:0] GPU_HW_Control_regs[HW_REGS_SIZE]
parameter HW_REGS_SIZE = HW_REGS;
parameter [7:0] RST_VALUES [32] = {
8'h01,
8'h02,
8'h03,
8'h04,
8'h05,
8'h06,
8'h07,
8'h08,
8'h09,
8'h0A,
8'h0B,
8'h0C,
8'h0D,
8'h0E,
8'h0F,
8'h10,
8'h11,
8'h12,
8'h13,
8'h14,
8'h15,
8'h16,
8'h17,
8'h18,
8'h19,
8'h1A,
8'h1B,
8'h1C,
8'h1D,
8'h1E,
8'h1F,
8'h20
wire valid_wr;
assign valid_wr = we && ( addr_in[19:8] == data_in ); // upper 8-bits of addr_in should equal data_in for a successful write
integer i;
if (rst) begin
// reset key registers to initial values
for (i = 0; i < 32; i = i + 1) begin
GPU_HW_Control_regs[i] <= RST_VALUES[i];
end
// reset remaining registers to zero
for (i = 33; i < HW_REGS_SIZE; i = i + 1) begin
GPU_HW_Control_regs[i] <= 8'h0;
end
end
else
begin
if (valid_wr) begin
// apply written value to addressed register
GPU_HW_Control_regs[addr_in[7:0]] <= data_in;
end
end
end
endmodule
So I've been wading through the specifications you provided in the earlier post for the GPU_HW_Control_Regs, but I'm struggling with this bit:
c)  Base write address for the write input.  The module will always take in all 20 address bits, but when writing data to the 8 bit data input port, the upper address wires [19:8] should equal this number for the write to be successful.  If parameter (b) is >256, then the bottom of the upper base write address [8] will be ignored as you will be opening a 512 byte window, and so on.  (Set this default to the base of the last 256 bytes in your system memory.  Yes, it will occupy the same last 256 bytes as your system GPU ram.)
I've got the check to make sure the data value is the same as the upper 8-bits of the address value, but the bit in bold is making my brain ache.  Can you rephrase those three sentences, or reduce them to single-syllable words with crayon sketches?  :o
So I'll need 32 output pins - one for each of the 'main' registers?
Post by: BrianHG on November 26, 2019, 11:18:01 am
input reg rst,
input reg clk,
input reg we,
8'h01,
8'h02,
8'h03,
8'h04,
8'h05,
8'h06,
8'h07,
8'h08,
8'h09,
8'h0A,
8'h0B,
8'h0C,
8'h0D,
8'h0E,
8'h0F,
8'h10,
8'h11,
8'h12,
8'h13,
8'h14,
8'h15,
8'h16,
8'h17,
8'h18,
8'h19,
8'h1A,
8'h1B,
8'h1C,
8'h1D,
8'h1E,
8'h1F,
8'h20
wire valid_wr;
integer i;
if (rst) begin
GPU_HW_Control_regs[ i ] <= RST_VALUES[ i ];
end
for (i = 4; i < HW_REGS_SIZE; i = i + 1) begin
GPU_HW_Control_regs[ i ] <= 8'h0;
end
end
else
begin
if (valid_wr) begin
end
end
end
endmodule
You just about got it... #1, see error in 'RED'
         end
         end
A simulation which had a reset somewhere and at least 8 output regs on display and some random parameters would have shown you this bug.
Ok, you need another Parameter.  Call it 'BASE_WRITE_ADDRESS'.  Now, change to your current valid write enable condition:
   assign valid_wr = we && ( addr_in[19:HW_REGS_SIZE] == BASE_WRITE_ADDRESS[19:HW_REGS_SIZE] );      // upper addr_in should equal to the same specified upper base address.  This will allow us to map the register bank anywhere inside the 20bit address range.
So, if we have a HW_REG_SIZE of 8, space for 256 registers, only addr_in address wires [19:8] need to be equal with the value in 'BASE_WRITE_ADDRESS[19:8]' and 'we' needs to be high to engage the write enable.  Remember, even though you may think of parameters as numbers, to a Verilog compiler, it is nothing more than a bundle of single wires with set specific high and low values.  So writing my above line make all too much easy sense.  (HINT: In specifying a Z80 window address location..... not in binary or 3 arbitrary bit located who knows where.... Give it a legitimate understandable figure which matches what you code in the Z80 + what you see when you enter an address in your simulator setup.)
And, don't forget this:
      if (valid_wr) begin
            GPU_HW_Control_regs[addr_in[HW_REG_SIZE-1:0]] <= data_in;
         end
Let's see a test bench of this for setting a few regs, then doing a reset showing all the defaults set in 1 shot.
Only if you want to send 32 registers to 32x8bit output pins.  All I'm saying is that when Quartus wires a addressable register ram on it's block diagrams, it calls them "mem[0..255][7..0]" instead of Veriog's  ' reg [7:0] mem [256]; '.  Quartus does this to allow you to take sub-groups of 'mem', like [15..20] and sen those to 1 module while wiring [200..210] to another in the block diagram.  Don't worry, we will be piping all 256, [0..255] into each verilog module and a parameter there will select which memory contents in that bundle will control it's features.  My example screenshot shows you how to select and wire a bundle of the mem register bank in the block diagram editor to anywhere you like.
Post by: nockieboy on November 26, 2019, 12:18:36 pm
         end
         end
Yeah, I spotted and corrected that bug in my post above, but not in time before you read it.  :)
Couple of issues here - HW_REGS_SIZE originally was intended to be a literal number of registers... i.e. 32 for 32 registers.  So I've had to make some changes to the code to treat HW_REGS_SIZE as the square root of the desired number of registers, so it can be dropped into address ranges directly as the number of address lines needed to make the required number of regs.  So now it would have a value of 5 for 32 registers, instead of 32 before.
The other thing is this:
BASE_WRITE_ADDRESS:  Can I just declare it as a hex or binary value?
BASE_ADDRESS = 19'b0000011111100000000;
That should be the address of the top 256 bytes of the GPU's 16K RAM?
input reg rst,
input reg clk,
input reg we,
output reg  [7:0] GPU_HW_Control_regs[2**HW_REGS_SIZE]
parameter BASE_WRITE_ADDRESS = 0;
8'h01,
8'h02,
8'h03,
8'h04,
8'h05,
8'h06,
8'h07,
8'h08,
8'h09,
8'h0A,
8'h0B,
8'h0C,
8'h0D,
8'h0E,
8'h0F,
8'h10,
8'h11,
8'h12,
8'h13,
8'h14,
8'h15,
8'h16,
8'h17,
8'h18,
8'h19,
8'h1A,
8'h1B,
8'h1C,
8'h1D,
8'h1E,
8'h1F,
8'h20
wire valid_wr;
assign valid_wr = we && ( addr_in[19:HW_REGS_SIZE] == BASE_WRITE_ADDRESS[19:HW_REGS_SIZE] ); // upper 8-bits of addr_in should equal data_in for a successful write
integer i;
if (rst) begin
end
for (i = 4; i < 2**HW_REGS_SIZE; i = i + 1) begin
end
end
else
begin
if (valid_wr) begin
end
end
end
endmodule
Post by: nockieboy on November 26, 2019, 12:35:13 pm
 :palm:
Now I'm hitting error after error trying to create symbol files for GPU_HW_Control_Regs.  I've saved it as a .sv file to try to enforce the System Verilog language, but it's really not happy with the RST_VALUES parameter array.
This is where I am currently - this error message:
Error (10016): Can't create symbol/include/instantiation/component file for module "GPU_HW_Control_Regs" because port "GPU_HW_Control_regs" has an unsupported type
input rst,
input clk,
input we,
input [19:0] addr_in,
input [7:0] data_in,
parameter HW_REGS_SIZE = 5;
parameter bit [7:0] RST_VALUES [32] = '{
8'h01,
8'h02,
8'h03,
8'h04,
8'h05,
8'h06,
8'h07,
8'h08,
8'h09,
8'h0A,
8'h0B,
8'h0C,
8'h0D,
8'h0E,
8'h0F,
8'h10,
8'h11,
8'h12,
8'h13,
8'h14,
8'h15,
8'h16,
8'h17,
8'h18,
8'h19,
8'h1A,
8'h1B,
8'h1C,
8'h1D,
8'h1E,
8'h1F,
8'h20
wire valid_wr;
integer i;
if (rst) begin
end
end
end
else
begin
if (valid_wr) begin
GPU_HW_Control_regs[addr_in[HW_REGS_SIZE-1:0]] <= data_in;
end
end
end
endmodule
I've made changes to how RST_VALUES is declared, including specifying a type which I think is causing this error, but I get other errors if I don't specify a type.
Post by: BrianHG on November 26, 2019, 12:37:12 pm
Yup, that's fine, just note that [19:0] is 20'bxxxx not 19'bxxxx.  0 in 19:0 counts as a bit as well.
As for hardware regs, just fix up the parameter nae to what you like.  A parameter of HW_REG_ADDR_SIZE would be fine and using the 2**HW_REG_ADDR_SIZE would do it for you  [7:0]reg[xxxxx], and don't forget your reset loop...
Post by: BrianHG on November 26, 2019, 12:42:04 pm
:palm:
input rst,
input clk,
input we,
8'h01,
8'h02,
8'h03,
8'h04,
8'h05,
8'h06,
8'h07,
8'h08,
8'h09,
8'h0A,
8'h0B,
8'h0C,
8'h0D,
8'h0E,
8'h0F,
8'h10,
8'h11,
8'h12,
8'h13,
8'h14,
8'h15,
8'h16,
8'h17,
8'h18,
8'h19,
8'h1A,
8'h1B,
8'h1C,
8'h1D,
8'h1E,
8'h1F,
8'h20
wire valid_wr;
integer i;
if (rst) begin
end
end
end
else
begin
if (valid_wr) begin
end
end
end
endmodule
It's in part a limitation of QuartusIIv9's 'generate sheet symbol' function, you just need to generate the sheet symbol in Quartus Prime, then it will still load in QuartusIIv9 once generated.  Once you have the symbol, everything else is still functional in both versions of Quartus.
Post by: BrianHG on November 26, 2019, 12:59:20 pm
If you cant solve the reset parameter array, just make 8 16 bit parameter inputs and assign the 8 to the first 16 regs.  We will most likely only use 4 of these, filled with 16 or even 24 bit quantities as they will point to the power up display address pointer settings to generate a valid picture.
Post by: nockieboy on November 26, 2019, 01:36:38 pm
It's Quartus Prime I'm getting the errors in.  :-\
I'll go for this solution, I think. Here's the updated code:
input rst,
input clk,
input we,
parameter RST_VALUE_0 = 16'b0000000000000000;
parameter RST_VALUE_1 = 16'b0000000000000001;
parameter RST_VALUE_2 = 16'b0000000000000010;
parameter RST_VALUE_3 = 16'b0000000000000011;
parameter RST_VALUE_4 = 16'b0000000000000100;
parameter RST_VALUE_5 = 16'b0000000000000101;
parameter RST_VALUE_6 = 16'b0000000000000110;
parameter RST_VALUE_7 = 16'b0000000000000111;
wire valid_wr;
integer i;
if (rst) begin
GPU_HW_Control_regs[0] <= RST_VALUE_0[7:0];
GPU_HW_Control_regs[1] <= RST_VALUE_0[15:8];
GPU_HW_Control_regs[2] <= RST_VALUE_1[7:0];
GPU_HW_Control_regs[3] <= RST_VALUE_1[15:8];
GPU_HW_Control_regs[4] <= RST_VALUE_2[7:0];
GPU_HW_Control_regs[5] <= RST_VALUE_2[15:8];
GPU_HW_Control_regs[6] <= RST_VALUE_3[7:0];
GPU_HW_Control_regs[7] <= RST_VALUE_3[15:8];
GPU_HW_Control_regs[8] <= RST_VALUE_4[7:0];
GPU_HW_Control_regs[9] <= RST_VALUE_4[15:8];
GPU_HW_Control_regs[10] <= RST_VALUE_5[7:0];
GPU_HW_Control_regs[11] <= RST_VALUE_5[15:8];
GPU_HW_Control_regs[12] <= RST_VALUE_6[7:0];
GPU_HW_Control_regs[13] <= RST_VALUE_6[15:8];
GPU_HW_Control_regs[14] <= RST_VALUE_7[7:0];
GPU_HW_Control_regs[15] <= RST_VALUE_7[15:8];
for (i = 16; i < 2**HW_REGS_SIZE; i = i + 1) begin
end
end
else
begin
if (valid_wr) begin
end
end
end
endmodule
Post by: BrianHG on November 26, 2019, 05:07:25 pm
input rst,
input clk,
input we,
parameter HW_REGS_SIZE = 8;
parameter BASE_WRITE_ADDRESS = 20'h003F00;
parameter RST_VALUE_0 = 16'h0000;
parameter RST_VALUE_1 = 16'h0011;
parameter RST_VALUE_2 = 16'h0022;
parameter RST_VALUE_3 = 16'h0033;
parameter RST_VALUE_4 = 16'h0044;
parameter RST_VALUE_5 = 16'h0055;
parameter RST_VALUE_6 = 16'h0066;
parameter RST_VALUE_7 = 16'h0077;
This should be more functional, closer to my spec, and easier to see on the simulation.
Post by: nockieboy on November 26, 2019, 06:19:35 pm
Okay, I've updated the code with those changes - still can't compile it in Quartus Prime.  :-\  Getting this error still:
This is where the problem is:
If I remove [2**HW_REGS_SIZE] it compiles.  Is it not happy with the parameter size or the maths going on there? Or both?
Post by: BrianHG on November 26, 2019, 06:29:28 pm
Arrrrrrrgggg  :rant: Damn Quartus prime and QuartusIIv9.1 with their 'SPECIFIC' syntax which must be met just for the block diagram entry.  This version works, generates the block diagram, compiles without warnings, still System Verilog compliant, and simulates properly too:
Do not loose this example.  It works, and is totally parameter configurable, including the 'Arrayed' parameter feature.
Not only that, but, the 'Generate Sheet Symbol' function now also works in Quartus II v9.1!!!
(Not to mention compiling and simulating in 2 seconds instead of 50 seconds!)
input rst,
input clk,
input we,
output reg  [7:0] GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)]
parameter int BASE_WRITE_ADDRESS = 20'h0;
parameter int RST_VALUES [32] = '{
8'h01, 8'h02, 8'h03, 8'h04, 8'h05, 8'h06, 8'h07, 8'h08,
8'h09, 8'h0A, 8'h0B, 8'h0C, 8'h0D, 8'h0E, 8'h0F, 8'h10,
8'h11, 8'h12, 8'h13, 8'h14, 8'h15, 8'h16, 8'h17, 8'h18,
8'h19, 8'h1A, 8'h1B, 8'h1C, 8'h1D, 8'h1E, 8'h1F, 8'h20 };
wire valid_wr;
integer i;
if (rst) begin
GPU_HW_Control_regs[i] <= RST_VALUES[i][7:0];
end
for (i = 32; i < 2**HW_REGS_SIZE; i = i + 1) begin
end
end
else
begin
if (valid_wr) begin
end
end
end
endmodule
Post by: BrianHG on November 26, 2019, 06:33:52 pm
I've attached a simulation test bench Quartus project of the above code testing a few writes, then a sudden reset.  As you can see, the simulation proves the module is doing exactly what we want it to do...
Post by: BrianHG on November 26, 2019, 06:43:44 pm
Ok, it's time to get onto points #4 and #5 here: https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2788698/#msg2788698 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2788698/#msg2788698)
Note: place the register bank in the last 256 bytes of the 16kb addressable memory and tie it's data/address/we inputs to the RS232 debugger outputs in parallel with system 'host_' memory.
I'm assuming you will be updating points #2.  And, we will wait on point #1 so you will see what happens and why point #1 needs to be taken care of after you finish point #5.
using the 'for' loop trick, point #5 is easily doable for all those cursors.  Mix the outputs in the new temporary 'color_sel' color mixing block.  Mix the lines with simple 'OR' gates right at the 'out[11:0]', prior to the modules output pins.  Show us your results...
Post by: BrianHG on November 26, 2019, 07:55:08 pm
Damn, we would be nowhere if I didn't re-install Quartus myself...
Post by: nockieboy on November 26, 2019, 07:59:11 pm
Works just fine in 9.1.  :-+
Okay, will have a go at this tomorrow now as I doubt I'll have any time tonight the way things are going.   ::)
Some things are just too complicated to give direction by proxy, I guess.  Quartus is certainly one of those things.  :-\
Post by: nockieboy on November 27, 2019, 10:56:23 am
Okay, point #4 is nearly done.  I've attached the project below - that's the LATEST version, with all the changes so far including point #4 changes and some tweaks I made to the format of the vid_osd_generator code at the very start to make the I/O declarations easier to read.  I've also made the connections on the design sheet to the outputs of the RS232 module, so should all be present and correct.
Here's a screenshot of the design sheet now - it's getting hard to fit into one screen:
[attach=2]
(I'm aware I've set a hex value when it should be INT for the BASE_WRITE_ADDRESS in the design sheet - that's corrected).  However, it won't compile due to bus width errors - it seems Quartus isn't happy with me connecting a 14-lane bus from host_addr in the RS232 debugger module to a 20-lane input bus for addr_in in the GPU_HW_Control_Regs module.  It's also complaining about bus width errors elsewhere where the GPU_HW_REGS_BUS connects to other modules.
Is there an easy way to interface buses of different sizes without changing parameters in the modules themselves?
Post by: nockieboy on November 27, 2019, 12:45:53 pm
In danger of diluting the focus of our current efforts (#4 & #5 in the current task list), here's my latest on #1.  I've updated the sync_generator to include the 16 pixel X and Y offset.  Not 100% convinced you'll be happy with how I've done it, but it seems to work according to how I'm interpreting the simulation results (below).
[attach=1]
It's not visible in the screenshot above, but hde doesn't go high until the h_count = 16, and vde doesn't go high until v_count = 16.  Here's some close-ups:
[attach=2]
Above shows hde going high after 16 pixels.
[attach=3]
Above shows vde going high on the 16th line.
Post by: BrianHG on November 27, 2019, 01:12:33 pm
(Attachment Link)
I just clicked on 1 error at a time and fixed them.  It compiled fine... See here...
Though, you will eventually need to up, or decide what to do with the RS232_Debugger's 14 bit address.
The desktop param does feed everything else properly.  (Warning, I changer the extension of the GPU_HW_Control_Regs.sv to GPU_HW_Control_Regs.v)
(Attachment Link)
Post by: BrianHG on November 27, 2019, 01:39:35 pm
(Attachment Link)
(Attachment Link)
(Attachment Link)
Your going to have to get rid of the '-1' and accept that the outputs are delayed by 1-Hcount and 1-Vcount.  Unfortunately, with the way it is setup, if you choose an offset of 0x0, the beginning positions would never happen.
The true method of getting a proper H&V count would be to make 2 new output regs, Hcount_out and Vcount_out which latch their values from the source H&V internal counters.
Having the 'Adjusting' -1 for the counter raster limits and for the syncs are fine, bur, you now need to verify that the HH&V syncs begin and stop 16 H&V positions later compared to their original locations so that the output image is still relatively centered.  This one is easy as you will just add the H&V offset to the H&V start and stop of your current formula knowing having a '0' for an offset would move nothing as it should.  Bit, wait a minute, you HDE and VDE are now 1 pixel/line later with the new setup having '0's as an offset.  It looks like your sync offsets were OFF by 1 pixel and line all along.... Who knew?  Wait, everything needs to be re-checked.  Your going to need to verify that you actually have 640 'ON' pixels, not 641... Same with lines.  Also, when does the sync begin and end.  (Remember I said there would be a pitfall...)
Ok, to clear things up, there is a 1 count delay from the counter when you say you want the start/begin to ==.  This is fine understanding that that 1 delay is everywhere else since you H&V internal counters are preparing their value 1 clock in advance, and the 'IF(a==b) DE=<=1' result 'DE<=#' are set on the next clock.  This is fine for 2 reasons, we do not use these Hcount & Vcount anywhere else, they are just internal for the sync generator & any special trigger controls we may be adding now will also be stuck on that 1 pixel/line clock delay.
Post by: nockieboy on November 27, 2019, 01:48:25 pm
Thanks - so it was just the naming of the bus(es) that was the issue.  |O  I just modified the design on my current project instead of using the one you uploaded above as I have modifications to sync_generator (made a start on #5) and image offset addition.  :-+
Post by: nockieboy on November 27, 2019, 02:27:13 pm
:o  Yeah, you're right. Okay, removed the -1's.
Okay, so vde goes on on line 17 and is going off on line 496, so that seems like 480 + Y_OFFSET is working okay:
[attach=2]
hde is going off on pixel 656, which is 640 + X_OFFSET:
[attach=3]
Both come on at the right time (unless I'm misunderstanding the whole 1 pixel offset thing).
Latest zipped project file attached.
Post by: nockieboy on November 27, 2019, 04:32:30 pm
5.  Add a new 48 register output to the 'sync_gen.v' called 'raster_HV_trigger[47:0]'.
Okay, that was easy enough - that's already in the project files I attached in my last post.  I may need some clarification of the next bits, though...  ???
Make the even 'raster_HV_trigger[47:0]' wires pulse at a horizontal pixel position and the odd wires pulse on a vertical line according to the new 'GPU_HW_Control_regs[HW_REGS_SIZE*8-1:0]' onput wire, organized as 16 bit words, using the first 10 of 16 bits of each 2x2 bytes coming from the new input "GPU_HW_Control_regs[HW_REGS_SIZE*8-1:0]".
So the even wires [0..46] need to have a positive (one-clock?) pulse when h_count matches a value that matches the 10 bits of each 2-byte pair in GPU_HW_Control_regs?
The odd wires [1..47] will be the same, but trigger when v_count matches a value in the hardware regs?
So only the wire corresponding to the appropriate byte-pair in the hardware registers will pulse?  :-//
You should add a new parameter input to the sync_gen.v which will allow you to shift the beginning byte base (beginning) address of GPU_HW_Controls where the 'raster_HV_trigger' get their 48 settings from.  IE 48x2 bytes = 96 bytes total.
Right, that makes sense.  So we're looking to use 96 bytes from the 256 available hardware registers for these raster triggers?  And this parameter will set the base where the first of 96 bytes will be read from in the hardware registers and have a value between 0 and 160 (or 2**HW_REGS - 96)?
Once done, out on your top block diagram, 'or' these 48 HV triggers outputs together and 'or' tie them to to the upper ro[],go[],bo[] bits of the OSD_img output.  Test with the GPUtalk app.  You should be able to move 24 vertical lines and 24 horizontal lines around the screen, with the first 0-15 coordinates being non-visible as those coordinates are too far to the left and above the top of the picture since we moved the picture window by 16 pixels to the right and down in step (1).  (Once working, mix and combine / change around the 'or' driven ro[]&go[]&bo[] colors VS raster_HV_trigger[47:0] even and odd pairs so each set of coordinate generated lines may generate a different color on the display.)
I was with you all the way to 'once done'...  :-DD :-//
Post by: BrianHG on November 27, 2019, 05:04:18 pm
Think this one through....
example:
for (..i..) begin
     if  ( h_count[9:8] == HW_REGS[i*4+base_offset+0][1:0] && h_count[7:0] == HW_REGS[i*4+base_offset+1][7:0] ) raster_HV_triggers[i*2+0] <= 1;
     else raster_HV_triggers[i*2+0] <= 0;
end
then inside the 'v_count increment 'IF()begin'  Place the vertical version.
Your Syncgen should have a new output register wire called 'raster_HV_triggers[47:0]' each even one should pulse on and off for a pixel.  Make sure the odd wires in there pulse on, then off for an entire line.
Take that bundle and tie it into the current 'color_sel' module.  Make a bunch of the 'raster_HV_triggers[47:0]' force on your choice of color for each wire, over the text box and static noise, or, whatever may be feeding the color_sel modules output so you may see if what you made works...
Now, you better figure out what the 'base_offset' is, otherwise I'll go nuts.
Post by: BrianHG on November 27, 2019, 05:29:14 pm
Your going to miss the vcount position '==0' if you keep your 'VDE' in it's current location.  Move it outside the vcounter increment but leave it inside when the vcoun increment happens...
This is what you have now, it needs correcting...
// reset h_count & increment v_count at end of scanline
if (h_count == LINE - 1) // end of line
begin
h_count <= 9'b0; // reset h_count
// Now h_count has been zeroed, check if the V-count should be cleared at end of SCANLINES
if (v_count == SCANLINES - 1)
begin
v_count <= 9'b0;
frame_ctr <= frame_ctr + 1'b1; // Increment the frame counter
end
else
begin // If v_count isn't being cleared, increment v_count
v_count <= v_count + 1'b1; // increment v_count to next scanline
if (v_count == IMAGE_OFFSET_Y)
vde <= 1'b1; // Turn on vertical video data enable - start of display area
else if (v_count == IMAGE_OFFSET_Y + V_RES - 1)
vde <= 1'b0 ; // Turn off vertical video data enable - reached bottom of display area
end
end
Actually, this would still work unless you vde is set to SCANLINES - 1....
Post by: nockieboy on November 27, 2019, 08:47:02 pm
begin
begin
v_count <= 9'b0;
end
else
end
end
Soooo... How about I just move the VDE assignment out of the if (v_count == SCANLINES - 1) conditional entirely?  It'll be assigned no matter what the outcome of the if-conditional then.
begin
v_count <= 9'b0;
end
else
end
Owzat?
example:
for (..i..) begin
end
Hmm.. well nothing blows up, so that's good I guess? ???  I'm going to have to remind myself how the values in raster_HV_triggers work.  I'd be lying if I said:
h_count[9:8] == GPU_HW_Control_regs[i*4+BASE_OFFSET][1:0] && h_count[7:0] == GPU_HW_Control_regs[i*4+BASE_OFFSET+1][7:0]
...didn't confuse the hell out of me.  :o  Doesn't help that concentration is difficult when I've got a daughter singing the theme tune to Frozen 2 in my ear...  :blah:
Oh ye of little faith..  ^-^  (Hoping against all hope that I actually did get it right!)
// VGA Sync Generator
// Default: 640x480x60
// Can take parameters when initialised
// to output sync signals for any screen
// resolution
module sync_generator(
// inputs
input wire pclk, // base pixel clock (125 MHz)
input wire reset, // reset: restarts frame
input wire [7:0] GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)],
// outputs
output reg [3:0] pc_ena,  // Pixel clock enable (4-bit to allow clock division in video sub-modules)
output reg hde, // Horizontal Display Enable - high when in display area (valid drawing area)
output reg vde, // Vertical Display Enable - high when in display area (valid drawing area)
output reg hsync, // horizontal sync
output reg vsync, // vertical sync
output reg [15:0] frame_ctr,
output reg [47:0] raster_HV_triggers
// default resolution if no parameters are passed
parameter H_RES = 640; // horizontal display resolution
parameter V_RES = 480; // vertical display resolution
// image offset parameters
parameter IMAGE_OFFSET_X = 16; // offset the display to allow room at the start
parameter IMAGE_OFFSET_Y = 16; // for things to go off edge of screen
// no-draw area definitions
// defined as parameters so you can edit these on Quartus' block diagram editor
parameter H_FRONT_PORCH = 16;
parameter HSYNC_WIDTH = 96;
parameter H_BACK_PORCH = 48;
parameter V_FRONT_PORCH = 10;
parameter VSYNC_HEIGHT = 2;
parameter V_BACK_PORCH = 33;
parameter PIX_CLK_DIVIDER = 4;
parameter HW_REGS_SIZE = 8; // hardware register size set by HW_REGS parameter in design sheet
parameter BASE_OFFSET = 32; // hardware register base offset for raster triggers
// total screen resolution
localparam LINE = H_RES + H_FRONT_PORCH + HSYNC_WIDTH + H_BACK_PORCH; // complete line (inc. horizontal blanking area)
localparam SCANLINES = V_RES + V_FRONT_PORCH + VSYNC_HEIGHT + V_BACK_PORCH; // total scan lines (inc. vertical blanking area)
// useful trigger points
localparam HS_STA = IMAGE_OFFSET_X + H_RES + H_FRONT_PORCH - 1; // horizontal sync ON (the minus 1 is because hsync is a REG, and thus one clock behind)
localparam HS_END = IMAGE_OFFSET_X + H_RES + H_FRONT_PORCH + HSYNC_WIDTH - 1; // horizontal sync OFF (the minus 1 is because hsync is a REG, and thus one clock behind)
localparam VS_STA = IMAGE_OFFSET_Y + V_RES + V_FRONT_PORCH; // vertical sync ON
localparam VS_END = IMAGE_OFFSET_Y + V_RES + V_FRONT_PORCH + VSYNC_HEIGHT; // vertical sync OFF
reg [9:0] h_count; // current pixel x position
reg [9:0] v_count; // current line y position
   always @(posedge pclk)
if (pc_ena == PIX_CLK_DIVIDER) pc_ena <= 0;
else pc_ena <= pc_ena +1;
integer i;
// handle signal generation
begin
if (reset) // reset to start of frame
begin
h_count <= (IMAGE_OFFSET_X + H_RES - 2);
v_count <= (SCANLINES - 2);
//z_count <= 1'b0;
hsync   <= 1'b0;
vsync   <= 1'b0;
vde     <= 1'b0;
hde     <= 1'b0;
frame_ctr <= 16'h0000;
end
else
begin
if (pc_ena[3:0] == 0) // once per pixel
begin
// horizontal raster trigger generation
for (i = 0; i < 24; i = i + 2) begin
if ( h_count[9:8] == GPU_HW_Control_regs[i*4+BASE_OFFSET][1:0] && h_count[7:0] == GPU_HW_Control_regs[i*4+BASE_OFFSET+1][7:0] )
raster_HV_triggers[i*2+0] <= 1'b1;
else
raster_HV_triggers[i*2+0] <= 1'b0;
end
// horizontal blanking area - set HDE LOW
if (h_count == IMAGE_OFFSET_X + H_RES - 1)
hde <= 1'b0; // Turn off horizontal video data enable
else if (h_count == IMAGE_OFFSET_X)
hde <= 1'b1;  // Turn on horizontal video data enable
// check for generation of HSYNC pulse
if (h_count == HS_STA)
hsync <= 1'b1; // turn on HSYNC pulse
else if (h_count == HS_END)
hsync <= 1'b0; // turn off HSYNC pulse
// check for generation of VSYNC pulse
if (v_count == VS_STA)
vsync <= 1'b1; // turn on VSYNC pulse
else if (v_count == VS_END)
vsync <= 1'b0; // turn off VSYNC pulse
begin
// vertical raster trigger generation
for (i = 1; i < 24; i = i + 2) begin
if ( v_count[9:8] == GPU_HW_Control_regs[i*4+BASE_OFFSET][1:0] && v_count[7:0] == GPU_HW_Control_regs[i*4+BASE_OFFSET+1][7:0] )
else
end
begin
v_count <= 9'b0;
end
else
end
end
else // not at end of scanline, so just increment horizontal counter
begin
h_count <= h_count + 1'b1;
hde <= 1'b0 ;  // Turn off horizontal video data enable
end // if (h_count == LINE - 1)
end // if (pc_ena)
end // else !reset
end // always @clk
endmodule
Post by: BrianHG on November 27, 2019, 09:18:29 pm
Read carefully....
for (i = 0; i < 24; i = i + 1) begin
if ( h_count[9:8] == GPU_HW_Control_regs[i*4+BASE_OFFSET+0][1:0] && h_count[7:0] == GPU_HW_Control_regs[i*4+BASE_OFFSET+1][7:0] )
else
end
for (i = 1; i < 24; i = i + 1) begin
if ( v_count[9:8] == GPU_HW_Control_regs[i*4+BASE_OFFSET+2][1:0] && v_count[7:0] == GPU_HW_Control_regs[i*4+BASE_OFFSET+3][7:0] )
raster_HV_triggers[i*2+1] <= 1'b1;
else
raster_HV_triggers[i*2+1] <= 1'b0;
end
Hints, what's i*2+1 = when 'i' is 23?
What's the top 'raster_HV_triggers' wire position.
Read all the other changes...
I'm expecting to see some screenshots with cursor lines which your positioned & moved around with the RS232_Debugger... Maybe video of them animated using the RS232_Debugger's mouse wheel, or +/- keys which actually edit a full 16bit word...
I also expect you to discover 1 problem with the vertical lines...
Post by: nockieboy on November 27, 2019, 11:05:10 pm
47... and 47...?
I'll get you screenshots tomorrow, it's late here, but I've had a quick play with the amended code and my limited understanding of how I can connect it all together and test it, and I've managed to get a green crosshairs to appear on the screen by meddling with the GPU memory from 3F00 onwards.  I've been able to move the vertical line to the right and back, but can't move the horizontal line.  I suspect there's something wrong with how I've wired it all up, so here's the design view:
[attach=1]
Post by: BrianHG on November 28, 2019, 12:15:17 am
For now, just use a few of these:
[attachimg=1]
Post by: nockieboy on November 28, 2019, 11:10:55 am
Well, I'm certainly no expert at this and have wired up the triggers as best I can currently - I've just OR'd them all together and then OR'd them into the green channel's MSB.  Design pic attached.
I can scroll the lines, make multiple lines etc.
[attachimg=1]
Post by: nockieboy on November 28, 2019, 11:16:56 am
Still looking for this one.  The vertical line on the left appears at 16, which seems okay.  The vertical line on the right edge of the screen, however, is at 661, which seems odd...  ???
EDIT:  Latest project files attached.
Post by: BrianHG on November 28, 2019, 01:50:46 pm
Ok, all I've done is turned off my snow, made the cursors yellow (so you know it's different), changed the base address in the 'sync_generator.sv' to 0, and set the register defaults to what I played with in the RS232_debugger.
I've included a 'cursor_borders.bin' in the .zip to load into the debugger so you may see the numbers.
Step #1 test if all ' raster_HV_triggers[47..0] ' do something....
Problem #1.  raster_HV_triggers[1], the first horizontal line after the first vertical line seems to be dead!!!
These are the coordinates I set in the first 4 functional cursors:
raster_HV_triggers[0] = $0017 = 23 decimal.  First vertical line at left most of screen. (Bad)
raster_HV_triggers[1] = DEAD
raster_HV_triggers[2] = $0295 = 661 decimal.  Right most pixel on screen. (Bad)
raster_HV_triggers[3] = $0010 = 16 decimal.    Top most line on screen.     (The 1 good thing...)
#4 skipped as it is vertical...
raster_HV_triggers[5] = $01EE = 494 decimal.  Bottom most visible line.  (Bad, Error, see if you can figure out why...)
Now, don't threat, I've done this stuff for years and know where your problems are, however, enough development and tools have been doe that you should be able to figure out the solutions.
Use the .zip I sent you and see what you can figure out.  (vid_osd_generator pipe delay)
Here is a photo of all 46 functional cursors, 24 vertical and 23 horizontal.
[attach=1]
Post by: nockieboy on November 28, 2019, 04:45:38 pm
Fixed this one.  Line 123 was the problem in sync_generator.sv:
Just needed changing to this:
Was a typo or throwback from some earlier iteration of the code that I hadn't picked up on.
raster_HV_triggers[1] = DEAD [FIXED]
Horizontal raster triggers:
The first vertical line should appear at 16, but appears at 23 (out by +7).
The last vertical line should appear at 656 (640+16 X_offset) but appears at 661 (out by +5).
Vertical raster triggers:
The first horizontal appears at 16 decimal, so that's okay.
The last appears at 494 decimal, when it should be 496 (480+16 Y_offset) (out by 2).
Could the vertical raster trigger errors be due to a counting problem with a stray -1 somewhere?
Post by: BrianHG on November 28, 2019, 06:01:49 pm
Think through the IF's.  What mutes the video on the screen, or allows it through.
Also think about pixel coordinates and their numbers.
Try setting the X&Y offset parameters down to 0, play with the H&V numbers to give you a hand and really think through what happens when in the 'IF (a==b) statements.  What the numbers are at each clock and what happens to the results and 'WHEN'...
As for the vertical lines, obviously think about when they come out and if I said that the OSD was dead perfect since I simulated the whole thing even before I 'threw' your GPU into one of my scalers, why is the text ok and why is the vertical lines miss located?
Post by: nockieboy on November 28, 2019, 10:07:46 pm
Okay... trying it with zero offset on X and Y.
With zero offsets:
The first vertical line appears at 7 - this is out by 7 as before.
The second vertical appears at 645 - this is out by 5 as before.
The first horizontal appears at 0. This is correct, as before with the offsets.
The second horizontal appears at 478.  As before, out by -2.
So the results are consistent, at least.  This must be something to do with the clock delays?  Is it because the checks are not being delayed like the rest of the pixel pipeline?  It can't be when the IF checks are being made - I've tried moving the horizontal raster trigger generation IF block to where h_count gets incremented, but no change.  :-//
I'd suggest using a pipe delay for the triggers, but the errors are not consistent (the vertical line is out by 7 on the left, but 5 only on the right, so a fixed delay line won't remove that error?) In fairness, it's the fact the errors aren't fixed that has me stumped.  If they were out by a constant 7 pixels across the screen and a constant 2 pixels down it, I could likely pin the cause down really quickly, but they change...  |O
Post by: BrianHG on November 28, 2019, 10:20:11 pm
Lets start with the Horizontal line only.  You say 0 starts at 0.  Fine.  Now, at 640x480, starting coordinate Y 0, where does Y actually end?
Post by: nockieboy on November 29, 2019, 09:43:48 am
With no offset, the display area ends at 479 and the last line is 524.  So could it just be a -1 error as it appears at 478?
Post by: BrianHG on November 29, 2019, 12:45:12 pm
Good, part of 1 problem solved, next...
If IMAGE_OFFSET_Y is 0, what does this line of code do?
When does it do it?
Next, assuming IMAGE_OFFSET_Y is till 0, and V_RES is 480: What does this line do?
When does it do it?
Please answer the questions next the next post...
Post by: nockieboy on November 29, 2019, 05:18:57 pm
When does it do it?
It turns vde on when v_count is 0.  As for when it does it - I guess on the rising edge of the next CLK?
When does it do it?
It turns vde off when v_count is 479 - again, on the rising edge of the next CLK pulse?
Post by: BrianHG on November 29, 2019, 05:32:14 pm
When does it do it?
When does it do it?
Ok, now here is the important bit....
Ignoring the clk for a second, if you have the video enable turning ON on line 0, and your starting coordinate Y is 0 and this is correct on the screen, do you not think turning OFF the visible line at line 479 is a bad idea if you want to visibly see line 479?
Regardless if the counter is behind by 1 CLK, meaning this hidden internal counter is already +1, meaning whend you turn on at line 0, the counter may be at line 1, and the same for at the end since the switch on and off both have the same delay....
Post by: nockieboy on November 29, 2019, 06:36:49 pm
Okay, so the -1 on line 134 needs removing?
if (v_count == IMAGE_OFFSET_Y)  <---- REMOVED -1
else if (v_count == IMAGE_OFFSET_Y + V_RES)
That fixes the bottom horizontal line...
Post by: BrianHG on November 29, 2019, 06:53:00 pm
Do a simulation and show me the key horizontal numerical points.  Make sure everything is going off and of with the right amount of pixels, regardless that they will all be shifted to the right by 1 pixel.
Post by: BrianHG on November 30, 2019, 11:09:45 am
@nockieboy I realize the holidays coming up with family obligations must be adding a toll on your available time to concentrate here.
You have 1 thing left to verify about the sync generator, then, you will be gutting the osd_generator and wiring in 2 or 3 address generators in place of my limited 64x32 column current one.
We'll skip sprites and just do the final 2 palette memories and overlay.  You already have what might already be functional Z80 interface, but you may want to multiplex that GPU memory interface side with a separate module so you may have additional access within the GPU project.
If there is time later, we'll look at piggy-backing on some sprites and other more advanced features.
Post by: nockieboy on December 01, 2019, 10:21:14 am
Okay, I'm hoping this is what you're asking for... I've got the start of the visible display (top left of screen) and end of the visible display (bottom right of screen):
Start:
[attachimg=1]
End:
[attachimg=2]
Yes, work had cranked up the last week as well, so I've been finding it very hard to find time to work on the project.  :'(
I would really appreciate being able to get some form of sprite support implemented, but I understand that your time is limited.  I may have some time this week so I'll try to catch up as best I can.  :)
I have the hardware for the Z80 interface sorted (well, it's just a breadboard with 4 buffers on it to convert from 5V down to 3.3V and a bi-directional buffer for the data bus), I think it's just the mux to allow the RS232 and the Z80_bridge modules to work alongside each other.  I haven't given that any thought past your previous comments on it yet.
EDIT:
Added end of line as well:
[attachimg=3]
So, I've removed a couple of the -1's from the checks for the hde assignment - I've also removed an unnecessary check to turn off hde when leaving the visible area as it's already done further down in the code.  Updated sync_generator code is below, but I've also attached the current project so we're on the same page.
This change means that the bottom horizontal bar is at decimal 495, and the far right vertical is now on decimal 662 (with X_OFFSET and Y_OFFSET set to 16).
Though I'm still going round in circles with this - I'm going to need you to tell me what the issue is, I think, as I'll never find it before Christmas on my own.  :-//
(Okay, can't leave the code for sync_generator in this post as there's a bug in the forum software that doesn't allow me to post code blocks in the same forum post as attachments for some reason.)
Post by: nockieboy on December 01, 2019, 10:57:53 am
// resolution
// inputs
// outputs
integer i;
begin
begin
//z_count <= 1'b0;
hsync   <= 1'b0;
vsync   <= 1'b0;
vde     <= 1'b0;
hde     <= 1'b0;
end
else
begin
begin
else
end
// start of visible display area - set HDE HIGH
begin
else
end
begin
v_count <= 9'b0;
end
else
end
end
begin
if (h_count == IMAGE_OFFSET_X + H_RES)
end // if (pc_ena)
end // else !reset
end // always @clk
endmodule
Post by: nockieboy on December 01, 2019, 02:18:24 pm
I've made tentative steps towards getting the data mux started for the RS232 and Z80_bridge modules (the last part needed to get the Microcom talking to the GPU?)
Currently, I've sorted out the inputs and outputs I think I need.  I'm hesitant to actually start writing the HDL for the mux as I'm not 100% clear on how I can create it.  I know it needs to switch between two (or even three?) sets of inputs consisting of:
Design pic below, showing the module (which is currently empty - just has I/O defined) partially connected to the Z80_bridge.
So, my thoughts on how it would work are that it defaults to Port A (the Z80 port), passing through address, data and wr_ena's.  When a rd_req is detected, it waits 2 clocks then passes the data output from the osd_generator module back to the Z80_bridge.
If a read or write request is detected on Port B (i.e. from the RS232 module) and it's doing nothing at that moment, it will switch the above described functions to route the address and data to/from the RS232 module instead.
What I'm not sure about is how it will deal with activity from either port that overlaps with an existing request.  ???  Will it just pipeline it for 2 clocks then push the new request through?
I'm aware this is a sidetrack from the current work on the raster triggers and sync_generator, but am trying to keep myself busy while I have some free time and it doesn't align with yours.  :)
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: jhpadjustable on December 01, 2019, 02:56:00 pm
If your arbiter only samples the request signals when there is no request in progress, there won't be any conflicts.
Post by: BrianHG on December 01, 2019, 03:18:11 pm
Start:
(Attachment Link)
End:
(Attachment Link)
EDIT:
[attachimg=3]
Ok, VDE beginning 1 pixel to the left is OK as it will not affect anything anywhere else.
There is 1 minor change I want you to make, though it wont alter anything, in reading the code, in the future, it will make things easier:
Move this line:
To right after this line:
adding the word 'ELSE' in front of the 'Turn Off' if().
Ok, now, for that pesky vertical margin bars being off the the right by 6 pixels.  Tell me:
Why do you think we pass the 'hde, vde, vs, hs' coming out of the sync generator, going into the 'vid_ods_generator', then out of the 'vid_osd_generator' into the 'vid_out_stencil' then out of there into the video output pins?  Why didn't we just tie those signals straight from the sync generator to all those adjacent modules and the output pins in parallel?
Where is the test picture coming out of?
Where are the HV triggers currently coming out of?
Post by: BrianHG on December 01, 2019, 03:22:46 pm
Even so, though I designed memory requests to operate on a 1 pulse, if he just makes a 1 bit counter cycling back and forth muxing port A&B, he has so much access speed that it will still be transparent to the Z80 and RS232.  Both Z80 and RS232 have return data ready latches for reads as well.
Post by: nockieboy on December 01, 2019, 04:24:47 pm
Move this line:
All done.  :-+
Ahhh... of course!  |O  There's a 6-pixel delay on hde, vde, vs and hs.  How did I not see that?!
So the question now is:  what's the best way to delay the 48 triggers by PIPE_DELAY?  I could create a 48-wide delay pipe, but to my inexperienced mind that seems very wasteful...  :-\
Post by: BrianHG on December 01, 2019, 04:39:46 pm
Move this line:
All done.  :-+
Yes, adding an HV triggers input to the osd_generator and again a through to an output would fix the problem and for now just do it.  You may use the new HW regs trick to make to verilog code look neater and tie the delay to the 6 'pipeline' parameter.
However, in the future, these HV triggers will never make it that far to an output.  Some will just be used to reset, increment and trigger the start and stop of your address generators.  They will never go through such a pipe.  And also remember, any unused HV triggers anywhere in the chain, automatically get removed by the compiler automatically before fitting into the FPGA.  You do not need to worry about waste.  During this test, since all 48 triggers are driving pixels on the display, yes, adding that 48x6 pipe would use up all registers.  You still need to add the input and output on the OSD with the pipe to try and see if all works correctly.  When we disconnect the output 'or' to the green and red colors, the compiler will drop any unused registers in the design, but in the future, if you need 1 of 2 test debug cursors on the screen, they will be there to tap at will.
Post by: BrianHG on December 01, 2019, 05:30:16 pm
it's a side effect of having someone else dictate a design strategy to you without you creating it completely yourself finding out these issues on your own.  I'm trying to balance letting you figure out things you may have missed or not noticed with how much more to just give you.  If everything works ok so far, we have address generators, bytes/pixel selection, 2 color palettes and 1 video superimpose switch.
Then we can look at sprites.
As for you 'Host' ram interface mux, your easiest solution will be a state machine to select what gets sent to the GPU's host ram port.  Since it's an A/B selection, you can do this with an 'IF' statement, and predict the pipe length going through the GPU ram for when it's read_rdy flag should pulse on the output.
Post by: nockieboy on December 01, 2019, 05:43:35 pm
Okay, all done.  In testing - using X and Y_OFFSET set to 16 - I'm getting lines appearing at these values:
16, 655, 16, 495
So with X- and Y- offsets set to 0, I would expect values of 0, 639, 0, 479.... which is spot on.  All seems to be working fine now!  :-+ ;D ;D
EDIT: Latest project files.
Post by: BrianHG on December 01, 2019, 09:20:35 pm
Ok, you will now need to generate a configurable - bitplane-2-raster - Verilog module.  You already have a fixed one here in the vid_osd_generator:
assign osd_image          = char_line[(~dly6_disp_x[2:0])];
What this is doing is taking the byte 'char_line[7:0]' and selecting the bits from MSB to LSB according to the disp_x coordinate's 3 lsb.
However, we will now have 4 pixel types:
You will have an 8 bit input for bitplane the pixel data.
You will have an 8 bit input for the background default color.
You will have an 'x' coordinate input.
You will have the pena[3:0] input.
You will have a color mode input + 1 special input to latch a second adjacent byte in multi-color text mode and 16 bit RGB color mode.
You will pass through the 'x' coordinate
You will pass through the color mode.
1) monochrome 8bit.  Basically the existing above, however, you will set the output pixel color to the first 4 bits of the background color when the bit on the picture bitplane byte is 0 and use the upper 4 bits when the bit on the bit-plane byte is high.
2) 4 color 2 bit per pixel.  Now, your output will be 2 bits stacked, 2 copies every second X pixel, you will output a 2 bit color. EG pixel 0&1 output bitplane[7:6],  pixel 2&3 output bitplane[5:4], pixel 4&5 output bitplane[3:2],
3) 16 color 4 bit.  Now, our output will be 4 bits stacked, 4 copies every four X pixel, you will output a 4 bit color.  EG pixel 0,1,2,3 output bitplane[7:4], EG pixel 4,5,6,7 output bitplane[3:0]
3) 256 color 8 bit.  Now, our output will be 8 bits stacked, 8 copies every eight X pixel, you will output a 4 bit color.  EG pixel 0,1,2,3,4,5,6,7 output bitplane[7:0], yes that same 1 value will repeat 8 times is the source X counter counts through those numbers sequentially.
4) Special color text mode where you latch the first character as the bit plane graphic and the second character as a replacement for the background default color.  The rest should follow #1.
5) Special 16bit true color mode.  Your taking 2 sequential bytes, like the color text mode, and outputting a full 16 bits parallel on the output, however you will also output a 17th bit as a flag so that proceeding modules will know you are in this 16bit RGB mode.
Come back with ideas on how you want to achieve this...
Post by: nockieboy on December 01, 2019, 09:46:38 pm
Yeah, just so I'm happy I understand this - char_line[7:0] is a byte returned from the GPU RAM where the character to be drawn is addressed at the current XY-position.  The 8-bits returned refer to the horizontal slice through the character at the current screen raster position, and the exact pixel is the bit in that byte referred to by ~dly6_disp_x[2:0], right?  ???
Bitplane pixel data?  Is this the character tile set?
This will be another bitplane, or a palette entry?
So this sounds like ~dly6_disp_x[2:0]?  Or will this be an 'x' coordinate from the entire width of the display area?
This one I can handle.  ^-^
These inputs don't sound like they'll be a parameters?  Could these be done with the HW_regs?
So these will need to be delayed by PIPE_DELAY accordingly?
So this is what we're using already, but using 4-bit colour taken from the MSN or LSN of the background colour based on whether the picture bitplane byte (or bit?) is 0 or 1?
 :o  Oh I'm going to need some serious guidance on creating this.   :-//
Post by: BrianHG on December 01, 2019, 10:06:31 pm
Ok, each byte coming from ram can either be set to:
2 color, B&W, ie, 1 byte of ram = 8 pixels.
4 color,  ie 1 byte of ram = 4 pixels, 4 possible colors each.
16 color, ie 1 byte of ram = 2 pixels, 16 possible colors each
256 color, ie 1 byte of ram = 1 pixel, 256 colors each.
Now it doesn't matter if the byte we receive is from a font memory (tile memory) or just raw pixel data.  The idea is to have a general purpose module where we can set an output video mode type, keep on feeding it bytes, doesn't matter from where, and an X coordinate.  This module should spit out pixels accordingly.
So, in 256 color mode, the X coordinate is ignored.  In 16 color mode, the X coordinate's 2 LSBs are ignored, it's just the 3rd bit which is used to determine whether to show the first half, or second half of the pixel.
In 2 color mode, we want to use the alternate background color byte to define the 2 possible 16 color to show.  If the pixel is 1, then present the upper 4 bits of the default input color byte.  If the pixel is a 0, then present the lower 4 bits of the default color byte input.
Let's start with this much.
Post by: nockieboy on December 02, 2019, 10:20:59 am
Okay, I've got this far:
module bitplane_to_raster (
// inputs
input wire clk,
input wire [3:0] pc_ena,
input wire [7:0] pixel_data_in,
input wire [7:0] bg_color,
input wire [9:0] x_in,
input wire [1:0] colour_mode_in,
input wire two_byte_mode,
// outputs
output reg osd_ena,
output reg [7:0] osd_data_out,
output reg [9:0] x_out,
output reg [1:0] colour_mode_out
// parameters
parameter PIPE_DELAY = 2;
// *  DELAY PIPES                                                              *
reg [9:0] dly_x [9:0];
reg [1:0] dly_colour_mode [9:0];
always @ ( posedge clk ) begin
if (pc_ena[3:0] == 0) begin
dly_x[0] <= x_in;
dly_x[9:1] <= dly_x[8:0];
x_out <= dly_x[PIPE_DELAY-1];
dly_colour_mode[0] <= colour_mode_in;
dly_colour_mode[9:1] <= dly_colour_mode[8:0];
colour_mode_out <= dly_colour_mode[PIPE_DELAY-1];
end // pc_ena
end // always@clk
// *  RASTER GENERATION                                                        *
// color_mode_in determines the operating mode for the bitplane_to_raster module
// it is a 2-bit signal, providing 4 modes of operation to this module e.g.:
// 00 =   2 colour mode - 8 pixels per byte in GPU RAM
// 01 =   4 colour mode - 4 pixels -----"------"------
// 10 =  16 colour mode - 2 pixels -----"------"------
// 11 = 256 colour mode - 1 pixels -----"------"------
case (colour_mode_in)
2'h0 : begin // 1-bit (2 colour)
assign osd_data_out <= pixel_data[(x_out[2:0])];
end
2'h1 : begin // 2-bit (4 colour)
assign osd_data_out <= pixel_data[(x_out[2:1])];
end
2'h2 : begin // 4-bit (16 colour)
assign osd_data_out <= pixel_data[(x_out[2])];
end
2'h3 : begin // 8-bit (256 colour)
assign osd_data_out <= pixel_data;
end
endcase
endmodule
Obviously I know the code above won't work in its current state, the case statement is mostly placeholder to assist with my understanding as we flesh it out, but I'm not sure about the delay pipes - whether they're needed at all, for example - but they're there and can be removed if necessary.  Also, am I going in the right direction with the case statement, or should it be in an always block?
I'm a bit confused about this next bit, though - I've obviously misunderstood the output from this module (so it should be an 8-bit output?):
If the output is an 8-bit value, we're only talking about assigning the upper or lower nibble of that output byte - what happens to the other half?
Is this going in the right direction?
Post by: BrianHG on December 02, 2019, 02:31:43 pm
Will this help:
[attachimg=1]
Now, in 2 byte 1 bit color mode, the 'Default Color Byte' will be the second 'Byte In' instead of the default single value input.
Post by: nockieboy on December 02, 2019, 05:50:03 pm
Sooo... something like this?
2'h0 : begin // 1-bit (2 colour) - 8 pixels per byte
// set the output pixel color to the first 4 bits of the background color
// when the bit on the picture bitplane byte is 0 and use the upper 4 bits
// when the bit on the bit-plane byte is high
if (pixel_data[(x_out[2:0])] == 1'b1) begin
assign osd_data_out[7:5] <= 1'b0;
assign osd_data_out[4] <= 1'b1;
assign osd_data_out[3:0] <= bg_color[7:4];
end
else begin
assign osd_data_out[4] <= 1'b0;
assign osd_data_out[3:0] <= bg_color[3:0];
end
end
2'h1 : begin // 2-bit (4 colour) - 4 pixels per byte
// output will be 2 bits stacked, 2 copies every second X pixel, you will
// output a 2 bit color. EG pixel 0&1 output bitplane[7:6],  pixel 2&3
// output bitplane[5:4], pixel 4&5 output bitplane[3:2]
end
2'h2 : begin // 4-bit (16 colour) - 2 pixels per byte
// output will be 4 bits stacked, 4 copies every four X pixel, you will
// output a 4 bit color.  EG pixel 0,1,2,3 output bitplane[7:4], EG pixel
// 4,5,6,7 output bitplane[3:0]
end
2'h3 : begin // 8-bit (256 colour) - 1 pixel per byte
// output will be 8 bits stacked, 8 copies every eight X pixel, you will
// output a 4 bit color.  EG pixel 0,1,2,3,4,5,6,7 output bitplane[7:0],
// yes that same 1 value will repeat 8 times is the source X counter
// counts through those numbers sequentially
end
endcase
So, according to the comments in the code (which I cut 'n' pasted from one of your previous posts for guidance), 1-bit and 8-bit modes should work according to the requirements.  It's just 2-bit and 4-bit I'm not sure about.  And haven't touched the special modes yet.  Your diagram helped me understand 1-bit colour mode, but according to the diagrams, 4-bit mode puts both halves of the pixel_data into two consecutive osd_data_out bytes with the top nibble set to 0 - is that right?  :-//
Post by: BrianHG on December 02, 2019, 06:12:51 pm
1 bit looks good.
2 bit should look like 4 bit, but you are tunneling bit AB, then CD, then EF, then GH into the bottom 2 bits of byte color out.
8 bit is obviously correct.
Then expand to 2 byte source data.  (This will mess thing up since the bytes come in sequentially adn you need to turn them into parallel ahead of everything else)
I know this doesn't look like the Amiga style bitplanes.  Where a separate bitplane layer comes from a different section of memory.  The Amiga was done this way since they wanted at least 32/64 colors with 14Mhz ram, 256 kilobytes on the original Amiga 1000.   We don't have speed issues, however, you did say you were going to a larger FPGA for internal ram and we do have the speed for true 8bit color, I chose the Atari800 style 2,4,16 color modes packed in 8 bits.
Post by: nockieboy on December 02, 2019, 07:44:48 pm
Okay, I'm not 100% but I think this is what you're asking for?
end
else begin
end
end
assign osd_data_out[7:6] <= pixel_data[1:0];
assign osd_data_out[5:4] <= pixel_data[3:2];
assign osd_data_out[3:2] <= pixel_data[5:4];
assign osd_data_out[1:0] <= pixel_data[7:6];
end
assign osd_data_out[7:4] <= pixel_data[3:0];
assign osd_data_out[3:0] <= pixel_data[7:4];
end
end
endcase
Post by: BrianHG on December 02, 2019, 09:07:29 pm
Nope...
Except for 8 bit, Pixels are coming in in a parallel fashion, you need to send them out in a series fashion.
Look at the 2 channels in my hand drawing for the 4 bit color.  The output is only 4 bits, bus switches between the source 2 groups of 4 bits depending on the x coordinate.
Post by: BrianHG on December 02, 2019, 09:36:20 pm
Think about is this way, you have 2 pixels in a byte, each can be 1 of the same 16 colors, how do you send those out, 1 16 color pixel at a time?
Now you have 4 pixels in 1 byte, 4 possible colors for each pixel, how do you send those out 1 4 color pixel at a time?
Now, you have 8 pixels in 1 byte, 2 possible colors, how do you send out those out, 1 2 color pixel at a time?  (Ignoring my bg_color[] thing)
Post by: nockieboy on December 02, 2019, 10:36:44 pm
Okay, how about this?
if (~two_byte_mode) begin // one-byte mode
assign osd_data_out[7:5] <= 3'b000;
end
else begin
end
end
assign osd_data_out[7:4] <= 4'b0000;
case (x_out[2:1])
2'h0 : begin
assign osd_data_out[3:2] <= pixel_data[7:6];
end
2'h1 : begin
assign osd_data_out[3:0] <= pixel_data[5:4];
assign osd_data_out[1:0] <= pixel_data[5:4];
end
2'h2 : begin
assign osd_data_out[3:0] <= pixel_data[3:2];
assign osd_data_out[1:0] <= pixel_data[3:2];
end
2'h3 : begin
assign osd_data_out[3:0] <= pixel_data[1:0];
assign osd_data_out[1:0] <= pixel_data[1:0];
end
end
end
if (x_out[3])
assign osd_data_out[3:0] <= pixel_data[3:0];
else
end
end
endcase
end // one-byte mode
else begin
end // two-byte mode
Post by: BrianHG on December 02, 2019, 10:42:03 pm
4 bit is correct.  With 2 bit, 4 color mode, why are you stacking 2 pixels at the output simultaneously.  There should only be 2 bottom bits coming out and all the 6 upper bits should = '0'.
Also, you cant 'assign' when you are making 1 reg equal another.
Also, get rid of the osd_data.  Let's call this one 'pixel_out'.
And for the input, call it 'ram_byte_in'.
These labels would make so much more sense.
Post by: nockieboy on December 02, 2019, 10:53:17 pm
Chalk that up to misunderstanding what you'd written previously about stacking bits and making copies every second pixel.  ::)
pixel_data_in is a wire, if that makes any difference?  I know you can't assign in an 'always' block, but this isn't in one?  So I should just remove the assign keywords?
Sure do.  Wasn't sure what to call them and, as I was working from the old vid_osd_generator, I used labels from that.  Okay, they're all renamed.  Full module code below.
// inputs
input wire clk,
input wire [7:0] ram_byte_in,
// outputs
output reg pixel_out_ena,
output reg [7:0] pixel_out,
// parameters
// *  DELAY PIPES                                                              *
dly_x[0] <= x_in;
end // pc_ena
end // always@clk
if (ram_byte_in[(x_out[2:0])] == 1'b1) begin
pixel_out[7:5] <= 3'b000;
pixel_out[4] <= 1'b1;
pixel_out[3:0] <= bg_color[7:4];
end
else begin
pixel_out[4] <= 1'b0;
pixel_out[3:0] <= bg_color[3:0];
end
end
assign pixel_out[7:2] <= 6'b000000;
case (x_out[2:1])
2'h0 : begin
pixel_out[1:0] <= ram_byte_in[7:6];
end
2'h1 : begin
pixel_out[1:0] <= ram_byte_in[5:4];
end
2'h2 : begin
pixel_out[1:0] <= ram_byte_in[3:2];
end
2'h3 : begin
pixel_out[1:0] <= ram_byte_in[1:0];
end
end
end
pixel_out[7:4] <= 4'b0000;
if (x_out[3])
pixel_out[3:0] <= ram_byte_in[3:0];
else
pixel_out[3:0] <= ram_byte_in[7:4];
end
pixel_out <= ram_byte_in;
end
endcase
else begin
endmodule
Actually, I've just tried compiling the code and it's throwing errors - should the raster generation section be in an 'always' block then?
Post by: BrianHG on December 03, 2019, 12:23:04 am
And this one is tricky, in 2 byte mode the ram_data_in will be giving you the bitplane data like usual when lsb of the X coordinate is 0 and it will be giving you the upper 8bits, or color_data when the X coordinate's lsb is 1.  Since you need the 2 data's in parallel, maybe you should latch these 2 firstly. and remember, 1 will need an extra delay to be parallel and you entire color pixel generator will now be up to a 3 pixel clock delay when all is said and done.
Remember, take and latch the ram data input and delay it.  Latch/hold it's value every second pixel if you are in 16bit pixel mode and latch the odd pixels into the upper 8 bits register.  We will want an output flag to signify 16 bit mode when not in the special colored text mode.
Post by: BrianHG on December 03, 2019, 12:25:38 am
// inputs
input wire clk,
// outputs
// parameters
// *  DELAY PIPES                                                              *
dly_x[0] <= x_in;
end // pc_ena
end // always@clk
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
end
end
if (x_out[3])
else
end
end
endcase
else begin
endmodule
Not only that, but inside the 'pc_ena[3:0]==0'.  Also, I think you have the 16 color high and low bits backwards/mirrored.
Post by: nockieboy on December 03, 2019, 09:54:30 am
Are you sure?  I've set it up as per the comment you'd made previously (included as comments):
if (x_out[3])
else
I've interpreted the comments to mean if x_out[3] is 1, output bitplane [3:0] - which is the pixel_out[3:0] <= ram_byte_in[3:0]; line?  Does that definitely need swapping around then?  ???
Post by: nockieboy on December 03, 2019, 10:41:16 am
Okay, ignore the content of the case selects for 16-bit mode, they're just placeholders from the 8-bit code.
I've updated the module to make a start on 16-bit mode.  In doing so, I'm wondering if we actually need a 'two_byte_mode' input at all?  It would make sense to just add another bit to colour_mode_in and put the 16-bit code in the main case..select block for any values of colour_mode_in with bit 2 set high?  Or do you have other plans for the separate 'two_byte_mode' input?
You may want to pay special attention to the DELAY PIPES block.  I've delayed RAM_BYTE_IN using the usual pipe method and am setting a new value, COLOUR_DATA, using the byte in the pipeline after the delayed RAM_BYTE value.  Hopefully that should work to get the two bytes in parallel for all cases where PIPE_DELAY > 1.
Now I'm just a little confused about the output in 16-bit mode, so haven't done anything with the placeholder code in the 16-bit case block.  Can you expand a little on what is required to make these two special cases work?
// inputs
input wire clk,
// outputs
output reg mode_16bit, // high when in 16-bit mode
// parameters
parameter PIPE_DELAY = 3; // minimum value of 2
// internal registers
reg [7:0] colour_data;
reg [7:0] ram_byte;
// *  DELAY PIPES                                                              *
reg [9:0] dly_ram_byte [7:0];
reg [9:0] dly_colour_mode [1:0];
reg [9:0] dly_mode_bit [1:0];
dly_x[0] <= x_in;
dly_mode_bit[0] <= two_byte_mode;
dly_mode_bit[9:1] <= dly_mode_bit[8:0];
mode_16bit <= dly_mode_bit[PIPE_DELAY-1];
dly_ram_byte[0] <= ram_byte_in;
dly_ram_byte[9:1] <= dly_ram_byte[8:0];
ram_byte <= dly_ram_byte[PIPE_DELAY-1];
colour_data <= dly_ram_byte[PIPE_DELAY-2]; // in two-byte mode, colour_data should follow the ram_data byte
end // pc_ena
end // always@clk
always @ (posedge clk) begin
if (~two_byte_mode) begin // 8-bit mode
mode_16bit <= 1'b0; // update mode_16bit output to 8-bit mode
if (ram_byte[(x_out[2:0])] == 1'b1) begin
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
pixel_out[1:0] <= ram_byte[7:6];
end
2'h1 : begin
pixel_out[1:0] <= ram_byte[5:4];
end
2'h2 : begin
pixel_out[1:0] <= ram_byte[3:2];
end
2'h3 : begin
pixel_out[1:0] <= ram_byte[1:0];
end
endcase
end
if (x_out[3])
pixel_out[3:0] <= ram_byte[3:0];
else
pixel_out[3:0] <= ram_byte[7:4];
end
mode_16bit <= 1'b0; // update the mode output to show whether it's 8 or 16-bit mode
pixel_out <= ram_byte;
end
endcase
end // 8-bit mode
else begin // 16-bit mode
case (colour_mode_in[0])
1'h0 : begin // special colour text mode
// latch ram_byte as the bit plane graphic and colour_data
// as a replacement for the background default color. The
// rest should follow #1.
end
else begin
end
end
1'h1 : begin // 16-bit (true colour)
// taking 2 sequential bytes, like the color text mode, and outputting
// a full 16 bits parallel on the output, however you will also output
// a 17th bit as a flag so that proceeding modules will know you are
// in this 16bit RGB mode.
mode_16bit <= 1'b1; // update mode_16bit output to 16-bit mode
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
endcase
end // 16-bit mode
end // if (pc_ena[3:0] == 0)
end // always@clk
endmodule
Post by: BrianHG on December 03, 2019, 04:14:55 pm
Ok, for the 16 bit mode, we will use an alternate parallel byte input.  eg: currently you are using the bg_color[7:0].  place a second input 'ram_byte_h[7:0]'.  Use that byte that byte switch inside the first :
case()
Where you select between bg_color[7:0] & ram_byte_h[7:0] depending on 16 bit color mode.  get rid of the second half or your code.
Next, instead of an 'if' just pixel shift/pipe through the 'two_byte_mode' to it's output and shift in a 'ram_byte_h[7:0]' to a 'pixel_out_h[7:0]'.  Make sure the pipes have the same delay as the pixel bitplane to raster processing.
Also, you only have 3 color modes, I want a fourth 'enable/disable'  in the disable, you should shift out '0' on the pixel_out and two_byte_mode outputs.  Remember that all the input controls should operate in parallel and any controls being fed through should come out with the appropriate pixel.
The x pixel positioning looks correct everywhere except in the 1 bit color mode.  You need to have the ' ~ ' just like in the original code when analyzing the bit based on pixel location.  My dyslexia got the 16 color and 2 color modes backwards...
For now, see if you can wire in the module to the existing font ram's output.  Adjust the osd_module's 6 pipeline delay setting, start choosing and wiring HW_Regs to the input controls.  Make a HW_Regs table so you know where your controls are and what they do.  And for the output, we will next make 2 palettes, 1 for text and 1 for regular 256 color graphics.  You will need to made default colors for these as well...
Post by: nockieboy on December 03, 2019, 04:36:21 pm
case()
Sorry, didn't get that at all. :o  Again with the crayons and single-syllables please!  ;)  I've created an extra input, 'ram_byte_h[7:0]', but I don't follow with the rest of the instructions here.  :-[
Instead of an if??  I've created another output, 'pixel_out_h [7:0]', and created a delay pipeline for ram_byte_h to pixel_out_h.  two_byte_mode is already pipelined.
3? Looks like 4 to me? 2, 4, 16 and 256 colour mode?  How would I implement this? Add another bit to colour_mode?  ???
Okay, have fixed that hopefully.  Current code below:
// inputs
input wire clk,
input wire [7:0] ram_byte_h,
// outputs
output reg [7:0] pixel_out_h,
// parameters
reg [7:0] ram_byte;
// *  DELAY PIPES                                                              *
reg [9:0] dly_ram_h_byte [7:0];
dly_x[0] <= x_in;
dly_ram_h_byte[0] <= ram_byte_h;
dly_ram_h_byte[9:1] <= dly_ram_h_byte[8:0];
pixel_out_h <= dly_ram_h_byte[PIPE_DELAY-1];
end // pc_ena
end // always@clk
if (ram_byte[(~x_out[2:0])] == 1'b1) begin
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
if (x_out[3])
else
end
end
endcase
end // 8-bit mode
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
endcase
end // 16-bit mode
end // always@clk
endmodule
Post by: BrianHG on December 03, 2019, 04:51:05 pm
In 2 byte mode, if you keep your current mode of thinking, there is no 2bit color mode there, it's just the high byte and low byte being passed through.
It's 16 bit color mode. in other words, 65536 colors.
No palette for this mode.  That's why we need to pass-through flag to tell the palette section to change the way it works with a 16 bit pixel coming in instead of a 8 bit pixel.
Post by: nockieboy on December 03, 2019, 05:07:06 pm
There's no 1-bit or 4-bit mode either, surely?  But that doesn't clarify anything from my previous post.  I'm going away to have a lie down for a bit.  Maybe coming back after a break will help.  :scared:
Post by: BrianHG on December 03, 2019, 05:13:09 pm
No, everything else is correct...
No touch...
In 16bit mode, all 16 bits make a single pixel. Normal ram_byte and ram_byte_h make 1 16 bit pixel
5 bits go straight to red, 6 bits go straight to green, 5 bits go straight to blue.
It's only the 1 bit text mode which is different, where we use the lower byte to construct the text font and the higher byte to select the foreground and background 2 possible 16 colors.
I guess you can engineer a 4 color font mode if you like, re-routing the upper byte into the upper 6 missing bits of the pixel out, then route the 2 top bits into the 2 bottom bits of the pixel_out_h byte.
This is your project after all.  Make what you like.
Post by: nockieboy on December 03, 2019, 05:54:13 pm
No it's fine, I wasn't suggesting there should be a 4-colour font mode, I was just thinking through the implications of what you'd said.
Anywho, I'm at a bit of a stumbler here - I don't know what I need to do to progress the 16-bit mode code segment.  :-//
Post by: BrianHG on December 03, 2019, 06:07:35 pm
In 2 bit color color 2byte mode, the bg_color is swapped with the ram_byte_h.
That's the only mistake you have there.
In 8bit color mode, 2byte mode, you just pass the ram_byte_h to the output pixel_out_h.
When wired to the memory, the ram_byte_h is nothing more than a separate read port's data output.
You should be able to wire this thing into the current OSD mem output, except, only the first color mode would give you pixels if the bg_color has an appropriate value.
Post by: nockieboy on December 03, 2019, 06:35:44 pm
Oh right - I'm not used to there not being loads of things wrong with what I've written! I thought there must be something more... :-DD
Updated code below.  I'm just trying to work out how to connect the bitplane_to_raster module up in the design schematic..  ???
I'm either going to have to make design symbols for gpu_dual_port_ram_INTEL and/or multiport_gpu_ram, or do what we did in vid_osd_generator and instantiate those modules in the bitplane_to_raster code?
// inputs
input wire clk,
// outputs
// parameters
reg [7:0] ram_byte;
// *  DELAY PIPES                                                              *
dly_x[0] <= x_in;
end // pc_ena
end // always@clk
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
if (x_out[3])
else
end
end
endcase
end // 8-bit mode
// 2-bit colour 2-byte mode
pixel_out[3:0] <= ram_byte_h[7:4];
end
else begin
pixel_out[3:0] <= ram_byte_h[3:0];
end
end
pixel_out_h <= ram_byte_h;
end
endcase
end // 16-bit mode
end // always@clk
endmodule
Post by: BrianHG on December 03, 2019, 08:03:31 pm
// inputs
input wire clk,
// outputs
// parameters
reg [7:0] ram_byte;
// *  DELAY PIPES                                                              *
dly_x[0] <= x_in;
end // pc_ena
end // always@clk
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
if (x_out[3])
else
end
end
endcase
end // 8-bit mode
end
else begin
end
end
end
endcase
end // 16-bit mode
end // always@clk
endmodule
No more symbols, everything get wired as test inside the 'osd_generator'.
You may only make symbols a separate simulator project in QIIv9.1 to see if you module works on its own.
Fix the multiple bugs in this part:
Also, why did you :
and in 16 bit color mode:
Why not use 2'h3.
and change your 'case (colour_mode_in[0])' to the normal 'case (colour_mode_in)'?
Post by: BrianHG on December 03, 2019, 08:27:01 pm
I'll tell you what, you may make the next module, 2 palettes plus a color pixel mixer, as it's own module outside the osd_generator block.
Post by: nockieboy on December 03, 2019, 09:13:29 pm
Yeah they're not bugs as such, the code there is placeholder copied over from the 1-byte code above it (as you'd mentioned that it would follow #1).  I'm still trying to work out exactly what to put in here - your comment here:
...is throwing me, slightly.
Also, why did you :
Why not use 2'h3.
No idea - I've changed it now.
I think this was because there were only two 'special' modes, so I didn't care about anything other than the LSB of colour_mode_in to select between them?
Had another go at the special colour text mode code...
2'h0 : begin // special colour text mode
end
else begin
pixel_out_h <= bg_colour;
end
end
2'h3 : begin // 16-bit (true colour)
end
endcase
end // 16-bit mode
Post by: BrianHG on December 03, 2019, 09:34:28 pm
Your fine, place it inside the OSD generator in place of the :
//  The resulting 2-bit font image at x is assigned to the OSD[1:0] output
//  Also, since there is an 8th bit in the ascii text memory, I use that as a third OSD output color bit
Note that you will need to make the new 'osd_image' output into a pixel_out and pixel_out_h ports.  Call them pixel_out_top, pixel_out_top_h, and the wire 'pixel_out_top_16bit'
These 3 outputs will leave the vid_osd_generator.  For now, set single byte test mode and wire the bg_color to a spare GPU_HW_REGS.
For now, wile the 8 bits into some of the RGBs wires to the stencil, maybe 'OR' in a few rast_HV triggers for testing, like only 2 or 4 of them.
My next message will contain the palette module which goes in between the vid_osd_generator module and the vid_out_stencil module.
Post by: BrianHG on December 03, 2019, 10:10:09 pm
Now for the palette memory.  You will have 2 palettes.
Palette #1, specialized for the ASCII text and sprites.
On the Read only port, IE, pixel_in -to- text_pixel out, you will have:
8 bit address input, ie pixel_in[7:0].
On the data output, you will have a 16bit pixel_out[15:0].
The 16 bit output will be wired as follows:
text_pixel_out[15:12] -will be sent to- alpha_blend[3:0]
text_pixel_out[11:8]   -will be sent to- text_r[7:4] -and- text_r[3:0]
text_pixel_out[7:4]     -will be sent to- text_g[7:4] -and- text_g[3:0]
text_pixel_out[3:0]     -will be sent to- text_b[7:4] -and- text_b[3:0]
On the pixel side you will want the 'CLOCK ENABLE' feature for the address latch coming in and data latch going out.
The clock enables will be connected to the (pc_ena[3:0]==0) wire.
On the 'host' memory side, you will have a 9 bit address [9:0] and 8 bit data in and out.
The write ena will need attention as you will need to position this memory withing the system not to conflict with the main graphics memory.
You will need to generate a .mif default palette, otherwise, everything will be black.
Palette #2, specialized for the 256 color background.
Same as the text memory except the data_input will be wired to a 'graphics_data_in' and there will be a 'graphics_data_out' which will be wired like this:
graphics_pixel_out[15:11] -will be sent to- graphics_r[7:3] -and the upper bits to - graphics_r[2:0]
graphics_pixel_out[10:5]   -will be sent to- graphics_g[7:2] -and the upper bits to - graphics_g[1:0]
graphics_pixel_out[4:0]     -will be sent to- graphics_b[7:3] -and the upper bits to - graphics_b[2:0]
Don't forget to page the graphics color palette on a different page on the hose writing side.
For now, just wire the output of the
text_r[3:0] to the modules output  pixel_out_r[7:4] and pixel_out_r[3:0]
text_g[3:0] to the modules output  pixel_out_g[7:4] and pixel_out_g[3:0]
text_b[3:0] to the modules output  pixel_out_b[7:4] and pixel_out_b[3:0]
Yes, 24 bit color output, you will only pass the top 12 used bits to the pins after the stencil module.
Address generator Beta V 1 comes next, so get these working!
Post by: nockieboy on December 04, 2019, 08:06:34 pm
Right, back again - work's been keeping me busy - so, when you say 'place it inside the OSD generator', can you be just a little more specific? ???  Are you telling me to cut 'n' paste the code from bitplane_to_raster.v into vid_osd_generator.v in place of the osd_image assignment and work the new I/Os into the existing ones, or instantiate it (if that's even the right terminology?) in the same way that vid_osd_generator creates the multiport_gpu_ram instance?
Sorry about the basic question(s), but remember; a few weeks ago I knew the square root of nothing about FPGAs and Verilog...  :o
Post by: nockieboy on December 04, 2019, 08:11:06 pm
Will these palette memories be easily accessible by the host system?  I guess I'll just change the z80_bridge module to redirect reads/writes above address 16384 to the palette memory (or sprite memory or whatever else we add in)?
Post by: BrianHG on December 04, 2019, 08:39:18 pm
It's just more 2 port memories.  1 port dedicated to process the 8 bit pixel data into 16 bit pixel data.
The other side should be used to interface with the host.
With Cyclone, the smallest block of ram is 9kbit, or 8kbit, if 1KB. So, to save every tiny drop, even if you allocate a 256x16 bit block of ram, ie 512bytes, it would still count as a 1024bytes.
Now, I said 16 bits on the read output.  If you want to save every drop imaginable, and combine 2 palettes into 1 1024 byte ram block, you may use another of our 5 port ram and just wire the read addresses correctly to get 2x 16bit parallel port reads, ie 4 read ports in use and you still have the host port.
The saving is you get the 2 palettes in a single MK9 block inside the cyclone IV.  The easier way with separate ram blocks is each palette occupies 1x MK9 block.  You may double each the palette size in this configuration and use no additional memory.  The separate memory blocks eat less logic cells and runs a bit faster.  How you decide to mar the write address, either in parallel with a block from the existing 16kb, or somewhere outside as it is ram as well is your decision.
Post by: BrianHG on December 04, 2019, 08:43:10 pm
The 'memory_to_raster.v' module you just created is all on it's own a .v file included in your project.
You are only calling an instance of it inside the vid_osd_generator.  This is important as you will be calling at least 2 of them, and even more when we add sprites.  It may be possible to have 1 instance per sprite depending on architecture, so, you will have something like 10 of them inside the vid_osd_generator.
You've already called instances of our 5 port memory inside the vid_osg_generator, so, I know you know how to do this.
Post by: BrianHG on December 04, 2019, 09:14:34 pm
I'll leave the implementation to you.  However, remember, you may be adding multiple memories at multiple sizes.  Whatever method you choose, make sure you can easily move things around on a whim for no matter how many modules we may add.
Post by: nockieboy on December 05, 2019, 09:38:48 am
Okay, just need a little more guidance getting the bitplane_to_raster module connected up to the vid_osd_generator module.  Full code for vid_osd_generator at the bottom of this post.
Here's what I've got so far for creating an instance of bitplane_to_raster:
// * create a bitplane_to_raster instance
// * NOTE:  For testing, GPU_HW_Control_regs [10] sets bg_colour
// *                                         [11] sets two_byte_mode
// *                                         [12] sets colour_mode_in
bitplane_to_raster b2r_1(
.clk(clk),
.pc_ena_in(pc_ena[3:0]),
// inputs
.ram_byte_in( [7:0]),
.ram_byte_h( [7:0]),
.bg_colour( GPU_HW_Control_regs[10] ),
.x_in( disp_x ),
.colour_mode_in( [1:0] GPU_HW_Control_regs[12] ),
.two_byte_mode( [0] GPU_HW_Control_regs[11] ),
// outputs
.pixel_out_ena( osd_ena_out ),
.mode_16bit( pixel_out_top_16bit ),
.pixel_out( pixel_out_top ),
.pixel_out_h( pixel_out_top_h ),
.x_out( [9:0]),
.colour_mode_out( [1:0])
Firstly, hopefully the connections I've made so far are all correct?  Secondly, some specific questions:
module vid_osd_generator (
// inputs
input clk,
input [3:0] pc_ena,
input hde_in,
input vde_in,
input hs_in,
input vs_in,
input wire host_clk,
input wire host_wr_ena,
input wire [19:0] host_addr,
input wire [7:0] host_wr_data,
input wire [47:0] HV_triggers_in,
// outputs
output reg osd_ena_out,
//output wire osd_image,
output reg pixel_out_top_16bit,   // <--- new
output reg [7:0] pixel_out_top,   // <--- new
output reg [7:0] pixel_out_top_h, // <--- new
output reg hde_out,
output reg vde_out,
output reg hs_out,
output reg vs_out,
output wire [7:0] host_rd_data,
output reg [47:0] HV_triggers_out
// To write contents into the display and font memories, the wr_addr[15:0] selects the address
// the wr_data[7:0] contains a byte which will be written
// the wren_disp is the write enable for the ascii text ram.  Only the wr_addr[8:0] are used as the character display is 32x16.
// the wren_font is the write enable for the font memory.  Only 2 bits are used of the wr_data[1:0] and wr_addr[12:0] are used.
// tie these ports to GND for now disabling them
reg [9:0] disp_x,dly1_disp_x,dly2_disp_x,dly3_disp_x,dly4_disp_x,dly5_disp_x,dly6_disp_x,dly7_disp_x,dly8_disp_x;
reg [8:0] disp_y,dly1_disp_y,dly2_disp_y,dly3_disp_y,dly4_disp_y;
reg dena,dly1_dena,dly2_dena,dly3_dena,dly4_dena,dly5_dena,dly6_dena;
reg [7:0] dly1_letter, dly2_letter, dly3_letter, dly4_letter;
reg [9:0] hde_pipe, vde_pipe, hs_pipe, vs_pipe;
reg [47:0] HV_pipe[9:0];
parameter   PIPE_DELAY =  6; // This parameter selects the number of pixel clocks to delay the VDE and sync outputs.  Only use 2 through 9.
parameter   FONT_8x16  =  0; // 0 = 8 pixel tall font, 1 = 16 pixel tall font.
parameter HW_REGS_SIZE = 8; // default size for hardware register bus - set by HW_REGS parameter in design view
wire [12:0] font_pos;
wire [10:0] disp_pos;
wire [19:0] read_text_adr;
wire [19:0] read_font_adr;
wire [7:0]  letter;
wire [7:0]  char_line;
// * create a multiport GPU RAM handler instance
multiport_gpu_ram gpu_RAM(
.clk(clk),
.addr_in_0(read_text_adr[19:0]),
.addr_in_1(read_font_adr[19:0]),
.addr_in_2(20'b0),
.addr_in_3(20'b0),
.addr_in_4(20'b0),
.cmd_in_0(16'b0),
.cmd_in_1(16'b0),
.cmd_in_2(16'b0),
.cmd_in_3(16'b0),
.cmd_in_4(16'b0),
.pc_ena_out(),
.addr_out_0(),
.addr_out_1(),
.addr_out_2(),
.addr_out_3(),
.addr_out_4(),
.cmd_out_0(),
.cmd_out_1(),
.cmd_out_2(),
.cmd_out_3(),
.cmd_out_4(),
.data_out_0(letter[7:0]),
.data_out_1(char_line[7:0]),
.data_out_2(),
.data_out_3(),
.data_out_4(),
.clk_b(host_clk), // Host (Z80) clock input
.write_ena_b(host_wr_ena), // Host (Z80) clock enable
.addr_host_in(host_addr[19:0]),
   .data_host_in(host_wr_data[7:0]),
.data_host_out(host_rd_data[7:0])
defparam gpu_RAM.ADDR_SIZE = 14, // pass ADDR_SIZE into the gpu_RAM instance
         gpu_RAM.PIXEL_PIPE = 3;    // set the length of the pixel pipe to offset multi-read port sequencing
.clk(clk),
// inputs
.x_in( disp_x ),
// outputs
.x_out( [9:0]),
//  The disp_x is the X coordinate counter.  It runs from 0 to 512 and stops there
//  The disp_y is the Y coordinate counter.  It runs from 0 to 256 and stops there
// Get the character at the current x, y position
assign disp_pos[5:0]  = disp_x[8:3] ;  // The disp_pos[5:0] is the lower address for the 64 characters for the ascii text.
assign disp_pos[10:6] = disp_y[7+FONT_8x16:3+FONT_8x16] ;  // the disp_pos[10:6] is the upper address for the 32 lines of text
//  The result from the ascii memory component 'altsyncram_component_osd_mem'  is called letter[7:0]
//  Since disp_pos[8:0] has entered the read address, it takes 2 pixel clock cycles for the resulting letter[7:0] to come out.
//  Now, font_pos[12:0] is the read address for the memory block containing the character specified in letter[]
assign font_pos[10+FONT_8x16:3+FONT_8x16] = letter[7:0] ;       // Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
assign font_pos[2+FONT_8x16:0] = dly3_disp_y[2+FONT_8x16:0] ;  // select the font x coordinate with a 2 pixel clock DELAYED disp_x address.  [3:1] is used so that every 2 x lines are repeats
//assign osd_image = char_line[(~dly6_disp_x[2:0])];   <--- edited out - replaced by bitplane_to_raster instance
assign read_text_adr[10:0] = disp_pos[10:0];
assign read_text_adr[19:11] = 9'h2;        // my mistake, I has 1bit instead of 10bits
assign read_font_adr[10+FONT_8x16:0] = font_pos[10+FONT_8x16:0];
assign read_font_adr[19:11+FONT_8x16] = 0;        // my mistake, I has 1bit instead of 10bits
// *** Create a serial pipe where the PIPE_DELAY parameter selects the pixel count delay for the xxx_in to the xxx_out ports
hde_pipe[0] <= hde_in;
hde_pipe[9:1] <= hde_pipe[8:0];
hde_out <= hde_pipe[PIPE_DELAY-1];
vde_pipe[0] <= vde_in;
vde_pipe[9:1] <= vde_pipe[8:0];
vde_out <= vde_pipe[PIPE_DELAY-1];
hs_pipe[0] <= hs_in;
hs_pipe[9:1] <= hs_pipe[8:0];
hs_out <= hs_pipe[PIPE_DELAY-1];
vs_pipe[0] <= vs_in;
vs_pipe[9:1] <= vs_pipe[8:0];
vs_out <= vs_pipe[PIPE_DELAY-1];
HV_pipe[0] <= HV_triggers_in;
HV_pipe[9:1] <= HV_pipe[8:0];
HV_triggers_out <= HV_pipe[PIPE_DELAY-1];
// This OSD generator's window is only 512 pixels by 256 lines.
// Since the disp_X&Y counters are the screens X&Y coordinates, I'm using an extra most
// significant bit in the counters to determine if the OSD ena flag should be on or off.
if (disp_x[9] || disp_y[8])
dena <= 0; // When disp_x > 511 or disp_y > 255, then turn off the OSD's output enable flag
else
dena <= 1; // otherwise, turn on the OSD output enable flag
if (~vde_in)
disp_y[8:0] <= 9'b111111111; // preset the disp_y counter to max while the vertical display is disabled
else if (hde_in && ~hde_pipe[0])
begin // isolate a single event at the begining of the active display area
disp_x[9:0] <= 10'b0000000000; // clear the disp_x counter
if (!disp_y[8] | (disp_y[8:7] == 2'b11))
disp_y <= disp_y + 1'b1; // only increment the disp_y counter if it hasn't reached it's end
end
else if (!disp_x[9])
disp_x <= disp_x + 1'b1;  // keep on addind to the disp_x counter until it reaches it's end.
// *** These delay pipes registers are explained in the 'assign's above
dly1_disp_x <= disp_x;
dly2_disp_x <= dly1_disp_x;
dly3_disp_x <= dly2_disp_x;
dly4_disp_x <= dly3_disp_x;
dly5_disp_x <= dly4_disp_x;
dly6_disp_x <= dly5_disp_x;
dly7_disp_x <= dly6_disp_x;
dly8_disp_x <= dly7_disp_x;
dly1_disp_y <= disp_y;
dly2_disp_y <= dly1_disp_y;
dly3_disp_y <= dly2_disp_y;
dly4_disp_y <= dly3_disp_y;
dly1_letter <= letter;
dly2_letter <= dly1_letter;
dly3_letter <= dly2_letter;
dly4_letter <= dly3_letter;
dly1_dena   <= dena;
dly2_dena   <= dly1_dena;
dly3_dena   <= dly2_dena;
dly4_dena   <= dly3_dena;
dly5_dena   <= dly4_dena;
dly6_dena   <= dly5_dena;
osd_ena_out  <= dly4_dena; // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown
// It needs to be delayed by the number of pixel clocks required for the above memories
end // ena
end // always@clk
endmodule
Post by: BrianHG on December 05, 2019, 10:23:17 am
Yes, for now we are not touching the dly_x_out of the new module.
Sticking the module into 1 bit mode, normal 8 bit with an appropriate background color should create visible test on screen if you feed the new image out into the vid_out_stencil.  I would 'or' in 2 or 4 appropriate HV triggers as test margins.
Get rid of the doctored color_sel.  Next you will need to decide on the simple palette ram, or the complex 5 port ram method I listed above.  The simple one may use 1 additional M9K block, but uses a fraction the gates.  You decide where and how to map the memory.  Remember to protect the main system memory if you are going outside the 16k boundary.
Post by: nockieboy on December 05, 2019, 10:57:26 am
Hmm... okay, here's where I am with the internal connections:
.clk(clk),
// inputs
.ram_byte_in(char_line),
.ram_byte_h(8'b00000000),
.x_in( disp_x ),
.colour_mode_in( GPU_HW_Control_regs[12][1:0] ),
.two_byte_mode( GPU_HW_Control_regs[11][0] ),
// outputs
.x_out(), // disconnected for moment
.colour_mode_out() // disconnected for moment
And replace it with...? I'm a little lost as to what we do with the 8-bit (and potentially 16-bit) output from vid_osd_generator now.  The stencil doesn't have an 8-bit wide input - even color_sel doesn't - speaking of which, you want me to get rid of that completely?
Post by: BrianHG on December 05, 2019, 02:29:05 pm
.clk(clk),
// inputs
.x_in( disp_x ),
// outputs
Just tie the upper bits of '.pixel_out( pixel_out_top ),' to R,G,B.
We don't need snow or color settings from the debugger.
Post by: nockieboy on December 05, 2019, 03:19:50 pm
Hokay, well clearly there's a timing issue I need to sort out, though:
[attachimg=2]
Full project files attached so you can view the wiring in the design as well as the code. (Though the project files attached may have pixel_out_top incorrectly wired to the stencil - I've got pixel_out_top[3..0] connected to r_in, g_in and b_in now.)
EDIT: Better image, although it's not aligned to the screen properly (missing a column on the left and some of the top row - that's just the screen misaligned.)
Post by: BrianHG on December 05, 2019, 06:21:17 pm
Shouldn't you be using  'dly6_disp_x'.  Remember, since the first 'disp_x' has been used, there have been 6 pixel clock cycles until the '.ram_byte_in(char_line),' has a valid value.
Your 16 bit text mode doesn't look like the 8 bit text mode.  Copy the 8 bit mode and replace the 'bg_color[]' with the 'ram_byte_h[]'.
How did you move the OSD text across by 5 pixels?  An odd number...
Isn't osd_ena_out being set somewhere else.
Also, I don't see a disable mode in the current 6 modes.  Also in a disable mode, you should also '0' the 2 data outputs.
I haven't a clue about the 5 pixel (ahem 4 pixel delay once you fix an obvious thing).
I turned back on the HV_triggers test lines so you may count the error pixels.
I've attached the first fix only, plus turned back on the 'HV_trigger cursors so you may count the error pixels.
I've also attached the 'Quick-load' for the RS232 debugger which contains the cursor positions.
Post by: BrianHG on December 05, 2019, 06:34:19 pm
What in the world are all those delays for in the 'bitplane_to_raster' module?
Why would you want to add delay anywhere?
You are also missing a 'pixel_in_ena' and it's related function...
Post by: nockieboy on December 05, 2019, 07:30:54 pm
Was fairly sure I was following your advice - the code hasn't changed for the last few times I've posted it up here..  ???
Ah yes it is.  Fixed that.
Is this mode selected by the pixel_ena line you want me to connect to the raster module?
Fixed it - looks like the delays I've erroneously added to the bitplane_to_raster module were causing the problems.
[attach=1]
I added them when I was creating the bitplane_to_raster module - you'd mentioned that signals had to be delayed, so they were the first things I created in that module.  Probably a misunderstanding on my part.  ::)
This pixel_in_ena - as I asked above, does this set the disable mode in the bitplane_to_raster module?
Post by: BrianHG on December 05, 2019, 07:37:56 pm
Your pixels are still off by 1 or 2 according to the image I see.
The original code has 0 delay on the bit selection.  This new code has 1, so long as you remove all the internal delays.  You need the other modules to take that into effect.
Also, the pixel enable input should also mute the output pixels when it low and it should be fed by the original 'osd_ena_out' wire.
You want a disabled mode, and an ability to mute out the non-display area of the OSD text window.  So, both are needed.
You should have the original image, other than the text being blue, exactly if everything is done ok.
Post by: nockieboy on December 05, 2019, 10:40:37 pm
Right, fixed that by changing the x_in input to the bitplane_to_raster instance from dly6_disp_x to dly5_disp_x.  :-+
Done.  :-+
Okay, so what enables the disabled mode, if you'll excuse the oxymoron?
Like this then?
[attachimg=2]
Updated project files attached.
Post by: BrianHG on December 06, 2019, 12:12:59 am
 |O  Arrrrrrggg, how did you do that?  You found a different, yet perfect solution to a weird problem I never thought would end up like this....
Ok...  Fine...  Great...
Next, the 2 palettes.
Now, I'm telling you this so you could construct 2 real palette .mif files...
For the text mode/sprites, the data in the 16 bit output goes like this:
1                                0
6                                0
AAAA RRRR GGGG BBBB
The RGB are 12 bit color data like you are used to.
The A     is a 4 bit translucency value.  0 being 100% opaque, 15 being completely translucent to the graphics mode beneath.
The text colors are as follows:
0 through 15 = The outline color, or, pixel data = 0 color.  Whenever a font has a 0 bit, depending on your character color background selection, one of these 16 colors will be used.
16 through 31 = The pen color, or, pixel data = 1 color.  Whenever a font has a 1 bit, depending on your character color foreground selection, one of these 16 colors will be used.
(When making a default VGA palette, for now, the foreground and background colors may be mirror or offset values.  Whatever mimics VGA's 16 text color settings)
For the graphics palette, colors 0 through 255 are used in order, however, the 16bits hold the color differently:
1                               0
6                               0
RRRRR GGGGGG BBBBB
This is known as 565 color, being 5 bits red, 6 bits green, 5 bits blue.
I would look for an old VGA paint software palette to close as close as possible for the 256 color palette truncated to the 565 standard while for the text, look for the standard 16 colors used by VGA.  Copy those to the text palette in 12bit color, plus, use 0 for the alpha channel except for background color 0.
The palette module should be external between the OSD and Stencil.  It should pass through the HDE,VDE,HS,VS with appropriate internal delay to match the speed of the palette memories.
You will need a host port to read & write to the palette as well.
The palette should have 2 inputs, the text top layer and graphics bottom layer feeding the 2 palettes.  The output for now will just be the text layer palette.  We will do the translucency mixer math after the line address generators as they are needed to feed the graphics bottom layer.
Post by: BrianHG on December 06, 2019, 12:32:19 am
Well, you have 4 current modes, why not 7 modes and reserve a number for 'OFF'.
Post by: nockieboy on December 06, 2019, 09:11:49 am
Right, why didn't I think of that? ???
Okay, I've made colour_mode a 3-bit signal now - the 3rd bit enables/disables the output but can be changed later if more modes are created.
 :-//  Sometimes I almost make it look like I know what I'm doing, but not often...  :-DD
Okay, will get back to you soon on these...  :-/O
Post by: nockieboy on December 06, 2019, 10:50:33 am
I've just spent far too long trying to find a program online that will output a file of 565 hex values for a 256-colour palette.  :palm:
Here's my 32-colour text/sprite palette.  I've just based it off of the old Amstrad palette for the moment, there's obviously lots of room in the .mif for more palettes and the potential to swap palette LUTs on the fly, I'm guessing.
Post by: BrianHG on December 06, 2019, 11:16:56 am
Sprite mode is 4444, 4A, 4R, 4G, 4B.  The 565 is the 256 color mode.  Instead of throwing something together, I would do the conversion in something like MS Excel.
Also, I noticed that 0 is black, ok, but color 1 is dark blue?
ok.
Better, here is a source code generator where you can calculate any output you like.
https://github.com/canidlogic/vgapal (https://github.com/canidlogic/vgapal)
palette=(
000000 0000AA 00AA00 00AAAA AA0000 AA00AA AA5500 AAAAAA 555555 5555FF
55FF55 55FFFF FF5555 FF55FF FFFF55 FFFFFF 000000 101010 202020 353535
454545 555555 656565 757575 8A8A8A 9A9A9A AAAAAA BABABA CACACA DFDFDF
EFEFEF FFFFFF 0000FF 4100FF 8200FF BE00FF FF00FF FF00BE FF0082 FF0041
FF0000 FF4100 FF8200 FFBE00 FFFF00 BEFF00 82FF00 41FF00 00FF00 00FF41
00FF82 00FFBE 00FFFF 00BEFF 0082FF 0041FF 8282FF 9E82FF BE82FF DF82FF
FF82FF FF82DF FF82BE FF829E FF8282 FF9E82 FFBE82 FFDF82 FFFF82 DFFF82
BEFF82 9EFF82 82FF82 82FF9E 82FFBE 82FFDF 82FFFF 82DFFF 82BEFF 829EFF
BABAFF CABAFF DFBAFF EFBAFF FFBAFF FFBAEF FFBADF FFBACA FFBABA FFCABA
FFDFBA FFEFBA FFFFBA EFFFBA DFFFBA CAFFBA BAFFBA BAFFCA BAFFDF BAFFEF
BAFFFF BAEFFF BADFFF BACAFF 000071 1C0071 390071 550071 710071 710055
710039 71001C 710000 711C00 713900 715500 717100 557100 397100 1C7100
007100 00711C 007139 007155 007171 005571 003971 001C71 393971 453971
553971 613971 713971 713961 713955 713945 713939 714539 715539 716139
717139 617139 557139 457139 397139 397145 397155 397161 397171 396171
395571 394571 515171 595171 615171 695171 715171 715169 715161 715159
715151 715951 716151 716951 717151 697151 617151 597151 517151 517159
517161 517169 517171 516971 516171 515971 000041 100041 200041 310041
410041 410031 410020 410010 410000 411000 412000 413100 414100 314100
204100 104100 004100 004110 004120 004131 004141 003141 002041 001041
202041 282041 312041 392041 412041 412039 412031 412028 412020 412820
413120 413920 414120 394120 314120 284120 204120 204128 204131 204139
204141 203941 203141 202841 2D2D41 312D41 352D41 3D2D41 412D41 412D3D
412D35 412D31 412D2D 41312D 41352D 413D2D 41412D 3D412D 35412D 31412D
2D412D 2D4131 2D4135 2D413D 2D4141 2D3D41 2D3541 2D3141 000000 000000
000000 000000 000000 000000 000000 000000
[attachimg=1]
Now, I'm sure you can output this into 565 and 4444.  Remember, the 4444 is for the text and sprites while the 565 is for the graphics layer.
For the text layer palette, we want to copy the first 16 into the second 16 colors, unless we change a wire in the 'bitplane_to_raster' module.
Post by: nockieboy on December 06, 2019, 11:52:41 am
Like I said, I'd based the palette off of the old Amstrad 27-colour palette.  Just realised, might have confused you with the naming of the palette .mif file.  It's the text/sprite palette, but I just called it 'sprite' palette for brevity (I guess the text could be considered sprites in their own way).
So, just to clarify, the text palette is just 32 colours (two copies of 16, essentially)?  Is the sprite palette the same thing, or a separate palette after the text palette?
I did find that code during my searching, but disregarded it as I felt it needed a few hours development to turn into what I needed.  ???
Post by: BrianHG on December 06, 2019, 12:12:08 pm
Again:
palette=(
How hard is it to separate the RGB 8 bit values, divide by 16 on this source data, then multiply by 1,16,256 and add the sum?
Or in the case of the graphics palette,divide by 8 for red and blue, divide by 4 for green, then multiply by 1,32,2048 and add the sum?
Bit shifting would also work...
Post by: nockieboy on December 06, 2019, 01:58:17 pm
Does this look right for RGB565?
0000 0015 0540 0555 A800 A815 AAA0 AD55 52AA 52BF 57EA 57FF FAAA FABF FFEA FFFF
0000 1082 2104 31A6 4228 52AA 632C 73AE 8C51 9CD3 AD55 BDD7 CE59 DEFB EF7D FFFF
001F 401F 801F B81F F81F F817 F810 F808 F800 FA00 FC00 FDE0 FFE0 BFE0 87E0 47E0
07E0 07E8 07F0 07F7 07FF 05FF 041F 021F 841F 9C1F BC1F DC1F FC1F FC1B FC17 FC13
FC10 FCF0 FDF0 FEF0 FFF0 DFF0 BFF0 9FF0 87F0 87F3 87F7 87FB 87FF 86FF 85FF 84FF
BDDF CDDF DDDF EDDF FDDF FDDD FDDB FDD9 FDD7 FE57 FEF7 FF77 FFF7 EFF7 DFF7 CFF7
BFF7 BFF9 BFFB BFFD BFFF BF7F BEFF BE5F 000E 180E 380E 500E 700E 700A 7007 7003
7000 70E0 71C0 72A0 7380 5380 3B80 1B80 0380 0383 0387 038A 038E 02AE 01CE 00EE
39CE 41CE 51CE 61CE 71CE 71CC 71CA 71C8 71C7 7227 72A7 7307 7387 6387 5387 4387
3B87 3B88 3B8A 3B8C 3B8E 3B0E 3AAE 3A2E 528E 5A8E 628E 6A8E 728E 728D 728C 728B
728A 72CA 730A 734A 738A 6B8A 638A 5B8A 538A 538B 538C 538D 538E 534E 530E 52CE
0008 1008 2008 3008 4008 4006 4004 4002 4000 4080 4100 4180 4200 3200 2200 1200
0200 0202 0204 0206 0208 0188 0108 0088 2108 2908 3108 3908 4108 4107 4106 4105
4104 4144 4184 41C4 4204 3A04 3204 2A04 2204 2205 2206 2207 2208 21C8 2188 2148
2968 3168 3168 3968 4168 4167 4166 4166 4165 4185 41A5 41E5 4205 3A05 3205 3205
2A05 2A06 2A06 2A07 2A08 29E8 29A8 2988 0000 0000 0000 0000 0000 0000 0000 0000
Post by: BrianHG on December 06, 2019, 02:55:22 pm
If I've done my math right, the first 5 should read:
0000 0015 0560 0575 A800
Remember the green is /4, not divide by /8 since the green retains 6 of 8 bits, not 5 of 8 bits like the red and blue.
Post by: nockieboy on December 06, 2019, 04:09:01 pm
Probably because I'm just dropping the least-significant bits - this is my code to reduce from 3 bytes to 2 (C#):
rgb_out[1] = (rgb[0] & 0xF8) | (rgb[1] >> 5);
rgb_out[0] = ((rgb[1] & 0x1C) << 3) | (rgb[2] >> 3);
rgb[0] is red, [1] is green, [2] is blue.  rgb_out is an array, rgb_out[1] is MSB, rgb_out[0] is LSB.  They are output like this:
String.Format("{0:X2}", rgb_out[1]) + String.Format("{0:X2}", rgb_out[0]) + " ";
Post by: BrianHG on December 06, 2019, 06:23:57 pm
:palm: Yup, your color codes are correct...
Just do the 4444 as well.  That one is hard to mess up...
Post by: nockieboy on December 06, 2019, 06:28:39 pm
 ;) Okay, this is the output for RGB4444:
-- PALConverter-generated Memory Initialisation File (.mif)
-- For use with Quartus II & Quartus Prime.
-- Generated at: 06/12/2019 18:28:05
WIDTH=16;
DEPTH=256;
ADDRESS_RADIX=HEX;
DATA_RADIX=HEX;
CONTENT BEGIN
    000  :   0000;
    001  :   000A;
    002  :   00A0;
    003  :   00AA;
    004  :   0A00;
    005  :   0A0A;
    006  :   0A50;
    007  :   0AAA;
    008  :   0555;
    009  :   055F;
    00A  :   05F5;
    00B  :   05FF;
    00C  :   0F55;
    00D  :   0F5F;
    00E  :   0FF5;
    00F  :   0FFF;
    010  :   0000;
    011  :   0111;
    012  :   0222;
    013  :   0333;
    014  :   0444;
    015  :   0555;
    016  :   0666;
    017  :   0777;
    018  :   0888;
    019  :   0999;
    01A  :   0AAA;
    01B  :   0BBB;
    01C  :   0CCC;
    01D  :   0DDD;
    01E  :   0EEE;
    01F  :   0FFF;
    020  :   000F;
    021  :   040F;
    022  :   080F;
    023  :   0B0F;
    024  :   0F0F;
    025  :   0F0B;
    026  :   0F08;
    027  :   0F04;
    028  :   0F00;
    029  :   0F40;
    02A  :   0F80;
    02B  :   0FB0;
    02C  :   0FF0;
    02D  :   0BF0;
    02E  :   08F0;
    02F  :   04F0;
    030  :   00F0;
    031  :   00F4;
    032  :   00F8;
    033  :   00FB;
    034  :   00FF;
    035  :   00BF;
    036  :   008F;
    037  :   004F;
    038  :   088F;
    039  :   098F;
    03A  :   0B8F;
    03B  :   0D8F;
    03C  :   0F8F;
    03D  :   0F8D;
    03E  :   0F8B;
    03F  :   0F89;
    040  :   0F88;
    041  :   0F98;
    042  :   0FB8;
    043  :   0FD8;
    044  :   0FF8;
    045  :   0DF8;
    046  :   0BF8;
    047  :   09F8;
    048  :   08F8;
    049  :   08F9;
    04A  :   08FB;
    04B  :   08FD;
    04C  :   08FF;
    04D  :   08DF;
    04E  :   08BF;
    04F  :   089F;
    050  :   0BBF;
    051  :   0CBF;
    052  :   0DBF;
    053  :   0EBF;
    054  :   0FBF;
    055  :   0FBE;
    056  :   0FBD;
    057  :   0FBC;
    058  :   0FBB;
    059  :   0FCB;
    05A  :   0FDB;
    05B  :   0FEB;
    05C  :   0FFB;
    05D  :   0EFB;
    05E  :   0DFB;
    05F  :   0CFB;
    060  :   0BFB;
    061  :   0BFC;
    062  :   0BFD;
    063  :   0BFE;
    064  :   0BFF;
    065  :   0BEF;
    066  :   0BDF;
    067  :   0BCF;
    068  :   0007;
    069  :   0107;
    06A  :   0307;
    06B  :   0507;
    06C  :   0707;
    06D  :   0705;
    06E  :   0703;
    06F  :   0701;
    070  :   0700;
    071  :   0710;
    072  :   0730;
    073  :   0750;
    074  :   0770;
    075  :   0570;
    076  :   0370;
    077  :   0170;
    078  :   0070;
    079  :   0071;
    07A  :   0073;
    07B  :   0075;
    07C  :   0077;
    07D  :   0057;
    07E  :   0037;
    07F  :   0017;
    080  :   0337;
    081  :   0437;
    082  :   0537;
    083  :   0637;
    084  :   0737;
    085  :   0736;
    086  :   0735;
    087  :   0734;
    088  :   0733;
    089  :   0743;
    08A  :   0753;
    08B  :   0763;
    08C  :   0773;
    08D  :   0673;
    08E  :   0573;
    08F  :   0473;
    090  :   0373;
    091  :   0374;
    092  :   0375;
    093  :   0376;
    094  :   0377;
    095  :   0367;
    096  :   0357;
    097  :   0347;
    098  :   0557;
    099  :   0557;
    09A  :   0657;
    09B  :   0657;
    09C  :   0757;
    09D  :   0756;
    09E  :   0756;
    09F  :   0755;
    0A0  :   0755;
    0A1  :   0755;
    0A2  :   0765;
    0A3  :   0765;
    0A4  :   0775;
    0A5  :   0675;
    0A6  :   0675;
    0A7  :   0575;
    0A8  :   0575;
    0A9  :   0575;
    0AA  :   0576;
    0AB  :   0576;
    0AC  :   0577;
    0AD  :   0567;
    0AE  :   0567;
    0AF  :   0557;
    0B0  :   0004;
    0B1  :   0104;
    0B2  :   0204;
    0B3  :   0304;
    0B4  :   0404;
    0B5  :   0403;
    0B6  :   0402;
    0B7  :   0401;
    0B8  :   0400;
    0B9  :   0410;
    0BA  :   0420;
    0BB  :   0430;
    0BC  :   0440;
    0BD  :   0340;
    0BE  :   0240;
    0BF  :   0140;
    0C0  :   0040;
    0C1  :   0041;
    0C2  :   0042;
    0C3  :   0043;
    0C4  :   0044;
    0C5  :   0034;
    0C6  :   0024;
    0C7  :   0014;
    0C8  :   0224;
    0C9  :   0224;
    0CA  :   0324;
    0CB  :   0324;
    0CC  :   0424;
    0CD  :   0423;
    0CE  :   0423;
    0CF  :   0422;
    0D0  :   0422;
    0D1  :   0422;
    0D2  :   0432;
    0D3  :   0432;
    0D4  :   0442;
    0D5  :   0342;
    0D6  :   0342;
    0D7  :   0242;
    0D8  :   0242;
    0D9  :   0242;
    0DA  :   0243;
    0DB  :   0243;
    0DC  :   0244;
    0DD  :   0234;
    0DE  :   0234;
    0DF  :   0224;
    0E0  :   0224;
    0E1  :   0324;
    0E2  :   0324;
    0E3  :   0324;
    0E4  :   0424;
    0E5  :   0423;
    0E6  :   0423;
    0E7  :   0423;
    0E8  :   0422;
    0E9  :   0432;
    0EA  :   0432;
    0EB  :   0432;
    0EC  :   0442;
    0ED  :   0342;
    0EE  :   0342;
    0EF  :   0342;
    0F0  :   0242;
    0F1  :   0243;
    0F2  :   0243;
    0F3  :   0243;
    0F4  :   0244;
    0F5  :   0234;
    0F6  :   0234;
    0F7  :   0234;
    0F8  :   0000;
    0F9  :   0000;
    0FA  :   0000;
    0FB  :   0000;
    0FC  :   0000;
    0FD  :   0000;
    0FE  :   0000;
    0FF  :   0000;
END;
My program now outputs Quartus-compatible .MIF files.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on December 06, 2019, 06:39:51 pm
Perfect.  Just for address 0, make the word = F000.
Wire in a memory module called 'palette_mixer.sv'.
For now, wire the 4444 palette address to the pixel_out_top wire & pass through the hde,vde,hs,vs.
Make sure you now use the clk enable on the ram unless you are using my 5 port ram.
Post by: nockieboy on December 06, 2019, 08:02:36 pm
For anyone following along, the software I wrote to convert these palette values is PALConverter, on github here (https://github.com/nockieboy/PALConverter) and the .exe is available below.
Post by: BrianHG on December 06, 2019, 08:08:54 pm
Makes me wonder if we should have wasted the ram and just done a 24bit RGB and 32bit ARGB palette.
@nockieboy, you know it's your GPU, you could have said so at any time.
Post by: nockieboy on December 06, 2019, 08:13:08 pm
Would need to work out how much RAM we'd need for 24bit RGB mode at 640x480.  Wouldn't be a massive increase (33%) I suppose.  I think a graphics mode would be out of the question with internal RAM, though.  Would have to look at using an external SRAM for that?
Something I've been wondering - how easy is it to change the text display mode from the current 64x32 to 80x40, or some other arbitrary value?  I haven't looked yet, but I'd like to add parameters to the design to make that an easy option to set.
Post by: BrianHG on December 06, 2019, 09:26:22 pm
Your S-Ram would need to read 175 megabytes a second + CPU access + what about the 125 megabytes a second for the display.  we are at 325 megabytes a second, random row & column access, not counting an accelerated drawing engine.
3ns Fully static ram anyone?  Not only 3ns, but ZBT ram. (Zero Bus Turnaround)  Allows a write, then a read, then a write on adjacent cycles.
#2.  Address generator.  That's what it is for.  You will have to basically erase the OSD generator.
Post by: jhpadjustable on December 06, 2019, 10:53:28 pm
That would be kind of expensive, as BrianHG pointed out. But... how about some variation on Amiga HAM (hold-and-modify) mode? :)
Post by: nockieboy on December 06, 2019, 11:02:48 pm
Okay, further to the above with some "back of an envelope" maths:
640x480 text mode = 80x30 = 2,400 tiles.  So 2.4 KB required for the text mode screen space.
256 colour palette x 3 bytes (RGB888 'true colour' gamut) =  768 B for the palette, OR
2,400 tiles x 4 bytes (RGB888 + character value) = 9.6 KB for a true colour text mode.
For graphics, the story isn't so optimistic:
For true colour graphics, you're looking at 640x480x3 = 921.6 KB.  Couldn't even manage RGB565 graphics at 320x240 on an FPGA with less than 160 KB RAM.
You know, looking at engineering problems like this and some of the amazingly tight timings involved really gives me an appreciation of GPU card manufacturers.  Can't be easy making a GPU that can pump enough pixels to support a 4K display at 100Hz.  Yet they use external memory chips too (is it still GDDR?) - can't imagine the technical issues they must face designing those things.  :scared:
Ah - great. :D  I'll shut up and press on, then!  :-+
Now, forgive me if I'm completely wrong, jhpadjustable, it's been a few years since I've used my Amigas... but HAM mode - didn't that work by using two bytes for the colour, but reserved the top two bits to create a 4-value command that modified the remaining colour bits for the next pixel, or from the previous pixel (or something)?
That seems like it would require some serious horsepower from the Z80 CPU to get that to work - but that's coming from me with little understanding of how it works in the first place.
Post by: BrianHG on December 06, 2019, 11:24:00 pm
He has a true 16bit capability.  Right now, 565 with dithering will outdo the Amiga.  Though, If I were to implement 422 8 bit grey, 1 pixel U, 1 pixel V, he would have 24 bit color, DVD Grade, but without MPEG2 compression artifacts.  I'm waiting for him to place the palettes, and then the 'nightmare' of getting nockieboy to visualize the address generators, especially 2x2dimensions running with variable increment rates (address 16/32 bit memory steps), and increment sizes (periods), on X&Y axis with a secondary pointed address begin fed through the memory auxiliary port I had designed early in to point to the tiles/fonts, all of this reset, incremented, and enabled/disabled by 5 HV_Trigger inputs which will allow a variable sized floating text/graphics window on the screen.
My design is now running the ram at 5x, meaning, 125Mhz, 5 read ports per pixel.  When going to the Lattice FPGA, or even this CycloneIV, we can use the 250MHz ram with 10 read ports per pixel, meaning 1 ram for everything, including palettes.  And the 14$ Lattice FPGA has 2 Megabits which can run at 400MHz.
I haven't tried, but I wonder if the current CYClone IV memory core can be pushed to 270MHz...  The data sheet says the -c8 can do 235MHz & C7 can handle 274MHz.  We would probably need to extend the 'MUX' tree to a 2 layer pipe since 10:1 on the addressees would probably be too slow for 250MHz-270MHz.
Post by: BrianHG on December 06, 2019, 11:33:07 pm
The address generator shows what memory will be displayed inside the hardware window.
The HV_Triggers control the size and position of the window.
There are 2 hardware windows.  Each with font or true graphics capability.  The top window has 4096 color palette with 16 transparency levels to the second window beneath which uses 565 style 65536 colors.
The sprites share the top window, so you have access to the variable translucent colors on each sprite pixel.
Each sprite size and position will also be set by 4 HV_trigger markers.
We may scrap the 565 color for the bottom window and also use 4096 colors plus an alpha channel, however, what should we do with those 4 programmable bits?
Post by: nockieboy on December 06, 2019, 11:40:04 pm
 :o
Again I'm worrying that the hardest parts are yet to come and I won't get this done in time.  :-\
I'm making a start on the palette module now (though it's late here and I'm going offline in a sec) - just want to clarify something though;  you mentioned previously to create a 'palette_mixer.sv' file (after the creation of the 4444 palette) - will this module handle both palettes, or will I be creating (and tweaking) a copy of this module for the 565 palette?
Post by: BrianHG on December 06, 2019, 11:44:14 pm
In all honesty, if you insisted on DDR memory, we would have scrapped any low color modes, and make a 2D drawing/rendering engine to emulate a text and palette low res color video modes.  We would be just beyond a frame buffer at this point and the architecture would be complex enough that we would need block diagrams and system commands/functions with an instruction FIFO port and we would need to weave around both the DDR ram and system memory blocks as when emulating the palette, we would still want that instant access as we render pixels again and again every vsync every-time you modify a single palette number.
Post by: BrianHG on December 06, 2019, 11:49:22 pm
 :o
Other than sprites, as they are a piggy back measure, unless you only want 4 of them, the address generator will complete this project to V1.0.  You will need to concentrate and document everything as those 15 settings will create any display possible from your memory's contents.
Fiddle with setting here, and your text or graphics will move on the screen, change in scale and size, even bend/tear horizontally.
Playing with the palette will change color/brightness or everything.
You will need to get the Z80 doing things after this.
Post by: BrianHG on December 07, 2019, 01:47:38 am
Both palettes will be in 1 .sv module running in parallel, though, their Host address should have a different address point.
Post by: BrianHG on December 07, 2019, 11:32:32 am
@nockieboy, I hate to do this to you, but once you get the initial palette working, you will need to make a change to the 'multiport_gpu_ram.v' and 'gpu_dual_port_ram_INTEL.v'.  Now, I want to get this change right in 1 shot, so, we will need to go over it after the text palette is fully 100% functional without a single pixel in error.
On the read only port side, we will change the 8 bit data port to 16 bits.  This will double our read speed, however, we still want 8 bit address capability.  To do this, in the 'gpu_dual_port_ram_INTEL.v' altsyncram settings, you will make read port 16 bits, effectively lowering the address size by 1 bit.  However, the module 'gpu_dual_port_ram_INTEL.v' will still take the same read address size, and pass it through.  Into the altsyncram, you will feed the upper address beginning at 1 instead of 0.  For the 16 bit data coming out, you will swap the upper and lower 8 bits of that data depending if the read address[0] is high or low.
Effectively, if the proceeding modules use just the bottom 8 bits of ram data, like the 'bitplane_to_rasterbitplane_to_raster.v' we should be backwards compatible.  However, using the upper 8 bits as a font color for example, within 1 read we get 1 byte ascii text, 1 byte color.  When reading a font, we may now also have a few new pixel modes where we have a 16 pixel wide font, or, 4 color per pixel font on top of the base 16 foreground and 16 background offset colors.
The 'multiport_gpu_ram' will also now need to change the 5 read data_out_# ports to a 16bit word.
Next, change the 5 cmd_(in/out)_# ports in the 'multiport_gpu_ram.v' module from 16 bit to 32 bit.  Don't forget the single cmd_(in/out) pass through in the 'gpu_dual_port_ram_INTEL.v' will need to change to 16 bit as well.
As for the 'bitplane_to_rasterbitplane_to_raster.v', take in a 16 bit word for the '.ram_byte_in()', but, leave everything else the same.  For now, ignore the upper 8 bits.  I will specify the minor alterations once everything else is working.
Post by: nockieboy on December 07, 2019, 05:49:53 pm
@nockieboy, I hate to do this to you...
No worries - I just need to focus on one thing at a time, otherwise details get lost in the confusion.  :-+
Hoping to get some palette module work done if I can string together a few hours tonight or tomorrow.  :-\
Post by: nockieboy on December 07, 2019, 06:19:21 pm
Okay, some intermediate guidance required...  ???
I'm struggling to follow this.  Dual-port RAM, but one port is read only?  That port has an 8-bit address input and one 16-bit output?
text_pixel_out[15:12] -will be sent to- text_a[3:0]
text_pixel_out[15:12] -will be sent to- text_r[7:4] -and- text_r[3:0]
text_pixel_out[15:12] -will be sent to- text_g[7:4] -and- text_g[3:0]
text_pixel_out[15:12] -will be sent to- text_b[7:4] -and- text_b[3:0]
This refers to the 16-bit output mentioned above?
Do I need clkb?
Is this the read only side?  Are the clock enables the .clockenx entries in the altsyncram component declaration?  Also, and perhaps most importantly, can I create these palette memories by just copying and editing the code for the GPU RAM?  Or do they have to be created using the wizard?
Okay, below are two files - palette_mixer.sv and dual_port_palette_ram_text.v.  Neither are finished, I'm just putting them up here for feedback and guidance whilst I work on them and to check I'm going in the right direction.
Post by: jhpadjustable on December 07, 2019, 07:44:08 pm
Close. The top two bits (of six) held a command and the bottom four held a parameter. At each pixel you could load all three primaries from a palette entry, or modify one primary directly while holding the other two. HAM was really best suited to displaying pre-drawn static bitmap images, like a background playfield, and (with care) could be used for compositing in special cases, as long as you remember to always put a fixed palette load at each leftmost pixel.
As BrianHG observed, maybe it's not all that useful anymore, in favor of visually superior and simpler luminance:chrominance encodings like YCbCr. Never mind  :)
Post by: BrianHG on December 07, 2019, 08:56:46 pm
When usure about your altsyncram function, use the block diagram megafunction wizard to generate a reference .v file for you. You will see a picture of the memory module as you create it.
Then copy-paste the numbers and names generated in the example .v file.
Use Quartus 9.1 for this on a blank new block diagram on a blank new dummy project.
It should look like this:
[attachimg=1]
making this code:
module palette256 (
address_a,
address_b,
clock_a,
clock_b,
data_a,
data_b,
enable_a,
enable_b,
wren_a,
wren_b,
q_a,
q_b);
input [7:0]  address_a;
input [8:0]  address_b;
input   clock_a;
input   clock_b;
input [15:0]  data_a;
input [7:0]  data_b;
input   enable_a;
input   enable_b;
input   wren_a;
input   wren_b;
output [15:0]  q_a;
output [7:0]  q_b;
wire [15:0] sub_wire0;
wire [7:0] sub_wire1;
wire [15:0] q_a = sub_wire0[15:0];
wire [7:0] q_b = sub_wire1[7:0];
altsyncram altsyncram_component (
.clocken0 (enable_a),
.clocken1 (enable_b),
.wren_a (wren_a),
.clock0 (clock_a),
.wren_b (wren_b),
.clock1 (clock_b),
.address_a (address_a),
.address_b (address_b),
.data_a (data_a),
.data_b (data_b),
.q_a (sub_wire0),
.q_b (sub_wire1),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.address_reg_b = "CLOCK1",
altsyncram_component.clock_enable_input_a = "NORMAL",
altsyncram_component.clock_enable_input_b = "NORMAL",
altsyncram_component.clock_enable_output_a = "NORMAL",
altsyncram_component.clock_enable_output_b = "NORMAL",
altsyncram_component.indata_reg_b = "CLOCK1",
altsyncram_component.init_file = "palette.mif",
altsyncram_component.init_file_layout = "PORT_A",
altsyncram_component.intended_device_family = "Cyclone III",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 256,
altsyncram_component.numwords_b = 512,
altsyncram_component.operation_mode = "BIDIR_DUAL_PORT",
altsyncram_component.outdata_aclr_a = "NONE",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_a = "CLOCK0",
altsyncram_component.outdata_reg_b = "CLOCK1",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_port_a = "OLD_DATA",
altsyncram_component.read_during_write_mode_port_b = "OLD_DATA",
altsyncram_component.widthad_a = 8,
altsyncram_component.widthad_b = 9,
altsyncram_component.width_a = 16,
altsyncram_component.width_b = 8,
altsyncram_component.width_byteena_a = 1,
altsyncram_component.width_byteena_b = 1,
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK1";
endmodule
Remember, for the A port, we may use the clock enable if you want the palette to look like a 2 pixel pipe delay.
Also, please do not hard-wire the write-enable on that port to a 1 this time around.
Another thing, make sure you have a page address parameter which protects the writing on the host port.
Post by: nockieboy on December 07, 2019, 11:41:10 pm
Okay, not had much time to work on this tonight, but this is where I am so far.  Would appreciate some tips (like for the wr_ena and page address parameter etc) and corrections where there's bound to be errors.  ;)
Post by: BrianHG on December 07, 2019, 11:53:58 pm
No piping or reging needed on this memory.  Just feed the address in and data out.  Optionally use the clock enable, however, you may accelerate things to 1 pixel by re-latchting the data out of the ram on the pc_ena[3:0]==0 since the memory takes less than 4 clock to return a valid result.
This means just wiring the ram's .clocken# to 1.  Also, the data output would be reged once for now as also will be the HDE,VDE,HS,VS.  I force you to have the .clocken# so you may wire them in the future if needed.
There is no command pipe in or out here anymore, it is straight memory to a final pixel.  Reg that pixel at the output of the palette module with the HDE,VDE,HS,VS.
Once done, you should be able to produce VGA colored text with the current bg_color reg with 1 modification, change this line in the 'bitplane_to_raster.sv'.:
change this line 87 to this:
                  pixel_out[4]   <= 1'b0;   // 1'b1;
Post by: nockieboy on December 08, 2019, 12:45:21 pm
Okay, feel like I've lost my way a little and need some more steerage to get back on course.
Am I piping HDE, VDE, HS and VS through the dual_port_palette_ram_text module, or just through the palette_mixer module?  I guess I'd need to delay them by 1 clock if I don't pipe them through the ram module as well?
What exactly is required of the palette_mixer module?  I've included both files below, but am somewhat lost with what else needs to be added to palette_mixer (other than the pass-thru sync signals above)....?  :-//
Post by: BrianHG on December 08, 2019, 01:15:24 pm
The palette mixer module just carries the 2 ram palettes, 1 with the 4444 text palette and the 565 graphics palette.
You do realize the next iteration of the vid_osd_generator will output 2 pictures at the same time, right?
The mixer module will mix/superimpose 1 picture on top of the other, right?
You know, like an over head projector with 2 transparent stencils, 1 with a text engine output using a 4444 palette and another beneath showing conventional pixel graphics using a second palette holding the 565 colors.
We need 2 palettes working in parallel.  The palettes also have a read delay which we need to line up to the pixel clock.  The HS,VS,HDE,VDE also needs to match that delay.  You also need to take into consideration the fact that a new pixel will happen every 5 (or other number) clock cycles set by the pc_ena[3:0]==0.
You also want the palette mixer module to be standard verilog calling the 'memory' modules which are exclusive to Intel Quartus altsyncram function which would be swapped out in a different FPGA vendor's dual port memory scheme.  I guess you should rename the the 'dual_port_palette_ram_text.v' to 'dual_port_palette_ram_INTEL.v'.  Remember, the text and graphics palette ram are identical, so 1 ram module would be used twice.  It's just the way the 16 output bits are wired to the RGB on each ram module inside the 'palette_mixer.v' module.  And each ram just has a different .mif file.  So, I am sure you know how to pass parameters and call 2 different instances of 1 memory module, with different memory address and different wiring to the inputs and outputs.
The output of the 2 palettes will just go through 2xRGB multiplies each, then the sum added together at then end.  The 'Alpha' output on the text palette controls the multiplication factor of each palette's RGB output, mixing the 2 opposite proportions of each image together.
Post by: nockieboy on December 08, 2019, 01:59:44 pm
Quick question:  Can I specify a RAM parameter in the instantiating code?
// create a text/sprite palette RAM instance
dual_port_palette_ram_INTEL text_palette_RAM(
// inputs
.clock_a(clk),
.clock_b(clk),
.pc_ena_in(pc_ena_in),
.pixel_in(pixel_in),
.address_b(4'h0000),
.data_a(2'h00),
.data_b(2'h00),
.enable_a(pc_enable),
.enable_b(pc_enable),
.wren_a(1'b0),
.wren_b(1'b0),
// outputs
.pc_ena_out(pc_ena_out),
.pixel_out(pixel_out),
.data_out_b(data_out_b),
// registered outputs
.addr_out_a()
defparam text_palette_RAM.init_file = "palette_4444.mif";
Post by: BrianHG on December 08, 2019, 02:04:13 pm
Yes, just look at our existing examples in the multiport ram and intel ram where we specify memory size.
Post by: nockieboy on December 08, 2019, 04:21:37 pm
Got that in palette_mixer.v right now - both palettes are instantiated as text_palette_RAM and graphics_palette_RAM.
Ah okay, that makes a little more sense.  So it should have two 'image' inputs from the vid_osd_generator to look up the relevant palette entry for each one and mix them together into one 16-bit output?
Okay, I've got HS, VS, HDE and VDE passed through the palette_mixer module, with a user-definable delay.  It defaults to 6, but I'm sure you mentioned a delay of 1 or 2 earlier..? Might have imagined that, though.  :-//
Done.
Yes, that's all done.  I'll include dual_port_palette_ram_INTEL.v at the bottom for checking, but that's pretty much done with now.  It's instantiated twice in palette_mixer.v, specifying a different .mif file for each one.  My focus is now on palette_mixer.v and getting it set up properly.
Can you give me an example please?  Are we splitting the 16-bit data from the dual_port_palette_ram into its RGB components and performing these multiplies, as the two palettes are in different RGB formats?
palette_mixer.v
module palette_mixer (
// inputs
input clk,
input vs_in,
input hs_in,
input hde_in,
input vde_in,
input [3:0] pc_ena_in,
input [7:0] txt_pixel_in,
input [7:0] gfx_pixel_in,
// outputs
output reg [15:0] pixel_out,
output reg [3:0]  pc_ena_out,
output reg [7:0]  data_out_b,
output reg vs_out,
output reg hs_out,
output reg hde_out,
output reg vde_out
wire pc_enable = (pc_ena[3:0]==0);
wire txt_pixel_out;
wire gfx_pixel_out;
reg [9:0] hde_pipe, vde_pipe, hs_pipe, vs_pipe; // passthru delay pipes
// * create a text/sprite palette RAM instance (4444)
// inputs
.clock_a(clk),
.clock_b(clk),
.pixel_in(txt_pixel_in),
.data_a(2'h00),
.data_b(2'h00),
.wren_a(1'b0),
.wren_b(1'b0),
// outputs
.pixel_out(txt_pixel_out),
.addr_out_a()
// * create a graphics palette RAM instance (565)
dual_port_palette_ram_INTEL graphics_palette_RAM(
// inputs
.clock_a(clk),
.clock_b(clk),
.pixel_in(gfx_pixel_in),
.data_a(2'h00),
.data_b(2'h00),
.wren_a(1'b0),
.wren_b(1'b0),
// outputs
.pixel_out(gfx_pixel_out),
.addr_out_a()
defparam graphics_palette_RAM.init_file = "palette_565.mif";
always @(posedge clk) begin
if (pc_ena[3:0] == 0) begin
pixel_out <= txt_pixel_out & gfx_pixel_out; // *** placeholder *** for palette mixing function
end
end
endmodule
module dual_port_palette_ram_text (
// inputs
input clock_a,
input clock_b,
input [7:0]  pixel_addr_in, // address_a
input [8:0]  address_b,
input [15:0] data_a,
input [7:0]  data_b,
input enable_a,
input enable_b,
input wren_a,
input wren_b,
// outputs
output [3:0]  pc_ena_out,
output reg [15:0] pixel_out, // data_out_a
output reg [19:0] addr_out_a
// Dual-port palette RAM
.clocken0 (1'b1),
.wren_a (wren_a),
.clock0 (clock_a),
.wren_b (wren_b),
.clock1 (clock_b),
.address_a (pixel_addr_in),
.data_a (data_a),
.data_b (data_b),
.q_a (pixel_out),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (1'b0),
.rden_a (1'b1),
.rden_b (1'b1)
defparam
altsyncram_component.intended_device_family = "Cyclone IV",
endmodule
Post by: BrianHG on December 08, 2019, 04:51:59 pm
Yes.
I will let you figure out what the delay should be.
First, make from the palette outputs wires
text_r[7:0],text_g[7:0],text_b[7:0], graphics_r[7:0], graphics_g[7:0], graphics_b[7:0], alpha_blend[3:0].
Wire them to the palette out bits like here: https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2813672/#msg2813672 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2813672/#msg2813672)
Output regs:
pixel_out_r[7:0], pixel_out_g[7:0], pixel_out_b[7:0]
This is a 1 clock step version (which will probably be too slow for a CycloneIV):
pixel_out_r <=  ( (text_r[7:0] * ~alpha_blend[3:0]) + (graphics_r[7:0] * alpha_blend[3:0]) ) >> 4 ;
Now, you should be able to guess the _g, and _b.
Since you asked, I just wanted the text palette out for now, but let's do the full formula.
     If your F-Max drops below 140Mhz, you will need to separate the 2 multiplies into 2 separate regs shifted down to 8 bits each, then the final pixel_out_r/g/b will need to be the sum of those 2 inbetween 8 bit regs making everything take 2 clocks to compute a pixel instead of 1 clock.  With the 2 stages, you will have 0 trouble ever achieving the FMAX.
YES, the output of the palette mixer is 24 bit color.  Just feed the top 12 bits into the vid_out_stencil
YES, since we are mixing colors, if you really want to see 24bits from your 12 bit dac, you can mix into the final 24bit RGB with my white nose generator before sending that into the 4 bit dac, but, do that in a separate module before feeding the vid_out_stencil.  Lets not complicate things right now.
Post by: nockieboy on December 08, 2019, 06:22:27 pm
I've not had much time to work on this today, been busy here and going to have to take another break now.  Here's the latest project zip - everything compiles, I've got a design for the palette_mixer, I just need to wire it up.  Would appreciate a check of the palette_mixer code, though, to make sure there's no glaring mistakes, if you have a spare 5 mins!
Post by: BrianHG on December 08, 2019, 08:19:57 pm
|O  pixel_out_r <=  ( (text_r[7:0] * ~alpha_blend[3:0]) + (graphics_r[7:0] * alpha_blend[3:0]) ) >> 4 ;   |O
You were supposed to figure that one out, I slipped.....
Ok, I'll I'm doing a quick check now...
Post by: BrianHG on December 08, 2019, 08:41:49 pm
Ok, on the intel ram: (see stars)
// inputs
input clock_a,
input clock_b,
input [3:0]  pc_ena_in,  ***************************** GET RID
input [7:0]  data_b,
input enable_a,
input enable_b,
input wren_a,
input wren_b,
// outputs
output [3:0]  pc_ena_out,  *********************************** GET RID
output reg [15:0] pixel_out, // data_out_a  ************* WIRE not reg
output reg [7:0]  data_out_b,                                   ************* WIRE not reg
output reg [19:0] addr_out_a  *********************************** GET RID
.clocken0 (1'b1),  ******************************** (enable_a)
.wren_a (wren_a),
.clock0 (clock_a),
.wren_b (wren_b),
.clock1 (clock_b),
.data_a (data_a),
.data_b (data_b),
.q_a (pixel_out),
.q_b (data_out_b),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (1'b0),
.rden_a (1'b1),
.rden_b (1'b1)
defparam
altsyncram_component.init_file = INIT_PALETTE,  ************** You still need to call this something and call it a parameter at the beginning of this .v file, even if the parameter name is 'init_file'...  To be clean use my name
endmodule
You can rename the address & data B to host_  so they match what you see in the vid_osd_generator as port B serves the same function.
Next:
// inputs
input clk,
input vs_in,
input hs_in,
input hde_in,
input vde_in,
// outputs
output reg [7:0] raster_out_r,   *****************  Lets change raster_ for pixel_
output reg [7:0] raster_out_g,
output reg [7:0] raster_out_b,
output reg [7:0] data_out_b,   *********************** make a proper complete host_ port ans place it at the bottom of all the graphics port IOs
output reg vs_out,
output reg hs_out,
output reg hde_out,
output reg vde_out
wire pc_enable = (pc_ena_in[3:0]==0);
wire [15:0] txt_pixel_out;
wire [3:0] alpha_blend;
wire [7:0] text_r;
wire [7:0] text_g;
wire [7:0] text_b;
wire [15:0] gfx_pixel_out;
wire [7:0] graphics_r;
wire [7:0] graphics_g;
wire [7:0] graphics_b;
assign alpha_blend = txt_pixel_out[15:12];
assign text_r[7:4] = txt_pixel_out[11:8];
assign text_r[3:0] = txt_pixel_out[11:8];
assign text_g[7:4] = txt_pixel_out[7:4];
assign text_g[3:0] = txt_pixel_out[7:4];
assign text_b[7:4] = txt_pixel_out[3:0];
assign text_b[3:0] = txt_pixel_out[3:0];
assign graphics_r[7:3] = gfx_pixel_out[15:11];
assign graphics_r[2:0] = gfx_pixel_out[15:13];
assign graphics_g[7:2] = gfx_pixel_out[10:5];
assign graphics_g[1:0] = gfx_pixel_out[10:9];
assign graphics_b[7:3] = gfx_pixel_out[4:0];
assign graphics_b[2:0] = gfx_pixel_out[4:2];
// inputs
.clock_a(clk),
.clock_b(clk),
.data_a(2'h00),
.data_b(2'h00),
.enable_b(pc_enable),  ********************** Wire this to 1'b1 as the host_ port we don't use the clock enable.
.wren_a(1'b0),
.wren_b(1'b0),
// outputs
.data_out_b(data_out_b),   *********************** host_ port...
.addr_out_a()              ******************** get rid
// inputs   **************************** perform the same corrections as above...
.clock_a(clk),
.clock_b(clk),
.data_a(2'h00),
.data_b(2'h00),
.wren_a(1'b0),
.wren_b(1'b0),
// outputs
.addr_out_a()
if (pc_ena_in[3:0] == 0) begin
// mix output rgb
raster_out_r <= ((text_r[7:0] * ~alpha_blend[3:0]) + (graphics_r[7:0] * alpha_blend[3:0])) >> 4;
raster_out_g <= ((text_g[7:0] * ~alpha_blend[3:0]) + (graphics_g[7:0] * alpha_blend[3:0])) >> 4;
raster_out_b <= ((text_b[7:0] * ~alpha_blend[3:0]) + (graphics_b[7:0] * alpha_blend[3:0])) >> 4;
end
end
endmodule
Change the 'raster_out_rgb' ahem, 'pixel_out_rgb' equation into a 2 stage pipe.  Like I wrote in the previous message, stage 1 will be the 2 multiplies/contrasts on their own >>4 to get 2 8 bit results.  Stage 2 will sum those 2 together to give you a final pixel value.
Post by: nockieboy on December 08, 2019, 10:47:10 pm
Latest pixel_mixer.v:
// inputs
input clk,
input vs_in,
input hs_in,
input hde_in,
input vde_in,
// outputs
output reg [7:0] pixel_out_r,
output reg [7:0] pixel_out_g,
output reg [7:0] pixel_out_b,
output reg vs_out,
output reg hs_out,
output reg hde_out,
output reg vde_out,
// host port
input [9:0] host_addr_in,
input [7:0] host_data_in,
output reg [7:0] host_data_out
// **** TO DO:
wire host_wren_txt; // need to complete this so that they go high when
wire host_wren_gfx; // the palette is correctly addressed by the host
wire [7:0] text_r;
wire [7:0] text_g;
wire [7:0] text_b;
reg [7:0] pixel_r1, pixel_r2, pixel_g1, pixel_g2, pixel_b1, pixel_b2;
// inputs
.clock_a(clk),
.clock_b(clk),
.host_address(host_addr_in),
.data_a(2'h00),
.host_data_in(host_data_in),
.host_enable(1'b1),
.wren_a(1'b0),
.host_wren(host_wren_txt),
// outputs
.host_data_out(host_data_out)
defparam text_palette_RAM.INIT_PALETTE = "palette_4444.mif";
// inputs
.clock_a(clk),
.clock_b(clk),
.data_a(2'h00),
.host_enable(1'b1),
.wren_a(1'b0),
.host_wren(host_wren_gfx),
// outputs
.host_data_out(data_out_b)
defparam graphics_palette_RAM.INIT_PALETTE = "palette_565.mif";
// mix output rgb
pixel_r1 <= (text_r[7:0] * ~alpha_blend[3:0]) >> 4;
pixel_r2 <= (graphics_r[7:0] * alpha_blend[3:0]) >> 4;
pixel_out_r <= pixel_r1 + pixel_r2;
pixel_g1 <= (text_g[7:0] * ~alpha_blend[3:0]) >> 4;
pixel_g2 <= (graphics_g[7:0] * alpha_blend[3:0]) >> 4;
pixel_out_g <= pixel_g1 + pixel_g2;
pixel_b1 <= (text_b[7:0] * ~alpha_blend[3:0]) >> 4;
pixel_b2 <= (graphics_b[7:0] * alpha_blend[3:0]) >> 4;
pixel_out_b <= pixel_b1 + pixel_b2;
end
end
endmodule
Latest dual_port_palette_ram_INTEL.v:
// inputs
input clock_a,
input clock_b,
input [8:0]  host_address,
input enable_a,
input host_enable,
input wren_a,
input host_wren,
// outputs
output [15:0] pixel_out, // data_out_a
output [7:0]  host_data_out
parameter INIT_PALETTE = "palette_565.mif";
.clocken1 (host_enable),
.wren_a (wren_a),
.clock0 (clock_a),
.wren_b (host_wren),
.clock1 (clock_b),
.address_b (host_address),
.data_a (data_a),
.data_b (host_data_in),
.q_a (pixel_out),
.q_b (host_data_out),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (1'b0),
.rden_a (1'b1),
.rden_b (1'b1)
defparam
endmodule
Need to sort the wr_en's for the graphics and text palette memory though.
Post by: BrianHG on December 08, 2019, 10:56:13 pm
// inputs
input clk,
input vs_in,
input hs_in,
input hde_in,
input vde_in,
// outputs
output reg vs_out,
output reg hs_out,
output reg hde_out,
output reg vde_out,
// host port
// **** TO DO:
wire [7:0] text_r;
wire [7:0] text_g;
wire [7:0] text_b;
// inputs
.clock_a(clk),
.clock_b(clk),
.data_a(2'h00),
.host_enable(1'b1),
.wren_a(1'b0),
// outputs
// inputs
.clock_a(clk),
.clock_b(clk),
.data_a(2'h00),
.host_enable(1'b1),
.wren_a(1'b0),
// outputs
// mix output rgb
end
end
endmodule
// inputs
input clock_a,
input clock_b,
input enable_a,
input host_enable,
input wren_a,
input host_wren,
// outputs
.wren_a (wren_a),
.clock0 (clock_a),
.clock1 (clock_b),
.data_a (data_a),
.q_a (pixel_out),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (1'b0),
.rden_a (1'b1),
.rden_b (1'b1)
defparam
endmodule
For the host ADDR in, you will need all 20 addresses & you will want 2 parameters to assign where each 512 bytes of ram will be written to and read from.
You should use a single host_write_ena, it's the base address parameters which will decide if the write should be executed or not.
Wire the thing up and test.
Compute & set the proper default pipeline size for this module.
Post by: BrianHG on December 08, 2019, 11:30:17 pm
Or, you can just put 9 addresses in and wire the msb & ~msb on the address into and && with the host_write_enable input.
Stacking the 2 palettes on top of each other and externally handling the paging of these memory blocks.
Post by: nockieboy on December 09, 2019, 10:07:15 am
Well I'm not sure about the host_write_enable - we can't have both palette memories being written to at the same time, so I've done my own thing to interpret which palette should be written to and which palette's data should be output to the host...  it's probably wrong and I've likely completely misunderstood why you want a common host_write_enable, but here it is in a nutshell:
parameter [19:0] TXT_PALETTE_ADDR = 19'h4000; // Position the text palette after the top of the GPU RAM
parameter [19:0] GFX_PALETTE_ADDR = 19'h4200; // Position the graphics palette after the text palette
wire host_gfx_data_out; // host data outputs from the
wire host_txt_data_out; // palette RAMs
wire host_wrena_txt; // write enables to each
wire host_wrena_gfx; // palette RAM
wire txt_addressed;
wire gfx_addressed;
// write enables to either palette RAM only go high if addressed correctly during a write
assign txt_addressed = (host_addr_in[19:10] == TXT_PALETTE_ADDR[19:10]);
assign gfx_addressed = (host_addr_in[19:10] == GFX_PALETTE_ADDR[19:10]);
assign host_wrena_txt = host_wrena & txt_addressed;
assign host_wrena_gfx = host_wrena & gfx_addressed;
// route the correct palette data out to the host
if (txt_addressed)
host_data_out <= host_txt_data_out;
else if (gfx_addressed)
host_data_out <= host_gfx_data_out;
end
Above is pseudo-code effectively as I've just cut 'n' pasted the appropriate bits of code from palette_mixer.v to illustrate the point.  The full code is in the attached project.  host_wrena is tied to ground in the design anyway, so it shouldn't be affecting the issue below...
I've wired up the palette_mixer and tested in the dev board - just getting a black screen apart from the trigger bars; no text or background, despite messing with the bitplane_to_raster settings.  :-\  I've either made a silly wiring mistake that I can't spot or there's a problem with the code.  I haven't worked out the PIPE_DELAY yet as I figured I should get something on the screen, even if the delay is wildly out, but there's nothing.  :-/O
Post by: BrianHG on December 09, 2019, 12:09:19 pm
Ok, I cannot fault you on this one, change the following lines:
// mix output rgb
pixel_r1 <= (text_r[7:0] * (15-alpha_blend[3:0]) ) >> 4;
pixel_g1 <= (text_g[7:0] * (15-alpha_blend[3:0]) ) >> 4;
pixel_b1 <= (text_b[7:0] * (15-alpha_blend[3:0]) ) >> 4;
Is there someone else out there who can tell me why this works?
But, this fails and always returns '0'?
pixel_r1      <= (text_r[7:0] * (~alpha_blend[3:0]) ) >> 4;
Even this fails:
pixel_r1      <= (text_r[7:0] * (4'hF ^ alpha_blend[3:0]) ) >> 4;
And this fails too:
pixel_r1      <= (text_r[7:0] * (4'hF - alpha_blend[3:0]) ) >> 4;
EVEN THIS FAILS!!!  :scared:
pixel_r1      <= (text_r[7:0] * (4'd15 - alpha_blend[3:0]) ) >> 4;  :scared:
BUT WHY DO THESE WORK???
pixel_r1      <= (text_r[7:0] * (32'd15-alpha_blend[3:0]) ) >> 4;
pixel_r1      <= (text_r[7:0] * (16'd15-alpha_blend[3:0]) ) >> 4;
@nockieboy, your text is too far to the left, however, since this is the first time you will see the results, you will need to adjust a few things.
As for selecting the 'Host_data_out'.  Some other adjustments will mat be needed as well.
I'm thinking of using the memories' :
            .rden_a (rden_a),
            .rden_b (rden_b),
Now, feed each rd_en_b(), (read enable) the txt_addressed and gfx_addressed wires.  .rden_a (rden_a), should obviously be (1'b1).
When rd_en_b(), is low, the read contents will be 0.  So, you just 'OR' the output data buses.
Same will go for the GPU main memory.  Assign a base address based on the gpu_RAM.ADDR_SIZE (which you have yet to expose to the top block diagram) and create for that memory an appropriate '.rden_b (rden_b),'.  On the block diagram, just 'OR' that host_data buss with the palette's host_data bus and all the memorie's data output will have a single 7 bit result, no additional register clock delays...
Post by: nockieboy on December 09, 2019, 12:49:47 pm
I tweaked palette_mixer's PIPE_DELAY down to 3 and it appears to be aligned okay now.  :-/O
[attach=1]
I'm not sure that's the right way to fix it, though - the HV triggers seem to be out at 19, 16, 658, 495.  The horizontal triggers seem to be out by 3 pixels?
EDIT: Ignore me, being a dunce.  It's because the HV triggers aren't delayed through the palette_mixer as well, isn't it?
Post by: nockieboy on December 09, 2019, 12:51:17 pm
            .rden_a (rden_a),
            .rden_b (rden_b),
Is this okay?
palette_mixer.v:
// inputs
input clk,
input hde_in,
input vde_in,
input hs_in,
input vs_in,
// outputs
output reg hde_out,
output reg vde_out,
output reg hs_out,
output reg vs_out,
// host port
input host_wrena,
input [19:0] host_addr_in,
parameter PIPE_DELAY = 6; // This parameter selects the number of pixel clocks to delay the VDE and sync outputs.  Only use 2 through 9.
wire txt_addressed;
wire gfx_addressed;
wire [7:0]  text_r;
wire [7:0]  text_g;
wire [7:0]  text_b;
// inputs
.clock_a(clk),
.clock_b(clk),
.pixel_addr_in(txt_pixel_in),
.host_address(host_addr_in[8:0]),
.data_a(2'h00),
.host_enable(1'b1),
.rden_a(1'b1),
.rden_b(txt_addressed),
.wren_a(1'b0),
.host_wren(host_wrena_txt),
// outputs
.host_data_out(host_txt_data_out)
// inputs
.clock_a(clk),
.clock_b(clk),
.pixel_addr_in(gfx_pixel_in),
.data_a(2'h00),
.host_enable(1'b1),
.rden_a(1'b1),
.rden_b(gfx_addressed),
.wren_a(1'b0),
.host_wren(host_wrena_gfx),
// outputs
.host_data_out(host_gfx_data_out)
// mix output rgb
pixel_r1 <= (text_r[7:0] * (15-alpha_blend[3:0])) >> 4;
pixel_g1 <= (text_g[7:0] * (15-alpha_blend[3:0])) >> 4;
pixel_b1 <= (text_b[7:0] * (15-alpha_blend[3:0])) >> 4;
end
// route the palette data out to the host
host_data_out <= host_txt_data_out | host_gfx_data_out;
end
endmodule
Okay, will get on that later this evening.  :-+
Post by: BrianHG on December 09, 2019, 01:02:30 pm
            .rden_a (rden_a),
            .rden_b (rden_b),
Is this okay?
palette_mixer.v:
end
endmodule
Switch the 'host_data_out'  into a wire and assign it to '= host_txt_data_out | host_gfx_data_out'.  Now there will be 0 clock cycles for clocking a register.
Post by: nockieboy on December 09, 2019, 01:16:27 pm
Done.  Also sorted the HV trigger problem - now delayed through palette_mixer, although I imagine that's a temporary debugging thing and I'll be removing them from the final display before too long.
EDIT: Forgot to mention, Fmax is down to 146.63 MHz now.
Post by: BrianHG on December 09, 2019, 01:39:18 pm
Found a bug in the 'bitplane_to_raster' module.
Line 146: if (x_out[3])...
I'll let you figure out the bug...
Also, make the HW_regs font default color to 240, that cyan background is ugly...
Post by: nockieboy on December 09, 2019, 02:05:34 pm
Ooh.. shouldn't that be x_out[2]?
Yeah, that was my reaction when I saw it too.  :-DD  Didn't think to change the HW_regs default settings - I was setting it to E1 in the RS232_debugger.  ;D
Post by: BrianHG on December 09, 2019, 02:06:12 pm
Remember my comment after this fix post of yours:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2816848/#msg2816848 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2816848/#msg2816848)
Doing it the wrong way will come back to haunt you later....  Like soon...
Post by: BrianHG on December 09, 2019, 02:07:00 pm
Yes.
But, don't forget this: https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2821728/#msg2821728 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2821728/#msg2821728)
Post by: nockieboy on December 09, 2019, 02:49:54 pm
Sorry, you've lost me there.  Is the fix you've linked to above incorrect then?  Or is the fault with x_out[3] linked to this previous fix? Should it be x_in[3] instead to remove the one clock delay?
Post by: BrianHG on December 09, 2019, 03:03:28 pm
     You have 2 problems with the code.  Changing the bit from 3 to 2 fixes 1 problem.  Playing with the pixel bitplane mode setting with the on screen text should have shown you a difference and you would have noticed the problem with the [3].
     Now, your home made delay 6 to 5 patch trick will not work with the new address generators as there will no longer be any x position delays to tap from once we go to the new address generators.
Post by: BrianHG on December 09, 2019, 03:42:09 pm
Ok, the ' .rden_b() ' doesn't do what I want, we must use the ' .aclr1 () ' for all the host memory ports.
Do this exactly:
Loose your rden_b port, and make a sclr_n_rd_b input and inside the 'ram_INTEL' module, add this...
reg aclr_delay,aclr_delay2;
on the altsyncram add this port:
            .aclr0 ( 1'b0 ),
            .aclr1 (aclr_delay2)
make sure you don't have doubles and the rden_b is now forced back to ' (1'b1) '
change these defparams:
      altsyncram_component.outdata_aclr_a = "CLEAR0",
      altsyncram_component.outdata_aclr_b = "CLEAR1",
add this at the end of the memory before ' endmodule'
always @(posedge clk_b) begin
aclr_delay  <= ~sclr_n_rd_b;
aclr_delay2 <= aclr_delay;
end
Post by: nockieboy on December 09, 2019, 05:05:02 pm
Do this exactly:
            .aclr0 ( 1'b0 ),
end
Okay, done all that - I assume when you said, "we must use the ' .aclr1 () ' for all the host memory ports", you meant the palette memory ports and not the GPU memory as well??
Post by: nockieboy on December 09, 2019, 05:08:33 pm
So either I'm screwed or there's some solution you're alluding to that is just beyond my grasp with the meagre time I have to focus on this currently?  :-[
Post by: BrianHG on December 09, 2019, 06:15:49 pm
This isn't difficult.  Think carefully.  If you are shortening the delay of the 'x' counter position by "1" before you feed the input of the bitplane to raster module to fix a problem, then, is it possible that you have a delay in the currently used 'x' coordinates inside the bitplane to raster module which shouldn't be there?
Post by: nockieboy on December 09, 2019, 09:04:00 pm
The only 'internal' delay to the x coordinates I can spot is the one I mentioned earlier? It's possible you read that message before I edited the comment in red into the post...  :-/O
Post by: BrianHG on December 09, 2019, 09:05:54 pm
Do this exactly:
            .aclr0 ( 1'b0 ),
end
 :( The .aclr1() trick wont work as well, make this change instead...
Change the output to a reg:
Make a new wire
wire [7:0] pre_data_out_b;
change the altsyncram IOs:
            .q_b (pre_data_out_b),
            .aclr0 (1'b0),
            .aclr1 (1'b0),
change the altsyncram defparams:
      altsyncram_component.outdata_reg_b = "UNREGISTERED",
create this true synchronous read with clear data before the 'endmodule':
aclr_delay  <= rd_en_b;
     if (aclr_delay) data_out_b  <= pre_data_out_b;
     else               data_out_b  <= 0;
end
This will keep a 2 clock read, with good performance, and create a synchronous '0' with the read 2 clock timing when the read enable is low.
Post by: BrianHG on December 09, 2019, 09:13:15 pm
Look carefully at the:
line 86               if (ram_byte_in[(~x_out[2:0])] == 1'b1) begin
line 112               case (x_out[2:1])
line 146               if (x_out[2])
line 180               if (ram_byte_in[(~x_out[2:0])] == 1'b1) begin
Is it possible that you have a delay in the currently USED 'x' coordinates inside the bitplane to raster module which shouldn't be there?
Prepare to bang your head and see why I was banging mine with the comment:
Next...
If I need to make 1 more comment on this, your gonna feel worse...
Post by: BrianHG on December 09, 2019, 09:43:28 pm
Look at line #37:
      x_out               <= x_in;
Post by: nockieboy on December 09, 2019, 10:28:08 pm
Make a new wire
            .aclr0 (1'b0),
            .aclr1 (1'b0),
end
All done.  Updated dual_port_palette_RAM_INTEL.v below:
module dual_port_palette_ram_INTEL (
// inputs
input clock_a,
input clock_b,
input enable_a,
input host_enable,
input wren_a,
input host_wren,
input rden_a,
input rden_b,
input sclr_n_rd_b,
// outputs
reg aclr_delay;
.wren_a (wren_a),
.clock0 (clock_a),
.clock1 (clock_b),
.data_a (data_a),
.q_a (pixel_out),
.aclr0 (1'b0),
.aclr1 (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (1'b0),
.rden_a (rden_a),
.rden_b (rden_b)
defparam
always @(posedge clock_b) begin
if (aclr_delay)
else
data_out_b <= 1'b0;
end
endmodule
Post by: nockieboy on December 09, 2019, 10:32:08 pm
Look at line #37:
      x_out               <= x_in;
Darnit, you didn't give me time to reply before you posted another message!  :-\
I'm using x_out in the code, which is delayed by a clock due to the line you've quoted above, when I should be using x_in.  I spotted that earlier and updated the reply I'd made, suggesting it as a modification, but you missed it?  Either that, or you're saying that I shouldn't be assigning x_in to x_out at all and it should just pass straight through without being registered?
Post by: BrianHG on December 09, 2019, 10:45:39 pm
Oooops, I saw the x_in[3] and focused on the '3' not the '_in'.  Yes, inside the 'if' your should only be using the x_in[] since it's the input which also needs comparing with the input data.  Everything should run in parallel...
Yes, you did get it earlier...
Ok, gotta do the 2-3 fixes to the main GPU_RAM module, then the address generators.
Next, do this: https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2818788/#msg2818788 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2818788/#msg2818788)
Then we can tackle the address generator.
Post by: nockieboy on December 10, 2019, 09:33:34 am
Sorry, just remind me what these 2-3 fixes were, exactly?  I'm working on making the gpu_dual_port_ram_INTEL module output 16-bits as per your linked previous post - are there other changes to be made as well?
Post by: nockieboy on December 10, 2019, 10:18:46 am
@nockieboy, I hate to do this to you, but once you get the initial palette working, you will need to make a change to the 'multiport_gpu_ram.v' and 'gpu_dual_port_ram_INTEL.v'.  Now, I want to get this change right in 1 shot, so, we will need to go over it after the text palette is fully 100% functional without a single pixel in error...
Okay, I've made all the changes you've specified, but I'm getting the following error:
Error (272006): In altsyncram megafunction, when OPERATION_MODE parameter is set to BIDIR_DUAL_PORT, total number of bits of port A and port B must be the same
The RAM isn't happy with 8-bit and 16-bit ports.  I'd made a start making the host port 16-bit, planning to use the same technique to swap bytes around depending on the address's LSB, but then I realised that writing to the 16-bit port by an 8-bit host will be... messy... at best, and will corrupt the RAM contents at worst.  So I'm holding here to see if you have any pearls of wisdom?
Current project attached so you can review the changes made to the RAM so far.
Post by: hamster_nz on December 10, 2019, 11:17:54 am
Did you change the width of the address line too? The address line for the 8-bit port needs to be one bit wider than the 16-bit port (as 16*1024 = 8*2048 = 16384 bits)
Post by: BrianHG on December 10, 2019, 11:28:44 am
There were the primary mistakes:
altsyncram_component.numwords_a = NUM_WORDS /2,
altsyncram_component.widthad_a = ADDR_SIZE - 1 ,  // *************************** 1 less address since we are now 16 bit
altsyncram_component.init_file_layout = "PORT_B",      // *************** assign .mif file to layout 'B'
Too many other changes all at once.  Before making these changes, did everything else work properly?
Like, why did 'PIPE_DELAY' go from the proper value of 7 down to 6 from the last version to this version?
This would have messed up the display by 1 pixel.
I cannot track compound errors...
Too many other changes all at once...
Now, I've gone back 1 version, and just changes the ram_INTEL to make port 'A' 16bit, and use the assign 'mux' ram_data_a from 16bit to 8 bit out, and with 1 change of the addr[0], to the correct delay of addr[0], it works properly.  You will need to reverse the additional compound errors yourself as I cannot figure out why your latest  upload has numerous crap text errors and green background.
Post by: nockieboy on December 10, 2019, 11:58:18 am
Ah, that's got it compiling again...
Yes, it was working fine - the PIPE_DELAY error was because I'd fixed the x_in/x_out issue and changed PIPE_DELAY back to 7, but because of a work distraction here, I came back and got confused about the original value and changed it back to 6.  |O
Now, I've gone back 1 version, and just changes the ram_INTEL to make port 'A' 16bit, and use the assign 'mux' ram_data_a from 16bit to 8 bit out..
I've made the changes you specified in the main post previously, including making the command bus 32 bit etc., have had to expand the pipelines from 8- to 16-bit according to the changes made to the data bus etc.  As far as I can tell, the changes are according to what you've specified.  I'd marked all the requested changes in the code with comments to make them easier to spot.
This is my output currently:
[attach=1]
...and with 1 change of the addr[0], to the correct delay of addr[0], it works properly.  You will need to reverse the additional compound errors yourself as I cannot figure out why your latest  upload has numerous crap text errors and green background.
Well, it should be a blue background.  It compiles with no errors now, but the text is clearly corrupted.
Post by: nockieboy on December 10, 2019, 12:02:35 pm
Ignore the green background, I'd been messing with the default values.  :-\
Post by: BrianHG on December 10, 2019, 02:19:49 pm
Noooooooooo.  The x_in/x_out fixes the:
.bg_colour( GPU_HW_Control_regs[10] ),
.x_in( dly6_disp_x ),
.colour_mode_in( GPU_HW_Control_regs[12][2:0] ),
.x_in( dly5_disp_x ),
 Back to the proper:
This bug had nothing to do with the 'PIPE_DELAY', which had the proper value of '7'.
The PIPE_DELAY went from 6 to 7 because the 'bitplane_to_raster' takes 1 clock cycle to create an output pixel where the older pixel character[~xsel] selection from the ram took 0 clock cycles.
Now, your garbage text, did you fix the 'addr[0]' so that the addr which selects the correct memory output byte is the same addr with the same byte we expect to receive from the altsyncram's memory output when the original address was fed in.
Remember, we are feeding 125 million new read addresses second.  Non stop.  The ram coming out keeps on changing 125 million times a second, even though it is 2 clocks behind.  Take this info into consideration when selecting the high and low byte.
(You still have other errors as even the green seems impossible.  I only re-wrote your code from the last version to what you were supposed to create, and it correctly worked with the 16 bit memory and 16 bit mux and 32 bit aux ports and I got perfect blue text.)
After the address generator, we will be modding the gpu_INTEL ram into a new wrapper module, running the the INTEL ram at 250MHz, making it's 2 ports into 4 ports at 125MHz.  And, we will be multiplying the 'multiport_gpu_ram' module 3 fold making a 15 read address ports for 15 parallel pixel reads, plus the 1 host_ port.  I hope you are up to the challenge.  (We would need 1GHz 8 bit static ram to replicate this, not counting the palette memory which would double that as we might do the same 15 ports there for true multiple degrees of translucency between all layers instead of between 2 layers, then just transparent color 0 / vs non-transparent.  Also in the lattice part, you will ran the ram at 500Mhz, in other words, you would need a 4GHz 8 bit static ram to replicate that display engine with it's 40 parallel read ports and 2x equivalent host_ ports.)
Post by: nockieboy on December 10, 2019, 02:38:25 pm
I've rolled back the 16-bit changes I made (except the 32-bit changes to the command bus - this isn't used yet so won't affect the output at the moment) and I'm getting a good display again.  Clearly something I'm doing with the 16-bit changes is incorrect.  Here's a summary of the changes I made: (NOTE: these are JUST the changes to the data bus, not the full code)
In multiport_gpu_ram.v:
// data buses (output)
output reg [15:0] data_out_0, // ****** changed to 16 bit width
output reg [15:0] data_out_1, // ****** changed to 16 bit width
output reg [15:0] data_out_2, // ****** changed to 16 bit width
output reg [15:0] data_out_3, // ****** changed to 16 bit width
output reg [15:0] data_out_4, // ****** changed to 16 bit width
wire [15:0] data_mux_out; // ****** changed to 16 bit width
reg [DEMUX_PIPE_TOP*16+15:0] data_pipe; // ****** changed to 16 bit width
data_pipe[15:0]                     <= data_mux_out[15:0]; // fill the first 16-bit word in the register pipe with data from RAM
data_pipe[DEMUX_PIPE_TOP*16+15:1*16] <= data_pipe[ (DEMUX_PIPE_TOP-1) *16+15:0*16]; // shift over the next 9 words in this 10 word, 16-bit wide pipe
data_out_0 <= data_pipe[MUX_0_POS*16+15:MUX_0_POS*16]; // ****** changed to 16 bit width
data_out_1 <= data_pipe[MUX_1_POS*16+15:MUX_1_POS*16];
data_out_2 <= data_pipe[MUX_2_POS*16+15:MUX_2_POS*16];
data_out_3 <= data_pipe[MUX_3_POS*16+15:MUX_3_POS*16];
data_out_4 <= data_pipe[MUX_4_POS*16+15:MUX_4_POS*16];
In gpu_dual_port_ram_INTEL:
output wire [15:0] data_out_a, // ****** changed to 16 bit data width
// * NEW SECTION to reverse byte order of read-only port if addressed LSB is 0
wire [15:0] ram_out_a;
assign data_out_a[15:8] = (addr_a[0] == 1'b0) ? ram_out_a[15:8] : ram_out_a[7:0];
assign data_out_a[7:0] = (addr_a[0] == 1'b0) ? ram_out_a[7:0]  : ram_out_a[15:8];
.address_a (addr_a[ADDR_SIZE - 1:1]), // ****** changed LSB from 0 to 1
.data_a (16'b0000000000000000), // ****** changed to 16 bit data width
.q_a (ram_out_a), // ****** changed from data_out_a to ram_out_a
altsyncram_component.numwords_a = NUM_WORDS / 2,   // ****** changed to NUM_WORDS / 2
altsyncram_component.widthad_a = ADDR_SIZE - 1,  // ****** changed to ADDR_SIZE - 1
altsyncram_component.width_a = 16, // ****** changed from 8 to 16
In bitplane_to_raster.v:
input wire [7:0] ram_byte_in, // ****** changed to 16 bit width
These are all the changes I made (other than the cmd bus ones) - I've reverted all these changes and the output is fine again.  Any chance you could share the changes you've made to get it to work?
 Back to the proper:
Yes, realised this later.   :palm:
Fix as in register it? Err... no?  Would this code not work then, unless addr_a[0] is registered?
(You still have other errors as even the green seems impossible.  I only re-wrote your code from the last version, and it correctly worked with the 16 bit memory and 16 bit mux and 32 bit aux ports and I got perfect blue text.)
The green isn't an error, it's where I'd changed the default HW_regs settings and forgot to change them back before posting the project.  ::)
Post by: nockieboy on December 10, 2019, 04:10:15 pm
Okay, at first glance I seem to have fixed the corrupt text.  :-/O Instead of using addr_a coming IN to the gpu_dual_port_ram_INTEL module, I switched it to the address going OUT (addr_out_a) - it's a clock behind, but it's a register so should stay valid long enough to lift the data from both bytes in the word... and it does.  :)
Obligatory pic:
[attach=1]
EDIT: Latest project files attached.
Post by: nockieboy on December 10, 2019, 05:23:01 pm
 :-\  I hope I'm up to the challenge, as well!  I might have to fold and ask for more breadcrumbs to get me through this more quickly, though.  Can't believe I've wasted a day today hunting for (and thankfully fixing) two silly bugs.  |O
I'm going to need a bigger FPGA! :o  It'll maybe stretch to doubling the multiport_gpu_ram module with it's ~33 KB of RAM, but certainly won't manage three or more such modules.  :-\
Post by: BrianHG on December 10, 2019, 05:38:36 pm
Obligatory pic:
(Attachment Link)
How did you come to the conclusion that the 'addr_out_a' is a clock behind the ram 'data_out_a'?
Does this image not represent the GPU_INTEL memory:
[attachimg=1]
Count the number of clocks from address in to data out by counting the number of D-flipflops in the attached image...
How many do you count?
How many D-flipflops has the 'addr_out_a' gone through since the 'addr_a' input?
It's important you understand what's going on here.  All these pipes I made, though they all might not be used, the address generator will feed some values through them, IE coordinates, new memory to point to, expecting a ram read/or/pixel and these values/settings to be parallel at the output for everything to work properly at the next stage.  Without this parallel infrastructure, you will have code like in the current OSD generator's old junk like this obsolete patch work:
// *** These delay pipes registers are explained in the 'assign's above
dly1_disp_x <= disp_x;
dly2_disp_x <= dly1_disp_x;
dly3_disp_x <= dly2_disp_x;
dly4_disp_x <= dly3_disp_x;
dly5_disp_x <= dly4_disp_x;
dly6_disp_x <= dly5_disp_x;
dly7_disp_x <= dly6_disp_x;
dly8_disp_x <= dly7_disp_x;
dly1_disp_y <= disp_y;
dly2_disp_y <= dly1_disp_y;
dly3_disp_y <= dly2_disp_y;
dly4_disp_y <= dly3_disp_y;
dly1_letter <= letter;
dly2_letter <= dly1_letter;
dly3_letter <= dly2_letter;
dly4_letter <= dly3_letter;
dly1_dena   <= dena;
dly2_dena   <= dly1_dena;
dly3_dena   <= dly2_dena;
dly4_dena   <= dly3_dena;
dly5_dena   <= dly4_dena;
dly6_dena   <= dly5_dena;
osd_ena_out <= dly4_dena; // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown
// It needs to be delayed by the number of pixel clocks required for the above memories
pixel_ena <= dly4_dena;
Which is about to be all deleted.  But, if you have a mistake somewhere in the 'multiport_gpu_ram' and it's parallel pipe, when we feed it a continuous address with embedded in the auxiliary pipe x coordinates and start and stop pixel coordinates to be displayed in parallel with 3 to 12 other address generator on every addr_in_# channel, you will never be able to back track and find any error at all if 1 single thing is out with this code.
Post by: nockieboy on December 10, 2019, 05:47:47 pm
(Attachment Link)
I actually meant that addr_out_a is one clock behind addr_a, not data_out_a.  It's actually two clocks behind:
rd_addr_pipe_a <= addr_a;
addr_out_a <= rd_addr_pipe_a;
That's what I was referring to, but in any case the reason for using it was that data_out_a was getting ahead of itself using addr_a, which wasn't holding the right data and corrupting the output, I guess.  :-BROKE
Post by: BrianHG on December 10, 2019, 06:04:16 pm
I hate to burst your bubble, but, I just compiled you project for your Cyclone IV EP4CE6E22C8 after removing the bulk of the HV_triggers which would never reach the display directly.  You are only using 20% of your logic gates.
In your compilation report, under Fitter section, under resource section, under 'resource utilization by entity':
[attachimg=1]
It says that 82 logic cells are used, and we are using 50% of the module, so, 1 full module would be around 164 logic cells.  * by 3 = 492, - original 82 = 410, since we are not adding ram, the change means 410 new additional logic cells for 15 read ports.  So, your current design total of 1330 logic cells of 6272 will increase to 1740 or 6272 = 28% usage.  That's only an 8% increase of used logic cells.
You are clear for a 15 port, 25Mhz x 16 bit read ram, or a read rate of 750 megabytes a second not counting the additional speed of the host port's 125 megabytes a second plus the palettes read speed.
Post by: nockieboy on December 10, 2019, 06:10:31 pm
Well colour me impressed, then.  ^-^ I thought you meant there'd be three RAM modules (each 16 KB).  ???
Ooh, latest project files attached.
Post by: BrianHG on December 10, 2019, 06:20:46 pm
The first 3 ports are the text and bottom display windows.  The new 12 will be the 12 sprites, each again 1 window anywhere on the screen positioned by the HV_triggers, and any width and any height pointing anywhere in your bulk of GPU memory.
If you go to the 2 megabit lattice part, with it's 500MHz capable core ram, you will have room and cycle time for 30 read ports, leaving 27 sprites, or graphics windows overplayed on top of each other.
Now these window sprites can be larger than the display area too.  Any X&Y size from memory meaning a 27 layer parallax scrolling game scenery is possible in full color.  Talk about roasting the Amiga.
Each window layer can be at any resolution, any bitplane color depth, any zoom level, as long as they all share the same 256 color palette or, you set a layer to 65536 color mode where the palette will be bypassed.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on December 10, 2019, 06:37:10 pm
A little more perspective:
The Amiga could only do 4 bitplanes in highres.
Here, in high res, you have a maximum of 16 bit per pixel with 14 superimposed parallel layers.  That's a 224 bitplane display.  Double that on the lattice part.
Post by: nockieboy on December 10, 2019, 06:49:49 pm
Aye carumba!  :o
So, the address generators are next?
Post by: BrianHG on December 10, 2019, 06:59:33 pm
Yes.
An address generator resets to a base HW_REGS reg stored memory address once every v-sync.
Every (Y size) H-syncs, a second HW_REGS is added to that address generator base defining the horizontal size of the bitmap to be displayed.
Another HW reg store a pixel X size counter and Y size counter defining the width and height of the active window.
Another 2 store the X&Y beginning point of the window already setup with the HV_triggers.
2 more X&Y period size counters define the width and height of the pixels. (call this an X&Y zoom, or scale)
Another HW reg stores the bitplane color mode, background color and enable/disable.
This above address generator is identical for all graphics / sprite layers.
For the text mode, another HW_Reg stores the base address and X&Y pixel size of the font to be passed through the read port ram a second time from it's first address generator.  Later in the Lattice part, with it's size, you may have the room for a text mode for every sprite layer making the Supernintendo's tile system look like a toy peanut.
Post by: BrianHG on December 10, 2019, 07:13:14 pm
An expansion patch to the bitplane to raster module:
Everywhere you have unused surplus pixel_out bits, ie:
pixel_out[7:2] <= 6'b000000;
pixel_out[7:4] <= 4'b0000;
Change it to:
pixel_out[7:2] <= bg_color[7:2];
pixel_out[7:4] <= bg_color[7:4];
You know what, just copy and paste the changes from here:
module bitplane_to_raster (
// inputs
input wire clk,
input wire pixel_in_ena,
input wire [3:0] pc_ena,
input wire [15:0] ram_byte_in, // ****** changed to 16 bit width
input wire [7:0] ram_byte_h,
input wire [7:0] bg_colour,
input wire [9:0] x_in,
input wire [2:0] colour_mode_in,
input wire two_byte_mode,
// outputs
output reg pixel_out_ena,
output reg mode_16bit, // high when in 16-bit mode
output reg [7:0] pixel_out,
output reg [7:0] pixel_out_h,
output reg [9:0] x_out,
output reg [2:0] colour_mode_out
// internal registers
//reg [7:0] colour_data;
// *  PASS-THRUS                                                               *
always @ ( posedge clk ) begin
x_out <= x_in;
//colour_data <= ram_byte_in; // in two-byte mode, colour_data should follow the ram_data byte
colour_mode_out <= colour_mode_in;
end // pc_ena
end // always@clk
// *  RASTER GENERATION                                                        *
// color_mode_in determines the operating mode for the bitplane_to_raster module
// it is a 3-bit signal, providing 4 modes of operation to this module e.g.:
// 000 =   2 colour mode - 8 pixels per byte in GPU RAM
// 001 =   4 colour mode - 4 pixels -----"------"------
// 010 =  16 colour mode - 2 pixels -----"------"------
// 011 = 256 colour mode - 1 pixels -----"------"------
// 1xx = OFF
always @ (posedge clk) begin
pixel_out_ena <= pixel_in_ena; // pass pixel_ena through to the output
if (~pixel_in_ena || colour_mode_in[2]) begin
// nothing to see here (disabled)
pixel_out <= 8'b00000000;
pixel_out_h <= 8'b00000000;
end
else if (~two_byte_mode) begin // 8-bit mode
case (colour_mode_in)
2'h0 : begin // 1-bit (2 colour) - 8 pixels per byte
// set the output pixel color to the first 4 bits of the background color
// when the bit on the picture bitplane byte is 0 and use the upper 4 bits
// when the bit on the bit-plane byte is high
mode_16bit <= 1'b0; // update mode_16bit output to 8-bit mode
if (ram_byte_in[(~x_in[2:0])] == 1'b1) begin
pixel_out[7:4] <= 4'b0000; // was: pixel_out[7:5] <= 3'b000;
pixel_out[3:0] <= bg_colour[7:4];
end
else begin
pixel_out[3:0] <= bg_colour[3:0];
end
end
2'h1 : begin // 2-bit (4 colour) - 4 pixels per byte
// output will be 2 bits stacked, 2 copies every second X pixel, you will
// output a 2 bit color. EG pixel 0&1 output bitplane[7:6],  pixel 2&3
// output bitplane[5:4], pixel 4&5 output bitplane[3:2]
case (x_in[2:1])
2'h0 : begin
pixel_out[1:0] <= ram_byte_in[7:6];
end
2'h1 : begin
pixel_out[1:0] <= ram_byte_in[5:4];
end
2'h2 : begin
pixel_out[1:0] <= ram_byte_in[3:2];
end
2'h3 : begin
pixel_out[1:0] <= ram_byte_in[1:0];
end
endcase
end
2'h2 : begin // 4-bit (16 colour) - 2 pixels per byte
// output will be 4 bits stacked, 4 copies every four X pixel, you will
// output a 4 bit color.  EG pixel 0,1,2,3 output bitplane[7:4], EG pixel
// 4,5,6,7 output bitplane[3:0]
if (x_in[3])
pixel_out[3:0] <= ram_byte_in[3:0];
else
pixel_out[3:0] <= ram_byte_in[7:4];
end
2'h3 : begin // 8-bit (256 colour) - 1 pixel per byte
// output will be 8 bits stacked, 8 copies every eight X pixel, you will
// output a 4 bit color.  EG pixel 0,1,2,3,4,5,6,7 output bitplane[7:0],
// yes that same 1 value will repeat 8 times is the source X counter
// counts through those numbers sequentially
mode_16bit <= 1'b0; // update the mode output to show whether it's 8 or 16-bit mode
pixel_out <= ram_byte_in[7:0];
end
endcase
end // 8-bit mode
else begin // 16-bit mode
2'h0 : begin // special colour text mode
// 2-bit colour 2-byte mode
// latch ram_byte as the bit plane graphic and colour_data
// as a replacement for the background default color. The
// rest should follow #1.
pixel_out[3:0] <= ram_byte_h[7:4];
end
else begin
pixel_out[3:0] <= ram_byte_h[3:0];
end
end
2'h3 : begin // 16-bit (true colour)
// taking 2 sequential bytes, like the color text mode, and outputting
// a full 16 bits parallel on the output
mode_16bit <= 1'b1; // update mode_16bit output to 16-bit mode
pixel_out_h <= ram_byte_h;
end
endcase
end // 16-bit mode
end // if (pc_ena[3:0] == 0)
end // always@clk
endmodule
So now, if you define a sprite with 4 or 16 color pixels, you may choose the upper palette bits of that sprite's layer by setting the matching upper bits of it's bg_color.  This way, each sprite can share or have it's own palette anywhere inside the 256 color palette as long as it isn't 256 color sprite where it obviously uses all 256 entries in the palette.
Post by: nockieboy on December 10, 2019, 07:23:25 pm
Okay, having read that I'm thinking of moving the existing three HW registers (fore/background colour, two_byte_mode and colour_mode_in) from their current positions to 00, 01 and 02.  I can then just use the regs sequentially after that for the new features we're adding.  I feel it's more logical than them currently being sat in an island from 0A-0C, which was just an arbitrary address I plucked out of thin air.  Any issues with that?
Toy peanut. Love it.  ;D
Post by: BrianHG on December 10, 2019, 07:33:10 pm
Hang on, I'll lay out the address generator controls by byte tonight and we will decide the base for each address line generator since the HV_Triggers are separate of the line generators  and the first text mode and controls reside inside the 32 reset defaults.  This way when the 'reset' is hit, a default functional display will be produced.
With your current layout, before switching you core GPU INTEL ram from 125MHz to 250MHz, you will only have access to 1 text display and 3 sprites, 1 of which is the bottom background graphics display while the other 2 sit on top of everything else including the text.
Post by: nockieboy on December 10, 2019, 07:40:18 pm
An expansion patch to the bitplane to raster module...
...So now, if you define a sprite with 4 or 16 color pixels, you may choose the upper palette bits of that sprite's layer by setting the matching upper bits of it's bg_color.  This way, each sprite can share or have it's own palette anywhere inside the 256 color palette as long as it isn't 256 color sprite where it obviously uses all 256 entries in the palette.
Excellent, thanks.  :-+
I'm especially intrigued to find out how the sprites will move - I guess this will be driven by the Z80 setting an X,Y position in the HW regs every frame?
Post by: BrianHG on December 10, 2019, 07:59:30 pm
Yes, you need to set the HV trig as an X&Y, I'm still deciding if you will need to set the right side and bottom, or will I have additional X&Y counter...
To scroll the image off the left hand side of the screen or scroll it above the top of the display, your going to need to adjust 2 more bytes to reposition the raster's memory base address and shrink the visible width.
Post by: BrianHG on December 10, 2019, 08:41:45 pm
Remember this one: https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2782402/#msg2782402 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2782402/#msg2782402)
Just scroll down the message and look for that big red '1' and you will see what took me hours to find...
In the new year, I wont have the same time as now, your gonna have to get used to finding bugs all on your own...
Post by: nockieboy on December 10, 2019, 11:21:00 pm
I know, and I really do appreciate the time and effort you've put in to help me.  :)  I'm operating on the assumption that you won't be around after the new year to help at all, so I'm hoping to get as much done before Christmas as possible; stupid mistakes allowing, of course.  :-[
Post by: BrianHG on December 11, 2019, 04:26:53 am
Next is the address generator/graphics instruction engine.
Here are the targeted controls/capable features:  (We want to make 1 identical algorithm which will be used 4 times.)
1) Enable/disable.  Requires 1 bit.
2) The base/beginning of a memory address which contains either the screen text data, font data, graphics data and sprite data.  (This eats 20 bits since we can address 1 megabyte for this address)
3) Vertical memory increment size.  When beginning a new line, this is the amount added every time to the base address.  (16 bits is fair, maximum 64kb wide picture.)
4) Pixel type.  1bit=8 pixels wide per byte 2 colors per pixel,
                       2bit=4 pixels per byte 4 colors per pixel,
                       4bit=2 pixels per byte 16 colors,
                       8bit=1 pixel per byte, 256 colors,
                      16bit=2 bytes per pixel, 65k true-color
          = 5 settings possible meaning requires 3 bits for this setting.
5)  X scale.  Counts the number of pixels wide each bitmap image pixel will occupy.  1 through 16 (4 bits)
6)  Y scale.  Counts the number of lines each bitmap image line  will occupy.  1 through 16 (4 bits)
7) Sub-pixel starting X&Y coordinates.  This setting vertically & horizontally shifts the image up and to the left by single pixels in text mode and 4/2/1 bit color modes.  IE, smooth scrolling of text horizontally by up to 7/8th of 1 character, then you can change the base memory address by 1 character and reset this setting back to 0 allowing you to move the text pixel by pixel horizontally and vertically. The shift 16 pixels x by 16 pixels y , or 8 bits total.
8 )  Special control for font size.  8x8 pixel bitmap to 16x16 bitmap.  4 bit control.
9)  Total number of video lines to render before loading a new set of the above controls.  This will allow you to switch video modes mid screen, EG: have a window of 40 column text for half the screen, then switch to 80 column text for the bottom half.
Have I missed anything.  The total here is around 14 control bytes, or, we will reserve 16 bytes per address generator and call it safe.
Extra Note: The horizontal and vertical windows and enables for the 16 sprites will be stored separately.  10bit X 10 bit Y.
Palettes also have a dedicated separate set of registers.  A programmable interrupt generator based on a selected line of video will also be added for smooth animation apps.
Ok, here we go:
     We will have a master H & V trigger for the horizontal reset and vertical reset.  This will be parameter assigned inside the address_generator-s, bitplane_to_raster-s, and palette_mixer-s.
     All register controls should be latched on the parameter selected ' H && V ' triggers so that the Z80 can make changes during the entire display time, however, the entire bulk of graphics / coordinate settings will be updated/refreshed once every V-sync.  The down side (except for the H&V trigger which we will fix later on) is that you cannot take 1 sprite and manipulate it's settings in real time during the middle of the screen refresh to trick construct multiple additional sprites.  However, the pros are a ton of CPU cycles may be used to construct an animated display during the entire display time while the next V-sync, all screen geometries will be refreshed all at once.  Also, with 12 sprites, and a jump to 24 sprites with the Lattice FPGA part, each one of the 24 being able to be larger than 640x480, like 65536x65536 viewport window, if you complain about this real-time limitation, I'll be on a flight over seas to murder you...  ;)
Each line generator will also have a parameter to identify which 1 set of H&V trigger will be used to position their top-left X&Y coordinate location and a second H&V trigger to define the bottom right screen coordinates of the image.
Next, #1 & #4.  We will squeeze these 2 together with a few other options.  This HW_REG will hold the control for the bitplane_to_raster module.  All 8 bits will be sent into that module and define the video mode.  Off, 1 bit color, 2 bit color, 4 bit color, 8 bit color, 16 bit color, special 2 byte text color font.  Color Palette type (either ARGB 4444, RGB 565, or 16 bit 565 thru, or mixed 16bit 656 thru with last 256 colors assigned through the palette).  (5 or 6 bits consumed, 2 spare bits for future features)
Next, bg_color and fg_color.  These are 2 HW_REG byte values used for the 1 bit color mode and for where within the palette the remaining missing upper bits of the 16 and 4 color modes will be placed.
Next, #2  The base/beginning of a memory address which contains either the screen text data, font data, graphics data and sprite data. 3 HW_REG bytes.
Next, #3  The X size/width in bytes of the image in memory being displayed.  2 HW_REG bytes.
next, X&Y scale, and sub_pixel X&Y start.  1 byte each for a total of 4 bytes.
We are at 16 bytes to control every feature of the window line generator.  15 address generators, + 16 bytes for a few global controls means 256 bytes for the HE_REGS.  You will need to double this setting on the Lattice FPGA as it will have 30 address generators.  More if you want to add an audio system.
When a line generator is in the special ascii text mode, it will have the same controls, but with 1 or 2 changes to define the font's X&Y size attributes plus 1 input in the module will be used to receive an incoming ASCII character from the multiport_ram output from a previous line generator to realtime point to a font's position to construct a bitmap.  This means you need 2 address generators with 2 ram ports to construct a text/character tile based display on the screen, though the second line generator is mostly dead and just passes through a bunch of wired signals.
For our development path, we will start with a simple line generator which will open a 256 color display window on the screen, with adjustable X&Y coordinates and X&Y size.  We will use port 3 on our multiport ram and add bitplane to raster module to receive the output, then feed the palette mixer module 565 input.
We wont touch the text yet.  Need to first get the basics working.
More to come after some sleep...
Post by: BrianHG on December 11, 2019, 12:07:00 pm
Step #1, minor touch up to the bitplane_to_raster.v module:
     Add HW_REGS input to the bitplane_to_raster module.
     Add a parameter which defines the base of the 3 control bytes:
             The video mode byte, the bg_color byte and fg_color byte.
     Change you 'case' statement to accommodate the the new byte bitplane mode selection from the above post which controls everything in 1 byte.  Like 16bit color mode, pixel color bits, ect.  (document these bit switches)
     Add a new input wire named 'enable_in'.  When low, the pixel outputs will go to '0', identical to having the video mode set to 'off'.
     Add a new output reg called 'enable_out'.  Goes low when 'off' or 'enable_in' is low.  Goes high when 'enable_in' is high and any selected valid video mode.
Start documenting the new controls.  Also note that each display layer will have it's own bitplane_to_raster.v, so, this means 5 of them in you current design going up to 15 once we double the clock of your core memory, each with their own controls.
First part of the address generator, window coordinates, H&V size and H&V scale coming this afternoon.
Post by: BrianHG on December 11, 2019, 12:59:16 pm
And now you know why within my RS232_Debugger HEX editor, you may click on the bits in the Binary view of the memory byte you are editing, and that bit will toggle allowing you to switch on and off multiple features controlled by different bits in a single byte.
Post by: nockieboy on December 11, 2019, 01:34:59 pm
All done.  Have hardwired enable_in HIGH in vid_osd_generator for testing.
I've removed colour_mode_in and colour_mode_out from the bitplane_to_raster module as they're not used now that the video_mode byte has taken over setting the mode.  All working as expected so far.
// inputs
input wire clk,
input wire enable_in,
//input wire [2:0]  colour_mode_in,
input wire [7:0]  GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)],
// outputs
output reg enable_out,
//output reg [2:0] colour_mode_out
parameter CTRL_BYTE_BASE = 8'h0; // defines the base address of the 3 control bytes (video_mode, bg_colour, fg_colour) in the HW_REGS
// video_mode byte - CTRL_BYTE_BASE + 0
// This HW_REG defines the video mode:
// 0000 - Off
// 0001 - 1 bit color
// 0010 - 2 bit color
// 0011 - 4 bit color
// 0100 - 8 bit color
// 0101 - 16 bit color
// 0110 - Special 2-byte text colour mode
// 0111 - ARGB4444
// 1000 - RGB565
// 1001 - 16 bit 565 thru
// 1010 - Mixed 16-bit 656 thru with last 256 colors assigned through the palette
parameter HW_REGS_SIZE = 8; // default size for hardware register bus - set by HW_REGS parameter in design view
// *  PASS-THRUS                                                               *
x_out <= x_in;
//colour_mode_out <= colour_mode_in;
end // pc_ena
end // always@clk
// 1xx = OFF
enable_out <= enable_in;
if (~pixel_in_ena || ~enable_in) begin
// disable output as not in display area or enable_in is LOW
end
else begin
case (GPU_HW_Control_regs[CTRL_BYTE_BASE + 0]) // select case based on video_mode HW_reg
2'h0 : begin // off
// disable output as turned off
enable_out <= 1'b0; // set enable_out LOW
end
2'h1 : begin // 1-bit (2 colour) - 8 pixels per byte
mode_16bit <= 1'b0; // set mode_16bit output to 8-bit mode
enable_out <= 1'b1; // set enable_out HIGH
end
else begin
end
end
2'h2 : begin // 2-bit (4 colour) - 4 pixels per byte
pixel_out[7:2] <= bg_colour[7:2];
case (x_in[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
2'h3 : begin // 4-bit (16 colour) - 2 pixels per byte
pixel_out[7:4] <= bg_colour[7:4];
if (x_in[3])
else
end
2'h4 : begin // 8-bit (256 colour) - 1 pixel per byte
end
2'h5 : begin // 16-bit (true colour)
mode_16bit <= 1'b1; // set mode_16bit output to 16-bit mode
end
2'h6 : begin // special colour text mode
end
else begin
end
end
endcase
end
end // always@clk
endmodule
Post by: nockieboy on December 11, 2019, 01:37:36 pm
Obviously, the case doesn't have any selects for the palette modes (0111-1010) yet - I assume that's correct and have left them out for the moment.
It's almost as if you're working to some kind of plan...  ;)
Post by: BrianHG on December 11, 2019, 01:54:26 pm
// inputs
input wire clk,
// outputs
// 0000 - Off
// 0111 - ARGB4444
// 1000 - RGB565
// *  PASS-THRUS                                                               *
x_out <= x_in;
end // pc_ena
end // always@clk
// 1xx = OFF
end
else begin
2'h0 : begin // off
end
end
else begin
end
end
case (x_in[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
if (x_in[3])
else
end
end
end
end
else begin
end
end
endcase
end
end // always@clk
endmodule
Dont forget to remove the bg_color input and make a bg_color and fg_color wires which are assigned to the adjacent HW_Register for the control mode.  Also, for now, make the default base address 16 decimal as we don't want to interfere with the first HV_Triggers.
Also, we never got into this, but, are you using little or big endian for your data in the Z80?  I don't know how the Z80 handles 16bit and 32bit math.  We may want to get this fixed now...
Post by: nockieboy on December 11, 2019, 02:04:58 pm
Little-endian.  But it's what you do with it that counts.  :-DD
EDIT:  In terms of 16-bit and 32-bit math, it doesn't really do a lot - it is capable of doing limited 16-bit math with the instruction set, but mostly it's up to the user to write routines that do anything more complicated than addition or subtraction of 16-bit numbers.
Post by: nockieboy on December 11, 2019, 02:22:10 pm
Done - although fg_colour isn't set up in the case yet, so I can only change the background colour.  Foreground is black, so I guess I need to replace all the pixel_out[7:4] assignments from 4'b0000 to fg_colour?
Post by: nockieboy on December 11, 2019, 04:36:33 pm
Fixed foreground (font) colour in 1-bit mode:
pixel_out <= fg_colour;
end
else begin
pixel_out <= bg_colour;
end
end
I figured that's how you planned on it working in 2-colour mode - there's either going to be the foreground or background colour, which the above case caters for.  I've removed the old byte-splitting and am just assigning the entire colour byte to the pixel output now, so it's 2-colour mode, from a palette of 256 colours.  Hope that's okay?
Post by: BrianHG on December 11, 2019, 05:08:35 pm
As I'm sure you know, this is important as it defines when you write or copy all these settings, right now, the lower memory address holds the MSB of a 16 bit or 32 bit number.  As you increase the memory address, you head toward the LSB.  So, I assume we are keeping this setup?
IE, you wont be using any compilers/interpreters which store 16bit ints backwards making this graphics card incompatible?
ANY other viewers with Z80 experience have any comments?
Post by: nockieboy on December 11, 2019, 06:43:41 pm
Hmm..  ???  This could be a bit of an issue if the conversion for little-endian to big-endian is done by the Z80 - it'll add processing overhead to any interactions with the GPU.
EDIT: Of course my suggestion to convert in the z80_bridge wouldn't work, as only 1 byte is written at a time by the Z80 so it would be impossible to work out if a 16-bit word is being written and thus needed to be reversed...
Post by: BrianHG on December 11, 2019, 06:56:18 pm
It's just 1 more thing I need to also consider.  What we might do is make an Invert feature on the LSB bit of the HW_Regs address input and only worry about the 16 bit ints.  Only the base address setting in the address generator is 24 bit and we can do the same invert with the palette memory reads easily enough.  As for the 16bit color raster graphics, we can use a spare bit in the video mode setting to swap the byte_in and byte_in_h.  This would be near all control register software select able, however, any 8 bit control settings will be swapped with their adjacent control settings.
Note that all 16 bit data, whether big or little endian will need to be 16 bit word aligned, as it is currently setup.
Post by: nockieboy on December 11, 2019, 08:39:32 pm
So that would just require a little adjustment of the documentation - instead of video_mode being at HW_REGS[16 + 0], it would be at HW_REGS[16 + 1]?  Ditto for each pair of bytes in memory?
Post by: BrianHG on December 11, 2019, 08:42:16 pm
Nope, if we are going to do it, it needs to be done right.  Otherwise, all your HW_Regs would begin on an odd address.  No future compatibility with a 16 bit processor as well.
Post by: nockieboy on December 11, 2019, 09:06:30 pm
Future compatibility is important too - no telling when I might get the urge to make a computer based on one of the 68010s I have in a box somewhere...  ???
Okay, so how hard is it going to be to do it right?  It affects any memory in the GPU (including the hardware registers) that the host system can access for a 16-bit value, but only when it accesses that memory using one of the (few) 16-bit opcodes - but they're useful for the kind of work I'd be doing here with graphics; lots of copying and moving data.  |O
Post by: BrianHG on December 11, 2019, 09:46:25 pm
Ok, the address generator's IOs.
1) inputs:
clk
pc_ena[]==0
all HW_regs
all HV_triggers
cmd_in[31:0]
2) outputs: (use all wires as we will embed the connected registers inside the module)
read_addr[19:0]
cmd_out[31:0]
bp_2_rast_cmd[23:0]
3) parameters:
HW_REG_BASE = #
H_RESET_TRIG = #
H_POS_TRIG    = #
localparam
V_RESET_TRIG = H_RESET_TRIG + 1
V_POS_TRIG    = H_POS_TRIG + 1
BP2RAST_cmd = HW_REG_BASE + 0   // transfers the video mode setting to the new bitplane_2_raster module
BP2RAST_bgc  = HW_REG_BASE + 1  // transfers the bg_color setting to the new bitplane_2_raster module
BP2RAST_fgc   = HW_REG_BASE + 2  // transfers the fg_color setting to the new bitplane_2_raster module
RST_ADDR_H  = HW_REG_BASE +      // MSB bits of 24 bit base read address
RST_ADDR_M  = HW_REG_BASE +      // MID bits of 24 bit base read address
RST_ADDR_L  = HW_REG_BASE +       // LSB bits of 24 bit base read address
YINC_ADDR_H = HW_REG_BASE +      // MSB bits of 16 bit Y-Line increment for read address
YINC_ADDR_L = HW_REG_BASE +      // LSB bits of 16 bit Y-Line increment for read address
X_SIZE_H = HW_REG_BASE +      // MSB bits of 16 bit display width screen pixels
X_SIZE_L = HW_REG_BASE +      // LSB bits of 16 bit display width screen pixels
Y_SIZE_H = HW_REG_BASE +      // MSB bits of 16 bit display height screen y lines
Y_SIZE_L = HW_REG_BASE +      // LSB bits of 16 bit display height screen y lines
X_SCALE  = HW_REG_BASE +      // Compound of two 4 bit words.  upper 4 bits controls the X increment every period, lower 4 bits is a pixel period counter to define the number of pixels until the upper 4 bits are added to the address-pointer.
Y_SCALE  = HW_REG_BASE +      // Compound of two 4 bit words.  upper 4 bits reserved for text tile mode Y size while the lower lower 4 bits is a line period counter to define the number of lines until YINC_ADDR is added to the address-pointer
X_START_SUB  = HW_REG_BASE +      //  An 8 bit word which defines an odd pixel start position within the period counter and X position within a bitplane's X coordinate position
Y_START_SUB  = HW_REG_BASE +      // An 8 bit word which defines and odd line start within within the period counter and Y coordinates inside a font.
Damn, we are at 20 control bytes per window, not 16...
This means 15 windows = 300 register control bytes.
We will stick with this for now as we only have 5 windows to worry about.
You will also need to take into account we are using other HV_Triggers, so assign you byte offseta around everything else.
Also, copy the current 'bitplane_to_raster' into a 'bitplane_to_raster_v2' as we will change the IO and depricate the old one soon.  In the new 'bitplane_to_raster_v2':
change '   .ram_byte_in' into 16 bit and get rid of '   .ram_byte_in_h'.
get rid of :
   .two_byte_mode( GPU_HW_Control_regs[11][0] ),
and make a inputs:
       .bp_2_rast_cmd[23:0]
       .cmd_in[31:0]
assignments:
assign colour_mode_in[7:0] = bp_2_rast_cmd[7:0]
assign bg_colour[7:0] =  bp_2_rast_cmd[15:8]
assign fg_colour[7:0] =  bp_2_rast_cmd[23:16]
assign window_enable = cmd_in[7]                      // used to be "pixel_in_ena"
assign x_in[4:0]         = cmd_in[4:0]
assign two_byte_mode = colour_mode_in[6]
More to come (window counter and scale in address generator)....
Post by: BrianHG on December 11, 2019, 09:47:22 pm
Don't worry, it will be a parameter thing, also with the Lattice part, you may embed a full 125MHz 68020 + FPU & add external DDR ram for main system memory.
Post by: nockieboy on December 11, 2019, 10:43:34 pm
Going to need a bigger FPGA!  The Lattice one is really looking like the best option - shame there's not a cheap(ish) dev board for it.
Question regarding this line:  Do you mean that because there's more than one MAGGIE, their offsets will need to take every other MAGGIE's HV_Triggers into account so they don't end up using the same ones?  I feel I'm getting confused between HV_triggers and HW_regs.  (It is late here though).
get rid of :
and make a inputs:
       .cmd_in[31:0]
assignments:
Apart from making the new inputs and assigns, most of those changes I'd already made, so that's good.  What's going to replace x_in, though?  I should also get rid of pixel_in_ena and pixel_out_ena as well?
Post by: nockieboy on December 11, 2019, 10:48:32 pm
Yeah, I could have done that with the Z80 as well - could have fit everything onto an FPGA, but that would have sidestepped the reason I started the project in the first place; to learn about electronics and how to build a computer 'the old fashioned way', soldering and designing PCBs etc.  Plus I didn't really know anything about FPGAs until about 2 months ago.  I must admit, it's really tempting to stick a whole load of stuff onto the FPGA, not just the GPU... I'm certainly keen to get a programmable sound generator on it, and it would be remiss of me not to include a PS/2 port for a keyboard and maybe even an SD card interface as well...  ;D
Post by: BrianHG on December 11, 2019, 11:06:56 pm
Now, more on the address generator.
Make the following regs
ram_read_pointer_y[19:0]
ram_read_pointer_x[23:0]
run_x
run_y
period_x[4:0]
period_y[4:0]
make the following assignments (don't forget to declare wires for new next names)
assign bp_2_rast_cmd[23:0] = { hw_regs[BP2RAST_fgc] , hw_regs[BP2RAST_bgc] , hw_regs[BP2RAST_cmd] }
assign x_rst         = HV_trig[H_RESET_TRIG]
assign xy_rst        = HV_trig[V_RESET_TRIG] && x_rst
assign v_trig        = HV_trig[V_POS_TRIG]
assign h_trig        = HV_trig[H_POS_TRIG]
assign window_enable = (HV_trig[H_POS_TRIG] || run_x) && run_y
assign cmd_out[7]    = window_enable  // commands the pixel/by/pixel window enable for the bitplane_2_raster module
assign cmd_out[6]    = 1'b0        // for now, disables the 2 byte color mode.
assign reset_addr[23:0]  = { hw_regs[RST_ADDR_H] , hw_regs[RST_ADDR_M] , hw_regs[RST_ADDR_L]  }
assign inc_addr_y[15:0]  = { hw_regs[YINC_ADDR_H] , hw_regs[YINC_ADDR_L] }
assign inc_addr_x[3:0]   =   hw_regs[X_SCALE][7:4]
assign read_addr[19:0]   = ram_read_pointer_x[22:3]
assign cmd_out[2:0]      = ram_read_pointer_x[2:0]   // commands the sub pixel X position for the bitplane_2_raster module
assign period_x[3:0]     = hw_regs[X_SCALE][3:0]
assign period_y[3:0]     = hw_regs[Y_SCALE][3:0]
assign period_x_rst[3:0] = hw_regs[X_START_SUB][3:0]
assign period_y_rst[3:0] = hw_regs[Y_START_SUB][3:0]
assign x_size[11:0]      = { hw_regs[X_SIZE_H][3:0], hw_regs[X_SIZE_L][7:0] }
assign y_size[11:0]      = { hw_regs[Y_SIZE_H][3:0], hw_regs[Y_SIZE_L][7:0] }
You got a killer, though a feature or 2 not yet implemented, starting here...
Post by: BrianHG on December 11, 2019, 11:15:50 pm
The raster HV_triggers are a set 48 of X&Y coordinates, 24 horizontal, 24 vertical, which pulse the 'HV_trigger' output wires when that pixel coordinate or line number has been reached on the screen.
Those 48 raster HV_trigger screen coordinate positions are stored in the bulk first 96 bytes of the GPU_HW_REGS.  This doesn't mean wan cannot use each reg for more than 1 thing, just that if it shares a HV_Trigger setting, writing 1 number there would alter one of the raster triggers as well as whatever else you are controlling.
Post by: BrianHG on December 11, 2019, 11:25:41 pm
get rid of :
and make a inputs:
       .cmd_in[31:0]
assignments:
x_in is now an internal wire and it has been assigned to a set of bits on the new cmd_in input port:
'assign x_in[4:0]         = cmd_in[4:0]', read code.
pixel_in_ena has been renamed to window_enable and is has been assigned to a cmd_in bit.  Read code.
pixel_ena_out, the one change I would make is rename it to 'window_ena_out' and keep it's same function.
Post by: BrianHG on December 11, 2019, 11:40:06 pm
How the address generator is wired and works:
The address generator takes a clk, pc_ena, HW_Regs & HV_Trigger inputs, plus a spare 32 bit cmd_in which will be used later.
It outputs a 24 bit control 'bp_2_rast_cmd[23:0]'  for it's mated 'bitplane_2_raster' module.
It also outputs a 20 address to go to it's mated read GPU memory address read port _#.
It also outputs a 32 bit cmd_out port which feeds the matching GPU multiport memory cmd_in_# port.
The new 'bitplane_2_raster' command module's new cmd_in port receives the cmd_out_# from the GPU multiport ram module which contains real-time pixel drawing instructions, like sub-x coordinates and window enable/disable functions.  In the next iteration, this output will also feed the next address generator's cmd_in & ram read address allowing font/tile graphics memory pointers.
Post by: nockieboy on December 12, 2019, 09:22:35 am
Latest versions of the two new modules attached.  :-+
Post by: BrianHG on December 12, 2019, 01:20:43 pm
#2, bitplane_to_raster_v2.v :
   input wire enable_in,   *** no longer in use.
   input wire [7:0]  GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)],   *** no longer in use
   output reg enable_out,  *** no longer in use, replaced by window_ena_out,
   output reg [7:0] pixel_out_h,      **** merge these 2 into 1 single pixel_out[15:0]
                                                        **** correct all the appropriate code below.
   output reg [9:0] x_out     **** not used
parameter CTRL_BYTE_BASE = 16;    **** no longer used
parameter HW_REGS_SIZE   = 8;     **** no longer used
wire [7:0] bg_colour = GPU_HW_Control_regs[CTRL_BYTE_BASE + 1];
wire [7:0] fg_colour = GPU_HW_Control_regs[CTRL_BYTE_BASE + 2];
***** get rid of the "  = GPU_HW_Control_regs[CTRL_BYTE_BASE + #]; " in both cases
assign two_byte_mode         = cmd_in[6];  **** obsolete, get rid
      window_ena_out   <= window_enable;   // pass pixel_ena through to the output
              **** this output is also dependent if the video mode is on or off
      enable_out       <= enable_in;    **** no longer used
***** fix...
Next, the maggie.v...
Post by: BrianHG on December 12, 2019, 01:50:30 pm
next: maggie.v.
parameter H_RESET_TRIG   = 4;
parameter H_POS_TRIG   = 6;
add a parameter:
RAM_READ_CYCLES = 3;
add a reg:
h_trig_delay[7:0]
add an assign under bp_2_rast...:
assign text_mode_master = hw_regs[BP2RAST_cmd][7]
change :
assign window_enable         = run_x && run_y;
add just above
h_rst                =    text_mode_master ? h_trig_delay[0] : h_trig_delay[RAM_READ_CYCLES];  // When in text mode, push the window left by 'RAM_READ_CYCLES' as it takes a second memory read to get the font image
And all the way at the bottom:
always @(posedge clk) begin
   if (pc_ena_in[3:0] == 0) begin
      h_trig_delay[7:0] <= { h_trig_delay[6:0] ,  h_trig };
         if ( xy_rst ) begin // equivalent to a vertical sync/reset
         end else if (x_rst) begin   // equivalent to a horizontal sync/increment
         end else begin
            snap to it....
         end // ~x_rst
   end // if (pc_ena_in[3:0] == 0)
end //@(posedge clk)
endmodule
Post by: nockieboy on December 12, 2019, 03:09:55 pm
***** fix...
Both of the above changes require an input that specifies the video mode.  This was specified in the HW_REGS, but we're not using those now - so what do I use in their place?
Post by: nockieboy on December 12, 2019, 03:19:28 pm
Latest updates to bart and maggie.
Post by: BrianHG on December 12, 2019, 05:34:19 pm
***** fix...
Tadaaaaaa:
assign colour_mode_in[7:0]   = bp_2_rast_cmd[7:0];
Line #63 > NO
window_ena_out   <= window_enable && (##);   // pass pixel_ena through to the output
Line #67 > Put this:
window_ena_out   <= 1'b0 ;
Line #78 > What?  Its window_ena_out.
Make it:
window_ena_out    <= 1'b0;            // set enable_out LOW
Line #84, 102, 134, 148, 157, 166> What?  Its window_ena_out.
Change these lines:
pixel_out[7:4] <= fg_colour[7:4];
pixel_out[3:0] <= font_color[7:4];
end
else begin
pixel_out[3:0] <= font_color[3:0];
Add an assign and wire at the top of the code:
assign  font_color[7:0] = cmd_in[15:8]
************* ALSO,
What's with all the case 2'h# ?  2 bits?  When you are going up to over 5 or more cases?
Also, try to keep the pixels per byte in the mode numbers constant for the least significant bits.
IE:
00 = 8 pixels per byte
01 = 4 pixels per byte
10 = 2 pixels per byte
11 = 1 pixel per byte.
Use the next bit to the left for 16 bit modes on and off, also adhering to the first 2 bits pixels per byte.
Use the next bit over for video window mode ON/OFF.
We need the first 2 bottom bits to always reflect the 8pixels, 4pixels, 2 pixels, 1 pixels as 'MAGGIE' also uses these same 2 bits to know how fast to increment the memory read address.  IE, 1 inc per pixel, 1 inc every 2 pixels, 1 inc every 4 pixels, 1 inc every 8 pixels.  If you break this rule in the bitplane_2_raster module settings, the 2 modules will never sync pixel with memory.
Post by: nockieboy on December 12, 2019, 05:46:19 pm
Tadaaaaaa:
Line #63 > NO
Okay, the ## was there because I didn't know what signal to use.  Now I know it's colour_mode_in, would this work?
window_ena_out <= window_enable && colour_mode_in; // pass pixel_ena through to the output[/quote]
The idea being that if colour_mode_in is anything other than zero (off), and window_enable is high, then window_ena_out should be high?
************* ALSO,
Well spotted.  :-+
Post by: BrianHG on December 12, 2019, 05:58:58 pm
Tadaaaaaa:
Line #63 > NO
Well spotted.  :-+
Nope, do it as I said.
     The colour_mode_in is an 8 bit number, and if you read my text further, I want the bottom 2 bits of that variable to reflect specifically the number of pixels per byte.  This means having a color mode 0 = 1 byte to 8 pixels, usually text mode.
     The next bit#3 is the count of bytes per pixel, IE 16 bit color modes.  BUT YOU must keep the pattern of the 4 possible "pixels per byte".  The bit #4 will enable/disable the window completely.  We need a 'HARD' window disable setting since the layer may be active for font/tile mode, but the data coming through is the font's address data, not to be display.  That return data goes to the next line generator ad fed through to memory a second time then to that bitplane_2_raster module where that one will be enabled to generate an image.
Post by: BrianHG on December 12, 2019, 06:50:42 pm
This should help.  it is the internal full GPU MAGGIE wiring layout:
[attachimg=1]
Once the MAGGIE is complete and pair's with the previous MAGGIE for tile text support, there will be no other code inside the vid_osd_generator other than wires between the first 4 modules in the image.  All that obsolete code with delays and reg delays making the current ascii text function will be erased and forgotten.
The only 1 remaining delay code will be the HS,VS,HDE, & VDE which need compensation for the number of pixel cycles the pipe you see above takes to generate the first pixel.
Post by: nockieboy on December 12, 2019, 07:35:22 pm
Tadaaaaaa:
Line #63 > NO
Well spotted.  :-+
I thought I was going mad, then I went back to look at your previous post and you'd edited in the extra information below!
IE:
And there I was thinking I was going mad as I was unaware of this info when I wrote my reply..   |O
I'm a tad confused though - if bit 2 determines 16-bit mode, what value of colour_mode_in equates to the special colour text mode?  It's marked as an 8-bit mode in the comments, but there aren't enough bits unless I move everything left one bit and use bit 3 to increase the number of modes to 8?
Currently I've got:
000 - 1-bit mode
001 - 2-bit mode
010 - 4-bit mode
011 - 8-bit mode
111 - 16-bit mode
I'm using bit 4 for on/off:
if (~window_enable | ~colour_mode_in[4]) begin
pixel_out <= 16'b0000000000000000;
end
So bit 3 is free, but you state that's for bytes per pixel?
Post by: BrianHG on December 12, 2019, 07:52:49 pm
Currently I've got:
000 - 1-bit mode
001 - 2-bit mode
010 - 4-bit mode
011 - 8-bit mode
111 - 16-bit mode
end
bit 3 is 16 bits per pixel, ie 111
Mode
111 - 16-bit mode
but you are missing
100 - 16 bit text mode, ie 1 byte = 8 pixels.  This one uses the upper part of the byte, [15:12] for the bottom bits of the foreground color and [11:8] for the background color while the upper 4 bit palette bits still use the fg_colour and bg_colour.
101 - 16 bit mode with a 2 bit color pixel, ie 2 bits per pixel, and the upper color bits come from the upper ram byte[15:10], IE used in fonts with 4 colors per pixel.  (heheheh - the byte[9:8] allow addressing a 1024 character font, 8x8 pixel or 1024 tiles)
110 - 16 bit mode with a 4 bit color pixel, ie 4 bits per pixel, and the upper color bits come from the upper ram byte[15:12], IE used in fonts with 16 colors per pixel. (heheheh - the byte[11:8] allow addressing a 4096 character font, 4x8 pixel or 4096 tiles for display with 16 color pixels spread across 16 positions in a 16 color palette.  Imagine what you can do with that.)
bits 0,1 are the bitplane depth, bit 2 is the 16bit wide source data, bit 3 is enable/disable, bits 4 are for the new output mode_565.
Also add an output wire to the bitplane_2_raster:
mode_565
and assign it
assign  mode_565 = colour_mode_in[4];
Also, take a look at the upper image again, I just forgot to add a feedback green signal for the MAGGA when in tile/font mode.
Add an input wire to the MAGGIE:
ram_din[15:0]
Post by: nockieboy on December 12, 2019, 08:36:28 pm
Mode
111 - 16-bit mode
but you are missing
I'm having a complete brain fart setting these modes up.  I've read and re-read what you've written, but I'm still not 100% certain on what to do.   :-[  I've done what I can to the best of my understanding, but 110 (16-bit, 4 bits per pixel) is incomplete and I've probably messed-up on the other 16-bit modes as well.  Take a look at the attached files - they have all the changes you've mentioned so far, but these 16-bit modes are testing my focus tonight.  :(
Yep, understand that now.  Have corrected line 69 in the BitplAne_to_RasTer module to use bit 3 instead of 4.
if (~window_enable | ~colour_mode_in[3]) begin
end
mode_565
and assign it
Done.  :-+
ram_din[15:0]
That image makes it all much easier for me to visualise - thanks for that.  ;D
Post by: BrianHG on December 12, 2019, 08:56:39 pm
Ooyoyoy...
ok, 1:
3'b100 : begin // 16-bit text mode - 8 pixels per word
mode_16bit <= 1'b0; // I know this is weird, the 16 bit mode is reserved for turning off the palette and passing 16 bits straight to the DAC
window_ena_out <= 1'b1; // set enable_out HIGH
pixel_out[3:0] <= font_color[7:0];
pixel_out[7:4] <= fg_color[7:4];
end
else begin
end
next:
3'b101 : begin // 16-bit text mode - 4 pixels per word
pixel_out[7:2] <= font_color[7:2];
case (x_in[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
and:
pixel_out[7:4] <= font_color[7:4];
if (x_in[3]) *********************** 3, again????? it should be 2!!! ALSO ~x_in[2] or swap the ram_byte_in to look like the above code.
else
end
And also line 138:
get rid of lines 230-246.
Post by: nockieboy on December 12, 2019, 11:09:16 pm
A tad confused by the code you've posted...  Specifically blocks 2 and 3???
next:
case (x_in[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
and:
else
end
Is it me, or do they have exactly the same first line?  (The select case - both are 3'b101 with the same comment??)
I've put the third block of code (or the second one above) in as 3'b110 and kept the comment name for it - 16-bit 4-bit colour pixel - 4 bits per pixel.
And also line 138:
I've changed x_in[3] to [2] on line 212 (see the attached updated BART module below) and swapped the ram_byte_in order in the if...else - hopefully that's right now?
Post by: BrianHG on December 12, 2019, 11:42:37 pm
Sorry, copy and paste error...
Only 1 mistake, again my error.  Line 160 should read this:
Everything else looks good.
Wire the current MAGGIE and BART into memory channel 3, as per diagram, and wire the bottom 8 bits of the 16 bit BART output into 'pixel_out_top_h' which you should rename to 'gfx_pixel[7:0] for now and feed it into the palette gfx_pixel input.  On the current OSD text generator, don't for get to erase the current 'pixel_out_top_h'.
This should be enough to develop the MAGGIE code.
(This is a lot of work, isn't it?)
Post by: nockieboy on December 13, 2019, 08:52:22 am
Stupid question time:  where/how am I instantiating MAGGIE?  I'm guessing this will be done in the existing video_osd_generator module and connected up to port 3 of the multiport_gpu_ram instance via wires?  What happens to the old outputs from the video_osd_generator?  Seems I've got some gutting to do with the video_osd_generator's internals?
Post by: BrianHG on December 13, 2019, 09:19:54 am
Not yet.  Read the text.  The BART output feeds the GFX input in the palette mixer module.  Look at the top hierarchy of your project.  You made a mistake.  You were feeding the GFX input of the palette mixer the OSD text 'pixel_out_top_h'.  That supposed to be the output of the new BART's 'pixel_out' bottom 8 bits.
The gutting will only take place once the MAGGIE can produce ASCII text.  We got a way to go.
Post by: nockieboy on December 13, 2019, 09:53:09 am
I've tried to update the symbol file for the vid_osd_generator due to the IO port name change etc suggested above, but am getting this error:
Error (10703): SystemVerilog error at vid_osd_generator.v(133): can't resolve aggregate expression in connection to port 8 on instance "b2r_1" because the instance has no module binding
It relates to this line in vid_ost_generator.v:
.GPU_HW_Control_regs(GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)]),
I can't seem to find the issue - bitplane_to_raster.v is present in the project.  :-//
I've resolved quite a few variable-name errors in MAGGIE too, but as I can't get vid_osd_generator to build at the moment, I'm relatively stuck in trying to make the wiring changes.
Post by: BrianHG on December 13, 2019, 10:03:01 am
That isn't the error I'm getting:
[attach=1]
Choose now, American, or European English...
There is a lot more of 1 or the other out there, you might have to go through all the modules.
Post by: BrianHG on December 13, 2019, 10:16:32 am
After changing the 'color' issue, it compiles fine.  Yet, you haven't inserted the new MAGGIE & BART yet.
Post by: nockieboy on December 13, 2019, 10:18:21 am
(Attachment Link)
That's odd - I'm not getting any of those errors (I'm compiling in Quartus Prime).  I 'translate' your code into UK English as I enter it, so there shouldn't be any 'color' spellings in the code?
One change I had made was to rename bitplane_to_raster_v2.v to bart.v.  I've removed the old bitplane_to_raster_v2.v file from the project.  Neither maggie.v or bart.v are referenced in the project code yet, so they're just 'sitting' there in the file list in the project but are still getting compiled, of course.
[attachimg=1]
Above error relates to this line of code in maggie.v:
h_trig_delay[7:0] <= { h_trig_delay[6:0],  h_trig };
EDIT: Changed it to this:
h_trig_delay[7:1] <= h_trig_delay[6:0];
h_trig_delay[0] <= h_trig;
... and then got the 'color' errors in bart...  :palm:  Compiles now.  :phew:
Post by: BrianHG on December 13, 2019, 10:31:00 am
So, where are we at?
Post by: nockieboy on December 13, 2019, 10:35:02 am
[attachimg=1]
Back to here again.  I'm ignoring this error for now as I presume we're removing the old bitplane_to_raster module and replacing it with bart.  Just working on those changes at the moment.
Post by: BrianHG on December 13, 2019, 10:40:38 am
Give me you project .zip, because mine compiles.
Post by: nockieboy on December 13, 2019, 10:57:00 am
It compiles now for me too - but only once I removed the instantiation of the old bitplane_to_raster.  I've removed it from the project files now and all compiles well.  I'm just in the process of finishing up the bart connections and instantiating maggie.
Post by: BrianHG on December 13, 2019, 11:08:20 am
What did you do?
You need both barts, the old for the existing text and the new for the graphics layer with maggie.
The new bart isn't compatible with the old text generator.  Or at least, I never thought about doing that.
Post by: nockieboy on December 13, 2019, 11:15:16 am
[attachimg=1]
Still getting this error now I've added the HW_regs inputs - it's not happy with this line in the instantiation of bart OR maggie:
Post by: BrianHG on December 13, 2019, 12:02:58 pm
How do you keep on making multiple changes to multiple working modules at multiple times?
Here is the functional original 'bitplane_to_raster.v'
// inputs
input wire clk,
// outputs
// *  PASS-THRUS                                                               *
if (pc_ena[3:0] == 0) begin
x_out <= x_in;
end // pc_ena
end // always@clk
// 1xx = OFF
end
//pixel_out[4] <= 1'b1; // changed for new palette_mixer module
end
else begin
//pixel_out[4] <= 1'b0;
end
end
case (x_in[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
if (x_in[3])
else
end
end
endcase
end // 8-bit mode
end
else begin
end
end
end
endcase
end // 16-bit mode
end // always@clk
endmodule
Here is the original working initiation of that module:
bitplane_to_raster b2r_1(
.clk(clk),
.pc_ena(pc_ena[3:0]),
// inputs
.pixel_in_ena(pixel_ena),
.ram_byte_in(char_line),
.ram_byte_h(8'b00000000),
// outputs
.pixel_out_ena( pixel_out_ena ),
.mode_16bit( pixel_out_top_16bit ),
.pixel_out( pixel_out_top ),
.pixel_out_h( pixel_out_top_h ),
.x_out(), // disconnected for moment
.colour_mode_out() // disconnected for moment
Now, we are left with you error on MAGGIE when " Creating Symbol Files For Current File " :
It's a Quartus bug, or we just don't have the ' Perfect Syntax '  Quartus is expecting.
Temporarily change the line to:
.hw_regs( GPU_HW_Control_regs[2**HW_REGS_SIZE] ),
Then 'Creating Symbol Files For Current File'.
Then change the line back to:
.hw_regs( GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)] ),
Then compile the project.
In maggie, all these are wrong:
// registers
reg ram_read_pointer_y[19:0];
reg ram_read_pointer_x[23:0];
reg period_x[4:0];
reg period_y[4:0];
reg h_trig_delay[7:0];
The [#:#] belongs on the left side when defining a reg.  The right side is to define an array size.
I'm going to check what's up with Quartus not liking the 'regs[0:(2**HW_REGS_SIZE-1)] ' inside a function, but my trick listed above for now will work.
Post by: BrianHG on December 13, 2019, 12:34:15 pm
Found the Quartus bug,
Rename the MAGGIE.v to MAGGIE.sv
Rename the vid_osd_generator.v to vid_osd_generator.sv
Then everything works including create symbols.
Post by: nockieboy on December 13, 2019, 12:47:45 pm
Well done.  It compiles!  ;D
Post by: nockieboy on December 13, 2019, 12:51:22 pm
Do we need to make some changes to the palette_mixer now?  Your diagram shows:
as outputs from BART to the Palette_Mixer, but the existing palette_mixer module has no matching inputs.
Post by: BrianHG on December 13, 2019, 01:03:07 pm
  • window_ena_out
  • mode_16_bit
  • mode_565
  • pixel_out
Next week, for now, just feed 8 bits of the current pixel out.
Post by: BrianHG on December 13, 2019, 01:08:10 pm
Did you check for a picture?
Post by: nockieboy on December 13, 2019, 01:12:58 pm
Okie dokie, well that seems to be working okay.  Has gone back to the old way of setting colours via HW_REGS[10].
Post by: BrianHG on December 13, 2019, 01:19:30 pm
Arrrg, again, why?
Line 225 in vid_osd_generator:
      gfx_pixel <= pixel_out[7:0];
Erase that line!!!
Line 190:
   .pixel_out( pixel_out ),
Change that to :
.pixel_out( gfx_pixel ),
Lines 18 through 22:
   output reg osd_ena_out,
   output reg window_ena_out,
   output reg pixel_out_top_16bit,
   output reg [7:0] pixel_out_top,
   output reg [7:0] gfx_pixel,
Are all supposed to be 'WIRE', though except for the gfx_pixel fiasco, quartus automatically converted them to wires when compiling.
Post by: nockieboy on December 13, 2019, 01:35:01 pm
All sorted, image is good.  :-+
Post by: BrianHG on December 13, 2019, 03:58:16 pm
Here we go.
In that attached files, you have:
GPU_256char_font_MAGGIE_beta.zip    -> With a rudimentary MAGGIE address generator & other bug patches.
RS232_Debugger_Quick_file_MAGGIE_test.zip -> Quick load binary files which setup & turn on the new MAGGIE.
Changes I made to 'GPU_256char_font'.
1. Fixed a bug in the palette_mixer module.
    I for some reason had to assign the wire 'alpha_blend' to an 'integer' which I called blend.  This was connected with the '* (15-alpha_blend[3:0])' bug from a few days ago.  The multiply function seems to want an 'integer' in the math, otherwise it returns a '0' which made the second line on the mixer which didn't have the '15-' return a black image.
2.  Changed the 4444 text layer palette's .mif so that color 1, blue, is now semi translucent to the graphics layer below.  Color 0, black, is fully transparent.
3.  Changed the 565 palette's .mif so that color 255 is now white instead of black.
4.  Removed all the yellow H&V_Trigger cursors except for the first 4 of them.
5.  Added a code making rudimentary MAGGIE address generator:
    a) Moved the H&V resets to HV_trigger to 8, address 0x3F10, 0x3F12.             (do not touch)
    b) Moved the H&V window starting HV_trigger to 10, address 0x3F14, 0x3F16 (you can play with these)
    c) Base address 0x3F60 begins the MAGGIE controls.
        keep the BP2RAST setting the same
        play with RST_ADDR, YINC_ADDR, X_SIZE, Y_SIZE.  These are the only variables which function.
For now, use 8 bit color setting.
HV_trigger 10/11 tells MAGGIE where to position the top left coordinates of the window.
X_SIZE & Y_SIZE tells MAGGIE how many pixels wide and tall it's open window will be on the screen.
RST_ADDR tells MAGGIE the beginning byte position of the source bitmap graphics data.  You can write to this setting to also scroll horizontally and vertically the shown bitmap graphic inside the open window.
YINC_ADDR tells MAGGIE the width of the source bitmap graphics data in bytes.
Give me a report.
Post by: nockieboy on December 13, 2019, 08:22:37 pm
Hmm.. okay, so I've downloaded the project, compiled and flashed it to the FPGA and downloaded and loaded the binaries into RS232_debugger.  This is what I'm getting:
[attach=1]
I'm able to move it around, resize the overlay window etc. but I can't get a sensible image out of the overlay.  I haven't changed anything, I've just copied the project into a new folder and compiled it in Quantus Prime.  :-//  Also, it seems both quick binaries for the RS232_debugger are identical?
Post by: BrianHG on December 13, 2019, 09:04:52 pm
(Attachment Link)
Did you program a paint software to draw in there?
Do you have the ram for a 256x256 pixel, 8 bit image?
Your looking at the existing ram contents being fed through the palette.
Play with the controls I listed...
Ok, maybe, first, you should add the the MAGGIE support for different bitplane sizes.  This way, in 1 bit color, you could render the font in memory into the sprite if you made it 8 pixels wide with a 1 byte width setting for the graphics.
Looking at the code I sent you, and knowing where the pixels / bits setting is stored, show me how you would modify my MAGGIE code to recognizes the different bitplane modes horizontal sizes.
Yes, both quick binaries are identical.
Post by: BrianHG on December 13, 2019, 09:57:20 pm
Grrr, line 141 in bart.v reads:
               if (x_in[3])
Take a look at line 215...  You know what is should be...
also, lines 142 & 144 are backwards....
See lines 216 & 218...
Post by: BrianHG on December 13, 2019, 10:07:19 pm
Here are 2 different quick save files for when you get the MAGGIE to respond to the 'color depth'.
This time, they are both different.
You only need to modify 1 key line in the MAGGIE to get the pixels / bits setting to work.
I also recommend making a new wire called 'pixel_per_byte[1:0]' and assign it to the right place.
Post by: nockieboy on December 14, 2019, 11:15:34 am
(Attachment Link)
Not yet... I'd just assumed that there would be something meaningful in there as I could see a pattern of sorts, it was just out of phase.
No - I've only got 33KB to play with in total on this Cyclone IV EP4CE6 FPGA.
I'm considering designing and building a dev board for the Lattice LFE5U FPGA as there doesn't seem to be many cheap ones about (or many about at all - I found one that doesn't look great) - it would be a good practice run before starting on the GPU card build and if I slap an ADV7125 in there, I could have 24-bit VGA output to test with too.  Does anyone know of or have schematics with basic circuits to support an LFE5U FPGA?  Might start another thread on that question.  Obviously, a head start before I dive into the datasheets would speed up development.
Let me get back to you on this one.  Busy day today and I'm going to need a clear block of time to look at the code and concentrate.
Post by: nockieboy on December 14, 2019, 11:42:50 am
Is this line right?
wire [1:0]  pixel_per_byte;
assign pixel_per_byte = BP2RAST_cmd[1:0]; // bitplane setting equates to pixels per byte (0 = 1, 1 = 2, 2 = 4, or 3 = 8)
Post by: BrianHG on December 14, 2019, 03:41:11 pm
Yes.  Now make the address generator count at the right speed according to the setting.
Study my code carefully how I assigned the wiring around of the counters and how I am accumulating the address position.
It's 1 line to edit with only a 1 new term to get it working.
You will know it's working if 1 of the new quick save file generates a meaningful image.
Post by: nockieboy on December 14, 2019, 06:54:15 pm
Okay, I've had 10 minutes to look at this, so don't be too critical.  This is what I've come up with:
So now pixel_per_byte relates directly to the current mode.  Further down, in the always @(posedge clk) block, I've tweaked the ram_read_pointer_x increment to be sensitive to the current mode:
if (run_x) begin
width <= width - 1;
ram_read_pointer_x <= ram_read_pointer_x + 2**pixel_per_byte;
end
So ram_read_pointer_x is incremented by 1 bit in mode 0, 2 bits in mode 1, 4 bits in mode 2 and a byte in mode 3, instead of just being incremented by a byte each time previously.  This results in the following output based on the two binaries you supplied:
[attach=1]
Looking good so far.  8)
[attach=2]
Oh shazbut.  |O
Not sure what I'm doing wrong, I thought I'd got it in the bag...  :-[
Post by: BrianHG on December 14, 2019, 09:21:42 pm
Nope, you did great.  I also would have accepted:
ram_read_pointer_x <= ram_read_pointer_x + ( 1 << pixel_per_byte );
So, you truly need me to prepare graphics...
Maybe on Sunday.
Next, X - Zoom, or scale.  Also known as X period or horizontal period.
The setting is stored in ' period_x[3:0] '.
The goal, when 'period_x[3:0]' = '0', the picture you get should be the same.
When 'period_x[3:0]' = '1' then the picture should be twice as wide, or, every X pixel is repeated twice.
When 'period_x[3:0]' = '2' then the picture should be 3 times as wide, or, every X pixel is repeated 3 times.
When 'period_x[3:0]' = '3' then the picture should be 4 times as wide, or, every X pixel is repeated 4 times.
When 'period_x[3:0]' = '7' then the picture should be 8 times as wide, or, every X pixel is repeated 8 times.
You get the idea.
Around 3 controls left, then some fancy manipulation to get the text working.
Now you understand the text you saw was only a sprite set to 8 pixels wide, 1 bit color, 1 byte per line and 32 lines tall pointing to the letter 'A' in the GPU ram's current font.  You could play with the base address to vertically shift the image to a new letter, or, increased the size of the window to show more letters as the font is stored vertically, all 256 characters in 1 straight line.
You also could adjust the bg_ & fg_ color to your liking, or, try 4 color mode messing up the graphic, but you would recognize a font squeezed half-width as 2 bits now generate 1 4 colour pixel.  Also, now, the bg_color now would select which 4 colors in the palette would be used for those 4 possible colors.
Post by: nockieboy on December 15, 2019, 12:43:56 pm
Ah of course - didn't think about bit-shifting.  :)  I guess the hardware output would be the same and there's no performance penalty for squaring instead of bit-shifting?
You get the idea.
Okay, not such a simple solution for X-scaling.  I'm sure it's not the most efficient way of doing it, but here's my solution:
wire [7:0]  width_count;   <----- new wire
if (run_x) begin
if (period_x[3:0] == width_count) begin
width <= width - 1;
width_count <= 0;
end
else begin
width_count <= width_count + 1;
ram_read_pointer_x <= ram_read_pointer_x;
end
end
width_count is zeroed in the xy_rst, x_rst and h_rst if... blocks as well.  Full project attached below.
Here's a screenshot of a pixel scaled to 8x width:
[attachimg=2]
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: nockieboy on December 15, 2019, 02:18:44 pm
Okay, so I've pushed on a little further and implemented the Y-scale function as well.  :-/O
[attach=1]
Nice 8x8 scaling on the original sprite.  ^-^
Again, don't know if I'm using the optimal method to scale the sprite, but I've attached the updated MAGGIE code.  :-+
Post by: BrianHG on December 15, 2019, 04:42:06 pm
Have you tried moving the text around inside a zoomed box with and without the original 'Y' code, taking care of the source read address, you will see a little problem...
Are you sure your width and height is correct ad 1x and 2x zooms?
Is the right read address getting through?
Change the base memory address to 0x0B10 & 0x0B00.  Move it up and down 1 or 2 at different Y zoom levels 0 & 1.  Something is off.
Your top line of the font is off by 1 byte as 0x0B0F renders the beginning of the character properly.  And when zoomed, vertically to 1, you are also 1 line short at the bottom of the image.  In fact, at all zoom levels above 0, you are missing 1 line at the bottom.
(I counted using the test vertical bar cursor at address 0x3F03)
Post by: nockieboy on December 15, 2019, 06:01:40 pm
Thought I was doing too well.  :-\
I've been staring at the code for the last 30 minutes and, short of randomly moving stuff about to test the results, I don't think I'm likely to spot the problem any time soon.  :-//
One thing I've found is that it's missing the first line even without the Y-scale code changes.
Is it because width[] and height[] are registers, and thus are a clock behind?
Post by: BrianHG on December 15, 2019, 06:55:55 pm
Ok, lets see if I can help you out of this one...
Read my attached code carefully and compare the changes I made compared to yours.
Also read the comments I added.
// *  Multiple Address Generator & Graphics Instruction Engine  *
module maggie (
//inputs
input wire clk,
input wire [3:0]  pc_ena_in,
input wire [7:0]  hw_regs[0:(2**HW_REGS-1)],
input wire [47:0] HV_trig,
input wire [31:0] cmd_in,
input wire [15:0] ram_din,
//outputs (all wires as we will embed the connected registers inside the module)
output wire [19:0] read_addr,
output wire [31:0] cmd_out,
output wire [23:0] bp_2_rast_cmd
// parameters
parameter HW_REGS = 8;
parameter HW_REG_BASE = 96;
parameter H_RESET_TRIG = 8;
parameter H_POS_TRIG = 10;
parameter RAM_READ_CYCLES = 3;
// local parameters
localparam V_RESET_TRIG = H_RESET_TRIG +  1;
localparam V_POS_TRIG = H_POS_TRIG +  1;
localparam BP2RAST_cmd = HW_REG_BASE +  0; // Transfers the video mode setting to the new bitplane_2_raster module
localparam BP2RAST_bgc = HW_REG_BASE +  1; // Transfers the bg_colour setting to the new bitplane_2_raster module
localparam BP2RAST_fgc = HW_REG_BASE +  2; // Transfers the fg_colour setting to the new bitplane_2_raster module
localparam RST_ADDR_H = HW_REG_BASE +  3; // MSB bits of 24 bit base read address
localparam RST_ADDR_M = HW_REG_BASE +  4; // MID bits of 24 bit base read address
localparam RST_ADDR_L = HW_REG_BASE +  5; // LSB bits of 24 bit base read address
localparam YINC_ADDR_H = HW_REG_BASE +  6; // MSB bits of 16 bit Y-Line increment for read address
localparam YINC_ADDR_L = HW_REG_BASE +  7; // LSB bits of 16 bit Y-Line increment for read address
localparam X_SIZE_H = HW_REG_BASE +  8; // MSB bits of 16 bit display width screen pixels
localparam X_SIZE_L = HW_REG_BASE +  9; // LSB bits of 16 bit display width screen pixels
localparam Y_SIZE_H = HW_REG_BASE + 10; // MSB bits of 16 bit display height screen y lines
localparam Y_SIZE_L = HW_REG_BASE + 11; // LSB bits of 16 bit display height screen y lines
localparam X_SCALE = HW_REG_BASE + 12; // Compound of two 4 bit words. Upper 4 bits controls the X increment every period, lower 4 bits is a pixel period counter to define the number of pixels until the upper 4 bits are added to the address-pointer.
localparam Y_SCALE = HW_REG_BASE + 13; // Compound of two 4 bit words. Upper 4 bits reserved for text tile mode Y size while the lower lower 4 bits is a line period counter to define the number of lines until YINC_ADDR is added to the address-pointer
localparam X_START_SUB = HW_REG_BASE + 14; // An 8 bit word which defines an odd pixel start position within the period counter and X position within a bitplane's X coordinate position
localparam Y_START_SUB = HW_REG_BASE + 15; // An 8 bit word which defines an odd line start within within the period counter and Y coordinates inside a font.
// registers
reg [19:0] ram_read_pointer_y;
reg [23:0] ram_read_pointer_x;
reg [4:0] period_x;
reg [4:0] period_y;
reg [7:0] h_trig_delay;
reg [11:0] width;
reg [11:0] height;
wire run_x;
wire run_y;
assign run_x = width[11];
assign run_y = height[11];
// wires
wire h_rst, x_rst, xy_rst;
wire h_trig, v_trig;
wire window_enable;
wire [23:0] reset_addr;
wire [15:0] inc_addr_x;
wire [15:0] inc_addr_y;
wire [3:0]  period_x_rst;
wire [3:0]  period_y_rst;
wire [11:0] x_size;
wire [11:0] y_size;
wire [7:0]  height_count;
// assignments
assign bp_2_rast_cmd[23:0] = { hw_regs[BP2RAST_fgc] , hw_regs[BP2RAST_bgc] , hw_regs[BP2RAST_cmd] };
assign text_mode_master = hw_regs[BP2RAST_cmd][7];
assign x_rst = HV_trig[H_RESET_TRIG];
assign xy_rst = HV_trig[V_RESET_TRIG] && x_rst;
assign v_trig = HV_trig[V_POS_TRIG];
assign h_trig = HV_trig[H_POS_TRIG];
assign h_rst = text_mode_master ? h_trig_delay[0] : h_trig_delay[RAM_READ_CYCLES-1];  // When in text mode, push the window left by 'RAM_READ_CYCLES' as it takes a second memory read to get the font image
assign cmd_out[7] = window_enable; // commands the pixel/by/pixel window enable for the bitplane_2_raster module
assign cmd_out[6] = 1'b0; // for now, disables the 2 byte colour mode
assign reset_addr[23:0] = { hw_regs[RST_ADDR_H] , hw_regs[RST_ADDR_M] , hw_regs[RST_ADDR_L]  };
assign inc_addr_y[15:0] = { hw_regs[YINC_ADDR_H] , hw_regs[YINC_ADDR_L] };
assign inc_addr_x[3:0] = hw_regs[X_SCALE][7:4];
assign read_addr[19:0] = ram_read_pointer_x[22:3];
assign cmd_out[2:0] = ram_read_pointer_x[2:0]; // commands the sub pixel X position for the bitplane_2_raster module
assign period_x[3:0] = hw_regs[X_SCALE][3:0];
assign period_y[3:0] = hw_regs[Y_SCALE][3:0];
assign period_x_rst[3:0] = hw_regs[X_START_SUB][3:0];
assign period_y_rst[3:0] = hw_regs[Y_START_SUB][3:0];
assign x_size[11:0] = { hw_regs[X_SIZE_H][3:0], hw_regs[X_SIZE_L][7:0] };
assign y_size[11:0] = { hw_regs[Y_SIZE_H][3:0], hw_regs[Y_SIZE_L][7:0] };
      if (xy_rst) begin // equivalent to a vertical sync/reset
height             <= 0;
width_count <= 0;
height_count <= 0;
end
width <= 0;
width_count <= 0;
if (v_trig) begin              // V_TRIG is high for the entire first line of video to be displayed.  This is the point in place and time where the read address must be equal to the setting in the reset_addr.
height[11]   <= 1;      // set run_y bit active
height[10:0] <= y_size[10:0];
height_count <= 0;     // * must reset as well.
ram_read_pointer_y <= reset_addr << 3;  // V_TRIG is high during the first active line of video, set the read pointer, both
ram_read_pointer_x <= reset_addr << 3;  // the backup and currrent display address to the exact reset base address during this line.
end // V_TRIG
else begin  // ~V_TRIG
if (run_y) begin                // after the first line, do these functions.
if (period_y[3:0] == height_count) begin   // If the vertical scale period count has reached it's end
height <= height - 1;                  // count down the visible window size
height_count <= 0;                     // reset the vertical period
ram_read_pointer_y <= ram_read_pointer_y + (inc_addr_y[15:0] << 3);  // vertical increment display position in backup buffer
ram_read_pointer_x <= ram_read_pointer_y + (inc_addr_y[15:0] << 3);  // vertical increment display position in current display address
end // (period_y[3:0] == height_count
else begin                                // if the period count hasn't reached it's end,
height_count <= height_count + 1;  // increment the period count
ram_read_pointer_x <= ram_read_pointer_y; // restore the memory read address to the previous backup buffer address
end
end // ~V_TRIG
end
      end
else begin
if (h_rst) begin
width[11]   <= 1;       // set run_x bit active
width[10:0] <= x_size[10:0];
width_count <= 0;
end
if (run_x) begin
width <= width - 1;
width_count <= 0;
end
else begin
end
end
         //snap to it....
      end // ~x_rst
endmodule
Post by: BrianHG on December 15, 2019, 07:02:38 pm
Next, we want to shift the horizontal position within the sprite/window by a sub-bitplane-pixel.
This means shift the text image in the window to the left by 1 pixel at a time.
This figure is stored inside the 'period_x_rst'
Please do not touch the 'period_y_rst' as this has specifically to do with rendering tiles/fonts on the 'Y' axis.  We have 2 other variables to do first, then we need to gut the old OSD text and wire in the new MAGGIE in it's place before you can edit this last variable of the MAGGIE.
Post by: BrianHG on December 15, 2019, 08:57:14 pm
I cannot find a .pal or .act file of the VGA palette which I need to properly convert some bitmap files using photoshop.
If I convert an image using a different palette, you will need to edit the 565.mif file to see the image properly.
Post by: BrianHG on December 16, 2019, 01:28:38 am
Another mistake, this line should read:
assign pixel_per_byte = bp_2_rast_cmd[1:0]; // bitplane setting equates to pixels per byte (0 = 1, 1 = 2, 2 = 4, or 3 = 8)
Fix it up....
Post by: BrianHG on December 16, 2019, 03:12:31 am
Another mistake in BART.v module.
Lines 141 and 215 currently read:
if (x_in[2])
When they should actually read:
if (~x_in[2])
Now that you fixed the issues in my last 2 posts, load these attached test graphics files.
I deliberately left them a binary files you need to load into spare empty memory.  I recommend $1200 i.e. 0x1200.  This will place a bit of the graphics into the end of your text buffer, but there is no other space as they will go all they way up to address $3EFF.
The 4 files are:
z80_360x256x1.bin
pac_208x204x4.bin
z80_192x120x16.bin
z80_120x96x256.bin
I tested them all ok, so I expect proper screen shots.  You will need to figure out the MAGGIE settings for the X&Y resolution by # of colors.
Post by: nockieboy on December 16, 2019, 09:29:36 am
The 4 files are:
z80_360x256x1.bin
pac_208x204x4.bin
z80_192x120x16.bin
z80_120x96x256.bin
Here's what I've got - the palette is out mostly, but I think I can decipher the images:  ;)
z80_360x256x1.bin:
[attach=1]
pac_208x204x4.bin:
[attach=2]
z80_192x120x16.bin:
[attach=3]
z80_120x96x256.bin: (I moved the sprite down out of the way of the garbage text above it)
[attach=4]
The images are appearing BEHIND the text though - is there a setting I'm missing somewhere?
Post by: BrianHG on December 16, 2019, 09:53:02 am
The 4 files are:
z80_360x256x1.bin
pac_208x204x4.bin
z80_192x120x16.bin
z80_120x96x256.bin
z80_360x256x1.bin:
(Attachment Link)
You couldn't choose a better set of colors, like White and Black?
Remmeber, bg_color anf FG_color...
What about turning off the text layer?
Remember, the old bitplane_to_raster controls...
pac_208x204x4.bin:
(Attachment)
Ok, I was limited here.  You could only get the right image by editing the palette.  So for this one, I forgive you.
z80_192x120x16.bin:
(Attachment)
You couldn't choose an alternate palette base number from bg_color?
You would be surprised...
(Attachment)
Ok, unless you want to change the entire palette, this is the best I could do...
Post by: nockieboy on December 16, 2019, 10:31:05 am
I was just interested in getting the images to show, and to make the text overlapping the sprites visible.  I know I can turn the text off, just wondered if the 'z-order' of the drawing was correct and intended, that's all?
[attach=1]
Post by: BrianHG on December 16, 2019, 10:43:40 am
(Attachment Link)
When all 15 sprites/layers are in place, the z-order priority goes from top sprite to bottom sprite.
Ok, now, go back to the Yellow/Blue AB text test, make this function work:
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2830598/#msg2830598 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2830598/#msg2830598)
We then have 16 bit addressing, Y font/tile scale/size, MAGGIE Font-slave-addressing mode, replace old OSD Font algorithm with 5x MAGGIE with new font capabilities, update palette to 5 port ram function to receive 5 MAGGIE, switch 5 port rams to 15 port rams on GPU ram palette, fix up Z80 bridge to cope with 16bit GPU ram, and then you have finished your GPU V1.0 core.
Post by: nockieboy on December 16, 2019, 02:59:42 pm
Well, that got weird fast...  :o
I had a think about how best to implement horizontal scrolling as you've stated:
[attach=1]
Being more of someone who learns by experimentation, I cracked on and started writing code to get the sprite going horizontally, tweaking and adding bits to get the desired output.  I decided to stop when I realised I hadn't a clue what I was doing anymore and the sprite wasn't scrolling horizontally properly for every height it could have.  :-//
ram_read_pointer_x <= ram_read_pointer_x + (x_size * y_size) + x_size*((1 << y_size[7:4]) - 1) + 1 + y_size[7:4];
Can't be good when it starts to get that complicated and it still doesn't cover sizes of Y above 0x20.
Full code for MAGGIE attached so you can see what a convoluted mess I've made with my attempt.  ::)
Post by: BrianHG on December 16, 2019, 06:31:40 pm
(Attachment Link)
You only needed 8 pixels.  Your Z80 fills in the reset address.  This is all you should have written:
Lines 137 & 138: (undo your other changes)
ram_read_pointer_y <= (reset_addr << 3) + period_x_rst;  // V_TRIG is high during the first active line of video, set the read pointer, both
ram_read_pointer_x <= (reset_addr << 3) + period_x_rst;  // the backup and current display address to the exact reset base address during this line.
This allows byte/bitplane sub-pixel horizontal alignment along the X-axis when the sprite begins it's first pixel.  If you like, there is the potential to add 1 other thing to make this add always = to 1 pixel when dealing with 4 color and 16 bit color.  It's useless with 256 color at the base address increments as 1 for moving the image 1 pixel.
Next, the really weird 16 bit pixel mode.  Add this assign:
assign pixel_16_bit         = bp_2_rast_cmd[2];  // setting goes high when we expect 16 bit, 2 byte pixels.
Now, what this setting does is when set to 1, every time the 'X' read address increases, it will need to increase by 2, not 1 as it currently does.  If you truly figure the really simple way to get this one to work right, you will get a prize...   Remember, that 'Increment by 2' doe not affect the lower 3 bits which horizontally position the bitplane sub-pixel positioning.
Post by: nockieboy on December 16, 2019, 07:05:22 pm
... but that doesn't do what I thought you wanted?  I had in mind, for example for an 8x16 sprite, it would show the letter 'A' and when you scroll it, it would scroll to the left and show the letter 'B' coming in from the right, stopping one pixel short of showing the full tile (for the Z80 to re-set the start address and show the next char completely)?  :-\
Also, the 'new' tile scrolling in from the right is moved up a line?  Is that intended?
Erm... well, I'd change lines 151 and 152 to this:
ram_read_pointer_y <= ram_read_pointer_y + (inc_addr_y[15:0] << (3 + pixel_16_bit));  // vertical increment display position in backup buffer
ram_read_pointer_x <= ram_read_pointer_y + (inc_addr_y[15:0] << (3 + pixel_16_bit));  // vertical increment display position in current display address
Latest MAGGIE code attached.
Post by: BrianHG on December 16, 2019, 07:33:01 pm
I you are showing 1 pixel less, then you may want to shrike the horizontal width of the window so you don't see the extra junk on the right hand side.  Remember, the text font is 1 byte wide.  Try playing with the 1bit color, B&W graphic I gave you which is multiple bytes wide.  Shifting it to the left 1 pixel at a time will not make the right hand side vertically jump except all the way on the right hand side of the window.  Increase the read reset address by 1 and the image will shift 8 pixels to the left.  Increase the base address by the width byte setting and the image will vertically shift by 1 line.  We have not yet touched tiles/fonts.  You are missing a chunk of code which defines the current vertical location within a tile since you cannot add the current 'Y' address every line at the same character memory needs to be re-read every line while a sub-Y position is needed to compute where to read the font memory a second time around passing through the GPU ram again bases on the contents of the prior read character ram.
I'm curious, have you ever programmed direct HW registers for a video display on an Atari 800, or Amiga?  Did you not know this is how their internal video processors work the same way.  Or are you just used to library calls with do this control 'bit' manipulation under the hood?
ram_read_pointer_y <= ram_read_pointer_y + ((inc_addr_y[15:0] << 3) * (1+pixel_16_bit));  // vertical increment display position in backup buffer
ram_read_pointer_x <= ram_read_pointer_y + ((inc_addr_y[15:0] << 3) * (1+pixel_16_bit));  // vertical increment display position in current display address
EDIT: Hang on - testing a simpler way to do the 16-bit scroll..
Nope, that's wrong.  Right now, every time the horizontal address needs to increase, every 8, 4, 2 ,or every pixel, it increments by 1 address.  Meaning, 1 byte at a time.  We need to double this addition once every 8, 4, 2, or every pixel.  This has nothing to do with the vertical increment as that setting specifies the number of horizontal bytes you source image is.  So, naturally you would just have the correct number set there by the Z80 defining the number of bytes per line in the source graphic.  This is not what I am asking.  When MAGGIE is drawing the image, as it requests every single pixel, when the 16bit setting is high, it needs to recognize that every pixel is 2 bytes (16 bit) wide, not 1 byte.  How will you adapt MAGGIE to handle this.
Think about it this way, if you want color text.  Now don't go into reading the font yet as the font is still 8 bit.  But your memory has an 8 bit character stored as 1 bit monochrome.  And, the upper 8 bits, being read at the same time, stores the 256 possible colors, 16 foreground and 16 background colors.  Now, our ram is already wired to read 16 bits in 1 shot, but, the upper 8 bits is just the adjacent address according to the opposite LSB address as we wired it that way as a backwards compatibility to 8 bit mode.
Post by: nockieboy on December 16, 2019, 08:01:10 pm
...Shifting it to the left 1 pixel at a time will not make the right hand side vertically jump except all the way on the right hand side of the window.
Okay, well that's what I'm seeing then - way over at the right-hand side of the window, the image is re-appearing, but one line higher.
I've never done anything like this in my life!  Closest I got to the hardware on the Amiga was with Blitz Basic 2 (https://www.amigacoding.com/index.php/Blitz:Versions) when I wrote a Scorched Earth (https://en.wikipedia.org/wiki/Scorched_Earth_(video_game)) clone and some other basic games instead of studying.  ;) So, not even vaguely close.  I hadn't even really touched assembly on my Amstrad as a kid; I've learned the vast majority of what I know in the last two years working on my DIY computer.  It's been a learning curve!  :o
Ah okay, back to the drawing board.  ;)
Post by: BrianHG on December 16, 2019, 08:12:54 pm
Now I want you to think out of the box here.  Having the ram read address increment 2 for every 1 pixel instead of 1 for every 1 pixel, yet not touch the sub-bitplane-pixel counter isn't hard with a little thought.
Post by: nockieboy on December 17, 2019, 02:39:08 pm
It's no good, I've gone code-blind staring at MAGGIE trying to work out exactly WHERE ram_read_pointer_x is incremented by one pixel.   :o |O
Should I be looking to make changes in the if (run_x) begin block?
Also notice inc_addr_x isn't used at all?  Is that for a later feature?
Post by: BrianHG on December 17, 2019, 06:30:30 pm
Yes, the ram read pointer is being incremented inside the if(run_x).
At line 174.
But if you think about it, you might run into trouble here as the sub-pixel X position is also buried into the X increment here.  You don't want to alter how the bit-plane sub pixel positioning is generated.
Try looking at line 98.  You might be able to come up with a few ideas there.
Post by: nockieboy on December 17, 2019, 07:59:46 pm
At line 174.
Okay, so here's what I'm thinking.  This is where the ram_read_pointer is incremented by a value relating to the mode (line 183 in my MAGGIE):
If MAGGIE is operating in 16-bit mode, this needs to add another 8 bits on this line?  So something like this?
ram_read_pointer_x <= ram_read_pointer_x + 2**pixel_per_byte + 8 * pixel_16_bit;
Post by: BrianHG on December 17, 2019, 08:22:11 pm
At line 174.
Still thinking inside the box...  ;)
Unfortunately, with your code, when in 1 bitplane mode, 16 bit pixel, you will increment the X address every pixel, plus increment the X address twice every 8th pixel.  With a 16 bit data pixel, we would still want the X to increment twice every 8 pixels, but not during the middle of the 7 pixels of the bitmap.
Take a long hard look at line 98 once again and ask yourself, this read address increases by 1 at the right time, in 16 bit mode, when it increases by 1, I want it to increase by 2 instead...
Post by: nockieboy on December 17, 2019, 11:59:43 pm
Okay, so I tried this:
assign read_addr[19:0] = ram_read_pointer_x[22:3] + 8*pixel_16_bit;
Didn't work. :-\
And I tried this in if (run_x) begin:
if (width == 0) begin
ram_read_pointer_x <= ram_read_pointer_x + 8*pixel_16_bit;
end
Didn't work. :-[
The idea being with the above piece of code was to add 8 bits to the pixel address pointer at the end of the tile...  :-//  I think the problem is, I don't fully understand what the existing code is doing.  If I did, I'd see the bigger picture and probably find the solution, even if it's not the most efficient way to do what you're asking.  But as it is, I'm almost groping in the dark for the solution.
So, I want MAGGIE to read a pixel, which is represented in memory by 1, 2, 4 or 8 bits.  In 8-bit mode, the next pixel immediately follows on from the current one, so line 184 handles this increment to the next pixel, incrementing ram_read_pointer_x by 1, 2, 4 or 8 bits according to the mode.  However, in 16-bit mode, the pixel size remains the same (either 1, 2, 4 or 8 bits in size, specified by the 2 LSBs), but for each increment we need to skip a byte which contains palette or colour information??
This is my understanding of how MAGGIE is working, in a nutshell and to me the solution is to change line 184 to add 8 bits to ram_read_pointer_x every time it increments to skip the current pixel's associated palette/colour byte??  This means:
ram_read_pointer_x <= ram_read_pointer_x + 2**pixel_per_byte + 8*pixel_16_bit;
...but then I remember that for all the sub-pixels in the same tile, they share the same colour/palette byte, so incrementing by the extra 8 bits isn't necessary until the end of the tile.  But then I'm getting confused with tiles, sprites and variable widths, etc.  But where in the code does the 'end of tile' trigger occur?
 |O :horse:
I'm off to bed. Perhaps all this might make more sense tomorrow.  :palm:
Post by: BrianHG on December 18, 2019, 03:45:52 am
Ok, I'll give you half of this one.  Line 98 should be:
assign read_addr[19:0]      = ram_read_pointer_x[22:3] << pixel_16_bit;
This multiplies the ram read pointer address by 2 when in 16 bit mode.
Now, you need to patch 4 other lines so that the read address is still correct during reset and image width setting.  See lines 137,138, & 146,147.
If you coded things correctly, when viewing my 256 color test image, enabling the 16 bit mode should horizontally shrink the image in half with a replica image to the right of it shifted up by 1 line.
If you got this working, we will tackle the getting rid of the old OSD text and wire in 2 MAGGIES in it's place to generate text, including color text.  Then, the palette mixer will need re-working to accept 5 inputs.
Post by: nockieboy on December 18, 2019, 08:47:08 am
:wtf:  Now this is where bit operations start to look like a dark art to me.  :-\  ram_read_pointer_x is a 20-bit address, pointing to the current pixel.  Bit-shifting that value left 1 place if in 16-bit mode doubles the value, why would that doubled value point to the next byte?
If ram_read_pointer_x is, e.g., 0x40 - doubling that to 0x80 via a <<1 operation won't point to the next byte, it'll point to an arbitrary area of RAM, an increasing distance from the previous memory location as the address increases?  If ram_read_pointer_x is operating anywhere in the top half of memory, this operation will put the pointer out of bounds, surely?   :-//
EDIT:  Ignore the above - boy did my thoughts go off on a tangent there!!  :-DD
Of course it won't double the number (at least not in the sense that it will exceed the top of memory) as it's capped at 20 bits.
Our line numbers are out of sync - 147 is an empty line, and the others don't make much sense.  Rather than try to guess which lines you're talking about (139,140 and 151, 152 presumably), here's the latest version of MAGGIE; if you use this one, the line numbers you're quoting will match up to what I'm seeing.
EDIT:  I'm off to go learn more about bit-shift operations (well, the concepts we're dealing with more than the operations themselves). :o  There's clearly a hole in my understanding here.  But bit-wise tantrum aside, here's what I've done with MAGGIE to get 16-bit mode working as you've specified:
Line 139: ram_read_pointer_y <= (reset_addr << (3 - pixel_16_bit)) + period_x_rst; // V_TRIG is high during the first active line of video, set the read pointer, both
Line 140: ram_read_pointer_x <= (reset_addr << (3 - pixel_16_bit)) + period_x_rst; // the backup and currrent display address to the exact reset base address + x_offset during this line
Line 151: ram_read_pointer_y <= ram_read_pointer_y + (inc_addr_y[15:0] << (3 - pixel_16_bit));  // vertical increment display position in backup buffer
Line 152: ram_read_pointer_x <= ram_read_pointer_y + (inc_addr_y[15:0] << (3 - pixel_16_bit));  // vertical increment display position in current display address
I've just countered the doubling of ram_read_pointer by only shifting it left twice instead of 3 times in 16-bit mode.  Seems to work - the image is doubled, as you stated.  ^-^
Post by: nockieboy on December 18, 2019, 09:59:35 am
Just in case you want photographic evidence.  ;)
8-bit mode:
[attach=1]
16-bit mode:
[attach=2]
Post by: BrianHG on December 18, 2019, 08:25:27 pm
Ok, you got that all correct.
Now, 1 last thing before making wiring the MAGGIE into text mode.  A font 'Y' coordinate counter.
This one is weird as it sort of sits in parallel with the 'Y' period counter, but, it needs to either be off, count between 0 and 7, or 0 and 15.  It needs to increment after every number of period sequence counts for the 'Y' scale, yet, it also needs to prevent the height, height_count and inc_addr_y[15:0] from taking place until it reaches it's end.
Lets add an assign:
assign font_y_size[3:0] = hw_regs[Y_SCALE][7:4];
font_y_size will define the height of the font.  With this, you should be able to define a font tile size of '0' being 1 line font, to 15, being a font 16 lines tall.
The second assign will be: (It is actually taking the place of the 'period_y_rst[3:0]')
assign font_y_rst[3:0] = hw_regs[Y_START_SUB][3:0];
This reset position will define the beginning first line to be shown of the font at the top left hand of the window.  It performs the equivalent function to the bitplane's period_x_rst.
Now, you will also need a reg:
font_y_pos[3:0]
This reg will reg will hold the counter of the current display's font's 'Y' coordinates.
Let's see how you weave the font Y position into the current 'Y' coordinate counting system.  Unfortunately, there is nothing for you to display and if you haven't set up a simulation, you will have to guess/assume your results as a vertical font size of '7' ie 8, should stretch your picture vertically 8 fold.
To properly test this, we would need to wire the 2xMAGGIEs in place of the current text generator, assign the font Y coordinates to the cmd_out, and make the font 'SLAVE' mode in the second MAGGIE receive the command in, process it's base address with the incoming memory character data and font Y coordinates buried in the cmd_in port, and generate a new output address to sen to the memory to read a second time to fetch the font image to send to the BART for display.
This is the last of the truly tricky stuff.  Once done, we will fix up the palette mixer to handle multiple inputs, combine the 2 palettes (4444 & 565) into 1 larger palette and touch up how the layers are blended.
Post by: BrianHG on December 18, 2019, 08:42:10 pm
You are thinking of this the wrong way.  I'm multiplying the read address by 2.  So, if you start at read address 0, then increase to 1, then increase to 2, then 3, the output will be 0, 2, 4, 6.  IE, every increment of 1 jumps 2 instead.
Now, the initial starting address, and Y increment every line, those we are dividing by 2, so when beginning a line, they also begin the memory address at the right position.
However, you may notice that we have lost the first address bit, or, the possibility of addressing ODD pixels here.  This is fine.  We will not be starting a display's memory address at an ODD memory location when using 16bit wide pixels.  Sort of like when using a 68000 to copy & manipulate 16bit pointers.  It also wants even word aligned address pointers.
Post by: nockieboy on December 19, 2019, 04:04:01 pm
Lets add an assign:
font_y_pos[3:0]
...it needs to either be off, count between 0 and 7, or 0 and 15.
How is this decided?  Which HW_regs value am I using (if any) to set this behaviour?  Is this based on the screen mode?
Right, time is short for me these next few days so I'm going to try to make small changes in the time I have and post them up here for checking.  I've added the wire and reg you've mentioned above, and also the counting system to increment font_y_pos.  That's all it does at the moment - no checks or actions - it just increments the counter (hopefully in the right positions!)
Post by: BrianHG on December 19, 2019, 09:07:55 pm
Ok, to begin, ok so far.  Yes, implementation is all messy.
The 'font_y_pos' limit is set by the  font_y_size hw_reg.  Having a  font_y_size of 0 means every new line is a new vertical address increment, or just call that mode 'OFF'.  Setting the  font_y_size to 7 means the Y font_y_pos will count from 0, 1, 2,... 7 before a inc_addr_y.  This means you font has 8 vertical position, or a font of 8x8.  Also, don't forget with the period_y setting, each of those 8 positions may be repeated 1, 2,3,4,...16 times stretching out you text vertically.
Post by: nockieboy on December 20, 2019, 07:10:54 pm
Some changes made around lines 160-180 to reset font_y_pos at the right time.  I'm not convinced it's right, though, as I'm confused about what is required and how to implement it.
So font_y_pos should increment on each pc_ena[3:0]==0 clock, if run_y is true, and not allow increments to height_count unless font_y_size is zero or font_y_pos == font_y_size, in which case allow a vertical increment to occur..... hmm.  No, I'm confused about this bit.  The whole if (run_y) begin block needs a close look at - this is where I'm presuming all the font_y_pos tweakery goes on, but I'm unsure what I should be doing.  I'd need a whole day to filter out the conditions of what you're asking for, then to try to understand MAGGIE in more detail than I do currently to then make the modifications to get it all to work as you want.  I'm struggling with time at the moment.  :-\
Post by: BrianHG on December 20, 2019, 07:22:14 pm
Since you arent simulating, you are going to have to wire everything in.
Remove the old OSD text and wire in 2 MAGGIEs on the first 2 read ports, assign H&V + normal HW regs for each, and on the second MAGGIE's ram output, wire that one's BART's output into the palette mixer's text layer input and begin to play, except, the current MAGGIE is missing the function to receive the last MAGGIE's memory character and point to a font memory address.
Post by: nockieboy on December 20, 2019, 07:34:25 pm
Remove the old OSD text and wire in 2 MAGGIEs on the first 2 read ports...
So when you say 'remove the old OSD text', are you just talking about disconnecting read_text_addr and read_font_addr from the gpu_RAM in the vid_osd_generator, or completely replacing the vid_osd_generator with a module that handles the two MAGGIEs?
...assign H&V + normal HW regs for each, and on the second MAGGIE's ram output...
That would be the data_out#x from the gpu_RAM to the BART, right?
...wire that one's BART's output into the palette mixer's text layer input and begin to play, except, the current MAGGIE is missing the function to receive the last MAGGIE's memory character and point to a font memory address.
 :o Will have a go this weekend...
Post by: BrianHG on December 20, 2019, 07:44:27 pm
https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2826458/#msg2826458 (https://www.eevblog.com/forum/fpga/fpga-vga-controller-for-8-bit-computer/msg2826458/#msg2826458)
Since your current palette mixer has only 2 inputs, you will have to use the second MAGGIE's/BART's read channel to feed the first input of the current 2 channel palette mixer.
Post by: nockieboy on December 20, 2019, 07:45:12 pm
Already using it.  ;)
Post by: BrianHG on December 20, 2019, 07:46:58 pm
Post by: nockieboy on December 22, 2019, 05:45:39 pm
I just don't have the time to put into this at the moment.  :-[ I started trying to wire up the two MAGGIEs and their BARTs in the vid_osd_generator a few days back and have come back to it to work on it again for half an hour and spent that time trying to work out where I was with it all instead of progressing it further.  :palm:
Doesn't help that I feel what you've asked me to do should be easy, but I'm struggling with it and feel that I've used up my question quota and should understand it all by now.  :scared:
Post by: BrianHG on December 25, 2019, 09:38:12 am
Merry Christmas,
I've done a huge deal of work for you, something like 2-3 months worth based the current trend.
Here is all the work I have done:
Increased ram to 28672 bytes + 1024 bytes for the palette filling out your current Cyckone IV.
The main GPU ram begins at address 0 and reads/writes up until byte 28671. (address $6FFF).
The palette is currently stored at $007C00 through $007FFF.  The first 512 bytes is the ARGB 4444 palette while the second 512 bytes is the RGB 565 palette.
HW_regs now begin at address $006F00 through $6FFF.
MAGGIE code has been patched and text_mode_master/slave have been implemented.
Added MAGGIEs 0 through 4, 5 graphics layers in total.
When presenting bitmap/tile windows, the top MAGGIE, lower MAGGIE # has higher priority / sits above the lower ones.
All of the MAGGIEs have their HV resets set to HV_Trigger 8 & 9.
MAGGIE H&V top left window position begin with MAGGIE 0 @ 10 & 11.  Increase each HV trigger pair for each sequential MAGGIE.
MAGGIE 0 control HW_regs + 128 bytes, for 16 bytes.  Increase 16 bytes for each sequential MAGGIE.
When using text/font/tile mode, 2 adjacent MAGGIES must be used.  The first one must have the 'text_mode_master' bit set in the 'BP2RAST_cmd' while the second MAGGIE must have the 'text_mode_slave' bit set in the 'BP2RAST_cmd'.  The 'BP2RAST_cmd' video mode in both must match except in the master where the BP2RAST_cmd video enable [4] must be disabled, otherwise you will get junk on the screen.
The 16 control bytes for the 'text_mode_master' MAGGIE points to the text/tile IDs.  All other controls are identical as when using it as a bitmap graphics window.  The 'font_y_size', combined upper bits of '{hw_regs[Y_START_SUB][7:6],hw_regs[Y_SCALE][7:4]}' in the text_mode_master which must also be set to the font/tile height -1. EG: 0=1 line, 7=8lines, 15=16lines, 31=32lines when in text/font/tile master mode...
For the 'text_mode_slave' MAGGIE, the only functioning 4 controls are the 'reset_addr' which now points to the base memory address of the font/tiles graphics data, period_x[4] which defines a font being 16 pixels wide when set, or, 8 pixels when low, period_x[3:0] which mask out the upper bits for fonts/tile addressing for 256, 512, 1024, 2048, 4096 characters (used in 16 bit addressing mode, otherwise set these bits to 0), period_y[1:0] which defines the font height, 0=8, 1=16, 2=32, 3=64 lines tall, and 'BP2RAST_cmd' which should match the text_mode_master MAGGIE settings except for the master and slave bit.
All base memory address settings should be on an even byte when using 16 bit mode.  Fonts/tile graphics data should always begin on an even byte address.
BART has been patched to embed the .window_ena_out,.mode_16bit,.mode_565 into it's .pixel_out bus.
Palette_mixer has been updated to receive the new BART's .pixel_out bus with the embeded .window_ena_out,.mode_16bit,.mode_565.
The palette is now 512 entries wide, with the 4444 color palette occupying the first 256x16 entries while the 565 palette occupies the second 256x16 entries.
It also now has 5 inputs which get mixed together to form 1 output.
This means without text, you can mix 5 on-screen sprites, or, 1 text layer and 4 sprites.
Other than a ram limitation, there are no other output limitations.  Any mode ant any res with any palette may be all mixed simultaneously onscreen.
Right now, I disables the linear translucent alpha blending for a basic transparent of opaque pixel on each sprite layer until I figure out a good way to accomplish this across multiple layers without filling up your tiny FPGA.  Maybe we can reserve the alpha blend technique for 2 sets of different paired layers while going back to basic stencil layering between all the remaining layers.
I'm having trouble with clock domain crossing in trying to get the 2x core GPU ram working which will give you all 15 graphic layers.  Running everything at 2x clock would be simple, but I don't have the time to optimize your code to make this cyclone run at 250MHz.
Let's see if I can find the bug over the next day or 2.
Everything else is ready for you to get you Z80 running.
See the attached files and check the RS232_debugger quick load files which have a 16bit color text demo with 3 additional scaled sprites onscreen.  Photograph to make sure that everything works.  If you want nicer graphics, you will have to start generating you own files...
Post by: BrianHG on December 25, 2019, 09:58:25 am
There has been so many changes, you will need to throw out your old project folder.
Post by: nockieboy on December 25, 2019, 03:34:57 pm
Wow - thank you so much!!   :-+
Okay, so I've got some documentation to do and some work on the Z80 interface (the mux with the RS232_debugger interface is nowhere near done yet) and it's done.  ^-^
Merry Christmas to you too!! (and anyone else reading this!)
[attach=1]
[attach=2]
In the image above, the white fade-out on the right-side of the Z80 image isn't a photographic artefact - could that be caused by capacitance in the output wires?
Post by: BrianHG on December 25, 2019, 06:29:49 pm
Strange.  Since I'm using a real DAC, I see nothing but a perfect image on my end.  Maybe something happened with the IO current strength settings, or, too much on screen for the the method of the analog dac.
When you have time, see if you can get a scope shot.
BTW, I now have all 15 layers working now on my side, but, your Cyclone IV is too small.  Maybe I will come up with an idea.  1 Cyclone larger and 15 would be no problem on your side too as you are ran out of logic cells and ram needs to shrink to fit the design as well.
Post by: BrianHG on December 25, 2019, 06:41:27 pm
(Attachment Link)
(Attachment Link)
Check your IOs as I have made the outputs 24 bits instead of 12 bits.  You only want the upper 12 bits [7:4] wired to the DAC pins.  Maybe check IO assignments as you may be using the lower IOs or having new adjacent IOs new interfering with the video.
Post by: nockieboy on December 25, 2019, 07:07:28 pm
Will check IOs when I get the time - it probably doesn't help that I've got wires from the FPGA board to the resistor DAC breadboard, then more wires to the VGA connector.  I'm waiting on a couple of parts to arrive in the post then I'll have a proper PCB-based 24-bit DAC up and running.
Hmm.. I knew this Cyclone IV board was cheap, but it's got the smallest Cyclone IV imaginable on it!  >:(
Well, I'm guessing the Lattice LFE5U won't have these issues.
Hmm.. will go check this in a bit.  :-+
Post by: nockieboy on December 25, 2019, 08:18:23 pm
Yeah, that's an improvement.  I can see the HV_trigger lines around edges now, too.  There is still a very faint amount of 'runoff' from the white background on the sprite into the black background behind it, but nowhere near as noticeable as before.  I'm no electronics expert, but I'd be happy to bet that once I've got a less 'cobbled-together' DAC created, that runoff will disappear.
Thanks again, BrianHG.  Hope you're taking a break over the holiday season?!!
Post by: BrianHG on December 25, 2019, 10:41:44 pm
Well, 15 layers as the current project stands takes 11K logic gates and your CycloneIV has 6K.
To turn back on transparency between a number of layers, add 1K-2k more gates as it is all a bit table of 3x3x3 multiply adds.
I just compiled the project with the LFE5U settings as my old CycloneIII EP3C55 has the gates and ram for the job.  It takes 17% of the logic elements and 76% of the ram bits with over 220kilobytes of graphics ram.  The Lattice LFE5U is 10% smaller FPGA, so no problem there.
With the addition of a 1$ DDR ram chip on you PCB, you can reserve 1 MAGGIE channel to that ram controller and get a 32 bit graphics layer with 16mb of addressable space.  Making a DDR ram controller which only has to deal with a single 27million pixels a second read and a Z80 at 2-8 million transactions a second is a joke compared to the all the cross-reads going between all the other 14 MAGGIEs which read all random memory locations every-which-way as I designed the core to do so.
Basically you would treat the onboard 220kb as texture and sprite memory as the bulk DDR ram would be for background and swapping of large chunks of additional animation graphics.
The rest of the FPGA logic would be 75% empty for a cool hardware accelerated drawing engine.
Post by: nockieboy on December 25, 2019, 11:37:20 pm
I'm making a start on designing a custom board for an LFE5U - it'll be a few months and probably a few test runs before I get to attaching a BGA to a custom board, but once that's done it seems the sky is the limit.
DDR RAM, not the SDRAM that I've got on the dev board at the moment?  Might have to look into that - very tempting.
 :o  Sounds awesome.  I wish I had 10% of the knowledge you have with FPGAs..  but then I'd be in a different career, I guess.
Random question - would there be any mileage in a hardware scrolling capability for text mode?  Specifically, I was thinking of using the sub-pixel offset capabilities to scroll text upwards (or downwards) when a new line is written to a single-line buffer which would be 'off the top or bottom of screen' and not visible?  Or having a 'viewport sub-pixel' setting, to allow the entire screen (of text) to be smoothly scrolled by offsetting the viewport up to a single line of text?  Too much work for little payoff?
Post by: BrianHG on December 26, 2019, 12:19:35 am
It's all there.  If you hadn't noticed, I literally finished your graphics engine.  Sup-pixel scrolling is there.  As well as modifying the base address to shift 1 character at a time, or a line at a time.  Including the source bitmap/raster 'width' setting which allows you to set a display width of up to 65535 characters wide.  This is how side scrolling video games like Super Mario Bros is where the backdrop is nothing more that character tiles from a font memory with a horizontal display set larger than the width of the screen.  With what you have now, memory limiting of course, you can use 16 bit characters for a 4096 character font of 4x8 or 4x16 pixels, or 8x8/8x16 pixels to make a huge display of regular repeated items.  Or, you can use multiple layers in graphics modes, 1 for a bottom background, next layer for onscreen animated objects and another layer or 2/3.../10 for player sprites.
Even the soft blending in the palette mixer is there, I just removed the multiplies in place for a layer switch, but, all the controls and assigns are present.
Your just going to have to learn play and re-document every control to date to get a feel for what is possible.
Though I specified all the control names and they are all organized into defparams in the beginning of the MAGGIE & BART, you still need to fill the ram with usable image data and play with all the controls to see what happens.
Post by: BrianHG on December 27, 2019, 07:46:45 am
How to generate rich compact code in C++17 for x86, though the code example here is also finally translated into 6502 for the Commodore C64, the example output given here is assembled into x86 code, and the presenter shows you how to generate Z80 driven bitmap graphics and color tables using the right C++17 headers in the compiler to make the tiniest, most compact Z80 assembly code possible which directly addresses memory in connected hardware.  He gets the C++17 to actually synthesize bitplane data from arrays and encode them into the smallest x86 assembly possible.  You would just need to get a x86 to Z80 converter, or a direct Z80 output of the C++ compiler.
https://www.youtube.com/watch?v=zBkNBP00wJE (https://www.youtube.com/watch?v=zBkNBP00wJE)
Post by: BrianHG on December 30, 2019, 07:16:18 am
 :phew: Ok, here is the GPU, with the core ram at 250MHz.  Though I selected the -C7 FPGA, in -C8 it is so close to 250MHz, it should still work fine. (My Cyclone III -C8 works fine and it compiles with even a slightly slower FMAX (220MHz) than the Cyclone IV -C8 (238MHz) The -C7 compiles with a 270MHz FMAX.)
Here are the changes:
Latest memory layout.
24576 = size of current GPU ram
    0 -   511 = All HW_Regs shared with generic GPU RAM.
                00 thru 07 = H&V triggers for 4 yellow test cursors
                12..15     = H&V triggers which is the H&V reset coordinates for all 15 MAGGIE_Layer#s
                16..19  +  2*MAGGIE_Layer# = H&V Top left edge of each MAGGIE_Layer# window.
                    96  + 16*MAGGIE_Layer# = 16 byte controls for each of the 15 MAGGIE layers.
  512 -  4607 = Default IBM VGA 8x16 Font
 4608 -  7007 = Default ASCII text buffer, 80 characters x 30 lines (MAGGIE 0&1)
 7008 -  8207 = Color text buffer, 2 bytes per character, 40 characters x 15 lines.  (MAGGIE 2&3)
13056 - 24575 = 16 color Z80 CPU graphic image. (Rendered at 3 sizes across 3 different palettes, MAGGIE 4,5,6)
31744 - 32255 = Primary palette, ARGB 4444 style.
32256 - 32767 = Secondary palette, RGB 565 style.
New GPU project parameters:
NUM_LAYERS   = 2 through 15 = 2 layers through 15 layers.
PALETTE_ADDR = Sets the base address for the 2 palettes.
               This one is automatically set to (2**ADDR_SIZE - 1024), so the palettes are the last 1024 bytes.
Though you lost a little ram because of the all 16bit core, and memory allocation size parameter, you now have 7 active layers.  And with this final code, all you need to do is change the parameter setting on the block diagram to 15 to get 15 layers as well as increase memory size once you get a larger FPGA as the HW Regs is now at the bottom of the ram, it will always powerup to the right default settings.
The only thing missing is the semi-translucent layer feature which I will finish off tomorrow.  However, turning the feature on may eat more logic cells, lowering your layer count since now you are at 94% utilization with 7 layers.
All the other changes means I also had to update the RS232_Debugger files.
Send photos of the powerup test screen once compiled.  I hope it works.
Post by: nockieboy on December 30, 2019, 09:15:01 am
:phew: Ok, here is the GPU, with the core ram at 250MHz.  Though I selected the -C7 FPGA, in -C8 it is so close to 250MHz, it should still work fine. (My Cyclone III -C8 works fine and it compiles with even a slightly slower FMAX (220MHz) than the Cyclone IV -C8 (235MHz) The -C7 compiles with a 270MHz FMAX.)
 :o :clap:
[attachimg=1]
That looks great!  Well done!!
I've just scanned through the changes - I'm liking the vid_osd_generator parameters and starting GPU RAM contents file.  It's all working, as the screenshot above shows.  Thank you so much for this! :-+
I can manage without that for the moment until I get a bigger FPGA sorted ;) - I've been working on getting the Z80_bridge and data_mux modules finished (though that sounds like I've actually had any time to work on them - I've basically just sorted out the wiring for them so far); when I get more time I'll see about getting a Lattice dev board done.
Thanks again.  ^-^
Post by: BrianHG on December 30, 2019, 09:53:52 am
It's a close match to my board's display on a CRT...
[attachimg=1]
Post by: BrianHG on December 30, 2019, 10:14:17 am
DVI output on LCD version:
[attachimg=1]
In person, the CRT obviously looks best!
Post by: nockieboy on December 30, 2019, 11:03:40 am
Seems you can't beat quality CRT output.  :)
It's a quiet morning here at the moment, so I've just soldered together my 12-bit resistor DAC since the SSOP 74HCT541s I ordered arrived this weekend.  Have gone from this:
[attach=1]
... to this:
[attach=2]
... and the run-off in the white areas has pretty much disappeared.  It plugs straight into the dev board, so no annoying jumper cables anymore. ;) Just waiting on an ADV7125 to arrive in the post and I'll have a 24-bit DAC to use in its place as well.  :-+
Post by: nockieboy on December 30, 2019, 01:01:19 pm
 |O
I'm trying to make some progress on the data_mux to gate the RS232 and Z80_bridge I/O to the GPU RAM.  I'm making baby steps, and testing as I go, but something really odd is going on.
In the attached project, the RS232_debugger should NOT be able to read or write to the GPU RAM.  I've only attempt to implement reading anyway, but the data_mux should be disabled, yet when I test the project it works normally (reading AND writing)...  :-//
Note that this isn't the latest version of the project, but it is the latest version of the data_mux work.
Post by: BrianHG on December 30, 2019, 07:04:28 pm
|O
Ok, you made a few booboos.  Take a look at the changes I made on the main .bdf and inside your bridge.
You have too many cross versions of everything going around....
You will eventually need to upgrade everything to my 7-layer MAGGIE version as it is not backwards compatible as you have things now...
This means re-editing the top .bdf as well.
Post by: nockieboy on December 30, 2019, 08:01:59 pm
Yeah, I'd already made a start on the bridge and mux module modifications when you dropped the 7-layer project, so I shunted my existing project to the side with the intention of working on the bridge/mux portion and porting their .v files over to the 7-layer project once they're done.
I'll go take a look at the mods you've made - thanks very much.  :) :-+
Post by: nockieboy on December 30, 2019, 08:34:36 pm
Thanks for clarifying the DFFs on the RS232 output - I was going to use them (or another set) on the mux output to the vid_osd_generator, but I guess I won't need them as the mux runs at system clock speed?
As for the mux code - ENABLED is only there whilst I was trying to debug the RS232_debugger still being able to communicate with the GPU RAM, I'll remove that - or make it specific to the RS232 module.
Thanks for updating the code - I'd have got there eventually!  :o ;D  Port A code will just be a copy-pasta of the existing two if-else-end blocks with vars renamed appropriately?
Post by: BrianHG on December 30, 2019, 11:47:07 pm
What you should better do is make 2 wires, run_portA and run_portB.
Assign a set of rules for each wire with simple Boolean terms.
And use those wires to drive the 1-2 if statements and read/write request flags...
Remember to set and clear busy status for each port in the 'if's, use those as status in the boolean selection and make sure the Z80 get's first choice/priority over the RS232.
Post by: nockieboy on December 31, 2019, 10:51:06 am
Hmm.. not sure I follow..  run_portA and run_portB would just reflect the existing 'if' conditions?
The read-ready flags are handled by the sequencer pipelines and assign statements.  It's just the write flag to the GPU that is shared between the two ports and needs a little extra logic to enable the inclusion of port A?  (Would it make sense to have two gpu_wr_ena's, one for each port, that are OR'd together to make the existing gpu_wr_ena output?) Otherwise it'll be set to zero each clock cycle by the port B 'else' condition in the write if.. block.
No doubt you're describing a more efficient way of doing what I was going to do by just copying the existing port B if.. statements, but I can't see it at the moment.  ???
Post by: BrianHG on December 31, 2019, 11:01:49 am
Does this help any?
wire run_r_porta, run_r_portb,run_w_porta, run_w_portb;
assign run_r_porta  = rd_req_a && ~portb_bsy;
assign run_w_porta = wr_ena_a && ~portb_bsy;
assign run_r_portb  = rd_req_b && ~porta_bsy && ~run_r_porta && ~run_w_porta;
assign run_w_portb = wr_ena_b && ~porta_bsy && ~run_r_porta && ~run_w_porta;
Note that there is no latching or latching logic here.  Everything is realtime.
(Hint, since port B, the RS232 is running at 50MHz, it's write and read request will always be at least 2 or more clock cycles long.  In fact, the way I programmed it, you can multiply that figure by a good 3x.)
Post by: nockieboy on December 31, 2019, 11:20:56 am
Does this help any?
Ah okay, thanks.
I've copied the data_mux.v and Z80_bridge.v files from the older project that you updated yesterday into the current project (7-layer one), so I'm working on the mux from the current project now.
gpu_wr_ena <= run_w_porta || run_w_portb;
Would the above be okay in the always loop?
Post by: nockieboy on December 31, 2019, 11:24:15 am
always @ (posedge clk) begin
porta_bsy <= run_r_porta || run_w_porta;
portb_bsy <= run_r_portb || run_w_portb;
if (run_r_portb) begin
rd_sequencer_b[9:0] <= { rd_sequencer_b[8:0], 1'b1 };
gpu_address      <= address_b;
end else begin
rd_sequencer_b[9:0] <= { rd_sequencer_b[8:0], 1'b0 }; // this line must always run no matter any other state
end
if (run_w_portb) begin
gpu_data_out        <= data_in_b;
end
end
Would that be better?
Post by: BrianHG on December 31, 2019, 11:27:33 am
Does it work?
Post by: nockieboy on December 31, 2019, 11:31:21 am
Does it work?
Sure does.
Compiles are taking 1 min 50 seconds now.  ;)
// *** UPDATE GPU_WR_ENA AND FLAGS EACH CLOCK ***
// *** HANDLE PORT A READ REQUESTS AND SEQUENCER ***
if (run_r_porta) begin
rd_sequencer_a[9:0] <= { rd_sequencer_a[8:0], 1'b1 };
gpu_address    <= address_a;
end else begin
rd_sequencer_a[9:0] <= { rd_sequencer_a[8:0], 1'b0 }; // this line must always run no matter any other state
end
// *** HANDLE PORT A WRITE REQUESTS ***
if (run_w_porta) begin
gpu_data_out        <= data_in_a;
end
// *** HANDLE PORT B READ REQUESTS AND SEQUENCER ***
end else begin
end
// *** HANDLE PORT B WRITE REQUESTS ***
end
end
Post by: BrianHG on December 31, 2019, 11:35:23 am
So next, wire in the Z80,...
Post by: nockieboy on January 01, 2020, 09:43:47 pm
Got that done today, have just been debugging the connection with a little spare time.  Started out oddly - clearly a bad connection for bit 1 on the data bus, fixed that now but am still not getting 100% results.
I'm using two methods to read and set the contents of the GPU RAM from the Microcom - the PEEK direct command in my monitor program (DMI) and MEMX, a memory viewer/editor program in the DMI.  I'm trying to set contents using the POKE direct command.
Here's the output from MEMX when viewing the first page of the GPU RAM (a 16KB bank of the GPU's memory window mapped to $C000), compared with the (simultaneous) output from the RS232_debugger viewing the same page:
MEMX:
[attachimg=1]
RS232_debug:
[attachimg=2]
As you can see, there are some errors in the MEMX output (addresses $C01C, $C01E, $C02C are the first).  Looks like a timing issue getting data out from the GPU to the Z80?
Writing the GPU RAM using POKE seems to be fine for the most part, unless I try to perform a block write - I have another command that sets a block of RAM to a user-specified value (it uses LDIR (http://z80-heaven.wikidot.com/instructions-set:ldir) iirc - one of the Z80's block data-shifting commands) - that completely fails - doesn't change anything according to the RS232_debugger, but returns all zeros (or whatever value was written) on the Microcom.
Going to dig out the Z80 manual and see what it says around the memory RD/WR cycles.  I'm wondering if I need to keep the data valid on the data bus for a short while AFTER the end of the memory cycle, but I'm pretty sure the Z80 doesn't require the data to be held after RD goes high...
Sometimes PEEK returns the correct value, sometimes it just returns $FF and the data returned using MEMX changes each time I view the page (well, the errors change in terms of value and location).
Post by: nockieboy on January 01, 2020, 11:40:21 pm
Have looked at the level converters - I'm using a 74LVC245 to shift the data bus from 5v down to 3v3 for the FPGA - it's powered at 3v3, so it will be outputting to the Z80's data bus at 3.8v maximum, according to the datasheet (http://www.ti.com/lit/ds/symlink/sn74lvc245a.pdf) and the Z80 has a buffer on its data bus anyway (a 74HCT245) which takes 2v as a high input, so I don't think there should be any voltage level issues...  :-//
Post by: BrianHG on January 02, 2020, 12:10:01 am
?  How do you get more voltage out of an output buffer, IE3.8v, when powering it at 3.3v?
Do you have a scope shot?
It looks as if you may be decoding/latching the GPU ram at the wrong time, or forgetting to latch it at all.
Also, for the Z80 writes, it may be wise to scope both sides of the buffer.
As for the block writes, we rely on the cycling of the WRn from the Z80, if during a block write that signal remains low throughout multiple writes, we may need to adapt our Z80 bridge write logic.
The fact you got this far on the first day is actually a good sign.
Post by: BrianHG on January 02, 2020, 09:15:38 am
Change your Z80 buss interface so it responds on every rising clock edge, both whether it is a read or write.  Ignore the edge transitions of the mreq and wrn.  In in other words, if there are 2 or 3 consecutive mreqs across multiple clocks, trigger and respond at each one.
Also make a switch input which will allow you to switch triggering on the positive edge clock, or, the negative edge clock.
Post by: nockieboy on January 02, 2020, 11:19:08 am
I was just quoting from here in the linked datasheet:
[attachimg=1]
It's immaterial, anyway, as the Z80 buffer reads anything above 2v as HIGH, so there should be no issues with the voltage conversion.
Scope or logic analyser?  My scope is of limited use as it's not digital and is very old - unless I'm worried about voltage levels or analogue signals, I tend to default to the logic analyser.  In either case, no, I don't have any shots (yet) - setting them up is a pain and I go to them as a last resort, usually.
This is highly possible, as I've taken the z80_bridge module to be working since I last posted the code for it some time ago and didn't get any comments from you on it?  :o
The data output from the Z80_bridge module (Z80_rData[7:0]) is a register though, so should latch anyway?
I've attached the latest code for the z80_bridge module below.
Even during 'block' writes, WR is cycled by the Z80 - the normal WR cycle is observed, it's just that LDIR (http://z80-heaven.wikidot.com/instructions-set:ldir) (and others (http://z80-heaven.wikidot.com/instructions-set:ldi)) simplifies the assembly for the programmer by removing the need for a loop.  You just specify the source and destination addresses, number of bytes to copy, then LDIR does the rest.  Each step in the loop is a load (RD) from the source address, then a WR to the destination address, then the Z80 increments the address pointers and decrements the number of bytes to copy before looping.  There is no RD-MODIFY-WR or anything like that on the Z80 - all the RD and WR cycles are as shown in the timing diagram in the Z80 datasheet.
[attachimg=2]
According to one source I found, the Z80 latches the data during a RD operation on the falling edge of T3. This appears to be very close to the rising edges of MREQ and RD, but according to the datasheet should be no more than 60ns before the rise of RD for a Z84C008 (timing 23 in the below chart).  No minimum is given, but that's because of 'overclocking' - my Z84C008 runs at 8 MHz, so that figure should be close to 60ns.
[attach=3]
[attach=4]
I was actually hugely surprised, to be honest, that I got it working at all.  It's a rat's nest of wires at the moment - will be glad when I've got a Lattice dev board done and have some confidence in BGA soldering...  but that's a way off yet!  :o
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on January 02, 2020, 11:52:13 am
Without an analog scope shot, how can you be certain that the CMOS buffer output signals cleanly clears 2v when driving the CPU's input loads?
A logic analyzer is a powerful debug tool, but if it considers 1.5v a high and the CMOS buffer is outputting a 1.9v signal, you still need to verify everything is ok.
Post by: nockieboy on January 02, 2020, 01:17:36 pm
:o Fair point.  Well, I wrote a (very) short program to repeatedly read the first address in GPU RAM and loop.  Literally two lines of code (well, three as I had to disable interrupts).  I have to get repeating signals otherwise my scope will just display garbage - it has no hold/freeze.  From what I can tell, at least 3v are going out of the converter.
If the voltages weren't high enough to be read as HIGHs, surely the corrupt values would be missing bits (LOWs) or bytes coming out as zeroes, rather than the current case where the corrupt bits are high or low?  I'm sometimes getting $FF instead $00, for example, which leads me to think it's a timing issue rather than a voltage one.  :-//
Post by: nockieboy on January 02, 2020, 01:39:45 pm
Still thinking about this - I'm not sure the Z80_bridge module is 100% correct - I'm not latching the data at all, other than the output to the Z80 is a register?  Should I have some DFFs on the output to the Z80 from the Z80_bridge like you did with the RS232 outputs to the GPU RAM, but clocked from the Z80 (or the Z80's RD?) instead of the GPU clock?
Post by: nockieboy on January 02, 2020, 11:39:12 pm
So close...
Console output:
[attach=1]
GPU output:
[attach=2]
EDIT: Yes - I know the year is out on my RTC!  ;)
Post by: BrianHG on January 03, 2020, 12:21:58 am
Start with my recommended changes to the Z80 bridge code.  I don't know if I have time to look at it myself.  Maybe on the weekend.
Also think about assigning 'Fast Input Registers' and 'Fast Output Registers' and 'Fast Output Enable' registers in Quartus.  Note that these don't get assigned in the verilog, they are project assignments.
Post by: nockieboy on January 03, 2020, 12:28:42 am
Okay, will take a look at the changes tomorrow.  Will do some research on these Fast Input/Fast Output registers too.  Thanks.  :)
Post by: BrianHG on January 03, 2020, 05:44:00 am
Try this:
   if ( Z80_write_sequencer[0] )                 Z80_245data_dir  <= 1'b1;            // set 245 dir toward FPGA
   if ( Z80_write_sequencer[0] )                 Z80_rData_ena    <= 1'b0;            // set FPGA pins to input (should be by default)
   if ( Z80_write_sequencer[0] )                 Z80_245_oe       <= 1'b0;            // enable 245 output
   if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_addr         <= Z80_addr[18:0];// latch address bus onto GPU address bus
   if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_wdata        <= Z80_wData;      // latch data bus onto GPU data bus
   if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_wr_ena       <= 1'b1;            // turn on FPGA RAM we
   if ( Z80_write_sequencer[DELAY_CYCLES + 3] )  gpu_wr_ena       <= 1'b0;            // turn off FPGA RAM we
   if ( Z80_write_sequencer[DELAY_CYCLES + 3] )  Z80_245_oe       <= 1'b1;            // disable 245 output
This will force 2 sequential write pulses, perhaps patching a bug within the MUX algorithm.
Also in the MUX, take a 1-shot approach to read and writes from the RS232 debugger port.  (Make the read and write req go through a 1 clk delay and run once only if the signal does a low to high transition.)   Since the RS232 operates at 50MHz, a write or read command remains on for multiple clocks.
Post by: nockieboy on January 03, 2020, 12:03:31 pm
Try this:
Ah - the changes above seem to have fixed it (including one-shotting the RS232 read/writes)! ^-^
I'm getting no errors, either reading from or writing to the GPU now from the Z80 (and the RS232_debugger is unaffected) - I'm able to do block memory ops as well, so clearing the screen (eg) is dead easy now.  I'll keep an eye on the interface stability as I develop the driver for the GPU, but it's looking good so far.  :-+
 ;D ^-^ ;D ^-^ ;D ^-^ ;D
Post by: BrianHG on January 03, 2020, 12:11:00 pm
You have cornered the problem and made a quick workaround according to my recommendations.  Do not assume it is wise not to properly fix the code.  For now, you are fine, but with the addition of a hardware accelerated drawing engine in the future, you will by that time want to get the read and write mux and Z80 interface to properly work with a single write pulse as you do not want to waste R/W cycles when you have a fast drawing engine sharing the GPU ram bus.
The proper thing is within the MUX would be to unilaterally acknowledge a single read and write pulse, holding it internally until that address and write_ena makes it way out to the GPU ram.
Post by: nockieboy on January 03, 2020, 11:22:24 pm
I've been trying to get the mux to hold off all other requests until a read cycle is completed, but not had much luck so far.  I presume this is what you're talking about above?  I've attached the files below for reference - data_mux has the work I've tried to hold off on requests, although the lines are commented-out at the moment.
It seems I spoke too soon about the interface stability earlier - whilst I am able to block-write zeros to part of the GPU RAM as part of a CLS (or clear screen) command, it really doesn't like me trying to scroll the screen data upwards one line when the cursor tries to go past the bottom of the screen (the idea being to scroll all lines up 'one line' apart from the top line, which would be overwritten, and blank the bottom line).  I'm getting all kinds of write/read errors when I try to copy the data (I'm basically starting at the second line, copying each byte to an address 50 bytes earlier (one line up) and cycling through to the bottom of the screen before blanking the last 50 bytes of data).
I haven't tried these modifications yet.  You're asking me to ignore MREQ and WR, just respond to ANY RD or WR trigger?  I guess the 'valid_address' would gate reads or writes to non-GPU RAM space effectively.
One other thing I've failed miserably at is in z80_bridge.v (attached below).  I want it to ignore reads or writes to addresses above the GPU's RAM space.  The GPU window is 512KB, but I'd like the GPU to return $FF for any reads to addresses above 32 KB (or a user-definable value, at least).  This is important for two reasons - it prevents bad data being returned and the Microcom determines if a memory bank is RAM, ROM, or something else by the values it receives when it reads the last page of a 16KB block of memory.  I'd like the GPU to be able to return a pre-defined value if a read to that page is detected.  What I've tried in z80_bridge just isn't working - I'm just getting garbled data (all the time), even when accessing the proper GPU RAM.  mem_valid is the trigger I'd set up, commented out in the z80_bridge code.  Would appreciate some tips (from anyone!) on getting that particular requirement working.
Post by: BrianHG on January 04, 2020, 11:52:09 am
Ok,...
Here we go....
I replaced your data_mux with a dumb AB, back and forth version.
I changed RS232_Debugger to operate at 125MHz.
I corrected your Z80_bridge as it wasn't posting and releasing the reads correctly.
Using the PC RS232_Debugger software, you can set debug port bits 'OUT3[6]' and 'OUT3[7]' to change which edge or edges of the  Z80_CLK input the bus controls will be latched on.
OUT3[6] is active low, when low, the Z80_bridge will latch the Z80 bus controls on the falling edge of the Z80_CLK input.  When high, the falling edge clock is disabled.
OUT3[7] is active high, when high, the Z80_bridge will latch the Z80 bus controls on the rising edge of the Z80_CLK input.  When low, the rising edge clock is disabled.
Enabling both clock edge control bits means that the Z80_bridge double clocks, once on the rising, then again on the falling.
*** You did not do your assignments 'Fast Input/Output/OE' for all your bus controls and OEs.  You have 2 choices, assign setup and hold timing settings in nanoseconds, or, use the 'Fast ***' feature to achieve the best possible logic cell placement of each IO for best clocking capability.  Without these assignments, every time you compile your project, each IO pin will randomly be slower or faster since the compiler will try to best locate the internal logic and not care about the speed and performance of your IOs.  This means every compile, your Z80 bus may get random IO errors which may have nothing to do with any code changes.  This is FPGA 101.
Post by: nockieboy on January 04, 2020, 12:51:40 pm
Ok,...
Here we go....
Thanks for the patch - I'm looking at the assignments currently and am getting them sorted first.  It may be FPGA 101, but as I'm starting out learning about FPGAs then maybe I can be forgiven for not knowing about this just yet?  ;)  Just to make sure, I'm in the Assignment Editor, going down the list of pins/IO connections, and changing 'Location' in the 'Assignment Name' column to Fast Output or Fast Input Register as appropriate, then selecting 'On' in the 'Value' column in place of the PIN_xx number that was there?  What do I do with the bi-directional Z80_data pins?
Post by: BrianHG on January 04, 2020, 01:16:10 pm
You have other errors:
Warning (176225): Can't pack node Z80_bridge:inst7|gpu_addr[13] to I/O pin
   Warning (176228): Can't pack node Z80_bridge:inst7|gpu_addr[13] and I/O node Z80_ADDR[13] -- I/O node is a dedicated I/O pin
Warning (176225): Can't pack node Z80_bridge:inst7|gpu_addr[12] to I/O pin
   Warning (176228): Can't pack node Z80_bridge:inst7|gpu_addr[12] and I/O node Z80_ADDR[12] -- I/O node is a dedicated I/O pin
Warning (176225): Can't pack node Z80_bridge:inst7|gpu_addr[10] to I/O pin
   Warning (176228): Can't pack node Z80_bridge:inst7|gpu_addr[10] and I/O node Z80_ADDR[10] -- I/O node is a dedicated I/O pin
Warning (176225): Can't pack node Z80_bridge:inst7|gpu_addr[11] to I/O pin
   Warning (176228): Can't pack node Z80_bridge:inst7|gpu_addr[11] and I/O node Z80_ADDR[11] -- I/O node is a dedicated I/O pin
Also, something weird, is says that :
   Warning (13410): Pin "245_DIR" is stuck at GND
This needs to be fixed...
Give me 30 minutes...
Post by: nockieboy on January 04, 2020, 01:20:43 pm
I didn't get those errors - but just compiled the project and got some messages about ignoring invalid assignments (funnily enough, all the fast assignments I'd made) and when running the GPU, the RS232_debugger reads/writes just fine, but nothing is displaying from the Microcom.  :-//
Post by: BrianHG on January 04, 2020, 01:40:53 pm
Here you go, latest assignments added and fixed the Z80_bridge code, it should now work, but:
[attach=1]
I've added the assignments, 4 errors appear on 4 address lines.  Check the compilation reports now.
Did you wire those to dedicated inputs?  Their timing will not match the other address inputs if you do that.
Warning (176250): Ignoring invalid fast I/O register assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
You may want to move those 4 pins to regular IOs, they may create addressing errors.
Try out the new attached version.
Post by: BrianHG on January 04, 2020, 01:46:29 pm
OOOPPPSSS Change this 1 line, LINE #62 in the Z80_bridge to what I've written below:
assign Read_GPU_RAM_END =  Z80_clk_trig && (~Z80_read || ~Z80_mreq || ~mem_window) ;   // Define the ending of a Z80 read request of GPU Ram.
Post by: nockieboy on January 04, 2020, 02:01:37 pm
(Attachment Link)
Oooh... maybe.  I just connected up the wires consecutively to the IO pins on the dev board, I didn't give any thought as to the type of pin they were... Chalk that one up to learning about FPGAs!  :-//
So I'm going to need to find alternative pins for those connections then.  ::)  Running out of pins if I want to use 24-bit RGB output as well (I've got 8 left, not including the mass of pins over the other side of the board I'd reserved for the video output...)
Haha! Caught me mid-compilation, too.  ;)
Okay, hmmm... it's not working - I'm getting the usual display output on the screen, but when I start up the Microcom it displays the usual 'Press space to begin' in the console, but when I press space nothing happens - it just locks up - and that's before it does anything with trying to access the GPU RAM...  ???
Post by: BrianHG on January 04, 2020, 02:04:45 pm
In the RS232 debugger, try setting the OUT3[7] bit to 1.
Post by: nockieboy on January 04, 2020, 02:10:18 pm
Okay, that stops the Microcom from hanging - but there's no output on the screen because it seems the writes are not being received properly at all.  The GPU RAM is getting corrupted badly, with $FFs where there's no writing going on, and $00s where a value should be written...
Post by: BrianHG on January 04, 2020, 02:11:25 pm
Try changing these 3 lines:
assign Write_GPU_RAM =  mem_window && Z80_mreq && Z80_write; // Define a GPU Write action - only write to address within GPU RAM bounds
assign Read_GPU_RAM_BEGIN =  mem_window && Z80_mreq && Z80_read;   // Define the beginning of a Z80 read request of GPU Ram.
assign Read_GPU_RAM_END =  ~Z80_read ;   // Define the ending of a Z80 read request of GPU Ram.
This ignores the clocks and makes the FPGA look like static ram.
Post by: BrianHG on January 04, 2020, 02:16:24 pm
Ok, here is a new fix for the Z80 bridge:
module Z80_bridge (
// input
input wire reset, // GPU reset signal
input wire GPU_CLK, // GPU clock (125 MHz)
input wire Z80_CLK, // Microcom clock signal (8 MHz)
input wire Z80_M1n, // Z80 M1 - active LOW
input wire Z80_MREQn, // Z80 MREQ - active LOW
input wire Z80_WRn, // Z80 WR - active LOW
input wire Z80_RDn, // Z80 RD - active LOW
input wire [21:0] Z80_addr, // Microcom 22-bit address bus
input wire [7:0] Z80_wData, // Z80 DATA bus to pass incoming data to GPU RAM
input wire [7:0] gpu_rData,
input wire gpu_rd_rdy, // one-shot signal from mux that data is ready
// output
output reg Z80_245data_dir, // control level converter direction for data flow - HIGH = A -> B (toward FPGA)
output reg [7:0]  Z80_rData, // Z80 DATA bus to return data from GPU RAM to Z80
output reg Z80_rData_ena, // flag HIGH to write data back to Z80
output reg Z80_245_oe, // OE for 245 level translator *** ACTIVE LOW ***
output reg gpu_wr_ena, // flag HIGH for 1 clock when writing to GPU RAM
output reg gpu_rd_req, // flag HIGH for 1 clock when reading from GPU RAM
output reg [19:0] gpu_addr, // connect to Z80_addr in vid_osd_generator to address GPU RAM
output reg [7:0]  gpu_wdata, // 8-bit data bus to GPU RAM in vid_osd_generator
    input wire  sel_pclk,  // make HIGH to trigger the Z80 bus on the positive edge of Z80_CLK
    input wire  sel_nclk   // make LOW  to trigger the Z80 bus on the negative edge of Z80_CLK
// TODO:
// 1) Prevent reads to GPU RAM above top of GPU RAM
// 2) Respond with appropriate data to any requests from Microcom ROM identification routines
parameter MEMORY_RANGE  = 3'b010; // Z80_addr[21:19] == 3'b010 targets the 512KB 'window' at 0x100000-0x17FFFF (Socket 3 on the Microcom)
parameter DELAY_CYCLES  = 0; // number of cycles to delay write for 245
parameter MEM_SIZE_BITS = 15; // number of cycles to delay write for 245
wire mem_window, Z80_mreq, Z80_write, Z80_read, Write_GPU_RAM;
wire Read_GPU_RAM_BEGIN, Read_GPU_RAM_END, mem_valid_range;
wire Z80_clk_pos,Z80_clk_neg,Z80_clk_trig;
reg Z80_clk_delay;
reg [9:0] Z80_write_sequencer;
//reg [18:0] rd_addr;
//assign mem_valid  = (rd_addr[15] == 1'b0); // HIGH if address is inside GPU RAM bounds (GPU RAM may not fill the 512KB host memory window, so this flag determines if the address is within GPU RAM bounds)
assign Z80_clk_pos   = ~Z80_clk_delay &&  Z80_CLK;
assign Z80_clk_neg   =  Z80_clk_delay && ~Z80_CLK;
assign Z80_clk_trig  = (Z80_clk_pos && sel_pclk) || (Z80_clk_neg && ~sel_nclk);
assign mem_window = (Z80_addr[21:19]            == MEMORY_RANGE); // Define an active memory range
assign Z80_mreq     = ~Z80_MREQn && Z80_M1n; // Define a bus memory access state
assign Z80_write = ~Z80_WRn; // Isolate a single write transaction
assign Z80_read     = ~Z80_RDn; // Isolate a single read transaction
assign mem_valid_range    = (gpu_addr <  2**MEM_SIZE_BITS); // Define GPU addressable memory space
always @ (posedge GPU_CLK) begin
Z80_write_sequencer[9:0] <= { Z80_write_sequencer[8:0], Write_GPU_RAM };
if ( Write_GPU_RAM )                 Z80_245data_dir  <= 1'b1; // set 245 dir toward FPGA
if ( Write_GPU_RAM )                 Z80_rData_ena    <= 1'b0; // set FPGA pins to input (should be by default)
if ( Write_GPU_RAM )                 Z80_245_oe       <= 1'b0; // enable 245 output (WAS 1 - moved forward to step 0)
if ( Z80_write_sequencer[DELAY_CYCLES] )  gpu_addr         <= Z80_addr[18:0];// latch address bus onto GPU address bus
if ( Z80_write_sequencer[DELAY_CYCLES] )  gpu_wdata        <= Z80_wData; // latch data bus onto GPU data bus
if ( Z80_write_sequencer[DELAY_CYCLES] )  gpu_wr_ena       <= 1'b1; // turn on FPGA RAM we
if ( Z80_write_sequencer[DELAY_CYCLES + 2] )  gpu_wr_ena       <= 1'b0; // turn off FPGA RAM we (WAS STEP +2, now STEP +3 for additional WR)
if ( Read_GPU_RAM_BEGIN ) begin
gpu_addr <= Z80_addr[18:0];// pass address to GPU RAM (cropped to 512KB range as that's all we're interested in)
gpu_rd_req <= 1'b1; // flag a read request to the mux which is one-shotted in the mux
Z80_245data_dir     <= 1'b0; // set 245 direction (TO Z80)
Z80_rData_ena     <= 1'b1; // set bidir pins to output
end else begin
gpu_rd_req <= 1'b0; // end GPU read req after 1 pulse
if ( Read_GPU_RAM_END && ~Write_GPU_RAM ) begin
Z80_rData_ena <= 1'b0; // re-set bidir pins to input
end
end
if ( gpu_rd_rdy ) begin
if (mem_valid_range) Z80_rData[7:0] <= gpu_rData[7:0];// Latch the GPU RAM read into the output register for the Z80
else Z80_rData[7:0]  <= 8'b11111111; // return $FF if addressed byte is outside the GPU's upper RAM limit
end
//last_Z80_WR <= Z80_WRn;
//last_Z80_RD <= Z80_RDn;
Z80_clk_delay <= Z80_CLK; // find the rising clock edge
end
endmodule
When not reading, it would always reset the 245 buffer even if a write was being performed.  I had to make a few changes...
Post by: nockieboy on January 04, 2020, 02:17:32 pm
Everything is overwritten with $FF now.  Just updated with your latest post and re-compiling.  Will update with results of that code in a minute or three.
Post by: BrianHG on January 04, 2020, 02:19:42 pm
Check my last msg.
Post by: nockieboy on January 04, 2020, 02:21:50 pm
module Z80_bridge (
// input
// output
// TODO:
reg Z80_clk_delay;
end else begin
end
end
end
end
endmodule
Ookay... the writes seem to be working, I can see the correct settings for the text mode when the Microcom boots into the DMI, but everywhere else is $FF... which means the screen display is corrupted because ALL the unused HV triggers, HW_regs, MAGGIEs etc are filled with $FF values.
Post by: nockieboy on January 04, 2020, 02:25:50 pm
... but with bit 7 set HIGH in OUTPUT[3] in the debugger, the mass of $FF's stops.  Output to the screen is corrupted, though - looks like some chars are being displayed twice.
Post by: nockieboy on January 04, 2020, 02:29:11 pm
No, I take that back - bit 7 isn't making a difference.  Writes are corrupted, so sometimes enough get through to set up the display properly, but there is visible corruption in the on-screen text, other times the display setup is corrupted and all kinds of weirdness happen.
Post by: BrianHG on January 04, 2020, 02:30:53 pm
Ok, I've made the reads and writes snap for 1 shot.
module Z80_bridge (
// input
// output
// TODO:
reg Z80_clk_delay, last_Z80_WR, last_Z80_RD;
assign Z80_write = ~Z80_WRn && last_Z80_WR; // Isolate a single write transaction
assign Z80_read     = ~Z80_RDn && last_Z80_RD; // Isolate a single read transaction
assign Z80_readn     =  Z80_RDn && ~last_Z80_RD; // Isolate a single read transaction
assign Read_GPU_RAM_END =  Z80_readn ;   // Define the ending of a Z80 read request of GPU Ram.
if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_wr_ena       <= 1'b0; // turn off FPGA RAM we (WAS STEP +2, now STEP +3 for additional WR)
end else begin
if ( Read_GPU_RAM_END ) begin
end
end
end
end
endmodule
Post by: BrianHG on January 04, 2020, 02:36:08 pm
Ok, I just patched the 'mem_valid_range' bug for the reads (fixes the reading of only 'FF'):
module Z80_bridge (
// input
// output
// TODO:
wire Read_GPU_RAM_BEGIN, Read_GPU_RAM_END;
reg Z80_clk_delay, last_Z80_WR, last_Z80_RD, mem_valid_range;
mem_valid_range  <= (gpu_addr[18:0] <  2**MEM_SIZE_BITS); // Define GPU addressable memory space
end else begin
end
end
end
end
endmodule
Post by: nockieboy on January 04, 2020, 02:38:05 pm
ONE thing that is consistent, though, is that the Microcom is reporting the correct amount of memory now - so the changes to the Z80_bridge to prevent reads/writes above the memory limit obviously works.  :-+
module Z80_bridge (
// input
// output
// TODO:
end else begin
end
end
end
end
endmodule
Hmm... nope.  Reads/writes are all over the place - and the GPU seems to be driving the data pins at the wrong time as the Microcom is sometimes crashing as well.  I'm just compiling your latest post with the patched 'mem_valid_range'.
Post by: nockieboy on January 04, 2020, 02:42:55 pm
Latest patch compiled and tested - writes to the GPU are corrupted; display setup is corrupted as a result and at one point I could see what I was typing into the Microcom via the console appearing on the screen, but the characters didn't match what I was typing.  Several resets later and during one reset, the Microcom crashed.
Post by: BrianHG on January 04, 2020, 02:54:34 pm
Try this:
module Z80_bridge (
// input
// output
// TODO:
assign Z80_readn     =  Z80_RDn; // Isolate a single read transaction
end else begin
end
end
end
end
endmodule
I can only recommend changing those 4 address pins if this doesn't work.
Also, try doing some reads exclusively to see if they work with the correct data before doing any writing.
Post by: BrianHG on January 04, 2020, 03:03:02 pm
Note that the writes outside the 32kb range are not protected.  Also, I might need to turn off the 245 at the end of a read....
try this:
module Z80_bridge (
// input
// output
// TODO:
if ( Z80_write_sequencer[DELAY_CYCLES] )  gpu_wr_ena       <= (gpu_addr[18:0] <  2**MEM_SIZE_BITS); // Define GPU addressable memory space  -  turn on FPGA RAM we
end else begin
   Z80_245_oe <= 1'b1; // enable 245 output
end
end
end
end
endmodule
Post by: BrianHG on January 04, 2020, 03:15:55 pm
Which Z80 are you using?
EXACT part number! Manufacturer name as well.
The timing on the data sheet has some NEGATIVE setup times for the bus control signals on some models.
Post by: nockieboy on January 04, 2020, 03:22:42 pm
Right.  So you may be on to something here.  I've been convinced I'm using an 8 MHz CPU, but it would appear not and this is quite embarrassing.  :-[  It's a Zilog Z80, Z84C0010PEG.  A 10 MHz model.
That could be the cause of the timing headaches right there. (It is DEFINITELY running at 8 MHz, however). :palm:
Post by: nockieboy on January 04, 2020, 03:27:51 pm
CANCEL THAT.
It's a Zilog Z84C008PEG CPU.
Sorry for the confusion.  My main Microcom is wired up to the GPU and the CPU isn't the top card, so I couldn't get to it without taking the stack apart, so I referred to my second Microcom I've got sitting on a shelf - it would appear THAT one has a 10 MHz CPU in it.  I've just disassembled my main Microcom stack and checked out the CPU - it's definitely an 8 MHz Zilog part.
Raises an interesting point though - I got both the Z80's at the same time from the same supplier a few years ago...  :-//
Post by: nockieboy on January 04, 2020, 03:37:04 pm
The project was working mostly at the start of the day - it only seemed to fall over when I tried to scroll the screen.  I might roll back to that state and try to sort out the pins that can't be assigned with fast regs, unless there's any changes you've made that definitely need to stay in?
Post by: BrianHG on January 04, 2020, 04:06:13 pm
CANCEL THAT.
ok, blahhh, anyways, try this after a bunch of code changes for the 10&20mhz variants...:
module Z80_bridge (
// input
// output
// TODO:
parameter MREQ_DLY_CLK  = 0; // number of cycles +1 to delay mreq trigger
wire Z80_mreq, Z80_mreq_pulse, Z80_write, Z80_read, Write_GPU_RAM;
reg Z80_clk_delay, last_Z80_WR, last_Z80_RD, mem_valid_range, MREQn_dly, MREQn_dly2, mem_window ;
reg [9:0] Z80_write_sequencer,Z80_mreq_dly;
assign Z80_mreq_pulse = ~Z80_mreq_dly[MREQ_DLY_CLK] && Z80_mreq_dly[MREQ_DLY_CLK+1];
assign Z80_mreq     = ~Z80_mreq_dly[MREQ_DLY_CLK+1] && Z80_M1n; // Define a bus memory access state
assign Write_GPU_RAM =  mem_window && Z80_mreq && Z80_write && mem_valid_range; // Define a GPU Write action - only write to address within GPU RAM bounds
assign Read_GPU_RAM_BEGIN =  mem_window && Z80_mreq && Z80_read && mem_valid_range;   // Define the beginning of a Z80 read request of GPU Ram.
Z80_mreq_dly[9:0] <= { Z80_mreq_dly[8:0], Z80_MREQn };
if (Z80_mreq_pulse) begin
gpu_addr         <=  Z80_addr[18:0];                         // latch address bus onto GPU address bus
mem_valid_range  <= (Z80_addr[18:0]  <  2**MEM_SIZE_BITS); // Define GPU addressable memory space
mem_window   <= (Z80_addr[21:19] == MEMORY_RANGE); // Define an active memory range
end
if ( Z80_write_sequencer[0] )                 Z80_245_oe       <= 1'b0; // enable 245 output (WAS 1 - moved forward to step 0)
if ( Z80_write_sequencer[DELAY_CYCLES + 2] )  Z80_245_oe <= 1'b1; // disable 245 output
end else begin
end
end
end
end
endmodule
I would still change those 4 pins if possible.  All addresses should be on a similar matching IO type.  Same for all data.
Do you have enough GND connections between the Z80 and GPU?
You might have massive ground bounce happening...
Post by: BrianHG on January 04, 2020, 04:28:57 pm
Ok, go to this version:
module Z80_bridge (
// input
// output
// TODO:
wire Z80_mreq, Z80_mreq_pulse, Z80_unmreq_pulse, Z80_write, Z80_read, Write_GPU_RAM;
assign Z80_unmreq_pulse = Z80_mreq_dly[MREQ_DLY_CLK] && ~Z80_mreq_dly[MREQ_DLY_CLK+1];
assign Z80_read     = ~Z80_RDn ; // Isolate a single read transaction
end else if (Z80_unmreq_pulse) begin
mem_valid_range  <= 1'b0; // Define GPU addressable memory space
mem_window   <= 1'b0; // Define an active memory range
end
end else begin
end
end
end
end
endmodule
Post by: nockieboy on January 04, 2020, 04:36:37 pm
I woul still change those 4 pins if possible.  All addresses should be on a similar matching IO type.  Same for all data.
It's top of my to-do list now.
Errrr... *goes away and looks up ground bounce*  Hmm... maybe not.  Just to explain the setup - I have the Microcom, I have a single breadboard with the level converters on it, then I have the FPGA dev board.
The Microcom's GND is connected to the breadboard via a single wire.  The breadboard GND is connected to the FPGA GND via a single wire.
I'm doubting that fulfils the 'enough GND connections between the Z80 and GPU question...  :o
Previous code changes doesn't help - mostly getting $FFs written to GPU RAM.  PEEK is returning garbage.  Seems to be just returning $1A.
module Z80_bridge (
// input
// output
// TODO:
end
end else begin
end
end
end
end
endmodule
Compiling as we speak.
Post by: BrianHG on January 04, 2020, 04:38:07 pm
module Z80_bridge (
// input
// output
// TODO:
end
end else begin
end
end
end
end
endmodule
Error, fix this line #59:
1 GND wire, WTF??????
You should have 1 GND wire for every 2-4 signal wires.  Otherwise the GND is waving up and down, bouncing with it's lower impedance and inductance characteristics, messing up everything.
A proper high frequency design usually has 1-1.  Like your old IDE/floppy drive cables, 1 row side was almost all GND wires.
Post by: BrianHG on January 04, 2020, 04:44:03 pm
I had better not been fiddling with all this just because you used 1 tiny thin ground wire which was competing against 35 CPU IO signals...
Post by: BrianHG on January 04, 2020, 05:12:15 pm
Also try these parameter settings:
parameter DELAY_CYCLES  = 2;      // number of cycles to delay write for 245
parameter MREQ_DLY_CLK  = 2;      // number of cycles +1 to delay mreq trigger
Don't forget to update the symbol and edit the 2 values on the top hierarchy.
This slows down, adds a delay to the latching of the address and data during the read and write.
Post by: nockieboy on January 04, 2020, 06:19:45 pm
Each IO group is grounded and is working at no more than 8 MHz, which is better than nothing I guess?  It was working fine(-ish) this morning and yesterday with only the one ground...  but that's not to say this test setup is anything near suitable - one reason I'm hoping to get a custom dev board created soon. :-[
Okay, that's a step forward - but it seems the data is still getting randomly corrupted.  It was able to display text on the screen this time and I could write some stuff there to test it.  It seems to be dropping characters and replacing them with null bytes ($00).
Post by: nockieboy on January 04, 2020, 06:40:39 pm
Reading seems to be quite accurate with individual PEEKs, but when I try to dump a page from the GPU, the system locks up.  Seems to lock up frequently trying to initialise the GPU as well.
For a sanity check, earlier I tested the project from this morning which I backed-up before we started making all these changes (at least I think I did before we made any sweeping changes).  It still works, but not very well - so I'm holding making any more changes until tomorrow when I can sort out exactly what's going wrong (it's going to be a bad connection on one of the buses) with a fresh head.   :palm:
Post by: BrianHG on January 05, 2020, 01:34:04 am
Ok.  Without superimposed multichannel scope shots, I cant tell if all your addresses are properly being asserted at the same time or not.
If you have a logic analyzer, you will want one with a good 100MHz sampling rate on at least half the data and and the first addresses + buss control signals, including the 'WAIT' states which may be asserted by a third device on the bus.
I made the current code sample the address at the fall of MREQn, after the fall of MREQ_DLY_CLK which run at 125MHz.
I downloaded the newer Zlog Z80 documents which have the 8/10/20 MHz variants included.  The bus transactions and timing is not as simple as that old dumb 4MHz data sheet.  The MREQn going up and down between bus cycles is not guaranteed, or, it can be such a small value in NS, that unless we make a true static interface, or a proper synchronous interface, things will go haywire.  Also, there are other cycles right after transactions, like refresh cycles, or program code fetch which may also hold or shrink the MREQn.
It's not that the interface needs to be any more complicated that it is, it that I cannot see what is going on remotely and 95% of the Z80 docs out there assume a cheap static type design.  And with you bread board wiring & choice of voltage level shifting, and choice of IOs, I'm not sure where the true problem is creeping in.
Post by: BrianHG on January 05, 2020, 09:02:23 am
Upload the latest copy of what you are compiling with...
Post by: nockieboy on January 05, 2020, 12:15:28 pm
Attached is latest copy of the project with all the changes made yesterday.
Post by: nockieboy on January 05, 2020, 12:25:35 pm
My scope is next to useless for digital testing and my logic analyser isn't really up to that sort of work - it's just an 8-channel 25 MHz 'cheapy' off eBay.  It's served me just fine building the Microcom, but we're well out of '8 MHz-league', here.
I have a bit of time right now, so I'm going to try and sort the address bus and get those offending lanes moved to fast-input pins.
I know, it's a haystack and there's probably some fake needles in there to confuse things as well.  Is there a better way of doing the voltage level shifting then?  I'm always open to suggestions and guidance!
Post by: BrianHG on January 05, 2020, 12:48:46 pm
Without seeing, I have nothing to go on.
Try changing these 2 values:
This should accelerate the response.  If it doesn't work, we can try full static approach.  However, this isn't too wise a strategy for future upgrade.
Also, you shouldn't use pins 88,89,90,91 for your addresses.  Please move them.
For these pins, you should only use them for Z80_CLK, only, or you may also tie MREQ, RD, WR to these pins as well.  They are dedicated inputs and their timing to logic cells slightly differs to the main IOs where the rest of the addresses are wired.
This is important especially if we want to clock off of the Z80_CLK input.
Also, in assignment settings, compiler settings, 'Advanced Settings (Fitter)...', please turn on :
Perform Register Retiming For Performance.
PLEASE SWAP THE INPUT PINS LIKE I SAID...
Post by: BrianHG on January 05, 2020, 01:06:49 pm
Its more than just level shifting.  With a bread board and 1 GND wire to something like 35 signal wires, do you have proper signal termination?
What does your signal bounce look like?  The FPGA is still sensitive to signals in the 100MHz to 200MHz range even though the Z80 may only be sensitive to 20MHz.
When you build a PCB, will you be able to do proper resistor series and parallel termination on the right sides of the CMOS buffers?
Can you measure the signal bounce?
Without the above question being answered, you may want to use series resistor packs in dip or sip form so you may insert alternate values, or, you will have to design a quality layout PCB, with more than 1 GND wire going to the Z80...
Post by: nockieboy on January 05, 2020, 02:03:51 pm
Okay, that's done, but shouldn't there be some delay for the 245 to enable?
Okay, the offending address lanes have been moved to alternate input pins (84, 86, 105 & 106) - I've moved the Z80_CLK line to pin 90.
Done.  Am just testing the output now - seems with DELAY_CYCLES set to zero and MREQ_DLY_CLK set to zero, I'm unable to read or write to the GPU RAM, although the Microcom was stable.  Have just tried it with DELAY_CYCLES back to 2, that wasn't good - Microcom wouldn't boot into the DMI (where the GPU is set up) without locking up and the GPU RAM being corrupted.
Post by: nockieboy on January 05, 2020, 02:10:29 pm
Aaaaaand it's at this point I realise I'm in waaaay over my head!   :o :o :o ???
How do you prototype circuits that run at silly speeds (100MHz+) if breadboard (clearly) isn't up to the task?
Post by: BrianHG on January 05, 2020, 02:14:19 pm
Ok, this one is static read, one shot write:
module Z80_bridge (
// input
// output
// TODO:
//if (Z80_mreq_pulse) begin
//end else if (Z80_unmreq_pulse) begin
// mem_valid_range  <= 1'b0; // Define GPU addressable memory space
// mem_window   <= 1'b0; // Define an active memory range
//end
end else begin
//if ( Read_GPU_RAM_END ) begin
// end
end
end
end
endmodule
Change the 2 delay parameters to 0, then try 1 and 2.  The parameters should only effect the writes.
Also, if your get timing violations, IE an FMAX too low, disable the 'register retiming' feature I told you to turn on earlier.
Post by: BrianHG on January 05, 2020, 02:20:17 pm
Good thick grounding wiring.  Decoupling caps everywhere, and, wire-wrap or soldered prototype boards usually do the trick.
Post by: BrianHG on January 05, 2020, 02:28:01 pm
Ooops, logic bomb on the 245 controls during write.  Here is the fix:
module Z80_bridge (
// input
// output
// TODO:
//end
if ( Read_GPU_RAM_BEGIN && Z80_WRn ) begin
end else begin
if ( Z80_WRn ) begin
end
end
end
end
endmodule
Delay cycles needs to be at least 2.
Post by: nockieboy on January 05, 2020, 02:42:04 pm
Everything has decoupling caps - all the chips on the breadboard are decoupled (I'm using SOIC->DIP converters with a 100nF cap on the mini-PCB).  There's two GND wires now (yay!) connecting the breadboard to both the FPGA and the Microcom.
Am just testing the delay settings now:
Both DLY valuse set to 0: Reading the GPU RAM caused a system crash.  Timing's definitely out on the 245, I presume.
Both DLY values set to 1: Writing any value to the GPU RAM writes $FF to that location.  Any read crashes the system.
Both DLY values set to 2: Writing any value to the GPU RAM writes $FF to that location.  Any read crashes the system.
EDIT: Just spotted your last post! Above results don't take that into account.
Post by: BrianHG on January 05, 2020, 02:50:34 pm
Ooops, accidentally delaying the 'MREQ'.  Ok, this one should work and not crash the system.
module Z80_bridge (
// input
// output
// TODO:
//end
end else begin
end
end
end
end
endmodule
Post by: nockieboy on January 05, 2020, 03:13:05 pm
Okay, with that latest update:
 DELAY_CYCLES  |   MREQ_DLY_CLK   |  RESULTS
          2             |              2              | Unstable. Crash on read. Write only writes $FF to GPU RAM.
          2             |              1              | Unstable. Crash on read. Write only writes $FF to GPU RAM.
          2             |              0              | Unstable. Crash on read. Write only writes $FF to GPU RAM.
1) When I've tried writing, I've tried values $00, $55, $AA, $01 etc. to a variety of addresses across the entire first page of GPU RAM.
2) Unstable means it's taken a couple of resets to get the Microcom's Bootstrap to show on the console.  The Bootstrap does nothing to the GPU, other than a quick write/read loop through all the banks of memory to ascertain what's RAM and what's ROM.  It's most likely the read part of that routine that is causing the crash when it tries to write to, then read from the GPU memory.
3) All attempts to read data manually (via the PEEK command) have resulted in a crash.
Should I start increasing the DLY values?
Post by: BrianHG on January 05, 2020, 03:33:55 pm
Seriously man, the read shouldn't be able to crash.  The read delay is being ignored.  It only delays the write capture of the Z80's data output.
Try this:
module Z80_bridge (
// input
// output
// TODO:
//end
end else begin
   //Z80_245_oe <= 1'b1; // disable 245 output
end
end
end
end
endmodule
If this one still crashes on read, something went haywire with your wiring changes, or new IO pin assignments, or breadboard wiring contacts.
When single writing, make sure the written 'FF' appear in the correct address.  It would seem your are not outputting the 245 to the GPU FPGA.  This may mean controls to the 245, or it's VCC/GND isn't wired good.
Post by: nockieboy on January 05, 2020, 03:59:12 pm
Try this:
I know, it's weird.  I've had this a lot during development, though, so I almost figure it's normal for electronics development.. I take it that it isn't.  ???  It's likely a loose connection somewhere, which frustrates me even more.
Well, that last update has certainly done something.
Writing to GPU RAM is now a little hit and miss - sometimes characters are dropped for null ($00) values, but infrequently.  I can almost get the DMI boot screen to display, but because of the write errors the Microcom isn't setting up the display properly.  If I load the default values using the RS232_debugger, I can see what I'm writing on the screen (but with the odd dropped character as mentioned previously).
Reading values appears to be solid - even if I 'dump' the entire first page of the GPU RAM to the console/screen, it's reading it accurately.
Here's the settings I'm using for this build:
DELAY_CYCLES  2
MREQ_DLY_CLK 0
Post by: BrianHG on January 05, 2020, 04:04:35 pm
Increase the delay cycles to 4 or 6 or 8 or 10 or 12.
You may have to increase the delay register size and it's shift register values...
Post by: nockieboy on January 05, 2020, 04:16:19 pm
Will do - not changing MREQ_DLY_CLK at all, right?
Post by: BrianHG on January 05, 2020, 04:17:53 pm
Its no longer being used...
Post by: nockieboy on January 05, 2020, 04:23:24 pm
Aha, okay - removed it from the parameter block then.  Just tried with DELAY_CYCLES set to 4 - still dropping chars, but noticed that the screen actually shifted up a couple of lines when I got to the bottom, with minimal corruption, so it seems we're going in the right direction..  :-+
Post by: BrianHG on January 05, 2020, 04:31:46 pm
Go to a delay of 8.
Post by: BrianHG on January 05, 2020, 05:15:02 pm
This version is fully static, the delays are ignored...
module Z80_bridge (
// input
// output
// TODO:
assign Z80_write = ~Z80_WRn ; // && last_Z80_WR; // Isolate a single write transaction
//end
// Z80_write_sequencer[9:0] <= { Z80_write_sequencer[8:0], Write_GPU_RAM };
// if ( Z80_write_sequencer[0] )                 Z80_245data_dir  <= 1'b1; // set 245 dir toward FPGA
// if ( Z80_write_sequencer[0] )                 Z80_rData_ena    <= 1'b0; // set FPGA pins to input (should be by default)
// if ( Z80_write_sequencer[0] )                 Z80_245_oe       <= 1'b0; // enable 245 output (WAS 1 - moved forward to step 0)
// if ( Z80_write_sequencer[DELAY_CYCLES] )  gpu_wdata        <= Z80_wData; // latch data bus onto GPU data bus
// if ( Z80_write_sequencer[DELAY_CYCLES] )  gpu_wr_ena       <= 1'b1; // turn on FPGA RAM we
// if ( Z80_write_sequencer[DELAY_CYCLES + 1] )  gpu_wr_ena       <= 1'b0; // turn off FPGA RAM we (WAS STEP +2, now STEP +3 for additional WR)
if ( Write_GPU_RAM ) begin
end else begin
end
end else begin
end
end
end
end
endmodule
If this works, first I'll need to do a cleanup, then we'll decide what to do next...
Post by: nockieboy on January 05, 2020, 06:37:06 pm
Oh boy does it work... CLS is clearing the screen nicely now and screen scrolling is working great with no artefacts at all...   ;D
[attachimg=1]
Post by: BrianHG on January 06, 2020, 12:01:50 am
I need a copy of your current project.
Post by: nockieboy on January 06, 2020, 08:19:57 am
Oops...  ::)  Here it is.
Post by: BrianHG on January 06, 2020, 11:29:10 am
Ok, here you go.
I cleaned up the project.  I had to also patch the MUX algorithm.
First, try the complete cleaned project 'GPU_Z80_bridge_staticIO.zip'.
If everything is ok, then switch the Z80_Bridge.v to the attached 'Z80_bridge_1-write.v'.  This version only does 1 single write to the GPU ram once at the end of every write cycle instead of 62.5 million writes / second during the entire time the Z80_WRn signal is low with a valid address.
Only if the 1-write version works, next switch to the 'Z80_bridge_1-read.v', 1 read / cycle version.  This version will send out a single read_req to the GPU ram at the beginning of the read cycle, latch the result and hold it on the output while the Z80_RDn is low instead of the static version which does a continuous 62.5 million reads / second during the entire time the Z80_RDn is low.
If the 1 read version works, then you have a good Z80 bridge interface which will eat practically no clock cycles from the GPU ram as a read and write to and from GPU ram will only come around once every 6 or more 8 MHz clock cycles.
In the future, it may be possible to enhance the MUX.v to better select the source A/B - READ/WRITE ports based on priority, but for now, it basically does a dumb 1 clk A, 1 clk B cycle.
Post by: nockieboy on January 06, 2020, 12:55:38 pm
Ok, here you go.
I seem to be fighting with a little instability today with one (or several) of the connections (which I've confirmed with the previous stable version of the project, it's not specific to the new project and Z80_bridge versions), but that aside, the new updates seems to be working very nicely.
EDIT: No - hang on..  more testing required.
Post by: nockieboy on January 06, 2020, 01:21:11 pm
No, the Z80_bridge updates aren't working properly - the first one causes write errors.  Haven't tested the second as a result.
Post by: BrianHG on January 06, 2020, 01:36:52 pm
The first one, the one which is in the .zip file, is identical to the one you deemed perfect.  All I've done is remove the comments and unused registers and parameters.
The only other difference is that I turned off the 'Perform Register Retiming For Performance' feature in the assignment settings, compiler settings, 'Advanced Settings (Fitter)...' button.
You can try turning that back on and see if there is a difference.
Post by: nockieboy on January 06, 2020, 02:07:05 pm
The project was fine - it's the first z80_bridge.v.txt update that seems to have caused issues?
Post by: BrianHG on January 06, 2020, 02:08:46 pm
Are you talking about ''Z80_bridge_1-write.v''?
If so, I need to know...
Post by: nockieboy on January 06, 2020, 02:36:36 pm
Yes.  :-+
Post by: BrianHG on January 06, 2020, 03:02:40 pm
Ok, change line 104 of 'Z80_bridge_1-write.v' to this:
gpu_wr_ena      <=  Write_GPU_RAM && ~last_Z80_WR ; // Pulse the GPU ram's write enable at the BEGINNING of the Z80 write cycle.
And test.
Post by: nockieboy on January 06, 2020, 03:30:33 pm
And test.
No, that's not working either - lots of errors caused when writing to the GPU RAM.
Post by: BrianHG on January 06, 2020, 03:44:45 pm
You have got to be kidding me....
Right?
It's almost as if for some silly reason, we need to fire off multiple of the same writes...
Unless the data lines are bouncing around and eventually the right data gets in...
Give this a try.  All I have done is make the gpu_wr_ena go active for 2 consecutive clocks instead of 1 single clock after a Z80 write has been confirmed.
module Z80_bridge (
// input
// output
// TODO:
wire Z80_mreq, Z80_write, Z80_read, Write_GPU_RAM;
wire Read_GPU_RAM;
reg Z80_clk_delay, last_Z80_WR, last_Z80_RD, mem_valid_range, mem_window, last_Z80_WR2, last_Z80_WR3 ;
assign Z80_write = ~Z80_WRn ; // write transaction
assign Z80_read     = ~Z80_RDn; // read transaction
assign Read_GPU_RAM   =  mem_window && Z80_mreq && Z80_read  && mem_valid_range;   // Define the beginning of a Z80 read request of GPU Ram.
//gpu_wr_ena       <= 1'b1; // turn on FPGA RAM we
end else begin
//gpu_wr_ena       <= 1'b0; // turn off FPGA RAM we
end
if ( Read_GPU_RAM ) begin
end else begin
end
if (mem_valid_range) Z80_rData[7:0] <= gpu_rData[7:0];  // Latch the GPU RAM read into the output register for the Z80
end
last_Z80_WR <= Write_GPU_RAM;
last_Z80_WR2 <= last_Z80_WR;
last_Z80_WR3 <= last_Z80_WR2;
last_Z80_RD <= Read_GPU_RAM;
gpu_wr_ena      <= Write_GPU_RAM && ~last_Z80_WR2 ; // Pulse the GPU ram's write enable only once after the Z80 write cycle has completed
//gpu_rd_req      <= Read_GPU_RAM && ~ last_Z80_RD ; // Pulse the read request only once at the beginning of a read cycle.
end
endmodule
Maybe something fishy is going on inside the MUX and it is not seeing the single clock wide write pulse, though, then, the RS232_debugger should also have similar write errors.
Post by: BrianHG on January 06, 2020, 03:55:40 pm
TYPO ERROR:, fix this line 106:
(I just edited the line in the above post as well.)
Post by: nockieboy on January 06, 2020, 04:02:25 pm
That seems to work fine?
Post by: BrianHG on January 06, 2020, 04:16:40 pm
Ok, Good.  Next, the new single cycle read version:
module Z80_bridge (
// input
// output
// TODO:
wire Read_GPU_RAM;
reg Z80_clk_delay, last_Z80_WR, last_Z80_RD, mem_valid_range, mem_window, last_Z80_WR2, last_Z80_WR3, last_Z80_RD2, last_Z80_RD3 ;
end else begin
end
//gpu_rd_req <= 1'b1; // flag a read request to the mux which is one-shotted in the mux
end else begin
//gpu_rd_req <= 1'b0; // end GPU read req after 1 pulse
end
end
last_Z80_RD2 <= last_Z80_RD;
last_Z80_RD3 <= last_Z80_RD2;
gpu_rd_req      <= Read_GPU_RAM  && ~last_Z80_RD2 ; // Pulse the read request only once at the beginning of a read cycle.
end
endmodule
I've done the same thing for the read as the write, so, it should also work fine.
Post by: nockieboy on January 06, 2020, 04:28:31 pm
Yes, that's working.  :-+
Post by: BrianHG on January 06, 2020, 04:35:08 pm
Ok, version 1.0 finished.
Archive it away and show us something 'interesting' working in the Z80.
Post by: nockieboy on January 06, 2020, 05:05:28 pm
Okay, v1.0 project files attached.  Will get something 'interesting' up here in the next few days, work allowing.  :-+
Post by: BrianHG on January 06, 2020, 05:08:25 pm
I still cant believe we got the Z80 bus interface working without a single scope shot or logic analyzer view.
Post by: nockieboy on January 06, 2020, 05:43:53 pm
And there I was worrying that it wasn't working on the first day I connected it all up. ::)  Was starting to think that there was something major wrong with my wiring and you were going to run out of suggestions to try next. :scared:
Post by: nockieboy on January 06, 2020, 05:47:27 pm
I've just realised, I've been spending time trying to get 8-bit and 16-bit text modes working and swapping between them with a command in the DMI... but then I stopped and thought, "Why?"  :-//  Is there any reason I'd need to use 8-bit text mode?  I mean, if the FPGA is so small that the difference between a 2.4 KB and 4.8 KB screen buffer is the difference between it working or not, then there's bigger issues with the choice of FPGA...?
Post by: nockieboy on January 06, 2020, 06:12:48 pm
What would be the most straight-forward way to modify the existing 'return any reads to addresses above mem_valid_range as $FF' to return a byte addressed from a string (say 'GPU v1.0' for example) virtually addressed in the last $0F bytes of each page ($FF bytes) in the ~mem_valid_range?
As a practical example, the Microcom identifies the contents of each 16 KB bank of memory by the last 16 bytes.  If it's a ROM bank (and it's not empty), it'll have something like "DMI v1.34" in the last 16 bytes of that bank.
It'd be handy if the GPU could return the core version, for example, so the Microcom could identify that a GPU is attached and report to the user what version the GPU core is.
I'd be considering something like this (pseudo-code):
      end else begin
          if (mem_ID_range == gpu_addr[13:4]) begin
              Z80_rData[7:0] <= ID_array[gpu_addr[3:0]][7:0];  // where ID_array = ['GPU v1.0' + 8'b11111111] *** for example ***
          else
      end
   end
Post by: BrianHG on January 07, 2020, 07:38:12 am
Now @nockieboy, when we were team-viewing awhile back, you setup a test bench simulation for your Z80_Bridge.  Update it's Z80_bridge.v to the new one, try a few different read addresses and test the code you want to create.
Post by: nockieboy on January 07, 2020, 11:25:47 am
Okay, it's not all that 'interesting', but here's a screenshot of the video output using the memory editor in the DMI:
[attachimg=1]
Post by: nockieboy on January 07, 2020, 11:35:01 am
And a screenshot of the memory editor viewing the first page of the GPU RAM, with the HV_triggers and MAGGIE settings.
[attach=1]
Post by: SiliconWizard on January 07, 2020, 04:33:36 pm
Nice!
Post by: BrianHG on January 07, 2020, 05:57:24 pm
Right off the bat, with 7 layers, if he uses 1 graphics layer, he has another 6 layers for sprites, he can make an authentic hi-res version on games like PacMan.  4 colors for the hires background maze & pellets, and 4 or 16 colors for the player sprites.  Or he can use a colored font layer for the background.
No audio though...
Post by: nockieboy on January 07, 2020, 06:00:13 pm
Playing around with the Z80 code now and 'colouring-in' lots of the output has made me realise how restrictive my MMU is.  4x16KB areas just isn't cutting it anymore - especially if I want to get the GPU running with CP/M; I'm going to have to make it more fine-grained.  I'm halfway through designing a much more flexible MMU in hardware, but I haven't touched that since I started down this FPGA GPU route a couple of months ago - now I'm thinking that I might as well build the MMU into the FPGA, seeing as it has access to (nearly) all the address lines it needs and some spare RAM space. I'm running out of IOs on this dev board though!  :o
PS2 keyboard is next, and whenever @jhpadjustable is up for it, perhaps some sound.  ;D
Post by: BrianHG on January 07, 2020, 06:01:59 pm
Nice!
Already have colored text functional.
Excellent.
Also got rid of the monochrome junk.  ;)
Post by: nockieboy on January 07, 2020, 06:02:30 pm
All I need is another 48 hours in the day, and I'll be set!  ;)
Post by: BrianHG on January 07, 2020, 06:12:31 pm
Can't use simple page-able ram?  You'll get 256 pages of 64kb.  Simple enough to implement in the FPGA, or anywhere else.  Though, I'm not sure about your Z80 code & you will need to reserve a memory location for the paging.  You can also have 2 paging spaces, 1 for executable code and 1 for program data, though, some of the advance features of the Z80 instruction set wont be able to cross page boundaries on their own.
Post by: nockieboy on January 10, 2020, 09:09:19 am
I'll just extend the same system I'm using now from reading A14-A15 and outputting EA14-EA21 to reading A12-A15 and outputting EA12-EA21 to break the banks down to smaller sizes. No issues crossing boundaries - the Z80 just sees 64KB of contiguous RAM, it doesn't know (or care) that the RAM could be made up of banks of RAM from all over a much larger physical memory space.
I'm designing a PCB for the 'next-level' dev board at the moment - it'll fit directly onto my computer and eliminate all the wiring, breadboards and dev board I'm currently contending with.  It'll basically be a v1 final board, but will have perhaps more IO considerations than the final board needs (for testing/developing an SD interface, etc).  For one, I'm looking to replace a couple of the 373 level converters on the address bus with 245s so I have the option of driving the expanded address bus from the FPGA - the FPGA will be able to fulfil the MMU's role if I decide to go that route, without any wiring, connection or PCB changes.  Will just need to modify the memory cards slightly to cater for the changes in A13/A12 being driven instead by EA13/EA12 from the FPGA etc.
I'm going to stick with Cyclone IV's for the moment as I have the dev environment set up for them - the above board will either use an EP4CE10 or CE15 FPGA, so the RAM will jump to 51 or 77KB respectively (and logic gate numbers increase respectively), but the package remains an easy-to-solder LQFP-144, minimising risk of problems/cost whilst I learn how to solder BGAs.  ;)
Post by: BrianHG on January 10, 2020, 12:10:55 pm
For the future, the Lattice chip has 6x6 more pins than this chip Louis Rossmann is repairing in this video.
https://www.youtube.com/watch?v=2eXMFIkdA0o (https://www.youtube.com/watch?v=2eXMFIkdA0o)
The secret here is the cleaning tinning of the pads and all that flux which helps transport the heat.
And a new PCB would be 100x cleaner than that water damaged mac.
Do not got to the 30$ lattice chip, that one has it's solder balls at 0.5mm instead of 0.8mm.  But, if you do got that route and have your PCB manufacturer place the BGA for you, you will have 4megabits of graphics memory.
30$ part: https://www.mouser.com/ProductDetail/Lattice/LFE5U-85F-6MG285C?utm_term=LFE5U-85F&qs=Rp3RbKSfAt3i%252b4nmoAgpiw%3D%3D&utm_campaign=LFE5U-85F-6MG285C&utm_medium=aggregator&utm_source=findchips&utm_content=Lattice (https://www.mouser.com/ProductDetail/Lattice/LFE5U-85F-6MG285C?utm_term=LFE5U-85F&qs=Rp3RbKSfAt3i%252b4nmoAgpiw%3D%3D&utm_campaign=LFE5U-85F-6MG285C&utm_medium=aggregator&utm_source=findchips&utm_content=Lattice)
This one would need research on how to build a PCB with larger vias for cheap mode with larger, but, you use so few IO, all the core VCC&GNDs would be shared and the outer edge IOs would be the only ones in use.
The 0.8mm 2megabit part should be easy peasy.
Also, if you want a 240pin QFP, these Cyclone III exist:
https://www.aliexpress.com/item/33040049112.html?spm=a2g0o.productlist.0.0.1fb0572cf1SudS&algo_pvid=c9decdb7-cb39-4c61-a5e7-e7d7fb87dbaa&algo_expid=c9decdb7-cb39-4c61-a5e7-e7d7fb87dbaa-15&btsid=29a7fbad-6c65-48e0-acb4-eb26363f6e85&ws_ab_test=searchweb0_0,searchweb201602_7,searchweb201603_55 (https://www.aliexpress.com/item/33040049112.html?spm=a2g0o.productlist.0.0.1fb0572cf1SudS&algo_pvid=c9decdb7-cb39-4c61-a5e7-e7d7fb87dbaa&algo_expid=c9decdb7-cb39-4c61-a5e7-e7d7fb87dbaa-15&btsid=29a7fbad-6c65-48e0-acb4-eb26363f6e85&ws_ab_test=searchweb0_0,searchweb201602_7,searchweb201603_55)
You will get 1 megabit.  My project runs your GPU on an Cyclone EP3C55, so you know it will work, though you will need to use Quartus, I think V16 or below, though you will need to check the supported versions.  I know Quartus V12 & programs chips fine in Win10.
You have enough IO for a 24bit DAC or HDMI transmitter (Look for a DDR interface 12 wire HDMI transmitter to still save IOs), enough more for a direct IO pin HDMI transmitter, and audio DAC and with 40k gates, you can make a hardware accelerated drawing engine, accelerated memory Flash card interface & add an 8 bit DDR2 ram chip.  (Careful here, you want the IO bank and it's voltage to be on one of the faster banks + on a separate voltage supply, but you can run it tops at 200MHz in DDR meaning 400Mb/sec.)
Post by: BrianHG on January 10, 2020, 12:18:41 pm
Also be careful of the larger Cyclone IV in the 144 pin package.  You loose some IOs since more IOs are changed into VCCint/core and GND pins as they are needed to power the larger core.
As for the CycloneIII, use an adjustable regulator for the core VCCint.  If you run the IC a little high at their max 1.25v, or 1.3v, you can push the C8 to run a single DDR2/3 ram chip to 500MHz without error.
Post by: BrianHG on January 10, 2020, 12:42:43 pm
Those memory figures are wrong.
Try 40 kilobytes for CE10 and 48 kilobytes for CE15.  Based on design, you can only sub-divide huge chunks of ram into dividends of 8 kilobytes, or smaller ones into 1/2/4/8 kilobytes.  You can test compile to check.  My suggested 240pin Cyclone III give you 120 kilobytes, + double the IOs + more than double the logic cells of the CE15.  With another 1 kilobyte for the palette, and another 1x2 kilobytes to cache the DDR memory.  Another 1x2 kilobytes to cache the flash ram card.  (This means a 320x240@256 color background with colored text and sprites with 15 MAGGIE layers before you even incorporate the 16 megabyte DDR2 ram chip)
Read the data sheet and learn what an M9K block is.  Also, since your memory allocation is using blocks divided into 16 bits instead of 18 bits, you loose some flexibility in memory allocation and you cannot use all the bits at your disposal.
Post by: nockieboy on January 10, 2020, 04:14:19 pm
He makes it look really easy actually - I guess with an SMT stencil and some decent flux, a BGA FPGA could be easier than an LQFP...
I'd have to be selling these things or crowd-funding the project if I was going to fund the cost for having a manufacturer place the BGA for me, it seems.  :o
You have enough IO for a 24bit DAC...
Yes, I'm just waiting on a DAC in the post to test my design on a PCB that will plug into the existing dev board and replace the 12-bit DAC.  I've built a 24-bit DAC into the new GPU board.
:wtf: I knew they were ball-park figures, but didn't realise I was that far out...  :(  Will go look at the Cyclone III more closely - or may just have to jump straight to the Lattice then, taking the BGA leap in one go... I take it an FPGA wouldn't be hot-air solderable in BGA format, unlike the smaller chip in the video you linked?
Post by: BrianHG on January 10, 2020, 04:39:32 pm
In the video, the BGA was only 0.6mm smaller than the Lattice BGA.  What you saw was equivalent to a 100 pin BGA, 0.8mm.  The Lattice part is 256 pin.  (10x10 VS 16x16 balls)  Hot air with a ton of flux so the BGA floats when heated allowing it to self-center will solder easy.  The larger 4mb Lattice part with more IOs is actually a smaller IC since the ball pitch is 0.5mm.  That one I would leave to someone with superior gear to mount.
The Cyclone III is a normal QFP making life easy to solder and patch in an emergency where you can lift a pin.  You also get enough IOs to make 1 or 2 IO banks 2.5v for the DDR memory while leaving the other IO banks at 3.3v.  However, be warned, for the VCCint/core, make sure you have a 2 amp regulator since it can draw power if you fill up the IC completely with logic and max out the clock speed.  Same goes for the larger Cyclone IV chips.  This is why you loose IO pins on the larger Cyclone IV chips as those pins get changed into VCCint power pins to supply the core.
I would use the TI DVI transmitter listed earlier, and also add a second HDMI connector directly connected to IO pins to try out a soft serializer core which you may develop before going to a Lattice FPGA since you might be able to get rid of the TI DVI transmitter IC.
Post by: nockieboy on January 11, 2020, 01:08:42 pm
Fair enough - seems I don't even need to worry about a hot plate or reflow oven then?  That would make the setup a lot cheaper.
Those Cyclone IIIs sound better than the IVs...?  Which seems ironic due to their numbering...?
Okay, the TFP410 (http://www.ti.com/lit/ds/symlink/tfp410.pdf)?  Are there any reference designs floating around in the ether for that chip at all?  I'm Googling for ideas as I write this reply, but not finding any obvious tips.
As for the second HDMI connector - there's going to be preferential (high-speed IO) pins to connect it to on the FPGA, right?  I'm going to have to switch to the Cyclone III or Lattice FPGA for these as I don't have the spare IO on the Cyclone IV CE10 (no point using the CE15 really, as it's more expensive, still limited on RAM and less IO).
@jhpadjustable - don't know if you're still following this discussion, but if so, what considerations do I need to make regarding IO pins so that I can use the new 'v1' GPU card to develop audio output on it?  Would make absolute sense to include an audio driver of some description (or just reserve a couple of pins connected to a header) so that I at least have the option of developing the audio side in the FPGA.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on January 11, 2020, 01:33:26 pm
Only the CycloneIV GX series offer a few different embedded hardware above the CycloneIII.  Otherwise, the III is identical to the IV which you are using in every respect, other than the 240pin QFP has been dropped for BGA packages only.
Read all you DVI transmitter datasheets... Also read the IO pins and their advanced uses in intel's manuals to know which IOs to use for ram & regular bus interface applications.  Read about audio DACs and how many IOs you need to operate them if you want sound.  TI has an absurd amount of info on audio DACs with different capabilities and prices.  Also, the DVI transmitters operate exactly like a video DAC, except you do not need to worry about driving the H&V sync down a video cable.  Also, the DVI transmitter can drive an HDMI connector as it is backwards compatible.  Also, the DVI transmitter may support multiplexed digital video meaning you send 12 bits, the upper 12 on a high clock, the lower 12 on a low clock meaning only 16 IOs in total are used instead of 28.
Post by: BrianHG on January 17, 2020, 08:15:02 am
Hi @nockieboy, I hope you are progressing well.  Do you have schematics for us to look at and Gerbers yet?
I hope you purchased a few of those Cyclone IIIs.  As is usual here at EEVblog, when a good deal with a good project is listed, like a huge 100$ FPGA for 35$, in a hand solder-able QFP, the stock is now sold out.  You would need to purchase something like 1K pieces or an entire production run direct from Intel to get that price.
Do you have anything new to show us on the Z80 software driving the GPU?
Remember, the part number is 'EP3C40Q240C8N'
Post by: nockieboy on January 17, 2020, 10:08:07 am
Unfortunately, progress has been pretty slow as work is getting progressively busier as the month wears on.  :scared:  Coincidentally, I have just finished an initial PCB design in the last couple of days though; schematics and PCB designs attached.  Would appreciate any feedback on them - especially if there's any problems or mistakes!  I'm not an electrical engineer and have no training, so I've tried my best to copy the schematic for the dev board where I can (rightly or wrongly) and add-in the bits and pieces I need.  I'm waiting on a couple of ADV7125s to arrive in the post so that I can test the 'video out' part of the circuit before committing the entire design to PCB.
I don't want bad design of the PCB to hinder later development of things like the keyboard interface, sound or SD card interface and what I've attached here is a first draft.  One thing I haven't done with the design is look at which signals go to which pins - a lot of what is connected where, and in which order, has been dictated by the board design and FPGA orientation to get a successful routing completed.  I need to review those connections and make sure it will work as intended.
I haven't purchased any Cyclone III's just yet - my budget is restrictive at best (remember, I'm doing this purely as a hobby) and my confidence in building one of these PCBs and getting it right first time matches that, so I'm taking smaller, slower steps initially and designing for a Cyclone IV EP4CE10.  Once I'm happy that I've got the design considerations down for that and a working build (and can get rid of the dev board and mess of wires off my desk!), I'll either switch straight to a Lattice build if my design skills are up to the task and I'm feeling brave, or see about getting a Cyclone III.  ;)
Parts are ordered for the first build - I haven't ordered the PCB yet (good thing as I hadn't thought you might want to check it out!) but they tend to get delivered a lot quicker than the parts do; seems that the parts come on the back of a tuk tuk or something from China. ;D
Other than the DMI monitor (some screenshots I've posted previously), there's nothing new really to show at the moment - I'm about to start working on the video driver for CP/M as soon as I get a day free to make a start on it, once that's done there'll be more to see.  :)
Quick question though - how did you get the Z80 image converted for the GPU?  Did you use stock software and something to save it in the required format, or write a converter yourself?  I'm using paint.net (https://www.getpaint.net/index.html) rather than Photoshop.
The other important thing I want to start testing shortly is the PS2 interface - need to get that up and running and sending chars to the Z80 via interrupts before I order the PCB, just so I'm happy the circuit will work.  With the FPGA using 3.3v, and needing to pull the 5v interrupt line low when required, I'm using a transistor to do that - hopefully that will work, but I've yet to set up a test.
Post by: BrianHG on January 17, 2020, 12:09:40 pm
Go for the cheapest version of the ADV7125 DAC, the 50MHz version, though the TI THS8136PHP is cheaper, faster and higher quality, but you need to run the IO and a bank on the FPGA at 1.8v, though, no voltage reference.
https://www.mouser.com/ProductDetail/Texas-Instruments/THS8136PHP?qs=sGAEpiMZZMswix2y39yldVRXhfgYHmM93ATDG4%252BVYYs%3D (https://www.mouser.com/ProductDetail/Texas-Instruments/THS8136PHP?qs=sGAEpiMZZMswix2y39yldVRXhfgYHmM93ATDG4%252BVYYs%3D)
vs
https://www.mouser.com/ProductDetail/Analog-Devices/ADV7125KSTZ50?qs=sGAEpiMZZMswix2y39yldfRSUiTQKynFVgceQfpCL2c%3D (https://www.mouser.com/ProductDetail/Analog-Devices/ADV7125KSTZ50?qs=sGAEpiMZZMswix2y39yldfRSUiTQKynFVgceQfpCL2c%3D)
Why are you clocking the DAC from your oscillator.  You should be using an output from the FPGA, preferably, one of the dedicated PLL output pins.  Use the second PLL CLK output if you have the reference oscillator on CLK1 input.
Why haven't you wired the 'blank' signal on the DAC to the video enable out.  It would help and also is necessary if you change the DAC for the DVI transmitter.
Things you can use the FPGA dedicated CLK inputs for:
clock oscillator <must be on a dedicated clock input for PLL to function  at high quality>
z80 clk input
Z80 buss controls, IE RD WR MREQ M1 INTA, IORQ, so long as all the buss controls are on the dedicated clock inputs.
reset
serial port RXD
I'm trusting you FPGA IO pins and part number.  Remember the EP4CE10E22C8N may have a few different IO pins than the EP4CE6E22C8N, typically a few less IOs changed into VCCint and GNDint.
What about the unused IOs on the SD-Card reader.
For the next revision, note that going straight to BGA means you cannot make a mistakes as you wont have access to pins to lift.
What size are your VIAs on your PCB.  are you sure any fab house can handle that in cheap PCB mode?  I know it's not a problem with higher quality expensive PCBs and if you are already using fine VIAs, you might as well go to a 4 layer PCB as it will be only a few dollars more from some China PCB manufacturers.
Are your power traces thin little traces like the data lines?
Your AMS1117-1.2 is ok for the EP4CE10E22C8N and you should expect it to get warm since it is linear with an almost 4v drop and a potential 0.25w VCCint load when switching your core to 15 layers.  This means around 208ma draw on a 800ma regulator.  With a 3.8v drop from the 5v supply = around 0.8 watts of dissipated waste heat.  (I'm assuming worst case with your current design).
Where is your 3.3v regulator?
You are going to get noise/ripples on you analog output with that ground layout and positioning of resistors.
Also, ADV7125 has an internal voltage reference mode.
With the ADV7125, also make sure the analog 5V is well filtered and isolated from the rest of your 5v design.
Post by: nockieboy on January 17, 2020, 01:29:59 pm
Yes, I've gone for the 50 MHz version.
Erm...  ::)  I guess because it's a 50 MHz clock and the DAC is 50 MHz, it seemed like a good idea at the time?  I take it using CLK7, 6, or 4 wouldn't be an issue?  It would make routing easier?
No particular reason, other than I guess I thought it wasn't needed.  Have added it in then.  :-+
z80 clk input
reset
serial port RXD
Well, I've yet to go through and confirm that the pins are all okay.  The realisation that the reference design I've been working from is for the CE6 version has caused me to go dig up a reference for a CE10 version - I'll go through the pins when I get a chance.
Well, I was getting short of IOs so it seemed a 1-bit connection was the best idea - again, based off of example schematics I'd found elsewhere...
Ah, well spotted.  They're 10mil vias (20mil overall) - I've just checked with JLCPCB and it appears I can go that small on a multi-layer PCB, but not on a 2-layer PCB.  :(
Most traces are 8mil, or 12mil for the 5v lines, with 6mil minimum spacing for all?  I guess with the power requirements of the EP4CE10, I'll need wider traces on ALL the power lines?
That's off-board, on another card in the stack along with the 5v regulator.  I guess I could do with adding a cap or two to that supply as it comes onto the card.
I'm into new territory here. :o How do I need to improve the ground layout?  Are there any guides or tutorials on this sort of thing?  So I don't need the AD1580 voltage reference?  I'll go see what I can learn about power supply filtering and isolation..  ???
Post by: BrianHG on January 17, 2020, 02:02:02 pm
The dac CLK needs to be the pixel clk, not the 50MHz clk.
You cannot use the FPGA dedicated CLK inputs as an output to drive the DAC clk input.  They are inputs only.  Read the Intel datasheet and find out which output are connected to a PLL clock output.
z80 clk input
reset
serial port RXD
You should only use the 6 mil spacing between traces-traces and pads.  You should have something like 10 or 12 mil spacing for everything else like polygon fills.
5V and 3.3V & 1.2v, if not filled should be at least 50mil for the most part.  Make sure you have no weak points and don't pass through single vias, or any at all.
Your ground around the VGA connector and dac and 75 ohm load resistors is broken up and not solid.  It routs as a large open object which connects at some different GND points at the outer edges.  Also, your 5v feeding the DAC is your digital 5v.  You need an analog 5v.  A separate 5v from it's own dedicated 5v regulator whose GND is referenced right at the DAC's analog GND and VGA connector's GND return pins for the R&G&B wires.  Make sure you feed the DAC's 5v regulator with 9v to 12v through a series RC or RLC filter whose filter termination attaches to the DAC's analog GND.
Read the dac data sheet, it tells you how to operate the DAC using it's internal voltage reference.
Post by: nockieboy on January 17, 2020, 05:01:09 pm
Righto, will sort that on the next revision. Vias are unavoidable on a 2-layer board.  Might have a look at what the cost of a 4-layer board would be. :-\
If I'm going multi-layer, it'll be for the first time ever.  Are there any particular considerations I need to bare in mind? Should I separate the power and ground planes with the signal plane (or not), for example?
I'm a little confused by the data sheet, to be honest.  It states there's an internal reference mode, but then states that the Vref pin should be connected up as per the application schematic (figure 12, page 15 of the datasheet), where it shows an external reference being used and makes no mention of how to enable the internal reference mode.  All I can surmise is that the diode and resistor should be removed and a capacitor (value unknown) placed in series with Vaa feeding the Vref pin?
Also, the 5V supply is direct from the USB port in this instance.  Or it could be from a 5V regulator if a 9-18V power supply is used.  Creating an analogue 5V supply is not going to be easy and will require modifications and a new version to an existing card that handles the power supply for the computer.
Post by: BrianHG on January 17, 2020, 05:09:24 pm
USB5v powering an analog 5v device... :(
Give me some time to think of something.
Post by: BrianHG on January 17, 2020, 05:16:40 pm
Your going to need to make the bottom almost all GND and thick VCC/VCCint/VCCa.  You will need multiple parallel vias for the power traces.  Coming from the regulators, use 50mil, but you may shrink them to 20 mils approaching the FPGA and other ICs, as long as the decoupling caps are next to a large filled GND plane.  Don't bother filling the top with a GND plane, it will just make you be sloppy about placing the GND and this allows you to focus on layout and IO pin selection.
You may take a few liberties with the 245 buffers, but with your layout, you probably wont need to.
Your design is simple enough to go with 2 layer, just need to do things a little smarter.
Post by: nockieboy on January 17, 2020, 05:23:19 pm
Let me add that the USB power supply is NOT a permanent thing.  All this time the Microcom has been slaved to a host PC so I can see its output and talk to it via a serial console.  With the addition of a video card and PS2 keyboard, it won't need to be connected to a host computer any more and so its usual method of receiving power will be via a 12V source (wall wart?).
Post by: BrianHG on January 17, 2020, 06:43:46 pm
I read the ADV7125 data sheet, it specifically says the dac can operate with a Vaa at 3.3v on page 4 of 17.  Use a dedicated 3.3v 150-350ma regulator powered from 5v with the input filter I mentioned.  This will allow you to filter your 5v supply to a clean 3.3v for the analog video out.
For the v-ref, as an output, just place the cap, no resistor.  But, I would place dummy pads for the resistor and reference diode since you may just leave them unpopulated.
Here is the cheapest ADV7125:
https://www.chip1stop.com/view/dispDetail/DispDetail?lang=en&cont=USA&partId=AD01-0052199&mpn=ADV7125KSTZ50&keyword=adv7125 (https://www.chip1stop.com/view/dispDetail/DispDetail?lang=en&cont=USA&partId=AD01-0052199&mpn=ADV7125KSTZ50&keyword=adv7125)
Post by: nockieboy on January 17, 2020, 07:09:20 pm
 :-+ Sounds like a plan.
I ordered mine here: https://www.aliexpress.com/item/4000433708668.html?spm=a2g0s.9042311.0.0.27424c4dqtzxLQ (https://www.aliexpress.com/item/4000433708668.html?spm=a2g0s.9042311.0.0.27424c4dqtzxLQ)
..but I notice it's a 240MHz part.  Should be okay though running at 50 MHz?  ???
Post by: BrianHG on January 17, 2020, 07:17:11 pm
? Your pixel clock is 25MHz, not 50.  Your need to clock the DAC at 25MHz to match your pixel clock speed.  The 240 is the upper limit.
Also, those at Aliexpress, what does the chip look like.  Though they might be fake, or 50Mhz relabeled at 250, they are a simple enough component which should still work fine.
Post by: nockieboy on January 17, 2020, 07:22:52 pm
Yep, you got me.  I should stop trying to do two things at once.  ;)
That's okay then.  Yes, it's always a concern about getting fake components, my luck will run out at some point...  ::)
Post by: BrianHG on January 17, 2020, 11:13:29 pm
Ok, here are the actual limits of each intel FPGA as I compiled your project with these chips:
EP4CE6E22C8
NUM_LAYERS = 7
ADDR_SIZE = 15
NUM_WORDS = 24576
Logic cells = 95% full
Remaining 1kbyte blocks = 5.
EP4CE10E22C8
NUM_LAYERS = 13
ADDR_SIZE = 16
NUM_WORDS = 40960
Logic cells = 96% full
EP4CE15E22C8
NUM_LAYERS = 15
ADDR_SIZE = 16
NUM_WORDS = 53248
Logic cells = 75% full
Remaining 1kbyte blocks = 3.
EP4CE40F23C8N OR EP3C40Q240C8N
NUM_LAYERS = 15
ADDR_SIZE = 17
NUM_WORDS = 122880
Logic cells = 30% full
Num_words is the bytes of available GPU display ram, + another 1024 for the palette.
Num_layers is the available display windows/sprites.  By now, you know what that means...
I was wrong about the 'EP4CE15E22C8', you actually make it to 53.248kb instead of 48kb.
The cyclone III makes it to 122.88kb + space and IO pins for a 128mb or 1gb DDR2 Dram + another 3 MAGGIE layers for the Dram's contents (18 total MAGGIEs), but, your Z80 has so little address space that the 1gb may be too much.
Since you are using the slowest -C8 versions, and, you need a C7, or even a -C6 for the higher densities, I recommend replacing the 1.2v regulator for an adjustable one and adjust it for 1.35v.  This will make a C8 perform somewhere inbetween a C7 and C6 which would be perfect.  Though, my GPU design, there are only a few critical address paths in the FPGA, so it still wont get warm or draw too much current over driving the VCCint to 1.35v.
Post by: BrianHG on January 18, 2020, 12:41:21 am
Wow, Aliexpress has this EP4CE55F23C8N:
https://www.aliexpress.com/item/4000565235137.html?spm=a2g0o.productlist.0.0.6f4070d8TJDFSw&algo_pvid=32026952-2ec8-4c29-8482-f604669bd0df&algo_expid=32026952-2ec8-4c29-8482-f604669bd0df-10&btsid=81dd9ffb-1486-42b3-a4ca-3047c798def0&ws_ab_test=searchweb0_0,searchweb201602_7,searchweb201603_55 (https://www.aliexpress.com/item/4000565235137.html?spm=a2g0o.productlist.0.0.6f4070d8TJDFSw&algo_pvid=32026952-2ec8-4c29-8482-f604669bd0df&algo_expid=32026952-2ec8-4c29-8482-f604669bd0df-10&btsid=81dd9ffb-1486-42b3-a4ca-3047c798def0&ws_ab_test=searchweb0_0,searchweb201602_7,searchweb201603_55)
At 2.3 megabit, that's slightly larger than the 1.9 megabit Lattice part.  Though, the 16$ lattice part is coming from reputable sources like Digikey and Mouser and you are guaranteed a legitimate part.  Digikey lists the EP4CE55F23C8N at $115 usd, so that 18$ Aliexpress price sounds too fishy.
Post by: BrianHG on January 18, 2020, 01:02:10 am
 Put in the extra effort and use at least the 'EP4CE15E22C8' fpga.  You get all 15 maggie layers, and enough free logic gates to add sprite collision detection or/maybe and semi-translucency between all layers.
Post by: nockieboy on January 18, 2020, 06:08:54 pm
EP4CE6E22C8
NUM_LAYERS = 7
ADDR_SIZE = 15
NUM_WORDS = 24576
EP4CE10E22C8
NUM_LAYERS = 13
ADDR_SIZE = 16
NUM_WORDS = 40960
EP4CE15E22C8
NUM_LAYERS = 15
ADDR_SIZE = 16
NUM_WORDS = 53248
NUM_LAYERS = 15
ADDR_SIZE = 17
NUM_WORDS = 122880
You know, the CE10 isn't looking that bad an upgrade at all.  Get's me another 6 layers, almost doubling the sprite count over the CE6.
Would be easy enough to page the 1gb into the 512KB 'window' available to the Z80, if I could find a use for all that RAM...
Righto, so scrub the 1.2v regulator and replace with an adjustable set to 1.35v.  Also, add in a 3.3v 'analogue' sourced from the 5v for the ADV7125.  Am I right in thinking the 'analogue' 3.3v source is just a well-filtered, but otherwise identical, source to the existing 3.3v in the Microcom, but dedicated to the ADV7125 and sharing a ground with it?  The ground will still have to meet up with the primary ground on the system at some point?
Post by: nockieboy on January 18, 2020, 06:20:51 pm
Hmm.. okay, have ordered one - will perfect the board design for the CE10 when I get a chance and then re-do it from the CE15.
Post by: BrianHG on January 18, 2020, 06:28:20 pm
Did you read Intel's data sheet and look at the pin planner for the CE15?  Make sure you have enough IOs.
Using the dedicated clock inputs the way I mentioned will give you 6 new free IOs, but, I think that with the CE15, you loose 6 IO since they change into power supply pins.
Also, re layout the DAC so it's analog out face the VGA connector directly, with proper GND return traces for the VGA connector's analog RGB GND return signals.  Also wire the 75ohm resistors properly within that return path.  Read my PCB design notes a few pages up.  The DAC draws so little current that you can use a simple RC filter for it's 3.3v regulator.
Post by: nockieboy on January 18, 2020, 10:35:42 pm
Looks like you lose 10 IOs - I can't absorb that loss on the board, even using the clock inputs as you've suggested, without losing the SD card interface. I'll stick with the CE10 for the moment and see if I can get that working and make use of the SD interface with that.  You queried the interface method to the SD socket previously - is there a better way I can connect it up to utilise the remaining handful of IOs I have on the CE10?
Okay, will give that a try.  I have a couple of days off after tomorrow, hopefully can get the PCB re-organised then.  I guess if I'm moving the DAC to sit above the VGA socket, the resistors will be closer anyway, but I'm not 100% on what 'properly' entails. ???  Is it just maintaining a solid ground plane all around the resistors and VGA socket or do I need to consider anything else as well?
Post by: BrianHG on January 18, 2020, 10:39:52 pm
Run the DAC at 18 bit.   You get 6 additional IOs + the other 6 on the dedicated clock inputs.
Your maximum palette has only 6 bits on the green anyways with 5 bit on the blue & red.
Post by: BrianHG on January 19, 2020, 02:47:19 pm
Here is a home made Lattice LFE5U-45 board, but, made with the 381 pin BGA.  The advantage using the 384 BGA is you can use the Lattice LFE5U-45 1.9megabit, or the LFE5U-85 3.7megabit interchangeably.  It's done in Kicad and the boards are home assembled.
https://www.youtube.com/watch?v=-rBTqxgmfaM (https://www.youtube.com/watch?v=-rBTqxgmfaM)
Kicad project files: https://github.com/gregdavill/ButterStick (https://github.com/gregdavill/ButterStick)
Example daughter board:
https://www.youtube.com/watch?v=WNOm_esUVsw (https://www.youtube.com/watch?v=WNOm_esUVsw)
Post by: SiliconWizard on January 19, 2020, 05:21:45 pm
Nice project!
Post by: BrianHG on January 19, 2020, 05:27:38 pm
Nice project!
Just so we are clear, it is not my project.  But the presenter illustrates how easy it is to mount and bake a 0.8mm BGA using a stencil and solder paste.  And how if you watch him, the initial error in alignment, and centering of the BGA is not a problem.
Post by: nockieboy on January 20, 2020, 12:18:42 pm
Okay, here's the latest on the power supplies for the FPGA.  3.3VA is the supply for the DAC - you say it needs some sort of filter on the output - mentioned either RC or RLC.  I don't know enough about this stuff to decide which to use and what values I'd need.  Any suggestions welcome.  :-+
[attachimg=1]
Post by: BrianHG on January 20, 2020, 01:45:12 pm
RC filter the 5v input to the DAC's 3.3v regulator.
10 ohm, 0805, or 1206 for safety and 10uf should do.
Remember positioning and layout of the analog end...
Note that there are chokes and filters better suited for this, but your dac only draws 70ma max and a large enough resistor and cap are as cheap and dumb as it gets.
You can always use the same LC filters which you are using for the FPGA PLL analog supply.
Post by: BrianHG on January 20, 2020, 02:06:21 pm
The RC filter feeds the power into the regulator so that the regulator wont transmit high frequency ripple through it and the output will always be 3.3v, even with a voltage drop across the resistor.
You are using an analog regulator, so with no high frequency ripple entering the 3.3v regulator, the output should be clean as the regulator should be grounded next to the DAC itself.
Post by: BrianHG on January 20, 2020, 05:03:13 pm
To do things right, you can always replace the resistor with the correct 0805/1206 ferrite bead or inductor.
Post by: nockieboy on January 20, 2020, 05:11:37 pm
Okay, so a 10 ohm ferrite bead can replace the resistor, or what value would I need for an inductor equivalent?
Post by: nockieboy on January 20, 2020, 05:24:20 pm
[attachimg=1]
Post by: BrianHG on January 20, 2020, 06:16:54 pm
Until you can find the spectrum of the noise on your 5v supply, you cannot exactly tell.  The 10 ohm is a blanket low pass filter.  Though, voltage noise feeding the regulator input below a certain frequency begins to be rejected by the regulator electronics itself and you can tune or choose a ferrite to choke out all frequencies above that range.
What you have is ok.  When you build the PCB, all you need is to do is make an all white screen and make sure the regulator input is at least 4.2v approximately.  If not, just shrink the 10 ohm to 5 ohm.
The advantage of a ferrite is that it may have a DC resistance below 5 ohm, or even below 1 ohm, but as the frequency noise in your 5v supply increases, the series resistance increases dramatically according to the ferrite's datasheet chart blocking that signal from penetrating through.
Look up ferrite datasheets for these charts and look up your regulator's supply rejection ratio VS frequency to see where you want your ferrite to actually be at a really high resistance.
Change your 10uf to 100nf since it is non-polarized and add a 10uf in parallel.  You need both as the 10uf filters a lower frequency band white the 100nf/0.1uf cleans up the higher frequencies.
Also set the core VCCint to 1.3v.  1.35 is overkill and you want a touch of safety margin as each regulator and resistor precision may have a bit of error.
Post by: nockieboy on January 20, 2020, 07:59:58 pm
Okay, here's the power supplies for the FPGA:
[attachimg=1]
On a slight tangent, taking 6 IOs (2 LSBs from each colour channel) will just about make up for the loss of 10 IOs on the CE15.  With the addition of the BLANK signal and the DAC CLK output, I don't have any free IOs on the CE10.  So if I move the key command signals (can't do all of them - non-critical signals like IORQ and RESET will have to go to normal IOs) to the FPGA's dedicated clock inputs, that will free up 5 IOs, plus the 6 from the colour output will give me 11 - so it'll be close, but I should be able to cater for the CE15.
Have attached latest schematic for info - still have yet to confirm that all the IO connections are valid and will work as intended.
Post by: BrianHG on January 20, 2020, 10:29:24 pm
I am just curious about the 2 pll analog GNDs going through those 2 ferrite beads.  I have never done that in my designs and I have not seen that elsewhere.  If your bottom layer is mostly a GND plane under the FPGA, you shouldn't need it.  However, can you show me a link to a third party design which uses it as personally I though something like this might actually create problems under some circumstances.  The ferrite on the +2.5v for the PLL is correct.
Post by: BrianHG on January 20, 2020, 11:55:50 pm
You only have 3 GND pins on your system expansion headers.  It is optimum to have 1 GND pin for every IO data pin for best results.  However, with your design's low frequency and low power, 4:1 or 5:1 should be fine.
Post by: nockieboy on January 21, 2020, 08:33:23 am
I've just copied the design from the EasyFPGA dev board schematics for the board I'm currently using - I figured it would be a good place to start from, considering the dev board seems to work fine.  :-//
Dev board schematic attached below.  Of course, I don't know if this is a 1:1 of the actual, physical dev board I'm using - I found it on the net by searching for the dev board name, but the part numbers match up.  It looks as though the ferrite beads on the physical board are actually just links - they look like SMD resistors (black) with a '0' on them, so 0R links.  Looks like no ferrite beads were used.  ???
Post by: nockieboy on January 21, 2020, 12:26:13 pm
Latest 2-layer PCB design with changes made to position of the DAC, number of colour bits to the DAC, etc. (I've dropped the two LSBs from each channel).
Has taken me an hour or two to get component positioning/orientation in a way that allows a successful auto-route.  Still had to wire two of the power feeds to the FPGA manually.
I haven't bothered working on ground planes yet - I thought I'd seek some feedback on the positioning of the DAC and those pull-down resistors for R, G and B before I start stressing about ground plane placement.
Post by: nockieboy on January 21, 2020, 06:05:41 pm
For DAC_CLK (the pixel clock output from the FPGA) I've got two PLL output pins I can use, according to the pin manager in Quartus for the EP4CE10; one for PLL1 and one for PLL2.  The PLL2 output is preferable as it's closest to the DAC (it's currently used by R4 in the red channel to the DAC) - but, and this may be a stupid question - how do I know if PLL2 is used and, if not, how would I force Quartus to use it or will the router manage that by itself when it sees I've connected the clk output from the PLL to a PLL2 output? ???
Post by: BrianHG on January 21, 2020, 07:28:17 pm
If you System clock in is on PLL#1's dedicated clock input, ie 50MHz, use PLL#2.  This way, currently, if you have a nice multiple output clock, ie 25Mhz, 125MHz &250 Mhz current clocks, Quartus will automatically connect PLL#1 to #2 to generate the PLL output.  If you wan to use a SMPTE compatible 480p, IE 27Mhz pixel, 135Mhz core, 270Mhz core ram, You can make PLL #1 in Quartus convert 50MHz to 270MHz, then use PLL#1 to drive PLL#2 to generate the nice required multiples 27,135,270MHz.
So yes, connect the DAC's CLK input to PLL #2's output as it offers your best flexible path.
Post by: BrianHG on January 21, 2020, 09:32:12 pm
Ohh boy, are you auto routing and auto placing this?
Move the VGA connector to the right a little.
Make the DAC at 90 degrees so that the analog out faces the VGA plug.
Make the DAC's 75 ohm resistors and dac wiring straight to the VGA plug.  Make the proper VGA plug's Analog R&G&B  GND return pin paths feed on the top through/wired to the other side of the 75 ohms and to the DAC's R&G&B negative signals.  Place as many of the decoupling caps on top to the sides of these signals.  Also, you should be using 0603 parts, or if your hands are steady enough,  go for 0402 for these DAC components so everything is in a straight line.
Under the dac, bottom layer, a fill GND should be used throughout.    Use 2 adjacent VIAs for every GND connection to the top layer.
For a 2 layer board, this should make a really good analog signal for your frequency range.
Remember, match red's return GND signal path with red's 75 ohm resistor, then to the dac's inverted red GNS input.  You do not want a signal reflection crosstalk across your video outputs since you didn't match GNDs.  The GND plane feeding the VGA connector's GND pins will be good enough for your bandwidth.
Post by: nockieboy on January 21, 2020, 10:42:11 pm
Is there any other way when things start getting complicated? ???
I've manually placed all the components, but I am auto-routing otherwise it'd take me days to do the board manually?  Is there a better way, then?  :-//
Post by: BrianHG on January 21, 2020, 11:37:33 pm
LOL, see my attached 100% manual routed 8 layer board...
I expect you to at least route the crucial analog traces and Power and GND thick traces and force multiple vias there.
You may route the rest automatically, however, your "puny" 2 layer PCB is a 30 minute manual job.
Look at the total stats on my all manual routed attached .pdf.
[attachimg=2]
Post by: nockieboy on January 22, 2020, 09:33:32 am
(Attachment Link)
[attachimg=1]
It may be a 30-minute job for a professional like yourself, but remember my experience with electronics is pretty minimal at best.  I've only got this far on the desire to learn and stubbornness bordering on stupidity.  ;D
Post by: nockieboy on January 22, 2020, 11:26:38 am
Made a start on the above - here's progress so far. Perhaps getting a little concerned about GND continuity, but not much I can do with that unless I start breaking signals or power lines out onto the bottom layer.
Close-up of the DAC area with a little more detail:
[attach=1]
Post by: BrianHG on January 22, 2020, 01:36:15 pm
Excellent...
Push up C1, it is too close to the VGA plug.
Move up R2 and C2 closer to R1, lower U2 below C2.
You should now have a clear path for the Vaa on the top layer from regulator to all Vaa points since each GND should have their own vias by each component pad to the bottom layer.
Rotate the 3.3v regulator 90 deg. with it's caps allowing you to move the dac and vga plug a little further to the right so the have a little clearance from the fpga.
***********  Remember, the GND via for C5 and C3 should have their own via positioned closer to the DAC.  Those GND points should not have any other wires going out of them to the digital FPGA GND pins, or any other GND signals for the dac should not branch out to the fpga.
Everything else should work great.
Post by: nockieboy on January 22, 2020, 04:39:13 pm
Okay, here's the latest.  The blue area is the ground plane on the bottom layer.  Don't worry about the ratlines indicating I should connect up to FB3 and C47 underneath - I'm ignoring those and will probably amend the schematic to use a unique ground connection for the DAC components so I won't have to worry about the auto-router (if I ever use it again! :o) connecting up the DAC ground to digital ground.
My only question is - where do I connect up the DAC ground plane? The nearest ground pin on the system header is at the top left of the 40-pin header next to the DAC.
[attach=1]
Post by: BrianHG on January 22, 2020, 05:05:42 pm
(Attachment Link)
Pretty good.
Are your via's drill hole size large enough?
The 2 GND vias on the right of the dac are too close to the pins.  move those vias under the dac where you have space.  Same for the 2 GND vias at the top of the DAC.
You do not require a unique GND for your dac.  You do not require a ferrite bead for the FPGA PLL GND as well if you fill the bottom layer with a good GND.  Your bottom layer should be 95% GND fill for everything with a few opening voids for occasional power and signal traces.  It is just important that by the dac and it's regulator, that this GND section is 1 solid chunk without any voids for other traces.  What you have is good.
Note that a larger via server the equivalent to 2-3 of the finest possible vias.
Fill the Vaa between the right side of the DAC and U13 regulator and VGA plug so that the VaA trace is thick between C1 and the rest of the DAC.  make sure all your polygon clearances are something like 12mil, not 8 mil.  Too much copper fill close to pads make it hard to solder and are a continuous possible short point around drill holes.
Post by: BrianHG on January 22, 2020, 05:55:55 pm
Arrrg, 1 thing, rotate your entire 3.3v regulator section by 180 degrees...
Keep it's reference GNDs points as close to the DAC as possible and only allow in the dirty 5v at the outer edge of the design...
Post by: nockieboy on January 22, 2020, 06:13:40 pm
They're all 12mil/24mil - standard size for EasyEDA (which I'm using to design the board) and JLCPCB's requirements.
Post by: nockieboy on January 22, 2020, 08:48:58 pm
Okay, latest update.  Just trying to manually route all the other lines now... and I'm starting to think I'll swap the 373s from the lower address lines for 245s, they'll make routing much easier even though I'll never need the ability to change the direction of the buffer.
[attach=1]
Oh, I also noticed that I'd missed the HS and VS signals from the FPGA out!  I was wondering why I wasn't seeing ratlines from HS_IN and VS_IN on the line driver chip...  so that's eaten up another 2 IOs.
Post by: BrianHG on January 22, 2020, 09:13:46 pm
Well, if you have a problem with the VGA output quality, it will now be a software or VGA cable issue...
As for your 74HC logic, make the VCC & GND traces to the caps thick, like you have doe already for a few of them.
Remember that you do not need to wire GND-GND on each 74HC IC, just add 2 vias along the thick GND trace as it will meet with the GND flood fill on the bottom of the PCB.
As for the VCC, look for the most convenient path.  This may also be partially along the bottom edge of the PCB, coming to the top layer just by the first ICs.
Post by: nockieboy on January 23, 2020, 06:25:13 pm
 :phew:
Here's the PCB design - all manually routed.  I must admit, there's a certain sense of achievement in doing it yourself - plus much finer control over trace widths for power supplies etc.  :-+
I get the feeling I've learned a lot from this exercise.  ;D
Post by: BrianHG on January 23, 2020, 06:56:08 pm
:phew:
Nice.    :clap:   :-+
Amazing job for a first timer!!!
Now, I understand the difficulty in achieving this 2 layer design with all the limitations.  Since I cant see net names, I only see 2 little things to consider.
FB4 is receiving power through a trace going through an IC pads and vias.  I'm not sure about the bottom cap next to how C10 is wired.  Try removing the FB3 and FB4 from your schematic.  You will simplify a few GND connections and remove a few caps in your design that way maybe allowing a better path for FB4's Vpll.
Hang on a sec, something seems wrong with the Vpll and VCCint, are some of those shorted, or, on the wrong pins?
Can you show me a printout/screenshot with net names on the FPGA pins?
As well as net names on the other components?
Post by: nockieboy on January 23, 2020, 08:23:50 pm
Hmm.. have PM'd you to see about giving you direct access to the project.  In the meantime, here's a breakdown of the design (one layer per page). Don't know if that will be useful?
Post by: BrianHG on January 23, 2020, 09:20:03 pm
The GND path under the FPGA and by the programming connectors is a little chopped up and can be easily fixed.  But, I want to look at the net names first as the Vpll and Vcore/int looks funny to me...
Post by: nockieboy on January 24, 2020, 06:07:50 pm
Okay, here's the latest on the schematic and PCB.  DRC completed with one error - the 5V line going up to R19 was only 10mil wide when the design rules called for 18mil, so I've widened that and there's no errors now.  I also moved the TCK trace up a little to hug around the NCONFIG via a little closer and make the underside look a little neater near the top.  :)
All I have to do now is wait for parts to arrive and order the PCB, once I'm absolutely happy I've got the right SD card socket (for some reason I'm finding it hard to get a matching part/footprint combination) and crystal oscillator package for the 50 MHz clock source.
 :scared:
Post by: BrianHG on January 24, 2020, 06:48:42 pm
:scared: 18MIL!!!
WTF, those pullups are 10kohm.  a 4 mil trace would have been overkill.
Anyways, take a look at the attached image, the trace circled in green it too wide for the pad.  Make it 12 mil.
[attach=1]
Post by: BrianHG on January 24, 2020, 09:23:12 pm
If you decide to go with the CycloneIII on your next PCB, add this ram chip:
https://www.digikey.com/product-detail/en/cypress-semiconductor-corp/S70KS1281DPBHV020/2015-S70KS1281DPBHV020-ND/9955180 (https://www.digikey.com/product-detail/en/cypress-semiconductor-corp/S70KS1281DPBHV020/2015-S70KS1281DPBHV020-ND/9955180)
You only need 12 IOs & 1 PLL balanced Pos/Neg pair output set to 1.8v running at the core clock memory speed.  You'll get the full 16 megabytes MAGGIE can address on this 1 chip, though, you will need to mask out first 128kb for the onboard FPGA ram and you will may need to add a wait state when the Z80 reads this ram unless you are smart about the programming.  No DDR ram controller, just shift out an address and data, and wait for a response.
Post by: nockieboy on January 24, 2020, 11:34:57 pm
:scared: 18MIL!!!
(Attachment Link)
 :-// It didn't like the 10mil trace - I think because it was the only one on the board that was less than the 18mil minimum for the 5V net.
Have sorted that wayward trace on the FPGA too - thanks for spotting that.  :-+
I like the look of that.  Could be a good (inexpensive) introduction to BGA soldering for me...
Post by: BrianHG on January 25, 2020, 12:10:46 am
That 1mm pitch BGA and the 240 pin QFP is your only solution for a 2 layer PCB with ram and no DRAM controller to engineer.  Every other option requires 4 layers and the lattice requires 10 or 8 mil vias because of it's density.
Post by: nockieboy on January 25, 2020, 10:43:46 am
I'd be happy to give that a try.  Once I've got a working v1, seems like the Cyclone 3 would be a worthwhile step up - it's significantly bigger than the CE4 chips though and will leave me with some routing headaches, I suspect, to cram it all into the form factor I'm working with.
Post by: BrianHG on January 25, 2020, 03:34:59 pm
No it wont.  All those extra IO means mostly single file traces next to each port.  With a lot of blank IO pins.
Post by: nockieboy on January 25, 2020, 04:25:08 pm
The EP4CE10E22C8N arrived today - I notice it has a ground pad underneath the body of the chip, which the part doesn't have in EasyEDA.  I've checked the Intel literature and yes, the EP4CE10E22 DOES have a ground pad and it's supposed to be connected to GND, so I'll need to update the PCB design with this.
Here's what's got me thinking, though - how do I solder that central pad under the chip to GND?  I suppose I could place a few large vias there and use a hot air gun to heat the PCB up from the underside? Any suggestions?
Post by: BrianHG on January 25, 2020, 06:28:45 pm
You can fake place a GND pad for the open copper area.  (IE, create a new custom home made SMD component with 1 pad connected to GND.)  A number of vias to GND within the pad around the perimeter will also be needed.  But, I recommend searching for the correct footprint type as it a standard and such a component will have the proper paste stencil.
As for soldering, hot air will do, baking is better but I know you are hot properly setup for that.
Post by: nockieboy on January 25, 2020, 07:21:37 pm
Okay, well it looks like the pad in the footprint I'm using is a little larger than the actual ground pad on the IC, and I'd just finished the attached update to the PCB before I read your post about putting vias around the edge - hopefully this will be alright?  I've moved the 2.5 line on the bottom side down, so it goes around the edge of the centre of U1 and there's now a nice ground plane under U1.
Post by: BrianHG on January 25, 2020, 07:54:50 pm
Everything looks good.
You still haven't considered the additional GND connections on the edge connectors which I mentioned earlier.
Post by: BrianHG on January 25, 2020, 10:34:24 pm
Is it just me, or, do the pads on your new footprint appear to be small?
Make a high quality 1:1 paper print of both versions of the PCB and make sure you can solder the FPGA in place by placing a FPGA on top and looking that there is exposed copper both under the pins + a little extra outside of the pins.  Without that little extra, you wont be able to do a clean proper solder with an iron.
Make sure your print copy doe not contain the extra mask around the IC pads, just the copper underneath.
Post by: nockieboy on January 25, 2020, 11:33:01 pm
No, it's not just you.  I was concerned about that myself - it seems the footprint I selected for the chip wasn't precisely correct.  I'd chosen a TQFP-144 package footprint, as it was the only one I could find at the time with a ground pad under the chip.  It turns out that the pads are smaller, too - I've since done some more hunting (I'm no expert with EasyEDA and creating new symbols) and found an EQFP-144 package which is the real deal and matches the chip much more precisely in terms of the ground pad underneath.  It also comes with a grid of vias already and pads that match the original.
 :phew:
Next step is to see about fitting the CE15 into this design for the backwards compatibility...
Post by: nockieboy on January 26, 2020, 11:05:35 am
Question:  Does it matter much if signal lines don't cross each other at right-angles?
Previously, whilst making my auto-routed PCBs I'd made for my CPU, memory, CompactFlash and power/serial cards, I've been a bit OCD about making sure signals on different layers cross each other at 90-degree angles to minimise cross-talk.  I don't even know where I got that idea from - or if it's even a thing I need to worry about. :-//
Just thought I'd ask and put that demon to bed once and for all.  >:D
[attachimg=1]
Post by: nockieboy on January 26, 2020, 12:13:38 pm
There's not a lot I can do about those unless/until I redesign the entire computer and its system bus.  Those headers were designed over two years ago, before I knew anything about multiple grounds etc.
Post by: BrianHG on January 26, 2020, 02:53:26 pm
(Attachment Link)
Too low frequency/power design to worry bout.  Long parallel trace above and below is a larger problem.
90 degree turns on a thin trace is also a problem as they are a weak etching point.  (You have 1 below a resistor by the PS2 keyboard connector on the top layer.)
Also, you have so many unused IOs on those connectors, you cannot add just 2-3 GNDs on each side?
Post by: nockieboy on January 26, 2020, 04:30:10 pm
Ah, missed that one - but yes, was aware of the no-right-angles rule (although I wasn't sure why - now I know!)  ;D
They're not used for this card (only the pins that are used have net labels in this design), but they are pretty much all used elsewhere on other boards.  There's a couple I could re-purpose as GNDs, but would have to bodge them into the same GND pins as I'm using currently when they get to the 'utility' card that handles the power supply.
Post by: nockieboy on January 26, 2020, 08:21:45 pm
Can't seem to find a solution to this issue I'm having.
I'm trying to return a value from a parameter array, defined as below:
parameter int BANK_ID[16] = '{9,3,71,80,85,0,255,255,255,255,255,255,255,255,255,255}; // The BANK_ID data to return
... based upon the address being read, like below:
Z80_rData[7:0] <= BANK_ID[addr_hold[3:0]]; // Return the appropriate value
addr_hold is an 8-bit register, addr_hold[7:0], consisting of the lowest 8-bits of a memory address.
I'm getting this error, though:
Error (10687): SystemVerilog error at z80_bridge.sv(115): indexing addr_hold returns an aggregate value
I can't seem to bottom out the meaning of this error or how to fix it.  :-//
Post by: BrianHG on January 27, 2020, 12:33:38 am
Z80_rData[7:0] <= BANK_ID[addr_hold[3:0]][7:0]; // Return the appropriate value
Post by: nockieboy on January 27, 2020, 08:21:50 am
The one thing I didn't try - specifying the width of BANK_ID.  ::)  I was thinking the problem was with addr_hold itself..
... but it returns the same error again.  :(
Full code:
module Z80_bridge (
   // input
   input wire  reset,            // GPU reset signal
   input wire  GPU_CLK,          // GPU clock (125 MHz)
   input wire  Z80_CLK,          // Microcom clock signal (8 MHz)
   input wire  Z80_M1n,          // Z80 M1 - active LOW
   input wire  Z80_MREQn,        // Z80 MREQ - active LOW
   input wire  Z80_WRn,          // Z80 WR - active LOW
   input wire  Z80_RDn,          // Z80 RD - active LOW
   input wire  [21:0] Z80_addr,  // Microcom 22-bit address bus
   input wire  [7:0]  Z80_wData, // Z80 DATA bus to pass incoming data to GPU RAM
   input wire  [7:0]  gpu_rData,
   input wire  gpu_rd_rdy,       // one-shot signal from mux that data is ready
input wire  sel_pclk,         // make HIGH to trigger the Z80 bus on the positive edge of Z80_CLK
   input wire  sel_nclk,         // make LOW  to trigger the Z80 bus on the negative edge of Z80_CLK
input wire PS2_RDY, // goes HIGH when data is ready from PS2 keyboard on PS2_DAT
input wire [7:0] PS2_DAT, // data from keyboard
input wire Z80_IORQ, // Z80 IORQ - active LOW
input wire Z80_IEI, // if HIGH, Z80_bridge can request interrupt immediately
   // output
   output reg  Z80_245data_dir,  // control level converter direction for data flow - HIGH = A -> B (toward FPGA)
   output reg  [7:0]  Z80_rData, // Z80 DATA bus to return data from GPU RAM to Z80
   output reg  Z80_rData_ena,    // flag HIGH to write data back to Z80
   output reg  Z80_245_oe,       // OE for 245 level translator *** ACTIVE LOW ***
   output reg  gpu_wr_ena,       // flag HIGH for 1 clock when writing to GPU RAM
   output reg  gpu_rd_req,       // flag HIGH for 1 clock when reading from GPU RAM
   output reg  [19:0] gpu_addr,  // connect to Z80_addr in vid_osd_generator to address GPU RAM
   output reg  [7:0]  gpu_wdata, // 8-bit data bus to GPU RAM in vid_osd_generator
output reg Z80_INT_REQ, // flag HIGH to signal to host for an interrupt request
output reg Z80_IEO // flagged LOW when GPU is requesting an interrupt
// TODO:
// 1) Respond with appropriate data to any requests from Microcom ROM identification routines
// 2) Implement PS2 keyboard interface and interrupt handling (INTACK occurs when M1 goes LOW, then IORQ goes LOW, ends when both go HIGH)
parameter MEMORY_RANGE  = 3'b010; // Z80_addr[21:19] == 3'b010 targets the 512KB 'window' at 0x100000-0x17FFFF (Socket 3 on the Microcom)
parameter MEM_SIZE_BITS = 15;    // Specifies maximum address size for the GPU RAM (anything above this returns $FF)
parameter BANK_RESPONSE = 1; // 1 - respond to reads at BANK_ID_ADDR with appropriate data, 0 - ignore reads to that address
parameter BANK_ID_ADDR = 17'b10111111111111111; // Address to respond to BANK_ID queries with data (lowest 4 bits left off)
parameter byte BANK_ID[16] = '{9,3,71,80,85,0,255,255,255,255,255,255,255,255,255,255}; // The BANK_ID data to return
wire Z80_mreq, Z80_write, Z80_read, Write_GPU_RAM;
wire Read_GPU_RAM;
wire Z80_clk_pos,Z80_clk_neg,Z80_clk_trig;
reg Z80_clk_delay, last_Z80_WR, last_Z80_RD, mem_valid_range, mem_window, last_Z80_WR2, last_Z80_WR3, last_Z80_RD2, last_Z80_RD3, bank_id_access;
reg addr_hold[7:0];
assign Z80_clk_pos    = ~Z80_clk_delay &&  Z80_CLK;
assign Z80_clk_neg    =  Z80_clk_delay && ~Z80_CLK;
assign Z80_clk_trig   = (Z80_clk_pos && sel_pclk) || (Z80_clk_neg && ~sel_nclk);
assign Z80_mreq       = ~Z80_MREQn && Z80_M1n;  // Define a bus memory access state
assign Z80_write      = ~Z80_WRn;               // write transaction
assign Z80_read       = ~Z80_RDn;               // read transaction
// Only allow RD/WR to valid GPU RAM space
assign Write_GPU_RAM  =  mem_window && Z80_mreq && Z80_write && mem_valid_range; // Define a GPU Write action - only write to address within GPU RAM bounds
//assign Read_GPU_RAM   =  mem_window && Z80_mreq && Z80_read  && mem_valid_range; // Define the beginning of a Z80 read request of GPU Ram.
// Allow RD/WR to entire 512KB memory window
//assign Write_GPU_RAM  =  mem_window && Z80_mreq && Z80_write; // Define a GPU Write action - only write to address within GPU RAM bounds
assign Read_GPU_RAM   =  mem_window && Z80_mreq && Z80_read; // Define the beginning of a Z80 read request of GPU Ram.
always @ (posedge GPU_CLK) begin
   gpu_addr         <=  Z80_addr[18:0];                        // Latch address bus onto GPU address bus
   mem_valid_range  <= (Z80_addr[18:0]  <  2**MEM_SIZE_BITS);  // Define GPU addressable memory space
   mem_window       <= (Z80_addr[21:19] == MEMORY_RANGE);      // Define an active memory range (this decides which socket the GPU replaces)
bank_id_access   <= (Z80_addr[21:4]  == BANK_ID_ADDR); // Define access to BANK_ID area
   if (Write_GPU_RAM) begin
      Z80_245data_dir  <= 1'b1;       // Set 245 DIR to FPGA
      Z80_rData_ena    <= 1'b0;       // Set FPGA pins to input (should be by default)
      Z80_245_oe       <= 1'b0;       // Enable 245 output
      gpu_wdata        <= Z80_wData;  // Latch data bus onto GPU data bus
   end
   if (Read_GPU_RAM) begin
      Z80_245data_dir  <= 1'b0;       // Set 245 DIR TO Z80
      Z80_rData_ena    <= 1'b1;       // Set bidir pins to output
addr_hold   <= Z80_addr[7:0];
   end else begin
      Z80_245data_dir  <= 1'b1;       // Set 245 dir toward FPGA
      Z80_rData_ena    <= 1'b0;       // Re-set bidir pins to input
   end
   if (gpu_rd_rdy) begin
      if (mem_valid_range) begin
Z80_rData[7:0] <= gpu_rData[7:0];  // Latch the GPU RAM read into the output register for the Z80
end else begin
if (BANK_RESPONSE && bank_id_access) begin
end else begin
Z80_rData[7:0] <= 8'b11111111; // return $FF if addressed byte is outside the GPU's upper RAM limit
end
end
   end
   Z80_clk_delay  <= Z80_CLK;          // find the rising clock edge
   last_Z80_WR    <= Write_GPU_RAM;
   last_Z80_WR2   <= last_Z80_WR;
   last_Z80_WR3   <= last_Z80_WR2;
   last_Z80_RD    <= Read_GPU_RAM;
   last_Z80_RD2   <= last_Z80_RD;
   last_Z80_RD3   <= last_Z80_RD2;
   gpu_wr_ena     <= Write_GPU_RAM && ~last_Z80_WR2 ; // Pulse the GPU ram's write enable only once after the Z80 write cycle has completed
   gpu_rd_req     <= Read_GPU_RAM  && ~last_Z80_RD2 ; // Pulse the read request only once at the beginning of a read cycle.
end
endmodule
Post by: BrianHG on January 27, 2020, 06:59:00 pm
Why arent you using :
Z80_rData[7:0] <= BANK_ID[Z80_addr[3:0]]; // Return the appropriate value
Post by: nockieboy on January 27, 2020, 07:01:27 pm
I seem to recall having problems using Z80_addr previously.  The bit of code that assigns the value to Z80_rData executes a couple of clock cycles later, after Z80_addr has been 'captured'.  I'm operating under the assumption that the address may have changed between the read being initiated and the value being returned to the data bus.  Thinking about it, however, this was back when we were having timing troubles with the whole Z80_bridge, so maybe I'm labouring under a false assumption...  :-//
It still doesn't compile, though - even though it successfully compiles symbol files...  ???
Post by: BrianHG on January 27, 2020, 07:09:29 pm
Yes it does compile.  I checked...  Showing your problem lies somewhere else, like with the line:
reg addr_hold[7:0];
Post by: nockieboy on January 27, 2020, 07:33:06 pm
reg addr_hold[7:0];
 |O
Project compiles now.  Silly mistake on my part, as usual..  ;)
Post by: nockieboy on January 29, 2020, 10:51:18 am
Okay, I seem to have another head-scratcher.  :o
I'm working on the PS2 keyboard interface.  I figured it would be easier to test using IO polling initially, rather than the whole interrupt setup as there are more unknowns there.  So the Z80 would be polling the GPU regularly to see if there is a character (or keycode) in the PS2 interface.  To do this, the GPU needs to intercept IO from the host - for the Z80, this is when IORQ and RD go LOW together, much like a memory cycle (but with IORQ instead of MREQ).
Here's the timing diagram for an IO cycle straight from the Z80 datasheet:
[attachimg=1]
It's pretty much identical to a memory cycle, except the Z80 automatically inserts 1 WAIT state into the cycle to give whatever is being addressed time to get its ducks in order. How generous.
So, I've set about modifying the Z80_bridge module to intercept IO cycles targeting a user-specified IO address ($F0 in this case), only looking at the lower half of the address bus as (officially, at least) the Z80 only uses the lower half of the address bus for IO addressing.  Yes, I know about IN A,(C)/OUT (C),A placing the full BC register on the address bus, just in case anyone is thinking about that.
Anyhow, should be simple, right?  I should be able to use the same process as for the memory read cycle in Z80_bridge?
Seems not.  I'm sometimes getting the right value back, but more often than not just getting $78 returned, which is effectively a null return on my system.
I've tried varying the delay between the IORQ cycle being detected, 'arming' the 245 in the right direction and putting the data on the bus, but a 2 cycle delay is a logical minimum to allow the 245 to change direction before driving the data bus, as proven with the previous memory cycle work.
I've tried adding a delay at the end of the IORQ cycle, despite the Z80 datasheets stating zero hold time is required after IORQ/RD goes HIGH at the end of the cycle.
With the code in its current state, I'm rarely getting the desired value returned (should get $AA returned for a valid IO read).
So I'm wondering if there's something stupid I've done in the code that is causing this issue?  It's fairly likely, after all.  :-[
I've also tried to break down the various functions within the always block to make it more readable (for me, anyway!)
I appreciate this sort of issue is a tough one to pin down if it's hardware-related, but I suspect it could be an issue with my HDL or the way I'm trying to do it.
Post by: nockieboy on January 29, 2020, 10:52:19 am
It won't let me post the code AND an in-line image at the same time...  |O
module Z80_bridge (
   // input
   input wire  Z80_IORQn,        // Z80 IORQ - active LOW
   // output
   output reg  Z80_IEO           // flag HIGH when GPU is requesting an interrupt to pull IEO LOW
// TODO:
// 1) Implement PS2 keyboard interface and IO-polled / interrupt handling
parameter int BANK_ID[16] = '{9,3,71,80,85,32,69,80,52,67,69,54,0,255,255,255};  // The BANK_ID data to return
wire Read_GPU_RAM;
// ********************** PS2 Keyboard interface stuff **********************
parameter int INT_TYP  = 0;            // 0 = polled (IO), 1 = interrupt
parameter byte INT_VEC = 'h30;         // INTerrupt VECtor to be passed to host in event of an interrupt acknowledge
parameter int IO_DATA  = 240;          // IO address for keyboard polling
parameter int IO_CTRL  = 241;          // IO address for keyboard status
parameter int IO_HOLD  = 2;            // CLK cycles to hold IO data on bus after end of Z80 cycle
wire PS2_READY, IO_DATA_RQ, IO_STAT_RQ, INTA_start, INTA_end, Z80_INTACK;
reg [7:0] PS2_CHAR;
reg PS2_prev, INTACK_prev, IO_DATA_prev, IO_STAT_prev;
reg [4:0] INT_DELAY;
reg [4:0] IO_245_DLY;      // Delay to allow 245 to change direction before putting data onto bus
//reg [6:0] dly_io = 7'b0;
reg IO_hold_clk = 1'b0;       // used to hold the IO cycle a little longer past the end of the real cycle
assign PS2_READY     = PS2_RDY && ~PS2_prev;                                  // HIGH for 1 CLK when valid data is available on PS2_DAT
assign IO_DATA_RQ    = ~Z80_IORQn && (IO_DATA == Z80_addr[7:0]) & ~Z80_RDn;   // HIGH when host is reading data via appropriate IO address
assign IO_STAT_RQ    = ~Z80_IORQn && (IO_CTRL == Z80_addr[7:0]) & ~Z80_RDn;   // HIGH when host is reading status via appropriate IO address
assign Z80_INTACK    = INT_TYP && ~Z80_M1n && ~Z80_IORQn;                     // HIGH when host is acknowledging interrupt
assign INTA_start    = INT_TYP && Z80_INT_REQ && Z80_INTACK && ~INTACK_prev;  // HIGH for 1 CLK when interrupt acknowledge detected
assign INTA_end      = INT_TYP && Z80_INT_REQ && ~Z80_INTACK && INTACK_prev;  // HIGH for 1 CLK when interrupt acknowledge ends
   if (PS2_READY) begin       // valid data on PS2_DAT
      PS2_CHAR          <= PS2_DAT; // Latch the character into Ps2_char register
      // Check IEI here to make sure we can request an interrupt
      if (INT_TYP) begin
         Z80_INT_REQ    <= 1'b1;    // Fire off an INTerrupt REQuest
         Z80_IEO        <= 1'b1;    // Pull IEO LOW to prevent anything downstream from requesting interrupts
      end
   end
   if (Write_GPU_RAM) begin   // *** WRITING TO GPU RAM
   end
   if (Read_GPU_RAM) begin    // *** READING FROM GPU RAM
   end
   if (INT_TYP && INT_DELAY[2]) begin  // *** RESPONDING TO INTERRUPT ACKNOWLEDGE
      Z80_rData[7:0]    <= INT_VEC;    // Put INT_VEC onto data bus after delay to allow 245 to get itself sorted
   end
   if (INTA_start) begin      // *** Valid INTerrupt ACKnowledge detected
      INT_DELAY[0]      <= 1'b1;       // Start delay timer
   end
   else if (INTA_end) begin   // *** End of valid INTerrupt cycle
      Z80_INT_REQ       <= 1'b0;       // Cancel INTerrupt REQuest
      Z80_IEO           <= 1'b0;       // Allow downstream interrupt requests again
   end
      end else begin
         end else begin
         end
      end
   end
   // *** START of IO cycle requesting PS2_CHAR byte
   if (~INT_TYP && IO_DATA_RQ && ~IO_DATA_prev) begin
      IO_245_DLY[0]     <= 1'b1;       // Start delay timer before putting data on bus
      IO_hold_clk       <= 1'b1;       // Enable IO hold
   end
   // *** RESPONDING TO IO READ
   if (~INT_TYP && IO_DATA_RQ && IO_245_DLY[2]) begin
      //Z80_rData[7:0]     <= PS2_CHAR;   // Put PS2_CHAR onto data bus after delay to allow 245 to get itself sorted
      Z80_rData[7:0]    <= 'hAA;       // Put static value on bus to test
   end
   // *** END of IO cycle
   if (~INT_TYP && ~IO_DATA_RQ && IO_DATA_prev) begin
      PS2_CHAR          <= 8'b0;       // Reset PS_CHAR value
      //dly_io[0]          <= 1'b1;       // Trigger IO shutoff delay
      IO_hold_clk       <= 1'b0;       // Release IO hold
   end
   // *** DELAYED END of IO cycle
   /*if (~INT_TYP && IO_hold_clk && dly_io[IO_HOLD]) begin
   end*/
   // *** IF NO INTERRUPT, MEMORY OR IO READ OPERATIONS ARE ONGOING, ENFORCE DATA BUS DEFAULTS ***
   if ((~INT_TYP || ~Z80_INT_REQ) && ~Read_GPU_RAM && ~IO_hold_clk) begin
      Z80_IEO           <= ~Z80_IEI;   // Pass-through Interrupt Enable flag from upstream devices
   end
   // *** FLAG & SIGNAL MAINTENANCE ***
   // CLOCK EDGE DETECT
   // WRITE EDGE DETECT
   // READ PROCESSING
   // IO EDGE DETECT & PIPELINE
   IO_DATA_prev   <= IO_DATA_RQ;
   IO_STAT_prev   <= IO_STAT_RQ;
   IO_245_DLY[4:1]<= IO_245_DLY[3:0];
   //dly_io[6:1]     <= dly_io[5:0];
   // INTERRUPT EDGE DETECT & PIPELINE
   INTACK_prev    <= Z80_INTACK;
   INT_DELAY[4:1] <= INT_DELAY[3:0];
   // PS2 KEYBOARD EDGE DETECT
   PS2_prev       <= PS2_RDY;
   // GPU RAM FLAGS
end
endmodule
Post by: nockieboy on January 29, 2020, 12:13:49 pm
Okay, I've made an improvement.  ;D
I'm now getting mostly the intended value back, but it's still not 100%.
[attachimg=1]
Now I'm getting an error in 1 in 7 results, approximately.  I've just cleaned up some of the IF... conditionals and completely removed any delay holding data on the bus after the end of the IORQ cycle.  Code in next post.
Post by: nockieboy on January 29, 2020, 12:14:21 pm
module Z80_bridge (
   // input
   // output
// TODO:
wire Read_GPU_RAM;
reg [7:0] PS2_CHAR;
      if (INT_TYP) begin
      end
   end
   end
   end
   end
   end
   end
      end else begin
         end else begin
         end
      end
   end
   if (IO_DATA_RQ && ~IO_DATA_prev) begin
      //IO_hold_clk       <= 1'b1;       // Enable IO hold
   end
   if (IO_DATA_RQ && IO_245_DLY[2]) begin
   end
   if (~IO_DATA_RQ && IO_DATA_prev) begin
      //IO_hold_clk       <= 1'b0;       // Release IO hold
   end
   end*/
   if (~Z80_INT_REQ && ~Read_GPU_RAM && ~IO_DATA_RQ) begin
   end
   // READ PROCESSING
   // GPU RAM FLAGS
end
endmodule
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: nockieboy on January 29, 2020, 12:35:20 pm
^-^ So I seem to have sorted it myself, though I'm not sure why.  I've removed all the terms from the IF... conditionals checking for IO cycle start, data release, end with wires that do the comparisons, as that was the only difference I could see between my IO conditionals and the memory ones.
So:
IF (IO_DATA_REQ && ~IO_DATA_prev) begin
has now changed to (only relevant lines shown - obviously the WIRE assignment doesn't appear in the ALWAYS block!):
assign IO_DATA_ST = IO_DATA_RQ && ~IO_DATA_prev; // HIGH for 1 CLK when valid IO_DATA cycle starts
if (IO_DATA_ST) begin
Now I seem to be getting reliable values returned every time.  If anyone can explain why, I'd like to know what the difference is!  :popcorn:
Post by: BrianHG on April 25, 2020, 02:46:13 am
So, has anything new progressed?
Or, are you on covid - save all your pennies/spend all of your time with the family lockdown?
Post by: nockieboy on April 25, 2020, 10:15:26 am
Hey!
Well, no news to report in terms of features or software developments (other than getting CP/M drivers working nicely so I can use all the various programs there with proper screen output).  Yes, lockdown has been in force here since mid-March, which has affected our post and sanity, but I got all the parts together to make the video card in the last few days, so I'm incrementally building it and testing as I go to make sure there's no problems.  Amazingly, the cheap EP4CE10's I got from China actually appear to be EP4CE10's...  :phew:
I have it running the GPU HDL, communicating nicely with the rs232_debugger software and playing tunes on the buzzer/speaker via a single IO.  I soldered the 245's onto the board last night to connect the FPGA up to the Z80's bus to see if I could read the GPU's RAM from the Z80, but all I'm getting is $7E's where I should be getting the first page of video RAM.  I didn't have time to take it any further last night, but whilst sleeping(!) wondered if it's because the test system I'm using is running at 4 MHz instead of 8?  Don't know if that would mess with the z80_bridge timings at all and cause the Z80 to miss the data the FPGA is putting back onto the data bus?
Anyhow, I'm going to look at that today if I get the chance - switch the uCOM over to 8 MHz and test it again, and if that still doesn't work then I'll test all the connections between the FPGA chip itself and the address & control buses to see if there's any bad connections preventing the FPGA detecting RD/WRs to it.  Will update as soon as I can with developments.  :-+
EDIT:
No - bumping the system clock up to 8 MHz makes no difference.  I'm able to turn on/off the sound output via an OUT command to the appropriate IO port, so it would appear the lower (A0-A7) part of the address bus and data bus is working properly, but it seems to me that getting no data back when trying to read the GPU RAM could be an issue with the middle/upper addresses not getting through properly.  Will continue looking at these.
EDIT 2:
The Z80 is able to write data to the GPU RAM - I've been POKE-ing values to the GPU RAM and can see the changes in the RS232_debugger, but the Z80 cannot read the values back - all I'm getting back is $7E, which is what I get when there's no chip in the socket where the memory address resides.  Could this be a timing issue?
Post by: BrianHG on April 26, 2020, 04:13:15 am
EDIT 2:
1. Check with a magnifying glass your soldering.
2. Check with ohm meter for continuity on the OE and DIR lines of the 245s.
3. Go with an ohm meter and make sure your IO buffer's OE/DIR aren't shorted to adjacent pins on the FPGA, or shorted to GND/VCC.
4. Double check the schematic by pin number to the Quartus pinout file since I think we moved some IOs to adapt to the PCB layout.
5.  Verify that the new IOs on the larger CycloneIV are valid free IO.  (You only need to concern yourself with the OE and DIR signals for the 245s as the write function works.
6.  Make sure during pin number swapping, you didn't accidentally label/number the OE and DIR controls coming out of the FPGA backwards.
This type of possible problem is normal with a first time brand new PCB.
Lastly, you will need to scope the 245's OE/DIR as the 'Chinese Cyclone' may have a damaged IO pin.  Make sure the signal has a good 3v high and 0v low.
Post by: nockieboy on April 26, 2020, 10:40:11 am
Have done these already - there's no issues with continuity between the FPGA and 245 for OE or DIR signals, no shorts that I can find.
Hmm.. well they appear to be valid IO according to the Pin Planner.  Where else do I need to look to check these?  I'm wading through datasheets and handbooks...
Have checked and double-checked this, all is good.
That's reassuring, but it's still frustrating!
Yes, so this is the next thing - will require some setup with my logic analyser and I'll check it with that first.  My scope won't touch this sort of issue unless I specifically write some HDL to repeatedly switch the DIR pin at a frequency that the scope can see and allow me to get a stable trace on the screen.
I've included the latest version of the project in a zip below in case it's useful.
Post by: nockieboy on April 26, 2020, 11:12:07 am
Hang on...
   end
   end
Above code is from z80_bridge.sv.
For a GPU RAM WRITE from the Z80, it's setting Z80_245data_dir HIGH.  That's setting the 245 to A>B direction.  This is fine for the prototype, because I've got the Z80 data bus on the A side, HOWEVER on the PCB I've got the FPGA on the A side.  :palm:
So if I'm reading it right, Z80_245data_dir is being set to the opposite value of what is required.  Amazing that I was able to write data to the GPU RAM at all...  :wtf:  Unless the 245's DIR pin never goes HIGH at all, in which case it won't matter what value Z80_245data_dir is set to, it'll always be sending data TO the FPGA.
I've reversed the values for Z80_245data_dir in the HDL to accommodate the change in layout of the PCB, but still not able to read anything from GPU RAM.  Strangely, I'm able to write to GPU RAM (and I can see the uCOM's bootstrap setting up the GPU for text display mode) but any block copies (using LDIR) just seem to write 0xB0 to every address, rather than 0x00 or any other value.
EDIT: Updated Z80_bridge.sv attached.
Post by: lintweaker on April 27, 2020, 11:49:36 am
Oh, yes. Those level converters with DIR can make things a lot harder...
It took me months to get a Z80 to read stuff back from peripherals living in the FPGA. After going back to the basics (simple LED with status readback) I've managed to get it working.
I am using TI SN74LVC8T245DWR or SN74LVC8T245PWRs as level converters with the 5V Z80 stuff on the 'B' side.
Did you put your project on github? I am interested in using it.
Post by: nockieboy on April 27, 2020, 12:24:50 pm
Yes - here it is: https://github.com/nockieboy/gpu (https://github.com/nockieboy/gpu)  :)
Post by: lintweaker on April 27, 2020, 01:42:43 pm
Thanks!
Post by: BrianHG on April 28, 2020, 02:29:30 am
Hang on...
   end
   end
Have your tried completely rolling back the version of the interface, way back to 1.0 where we didn't have the interrupt or PS2 keyboard interface...
Post by: nockieboy on April 28, 2020, 08:49:34 am
Not yet, but I'm pretty confident the PS2 (and by extension the interrupt request) sections of HDL in the Z80_bridge aren't interfering with anything else.  There is no PS2 HDL to handle and read the PS2 input (there's no PS2 connector on the board at the moment), but I've attached a GND to the PS2_RDY input on the Z80_bridge just to be sure - but even if it did float HIGH, it wouldn't do anything except read PS2_DAT into a register anyway, ready to be read by an IO RD from the Z80.
I'm fairly convinced it's a bad IO on the FPGA.  I've done my best to try and get some data from the 245_DIR line between pin 143 on the FPGA and pin 1 on the 74LVC245, but I'm finding attaching a logic analyser probe impossible - I need four or five arms to hold everything in place and operate the PC at the same time.
What I did do was a very tight loop of test code:
6000   LD HL,0C000H  ; Translates to GPU RAM address 0x0000
6003   LD A,(HL)     ; Read a byte from GPU RAM into the accumulator
6004   LD A,(HL)
6005   LD A,(HL)
6006   LD A,(HL)
6007   LD A,(HL)
6008   JP 6003       ; Jump back and read again
Basically, it gets the Z80 to read an address in GPU RAM (pointed to by HL) several times and loop back to read it again constantly.  Without looking at the clock timings for the individual commands I was using, I'd say it would be fair to estimate that the 245_DIR line should have been HIGH for anything between 20-40% of the time in that loop (disclaimer: wild guess from top of my head, but supported by some logic).  As all I could reliably connect to the 245's pin 1 was my multimeter, I would have expected to see something like 1V maybe, displayed as an average on the meter if it was working properly.
At rest (i.e. no GPU RAM access by the Z80), the pin read around 40mV.  Whilst the test loop was running, it read 49-60mV, sometimes jumping to around 200mV, but it didn't seem to like being measured and I could hear some faint static from the speaker briefly, then it locked up entirely.  I'm fairly confident that the test was sensitive enough to pick up if the line was going HIGH as it should do when the Z80 read the GPU RAM, but there was little sign of that.  Very strange behaviour.
Naturally, I'd prefer to get the logic analyser to record 245_DIR during a GPU RAM RD transaction, but I just can't seem to get a logic probe to contact securely with pin 1 of the TSSOP.  Might try soldering a wire to it later and try again.
My last step is a little extreme, so I'm holding off doing it until I'm happy I've exhausted all attempts with the logic analyser and I've had the time to dig out the oscilloscope and set it up (again, I need five arms and plenty of time to do that).  Basically, I'll cut the 245_DIR trace and connect a spare FPGA IO (I have a couple) to the 245 with some wire-wrap, if need be.
Post by: nockieboy on April 30, 2020, 02:18:04 pm
So it was a dead/faulty IO pin on the FPGA.  :phew:  I cut the line from pin 143 to the data 245's DIR pin and bodged a connection between a spare IO on the FPGA (pin 7) and the DIR pin, updated the HDL with the new pin assignment and hey presto! It works - I can read the GPU RAM now.  ;D
Now for the next step - build the VGA output section and hope that all works as intended!  :-+
Post by: BrianHG on May 01, 2020, 12:12:10 am
EDIT 2:
:-DD Heheheh, it's always the last thing...
Post by: nockieboy on May 01, 2020, 09:04:24 am
And there's always another thing...   :-\ I completed the VGA section last night and switched on, blank screen (no signal).  Now I haven't had much time to look into the issue, but I noticed after a quick look at the HDL last night that there was no BLANK output from the GPU to the DAC (but the line is there on the PCB), so I quickly added an output in HDL linked to Vcc and tried again - still no output.
So here's my to-do list - feel free to chip in with any other suggestions - that I'll try to work through over the weekend. Listed in order of ease of testing (I have no easy/reliable way to get my logic analyser connected to the FPGA pins):
1) Check Quartus HDL for errors/incorrect pin allocations (done this - this is how I spotted the missing BLANK output)
2) Check for bad soldering
3) Check BLANK line for 3.3V on PCB
4) Check good 3.3VA to U13 (DAC)
5) Check U6 for good 5V supply and test for HSYNC and VSYNC signals
6) Check U3 outputs (via R7-R9 for ease of access) for R, G and B signals
7) Check R/G/B lines from FPGA
8 ) ... not wanting to jinx it, but consider possibility there's a few more bad IOs on this FPGA ...  :o
Post by: BrianHG on May 01, 2020, 09:49:13 am
Doesn't Blank = VCC mean 'Blank' as in black, as in no picture?
Don't we have an 'active' video output which would just need to be inverted to feed this signal?
Post by: nockieboy on May 01, 2020, 10:08:17 am
The way I read the datasheet, I thought it meant no image if BLANK was not at Vcc?
[attachimg=1]
Errrr.... possibly - would that be the vid_de_out (vde at the pin) output from vid_out_stencil???
Post by: nockieboy on May 03, 2020, 10:05:43 am
It appears there's no hs and no vs coming out of the FPGA.  I couldn't pick up any blue signals on blue[5] or blue [2] when I tested them.  As I'm using my logic analyser, connected via a Dupont lead with a pin stuck in the end to connect to one of my multimeter's leads so I can use the sharp point on the end to single out the FPGA pins I want to test, it's a shaky method but I'm consistently getting a pixel_clk signal (sort of - my logic analyser won't measure a frequency that high, but I'm getting a signal as best it can manage) and BLANK is HIGH.
Could there be something I've missed in the HDL that is stopping hs/vs output?  I'll test the rest of the colour channels later, taking a break for a bit.
Post by: BrianHG on May 03, 2020, 05:28:06 pm
What does the scope say?
Post by: nockieboy on May 16, 2020, 10:19:52 am
Quick update, as nothing has really progressed.  The scope didn't provide any meaningful data (to me, anyway) - looks like the IOs are dead on the first FPGA and a second I put together is completely dead.
I've given up on the project for the moment while I wait for some low-temperature solder to arrive.  I have a concern that I may have cooked the last FPGA as I tried soldering it with a hot air gun from the top, instead of from underneath via the... vias... and not having an IR temp gun meant I had no idea how hot I was making the chip, so I figure the wait for some low-temp solder would be worth it and should mean I can solder the exposed ground pad underneath the chip without roasting the chip.  Obviously I use normal solder for the pins - I'm quite happy I can do them without causing much hassle to the chip.
I've got two of these FPGAs sourced from AliExpress left - if I can get better results soldering them using the low-temp paste (but they still don't work fully) then I'll know they're a bad batch and it's not my caveman soldering skills.  Sourcing an FPGA from a legitimate seller is about 6x more expensive, though, so I want to make sure my soldering is up to the task before I start literally burning through cash.  I'll get an IR temp gun before I start on a legitimate FPGA build...
TLDR: going on hiatus for a while - waiting for materials - before attempting another build.  ::)
Post by: asmi on May 16, 2020, 03:35:43 pm
Take a look at the project in my signature. It's open source (so you can modify it if you want to adapt it to your project by adding/removing peripherals, or using some other connector as the 0.1" one on the board is not really suitable for anything high-speed), it supports rather beefy FPGAs (up to Spartan-7 S50 with 76.8K logic cells and 90 36Kbit BRAM cells), there is up to 256 MBytes of DDR2 memory with 16bit bus running at 333 MHz (so theoretical maximum bandwidth is 333 * 2 * 16 = 10656 Mbit/s), and there is an HDMI output port. But most importantly, it's tested and known to work.
Post by: BrianHG on May 16, 2020, 10:15:28 pm
Heat burning a 144pin TQFP when just drag soldering the pins is tough to do.
1 IO dead, ok, maybe static electric discharge or Chinese junk.
1 bank of IOs dead, maybe an IO bank's VCCIO or GNDIO isn't soldered down or making contact.
If you see the DAC getting a clock & syncs & random data, but no picture, maybe a Chinese fake DAC ic.
You should have paid the extra 20% an purchased the read McCoys from the links I've provided when we did the price comparisons earlier and be guarantee good ICs.  (Note that I realize I also provided Aliexpress links for some FPGAs and I did warn of the possibilities of problems when purchasing from there)
Post by: BrianHG on May 17, 2020, 03:25:02 am
How about a detailed hi-res photograph of your assembled PCB.
Post by: nockieboy on May 17, 2020, 11:09:50 am
Agreed - and I'm confident enough in my soldering skills to not be slightly worried about this particular risk.
Using the hot air gun, however, I'm not so sure about.  I've ordered an IR temperature gun - I can't really hot-air solder a chip as large as a QFP-144 where I can't see the solder melting on the ground pad and expect to keep it even vaguely close to any kind of soldering profile.
I was always going to go for the cheapest FPGAs I could source initially as I had no confidence in my ability to be able to solder them (the 'hardest' I'd done before was the odd TSSOP, I hadn't gone smaller than 0805 for passives and I have no specialist or expensive equipment), so don't worry about the advice you gave me - it was good.
I'm happy that soldering a QFP-144 isn't actually that difficult now, even with the exposed ground pad, aside from my concerns with possibly overheating the chip - but I'm taking steps to prevent that now by getting the IR temp gun.  There's still no guarantee that's the issue - but I may as well deal with the obvious issues as well as the less obvious ones.
I've taken some pics with my phone - can't say they're much use, but I'll attach them anyway.  I've been using a x10 loupe magnifying glass for all my SMD soldering anyway, so I've inspected the board as best I can and can't see any bad connections on the FPGA.  The next step is to check all the power pins at the FPGA to make sure power is getting through.
Some of the resistor values are approximations (85R instead of 75R on the RGB outputs, for example), and I think I found X1 to be the fiddliest thing to solder of the lot (I used solder paste and hot air gun for it), but it's outputting a 50 MHz clock as far as I can tell (the FPGA works in terms of talking to the Z80 and operating the buzzer, anyway).
I'll attach the other four images in following posts, due to attachment size limitations.
[attach=1]
Post by: nockieboy on May 17, 2020, 11:12:09 am
This image shows the side of the FPGA closest to the video DAC.  The hs/vs booster (74HCT541) is just visible in the bottom left of the image and VGA socket at the bottom of the image.
[attach=1]
Post by: nockieboy on May 17, 2020, 11:14:09 am
90 degrees counter-clockwise from previous image, showing the FPGA side on the data and control bus input side.  The jumper lead is the bodge I made when I realised the data bus's 245_DIR IO pin wasn't working, so switched to an alternate IO pin on the FPGA.
[attach=1]
Post by: nockieboy on May 17, 2020, 11:15:55 am
Another 90 degrees counter-clockwise, looking at the side of the FPGA that connects to the clock source, serial port and AS/JTAG ports.
[attach=1]
Post by: nockieboy on May 17, 2020, 11:17:37 am
Finally, another 90 degrees counter-clockwise from previous post, showing side of FPGA that handles the system's address bus, from A0-X21.
[attach=1]
Post by: cruff on May 17, 2020, 01:20:18 pm
It looks like there are solder bridges on chip U3 on the upper side in the image.
Post by: nockieboy on May 17, 2020, 01:32:58 pm
Yes, they're supposed to be there.
[attach=1]
Post by: BrianHG on May 17, 2020, 05:58:52 pm
Ok,
Have you ever drag soldered pins?
Do you have extra flux?
Do you have solder wick?
I've attached at least 2 lifted pins, the VCCA pll and VCCIO for the DAC and I think some of the Z80 port.
Things are iffy, I bet other pins are also just barely touching cold solder joints.
Also, having a lifted VCCIO may be damaging to powering up the FPGA, but from what I see, properly cleaning things up may make this PCB work fine.
[attach=1]
[attach=2]
Post by: nockieboy on May 17, 2020, 07:01:17 pm
Yes to all those.  I have sticky/waxy (applied with a tooth pick), liquid (applied with a brush) and jelly-like (applied from a syringe) flux.  I've been using solder wick on the FPGA - you can probably see where the white solder mask has been removed on a few traces with some overzealous wicking...  And drag soldering is something I've learned on this FPGA and the one before it...
...but I'm happy there's no bad connections to the FPGA - I've checked and re-checked all the FPGA pins' connections to the PCB with a loupe and multimeter - I can confirm that ALL the 3.3V input pins to the FPGA are receiving 3.3V (well, 3.2V actually...  ???)
The 1.3V regulator is pumping out some heat, though - it felt quite hot to the touch whilst I was testing some of the FPGA pins, so here's some voltage readings from the tabs on the AMS1117s:  :-DMM
Short of testing every single pin on the FPGA, which I think I might just have to do, I'm pretty confident of ALL the FPGA connections to the PCB (including the exposed ground pad underneath).  The photos I've taken aren't the best quality - I'd need a digital microscope that can take stills really, so the pins you think look lifted or cold-soldered are actually fine if viewed with the light source from a different angle.
Post by: asmi on May 17, 2020, 07:48:07 pm
That's why almost all FPGA boards I've seen use buck converters for the core voltage. Some larger devices can consume a lot of current on that rail, so using linear converters is impractical because they would generate a serious amount of heat.
Also - why 1.3V? If my memory serves me Cyclone-4's Vccint is 1.2 V nominal ±0.05 V, or 1.0 V ± 0.03 V, so 1.3 V would certainly be out of spec.
Post by: nockieboy on May 17, 2020, 08:25:43 pm
This was recommended by BrianHG:
Since you are using the slowest -C8 versions, and, you need a C7, or even a -C6 for the higher densities, I recommend replacing the 1.2v regulator for an adjustable one and adjust it for 1.35v.  This will make a C8 perform somewhere inbetween a C7 and C6 which would be perfect.  Though, my GPU design, there are only a few critical address paths in the FPGA, so it still wont get warm or draw too much current over driving the VCCint to 1.35v.
Having checked the datasheet in more detail, you're quite right, it does appear to be out of spec, especially as the voltage coming out is actually slightly higher than the 1.3V required in the design.
I doubt that dropping the voltage to 1.2V will affect the performance in any material way (unless BrianHG can shed some more light on that) as the prototype version on the FPGA dev board runs fine with a 1.2V supply.  Interestingly, that's a linear supply as well.  Will have to check the temp on that part next time around.
Likewise, I can't see how 1.3V instead of 1.2V on Vccint is going to stop the IO at the DAC side from working, when everything else seems fine.
Post by: asmi on May 17, 2020, 09:22:47 pm
Overclocking 101 - before you overclock anything you always establish that device you're about to run out of spec works in spec. As going out of spec is always a lottery. There is a reason the specs are what they are, if Antel would be certain that their devices will have higher performance than they are at 1.3 V, they would certainly market this a a feature. For example, on Xilinx side there are certain FPGAs which are individually tested in production and have embedded VID code telling which voltage they can be ran at to get the most out of them.
Once you're out of spec, you're in terra incognita, and anything can happen. For all we know, FPGA might be now half brain-dead and outputting a mains voltage on its pins just for the hell of it.
Post by: nockieboy on May 17, 2020, 10:01:51 pm
Fair point, I guess I'll have to set the 1.3V output to 1.2V then before I do anything else.
Post by: BrianHG on May 17, 2020, 10:55:32 pm
1.2v is fine for your design.  The overclock is way too small to need any boosting.  I mentioned it as a last result.
The way I designed the core, errors from overclocking would only represent glitches in the core memory, however, since you confirmed that the Z80 reads and writes to the core memory with the RS232 Debugger, this isn't where your problem lies.
(Only the core dualport ram is running at 250MHz (Of the 240MHz limit reported by Quartus) with an AB-mux switch.  And only around 8 signals are out of slack by less than 0.1ns. Everything else runs at 125MHz and report all in the green by a good margin.)
Did you check that the syncs are coming out of the right pins of the VGA connector?
Are you sending +5V to pin 9 on the VGA connector so that the monitor +Vsense pin knows it is being connected to a turned on video card? Never mind, your old development board doesn't have it.
Also, pins 5,6,7,8 and 10 should be grounded.
Can I see the latest schematic and pcb prints, the white PCB you showed me doesn't match what is posted on here on the forum.  Some Vias don't line up or are missing.
That darn white soldermask doesn't allow you to see anything.
Did your scope show a proper HS and VS coming out of the VGA connector, when connected to a monitor?  This should at least turn on the monitor.
What was the frequency of the CLK output to the DAC?
Can I have a copy of your latest Quartus project?  Your GitHub has only single files and I will not download all the files individually 1 by one.
Post by: nockieboy on May 18, 2020, 08:16:02 am
Okay, no problem, I'll either replace the ADJ with a 1.2V regulator or adjust the resistors to drop the voltage to 1.2V.  Have updated the schematic as well (though not the copy I'm attaching in this post).
I've checked with my logic analyser, which picked up no signals whatsoever.  I've yet to get the oscilloscope set up - unfortunately I haven't had the time or space to dig it out and get it set up, have been too busy with work, but will try to do some testing with it and get some results soon.
No, but I've added that into the schematic for the next iteration of the board.  I note that a couple of pins in the VGA standard are for an I2C connection to a ROM in the monitor?  Presumably to identify the monitor and get resolutions etc?  My uCOM has I2C, so I'm wondering if it would be worth connecting it up to the VGA port as well.  Might be something to look at later.
No, there's nothing coming out of the VGA connector at all as far as I can tell - with the caveat that I haven't yet got the oscilloscope on it.  I've checked these signals back to the FPGA and there's nothing coming out of the FPGA, so it's not (necessarily) the DAC or hs/vs driver (U6).
I have no test equipment that can measure a 50MHz signal.  My scope is only 20MHz and it's as old as the hills. The best I can do is jury-rig a couple of FFs and divide the clock by 8 or 16 to measure it on my logic analyser or oscilloscope, with all the associated extra wiring and bad connections that brings with it.  I'm actually waiting on some PCBs and parts to make up a proper clock divider.
All attached below.  :-+
Post by: BrianHG on May 18, 2020, 09:14:30 am
Unless the board is held in reset by the reset input, a sync must come out as that sync generator section is hard wired logic.
As for the clock, it is 25Mhz, and a 20MHz analog scope should see it as a sine wave.  If we have it at 50MHz, it would be a shriveled sine wave.
You have a few more questionable soldering GNDIO and VCCIO and VCCINT around the sync lines and the port on the photo you provided which was true-white / bottom left side.
Your meter may still read these as connections since there are multiple VCC & GND connection inside the FPGA, but don't let that fool you, with a small 144pin package, every VCC/GND still needs a physical good connection otherwise funny things happen as seen on other homemade PCB FPGA threads here at EEVblog.
Post by: obiwanjacobi on May 22, 2020, 06:11:31 am
Not read the 40 pages preceding this - but it might be an idea to make the simplest 'hello world' code and start testing the basics and work up from there. Sounds like you need to establish what is working and what is not at a basic level.
Post by: BrianHG on May 22, 2020, 06:31:05 am
The code is good.  nockieboy got it fully functional on a dev board with a good CycloneIV on it.  He has poor soldering joints on his home made board and bought his CycloneIV from a questionable source, as he already discovered that it has 1 confirmed dead IO pin.  Other than a voltmeter, his old analog scopes hasn't been able to tell him much other than all the IO feeding the DAC are dead.
Post by: nockieboy on May 29, 2020, 06:50:22 pm
Yeah, nothing further to add - the oscilloscope is showing all the IO are dead for the RGB and HS/VS outputs.  I'm just waiting on some low temp solder, an IR temperature gun and I'll order a good FPGA from a reputable source before trying again.
Post by: BrianHG on May 29, 2020, 10:12:34 pm
I would still 'drag' solder all the pins on the sides I mentioned.
In fact, with normal leaded solder, I would blob solder the pins, then, using solder wick, wick us the excess.
You have nothing to loose at this point.
Post by: asmi on May 30, 2020, 12:15:20 am
Or add a crap ton of tacky gel flux, and then go with a molten solder "ball" across all pins. Flux will prevent bridges, while excess solder will ensure good wetting.
Post by: BrianHG on May 30, 2020, 05:55:31 am
What the results of drag soldering should look like with normal solder:
https://www.youtube.com/watch?v=nyele3CIs-U (https://www.youtube.com/watch?v=nyele3CIs-U)
Take a look at 4:15.  This is what your soldering should look like.
Post by: obiwanjacobi on May 30, 2020, 07:13:38 am
I remember that when I first tried soldering SMD, I found it easier to get good (enough) results with simply using a small soldering tip and carefully touching up on each pin individually. My point: you don't have to drag-solder.
You DO need lots of flux and use very little solder.
Also be careful with using wick - better to prevent that by using very little solder.
[2c]
Post by: SiliconWizard on May 30, 2020, 03:15:08 pm
Gel flux helps a lot.
I for one usually don't "drag solder". I usually rather solder a few pins at a time with either a bevel or chisel tip (depending on pitch and accessibility), essentially "dragging" along the pins being soldered rather than dragging along the side of the package. Takes maybe a little more time, but it's still fast and tends to make fewer bridges. YMMV.
Post by: nockieboy on May 30, 2020, 06:09:23 pm
I had been using a wedge tip with a tiny blob of solder on the end and lots of waxy flux.  Had got it so that I could do a whole side of the 144-pin FPGA with no bridges, or a couple if I was unlucky.  I did try drag soldering, but found it just seemed to bridge the entire set of pins, no matter how much flux I used.
As soon as the IR thermometer arrives, I'll try another of the cheap FPGAs (I have two left) and see how they go.  I'm probably completely wrong, but I feel that I may have been overheating the chips when I was hot-air soldering the central exposed ground pad on the last couple of attempts.  I do that first, then I go round the FPGA soldering its pins using the methods above.
Post by: nockieboy on June 14, 2020, 03:46:35 pm
Okay, so I might have found out why the RGB and HS/VS outputs of the FPGA are 'dead'...  :palm:
[attachimg=1]
I hadn't included an inverter on the Z80's RESET input to the FPGA.  RESET on the Z80 is active low, this is obviously in opposition to the workings of the FPGA's positive logic, meaning the video circuit was constantly in a state of reset and not outputting ANY colour signals or video sync signals.  I've added the inverter as shown above in the red circle, and I can now get good, clear HS and VS signals from my latest board.  (I say latest, it's the third board I've built so far - the first being the only other working one, but with the bad IO on the data buffer.)  So I'll get the rest of the video circuit built on this latest card and give it a test.
Still, it's been good practice soldering these TQFP-144s.  This latest board is looking much neater.  :-DD
Post by: nockieboy on June 15, 2020, 02:01:42 pm
Have just uploaded the new HDL to the first board I'd made (the one with the alternate GPIO used for the data direction on the Z80 interface to bypass the bad IO pin) and it's working perfectly.  Image is stable, all the colours are there, everything seems to be working fine.  :phew: :-+
[attachimg=1]
[attachimg=3]
The second board I made seems to be dropping bit 0 on the data bus, so there's probably a bad IO on pin 142 for that board.  I haven't got around to building the DAC and VGA output part of that board yet.
The third board (version 2 PCB with AS/JTAG connectors spaced further apart, spare IO pins exposed as pads on the PCB and another spare GPIO wired to an LED) is working just fine so far, but I've yet to solder the DAC onto the PCB.  It's outputting HS and VS fine, though.
[attachimg=2]
So I'd call that a successful project!  ;D
I've thanked you previously, but I'll do it again - thanks for your help BrianHG and everyone else who has chipped in with info and suggestions.  It's all very much appreciated.  :-+
Once I'm happy with my HDL code additions (for the LED and audio output for testing), I'll update the github repo with the latest version of the project.
I'm waiting on some PS2 keyboard connectors - when they arrive, I can start on working on keyboard integration into the project.  That'll make my computer fully stand-alone, so it's a major milestone for me.  After that/while I'm waiting on the post, I'm starting to look into integrating an AY-3-8910 or YM2149 (old 80's sound chips) into the FPGA, somehow.  I have spare IO to drive a stereo output, it's just a case of adapting what little I can find out there to work on my EP4CE10.  I'm also giving some thought to how I'm going to give the Z80 access to an SD card via the FPGA too.
Oh, and of course continue working on the software side for the video output.  I'm tempted to start investigating the graphics modes on the FPGA/MAGGIEs and develop some graphics functions (PLOT, LINE, CIRCLE etc) in software - but I'm wondering if they could be done in hardware somehow, too?
Post by: asmi on June 15, 2020, 02:34:00 pm
Congratulations!
If you have documentation describing how it works, I would just implement it inside FPGA too (sound chips of that era were very simple - just a bunch of various waveform generators and a mixer to mix them together), and add an I2S DAC to actually output sound. This will also open a possibility of outputting high-quality audio too (like waveform players, which present in some audio chips of that era or maybe a bit more recent), as all I2S DACs support at least 44.1 kHz/16bit format (this used to be called "CD quality" as that's the format used on audio CDs, of course they support lower bitrates too). I2S bus is also extremely pin-efficient, requiring only 3 pins (bit clock, left/right signal and a serial data line), and it doesn't require particularly high frequencies too (unless you want to output audiophool-grade signals at insane bitrates, even though most people would never hear the difference).
Also - have you considered placing it all on a single PCB once you ensure your prototype works?
Post by: nockieboy on June 15, 2020, 03:14:52 pm
Congratulations!
Thanks asmi!  ;D
Yes, that's the idea.  Currently I'm using less than 50% of the logic and RAM in the EP4CE10, although I'll increase the number of MAGGIEs and RAM exposed to the host system shortly, I'm intending on keeping some spare space for the PS2 keyboard interface and whatever I can implement to make some noise.  Ideally, I'd like to emulate the AY-3-8910 (or YM2149 - same thing, basically) so that I won't have to change any of the chiptune software I have in CP/M (aside from port numbers in the 'driver').
I'm definitely no audiophool - in fact I'm pretty much tone deaf. ;)  Whilst the idea of CD-quality output is nice, it's not essential - I'm working with an 8-bit processor and am looking to recreate audio capabilities of its era, generally (though any improvement would be great; I'm obviously not too concerned about being period-accurate, otherwise I wouldn't be using an FPGA in the first place!)  ;)
It'd be an expensive PCB and besides, I've made it to be as modular as possible.  What you see in the previous post is a stack of five cards, from bottom to top:
You can add another memory card to up the memory to 4 MB, add other interface/IO cards etc, but as a bare minimum you just need the power, cpu and memory card to have a working system and can expand it as you see fit.  In future I'll likely be adding more cards to the mix - different CPU's, for example - with a Motorola 68010 being a clear destination on my mental roadmap.  :)
Post by: BrianHG on June 15, 2020, 03:40:40 pm
Congratulations!
Too bad that over a few months gone to waste on an inverted reset input signal.  :palm:
At least the RS232 debugger wasn't tied into a reset and still functioned, otherwise with nothing working at all, who knows what you would have done with what would have been almost a totally dead FPGA...
Post by: asmi on June 15, 2020, 03:52:28 pm
That's fine - you can work with 8 bit data internally, and upconvert data to 16 bits (or even to 24 bits) right before sending it off to DAC - basically you left-align the data by adding 0x00 to the right (equivalent to logical left-shift by 8 ). Since the I2S is a serial bus, it doesn't cost you any more pins and no FPGA resources because I2S protocol itself requires sending quite a bit of "nothingness" for padding purposes.
Come of think of it, I also wonder when (historically) DMA became a thing in computers, because playing waveforms off storage it real time is going to consume quite a bit of CPU time. My memory is rather fuzzy on that I was born in 84, so most of pre-IBM PC stuff went before I got into computers ::)
I just think that having a single board (or more sensible modularity a-la computer motherboard with main board and extensions as opposed to "sandwitch-style") looks better, but it may be just me ^-^
Post by: nockieboy on June 15, 2020, 04:33:23 pm
Congratulations!
Thanks!  Yep, well, at least I'm not working to any kind of deadline.  It's just something I'm doing to pass the time, and it's certainly doing that!  ::) ;D  Funny how I instantly doubted my soldering and the hardware before checking the software more thoroughly.  Can't even remember why I was looking at the reset circuit and noticed the problem with the Z80's reset line.  :-//
Well, I was able to operate the speaker via IO port writes from the Z80, and read/write the GPU RAM, so I knew the FPGA wasn't totally dead, but I'd have ordered more FPGAs (from expensive but reputable sources), doubted my soldering skills even more and eventually given up, probably.  |O
Post by: nockieboy on June 15, 2020, 04:46:03 pm
Oooh I won't be playing waveforms or anything like that - at least not in the way you're thinking.  Before DMA and IBM-style sound cards, in the realm of 8-bit computers in the early 80's, a dedicated sound chip was used and data sent to it on a byte-by-byte basis with instructions on volume, pitch, duration etc.  It was still CPU-intensive and I think the commands/data to the sound chip were usually updated during the blanking interval at the end of each frame (I'm no expert though, so don't quote me).
The decision to go the route I've gone with the stacking headers boiled down to some VERY early (and uninformed) decisions I made when moving from breadboard to PCB a year or two back.  When I started, I knew next to nothing about electronics, PCBs and all the essential skills you need to design and build this kind of project.  Stacking headers seemed the most cost-effective and easy way to get the project working, given my skills and knowledge with electronics at the time.  Now, however, being more experienced in everything from electronics to soldering to PCB design, I'll likely change the format completely when I move on to a 16-bit system for my next project, but that's still a long way off yet.
Post by: NorthGuy on June 15, 2020, 08:15:28 pm
Congratulations! I haven't participated in the thread, but I have followed. Great job!!!
Post by: BrianHG on June 16, 2020, 12:25:03 am
@nockieboy, how's the DAC's quality?
     There was one thing about the data and clock feeding the DAC's digital inputs which I didn't consider when setting the output pins because of the slow 25MHz speed.
     If you see any pixel glitches, or, when you finally create a 'grey' ramp test pattern with each shade of grey being at least 4 pixels wide, if there are any fine vertical stripes between any 2 grey shade bars, inverting the DAC's CLK output pin will solve the problem.
     (This is due to driving the data lines and the CLK output both from D-flipflops outputs and we may be violating the setup&hold time for the DAC's digital inputs as all the transitions are right at the same time as the rising edge of the clock.)
Post by: BrianHG on June 16, 2020, 12:40:01 am
Yes.  You would create a command port address where the Z80 can feed a small FIFO input which would have something like a 16-64 commands x 64 bits (16-64 commands x 8 word x 8bits each).  Something like a 8bit function, pen FG/BG color & fill color, start x,y, end x,y coordinates + a third set of x/y coordinates if you want to make a triangle filling engine.
On the other side of the command FIFO, you would have your sequencer which would read a 64 bit command from the fifo whenever it is not empty, you will loop the start and end coordinates in the drawing pattern & write to a free memory port since you have 15 read/write ports running at 25MHz.  This would sacrifice 1 maggie channel as it would become a hardware accelerated pixel plotting channel.
1 more memory channels will be needed if you want to accelerate copy & paste graphics memory.  Something like a software sprite, or accelerated graphical paintbrush or fonts.
Those 15 ports gives you some cool capabilities, not to mention that you can use this engine to feed the main Z80 port as well allowing a drawing engine which can fill up to 125 million pixels a second instead of 25 million pixels a second.
Post by: nockieboy on June 16, 2020, 09:03:31 am
Hmm.. well, I haven't noticed any graphical glitches or stripes as you've described - the image looks good.  As you point out, though, I haven't set up a greyscale pattern yet and I'm just going by what I can see on the image of the Z80 you created.
I've got some experimenting and learning to do now that I have a stable system to play with (the original prototype suffered greatly from all those wire connections between the uCOM and the level converters on a breadboard, then to the FPGA dev board itself - it was getting more miss than hit as time went by) - I need to refresh my memory on the various MAGGIE colour modes and get a greyscale test image set up.
Quick question - what did you use to create the image of the Z80 chip?  Is there some format option or settings I can use to save an image in a suitable format to dump into the GPU's RAM?
Now this is where you're going to lose me very quickly again. :o  So the FIFO would be 16-64 commands deep with each command having space for up to 8 bytes?
Okay, so 1 MAGGIE used for hardware accelerated pixel plotting, writing the output from the sequencer into RAM.
A blitter (http://amigadev.elowar.com/read/ADCD_2.1/Hardware_Manual_guide/node0119.html), basically?
Okay, I feel I did pretty well up to this last sentence.  :o  Feed the main Z80 port? :-//  Even at 25 million pixels a second, isn't that a minimum framerate of over 80 fps at 640x480?  That isn't too shabby.
Post by: nockieboy on June 16, 2020, 11:31:14 am
Hmm.. think I have an issue with bit 1 of the green channel?
[attachimg=1]
Not a great picture, but there should be two more black squares to the left of the visible purple ones.  All should be shades of grey.
Post by: BrianHG on June 16, 2020, 11:33:41 am
When I say fifo on a Z80 port, I mean a memory address you may choose which allows the Z80 to write to the fifo.
You would also provide a 'fifo' full flag for the Z80.
The fifo actually isn't necessary, but it will allow your Z80 to post multiple drawing commands while the other side of the fifo which seeds the sequencer pixel plotter is busy working plotting pixels.
As for the commands, I would prefer an 8 or 16 bit word system.  1 byte control, 1 byte data.
On your sequencer side (the thing which reads and follows the commands in the FIFO and draws the lines) , your commands would be something like:
set coordinate x1 high byte.
set coordinate x1 low byte.
set coordinate y1 high byte.
set coordinate y1 low byte.
set coordinate x2 high byte.
set coordinate x2 low byte.
set coordinate y2 high byte.
set coordinate y2 low byte.
set foreground color
set background color
set drawing color depth
set graphics destination ram coordinates high byte
set graphics destination ram coordinates low byte
set graphics raster width size
set graphics screen width limit
set graphics screen height limit
run line
run circle
run circle filled
run rectangle
run rectangle filled
run triangle
run triangle filled
run/stop/reset geometry engine (this 1 command may be on it's own dedicated port with immediate action regardless of the FIFO's state.)
That's already 24 commands.
For accelerated graphics, I would pre-compile your graphics generating list and feed the fifo in a straight manner.
I would also double buffer the geometry settings so you may draw new shapes while only updating only the required coordinate changes instead of re-filling all the settings every time.
As for the BW Z80 graphic I made, I loaded and cropped the image into Paint-Shop-Pro 6.
Then made it black and white.
Then saved it as a 'RAW' image data making it 8 bit per pixel, IE: 1 byte per pixel, no header in the file.
Then passed that 'RAW' file through my home-made basic program which can squeeze the image down to 4 bits, 2 bits or 1 bit.
(Obviously, for 8 bit, you don't need any conversion from the 'RAW' format.  Also, if you switch your palette to a MAC default 256 colored palette, using (PSE) Adobe Photoshop Elements 9, that paint software will generate an 8bit  256 color image matching the MAC palette so you may insert full color scan.  The MAC 256 color palette is pretty good for faces and most other photos as the Adobe Photoshop will dither the results to look like a few thousand colors.)
I've attached my bitplane converter.
Note that the 256 output mode actually divides the 256 gray shade image down to 16 shades of grey and places that image on palette color 16 through 32.  (This has nothing to do with the Photoshop true 256 full color image which doesn't need any processing, all you need for that it to adjust your palette to match Photoshop's Palette converter's settings)
Photoshop 24bit color to Paletted image converter: Go to 'Image / Mode / Indexed Color'.  You will also most likely try to google the file format it uses to load and save a palette to convert to you GPU palette generator.  Also, dont forget that your GPU can hold 2 different palettes simultaneously as well as sub 16/4/2 color chunks of both palettes selected for each MAGGIE window.
[attach=2]
Post by: BrianHG on June 16, 2020, 11:47:17 am
(Attachment Link)
Check for short/adjacent short/open/dead IO pin.
Chick IO pin table.
Check palette data.
Remember, when using the 4444 palette, you can only have 4bits red,green,blue.
When using the 565 palette, you only have 5 bits red and blue, but only 6 bits green.
I don't remember how we wired the LSB bits in the code, but they may have been tied to the MSB bits to allow full contrast color.
Post by: BrianHG on June 16, 2020, 12:31:32 pm
Ooopsie, I forgot you are using bitplanes.  This means to write a pixel, you must read it's data, modify only the bits you are interested in changing, then write that data out.  That is unless we implement the bit-for-bit write mask feature which is available in Intel's dual-port ram megafunction.
This will be up to you.  As for the Z80 port, just use the RS232 debugger channel and you can then write 75 million pixels a second, or around 25 million read-modify-write pixel drawing commands.  This way you will not use up any MAGGIE channels.
Post by: nockieboy on June 16, 2020, 12:52:27 pm
I have no idea what the benefits or drawbacks are of using either system, other than the bit-for-bit write mask feature sounds like it could speed things up a little, not that speed is an issue?
Post by: asmi on June 16, 2020, 02:04:11 pm
Maybe it would be better to do it "the modern way" (how modern video cards do it) - CPU can create however many "command lists" in video memory it wants/needs, and then there is a GPU register which specifies the address of the current command list, and the way it works is that video core only reads it's value once in the beginning of a frame and executes it to the end before it reads the register again. This way a list switchover is guaranteed to be consistent, CPU can take it's time to create a new command list asynchronously from video core, and a video core can also prefetch entire command list from video memory into some kind of queue to improve core's performance.
If you guys have some spare time for reading, I highly recommend to read this blog series about how modern video cards and Graphics API work: https://fgiesen.wordpress.com/2011/07/09/a-trip-through-the-graphics-pipeline-2011-index/ Even if it won't be directly applicable to this project, it's still a very interesting reading, and can give you some ideas for your own designs.
Post by: BrianHG on June 16, 2020, 03:33:29 pm
     Until nockieboy adds DRAM to his GPU or goes to the 4megabit Lattice FPGA (preferably doing both simultaneously during the upgrade), I recommended a 1 to 2 kilobyte fifo since his GPU ram is very limited while his Z80 ram is huge.  It's just a strategy to minimize wasting the core graphics memory.  (With the Cyclone IV ram allocated as large as possible for the video core, there are a spare 2-4 kilobytes of ram which cannot be allocated as that 1 huge chunk, so, this additional fifo/graphics command buffer will end up in those and will actually have 0 penalty on the bulk graphics ram anyways.)
     When I say fifo, well it could just be a ram block with address pointer.  Or, this address pointer just feeds one of his 15 read ports.  With added 16 megabytes dram buffer, which would probably add another 7 MAGGIE ports + 1 Z80 R/W port, the fifo may be replaced with reading directly from one of those DRAM channels while the core memory MAGGIE channels will end up being used as sprite/texture data while the bulk DRAM will contain the full background graphics.
Post by: nockieboy on June 16, 2020, 04:27:15 pm
I don't seem to be able to get a reasonably-priced Lattice dev board from anywhere - unless anyone here can point me in the direction of one around the £30 / $40 USD mark that I haven't been able to find?
But yes, the next step is to start looking at the Lattice chips and building a board with one of those on it.  In fact my success on my first attempt with this video card (delay finding the HDL bug aside) and asmi's blog (http://thingselectronic.blogspot.ca/) has almost inspired me to make the jump to BGA - I guess hot air-soldering one isn't impossible?  May as well add a DRAM while I'm at it.
Yes, I'm making use of the RAM all the way up to 32KB now (leaving the 1KB for the palette at the top, still) - for some reason I've probably forgotten, NUM_WORDS was set to 24,575 (0x5FFF).  With 10 MAGGIEs, I'm at 74% of total logic elements.  The EP4CE10 has another 12KB or so, but I can't make use of it without messing with the RAM HDL and getting waaay out of my depth very quickly, so other uses for that RAM would be welcome.
Post by: asmi on June 16, 2020, 04:36:59 pm
The big advantage of using command lists is that it completely decouples GPU performance from CPU, allowing you to scale them independent of each other. And I don't think they will consume all that much memory, unless you're going to do something really insane like per-pixel drawing (which is always going to be much slower than using primitives).
Post by: SiliconWizard on June 16, 2020, 04:39:21 pm
I suppose you're looking for some ECP5 dev board? You'll have a hard time finding one in this price range. The MachXO2/3 boards are around $25, but those FPGAs are probably largely "underpowered" for your requirements?
The official ECP5 eval board is $99.99. Certainly more expensive than your target price, but I couldn't find anything cheaper based on an ECP5. https://www.latticestore.com/products/tabid/417/categoryid/59/productid/122774/default.aspx (https://www.latticestore.com/products/tabid/417/categoryid/59/productid/122774/default.aspx)
There is this open-source project: https://gregdavill.github.io/OrangeCrab/ (https://gregdavill.github.io/OrangeCrab/)
but: very few IOs broken out, and no ready-made board that I know of.
Post by: asmi on June 16, 2020, 04:46:11 pm
You're making your own board, right? So what stops you from adding an SRAM/SDRAM chip on it, or HyperRAM chip if your IO pin budget doesn't allow for the former (HyperRAM only uses 12 IO pins and has 64Mbit capacity running up to 100 MHz DDR for 3V and 166 MHz for 1.8V version)? Of those, SRAM is the easiest to implement a controller for (it's literally "place address out, read out the data on the next cycle"), followed by HyperRAM (because it "looks" like PSRAM meaning refresh is taken care of internally, and protocol is very simple, though it has quite a bit of latency from initiating command until first byte out).
Post by: nockieboy on June 16, 2020, 04:55:40 pm
Ah, that's okay then, I was just worried I was missing something somewhere.  Will have to wait a while to get one of those - I think trying to build a video card based on a Lattice FPGA may be a little fraught with problems, but then again I'm not sure what a dev board will do for me.  I've got the HDL, might need to tweak it some for the Lattice environment, all I need really is to get one onto a board so I can program it.
Is the toolchain similar to Altera's?
Yes, have made my own board - pictured previously.  The biggest problem stopping me from adding SRAM/SDRAM is the lack of free IO.  I've got literally 4 IO pins left free - I can stretch that to 7 if I drop the SD card that I want to include.  This is one of the reasons I'm probably using this platform as a stepping stone to BGA, but I get panicky if I think about that too much at the moment.  :scared: ;D
Post by: SiliconWizard on June 16, 2020, 05:04:02 pm
This basic dev board doesn't have SDRAM or DDR RAM so, that might be a problem for you (unless the amount of block RAM is sufficient.) There are other Lattice ECP5 dev boards, just take a look, one of them probably has that.
I have never really used Altera's tools much, so I can't really comment. But Lattice Diamond is reasonable and easy to use. I rather like it.
Speaking of Diamond, the ECP5 series is actually not supported by the free version, so you'll need an extra license. Lattice dev boards come with a free license (limited to the ECP5 model there is on the board IIRC), but if you don't buy a Lattice dev board, you'll probably have to buy a license. I have no clue about the current pricing. A few years back, it was $99/year, but it may have changed!
Post by: asmi on June 16, 2020, 05:39:32 pm
You will come to that eventually, like I did, and so did many others. At least now you've successfully passed the first stage  - "who the f*ck needs so many pins???" - and started to understand exactly why having more pins is good, not bad ;)
Like I said a million times before, your best bet is to give it a try. Begin from the cheapest FPGA in BGA package you can find, design a simple breakout with nothing on it except the bare minimum required to program the chip + some LEDs. My very first FPGA board used the cheapest 7 series chip I could find (at the time it was A15), once I got that working, I felt much more at ease working with more expensive parts. Now I don't shy away from placing $100+ BGAs on my boards.
Post by: NorthGuy on June 16, 2020, 06:15:24 pm
Sure is. The balls are made of solder, so all you need is a little bit of flux which you put on the board. Put it on and start heating. When it moves, pock it gently to make sure it's sitting well, count to 5, then remove the heat slowly.
Post by: nockieboy on June 16, 2020, 06:41:58 pm
Ah, the licence may be a deal breaker for me. :'(  I'm not building this with making profits in mind, it's a personal project and having to pay a yearly fee so I can use an IDE to program FPGAs sort of flies in the face of my desire to keep this hobby as a hobby.
Mind you, if I'm looking to step up to BGAs, then the options open up further for other makes of FPGA as well.  I could just get an EP4CE10 (or upgrade slightly to the CE15 or beyond) in a BGA package and have access to lots more IO that will let me add an SDRAM etc.
So adding SDRAM would be a definite benefit then?
That is so true.  I had no idea about FPGAs before I started this thread - literally none at all - and now I'm struggling with the limited IO on my FPGA - and that's just interfacing it to an 8-bit microprocessor and VGA video output with a couple of extra addons (SD card, PS/2, LED, speaker).
I'm quite enjoying learning about them and using them, though.  Whilst a lot of these discussions about various components of the video driver are going over my head, I'm also learning so much and loving the versatility of FPGAs.  But now I'm feeling the need.... for moar IOs!  ;D
I've spent a little time reading your blog today and I must say it's giving me a little confidence to go and try and make a BGA-based card.  I don't have a reflow oven like you, but I have a cheap hot air gun, lots of flux, some low-temp lead-free solder (now), and a desire to give it a try, so I think I'll take your advice and see what I can do.
Had a quick look for some BGA FPGA packages I could start out on - found this as the cheapest option:
LCMXO2 (https://www.mouser.co.uk/ProductDetail/Lattice/LCMXO2-256HC-4UMG64C?qs=aG4jnN2UxMUhCNE6rpggwg%3D%3D) - a Lattice MachXO2?  I'd rather stick with Intel/Altera as I'm familiar with the toolchain now, but the cheapest EPx FPGA I can find is over £15 for an EP4CE6 (https://www.mouser.co.uk/ProductDetail/Intel-Altera/EP4CE6U14I7N) from Mouser, or £18 for two EP4CE10F17s (https://www.aliexpress.com/item/32830183164.html?) from AliExpress.
Those EP4CE10F17s from AliExpress are 256-pin FineLine BGA packages... I've had a quick look to see what their dimensions are, looks like a 1mm pitch??  I'm guessing JLCPCB would be fine with that.
I'm also going to have to go to 4-layer PCB fab as well, I'm guessing?
Thanks NorthGuy.  :-+  I guess I just need to give it a go and build my confidence by doing it with smaller, cheaper packages first like asmi has suggested.
Post by: asmi on June 16, 2020, 07:14:13 pm
That is one reason I've chosen Xilinx from the get go - they provide a lot of useful stuff for free, as well as give access to a lot of devices, including some really beefy ones like Artix-200 with 200k gates.
One thing you need to note is that FPGA lines usually consist of several pin-compatible device subfamilies with different densities, so you can install larger device on your board if smaller isn't enough without board respin (or the other way around), if you designed your board to support the largest device is this pin-compatible subfamily from the get go (usually this means using DC-DC converters capable of providing enough current for the largest device). This is why you can take my Spartan-7 board and install any device in that package, and it will work. There are some gotchas with this approach, but in general it works just fine.
Having something is always better than not having it :) But you still got to watch out to not run out of pins - BGAs do have more pins, but you will run out of them just as well ;D
Thanks, I wish I would have more time to post stuff there, I got a lot to say, but no time to actually write it up and prepare all related materials (like pictures and stuff).
I would recommend you to be careful with those aliexpress chips, especially in the beginning as it's somewhat of a lottery and there is a chance to receive a dud. Imagine that you soldered your first BGA FPGA on, and it's not working. Why? Is it because you screwed something up in schematics, or it's a soldering failure (I'm yet to encounter one, but it is always a possibility), or your FPGA is a dud? How do you figure out which one it is?
This is why I'd suggest you to skip morning coffee for few days (or some beers for one Friday, since you're in UK ;D), and buy a known-good chip. At least this will all but eliminate one possibility. But be prepared for schematic/layout screw ups - it happens even to the best of us who should know better, and for me my first revision of any project almost never even gets to assembly, as I find some fatal flaw either while waiting for the boards to get manufactured and delivered, or during some basic testing of newly arrived boards.
Yes, that would be a start. You can do quite a bit with 4 layer boards nowadays, with more and more manufacturers allowing for ever narrower traces without paying through the nose.
If you don't mind working with older FPGAs, you can try getting your hands on some FBGAs with leaded solder balls instead of usual lead-free stuff. Yes, you can still find them even on Digikey, here is one example: https://www.digikey.com/products/en?keywords=XC6SLX25-2FT256I (https://www.digikey.com/products/en?keywords=XC6SLX25-2FT256I)
Also make sure you place your BGA devices far enough apart from other parts to make hot air gun assembly easier as you won't have to worry about blowing some nearby parts off board.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: NorthGuy on June 16, 2020, 07:16:56 pm
XC7S6-1FTGB196C is less than US $15 from Mouser.
Post by: nockieboy on June 16, 2020, 07:50:14 pm
Already been there with the current batch of EP4CE10 TQFP-144's I got from there.  Thing is, I intentionally got them from AliExpress knowing (or suspecting) that they may not be fully functional, but I did it because I needed practice soldering TQFP packages - I'd never done anything like that before, especially not with the exposed ground pad underneath.  Now I'm happy I can solder them reliably, the next batch I would get would be from somewhere like Mouser or Digikey.  So far, the success rate for the 3 FPGAs from AliExpress are 2 with a single dud IO, 1 working just fine.  But I'll update that once I get the third card fully built (though it's working fine so far).
Running my schematics and PCB design past you guys here seems to have ironed out most of the critical errors - the only issue I've found with the PCB so far is that I think I messed up the PS/2 socket wiring, but everything else is just fine.   :)
So what are the issues with lead-free stuff?  Are all the newer BGA FPGAs with lead-free solder balls?  In theory (and from what I remember of your blog!!) then an ENIG finish on the PCB would give better soldering results if I have lead-free BGA balls?
Post by: asmi on June 16, 2020, 08:17:54 pm
You're talking about logic, while I'm talking about perception. Your very first try would better be a success as it would provide insane morale boost, so even if you will see a failure down the road, it won't be that big of a deal.
Unfortunately since I focus pretty much exclusively on Xilinx 7 series devices, I can't help much with other devices. That's why I was kind of nudging you towards these devices, as I know them fairly well so I can say something actually useful and helpful ::) Specialization has some bad sides as well as some good ones.
Most modern chips are lead-free. But to be honest, I tried pretty much all combinations (LF balls with leaded paste, LF balls/LF paste, HASL/HALFSL/ENIG), and all worked OK. I still recommend ENIG because it provides flat surfaces and protects pads for a long time from corrosion. ENIG is compatible with both leaded and LF solder, infact I'd argue leaded solder provides stronger bond.
The reason I suggested using BGA with leaded balls is because they melt at lower temperature, so it's easier to solder using hot-air gun (for ovens it doesn't matter at much).
Post by: nockieboy on June 17, 2020, 10:46:01 am
True, fair point.  Well, it seems if I want to practice on an FPGA that is in the same family as the Intel/Altera ones I've been using, I'm looking to spend about $12 each on BGA packages (obviously excluding PCB fab costs too).  I don't mind too much learning another toolchain (I actually have an unused Spartan FPGA board on a shelf and the programmer to go with it), so do you have any recommendations on a cheaper option I can practice with?
Ah okay, I hadn't thought there'd be a difference in melting point, but that's logical.  Do you need additional solder (i.e. a solder mask) for BGAs, or can you just drop one onto a PCB (tacked in place with some sticky flux), and heat it up?
Post by: asmi on June 17, 2020, 03:04:33 pm
Like I said, the only practical experience I have is with 7 series devices because quite frankly they cover pretty much entire range of my immediate and potential near-to-midterm needs, allowing designs from very simple glue logic at the small end all the way to 933 MHz DDR3 memory and 10+ Gpbs transceivers for pretty much any modern hi-speed interconnect I can think of from HDMI/DVI to PCI Express 3.0 and 10G Ethernet.
That said, if you want to practice BGA soldering (not necessarily FPGAs), buy a bunch of QSPI flash chips in BGA-24 package (for example this (https://www.digikey.ca/en/products/detail/cypress-semiconductor-corp/S25FL116K0XBHI030/4914896)), get an FTDI's 3.3V MPSSE cable (or any 3.3V microcontroller you have which has an SPI port available), design a small breakout (this chip can be broken out on regular 2 layer board), and get on with your practice! Once you solder the chip down, you can use SPI master device (be in an MCU, or MPSSE cable) to verify that soldering was a success and you can communicate with the chip.
Solder and solder mask are two different things, the purpose of the latter is to prevent former from getting into places where it isn't supposed to go :)
If you use a hot air gun and ENIG (or any other flat) finish, you can go either way with or without additional paste on BGA pads, if using something like HASL, then you don't need to use solder paste as HASL already IS a solder :) With ENIG, advantage of soldering with solder paste on pads is that after soldering the device is sitting higher off board, which, for example, makes washing off remaining flux residue as well as small solder droplets (these quite often form in the oven) from under the package easier.
So I'd recommend sticking to ENIG, and not adding solder paste onto BGA pads before soldering unless you have a stencil and print solder onto entire board at once. Just add a good amount of tacky flux, and go for it. One thing - as flux heats up it loses viscosity and becomes more liquid, so if you put a bit too much of it, the part may shift a little (not a problem at all for reasonable pitch BGAs say 0.6+mm, but can be a big problem for microBGAs with <0.5mm pitch). As for package alignment - as you may or may not know, molten solder has very high surface tension (easy way to see it is to progressively add solder onto soldering iron tip - you will see that you can add A LOT before it drips, and the reason such big ball still hangs onto the tip is the surface tension), so BGAs tend to self-align if misalignment is less than half of the ball pitch, but if it's more, they can self-align into the wrong pads (off by 1), so you need to make sure misalignment doesn't exceed pitch/2 (again, this is typically not a problem for 1 and 0.8 mm pitch devices which you likely will be working with).
Post by: NorthGuy on June 17, 2020, 03:43:59 pm
Since you do not have good control over placement when you do this manually, you're risking smashing the solder paste and perhaps short something inside (although a chance of this is not that big). Thus, it looks more reliable to me not to use any solder paste, only flux. This lets you move the FPGA freely and thus you can achieve better placement prior to heating.
When you don't use solder paste, it is more important to have a flat surface. I've never used anything but ENIG, so I cannot comment on other surfaces.
The amount of solder added by the solder paste is small compared to the amount of solder in the balls, so it doesn't affect the quality of the connection much, for prototyping anyway.
Don't use too much flux, or it may start bubbling and bubbles will start escaping from under FPGA lifiting it up which may screw up the alignment.
Post by: nockieboy on June 17, 2020, 04:16:19 pm
Righto, will take a look at those QSPIs, they sound like a good way to practice.  :-+
Well done, you spotted my deliberate mistake.  ;D  Of course I meant an SMT stencil.  ;)
I've been using HASL all along so far - haven't really had enough there to solder anything to it without requiring additional solder, though.  I think I had one TSSOP pin actually tack down with no additional solder, but it needed some more before I was happy with the electrical connection.  I suppose what little is there would help a BGA ball to melt/attach, though.
Yes, I'm intending to start with 1mm pitch BGAs.  Aware of the self-alignment due to surface tension - have found it very useful when soldering the 3225 oscillator to the video card. All sounds very promising - I'm eager to get started, now! :)
Post by: nockieboy on June 24, 2020, 02:43:49 pm
My second video board is up and running with 10 MAGGIEs currently, no dead IOs found so far, nice clean grey scale bar show all RGB outputs are working:
[attachimg=1]
The picture isn't great - my phone has a potato camera - but all 15 shades are visible (there's two blacks).  Working on the PS/2 interface now.
Post by: nockieboy on June 25, 2020, 01:39:14 pm
Okay, more of a general electronics question now.
I've noticed that the 1.2V regulator (AMS1117-1.2) is getting very hot - around 60 degrees Celsius (140 degrees Fahrenheit) which I'm attributing to that fact it's running from a 5V source rather than the amount of current being drawn by the FPGA (it's all running fine from a USB cable).
I've been working on a v.2 board design for a little while, incorporating improvements to the power routing (widening traces where possible) and so on and I've changed the power to the AMS1117-1.2 from 5V to the 3.3V source,  believing (rightly or wrongly - let me know!) that dropping from 3.3V to 1.2V should create less thermal load than from 5V.
Is that right?  Will I have other problems (not enough power in the 1.2V rail, for example) though if I do this?
Post by: JagV12 on June 25, 2020, 01:55:27 pm
AMS1117 is a 'linear voltage regulator' which means that its power dissipation is (Vin - Vout)*Iin. So, the lower the input voltage, the better as long as drop out voltage is above 1.3V. This means the minimum input voltage should be 2.5V for a 1.2V regulator. 3.3V should then be OK
Post by: asmi on June 25, 2020, 02:17:03 pm
Or do it the proper way - replace linear regulator with switched-mode buck converter.
Post by: BrianHG on June 25, 2020, 04:33:09 pm
Right now, lowering the regulator's source to 3.3v will be borderline for your EP4CE10E22C8N.  If you spend the 1$ extra and go to the larger EP4CE15E22C8N (Yes, there is a 1 dollar price difference to get 50% more logic gates), you will need to go to the switched-mode buck converter as the larger core draws will draw more current as soon as you increase the 10 maggie layers in Quartus to 15 layers.
Make sure the regulator is set to 1.2v out.  Using it you default 1.3v causes an excessive amount of current draw from the Cyclone core.
Post by: nockieboy on June 25, 2020, 04:54:30 pm
Hmm.. the only issue with the EP4CE15 is that it doesn't have the required IO pins for my project (it drops from 91 to 81 IO pins).  To use a more powerful FPGA I'll need to switch to a BGA package as we've been discussing recently, in which case I'm looking to go to the EP4CE22 which has an increase in RAM as well and will require a complete redesign of the PCB.  I'm in the initial stages of creating the schematic for it, but I'm all ears for suggestions on how to improve any aspect of the design, including the power supply.  So switch-mode buck converters on the 1.2V AND 2.5V?  Will I need to beef up the 3.3V supply too or is that just used for the IO?
My first video card had the regulator set to 1.3V, but I've since changed it to 1.2V and the second video card is a straight 1.2V regulator.
Post by: asmi on June 25, 2020, 05:30:29 pm
The thing to watch out for with bucks is Vout ripple. I skimmed through Cyclone IV datasheet but couldn't find any specs for it. For reference Spartan-7/Artix-7 have requirement of <50 mVpp @20MHz BW, which is very generous and is rather easy to achieve with multiple MLCC caps at the output. Most modern-ish buck ICs are designed to work with MLCCs (which are unique due to their ultra-low ESR), but some older devices will be unstable.
As for specific devices, my favorite low-ish current buck is TLV62130, which accepts up to 17 V (so I can use 9-12-15 V walwarts, which I'm sure we all accumulated aplienty of from all kinds of electronic devices bought over years), is fairly cheap and can output up to 3 A of current. Right now I'm evaluating AOZ2151 IC, which accepts up to 28 V (so I can use up to 20 V rail coming from USB-C PD directly), provides up to 4 A of current, and is more precise (1.5% over PVT vs 2.5% for TLV62130), while still being cheap. Both are available in QFN-ish packages, and so ground plane can be used as heatsink (super important when you have several such devices close by, as they collectively can generate quite a bit of heat).
Post by: nockieboy on June 25, 2020, 06:31:23 pm
Okay, so it looks like I'm going to have to review my power supply if I'm going to go to a larger BGA FPGA.
My system has a 5V primary power rail powering everything, which is sourced from either the USB cable providing the serial connection with my desktop PC or a wall-wart DC input via a 7805.  An AMS1117 provides the 3.3V rail from the 5V supply.  The system as a whole currently pulls about 0.04A according to an imprecise USB voltage measuring tool I've just tried on it.
I based the FPGA design on a schematic for the dev board I was using to prototype the video card - so the power rails are identical to the ones in my dev board.  I've hunted down a schematic for a dev board using the EP4CE22F17 as well (the DE0-Nano (https://wiki.ntb.ch/infoportal/_media/fpga/boards/de0_nano/de0-nano-schematic.pdf)) and was intending to use that as a reference when designing the supporting circuits and power supplies.
Post by: asmi on June 25, 2020, 07:10:47 pm
That schematics has 1.5 A LDO for the Vccint rail :palm:
See attachment for the schematic of the buck that you need (taken straight out of device datasheet). As you can see, there are only 3 extra components compared to typical LDO implementation - one 3.3 nF cap to set up soft start (can be omitted if you don't particularly care about slowing down startup), 100K resistor for "power good" signal (again optional, can leave unconnected if you aren't going to use this signal) and inductor, so really only inductor is mandatory. Everything else (input/output caps, Vout setting resistor divider) is the same for buck and LDO. This circuit will give you 90+% efficiency almost across entire range output current when powered by 5 V, and so it probably won't be even warm at full 3 A current.
Post by: BrianHG on June 25, 2020, 07:28:08 pm
If you are going BGA, maybe taking a look at the Lattice 15$ fpga with 2 megabits ram may be useful.
I would also add 2x of the 'S70KS1281DPBHV020' 16 megabyte ram chips, each on their own 10/11 wire buss while only sharing their differential PLL clock outputs.  This would allow 2 separate banks of operation.  Though, you will need to wire 1 IO bank at 1.8v to get the full 250MHz speed of your core PLL clock.
At 2.15$ a chip, not as cheap as strict DDR ram, but it has a built in ram controller.  And Maggie can only address 16 megabytes anyways, maybe 32 megabytes with some modding.
Unfortunately, the good price of the 'S70KS1281DPBHV020'  is like that because it is being discontinued.  You need to go with the smaller 8 megabyte newer 'S27KS0642GABHI030' at 4.35$.  You need to wire 2 of them on 1 bus with separate CS# to match the S70K....  But in this configuration, during the 'additional latency', if setup properly, you can run 2 of these in a dual bank mode.
These are normal DDR2 rams and are much more available and cheaper per MB, but you need a DDR2 controller:
W9725G6KB-25
Post by: BrianHG on June 25, 2020, 10:37:12 pm
Look at what I found, DIY reballing.  You will need a dummy stencil for reballing, solder paste & a hot air gun, bu here is someone doing it: (Begins at 5:45) (IE, you can now remove and re-position/mount a failed mounted BGA IC again and again.)
https://www.youtube.com/watch?v=8a5Uvj5ibWI (https://www.youtube.com/watch?v=8a5Uvj5ibWI)
Since these stencils are cheap, then it is worth it if you have everything else:
Reballing Stencil (https://www.aliexpress.com/item/32555671822.html?spm=a2g0o.detail.1000060.1.37305c742Pcq9y&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=e89234c4-c868-4b53-a821-f3f8ee687201&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.13339.146401.0,pvid:e89234c4-c868-4b53-a821-f3f8ee687201,tpp_buckets:668%230%23177981%235_668%23808%233772%23903_668%23888%233325%231_668%232846%238114%23773_668%232717%237560%23281_668%233164%239976%23623)
Post by: asmi on June 26, 2020, 01:27:49 am
I've been working with BGAs for over 3 years now, and I have never had a soldering issue, and so never had to reball anything. But I only use chips purchased via official channels, so I'm not sure how things would go if I were to buy them off aliexpress et al.
Post by: asmi on June 26, 2020, 02:06:54 am
Lattice devices suck in a sense that they usually come in small pitch packages. And zero free IPs - you're on your own. If he changes vendor, he might as well go Xilinx as they are the best anyways.
You need to use 1.8 V Vccio and differential clock to get 166 MHz (or 200 MHz on newest HyperRAM 2 devices), at 3 V they only go up to 100 MHz. But the interface is DDR, so you get two transfers per clock. One thing that suck abouts them (aside from smallish capacity of only 8 Mbytes per die) is the latency is rather high, especially for dual-die ones (S70 series), so you will need to make sure your application takes advantage of their long burst ability in order to amortize initial latency. I actually have a simple FPGA devboard with a couple of these memory chips in parallel (this was my very first Xilinx FPGA devboard BTW!), and I found that single-die devices can work with singular latency most of the time, which is good if your access pattern is more random and you don't want to completely pipeline memory access for double-latency. Cool thing about using static double-latency though is that it allows to easily place multiple memory devices in parallel and get double (or more) bandwidth this way.
W9725G6KB-25
Again, the question here is of tradeoff between simplicity, capacity and bandwidth. If you need capacity and bandwidth, you need to use DDR3(L) memory because they provide highest capacity and bandwidth for price (MT41J128M16JT-125 is about 4.5$ and has capacity of 256 MBytes with 16bit data bus running up to 800 MHz!).
If he only needs like 1 Mbytes or less, I'd use regular SRAM as it's the simplest solution in terms of controller implementation, as well as it provides the smallest latency possible, so it's the best for truly random access.
As a middle ground, I would recommend looking at SDRAM or LPDDR1 modules - they provide between 16 and 256 MBytes of capacity, while still having rather small access latency. Also - Micron provides free simulation models for all of it's memory modules (from SDRAM all the way to DDR4), so designing controller is much easier because you can actually run full end-to-end simulations to check that controller works like it should. And these models are provides in full source code, so you can figure out some finer points in modules functionality in case datasheet is unclear on something.
Post by: nockieboy on June 26, 2020, 09:06:55 am
Good find.  :-+  That makes me more confident in giving it a try - if I do mess up for whatever reason, it isn't a complete lost cause and I could recover the BGA to try again. Nice.  :)
I seem to recall us talking about the Lattice recently and discovering there could be licensing issues?  $99 a year for the IDE is beyond my meagre hobby budget.  If we're going the route of external RAM though, the internal RAM (or lack of) won't be an issue.
W9725G6KB-25
Okay, well moving to BGA does mean I can add some external memory which is a big bonus (even if it's just SDRAM) - I'm assuming then that all the video RAM could be moved out to the external memory and there'd no longer be an issue with the limited size of RAM inside the FPGA?  Didn't you mention there'd be speed issues / complexity in the interface previously?
Remember that I don't need masses of RAM.  I'd be perfectly happy with 512 KB to fill the hole in the system memory that the FPGA creates, but I understand that with extra MBs I could get higher screen resolutions?  There's also the potential to build the MMU into the FPGA and remove the need for a memory card in my system altogether - all the system RAM could be hosted on the FPGA card.
The other proviso with all this is that I haven't a clue what I'm doing.  I've gotten this far on the goodwill of this forum and masses of support from BrianHG, but this next step to BGA and using external SDRAM/DDR/whatever seems like a pretty big step for me (though I'm sure it's dead easy for you guys experienced with this stuff) and I'd need guidance and instruction to get it right (esp. with the HDL).  I don't want to make a nuisance of myself.
Post by: NorthGuy on June 26, 2020, 02:30:44 pm
DRAM consists of two-dimensional arrays of very small capacitors. The capacitors are feeble, and need lots of special care.
Reading is done one row at a time. The row is read from the matrix into a buffer. The capacitors are so small that the read destroys the charges and memory is lost. Therefore, it is necessary to write the buffer back, even if its content doesn't change. The reading process is called "Activation". Write back is called "Precharge".
Now imagine you want to read something, but a different row is activated. This row now has to be precharged, new row activated and then your read performed. This produces substantial latency. So, truly random access is not very fast.
Worse yet, the capacitors lose charge over time. The content of a capacitor survives only tens of ms. Therefore, you must activate every row and discharge it every so often, or you'll lose the memory. This is called "Refresh". The memory chip may keep track of refreshes and maintain the counter which row must be refreshed next, so you only need to sent it a refresh commands every so often and it will refresh a rows at a time. The chip automatically cycles through all the rows making sure all are refreshed. With others, you may need to supply the address of the row being refreshed. If you suddenly decide to read something during refresh, your latency suffers - you now need to want until the end of refresh, then activate your row, then read. If you activate each and every row regularly (as may be the case with video buffer), you do not need refreshes.
The memory consists of one or more banks, each with its own memory array and IO buffer, all connected in parallel. You need to select which bank you read/write, but the operations which do not need IO (such as activations, precharges, and refreshes) can be done by every bank independently. Your controller must take care of every bank. All this requires certain complexity in the controller. Your choice is to either use a stock controller or write your own which is designed specifically for video buffer.
Or, you can take SRAM, which doesn't require any of that and has fixed latency (around 10 ns). The problem is it's many times more expensive than DRAM.
Post by: BrianHG on June 26, 2020, 04:33:58 pm
8 or 16 bit SDRAM and DDR1/2/3 Ram will be too slow for the MAGGIE system other than having 1-2 dumber linear MAGGIE background graphics layers.  All tile/font/sprite images will need to be stored in the FPGA + you will need an extra 1-2kb FPGA cache to stream the DRAM video.
To replace the core and storing everything in DRAM, you would need 1GHz 32bit DDR3 controller which is beyond the CycloneIV.  You would also have to use all of the core ram to create a smart read ahead cache since DDR ram reads bytes in bursts where you need only single bytes from.  The development cycle to accomplish this is beyond our time and scope.
Hence, with the DDR ram, you will only get 2 raster MAGGIE layers which may pass raster video through, or each feed 1 of the 15 core MAGGIE layers to address tiles/fonts/sprites stored in the core ram.  The other 50% access time of the DDR ram will be for the Z80 and pixel drawing engine.
Now, I say 16 megabytes since the address pointer in the MAGGIE is currently 24 bits, ie 16 megabyte pointer.  I do not know about the Z80 paging capabilities, but, if you are limited to 512kb, including graphics memory, there are other smaller 512kb static rams which are still 2-4$, but have much faster row access times which may have less of a driver interface issue and a smaller ras/cas penalties and no sequential burst requirements.
Post by: asmi on June 26, 2020, 04:54:34 pm
You've got to be kidding! 16 bit DDR3 even running at 400 MHz gives you enough bandwidth to stream and double-buffer (meaning you read and write in parallel) a 1080p/32bpp/60Hz video stream in real time with some bandwidth to spare! And this video card has a resolution of what? 640x480/8bpp/60Hz? You should be able to push at least 50 these streams in parallel with no problems whatsoever!
But if you for some bizzare reason need more, what stops you from implementing wider bus, up to 64bit SODIMM?
Something doesn't sound right here.
Post by: BrianHG on June 26, 2020, 06:05:16 pm
You've got to be kidding! 16 bit DDR3 running at 400 MHz gives you enough bandwidth to stream and double-buffer (meaning you read and write in parallel) a 1080p/32bpp/60Hz video stream in real time with some bandwidth to spare! And this video card has a resolution of what? 640x480/8bpp/60Hz? You should be able to push at least 50 these streams in parallel with no problems whatsoever!
Your figures are correct for 'bandwidth to stream' IE sequential burst-efficient access, 2 pictures simultaneously...
   You haven't followed the project, the MAGGIE system has 16 translucent video window layers (16 pictures), 16 bits each, at 25 million pixels a second.  HOWEVER, each MAGGIE layer can tell the next adjacent MAGGIE layer to address individual 16 bit pixels from anywhere else in ram on a pixel/pixel basis, no sequential multiple pixel reads, hence the realtime pixel zooming and skipping feature.
   All this means is that exactly like a said, running a single 125MHz or 250MHz DDR2/3 ram chip at 16 bits.  Since you cannot address single bytes/words and have those redirect to a point elsewhere in ram without waiting for a ras/cas/4-8 clk burst/terminate cycle, all being said and done, an over 35ns turnaround for each random byte access, you cannot achieve the 25MHz pixel speed * 15 pixels which sit on-top of each pixel, each which may randomly point to anywhere else in ram for an associated font/tile which can be also 16bits/pixel or pointer to another font/tile.
   However, just having 2 sequential 16bit/pixel raster layers with a small pixel cache is doable with a simple ram controller, + having another graphics geometry engine random read/write access port plus another port with 0 (ZERO) wait state at Z80 speed weaved in will be feasible with some simple HDL code.
Squeezing out the Drams approximate full 750MB/sec is doable with 16 random access ports, only half of them somewhat sequential can be done, all read ahead in time to generate each 16 layer finished pixel, however I want nockieboy to be able to finish the project.
Now, if 512kb is a limit on the Z80, maybe nockieboy should consider ZBT-SRAM.  It has access exactly like a static ram chip, but when swapping from reading to writing and back, the ram chip will have 0 wait states, or Zero Bus Turnaround.  A 250Mhz ZBT sram, 256K x 18bit (512 kilobytes).  The ram controller HDL code is non-existent other than a latch and IO pins set to the tightest timing tolerances.  Now the memory density is less, but it will perform almost identical to a core signle-port ram operating at 250MHz and 0 coding experience is needed.
For some reason, the 256kx18bit 200MHz is a cheap sweet spot for ZBT ram at 2$ each (maybe obsolete).
ZBT 250Mhz = $8.40.
Sync SRAM 250MHz = $5.53.  I need to read more on this as the interface is a little more complex as the first read/write can take 2 cycles.
I would say if the Z80 can access more than 2 megabytes, go for a single 16bit ddr ram chip.  If it can only access 512kb, a more expensive but more HDL friendly solution would be the ZBT ram.
Post by: NorthGuy on June 26, 2020, 07:54:13 pm
Aren't all asynchronous SRAM chips like that?
Post by: nockieboy on June 26, 2020, 08:12:26 pm
My Z80 system can address 4 MB of memory (in 16 KB banks) with the current MMU I have.  As luck would have it, that equates to 8 sockets on two memory PCBs (with each taking up to a maximum 512 KB chip).  The second PCB is optional, so with one PCB you've got 2 MB.  For sheer ease of interfacing the FPGA to the Z80's memory space, it inserts its core memory into the 512 KB 'window' that the 3rd socket would otherwise occupy (the first having to be RAM and the fourth needing to be the ROM OS).  So if I have a video card on the system, the 3rd memory socket has to be empty.  Currently, in place of the 512 KB of memory that could have been a chip in the 3rd socket, instead it is the 32 KB of core RAM the FPGA makes accessible to the Z80.
[attachimg=1]
There's nothing stopping me using a 16 MB chip on the video card and allowing the FPGA to handle memory management and give the Z80 access to all of that RAM.  I've just been talking about 512 KB not as a hard limit, but merely to make up the 512 KB that could have been in the 3rd socket instead of the FPGA.  All RAM on the system is SRAM and I've got no objection to using SRAM on the FPGA instead of DRAM, considering its benefits with this design's random memory access characteristics.
Post by: NorthGuy on June 26, 2020, 09:12:41 pm
16MB SRAM would be more expensive. The cheapest I can see on DigiKey (2 x 64Mb chips) is $40. That is compared to $2 for a DRAM chip.
Post by: BrianHG on June 26, 2020, 09:35:04 pm
SRAM and Synchronous SRAM are 2 different things.  Pure SRAM, IE no clock interface, comes in a number of sizes and speeds, like 70ns, 35ns, 15ns... As the speed goes up, the price and size increases.
The Synchronous SRAM comes in 2 variants, the normal and ZBT.  These rams have a clock and cleanly latch the address and data on the rising edge, or for the data, on both clock edges for the DDR variant.  The advantage of the Synchronous types is clocks up to 250 MHz for SDR, 400MHz DDR (800MHz data), and a cheaper price or larger size.  The non ZBT variant relies on 1 additional clock cycle when switching from a read to a write as the latched 'Write Enable' control which is clocked requires that 1 additional clock for the data line drivers to switch direction.
(Now we are talking only 1 chip, 512 kilobytes, his Z80's memory window size.  If nockieboy wants more ram, he'll go with DDR Ram)
Example:
https://www.rocelec.com/part/IDTIDT71V3558S200PFG?utm_medium=buyNow&utm_source=findChips (https://www.rocelec.com/part/IDTIDT71V3558S200PFG?utm_medium=buyNow&utm_source=findChips)
200MHz sync ZBT SRAM - 71V3558S200 datasheet - https://www.idt.com/document/dst/71v3556-58ssa-data-sheet (https://www.idt.com/document/dst/71v3556-58ssa-data-sheet)
(This one operates identically to a Quartus Memory IP block, but, external as it has a fixed pipeline delay of 2.  Since writes are also on a delayed pipeline of 2, there is no turn-around time for switching between write and read on the command input as 2 clocks later, you would have the IO direction swap & write data ready to go inside the FPGA.)
https://www.arrow.com/en/products/is61nlp25618a-200tqli/integrated-silicon-solution-inc?utm_term=backorder&utm_campaign=arrow_findchips_2019&utm_currency=&utm_medium=aggregator&utm_source=findchips&utm_content=inv_listing (https://www.arrow.com/en/products/is61nlp25618a-200tqli/integrated-silicon-solution-inc?utm_term=backorder&utm_campaign=arrow_findchips_2019&utm_currency=&utm_medium=aggregator&utm_source=findchips&utm_content=inv_listing)
200MHz sync SRAM - IS61NLP25618A-200TQLI datasheet http://www.issi.com/WW/pdf/61-64LPS_VPS12832EC-12836EC-25618EC.pdf (http://www.issi.com/WW/pdf/61-64LPS_VPS12832EC-12836EC-25618EC.pdf)
(This one when sending a write, the write data is taken immediately.  But when reading, the read comes in on the next clock.  So, when switching from the previous read, then going to a write, you need to wait that additional clock for the last read to be returned to you before swapping the IO direction to make an immediate write.  ZBT type sram doesn't have this issue and is easy-peasy to interface with as yo never need to add that 1 clock delay/pause.)
Normal SRAM, well, $1.20 for 256Kx16/18, but, 10ns access time.  And there are still write penalties in the timing diagrams as some models have a 15-20ns write cycle time while still claiming 10ns access.  You would want the 10 write cycle, 10ns access version for full 100MHz support.
(This one is simple, but, too slow operating at half speed, or even less.  But, it's great for battery retention memory.)
Post by: gcewing on June 27, 2020, 12:32:00 am
That's not quite right -- "precharge" refers to charging the bit lines coming in to the sense amplifiers up to 1/2 Vcc in preparation for reading a row. Writing back is called "refresh" (and kind of happens as a side effect of reading -- this Wikipedia article explains it quite well: https://en.wikipedia.org/wiki/Dynamic_random-access_memory (https://en.wikipedia.org/wiki/Dynamic_random-access_memory)).
Post by: NorthGuy on June 27, 2020, 01:08:24 am
This makes sense. I always wondered why such a strange choice of the word.
At any rate, from the controller viewpoint, you activate the row, work with it, then when you're done you issue the precharge command, at which point your data are written back and the row is deactivated. Apparently it also precharges amplifiers. Between activate and precharge commands, you can exchange the data with the buffer - read or write. The refresh command refers to maintenance refreshes which must not happen between activate and precharge commands. These refreshes are reads followed by writes.
Post by: nockieboy on June 28, 2020, 11:30:05 am
Okay, I can work on the BGA design whilst I do other stuff - in the meantime, what to get started on next with the HDL side?  The graphics accelerator?  How is this going to work (in a mid-level overview sort of way)?
BrianHG mentioned previously a list of commands/functions that the module would perform and I have a basic checklist myself, like CIRCLE, LINE, FILL, etc and even perhaps basic sprite collision - how would this be implemented and where do I start?  :scared:
Post by: BrianHG on June 28, 2020, 03:28:31 pm
If you want to start with a geometry engine, then:
Begin with writing your code written in basic.
Try to get as many of the functions possible done with the same 2 for loops.  IE (x & y) counter.
Try to make the drawng codes always draw from left to right as your ram is 16 bit which may be as many as 16 pixels per word.
Start this far.  Make sure the final output resembles addressing screen memory from a pointer, not X&Y pointers.
Then we optimize a bit.
Then we make a verilog equivilant.
Now, because of memory constraints, even though another said no, I do recommend the 'FIFO command plotting drawing port'.  This doesn't mean you will stick with this, all it means is that lateron, you will get rid of the first command FIFO and replace it with a programmable loop sequence counter pointing into system graphics memory to fetch the commands automatically (which would probably still feed fill this FIFO anyways  ;) ).
Now when I say basic, I mean use the 'Free Basic' compiler which I used for the RS232_Debugger.  It takes less than a second to compile and opening a graphics screen is 1 line command which emulating a dumb point placement is also 1 command.  You may use a 'C' compiler for windows to create your code, but, for this type of code fiddling around, you wont have such play-ability.  Also, you might end up coding too well and create code which will be more difficult to translate to verilog.
For the 'FIFO' port, the basic emulation code should read a file which contains the stream the Z80 would be sending to generate the graphics.
As we go further, you will need to add thing like screen base memory, limit X&Y coordinates so your commands don't end up erasing out of screen memory.  You also need to store the pixel bit-plane mode drawing type so the final section knows how to fill the ram.
The final part, written in verilog, pixel writer, takes the plotted memory coordinates and edits the ram's contents.  Because of the biplane system, you will need to read-modify-write each byte coming in.  In this small sequencer, you will want a smart 1 byte cache which will read a byte if needed, and edit contents.  It will not write the byte until it receives the next pixel write since it may be the same memory address as in that cache.  If so, it will re-edit the cache.  If not, it will write the current cache and read the next pixel byte to be edited.  (Now I know we talked about single bit masking for writing bitplane data, however, this may work inside the FPGA, however, if you want external DRAM or SRAM, we can only narrow this down to 8 bits.  So might as well put in the effort and do the cache for universal compatibility.)
I think I said enough for you to begin thinking....
As for every control listed above, I would probably engineer 2 banks of controls for 2 the drawing engine since you can display multiple graphics modes simultaneously on the screen, refilling all that data with 2 different window modes going on might offer an advantage.  This doesn't mean program it that way to begin with, just make allowances when storing all the control registers to hold the 2 banks.  The other choice is 2 distinct drawing engines taking up more FPGA resources.
As for compiling graphics command data.  I do have a universal configurable compiler I created for another project which can build 16 bit opcodes functions with data to create your 'FIFO' port file, however, you would be expected to create a Z80 driven controller of your own in the future.
A lot to think about...
Sprite collision is handled inside the pixel-mixer just before the palette since part of the code already exists to discern  if a pixel is solid or not and which once is drawn on-top of one-another.  As for software rendered sprites in the Geometry engine, that will be located in the 'pixel writer which takes the plotted memory coordinates and edits the ram's contents.'  Another reason the read-modify-write pixel drawing command has additional use above simple blind writes into memory which contains 'bit' for 'bit' write enables to access individual bit-planes.
Post by: nockieboy on June 28, 2020, 05:20:22 pm
Right, leave it with me.  I'll see what I can do.
There's little chance of me coding it too well!  :-DD
Okay, so I'll write a Free Basic program with the basic draw functions and get it to read a file with a list of commands and process them accordingly.  That's absolutely more than enough for me to be getting started with!  Just got to squeeze some time in to familiarise myself with Free Basic.
Post by: BrianHG on June 28, 2020, 07:16:00 pm
Almost done making a setup freebasic and a compiler for generating a drawing.binary file.
Give me a few more hours.
Post by: BrianHG on June 28, 2020, 10:47:49 pm
Here you go: 'geo.zip'.
Contents:
Command Prompt - Just a dos shell.  Nice big fat font...
c.bat            - Compiles 'Geo.bas'
geo.bas        - GPU geometry engine simulator/tester written in 'FreeBasic'
palette.bin    - Has your GPU palette so the simulator knows the color palette when drawing
fwasm.exe    - My assembly universal compiler, PIC-ASM16/18 mnemonic compliant, used to convert the 'Drawing.asm' into a binary 'drawing.bin'
instr.txt        - Used by fwasm.exe to define the opcode and operand structure to compile the 'drawing.asm'.  You will add to this file as you add GPU geometry commands.
Drawing.asm - An assembly code written similar to PIC-ASM16/18 mnemonic with a few test plotting commands
Drawing.lst   - Generated by my fwasm.exe, contains the compiled results, opcodes, memory addresses and errors
Drawing.bin  - Contains the fwasm.exe compiler binary which can be run using the geo.exe
Drawinf.mif   - the Drawing.bin in .mif format, less the 8 byte header.
geo.exe        - The compiled executable GPU geometry engine simulator which reads and executes the compiled 'Drawing.bin' file.  It's programmed to pause for a key-press after every plot command.  Once 'Drawing.bin' is finished, you will need to press the 'ESC' key to quit the program.
I've only setup a basic few things (yes it functions!), you will need to do a lot more.
Post by: BrianHG on June 29, 2020, 02:18:26 am
     Note that if you do not like the current fixed 16bit instruction format, there is still time to go with an 8bit op-code method which compresses the unused bits and removes commands as 1 command may be used to load multiple settings and perform functions.
     It doesn't make much a difference in the end other than saving a few bytes of ram per operation while making the verilog a little more complex.  Fancy repeat commands or fancy sequencing of functions will no longer be possible.  Corrupt commands creating infinite loops or a crash of the sequencer will now also become possible.
Post by: nockieboy on June 29, 2020, 08:50:20 am
Have completed the line function.  Will finish the circle function later tonight.  :-+
Post by: nockieboy on June 29, 2020, 08:52:03 am
Think I'll stick with the 16-bit format.  Less downsides and any loss of speed manipulating 16-bit instructions on an 8-bit processor will be more than made up for by having hardware-accelerated drawing anyway.
Post by: BrianHG on June 29, 2020, 09:31:44 am
I fixed 2 sets of errors.
On lines 101 through 104, the srcmem has the wrong '#'  for the x'#' and y'#'.
Also, I wrote little and big endian in the REMarks backwards.
Now for the line algorithm.
Ok, for the screen limits, what we will do in the verilog/code is just skip the PSet/write to pixel ram if the coordinates fall outside the screen limits.  This will allow for geometry to go slightly outside the screen area, yet not be corrupted.  Yes the code will still be generating draw commands, but will ignore the pixel writes.
Now, is everything in your line algorithm 'integer' math?
Can you visualize it in verilog like almost everything else I have already written.
I believe this is another line generator written using ints only as reference.  It's basically the same thing written in C: https://www.eevblog.com/forum/microcontrollers/any-simple-blitter-around-(looking-for-fpga-design)/msg1803284/#msg1803284 (https://www.eevblog.com/forum/microcontrollers/any-simple-blitter-around-(looking-for-fpga-design)/msg1803284/#msg1803284)
Except is it as minimal as it gets and uses fixed point 16.16 mathematics.  Well, I guess we can get away with 12.12 in verilog with the 125Mhz fmax.
After the circle, we will build this module in verilog where the input is a 16 bit data input port with enable & CTS output.  And a 12bit x, 12 bit y, 8 bit color, write pixel enable output & we will simulate it in Quartus.
The actual write pixel will be a second verilog module which will compute the memory address from the coordinates, then do a read / modify / write from GPU ram.  It will have a similar CTS (clear to send) output and an inputs to receive the first geometry unit's coordinates.
Between all these modules, we will tie them together with FIFO, using the full and empty and shift inputs flags for the CTS and data ready inputs to cache and sequence everything, though, except for large flood fills, I doubt the Z80 will ever fill out more than 2 or 3 commands before the geometry unit has finished.
Later, we will improve the pixel memory writer to have a pixel copy function.
Post by: nockieboy on June 29, 2020, 11:14:44 am
Now for the line algorithm...
Errr... no?  :o
I believe this is another line generator written using ints only as reference... Except is it as minimal as it gets and uses fixed point 16.16 mathematics.  Well, I guess we can get away with 12.12 in verilog with the 125Mhz fmax.
Attached is the updated Geo.bas, with a new line function based on the linked code.
Post by: BrianHG on June 29, 2020, 11:30:43 am
Now, that line generator code can easily be written in verilog.
When doing the circle, it will look pretty similar.
We will skip a filled circle and a filled triangle in place of starting the first part of the verilog simulation.
  I want to modify the filled triangle to a 4 sided filled polygon.  Where the triangle will be a 4 sided polygon with 2 sets of coordinates being identical. The idea is to make 1 function perform 2 shapes.  Then, perhaps make that function plot only the outer edges performing the un-filled variants of the shapes.  All that changes is when you call the different shapes, it will just pass the appropriate x'#' and y'#' into the polygon engine with a fill on or off.
Post by: BrianHG on June 29, 2020, 11:51:14 am
Oh, and a circle, filled or unfilled is just the 4 sided polygon with the 4 points generating a bezier curve.
With that 4 sided polygon, you can now make rotated rectangles, triangles & ovals, filled and unfilled completing a very functional geometry engine.
There are some old Amiga 100% polygon rendered game which you would now be able to run at 640x480 60fps on a Z80 where as the Amiga could only do 15fps at 320x200.
It would have been nice to play this buttery smooth and sharp at the time:
https://www.youtube.com/watch?v=wjMf_bEfqIc (https://www.youtube.com/watch?v=wjMf_bEfqIc)
Maybe we should re-thing the 12 bit coordinates and go for 24 bit with a scaling and rotating transformation multipliers for the geometry engine, with Z coordinates and you will have a simple 3D rendering engine.
Post by: BrianHG on June 29, 2020, 01:03:45 pm
Licensing?
https://www.latticesemi.com/en/Products/DesignSoftwareAndIP/FPGAandLDS/LatticeDiamond#_FD13D8A25CBB47BD83F143E5B55DBC75 (https://www.latticesemi.com/en/Products/DesignSoftwareAndIP/FPGAandLDS/LatticeDiamond#_FD13D8A25CBB47BD83F143E5B55DBC75)
Under the 'ECP5U', it has a tick 'Free License'.  It's the 'ECP5UM & ECP5UM5G' which require the license, however, I don't think you are placing a 50$ FPGA on your Z80 GPU.
Everything else you have written on your own.
Too bad, but a cheap eval board would really help.
Maybe I might take a look at their Lattice Diamond FPGA design software.
You still need to choose what type of memory you might want for your GPU.
Note that the FPGA internal ram is required for the tile/font texture memory.  The external extended memory, DDR or Hyperbus RAM can only be used for background raster graphics display ram or tile layout ram unless you use the ZBT sram.  With ZBT SRAM, the external memory can do everything like the internal FPGA ram, except, it will only have access to 3 MAGGIES if you run it at 125MHz, 4 MAGGIES if you run it at 150MHZ, 6 MAGGIES at the max 200MHz.  This does not take away from the internal possible 15 MAGGIES, it would be added to them.  Subtract 1 MAGGIE if you want the pixel copy/blitter command to run at 2x speed.  You only need this if you want to display something like 100 large software sprites onscreen 30 frames per second.
Post by: nockieboy on June 29, 2020, 01:37:19 pm
Aargh. Having trouble with the Free Basic syntax now.  I've got (what I think is) the circle function in there, but I can't test it as I can't seem to successfully add a 'radius' parameter to the func_plot function.  Just getting loads of errors.  Attached current code at bottom. :(
From the circle function?  :o
 ;D ;D ;D
Post by: BrianHG on June 29, 2020, 02:21:08 pm
Ok, I've updated the circle with the right command structure.
You were supposed to use the x0,y0 for the center, and the x1,y1 would be the x&y radius.
Now, I know that having 8 plotted points  is optimum since calculating the arc is considered processing intensive, but, inside the FPGA, with your architecture, the actual pixel writing is at the same speed or slower than the mathematics.
What I was thinking was running 4 curved line generators in a row, which each created an arc.  The top left, top right, bottom left, bottom right of the circle.  The reason behind this is when we will create a filled circle, the center of the circle is a right angle triangle filled to the edge of that generated line.
The reason behind this is if we move the left and right coordinates off the center axis and move the top and bottom coordinates off the Y axis, we can generate that oval with any rotation.
Start with drawing only the top left quadrant arc of the circle, using X0&Y0 as the circle's center, but use the X1&Y1 to stretch out the arc being generated.
The update I've attached just corrects your code, corrects the drawing.asm and instr.txt.
Post by: asmi on June 29, 2020, 02:21:13 pm
So it's a full 16x16 BGA matrix with 0.8 mm pitch... 0.8 mm pitch does not leave enough space to fit two traces between pads, so you can only breakout 2 rows on a top layer, 2 more on a next layer (as there are no vias), and only 1 on subsequent (because they will need to go between vias). I've assembled a full pinout matrix diagram for caBGA-256 (as it seems Lattice couldn't be bothered to), and it is 5 IO rows deep. That means you can't fully break it out on 2 signal layers (4 layer board) - you will need 3 signal layers and so 6 layer board.
You can try using a fab that offers 75 um traces - this way you will be able to fit 2 traces between pads on a top layer and so breakout 3 full rows. If that fab can also do 0.4 mm pad vias (or smaller), this will allow breaking out another 3 rows on a next layer, and 2 rows on any subsequent layers. All of that will dramatically reduce the total amount of layers, making 4 layer board absolutely feasible.
Or you can pick a different part that is available in 1 mm pitch BGA, this will mean even 0.1 mm traces will be more than enough to fully breakout a matrix on 4 layers.
Post by: BrianHG on June 29, 2020, 02:27:41 pm
With a 2 layer board, and 1 trace between 2 pads, he would have access to at least 90 IOs with no VIAs.
The via drill would still need to be small enough to do the VCC and GND.
For a few additional signals above the 90, only a few though, I would reserve them for slow signals where you could afford to snake them around the power which would all need to come in from 1 side or 2 sides of the FPGA.
He could get away with another 20 IOs viaed from top to bottom layer still leaving room for VCC/GND.
A 4 layer board would give him a lot of freedom.
The nice thing about the ZBT ram is that it runs at 3.3v removing an IO supply voltage required by HyperBus ram or DDR2 ram.
Post by: nockieboy on June 29, 2020, 02:46:14 pm
ZBT RAM is looking more and more appealing, and I don't think the cost will be a barrier either with the amounts I'd be using.
Post by: asmi on June 29, 2020, 02:46:51 pm
Wasn't the whole point of going to BGA is to use (a lot) more IO pins? Using only 90 is such ridiculous waste.
I don't quite see "a lot of freedom". You still can't have a full breakout, unless you go for 75 um traces, or pick a different part in 1 mm pitch package. 4 layer board still only gives you 2 signal layers, same as 2 layer board.
That mostly doesn't matter, because Vccio pins are mostly adjacent to the IO bank they serve, so you can easily place a planelet on a power layer. You will need to sacrifice a few hi-speed pins (use them only for slow signals as they won't have a reference plane directly below/above them) in order to bring in Vccint and Vccaux rails to the middle of the matrix though.
Post by: nockieboy on June 29, 2020, 03:17:26 pm
So instead of drawing all 8 octants, you only want 2 to be drawn for the top-left quadrant of the 'circle'?  Won't this just require removing 6 of the 8 draw_pixel calls in the displayBresenhmCircle() function, or is there more to this?
Post by: BrianHG on June 29, 2020, 03:22:03 pm
Originally, it was the 15$ price each for a core with 2 megabits ram.
He currently has 90 IO on his Cyclone IV.  He would want at least another 44 IOs for 1 or 2 ZBT SRAMs, a few less for DDR2 operating at a lower IO voltage, or, 13 IOs for the Hyperbus Ram, with that IO bank operating at a lower voltage.
He would want 6 IOs to drive a CD Quality stereo audio DAC.
He would want another 4 IOs to improve his SD card interface to support parallel 4 bit mode.
Another 12 IOs to directly drive a HDMI port.  (Though, it can be a replacement for the current Video DAC.)
Post by: nockieboy on June 29, 2020, 03:27:42 pm
geo.zip attached with top-left quadrant arc drawing.  I've commented-out the circle function call and diverted it to the arc function, so it'll work with the existing drawing.bin.
Post by: nockieboy on June 29, 2020, 03:31:15 pm
Originally, it was the 15$ price each for a core with 4 megabits ram.
Yes, this is accurate, plus another 10 IOs max to fill out the buffer (level converter) direction controls for the command and address buses as well, so that I have the option of being able to run the whole show from the FPGA with a soft-core CPU if I (or anyone else) wanted to go that route.
Post by: BrianHG on June 29, 2020, 03:46:09 pm
Ok, I think what I asked for was wrong.  What I'm looking for is Bresenham's Ellipse.  Remember, we don't want to make 2 codes in the FPGA for circles and ellipses.  When you call a circle, the Verilog will just copy and use the X1 coordinate as the X&Y radius while calling the ellipse.  When you want an ellipse, the same ellipse will be called using the separate X&Y figures stored in X1&Y1.  However, this will not allow you to rotate the ellipse.  The calculation speed in the FPGA for the ellipse will be just as fast as the optimized circle algorithm.
After this, we have the filled ellipse.
The triangle which calls 3 lines.
Filled triangle which calls 3 lines, while plotting a line from 1 coordinate of the rendering line.
I'm not sure what else you would like, but next we go to the Geometry_xy_plotter.sv and simulate.
Then will come Geometry_pixel_writer.sv and simulate on it's own.
The merge the 2 together and simulate.
Post by: nockieboy on June 29, 2020, 04:18:33 pm
Ah, my bad - thought it was too easy.  ::)
What else do I need?  Plot, line, circle/arc and polygon (and their filled variants) are all I can think of, unless you have other suggestions?
Post by: NorthGuy on June 29, 2020, 04:28:50 pm
May I suggest. You can create just a simple drawer which draws an arbitrary curve given three points. Such curves can then be used to draw any sort of lines - straight, circles, ellipses, true-type fonts etc. Then you can organize everything into a pipeline:
drawing commands (circle, line etc.) ---> FIFO ---> parser which dissects shapes into simple curves ---> FIFO --> curve drawer ->
This way you need only a single drawing algorithm and save some logic. Later you can add other drawers, such as area fillers or blitters in parallel with the curve drawer, each with its own FIFO queue from the parser.
Post by: nockieboy on June 29, 2020, 04:48:04 pm
Hmm.. I have to call it on this ellipse business.   :palm:
Should be easy in theory - I should be able to tweak the circle function to do it, but I'm having trouble finding anything reliable on ellipses that I can translate to Free Basic, and the function I've got isn't working because... well, I can't get it to work.  :-//
Post by: BrianHG on June 29, 2020, 04:52:38 pm
Yes, this is what I am looking for, as a circle just has those 3 points set to the canter coordinates, +/- the radius as a perfect circle.  With a curved line algorithm, with the 4 source coordinates being use as 4 center quadrant points on a circle, you can draw the ellipse rotated to any angle.
I believe think it is called a 'Rational Bézier curve'.
For simple circle & ellipse, the all integer 'Bresenham's Ellipse' algorithm is fine.
It also comes in the filled variant as well, though the filled variant is nothing more than a horizontal for X loop to draw from left half to right half of the circle.
Post by: asmi on June 29, 2020, 04:55:49 pm
Looks like whoever designed their pinouts was on something serious. Check out the pinout diagram of their 381 pin package in attachment. To me that matrix looks easier to break out than 256 ball one. Even Lattice themselves showing an example pinout of that package with only 4 layers, 4 mil traces and 7 mil drills (that might be a problem).
Post by: BrianHG on June 29, 2020, 06:19:30 pm
Ok, hang on.  Look here for notes on drawing an ellipse inside a rectangle: http://members.chello.at/easyfilter/bresenham.html (http://members.chello.at/easyfilter/bresenham.html)
Too bad that algorithm uses floats.  But, it is easy to modify if you want to fill the ellipse by adding a for x loop when drawing between the left and right side.
I need to look a little more tonight when I wake up.
For now, star a new dummy Quartus project to simulate the Geometry_xy_plotter.sv.
You will need inputs:
clk        // system clock
reset      // force reset
cmd_ready  // load the 16 bit data command
cmd_data[15:0] // data bus
draw_busy      // when high, the pixel writer is busy, so the geometry plotter will pause before sending any new pixels
You will need outputs:
load_cmd       //  output high when ready to receive the next cmd_data[15:0] input
draw_cmd_rdy   //  Pulsed high when the data on the draw_cmd[35:0] is ready to send to the pixel writer module.
draw_cmd[35:0] //  bits [35:32] hold an aux function number 0 through 15.
               //  When AUX=0,  do nothing
               //  When AUX=1,  write pixel,                             bits 31:24 hold the color bits 23:12 hold the Y coordinates, 11:0 hold the X coordinates
               //  When AUX=2,  write pixel with color 0 mask,           bits 31:24 hold the color bits 23:12 hold the Y coordinates, 11:0 hold the X coordinates
               //  When AUX=3,  write from read pixel,                   bits 31:24 ignored        bits 23:12 hold the Y coordinates, 11:0 hold the X coordinates
               //  When AUX=4,  write from read pixel with color 0 mask, bits 31:24 ignored        bits 23:12 hold the Y coordinates, 11:0 hold the X coordinates
               //  When AUX=6,  read source pixel,                       bits 31:24 ignored,       bits 23:12 hold the Y coordinates, 11:0 hold the X coordinates
               //  When AUX=7,  Set Truecolor pixel color                bits 31:24 8 bit alpha blend mixe value, bits 23:0  hold RGB 24 bit color.
               //                                                        Use function Aux3/4 to draw this color, only works if the destination is set to 16 bit true-color mode
               //  When AUX=14, set destination mem address,  bits 31:24 hold the bitplane mode and bits 23:0 hold the destination base memory addres for write pixel.
               //  When AUX=15, set source mem address,       bits 31:24 hold the bitplane mode and bits 23:0 hold the source base memory address for read source pixel.
When copying, yes, having a different bitplane mode for source and destination will work as the pixel writer will have basic conversion logic.
Can you think of anything else?
Post by: BrianHG on June 29, 2020, 06:43:05 pm
:scared:  WTF????????????!?!?!!?!?!!?!?!?!?!?!?!!?!?!?
That's some scary shit.
Post by: asmi on June 29, 2020, 07:27:33 pm
I think I figured it out. That big-ass ground section at the bottom is where SERDESes would be bonded out in UM devices. So it kind of make sense. Now I'm actually curious if it's possible to fully break it out using JLCPCB's 4 layer process (3.5 mil traces, 0.2/0.4 mm drills). Their example uses 4 mil traces and 7 mil drills (no via pad size is given).
Post by: BrianHG on June 29, 2020, 11:27:47 pm
I figure you are asking what low end JLPCB/PCBWay manufacturing constraint metrics you may get away with a 0.8mm BGA.  See attached photo for what I use.  It boils down to a 7.9mil drill, 15.8mil via (better read & properly set in Metric), 4mil trace between BGA pads, 6 mil trace for PWR/GRND, 17.7mil BGA pad.
Photo has metric unit scale listed:
[attach=1]
If you are going to copy, use the Metric figures as they are exact.  If I remember, JLPCB considers the vias as 8mil drill just squeezing into their lower tier PCB fab.  Also, that IC has Deep Color HDMI inputs an I had no problem with it's LVDS.  Still inspect PCBs before assembly.  When receiving 12 PCBs from an order of 10pcbs, 2 pcbs has slight drill alignment error.  They were still functional, but, the other 10 had dead center drilling.
To begin placement, I place the BGA on a 0.4mm metric grid (well, I work with 0.1mm electrical grid), then paint a complete grid of VIAs offset at 45 degree by 0.4x0.4mm.  Add a grid copy of top layer tracks at 45 degrees to all VIAs pointing outward from the center of the IC.  Then work my way backwards by erasing vias & tracks which are not needed.  I also group resize the top PWR&GND tracks from 4mil to 6 mil.  Then finish fanning out the top layer, then going to the bottom layer.
For power decoupling caps, I use 0402s (imperial) compact footprint on the bottom layer with 0.45mm (17.7mil) tracks across the PWR vias.  The 0402 allows for 1 4mil data trace in-between the pads.
Here is the bottom layer.  It's a little messed up as this IC has 6 separate power supplies voltages (PVDD, CVDD, TVDD, AVDD, DVDD, DVDDIO & GND), but this was a 6 layer PCB.
[attach=2]
The FPGA should be much neater with fewer caps and only 2 or 3 supply volatages.
Those caps will most likely sit in a square in under the inner most row of IOs.
Title: Re: FPGA VGA Controller for 8-bit computer
Post by: BrianHG on June 29, 2020, 11:46:56 pm
Oooops, forgot the clearance rules, see below:
[attach=1]
Basically, 4mil between tracks, 10mil for power plane and polygon fills.
Once again, use the Metric figures in my attached photo.
With a 4 layer board, and the LEF5U45 caBGA-256, you wont be able to route around 30 IOs of the available 197 resulting in 167 available routed IOs.  With a 6 layer PCB, you will have access to every IO.
You might reclaim some of those final difficult to route 30 IOs with a few short traces on the GND polygon layer, but they will go through additional vias, so use them for signals in the 25MHz and below range.  I would usually place the bprom configuration & reset signals here.
Post by: asmi on June 30, 2020, 01:19:10 am
With a 4 layer board, and the LEF5U45/85 caBGA-256, you wont be able to route around 30 IOs of the available 197 resulting in 167 available routed IOs.  With a 6 layer PCB, you will have access to every IO.
No, I'm more interested in caBGA-381 as it seems to me that it's possible to fully break it out on 4 layer board.
The fab I usually use can do 3/3 mil (75um) tracks and 0.15/0.3 mm vias (and the quality of their boards is a whole new level compared to the likes of JLCPCB who tries to cut every corner in the process to shave off another cent off production cost, even if quality suffers), so for me 2 tracks between pads/vias is not a problem, but I'm genuinely intrigued by their higher pin count packages (caBGA-554 and 756) because they are not full matrices and seems to be designed for low layer count boards, while providing a ton of IO pins. If I am to take Lattice word on it, they promise full breakout of 756 ball package (365 user IO!) on just 2 signal layers! I can't think of any other FPGA which would allow such a feat. Too bad the fabric in those devices is about two times slower than in 7 series, otherwise it would be one hell of a device!
Post by: BrianHG on June 30, 2020, 02:08:52 am
The fab I usually use can do 3/3 mil (75um) tracks and 0.15/0.3 mm vias (and the quality of their boards is a whole new level compared to the likes of JLCPCB who tries to cut every corner in the process to shave off another cent off production cost, even if quality suffers).
Now, for this project, nockieboy wants the cheapest functional PCB which will be quickest time to anyone as it is an open-source project where online users will most likely default their orders to JLPCB/PCBway.  Make no mistake, for some of my mass production designs, we have below 2 mil trace with lazer drill vias and 22GB/s LVDS.  I do not use JLPCB for this work.  My recommendations offer a sweet spot for these cheap fab houses while still trying to route as many of the BGA IOs as possible with 4 layers.
Yes, with a finer FAB, you can push this to a 2 layer board, but you wont really save on FAB cost until you mass produce PCBs.
Post by: asmi on June 30, 2020, 02:40:43 am
The fab I use is not that much more expensive than JLCPCB. So I'm not talking about some kind of high-end fab, just the one which cares about quality. And I (and my clients) certainly appreciate that and are prepared to pay a bit of premium.
2 layer board is going to be garbage because of signal integrity no matter what.
Post by: BrianHG on June 30, 2020, 02:55:09 am
LOL, a 4 megabyte (36 megabit) ZBT ram for 15$.  Too bad you need to purchase 800 of them.
https://www.verical.com/pd/integrated-silicon-solution-sram-IS61NVF102436B-6-5TQL-TR-1194781?utm_campaign=verical_findchips_2019&utm_currency=&utm_medium=aggregator&utm_source=findchips&utm_content=inv_listing (https://www.verical.com/pd/integrated-silicon-solution-sram-IS61NVF102436B-6-5TQL-TR-1194781?utm_campaign=verical_findchips_2019&utm_currency=&utm_medium=aggregator&utm_source=findchips&utm_content=inv_listing)
That would be every ounce of the Z80's accessible 4 megabytes all directly addressable picture, program and blitter sprite memory, though with 133Mhz speed, you are talking 3 MAGGIES which can access 4 megabytes, 4 MAGGIES with a little more effort and Z80 & Geometry engine with a potential 75MHz Z80 0 wait-state access.  And you would still have access to the 15 other MAGGIES channels as well which would have around 192kb for their address range.  The 3-4 ZBT MAGGIES can still drive the 15 FPGA MAGGIES and vice-versa.  You would have a hell of a lot of room for audio now as well.  Well worth placing in the FPGA an accelerated multichannel MP3 decoder/encoder on top of the FM synthesizer for the audio so you can playback mix in compressed high quality sound effects for games.
Here is a 2 megabytes ZBT, 16$ for 1, however, this one supports 200MHz: (7 MAGGIES)
https://www.mouser.com/ProductDetail/ISSI/IS61NLP51236B-200TQLI?utm_term=IS61NLP51236&qs=rnuWwpjhhVu7EtaUBW4FOg%3D%3D&utm_campaign=IS61NLP51236B-200TQLI&utm_medium=aggregator&utm_source=findchips&utm_content=ISSI (https://www.mouser.com/ProductDetail/ISSI/IS61NLP51236B-200TQLI?utm_term=IS61NLP51236&qs=rnuWwpjhhVu7EtaUBW4FOg%3D%3D&utm_campaign=IS61NLP51236B-200TQLI&utm_medium=aggregator&utm_source=findchips&utm_content=ISSI)
These guys require 32 bits for the data bus, not 16.  But, they are more available than the 18bit versions.
2 Megabyte, 18 bit version, fewer available: (7 MAGGIES, you can always place 2 of them for 4 megabytes)
https://www.mouser.com/ProductDetail/ISSI/IS61NLP102418B-200TQLI?utm_term=IS61NLP102418&qs=UxK%2FDTs6dB6rHPCxdOLQcw%3D%3D&utm_campaign=IS61NLP102418B-200TQLI&utm_medium=aggregator&utm_source=findchips&utm_content=ISSI (https://www.mouser.com/ProductDetail/ISSI/IS61NLP102418B-200TQLI?utm_term=IS61NLP102418&qs=UxK%2FDTs6dB6rHPCxdOLQcw%3D%3D&utm_campaign=IS61NLP102418B-200TQLI&utm_medium=aggregator&utm_source=findchips&utm_content=ISSI)
In quantity, the 2 megabyte versions go below 10$.
Even Micron makes the 2 megabyte ZBT Srams (36 bit version):
https://www.rocelec.com/part/CYPMCNMT55L512Y32PT-6?utm_medium=buyNow&utm_source=findChips (https://www.rocelec.com/part/CYPMCNMT55L512Y32PT-6?utm_medium=buyNow&utm_source=findChips)
18 bit version:
https://www.rocelec.com/part/CYPMCNMT55L1MY18PT-6?utm_medium=buyNow&utm_source=findChips (https://www.rocelec.com/part/CYPMCNMT55L1MY18PT-6?utm_medium=buyNow&utm_source=findChips)
Post by: asmi on June 30, 2020, 03:23:04 am
I think you guys will need to modify your video core to work with longer latency memory. Modern videocards use GDDR6 memory which have hundreds of cycles-long latency, and that doesn't stop video cores to saturate these interfaces despite insane bandwidth(which nowadays is measured in 100's of gigabytes per second) afforded by these interfaces. One thing to think about - video card resources don't have to be stored in video memory as flat contiguous chunks of memory, but can have any structure which facilitates algorithms utilized by the core.
Post by: BrianHG on June 30, 2020, 03:43:33 am
I need to read up on GSI Technologies '18Mb Pipelined and Flow Through Synchronous NBT SRAM'.  They are more available, a bit cheaper and supposed to have a mode similar to ZBT as well as up to 333MHz speed, though, your 15$ FPGA has a 200MHz limit on the IOs in SDR, bit in DDR maybe with a proper layout, you will achieve 11-12 MAGGIES on all 2 megabytes.
36Mb Pipelined and Flow Through Synchronous NBT SRAM at 200MHz is available at under 27$ for 1 while the 18Mb versions are around 14$ for 1.
Post by: BrianHG on June 30, 2020, 04:09:19 am
     Those cards have megabytes of smart cache just for their ram controller on their GPU die.  All sprites and overlays are now software rendered and stored in separate chunks of ram.  Now if we were to redesign the GPU for all software rendering windows form multiple source ram images to a destination screen display ram, with a software configurable rendering display manager, with a full instruction set for the GPU to perform all these tasks with a software stack, yes.  With 1 beginner developer, a few years from now, we will have re-engineered a semi modern obsolete 2D video card accelerator.  A lot of tricks were designed in to give him hardware video windows or sprties (the MAGGIES) which can be configured anyway what-so-ever with multiple palette chunks assigned to each layer, each one with different bits/color and different resolutions.  And there is only a little bit of code left to add to get hardware pixel collision through each layer identifying if any 2 pixels which don't contain the transparent color 0 sit on top of each other.  It has really been designed to be something like the ultimate 8bit CPU gaming display engine where complete character animations and background scrolls can be achieved only by updating 4-8 bytes per display element & reading 2 bytes per display element/layer to determine 16 possible collisions.
nockieboy just wants to tie in something and go.  I think the 2-4$ 512kb ram chip is fine for an 8 bit 8MHz Z80 while it requires 0 verilog coding experience to get it to work.
Remember, most old Z80 type 8bit personal computers only has to worry about 320x240 at 15Khz (140ns per pixel), 1 bit color per pixel, 160x240 at 4 colors in graphics mode.  Maybe 16 colors in text mode.  This GPU does 15 parallel superimposed windows at 640x480 @ 32Khz x 16 bits per pixel, or 8 bits palette color, with 0 wait states on the Z80 access, plus now a hardware accelerated geometry engine with blitter copy on a 15$fpga.  If I wanted only 1 screen with 640x480 @ 1 bit color, or 16 color text like nockieboy's original spec, or even just a graphics 32 bit color 640x480 with a geometry engine, yes, a single dram chip would be easy with the dumbest dram controller you could think of.  But it wouldn't have some of the goodies of of the old days 8-bit microcomputer style graphics, but now with full color and hi-res output.
Post by: asmi on June 30, 2020, 06:17:41 am
These cards also render billions of triangles per second. So let's scale it back by a factor of 1000 - can you render millions of triangles per second with kilobytes of "smart" cache (whatever that is)?
That is a lot of hand-waving. Let's consider facts - now you have a fully obsolete 2D video card accelerator. So devising just "semi-obsolete" will be a big step ahead ;) And no, I don't think it will take years. And even if it will - who cares, as long as it's fun to work on? ;) I, for one, would follow such a project really closely, and would find a way to contribute, because I have great interest in the the subject of 2D/3D rendering using modern approaches, even if they are implemented on a much smaller scale than what modern video cards can do. I'm not interested in using ancient techniques though. I have some experience developing 3D engines using 3D GFX APIs, so I have some knowledge on a subject, though of course it's mostly on the software side, which is why I have keen interest in what's going on on HW side of these APIs.
I can't read his mind, but I think this thread is a proof positive that that is absolutely not his intention. The way I see it, it's a typical hobby project where process is just as important as result, so once you achieve some goal, you invent another one, move the goal post and continue going. Infact if my memory serves me most of features you listed above were not in the original list of requirements, so they were added on the go, which again, is perfectly fine for a "permanently in-progress" hobby project.
That is a classic manifestation of sunk cost fallacy. When your solution becomes inadequate to the task at hand, you don't design crutches for it, instead you re-engineer it so it becomes adequate, and if that doesn't work - you throw it away and start from the ground up. The fact that you need an expensive memory to scale your solution up from measly 640x480 is a proof that existing solution is hitting the wall, and needs to be either significantly re-engineered, or just thrown away and re-designed using a different approach which would scale better.
That ship sailed a loooooong time ago in case you hadn't noticed, as Z80 systems did not have even remotely anything like what you have now. In fact if it's anything like my hobby projects, I absolutely wouldn't be surprised if tomorrow nockieboy comes around and says "you know what - that Z80 thingy is becoming too much of a limitation, so let's get rid of it and replace it with some 32 bit CPU, like RISC-V!" :) This kind of evolution is completely normal, and there is no need to hang on to existing solutions, and long as the process is still fun for those involved. At the end of the day, hobby projects are all about fun first and foremost. I don't think using this Z80 system is nearly as much fun as designing it :D
Post by: BrianHG on June 30, 2020, 07:37:55 am
@asmi, I think you are going off the deep end here.  If you want a 2D/3D accelerated GPU, you may start a thread on the subject and I will contribute.  A decade ago I touched on the subject matter and there is a lot to do and setup just to draw 100 million triangle a second, seeing that each triangle will need to be filled, each having potentially say an average of 4000 pixels each with some intelligence like read ahead cache and omitting hidden triangles beneath others still requires a degree of planning and design.
This project started with a wish to have 640x480 with 1 bit color, or 320x240 by 16 colors.  being a beginner project for nockieboy, we played around with a sync generator, then a 1 bit font and text.  Then, with what a small FPGA could do, we created a standardized method to address a few layers of video.  If nockieboy wants to abandon this project and begin anew with a simple 32 bit, large ram page flip-able display GPU, no MAGGIE, but a GPU accelerated programable core that renders a double buffered display from a stings of stored geometry data structures all on it's own like a modern video card, he is free to do so.  (Not to mention he will need to create his own compiler to construct the geometric code running in the video card)  Remember, his current cpu upgrade wishes is to add support for a 2-4MHz 6502, not a 100Mhz 486, hence the thread title 'FPGA VGA Controller for 8-bit computer'.
Now hooking DDRam to the current design is doable and still can offer everything that comes with large memory, and the limitations are minor as the existing core still offers additional internal ram for effects layers, but, it will take some time to get it right unless I program the whole thing myself.  I am offering trade-offs solutions and options as my free time is shrinking and nockieboy will have to do all the new development on his own.
Smart cache reads ahead, does branch prediction, holds extra content which will be used after plotting a line or row, or simple write-back for writing into same memory space before sending it back to ram.  In fact, our 'pixel writer' coming after the geometry unit will have a smart cache, except it is only 2 words long for the pixel reader and 2 words long for the pixel writer.  It will speed up any horizontal drawn lines and all fills up to 8 fold.  Most of our objects are only drawing 1 byte, or even parts of a byte written one after the other and 1 word can contain up to 16 pixels.  The 2 word cache will allow these type of reads and writes to be done multiple times immediately and only offload the data to or from the ram once a new completely different word of memory is required.  With DDR2/3 or Hyperbus RAM, these 2 words would be extended to the burst size X 2, so, 16 - 32 bytes each.  Still doable with a a lot more more work.
There is obviously more to this to improve design and efficiency.  I guess this is why CPUs have a L1 cache, then a L2 cache, then a L3 cache, then system memory.
However, there is one thing I can agree upon.  If nockieboy wants the engineering headache, place 2 independently wired Hyperbus Rams for 32/64 megabytes.  It will take a lot longer to get it to function, but he will have a ton of memory space whether he makes the memory interface efficient and extra fast or basically good enough to function.
Post by: nockieboy on June 30, 2020, 10:58:30 am
I like that site, wish I'd found that earlier! :)  Have attached latest Geo.bas and compiled drawing.bin to show the working ellipse function.
Okay, test project started in Quartus II with the inputs/outputs you've specified.  Nothing really to show yet, but I've attached geometry_xy_plotter.sv for info.
I'm hoping that's not a trick question, because right now I can't think of anything else.  ???
EDIT: Just a thought, but what about a general FILL function?  Specify a point coordinate and a colour and off it goes, filling in all pixels of the colour at the point coordinate with the new colour, until bounded by other colours?  Or would that be too far?
I guess as an alternate to this, I'm thinking about a filled polygon function?  Perhaps based off of the filled square, but being able to specify all four corner positions?
I know you guys have discussed this all already whilst I've been sleeping, but (for this project at least) $27 (or even $14) for a RAM chip is a bit expensive and I'd need to be convinced of the benefits before pulling the trigger on that.
Sounds good to me. Don't forget that I already consider the design and assembly of this card to be pretty advanced for a beginner - minimising the number of (relatively) expensive components that could be difficult to solder seems like a good strategy.
To some degree you're right, asmi, but I do have a specific goal in mind and I outlined that near the start of this thread.  In more general terms, I wanted to free my little DIY computer from the host PC, breaking away from the serial console and giving it its own video output and keyboard interface so I could use it as a standalone system.  I don't recall if I ever admitted this, but my holistic aim was to be able to create a computer, from scratch, that I could plug into the living-room TV and play Pong (or my home-coded version of it) with the family.  That was my gold-standard end goal.
Now, technically I could write Pong for it at the moment and that would be that, but you're right in that it's a typical hobby project and I have become quite addicted to the process as much as the end result.  Feature creep is a very significant factor, as is learning about this world of technicalities and skills I never, ever, thought I'd wind up learning about and developing.  Originally the design for my computer was all through-hole components.  I'm now soldering TSSOPs, 0603 passives and QFP-144s without breaking a sweat and seriously planning for the move to BGA.  I'm not an electronics engineer.  I'm not a programmer.  I have no formal education in either domain.  But I do like to learn - and if I can build something fun and practical whilst I'm doing that, so long as the 'next step' isn't insurmountable, then I'll always want to push further as long as you kind folks are willing to put up with my ignorance and stupidity.  :)
Err.. a 6502 isn't an upgrade from a Z80, it's more of a downgrade.  Just sayin'. ;)  There is a chance in the future that I'll move up to the 16-bit Motorola 68010 as I have one sitting in a box somewhere, but that's still a way off.
Post by: nockieboy on June 30, 2020, 11:36:42 am
Have just added filled ellipses.  Updated Geo.bas, Drawing.asm and drawing.bin below.
Post by: BrianHG on June 30, 2020, 03:47:12 pm
Nice.  Optimize converting the longs to ints like the line drawing algorithm shouldn't be a problem.
We were missing a few controls, so I added in the geo.bas: (Full files attached below.)
if func1<8 then
REM *************************************************************
REM **** Set 24 bit screen memory registers ************
if func2=127 and func3=0   then destmem = x0*4096 + y0: Rem set 24 bit destination screen memory pointer for plotting
if func2=127 and func3=1   then destmem = x1*4096 + y1: Rem set 24 bit destination screen memory pointer for plotting
if func2=127 and func3=2   then destmem = x2*4096 + y2: Rem set 24 bit destination screen memory pointer for plotting
if func2=127 and func3=3   then destmem = x3*4096 + y3: Rem set 24 bit destination screen memory pointer for plotting
if func2=127 and func3=4   then srcmem  = x0*4096 + y0: Rem set 24 bit source screen memory pointer for blitter copy
if func2=127 and func3=5   then srcmem  = x1*4096 + y1: Rem set 24 bit source screen memory pointer for blitter copy
if func2=127 and func3=6   then srcmem  = x2*4096 + y2: Rem set 24 bit source screen memory pointer for blitter copy
if func2=127 and func3=7   then srcmem  = x3*4096 + y3: Rem set 24 bit source screen memory pointer for blitter copy
if func2=127 and func3=8   then destmem = x0*4096 + y0:srcmem  = x1*4096 + y1: Rem both source and destination pointers for blitter copy
if func2=127 and func3=9   then destmem = x1*4096 + y1:srcmem  = x0*4096 + y0: Rem both source and destination pointers for blitter copy
if func2=127 and func3=10  then destmem = x2*4096 + y2:srcmem  = x3*4096 + y3: Rem both source and destination pointers for blitter copy
if func2=127 and func3=11  then destmem = x3*4096 + y3:srcmem  = x2*4096 + y2: Rem both source and destination pointers for blitter copy
if func2=127 and func3=12  then dest_width   = x2  : Rem Sets the number of bytes per horizontal line in the destination raster
if func2=127 and func3=13  then src_width    = y2  : Rem Sets the number of bytes per horizontal line in the destination raster
if func2=127 and func3=14  then dest_width   = x3  : Rem Sets the number of bytes per horizontal line in the destination raster
if func2=127 and func3=15  then src_width    = y3  : Rem Sets the number of bytes per horizontal line in the destination raster
REM **** Set screen width and height limits ************
if func2=126 and func3=0  then max_x = x0: max_y = y0 : REM set the maximum width and height of the screen
if func2=126 and func3=1  then max_x = x1: max_y = y1 : REM set the maximum width and height of the screen
if func2=126 and func3=2  then max_x = x2: max_y = y2 : REM set the maximum width and height of the screen
if func2=126 and func3=3  then max_x = x3: max_y = y3 : REM set the maximum width and height of the screen
if func2=126 and func3=16 then draw_collision = 0     : REM Clear the pixel drawing collision counter
if func2=126 and func3=17 then blit_collision = 0     : REM Clear the blitter copy pixel collision counter
And the additions to the 'geometry_xy_plotter.sv':
module geometry_xy_plotter (
    input clk,              // System clock
    input reset,            // Force reset
    input cmd_ready,        // 16-bit data command ready signal
    input cmd_data[15:0],   // 16-bit data command bus
    input draw_busy,        // HIGH when pixel writer is busy, so geometry plotter will pause before sending any new pixels
    output load_cmd,        // HIGH when ready to receive next cmd_data[15:0] input
    output draw_cmd_rdy,    // Pulsed HIGH when data on draw_cmd[15:0] is ready to send to the pixel writer module
    output draw_cmd[35:0],  // Bits [35:32] hold AUX function number 0-15:
                            //  AUX=0  : Do nothing
                            //  AUX=1  : Write pixel,                             : 31:24 color         : 23:12 Y coordinates : 11:0 X coordinates
                            //  AUX=2  : Write pixel with color 0 mask,           : 31:24 color         : 23:12 Y coordinates : 11:0 X coordinates
                            //  AUX=3  : Write from read pixel,                   : 31:24 ignored       : 23:12 Y coordinates : 11:0 X coordinates
                            //  AUX=4  : Write from read pixel with color 0 mask, : 31:24 ignored       : 23:12 Y coordinates : 11:0 X coordinates
                            //  AUX=6  : Read source pixel,                       : 31:24 ignored       : 23:12 Y coordinates : 11:0 X coordinates
                            //  AUX=7  : Set Truecolor pixel color                : 31:24 8 bit alpha blend mix value : bits 23:0 hold RGB 24 bit color
                            //  AUX=10 ; Resets the Write Pixel collision counter
                            //  AUX=11 ; Resets the Write from read pixel collision counter
                            //  AUX=12 : Set destination raster width in bytes    : 15:0 holds destination raster image width in #bytes so the proper memory address can be calculated from the X&Y coordinates
                            //  AUX=13 : Set source raster width in bytes,        : 15:0 holds source raster image width in #bytes so the proper memory address can be calculated from the X&Y coordinates
                            //  AUX=14 : Set destination mem address,             : 31:24 bitplane mode : 23:0 hold destination base memory addres for write pixel
                            //  AUX=15 : Set source mem address,                  : 31:24 bitplane mode : 23:0 hold the source base memory address for read source pixel
    output Write_col[7:0],  // An 8 bit saturation counter which counts the number of pixel write collisions
    output Copy_col[7:0],   // An 8 bit saturation counter which counts the number of blit write from read pixel write collisions
    output idle             // an output which goes high when the geometry plotter is finished and is doing nothing
Now I think you are ready to begin coding the 'geometry_xy_plotter.sv'.
Post by: BrianHG on June 30, 2020, 04:42:28 pm
You only call the function twice in a row...
EG,
; ** Draw a filled ellipse (250,250)-(300,350) with palette color 9
set_x 0,d'175' ; set x0 register to 250 - The ellipse's top-left X position
set_y 0,d'175' ; set y0 register to 250 - The ellipse's top-left Y position
set_x 1,d'300' ; set x1 register to 300 - The ellipse's bottom-right X position
set_y 1,d'350' ; set y1 register to 350 - The ellipse's bottom-right Y position
plot_circle_fill d'9' ; plot a filled ellipse with palette color 9
        plot_circle d'15'         ; plot the outline of the same ellipse with palette color 15
Remember, my commands holding their screen coordinates were optimized to do this sort of thing.
You may make such a command in your Z80 graphics driver, but, it would just execute the above code.
The Geometry unit will draw between 25 million all the way up to 125 million pixels a second.  It wont break a sweat drawing the extra few pixels surrounding the edge of an ellipse, or rectangle a second time.
Give it a test in geo.bas.
Now, truly begin the 'geometry_xy_plotter.sv'.  Start with being able to load it's internal storage registers with the command input port.
Use the maggie.sv and rs232_DEBUGGER.v to get an idea of how to associate/assign labels from the source command & how to store those labels into the memory registers.  The labels and registers should be almost identical to the geo.bas labels.  Except for the x# & y#, make them 2 dimensional 12 bit registers for ease of design.  (I should have done that anyways within geo.bas.  Sorry, my bad.
Post by: asmi on June 30, 2020, 05:12:14 pm
I will do so at some point, but first I need to figure out what kind of hardware will I need, and design and build such HW. I do have quite a bit of boards with HDMI out, but they all need to overclock FPGA in order to get 1080p out, with that I plan to design a board with DisplayPort out so that I will be free to output just about any resolution I want or need, and it can also output sound at the same time (which might become useful at some point). I know GPU cores require crazy amounts of memory bandwidth, but the best I can do while keeping costs reasonable is 400 MHz DDR3, the question is if it's better to have a single wide interface, or several smaller ones. The latter approach allows for some cool tricks - like taking advantage of large capacity by cloning the same resource (say texture) into all memory devices, and effectively getting ability to have multi-port read access to several different memory locations at once.
If I were him, I'd go for DDR3 as it's a general purpose memory, and so learning how to work with it will be useful in other projects in the future, while HyperRAMs are pretty specialist parts and only suitable in limited scenarios. Or implement a two-tier memory architecture by connecting relatively small (but fast) SRAM chip and DDR3 at the same time, so SRAM can be used as off-chip cache for much larger DDR3 memory array.
Post by: BrianHG on June 30, 2020, 06:01:39 pm
It took me almost a 2 months full time to get DDR3/2 working perfectly for my scaler.  However, let it be known that I designed that ram controller from scratch, it has 8 asynchronous read and 8 asynchronous write ports (with adaptive priority) with read request post in advance commands and write cache on each channel and it had to be as compact and efficient as possible operating on the slowest CycloneIII with 128bits where Altera's had the DQS port limit on a CcycloneIII at 96 bits on the higher speed upper and lower IO banks.  This doe not include reading every single nuance of the FPGA data sheet and DDR2/3 datasheets to make sure I made 0 errors in wiring the devices and that I would achieve the clocking goals before the design was complete.
Now I do not see this project requiring such bandwidth or such a complex design but unless nockieboy were to use an off the shelf DDR3 controller and carefully read the LFE5U's DDR3 ram implementation guide, he will get stuck.  The DDR3 will eat up 2 IO banks on his FPGA due to operating at a lower voltage.  I would use a 1GB reduced latency DDR3 as the price is only around 1$ more than the regular one but the memory controller will have a little less latency.  Maybe 2 of them for 32 bits is allowed by the LFE5U's within 2 adjacent higher speed IO banks.  The slowest LFE5U45-6 at 15$ can run the ram at tops 312MHz, or, 624MTPS.  (Can DDR3 be run that slow?) This is not too bad that a 1080p requires a continuous stream of 150 million pixels a second with a 32 bit ram bus, or 300MHz for a 16 bit ram bus.  The LFE5U without hardware serdes will just squeeze out 720p, actually the -7 variant wouldn't have a problem as well as increase the DDR3 clk speed.  That video mode cuts the 150Mhz @ 32 bit bandwidth requirement into 75Mhz.
     If I started from day one making a GPU with the 15$ LFE5U, I would target 720P with 1 or 2 1gb DDR3s.  Run a 32 bit (ARGB) true-color display and make everything else drawn by a geometry engine every frame with optional edge anti-aliasing using the 'A' alpha channel when drawing the graphics.  The memory space with full true color would mean full accelerated anti-aliased tiles/fonts/rendering including soft edge since there is an 8 bit translucency stencil alpha channel.  But, an 8 bit CPU would never really be able to take advantage of the horse power under the hood.  However, there is also enough room for a softcore 32bit - 68K type of cpu or simple arm-risc which can be placed inside the LFE5U as well as a 64 channel full MIDI wavetable audio system with accelerated DCT for compressed audio streams.
Post by: asmi on June 30, 2020, 06:28:58 pm
Again, this depends on the goal. If the goal indeed is to make it work somehow and call it a day - then yea, do the bare minimum to get it going, and call it good. However if the goal is to learn how to work with the most "commodity" memory available with the aim to use this knowledge and experience in the future projects - then this is a great opportunity to do so.
Now I do not see this project requiring such bandwidth or such a complex design but unless nockieboy were to use an off the shelf DDR3 controller and carefully read the LFE5U's DDR3 ram implementation guide, he will get stuck.  The DDR3 will eat up 2 IO banks on his FPGA due to operating at a lower voltage.  I would use a 1GB reduced latency DDR3 as the price is only around 1$ more than the regular one but the memory controller will have a little less latency.  Maybe 2 of them for 32 bits is allowed by the LFE5U's within 2 adjacent higher speed IO banks.  The slowest LFE5U45-6 at 15$ can run the ram at tops 312MHz, or, 624MTPS.  (Can DDR3 be run that slow?) This is not too bad that a 1080p requires a continuous stream of 150 million pixels a second with a 32 bit ram bus, or 300MHz for a 16 bit ram bus.  The LFE5U without hardware serdes will just squeeze out 720p, actually the -7 variant wouldn't have a problem.  That mode cuts the 150Mhz requirement into 75Mhz.
I just checked Micron 2 Git datasheet, and the minimum frequency is set at 303 MHz, unless DLL is disabled - in this case it can be as low as 128 kHz (yes, you read it right - kilohertz!) - it mentions 7800 ns as max clock period.
If I started from day one making a GPU with the 15$ LFE5U, I would target 720P with 1 or 2 1gb DDR3s.  Run a 32 bit (ARGB) true-color display and make everything else drawn by a geometry engine every frame with optional edge anti-aliasing using the 'A' alpha channel when drawing the graphics.  The memory space and full true color wound mean full accelerated anti-aliased tiles/fonts/rendering including soft edge since there is an 8 bit translucency stencil alpha channel.  But, an 8 bit CPU would never really be able to take advantage of the horse power under the hood.  However, there is also enough room for a softcore 32bit - 68K type of cpu or simple arm-risc V which can be placed inside the LFE5U as well as a 64 channel full MIDI wavetable audio system.
This was part of the reason why I suggested implementing command lists that can be stored in video memory - this will completely decouple GPU performance from CPU, as latter can take it's merry time preparing next list while GPU works with existing one. This is how DirectX 11/12 API works. Those command lists can have external parameters, so that CPU can update things like object positions etc, without changing the actual command list. In DX parlance they are called constant buffers. CPU can update these buffers without changing command list, and then these are fed into the rendering pipeline automatically when command list references said buffer. All of that will make CPU performance almost non-factor, as pretty much all graphical stuff will be offloaded onto GPU.
Also I wonder if your existing core would be much simpler had it worked with full color objects and surfaces as opposed to packed-color ones, as I assume you will need additional HW to pack and unpack pixel information from data bytes stored in memory. While in case of full color this will be a trivial memory address calculation without any need to somehow transform data you get from memory.
Post by: NorthGuy on June 30, 2020, 07:51:30 pm
You won't have enough time to refresh everything at that speed.
Post by: asmi on June 30, 2020, 07:59:47 pm
DLL disabled mode is not designed for operational use and none of characteristics are guaranteed. Quote from Micron's datasheet:
The DRAM is not tested to check—nor does Micron warrant compliance with—normal mode timings or functionality when the DLL is disabled. An attempt has been made to have the DRAM operate in the normal mode where reasonably possible when the DLL has been disabled; however, by industry standard, a few known exceptions are defined:
• ODT is not allowed to be used.
• The output data is no longer edge-aligned to the clock.
• CL and CWL can only be six clocks.
When the DLL is disabled, timing and functionality can vary from the normal operation specifications when the DLL is enabled (see DLL Disable Mode in Commands section of the data sheet for more information). Disabling the DLL also implies the need to change the clock frequency (see Input Clock Frequency Change section of the data sheet for details).
Post by: BrianHG on June 30, 2020, 09:18:56 pm
EG,
 :palm: Sorry, my bad.  You meant a general 'Flood Fill', right?
     Ok, that would take a little feedback cooperation between the 'geometry_xy_plotter.sv' and 'pixel_writer', but I'm wondering how I could generate a cheap method where it can properly seek and fill around the corner of an onscreen object.
     A radiant style fill would be easy, but, on screen objects would be able to cast shadows which means it wouldn't be a true 'Flood Fill'.  If a shadow is cast, you would need to manually start an additional 'Flood Fill' in the void to complete the fill which may once again still contain additional voids.  If I can figure out an easy way to automatically drive the filling of the voids, you would have a really fast 'Flood Fill'.  Otherwise, the fill will need to be done in a much slower maze-seek algorithm.  (Much slower means filling something like 5 million pixels a second instead of 125 million a second.)
Post by: nockieboy on June 30, 2020, 09:31:24 pm
Yes, that's the one.  Sorry, my terminology isn't necessarily up to the task - this is all new ground for me.
Okay, well I kind of broke it into two separate things.  One was the original idea - the flood fill.  I have memories of doing these on my old Amstrad in whatever graphics programme I used to have and it would literally take tens of seconds, if not more for more complex shapes, to fill with a colour.  Having a hardware version of that would be useful - although perhaps with limited use-cases (the aforementioned graphics programme being the most obvious) - or old 'graphical adventures', where the picture for a key location would be built up in front of you as you read the descriptive text - again with some painfully slow flood fills.
The other idea that came out of it was polygons.  I think you mentioned being able to draw triangles or polygons with the ellipse function?  Being able to draw bespoke shapes with three, four or potentially more, vertices either as wireframe or filled would be VERY useful.  I know the line function can do the same thing with some additional work from the Z80, but being able to fill those shapes would be nice.
Post by: BrianHG on June 30, 2020, 09:42:01 pm
Yes, currently we have multiple different packed color modes and the pixel writer after the geometry unit has code to deal with it.  Yes, 32 bit only removes a lot of glut, but, remember DDR3 smallest burst has 8 words @ 32 bit for the optimum.  To make efficient use of the dram when reading and writing pixels, internally we would have a 8x32 = 256 bit bus which would look equivilant to a 1 bitplane image with an 8 bit memory bus.  Yes, it would be written out a little different, but it boils down to the same idea.  When reading or writing adjacent pixels, you do not want to sacrifice that minimum 4 cycle burst of the same DRAM memory address 8 times in a row with the write mask set for 1 individual byte every time.  Now you may have a DDR3 ram controller with a smart cache to manage this, but to properly weave your pixel plotting commands with reads for the screen refresh, you should organize your memory requests on the page burst boundary with the bottom CAS A0,A1,A2 all = 0.  Otherwise, there will end up having a few access penalties when as you cross a row address if the word alignment isn't on centered on the 8 byte burst.  In fact, once you have done this, everything, like geometry command arrays should all be padded and sit on an 8 word boundary.
The big difference is that we wouldn't have to worry about any other pixel formats.  And in the case of a 256 color paletted bitmap, there would be 1 function in the pixel writer to convert that bitmap to 32 bit in real time.
Post by: BrianHG on June 30, 2020, 09:53:13 pm
Triangle and filled triangle, 4 sided polygon and filled 4 sided polygon will be added as they are basic functions for a 2D accelerator.  They are basically just 2 line functions running at once and tied together.  This is why I made the source X&Y coordinates have 4 points for up to 4 vertices.
Using the 'Line' function, with multiple coordinates to construct a closed shape, then flood fill that shape is easy.  Once the shape is completed, you would once again go back through all the 'points' in the object and do a radiant style fill 1 pixel toward the inside of the object.  Otherwise, you would just generate your object using multiple filled triangles just like any other 3D geometric generated image, or filled 4 sided polygons which are actually only 2 triangles with 1 matching face.
Post by: asmi on July 01, 2020, 01:08:17 am
Well - there is quite a bit you can do. For example, you can have a FIFO with 32 bit write port and whatever your memory interface width for a read port. Or you can split single x32 interface in two x16 ones, or four x8 (though that can get a bit wasteful in terms of pins needed for ADDR/CTRL lines). Or just duplicate your processing cores and process several pixels in parallel, so that you can write them all at the same time. Or some combination of above :)
Post by: NorthGuy on July 01, 2020, 01:47:51 am
If your addressing scheme is such that the adjacent rows are in different banks, then crossing row boundaries will not pose any additional penalties.
Post by: BrianHG on July 01, 2020, 02:39:40 am
You still cannot terminate mid burst without penalty.  With so much ram, word aligning all you data structures to sit evenly on a 8 word x whatever width bits boundary in the memory just shrinks down that problem.  For example, if you need to begin to read right at the end of the row, all addresses '1's, even though the ram will do it, the 8 word burst will just wrap around for the remaining 7 cycles after you get that first word you want, and the remainder of that burst will be wasted when what you want right after that initial last word is the next row right after.  Such word, and even double word alignment for data and code to even accelerate CPU copies began way, way, way back with 68020 and up.
Post by: nockieboy on July 01, 2020, 02:32:42 pm
I'd be lying if I said I knew what I was doing, so I've thrown some code at the Quartus project and I'm hoping what stuck is vaguely going in the right direction..  ???
Have got as far as the functions (I think) - not sure how to progress.  Anyway, take a look at the attached and let me know where I've gone wrong so far.  ::)
EDIT:
Updated code as I hadn't created registers for max_x, max_y or the two collision counters.  :palm:
Post by: NorthGuy on July 01, 2020, 02:43:53 pm
You just read in whole bursts. If the start address is all ones, you don't align it so that it is the first bit in the burst. You align the bursts always the same. The content corresponding to the odd address with all '1' will be the last bit in the burst. Then you can cross row borders without problems. You can read something which spans several rows non-stop.
Post by: BrianHG on July 01, 2020, 04:01:52 pm
EDIT:
Ok, a little mistake on my part, these guys will be in the inside the memory pixel writer...  So they have to be removed.
    output idle             // An output which goes high when the geometry plotter is finished and is doing nothing
Next, your first 4 assigns need the destinations to have wires declared.
Next, this module's outputs are also wires (as well as the inputs).  (See maggie.sv for example.)
To begin with, make all your inputs and outputs on the ports 'wire'.  Look at maggie.sv to see how this is done.  You have the [x:y] on the wrong side of the names.
next make these 5 regs:
draw_cmd_func[3:0]
draw_cmd_data_color[7:0]
draw_cmd_data_word_Y[11:0]
draw_cmd_data_word_X[11:0]
draw_cmd_tx
Then I would assign the output port wire to them:
draw_cmd[35:32] = draw_cmd_func[3:0]
draw_cmd[31:24] = draw_cmd_data_color[7:0]
draw_cmd[23:12] = draw_cmd_data_word_Y[11:0]
draw_cmd[11:0]  = draw_cmd_data_word_X[11:0]
draw_cmd_rdy    = draw_cmd_tx
Make 16 localparams CMD_OUT_#choose a function name#  and make each = to the AUX# in my comments.
Then when sending a command, all you need to do is:
begin
 draw_cmd_func         <= CMD_OUT_#choose a function name#[3:0];
 draw_cmd_data_color   <= 'usually the draw color'
 draw_cmd_data_word_Y  <= 'usually Y coordinate'
 draw_cmd_data_word_X  <= 'usually  X coordinate'
 draw_cmd_tx           <= 1;
end ...
 else if no other new commands running draw_cmd_tx  <=0 ;
Basically, when sending a command, the 'draw_cmd' should have the right data and the 'draw_cmd_rdy' should go high same time.  The 'draw_cmd_rdy' may only be high for additional clocks if the next command going out is ready to go.
Basically when sending a command, make the draw_cmd_rdy =1, when doing nothing, or default state, make it =0.
I left out the things you should be able to work out on your own...
After this, compile in Quartus 9.1 on a schematic with inputs and outputs & try sending a few of the current completed commands and see if the output simulate right.
See attached 'geometry_xy_plotter.sv' where I tell you where and when you send out a command...
Post by: nockieboy on July 01, 2020, 04:48:03 pm
Sorry, bit confused - how does draw_cmd[35:0] get populated with data?  draw_cmd_func, draw_cmd_data_color, draw_cmd_data_word_Y and draw_cmd_data_word_X don't get set anywhere?  I've obviously missed something...  ???
EDIT: Yes - I missed the last code paragraph in your reply.  Still not sure which X/Y coordinate gets set though?
Post by: BrianHG on July 01, 2020, 05:17:28 pm
Take a look at the assigns I added:
// Assign output port wires to internal registers
assign draw_cmd[35:32] = draw_cmd_func[3:0];
assign draw_cmd[31:24] = draw_cmd_data_color[7:0];
assign draw_cmd[23:12] = draw_cmd_data_word_Y[11:0];
assign draw_cmd[11:0]  = draw_cmd_data_word_X[11:0];
assign draw_cmd_rdy    = draw_cmd_tx;
Also, I changed your first 4 command names so they make modern sense.
I also added parameters to the reset collision counters so you may also set 1 to 4 transparent colors when counting collisions, and for when you write/paste a pixel with the mask function.
(See next post)
(back in 1.5hours)
Post by: BrianHG on July 01, 2020, 05:55:58 pm
Ok, I simplified the layout and and broke everything down to 2 case statements.  See attached code.
It would be nice to replace all the 8'd### with FUNC_IN_'name of function' and at the beginning of the code, make localparams for all the FUNC_IN_'name of function'.
You will need to change the geo.bas to reflect the new FUNC_IN_xxxx #s, and modify the 'instr.txt' file for the fwasm.exe compiler so it's commands reflect the new FUNC_IN_xxxx #s.
I'll be back in 1.5 hours...
Post by: nockieboy on July 01, 2020, 06:25:22 pm
So I'm removing the func3 checks from Geo.bas entirely and instead checking func2 values, which need to match those in the Verilog file, right?
Did you include the code for 8'd127 in the extend_cmd case statement as an example of how the rest should go, or....?  Bit confused as Geo.bas uses x0 * 4096 + y0, but in the Verilog you've just assigned x[0] and y[0] directly to draw_cmd_data_word_X/Y.  Is that right?
Post by: BrianHG on July 01, 2020, 07:20:54 pm
Yes.  Its just that in the geo.bas, x&y should be swapped as Y holds the MSBs and X the LSBs.  I already got the right order in the .sv file for you.
Just look at the width of the assigned bits and where they end up.
I know in basic, I did it the *4096 for the MSBs and +(add) the LSBs.
Since the command input into this module is 16 bits wide, we need a method send a 24 bit address to the pixel writer.  The only way to do so is load 2 12 bit addresses into one of our temporary X&Y registers, then send those to the pixel writer.  Remember, the pixel writer has a 36bit command port, not 16 bit.
I allowed 12 bits to sent in 1 command by reserving commands 128 through 255, and using the lower 12 bits of the command to set the 8 available 12bit work registers.  Commands 0 through 127, IE command bit [7] being low, all perform 1 alternate function with the allowance for 1 additional byte stored in the first 8 bits of the command.
This means for the Z80 to send a command, it would need to send 2 adjacent bytes every time.
The 'geometry_xy_plotter.sv' takes in those 16 bit commands and will occasionally spit out 36bit commands to the next module containing the address generator which translates the mem address and x&y coordinates into a new mem address with the right offset pointing to the pixel, that unit will feed the memory writer which does a read/modify/write at the specified address, counting if there is a pixel collision.
After you complete this part and simulation of the geometry engine, we will add the first geometric shape, a box and a box fill.  When simulating that one, after issuing the command, the geo engine should spit a stream of CMD_OUT_PXWRI commands with x&y coordinates.
Post by: nockieboy on July 01, 2020, 08:08:50 pm
Okaaay.. I think the code is up to date with what you've specified.  Have attached both the Verilog and Free Basic source below.
Post by: BrianHG on July 01, 2020, 09:02:18 pm
Ok, I touched up the geometry_xy_plotter.sv.
Read it carefully and make it work and simulate in Quartus.
Also, add an IF(reset) ... else ... right at the top to default all the registers.
I also added the geo_shape, geo_run, geo_mask, geo_fill registers, tied them into the case statement and made a separate section after the loading of a command, the area where we place the running geo units.  I also assigned the load_cmd output and commented on each reg's purpose.
Post by: nockieboy on July 01, 2020, 09:33:07 pm
You just need to attach the file.  ;)  Will take a look tomorrow.  :-+
Post by: BrianHG on July 01, 2020, 11:06:43 pm
Ok, I've done the heavy lifting...
Here is the Quartus9.1 Simulation test bench:
[attachimg=1]
Here is a test simulation:
[attach=2]
And, I've attached the Quartus project.
Read the 'geometry_xy_plotter.sv' inside and see how I vastly simplified the case setup using the 'casez' command and using '?' for don't care bits on the commands.
Make sure you understand everything before continuing.  Next, you still need to add the 'reset' and test out a few of the current functioning commands in the simulation.
Ask questions!
Change my stimulus simulation inputs so that you at least fill an x&y coordinates in x0/y0, x1/y1.
Don't assume anything cause next, we will put in the 'draw_box' algorithm and watch it spit out a bunch of coordinates to plot.
Post by: BrianHG on July 02, 2020, 03:40:15 am
Ok, so I had time and got bored....  I figured coding would be better the snacking on junk food...
I've added the box & box_filled command, however, I deliberately did not make any comments on the function.
It will be your job to fill in the comments for each line & post them here so I can make sure you understand what's going on.
The code appears to simulate fine, with coordinates in all 4 directions.
You will also be responsible for testing the code in the simulator by manipulating the commands going into the geometry unit and deciphering the results.
Full Quartus project attached below.
(It so far compiles with an FMAX above your core 125MHz clock, though, we can run the geometry unit at 75MHz if ever needed.  It's only the memory pixel writer which we want running at 125MHz.)
Post by: nockieboy on July 02, 2020, 10:15:54 am
Here you go:
case (geo_shape)    // run a selected geometric drawing engine
4'd1 : begin    // draw a filled rectangle
if ( geo_y != (y[1] + geo_ydir) ) begin             // Check for bottom (or top, depending on sign of geo_ydir) of rectangle reached
if ( geo_x != (x[1] + geo_xdir) ) begin         // Check for right (or left, depending on sign of geo_xdir) of rectangle reached
draw_cmd_func        <= CMD_OUT_PXWRI[3:0]; // Set up command to pixel plotter to write a pixel,
draw_cmd_data_color  <= geo_color;          // ... in geo_colour,
draw_cmd_data_word_Y <= geo_y ;             // ... at Y-coordinate,
draw_cmd_data_word_X <= geo_x ;             // ... and X-coordinate.
draw_cmd_tx          <= 1'b1;               // send command (have moved this after the X, Y setting for easy reading)
// Now increment (or decrement according to geo_xdir) geo_x to the next pixel.
// If geo_fill is HIGH, step to next X-position to fill the rectangle.
// If geo_x is at the end edge, step past it.
// If geo_y is at start or end (top or bottom edge), step to next X-position to draw the horizontal line.
if (geo_fill || geo_x == x[1] || geo_y == y[0] || geo_y == y[1] )   geo_x <= geo_x + geo_xdir;
// Otherwise, jump to end X-position to draw other edge for non-filled rectangle.
else        geo_x <= x[1];
end else begin  // geo_x has passed vertical edge
draw_cmd_tx         <= 1'b0;                // do not send a draw cmd this cycle
geo_x               <= x[0];                // reset X to start X-position
geo_y               <= geo_y + geo_ydir;    // increment (or decrement) Y-position for next line
end
end else begin      // geo_y has passed horizontal edge
geo_run             <= 1'b0;                // stop geometry engine - shape completed
end
end // draw a filled rectangle
I'm confused about how cmd_h (with a value of 12) creates a filled rectangle (or a value of 8 creates a non-filled rectangle) - or how any value is interpreted from cmd_h and cmd_l.  There's a few bit operations and splitting of the cmd bus going on that I'm having difficulty following.   :o
Post by: BrianHG on July 02, 2020, 11:08:34 am
I separated the command into _h and _l for legibility.  Take a look at lines 207 through 231 (in particular line 214 where I transpose the draw command number) this is where I setup all the controls for the geometry engine:
            8'b000????? : begin // this range of commands all begin drawing a shape.
                                // drawing commands begin here.  Keep the convention that:
                                // extend_cmd[0] = mask enable
                                // extend_cmd[1] = use the color in the copy/paste buffer.  This one is for drawing in true color mode.
                                // extend_cmd[2] = fill enable
                geo_shape[3]         <= 1'b0;           // geo shapes 0 through 7, geo shapes 8 through 15 are for copy & paste.
/*LINE 214*/      geo_shape[2:0]       <= command_in[5:3];// Set which one of shapes 0 through 7 should be drawn.  Shape 0 turns means nothing is being drawn
                geo_fill             <= command_in[2];
                geo_paste            <= command_in[1];  // used for drawing in true color 16 bit mode
                geo_mask             <= command_in[0];
                geo_run              <= 1'b1;           // a flag which signifies that a geometric shap drawing engine will begin drawing
                geo_color            <= command_data8;  // set the 8bit pen color.
                geo_sub_func1        <= 4'b0;           // for geometric engines which have multiple phases, reset the phase counter
                geo_sub_func2        <= 4'b0;           // for geometric engines which have 2 dimensional multiple phases, reset the phase counter
                // Initialize the geometry unit starting coordinates and direction so it can begin plotting immediately
                geo_x                <= x[0];           // initialize the beginning pixel location
                geo_y                <= y[0];           // initialize the beginning pixel location
                if ( x[1] < x[0] ) geo_xdir <= 12'd0-12'd1; // set the direction of the counter (negative x in this case)
                else               geo_xdir <= 12'd1;       // positive x direction
                if ( y[1] < y[0] ) geo_ydir <= 12'd0-12'd1; // negative y direction
                else               geo_ydir <= 12'd1;       // positive y direction
            end
Now, let's make a change (Read all the ***):
                                // ***extend_cmd[3] = fill enable
                                // ***extend_cmd[4] = use the color in the copy/paste buffer.  This one is for drawing in true color mode.
                                // ***extend_cmd[5] = mask enable - when drawing, the mask colors will not be plotted as they are transparent
/*LINE214*/     geo_shape[2:0]       <= command_in[2:0];// *** Set which one of shapes 0 through 7 should be drawn.  Shape 0 turns means nothing is being drawn
                geo_fill             <= command_in[3];  // *** Fill enable bit.
                geo_paste            <= command_in[4];  // *** used for drawing in true color 16 bit mode
                geo_mask             <= 1'b0;           // *** Mask disables when drawing raw geometry shapes
            end
Change the .sv and simulate.  Tell me now what are the new 2 commands for drawing a box outline and filled box.  Simulate to make sure you got the figures correct.
This setup should make more sense...
Also make sure you verify that you understand how lines 101 & 102 work.  Why those 2 allow you to set all the x#&y# with 12 bit numbers, and why lines 107-108 & 115-116 send out all 4 of each as destination or source memory addresses.
