Electronics => PCB/EDA/CAD => Topic started by: legacy on February 18, 2019, 08:04:17 pm
version 2.1.1
Elisabeth and I have just created an ebuild (http://www.downthebunker.xyz/wonderland/chunk_of/stuff/public/projects/gentoo/pcb/pcb-rnd-2.1.1c.ebuild) (rev C), it has been tested on { ppc, hppa }, and it requires these (http://www.downthebunker.xyz/wonderland/chunk_of/stuff/public/projects/gentoo/pcb/files) two patches
besides, it requires these use flags, in /etc/portage/package.use/eda
sci-electronics/gerbv doc examples -static-libs unit-mm
sci-electronics/pcb-rnd -cairo gtk motif -opengl xrender gcode gerber
The installed programs will come with two GUIs: gtk and openmotif!
If you want opengl hardware support, you need to enable the opengl flag.
edit:
We (at DTB) are not affiliated with Gentoo, but we are unofficial supporters for non-x86 machines.
We will try to support future versions of pcb-rnd as soon as released.
Wow. Thank you for doing this!
Thanks also from our project leader Igor2.
we have just enhanced a bit the ebuild (http://www.downthebunker.xyz/wonderland/chunk_of/stuff/public/projects/gentoo/pcb/pcb-rnd-2.1.1e.ebuild) (rev E) and added a userflag (http://www.downthebunker.xyz/wonderland/chunk_of/stuff/public/projects/gentoo/pcb/pcb-rnd-2.1.1-useflags.txt) table.
