I've recently got a
Logitech StreamCam. I'm still not sure it was wise to spend this much on a webcam but I'm from the "buy good and buy once" camp so yeah, anyway, it's done.
Addressing your requirements, one by one:
- You can use digital zoom from within the "Logi Capture" software. There's also a smart framing feature that fills most of the frame with your face and and follows it automatically using digital zoom. *
- Exposure controls (manual/backlight compensation) are available in "Logi Capture" *
- The lens is fast at f/2.0 but the small physical sensor size makes the Depth of Field large anyway. You should expect pretty much of all the junk behind you to come out just as sharp as your face unless you're focusing at extremely close distances. There is a manual focus option in "Logi Capture" (*)
Note:Wherever I mention a feature exposed in "Logi Capture" application (*), it means it's either software-based or software-enabled. The app allows for recording video and snapshots from within itself it that's all you need. However, if you want to use these (*) features e.g. in a video conferencing app, on Windows the "Logi Capture " app can act as a kind of proxy, by exposing its own, processed video stream. Then you could set Skype/Teams/Zoom/Webex/whatever to use that stream. On macOS however, this function it not (yet?) available so it's either recording from within Logi Capture using the bells and whistles or using raw video stream from third party apps on Mac.
