Author Topic: ipad mini 2 2nd generation white lines on screen  (Read 1605 times)
Offline nvidiaTopic starter
« on: February 06, 2020, 06:08:11 am »
my mum gave me her old ipad because it had a problem its never been dropped always been in a case and taken good care of but when turning the  ipad it takes around 15-20seconds to boot up when booting screen is fine once on the lock screen after a couple of seconds up to maybe 20second i get the lines white lines on the screen
screen only goes bad when i pad is fully booted up
what could cause this problem and is there anything i can try and do without having to open ipad or replace the screen to try and fix this
Offline kripton2035
Re: ipad mini 2 2nd generation white lines on screen
« Reply #1 on: February 06, 2020, 06:33:54 am »
connect it to a computer with itunes installed, and try to restore it.
« Reply #2 on: February 06, 2020, 07:33:30 am »
ok i will try this
Offline kripton2035
« Reply #3 on: October 23, 2020, 09:16:21 am »
it's an "old ipad" the specialist will tell you to buy a new one...
