I use Windows 10 (64 bits) and currently do my HEX edditing with Notepad++ using the HEX EDITOR plugin.
This has been ok so far, but I am starting to have more and more HEX edditing cases and Notepad++ is not so great for this:
- Has issues handling big files
- Does not do HEX compare of two files
- Crashes/Freezes when selecting bigger chunks of data
Ideally the HEX Editor should be:
- free
- allow to handle big files (at least up to 20 MByte)
- should feature good Search/Replace functionality (in HEX and String)
- should show data in 8, 16, 32 or 64 bytes per line (selectable)
- allow COPY&PASTE of bytes (even large chunks)
- file compare when two files are open
- allow multiple windows (Notepad++ sucks IMHO here, as you need to first save the file, before you can drag it to a separate window and then all settings are put to default, i.e. the current line)
- if you are working on a specific line (file position) and resize the window or similar, that line has to be kept as current selected line
Please do not discuss how great Linux is and what great HEX Editors are available for this operating system. I happen to work in Windows, because this is the operating system that runs the applications I earn my money with.
Thanks,
Vitor
