Author Topic: BIOS for MSI MS-6163 Motherboard  (Read 1736 times)
Offline spilihpsTopic starter
« on: January 11, 2020, 05:17:10 pm »
So, after some recent diving in my old computer part boxes, i found this board.
For some reason, it has the BIOS - flash chip pulled. I have no idea if i have done it, if it was handed to me like that or what.
Does anyone have any information of compatible flash chips, and can the files that are still downloadable from MSI site be used?
https://www.msi.com/Motherboard/support/MS6163_Pro.html
« Last Edit: January 11, 2020, 05:21:53 pm by spilihps »
Online PA0PBZ
Re: BIOS for MSI MS-6163 Motherboard
« Reply #1 on: January 11, 2020, 08:37:14 pm »
If you can get the correct flash memory and a way to program it look in the downloadable .exe file and you will find a w6163imj.3a0 file which looks like an image for the flash. I attached it here for you but I had to rename it because you can't upload .3a0 files, so now it has a .hex extension. A proper extension would be .bin so rename it to read it into a programmer.
« Reply #2 on: January 11, 2020, 08:51:19 pm »
Thank you very much for that info.
Do you have any idea what memory was used? Or one that can be used :)
« Last Edit: January 11, 2020, 08:52:50 pm by spilihps »
Online wraper
  • Country: lv
« Reply #3 on: January 11, 2020, 08:55:27 pm »
Well, apparently some 2 Mbit (256KB) SPI parallel FLASH.
« Last Edit: January 11, 2020, 09:02:01 pm by wraper »
Offline MrMobodies
« Reply #4 on: January 11, 2020, 08:56:35 pm »
I couldn't find a good size picture and one readable ones have that "Award" logo over it.
See picture.
I typed in SST MPF and this number seems to match a bit on the blurry writing.
SST MPF SST39SF010A which is also showing on an old Xeltek programmer.
« Reply #5 on: January 11, 2020, 09:01:04 pm »
Thanks!
Yeah same here.. I think your picture may be from "ver2"
Mine is ver1
I found a picture that is almost readable.. it may say winbond 29c256
Edit : that was also ver 2 after some zooming.. wonder if that is any problem?
« Last Edit: January 11, 2020, 09:03:15 pm by spilihps »
Online wraper
  • Country: lv
« Reply #6 on: January 11, 2020, 09:03:47 pm »
I found a picture that is almost readable.. it may say winbond 29c256?
No chance. It may end with 020 but certainly not with 256.
EDIT: like SST39SF020 or similar from winbond.
IMHO on the picture is SST39SF020-70-4C-PH
EDIT2: If that's correct, you could use this as replacement https://eu.mouser.com/ProductDetail/Microchip-Technology/SST39SF020A-70-4C-PHE?qs=RKLR0Pe6v1lBETiSouLjAQ%3D%3D. And it's still in production so you don't need to buy dodgy salvaged/remarked crap from china.
« Last Edit: January 11, 2020, 09:12:22 pm by wraper »
« Reply #7 on: January 11, 2020, 09:14:13 pm »
Oh I see..
It was this picture, one of the few without the sticker
http://www.hardware-one.com/reviews/msi6163pro/images/6163pro_soft.jpg
Guess 020 would be possible  :-//
« Reply #8 on: January 12, 2020, 02:49:08 pm »
Sorry, did not see your edits yesterday.
Thats good news. I guess i will just try and order a couple of those. Finally a component that is not a dodgy pull from China that need 1 month delivery time :=\
