Author Topic: COM port on PC(Win 8.1 pro) - reset  (Read 846 times)
Offline PerranOakTopic starter
« on: August 06, 2020, 03:02:08 pm »
Occasionally, I have an error on a COM port that is resolved by rebooting the machine.
Is there a convenient way to reset/reinitialise without resorting to a reboot?
Cheers.
You can release yourself but the only way to go is down!
RJD
Offline thm_w
  • Non-expert
Re: COM port on PC(Win 8.1 pro) - reset
« Reply #1 on: August 06, 2020, 10:44:55 pm »
You can go to:
Device manager -> Ports -> Properties of the com port -> Port Settings tab -> Advanced -> Change port number
then try disable and re-enable it.
The downside is number has now changed.
If you are not using USB COM port already, try that, then it can possibly be unplugged an replugged.
The following users thanked this post: PerranOak
