a catastrophic event silently happened this morning: due to a bug in a script, a whole folder got deleted, and worse still, the script launched several resyncs before we noticed the problem.
Thousands precious files lost, with Inodes overwritten by houndred of useless files
When the Kernel primive "file_delete" is invoked, the ext3 filesystem doesn't leave the inode pointing to a file or to a folder, but it actually zeros out the block pointers in the inode, whereas ext2 just marks these blocks as unused in the block bitmaps and marks the inode as "deleted" and leaves the block pointers alone.
This means, common recovery tools (like DiskTest) simply do not work with ext3, you have to cross your finger, and try special tools, like described
here by the first person who tried to find a solution.
2019-10-21--14-33-18---2019-10-21--14-35-13 - [ sys-fs/extundelete ] - success - @2.29.1/7.3.0
2019-10-21--15-21-12---2019-10-21--15-21-58 - [ sys-fs/ext3grep ] - failure - @2.29.1/7.3.0
configure: error: ext3grep doesn't work on Big Endian systems
Unfortunately
ext3grep does not even compile on BIG Endian systems ( I am on a HPPA workstation ), while extundelete is less advanced, hene I moved the harddrive to a x86 machine.
But ... I was not so lucky to find the folder "/home/project/DT11", probably because overwritten by the resync. At least, the inode that describes the folder "project" is gone, but other inodes might still be there.
That project had backups, but the last one was made 30 days ago, and in the meanwhile my friends added a lot of new patches.
I am saying, the last four weekends of work is gone
So ... I am trying searching withing blocks with the idea of grabbing some block containing the header of tarball so the block might be reversed somehow into the inode and ext3grep might try to resume the file.
Each project had its tarball, kind of archive/${name}-ver${x}-rev${y}.tgz
