Bi/In alloys are often used to control for thermal expansion. It seems you can dial it in over a wide range of properties
Maybe even allow it to go to a liquid state towards the higher range (assuming you can mechanically prevent it from drooping all over your chip of course).
I'd think the thermal conductivity would be higher in a liquid state, and the heat sink bottom could be patterned for maximum surface area. Well worth trying imo!
Thank you,
I'm glad to hear regulating expansion is documented.
Irm afraid the liquid temperature range would be a tad too high for a cpu to run at comfortably. I was hoping for the 90 ish cap to be reached while not using a fan allowing the compound to flow and stick, then letting it cool.
After cooling I would hope it doesn't go above 65, doing it's job. The solid state, linking the copper and the lid was my hope for making a good thermal bond.
If something could get added to the/an alloy to make it fluid at 65 it would be the territory of the "liquid metal" product I would think. Applied sparingly enough I'm sure it wouldn't leak very much. idk...
The "liquid metal is advertised as having a 70 + W/mk conductivity"
Still I would like to see if what comes down to basically "soldering the sink to the lid" gives as a result.
