Author Topic: SSD slow WriteFile() with "FAST IO DISALLOWED" (Win11)  (Read 7361 times)
Offline Georgy.MoshkinTopic starter
  • Country: hk
  • R&D Engineer
    • How to become a Tech Sponsor
« on: December 03, 2023, 02:24:40 pm »
Observing some strange slowdowns when copying files...
1. AS SSD Benchmark write speed around 200mb/s
Process Monitor shows that benchmark writes to file and WriteFile () result is always SUCCESS. Procmon also shows, that file is created with "nocache" attribute.
2. Copying single 90gb file to external SSD using FAR Manager, write speed is 100mb/s. Haven't checked procmon yet. Was wrong about this one, speed is much lower. Disk goes to 100% load in task manager and speed drops.
3. Copying a lot of files using 7-zip (zero level compression) 12mb/s to external SSD, 20mb/s if writing to same disc. ProcMon shows that large 7z archive has a lot of WriteFile() calls, and some of then has FAST IO DISALLOWED result. 99% sure will work fast after clean install, but then something may be broken again. No defender, indexing, stopped all services with clickable stop button. Want to avoid reinstalling the system.
So what's strange is that making 100gb zero level compression file on the same disk as input files and then copying big file to external ssd is faster than outputting 7z archive directly on external ssd. Using this backup process since windows 8, and it's always something new with slowdowns. My 10-year old notebook does same backup with 7z at 90mb/s, and slowdowns was due to indexing or defender and resolved fast enough by disabling them.
Maybe something to do with sata ahci controller vid_8086 pid_4dd3. I couldn't find any driver, so currently it's Microsoft standard sata ahci driver.
Computer is noname n5095 laptop, 16gb ram, replaced SSD with a faster one.
What could it be? I tried to disable "MSI" through registry key, monitored disk writes and reads, disabled/enabled caching policy, but it's still unclear what makes copying process so slow.
« Last Edit: December 06, 2023, 03:50:58 pm by Georgy.Moshkin »
Disappointed with crowdfunding projects? Make a lasting, meaningful impact by becoming a Tech Sponsor today. Visit TechSponsor.io to Start Your Journey!
  • Country: hk
  • R&D Engineer
Re: SSD slow WriteFile() with "FAST IO DISALLOWED" (Win11)
« Reply #1 on: December 04, 2023, 01:46:27 pm »
I couldn't stand it, made a backup and reinstalled Windows. There is an improvement, backup speed is around 60mb/s, but not reaching 100mb/s.  It turns out that "fast io disallowed" for writes is not related to this problem. Most likely it is somehow related to SSD firmware, I'll try to search for updates. This doesn't explain why AS SSD benchmark always shows the same good results though.
Offline Haenk
« Reply #2 on: December 06, 2023, 10:59:39 am »
Too little info.
How is the external SSD connected? eSATA? USB? (level?) to SATA or m.2 SSD?
Which model of SSD?
Just a note on SSDs: A lot of cheaper SSDs even come without DRAM cache these days and reach their advertised speed by using multilevel flash as single level. But only a small amount of the storage capacity is used this (fast) way. The regular quad level memory is quite slow.
So when copying a really large file, you immediatly saturate the DRAM cache, very soon saturate the single level area (a couple of GB, max) and then run into quad level writing, which is really slow. Depending on the model it might be way slower than a mechanical HDD.
Benchmarking usually runs only on DRAM or single cell has no meaning when doing large transfers.
And, another thing, the SSD controllers get very hot when running a maximal transfer - going into thermal throtteling is common. (This is rather an issue with fast M.2 and not so much on SATA SSDs...)
The following users thanked this post: SeanB, 5U4GB
Online DavidAlfa
« Reply #3 on: December 06, 2023, 11:28:11 am »
Which SSD? Is everything OK in SMART?
Cheap ones have slow NAND, no DRAM cache, can perform like a slow USB drive!
  • Country: hk
  • R&D Engineer
« Reply #4 on: December 06, 2023, 02:19:05 pm »
Internal ssd is Kingspec nt-512 (2280) ngff. I will check smart. Something tells me that if I use ReadFile() and WriteFile() the same way as AS SSD Benchmark, then copy speed will be around 100-200mb/s for big files. I think that something if broken in Windows when using this chipset.
External SSD:
1) Cuso c5s-evo 480gb in Jmicron usb 3 generic enclosure. This one gave around 100mb/s during backups when connected to an old Inspiron-3542 laptop.
2) Product page vanished, I'll check later. Jmicron usb 3 enclosure. This one was main SSD of Inspiron-3542. CD-ROM was replaced by another 128gb SSD. Copy speeds always was satisfactory.
Now, using a newer PC I observe slightly better AS SSD Benchmark results, but copy speeds became much worse. I always used 7-zip's "store compression" level for backups, because it generates single file on external drive and provides significant copy speed boost compared to normal copy/paste.
« Last Edit: December 06, 2023, 02:37:33 pm by Georgy.Moshkin »
Online DavidAlfa
« Reply #5 on: December 06, 2023, 02:25:04 pm »
Have you tried documenting yourself googling that error?
There's plenty of info about it.
  • Country: hk
  • R&D Engineer
« Reply #6 on: December 06, 2023, 03:38:15 pm »
Yes, my hypothesis was that 100% disk C: load is somehow related to this error (copying from C: to C:). That's the only difference between AS SSD Benchmark and system copy routine in process monitor (plus nocache flag for AS SSD Benchmark generated temp files). Actually, topics on Microsoft forum and serverfault are not helping to solve this slowdown mystery. I observe these errors for writes (not reads!), and most of time it returns "SUCCESS". I still think that it may be related. Most importantly, I do backups all the time and know the speeds. Full backup of 128gb old ssd to 1gb toshiba hdd took less than 25 minutes around 10 years ago. System + data on SSD was around 70gb. When I bough bigger 256gb ssd and performed backup to an old 128gb ssd, I was pleased by 15 minute backup speeds.  Now it's 2023 and I copy 90gb and it takes almost 2 hours, but should take 30 min maximum.
Simple readfile/writefile test with FILE_FLAG_NO_BUFFERING can help with checking my hypothesis: If I am right, reading 100gb file from C: and writing it to external D: should show something around 100mb/s minimum.  Circular bufer, two threads, reading/writing by chunks chasing one another.
« Last Edit: December 06, 2023, 03:47:01 pm by Georgy.Moshkin »
  • Country: hk
  • R&D Engineer
« Reply #7 on: February 28, 2024, 09:49:40 am »
Finally solved! 14-minutes backups are back! It seems that source of the problem was Window Event Log service (now disabled).
I have used resmon (windows built-in), ProcessMonitor and ProcessExplorer. It seems that frequent "trickle charge" Event Logs slowdowns copying speeds. Today my backup speed dropped to 11mb/s and took 2+ hours! I never believed "experts" who told that SSD is very slow, and it's normal. It's simply not! I clearly remember that 10 years ago I already had fast daily backups.
1. First, I've noticed that pagefile start burst writes during backup. I tried to disable pagefile - no effect. Enabled it back.
2. Second, I've noticed that there are lots of tiny system writes from NTFS. I found some "NTFS hacks" page and tried this:
fsutil behavior set disable8dot3 1
fsutil behavior set mftzone 2
fsutil behavior set disablelastaccess 1
backup speed is still slow, but Task Manager now shows 60%-80% for source disk usage instead of 100%. No speed improvement, but still interesting.
3. Tried
fsutil usn deletejournal /d /n c:
no effect
4. The winner!
Disabled "Window Event Log service" and wow! Speeds goes up from 11 mb/s to  146 mb/s
Somehow this "trickle" logging slowdowns SSD significantly. Had same problem ~10 years ago because multi-functional printer driver constantly trickled event log with 20 bytes of some "could not find some compatible Twain" bs error.
Update: unfortunately this only worked for one or two weeks. I reinstalled everything to get speeds I need...
« Last Edit: April 01, 2024, 08:35:48 am by Georgy.Moshkin »
Online DavidAlfa
« Reply #8 on: February 28, 2024, 02:38:42 pm »
Don't delete the journal, you'll regret it when something unexpected happens to your FS.
Make sure you didn't lit a match near a gas tank when setting those "hacks".
  • Country: hk
  • R&D Engineer
« Reply #9 on: April 01, 2024, 08:34:01 am »
Ok... It came back few days ago. Copying became slow again. I've made a backup, deleted all partitions on SSD and created a new one using third-party partition manager bootable flash drive, installed latest WIN11 and now it works great again with >100mb/s copying speeds.
Offline radiolistener
  • Country: ua
« Reply #10 on: April 11, 2024, 08:16:20 am »
Did you tried to execute blkdiscard command for that SSD drive before testing?
The speed slowdown is possible due to many not erased sectors on SSD, it requires controller to perform erase operation during write operation and it takes additional time. If you do blkdiscard before testing it will erase all unused sectors, so the write operation will be executed faster.
I'm not familiar with details on how it's implemented, but blkdiscard helps to improve write speed performance in my case.
« Last Edit: April 11, 2024, 08:28:25 am by radiolistener »
The following users thanked this post: Georgy.Moshkin
Offline 5U4GB
« Reply #11 on: April 12, 2024, 09:52:02 am »
Various comments, firstly check everything @Haenk said, that was also my first reaction to seeing your post.  In particular Kingspec drives are cheap and nasty so the problem could just be the drive, see if you get the same problem with something like an EVO 8x0 series.  Finally, how much have you written to the drives?  The temporary reinstatement of performance after a reinstall, i.e. a complete redo of storage, followed by a slowdown again may just mean the flash wear limit has been reached.
Offline mariush
« Reply #12 on: April 12, 2024, 10:33:44 am »
I would suspect the constant writing (trickle writing, small writes) prevents the firmware from entering into garbage collection mode and erase/recover blocks of flash memory marked for erase
Flash memory is arranged in blocks (ex 24/32/64 MB or higher blocks of flash, which are then arranged in pages of 512 bytes or 4096 bytes or other sizes) - the controller can write to an empty page, but can't overwrite that page - in order to make the page available for writing the whole block (64 MB or whatever size it is) has to be erased (and that erase process wears out the flash memory).
So each time something has to be overwritten, the controller just finds an empty page somewhere in other parts of the flash drive, copies the old page with the changed bytes to a new page , marks the old page for erase, and updates a lookup table that says contents previously on block x , page y is now in block m, page n .... (off topic that lookup table is usually cached in ram at startup and makes dram based ssds a bit faster, dram isn't used to cache writes)
When there's a threshold of erased pages out of a block reached, for example 90% of pages from a 64 MB block, the controller copies the remaining 10% of pages in random places and then erases the block and makes it available to the system.
If the controller doesn't detect some idle time, it's possible it never erases blocks so the more time it takes the harder it is for the controller to find empty pages to put content into, and it may not have enough empty blocks to convert from TLC to pseudo-SLC to faster write speeds.
One potential solution would be to run the TRIM command (Windows defrag tool will do it on SSDs instead of defragmenting, TRIM will force the drive to do cleanup)
Most drives use pseudo-SLC to cache writes - what they do is take one of those blocks of 24/32/64 MB of flash memory where each cell holds 2 bits for MLC, 3 bits for TLC and 4 bits for QLC, and convert the block to SLC mode storing just one bit in each cell - so for example 64 MB of QLC becomes 16 MB of fast SLC cache, 64 MB of TLC becomes around 20 MB of SLC cache etc etc.
You write stuff, controller puts it in SLC cache and afterwards at idle time, it will slowly move the data to TLC memory areas.
Blocks in pseudo-SLC mode wear out slower ... maybe 10k erases QLC is rated for 200-600 erases, TLC goes from around 1000 to 4000 erases, MLC goes up to around 10-15k erases, SLC goes from 10k to maybe 30-50k erases, some small slc chips can do even 100k erases.
OP , if your backups are a few GB or less, I would suggest seeing if you can spin up a ram disk before your backup - for example on Windows I use ImDisk toolkit and can create ram drives with or without physical backup (disk image).  Without a disk image, I can set up a 10 GB ram drive (because I have 16 GB of ram) in seconds and quick format it to NTFS and you could compress the data to the RAM drive, then simply copy the archive to the SSD in a burst.
You may also take advantage of this to sort your file types and then pack together your files in a TAR archive (7zip can create TAR archives) and you could run a DIFF between previous backups and current backup. I like XDelta  (open source tool) but there's other binary diff tools.
Keep each day's archive for 30 days, after that you could keep only 1st day of the week or month and then for the next days keep the diffs only (so if you want friday's backup, generate from diff between monday and friday). 7z in store mode may also work, but 7z format may shift some bytes around that could make it less efficient to do binary diffs.  TAR is simpler, 512 byte blocks, if your files are sorted in same order then a binary diff would easily store only the differences.
  • Country: hk
  • R&D Engineer
« Reply #13 on: May 14, 2024, 01:43:17 am »
An update...
Internal SSD #1: Kingspec nt-512 "2280 NGFF" (installed in notebook's motherboard slot)
External SSD #2: stmagic 512G (can't find model on enclosure) in "cool fish" usb3.0 jmicron chip enclosure - works slower than #3 for backups
External SSD #3: CUSO C5S-EVO 480G in "cool fish" usb3.0 jmicron chip enclosure - works pretty fast for backups
So, I was wrong about my assumption that it is not an SSD problem. I needed a backup, but this time speeds dropped to 14mb/s when copying from SSD #1 to SSD #2. I connected internal SSD to table PC motherboard (win10) and made a backup at only around 20mb/s, which is obviously an SSD problem.
I put SSD back to the notebook and copied all the data (140gb) to temporary directory at something close to 20mb/s. Yes, no external drives this time. I copied data from #1 to #1. One of the reasons was that I wanted to see how TRIM results ("defrag E: /L /U /V") will change after I delete large chunk of data. I performed trim through "Defrag and Optimize" on #1 before copying, performed a reboot. For some reason, copying from #1 to #1 was still faster than copying from #1 to #2. Then, I deleted original directory and renamed temporary one, so everything looks as before. To my surprise, copying #1 to #2 is to 40mb/s and copying from #1 to #3 is 70mb/s. I did full 140gb backup at 70mb/s, it took around 30 minutes. And then used bootable flash to do a full backup (system+data) on a slower SSD #2.
About disabling services, etc. It helps, but it seems that windows always pops some new tasks if CPU load is high. I spent a lot of time with process monitor, process explorer and resource monitor.  E.g., first it was defender, then indexing, then some crazy registry activity related to DNS and TCP/IP. After I disabled everything one by one, serviecs.exe started to check registry keys related to disabled DNS-something service. I still see a lot of NTFS journaling and some LOG/LOG2 files saved in registry directory. Currently, I run Win 11 23H2, but speed improvement after copying SSD #1 data on itself (#1 to #1) convinced me that installing some old build Win 10 will not help, and it is most likely SSD problem and not OS problem (I believe OS file access routines can be modified in some way to optimize for speed on such SSD drives).
I still think that my internal SSD is a good one. I need more proofs and have an idea of creating small application which pumps data from one SSD to another. Idea is to make multi-threaded app which finds an optimal number of overlapping threads for fast transfers of big and small files. Something is not right here. I am going to speculate. At first, I thought that there is some broken NTFS journaling or this LOG/LOG2 files writing activity affects performance. But the latest experiment shows 5-6 times speed improvement when copying same 140gb chunk of data from the same SSD to external SSD (on a 16gb RAM notebook, it can't be cached). So, conclusion can be that now first 140gb directory occupies "bad" slow sectors, and the second copy of 140gb directory occupies "good" fast sectors. BUT, when I perform sector-level backup using bootable flash drive (aomei backupper) backup speeds are constant - with no dips. But even this speed was far from ideal after some time. What the hell causes this slowdown? Need more experimentation, e.g. use non-windows bootable sector backup app to check if it is not some ntfs journaling trickling in background, not sure if it is possible to perform a backup of unmounted drive. Maybe something wrong with SSD controller algorithms.
To sum up:
1) Disabling services helps, but it seems that windows activate some other background tasks more frequently if there is low CPU/disk load.
2) There is some problem with SSD controller or with NTFS/OS disk access routines. After I made a copy of 140gb directory on the same SSD, files from new directory can be read at 70mb/s compared to 14mb/s from old directory. But it doesn't affect sector-level backup speed using bootable flash drive (winpe aomei backupper). Note that sector level backup speeds are still lower than 70mb/s.
3) It would be interesting to see if it is possible to make copy utility tests if files can be copied at >100mb/s speeds between two ssd drives drives. I am talking about this particular setup with N5095 based notebook PC. I have table PC with NVME drive which copies files very well at >500mb/s and shows something close to 1000mb/s in AS SSD benchmark.
4) 146 mb/s is gone?! Can't reproduce this speed by re-creating partition and reinstalling the whole thing. I still wonder how the hell my 10+ years old Toshiba notebook pc with less ancient Galaxy 120gb SSD demonstrated something close to 80mb/s when I performed backup on external HDD. I remember how backup speed slowly dropped to 60mb/s to the end of backup. I remember 15-20 min backups and how I wondered why nobody I know doing this, because it is so easy. Just backup the whole SSD disk with data in the morning (windows XP + all data on the disk).
radiolistener, no, I haven't tried to force trim before yesterday. But I've noticed that "Defrag and Optimize" reported around 10 days since last optimization (I assume it means TRIM, at least pressing button displays message about SSD trim operation is in progress). In yesterday's experiment, I used trim - copied data from one directory to the second directory. And new copy of data read speeds are now much faster. Not sure if it is related to running trim right before making this operation. It turns out that I have some problems with read speeds too.
5U4GB, my internal SSD age is around 1 year and 3 months. Not much writing and plenty of free space (225gb out of 476gb currently is free). At first, I was skeptical about this idea of wearing out. Not so sure now. Maybe something is wrong in some SSD area, e.g., NTFS tables occupied some "slow" sectors and controller did not relocate it properly, or something like that.
mariush, I usually use 7Zip with zero level compression ("0-Store"), because it provides fastest backup speed compared to compression. I used 7Zip-Std modified version for some time, because it provided compression fast enough to even improve copying speeds - less writes. 7Zip-std uses Zstandard, a "Fast real-time compression algorithm". Process you described sounds very interesting and also makes me worry that for some reason my SSD controller starts to perform some erroneous maintaining operations, e.g. I often observe 100% disk load with read speeds dropped to 14mb/s. Interestingly, changing AHCI affects this value. It's either calculation formula differences between intel and Microsoft drivers, or AHCI drivers different some other way.
« Last Edit: May 14, 2024, 02:23:14 am by Georgy.Moshkin »
