Author Topic: Do you trust consumer grade SSD to store back up?  (Read 4327 times)
Offline Rick LawTopic starter
« on: January 18, 2023, 07:02:53 pm »
I go back and forth with this one.  I have a couple of Crucial MX500 (500gb SSD) and a few Seagate Momentus (500gb  spinning disc).  Both are easy to connect up to do back-up, but from experience of > a decade ago (40 gb SSD), I found myself having difficulty trusting the SSD for long term (5 to 10 yrs) back-up.
What are your experiences with consumer grade SSD for long term (over 5 years) backup?
Offline Zucca
  • EE meid in Itali
Re: Do you trust consumer grade SSD to store back up?
« Reply #1 on: January 18, 2023, 07:21:19 pm »
The first SSDs that show up on the market (2013-2014) were absolutely a horror movie!
Today things are different, they are reliable and all is good.
That said SSD or not there is only one golden rule: do regular backup on your data.
I have multiple backup on SSD, spinning and cloud for my crap.
Offline rdl
« Reply #2 on: January 18, 2023, 07:53:42 pm »
I doubt they're worse than anything else. They might be better. Right now what I distrust the least is good quality spinners. But I would say SSD is a very close second. I am using both for long term storage but I don't have any history yet with SSD.
Offline bdunham7
« Reply #3 on: January 18, 2023, 08:08:12 pm »
I wouldn't rely on broad classifications to make such decisions, I'd look at the historical failure rates of specific models.  For me SSDs are only Samsung and not the old 840 series.  HDDs are various HGST models, the Samsung (now Seagate) 2TB 2.5" M9T (for laptop internal backup) and for big non-critical stuff (media) the 8TB Samsung 3.5" drives shucked from external enclosures.  The last are low-power, low-RPM and SMR, but so far so good. YMMV and it might pay to read the reliability reports from BackBlaze.
As far as time and potential bitrot, I've been running a Samsung 830 for 10 years and that computer is now only used occasionally.  No issues or errors.
Offline iMo
  • Country: bt
« Reply #4 on: January 18, 2023, 08:24:26 pm »
It depends on the SSD technology.. With newer SSDs the endurance (number of writes per flash cell) decreases significantly (while the flash cell density increases significantly). You have to doublecheck the flash technology of your SSD. Moreover the flash memory cells consist of Leyden jars where the charge slowly evaporates, thus you have to consider the max flash cell retention time (usually 10 years).
« Last Edit: January 18, 2023, 08:27:00 pm by imo »
Offline Twoflower
« Reply #5 on: January 18, 2023, 08:26:19 pm »
SSDs has some problems with storage if the device isn't powered up regular. The flash cells don't hold the electrons forever trapped. If you want to use SSDs for long therm storage: Store them cold and power them up every now and then to allow the drive to refresh the data. Some more information can be found here: https://www.partitionwizard.com/clone-disk/is-ssd-good-for-long-term-storage.html Including some information about how long the data is stored under certain temperatures.
The following users thanked this post: Ed.Kloonk
Offline iMo
  • Country: bt
« Reply #6 on: January 18, 2023, 08:29:51 pm »
I don't trust any media for backups. I limit myself to projects and work that don't require backups. I only do things that I can remember 100% in my head at all times. If I forget anything, it wasn't worth remembering.
What projects are you into?
Online SiliconWizard
« Reply #7 on: January 18, 2023, 08:45:18 pm »
Short answer: No.
More elaborate answer: you shouldn't trust any particular media for "long-term" storage anyway. Each have their own particular way of failing. So unless you absolutely have to guarantee long-term retention (such as if you were sending data in deep space hoping for some civilization to find it someday), your best bet is always to replicate data on a regular basis.
Sure the time period is ideally not too short, else it becomes unpractical. Once a year or once every other year, for data that doesn't change, is reasonable. 5 may be pushing your luck a bit too far, and 10 certainly.
Just my 2 cents.
Offline iMo
  • Country: bt
« Reply #8 on: January 18, 2023, 08:56:44 pm »
The best storage disk so far..
The following users thanked this post: SeanB, DiTBho
Online Halcyon
  • Global Moderator
« Reply #9 on: January 19, 2023, 05:27:09 am »
Data retention on SSDs vary, but there is a limit. It all depends on the type of memory used, quality, storage temperature etc...
Figures will vary but you should expect data to remain intact for about 10 years on an good quality SLC (very expensive) or MLC-based SSD at normal room temperature (25°C). With TLC, you may only get 1 year or two depending on how full the drive is. (These are in a powered-off state by the way.)
As temperatures increase, data retention decreases. For example, some tests show data retention at 55°C on a drive nearing capacity to be only a few months.
There is a JEDEC specification for endurance of SSD drives as well.
This might not be too important for home users, but in data centres where server rooms can operate at elevated temperatures, it can be a real problem. IBM released this note a few years ago: https://www.ibm.com/support/pages/potential-ssd-data-loss-after-extended-shutdown
I haven't done any reading into V-NAND/3D NAND however some sources claim that it's approaching the level of endurance compared to the older MLC flash.
My advice is, keep data in motion. Create multiple copies and use a resilient file system, like ZFS to detect and correct data errors through semi-regular scrubs.
« Last Edit: January 19, 2023, 05:31:57 am by Halcyon »
The following users thanked this post: thm_w, Zucca, Ranayna, Trader, DiTBho
Offline Trader
« Reply #10 on: January 19, 2023, 07:22:44 am »
SSD offline can lose information, TLC (the most common today) is safe for up to 6 months, after that there is a high probability of missing bits.
Offline Berni
  • Country: si
« Reply #11 on: January 19, 2023, 08:08:44 am »
Nope, do NOT use SSDs as backup drives.
The modern flash is more and more packed (both in cell size and number of analog levels per cell) so the data retention reliability keeps getting worse and worse. They mainly rely on ECC codes to repair corrupt data while it is being read back out. So the data has to be accessed every few years to make sure any corruption gets found and patched up. If a page of flash accumulates too many corrupt bits(as as the charge leaks out of the flash cells), then the ECC might not be able to repair the damage anymore.
The industrial solution to the problem is tape drives. They essentially last forever if stored in the right environment and the media/drive are separate. So if a tape drive fails the same tape can still be read back out on a brand new tape drive. This is more of an enterprise solution so it is not that cheap, but you might be able to find some units that ware thrown out of a server room up on ebay.
But the common home solution is to just buy a 2 external USB hard drives. They are cheep at high capacities and hard drives are generally very reliable long term. The reason why you want 2 is to guard against a hard drive failure. You can simply alternate between using the two drives when doing a backup. That way one drive is holding the latest backup, the other one is holding the previous backup. That way it is no more extra effort as you still copy onto just one drive, but you have a safety net if a drive dies or the backup process writes something bad to a drive.
Offline magic
« Reply #12 on: January 19, 2023, 10:41:51 am »
Another fun fact about SSDs is that a few bit flips in the right place can render the whole drive completely unreadable. Happened to me. After secure erase, the drive keeps working as if nothing happened, but old data are gone forever.
With spinning rust, media errors are localized and mechanical failures I have encountered so far tended to give some warning (smaller glitches) before no data could be recovered at all.
Offline wraper
  • Country: lv
« Reply #13 on: January 19, 2023, 10:58:13 am »
They were already available 5 years earlier. I personally bought 240GB OCZ Vertex 2 in about 2012 IIRC.
« Last Edit: January 19, 2023, 11:00:27 am by wraper »
Online DiTBho
« Reply #14 on: January 19, 2023, 11:00:33 am »
I dream about a msata solid disc made with FeRAM  :D
Online Psi
« Reply #15 on: January 19, 2023, 11:23:51 am »
Trust the number of backups you have, not the medium they are backed up on.
SSDs are fine
Offline golden_labels
« Reply #16 on: January 19, 2023, 12:49:06 pm »
I do not have own data on SSD for backup solutions. Based on talks with other people: modern SSDs do not have any absurdly high failure rate.
Having to choose between HDD and SSD, I would choose HDD for reasons unrelated to reliability. I can buy multiple HDDs for a price of equally sized SSD. Numbers always trump reliability of a single component.
People imagine AI as T1000. What we got so far is glorified T9.
Online DiTBho
« Reply #17 on: January 19, 2023, 01:16:11 pm »
Some bits flipping in the right place which can really make the whole disk completely unreadable or insanely corrupted; the same happened to me, after the Windows XP crash, to a laptop that I had left in my desk drawer for 4 months.
I mean, a simple crash can't destroy NTFS like this, and I'm not sure, but the accident might be the consequence, not the cause, because some months later, the same problem happened with xfs-v3 running Linux.
Again, as you said, after the secure erase, the drive continued to work as if nothing happened, but this time I decided to replace the SSD with a new one because I trust it anymore.
No precious data lost, thanks to back-ups  :-+
Offline wraper
  • Country: lv
« Reply #18 on: January 19, 2023, 01:28:40 pm »
SSDs usually crap out because of firmware locks it, often because of some firmware bugs as it shuffles the data all around a lot. It's much more complicated than HDD which simply write the data to designated area. Old SSD tended to lock out completely as some error happened, modern SSD usually lock into read-only mode which allows you to copy the data slowly.  I would not recommend using SSD for a long term backup where SSD remains non powered for many months. Modern NAND loses charge pretty fast and the more bit per cell is stored, the harder it's to distinguish the actual level initially written.
The following users thanked this post: SiliconWizard, Trader, DiTBho
Offline 50ShadesOfDirt
« Reply #19 on: January 19, 2023, 06:16:10 pm »
Didn't see it yet, but as long as your valuable data is protected under something like the "3-2-1" rule for backups, then you should be as "golden" as that voyager disk.
Then you can fiddle with individual elements of the rule, like SSD in place of something else, for some piece of the 3-2-1 rule.
Offline Nusa
« Reply #20 on: January 19, 2023, 09:22:48 pm »
Punch cards survive the longevity rule. Still having the equipment to create or read them is another matter.
Offline dobsonr741
« Reply #21 on: January 19, 2023, 09:57:16 pm »
SSD improved a lot and prices went down in the last 10 years. Check the TBW (total bytes written) as the indicator of the endurance. The good news when SSD fails it goes read only, not like a spinning disk completely dead.
If you think about data retention for 10 years you must be thinking on backup alternatives, regardless of media.
I’m personally doing SSD for fast access at home, and cloud backup for long term.
Offline Perkele
  • Country: ie
« Reply #22 on: January 19, 2023, 10:00:55 pm »
Define "backup". Large monolithic files, or a huge number of smaller ones?
How often is a backup disk powered-on? How often do you check it for errors?
The same applies to "spinning rust" disks, USB memory sticks and any other R/W media.
Which filesystem?
And yeah, without some variant of "3-2-1" you're going to lose the data.
Online DiTBho
« Reply #23 on: January 19, 2023, 11:42:49 pm »
DVD-ram is a good backup solution for me, 4GB on each cartridge.
But I want a Plasmon unit  :D
Offline vk6zgo
« Reply #24 on: January 20, 2023, 12:37:41 am »
Quite a few years ago, I decided to "digitise" all my 35mm transparencies, so bought an appropriate scanner.
I did a bunch of them, & it was "so far, so good", except that the scanner didn't have the dynamic range to reproduce detail of relatively dimly lit subjects, but they were quite few, so I was happy enough.
At that point, the (XP) computer crashed, & lost all of my photos.
After trying all the "clever tricks" to no avail, I put it into the "too hard basket".
I got about 6 months of storage, out of that "spinning rust" drive!
Meanwhile, the original transparencies are still "hanging in there", from 50-60 years ago!
The slide scanner disappeared into the household "black hole", & only recently emerged, minus its software disk, so I guess I will have to buy something else to do the job, plus, maybe, a standalone backup drive.
The easy way is to say, "To hell with it---when I'm gone, nobody will care, anyway!"
The following users thanked this post: karpouzi9
