Soldered memory would either need to include the registered clock driver chip or the memory controller could perform that function itself. The registered clock driver is only absolutely required when the plug-in DIMM form factor is used.
Whether anybody will make processors with the registered clock driver built in to directly access soldered in memory is a completely different question, but they could.
