I believe I have seen both types used.
Generally the push on, push off I have seen have been in older (like 90’s or 00’s) machines so am guessing the answer is probably momentarily, but can’t be 100% sure.
Do you know the motherboard/ still have the info on that? I believe the documentation for that should say
Edit: in my experience pulling old computers apart, if hitting the power button instantly turns the computer off, it is likely a push on / push off. However, if you need to hold for 5 seconds or what not, it is probably momentary. I’m not sure if that is a hard and fast rule, but is just something I have noticed
