Author Topic: Failing Win XP HDD  (Read 4784 times)
Online Postal2
  • Country: ru
Re: Failing Win XP HDD
« Reply #75 on: May 22, 2024, 08:27:49 am »
soldar, if your OS is Windows, I can provide my tool for cloning with instructions. You will finish your work in 30 minutes.
Online soldarTopic starter
« Reply #76 on: May 22, 2024, 09:20:27 am »
--size is a self explaining option.
Probably this option might have worked for me the first time around had I known it. Without it I just got an error that the destination was smaller than the original and the program terminated.
I might try this next first but I want to wait a while because I have spent too much time on this already and I need to recover myself. And I want to make sure everything works OK in my new copy so I will be using it for a while before I do the new clone.
So, let us assume:
Origin:
sda = MBR, total 3TB, HDD
- sda1 : 336 GB NTFS
- sda2 : 663 GB NTFS
- Empty space : 2 TB
Destination:
sdb : 500 GB, empty, SSD
So I can try
sudo ddrescue --size 350GB /dev/sda /dev/sdb /home/user/Desktop/mapfile.txt
And that would copy the MBR, the first partition and just the beginning of the second partition. Then I could use something like gparted or similar tool to delete the part of the second partition and enlarge the first partition to fill the entire 500 GB of the SSD. Correct?
Online Postal2
  • Country: ru
« Reply #77 on: May 22, 2024, 09:28:13 am »
........ Then I could use something like gparted or similar tool to delete the part of the second partition and enlarge the first partition to fill the entire 500 GB of the SSD. Correct?
You can boot clone and make all needed from there.
Offline m k
« Reply #78 on: May 22, 2024, 02:20:55 pm »
So I can try
Yes.
But since there are no problems now you can drop the mapfile.
You can also try something fancy, since as you know, Linux is a nerd thing.
Generally syntax between options like -s and --size are different, but it's not stone carved.
Usually '--' and '=' are friends.
sudo touch /home/user/Desktop/1st_blk.img
sudo ddrescue -s 512 /dev/sdb /home/user/Desktop/1st_blk.img
sudo hexdump --canonical /home/user/Desktop/1st_blk.img > /home/user/Desktop/1st_blk.txt
There's your new MBR, it may have many copies.
sudo touch /home/user/Desktop/some_blocks.img
sudo ddrescue -s 4096 /dev/sdb /home/user/Desktop/some_blocks.img
Then the fancy part.
sudo ddrescue -o 462 --size=16 /dev/zero /dev/sdb
Now you have cleared the second partition table, or that's at least my impression.
Not very canonical way of ddrescue, but hey, it's a nerd thing.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
Offline Monkeh
« Reply #79 on: May 22, 2024, 06:29:57 pm »
Just like with any other tool once you're done dealing with drive firmware.
Don't enlarge the partition from outside Windows. Windows is not smart, and will break.
Online Postal2
  • Country: ru
« Reply #80 on: May 22, 2024, 07:14:26 pm »
I told you, it's natively win32diskimager.
https://github.com/joshg253/win32diskimager/blob/master/src/disk.cpp
Added:
Enumerating all disks via setupapi;
Enhanced checking/skipping of errors;
Variable buffer size.
Offline Monkeh
« Reply #81 on: May 22, 2024, 07:32:15 pm »
And? It's not magically faster than any other tool which relies on the OS to handle the disk. Now he has a clean copy there's no bottleneck (which was never the tool, always the drive).
Online Postal2
  • Country: ru
« Reply #82 on: May 22, 2024, 07:42:02 pm »
You right. It's not magically faster. Simply your tool is magically slower.
Okay, dumb disk drive seats on the track, watch track signature, can re-read without moving, but so dumb to execute reset. Your tool nothing do with it.
« Last Edit: May 22, 2024, 08:00:57 pm by Postal2 »
Offline Monkeh
« Reply #83 on: May 23, 2024, 12:36:22 am »
The tool you didn't even know existed, despite it being 20 years old, and that you've not used or done any research on.
Not my tool. And not my fault you haven't encountered drives which aggressively retry reads rather than return errors.
Seeing as the issue of cloning a failing drive successfully is now resolved with industry standard, openly available tooling, perhaps instead of confusing matters further you could just go learn about that.
Offline m k
« Reply #84 on: May 23, 2024, 07:43:33 am »
Yes, luckily nowadays Windows has a simple tool for that.
But it doesn't move files, or didn't when I used it, so defrag may be needed.
Online Postal2
  • Country: ru
« Reply #85 on: May 23, 2024, 08:01:41 am »
I know program "Calibrate" from Norton which behavior exactly same and so old too.
Yes I encountered in the last century.
I told you, disk retries himself when lose track, but in this case soldar cannot clone without errors.
« Last Edit: May 23, 2024, 08:30:00 am by Postal2 »
