I'm checking out all the driver vers to find out when this problem originaly occurred.
I'm currently using 319.92, reason I wanna update it is because it's about a year old now.
Anyways it looks like the latest ver I can get my hand =s on without the prob might be 320.49.
I have not actually checked it though.
320.86 I know is affected, and it looks as if 320.78 is affected as well but I haven't checked.
I'm just going by what the readme's say this sec for those untested drivers.
I don't think it needs the edid forced because it can still read it from the monitor.
I'm gonna try this program called nvidia pixel clock patcher, it might take me a day to get around to trying it.
If that doesn't work, I'm try my hand at hex editing the driver and see if I can't figure out what changed.
I just get ver 320.49 downloaded and I'm gonna try that.
Um and in the driver readme's the issue is laid out as:
Multi-Monitor Support on GRID
Multi-monitor support on GRID boards K1
and K2 requires the following VBIOS
versions:
GRID K1:
80.07.AF.00.00
or later
GRID K2:
80:04:BA:00.00
or later
I read back when that people were having trouble getting past single link speeds in there virtual machines and this was the fix for it.
So I assume the fix and problem is one in the same.
Tesla k10 might be a solution, I haven't checked in a while which needs which resistor config but whatever is the easiest
These smd's, I've never seen them so small before, the ones on my card are sooooo tiny.
And thanks for the replies anyways
