Author Topic: [MOVED] Hacking NVidia Cards into their Professional Counterparts  (Read 1663483 times)
Offline amin_eshgh
Re: [MOVED] Hacking NVidia Cards into their Professional Counterparts
« Reply #1050 on: August 29, 2014, 11:58:09 am »
I said that because 650 ti boost have same hardware like k4000 but 660 have more shader
Offline Patribus
« Reply #1051 on: August 29, 2014, 02:03:48 pm »
sorry, but can you explain waht you mean with "more shader"?
best regards
Offline amin_eshgh
« Reply #1052 on: August 31, 2014, 02:16:44 am »
My mean is that your card should have 928 core but 660 have 980 core
Offline Patribus
« Reply #1053 on: August 31, 2014, 08:39:44 am »
But which Quadro card would correspond to the 660 one than?
Offline kzyswd
« Reply #1054 on: September 04, 2014, 01:37:01 am »
I want to make one thing clear. Quadro cards usually has lower clock speed and such, which makes it slower in gaming compared to Geforce but makes up with the "better" driver for certain applications. Since hacking a Geforce into Quadro doesnt change its hardware, does it mean it will have the same gaming performace as before it was hacked, but with increased performance for professional applications?
In other words, will a hacked GTX 690 + qudaro driver still performs the same as original Gtx 690 in gaming, but will also perform as well or even better in professional application compared to K5000 ??
« Last Edit: September 04, 2014, 01:40:11 am by kzyswd »
Offline Therion
« Reply #1055 on: September 05, 2014, 10:34:42 am »
Hello
I have discovered this thread a while ago... since I had success soft modding an GTX470 into an Quadro and using it via VGA Passthrough/ESXi 5.5 I also wanted to try the hard mod version.
I got my hands on an GTX680 (Gainward board) and tried to remove the resistor on the back, I seemed to have success.
The card identifies now as Tesla K10 - however on my  first try yesterday I wasnt able to load any drivers, I tried 337.xx GeForce (WHQL), 331.xx GeForce (WHQL) and also some Quadro-Tesla-Grid 331.xx.
With the modded GTX470 this is working fine (running on Win7 x64 with 337.xx driver).
The error code is always 10 (unable to start the device).
Any ideas, could it be an ESXi only problem?
Or would you say I did break the card?
I'll try it again either today or in a couple of days (depending on my time...).
Offline pluger
Re: Hacking NVidia Cards into their Professional Counterparts
« Reply #1056 on: September 05, 2014, 04:13:50 pm »
Hi all again ;)
I successfully modified SPARKLE SXS4501024D5SNM GeForce GTS 450  1GB to Quadro 2000
board is reference nvidia gts 450 http://www.ixbt.com/video3/images/ref/gts450-scan-back.jpg
upd:
gpu passthrough works fine.
Initial values are:
indexmeaningresistance
13 byte value Dnone
23 byte value C35k
34 byte values 8-fnone
44 byte values 0-725k
device / resistors table
device nameR1R2R3R4
gts 450none35knone25k
Quadro 200035knone5knone
furmark: http://www.ozone3d.net/benchmarks/furmark_192_score.php?id=120616
Today, i do this hard mod with Gygabyte NVIDIA GTX 650 4gb overclocked version(GV-N650oc-4GI), i convert to Nvidia Quadro K2000, the pcb is the same that any (gtx 650), i remove the Resistor number 1 with value 25K. For the resistor number 2, i bought a smd resistor 0402 +-5% 39K OHM (similar to 40k ohm resistor) its works, i recomend to buy a smd flux and desolder to made more symple this hard mod. For the resistor number 3, i remove it, and then i put this resistor in the resistor 4 place. This graphic card don't need any bios mod with hex edit, only desintall any old graphic card driver, and install a clean quadro driver.
Offline amin_eshgh
« Reply #1057 on: September 06, 2014, 12:50:23 pm »
congratulation Pluger  >:D
Kzyswd : no because in quadro driver Physics is remove.
Offline maxpoz
« Reply #1058 on: September 06, 2014, 04:19:09 pm »
hello,
it's possible to hack my 560ti to use a quadro driver?
Offline Patribus
« Reply #1059 on: September 07, 2014, 11:36:03 am »
Hello, my question again: is there some Wiki where an overview of the mods is available? IT is really diffucult to maintain the overview in a forum like this one.
And if not, should we start one?
Best regards
« Last Edit: September 07, 2014, 09:48:48 pm by Patribus »
Offline ngphucok
« Reply #1060 on: September 09, 2014, 02:16:33 am »
Hi all again ;)
upd:
Initial values are:
13 byte value Dnone
23 byte value C35k
device nameR1R2R3R4
Hello , can you please check the value again ?  If it is None 35K None 5K, then what is the device supposed to be? I read up in the Nvidia Device ID list.  Quadro 2000 suppose to be 0308 right ?  Btw, I tried to mod like you with the PNY GTS450 but for some reason it turns out to be 0DDC which is unrecognized as anything.  Btw, do we need to change any BIOS? if so, can you please show me how? Thanks a lot ... !!!
Looking to hear from you soon.
« Last Edit: September 11, 2014, 05:32:28 pm by ngphucok »
Offline dreadkopp
« Reply #1061 on: September 11, 2014, 10:29:11 pm »
aloha community!
i am very interested in modding a Nvidia Card into a Grid k2 to share it with multiple VMs.
What i want to do is to use the rig (xeon 5650 6C/12T@3,8Ghz+24gb DDR3 Ram + hopefully false Grid k2) as a Host for multiple Windows instances  which i'd like to share to some old notebooks (using gigabit ethernet) for gaming purpose. So for the next LAN for example nobody needs to bring its full rig and stuff but just its notebook and everybody gets still good performance (using 1C/2T+ 4GB Ram + 1/4 Grid k2 + domU in own hdd or on SSD).
is this doable or is the performance via gigabit ethernet too slow?
Also i read that this mod works with GTX 680 2 GB.
Since a GTX 770 is cheaper and basically the same card in specs i wonder if the mod would still be possible with GTX 770?
Also i'd like to know how the modded card performs when shared fully to just one domU?
is it even possible or is the Grid k2 "divided" into separate parts which i share to multiple VMs?
if it is that way, had anyone tried to solder a switch to the resistors? if i get it correctly you 'just' need to remove two resistors at the gtx 680. that way it should be possible to solder a little switch to choose between 45k and ?. that way when the machine is shutdown i could just switch between the 'different' cards. when starting with the gtx 680 i boot into the hdd my windoze or linux domU is located at. (which will propably result in issues with the driver(?))
hope you guys can help me!
i really like to get that discount of about 1800€ on a Grid k2 :P
Offline amin_eshgh
« Reply #1062 on: September 12, 2014, 12:46:41 pm »
ngphucok : read this page correctly  :palm:
dreadkopp : read this forum more  :clap:  + for best performance your notebooks should have 1Gbps Lan
maxpoz : NO :-BROKE
Offline dreadkopp
« Reply #1063 on: September 12, 2014, 10:19:43 pm »
sorry, two pages ago someone modded his gtx 770 to grid k2 ...
so i will get one soon, if necessary someone can help me to detect the correct resistors?
Greetings!
Offline joe500
« Reply #1064 on: September 16, 2014, 02:30:49 pm »
Hello,
first thank you all for this very helpful thread! :-+
I was able to hardmod my GTX 770 to a Tesla K10.
But none of the temperature sensors are working now, and I can't access the Nvidia controll panel(there is no display attached to the gpu :palm:)
Should I flash a K10 bios, to get all the stuff working? I also can't play any game |O
Maybe someone can help me solving these problems :-+
EDIT: Made it a Grid k2 and all works perfect now!!! Thank you all so much!!!
« Last Edit: September 16, 2014, 05:42:30 pm by joe500 »
Offline axero
« Reply #1065 on: September 19, 2014, 08:10:30 pm »
How does this perform in GPGPU benchmarks? Is the double precision float numbers comparable to a real K2 or is the performance still crippled? You can find such a benchmark in Aida64 under Tools -> GPGPU Benchmark
Offline Patribus
« Reply #1066 on: September 20, 2014, 11:07:49 am »
Hello everyone,
for those who have time,
I started a Wiki to gather all the info in this forum in a struktured way.
The wiki is still kompletely empty, I'll start filling in out in the next few weeks, mainly with all the info related to the GTX 660 card (which is the one I have).
PLEASE FEEL FREE TO EDIT THIS WIKI
located at http://aidivn.wikia.com
TO be honest, I still did not check how the permissions settings are, but I'll change them step by step, so everyone can have access to edit.
Well, that's it for the moment.
Best regards
Offline NiHaoMike
    • Facebook Page
« Reply #1067 on: September 20, 2014, 11:24:58 pm »
Any idea if the new 980/970 would be hackable?
Offline vacaloca
« Reply #1068 on: September 22, 2014, 05:01:00 am »
I don't believe there are any professional model cards with GM204 chips, so my guess is GTX 970 and 980 can't be converted to anything else.
Would this be doable? Interested in TCC... From:
NVIDIA_DEV.1380 = "NVIDIA GeForce GTX 750 Ti"
NVIDIA_DEV.1381 = "NVIDIA GeForce GTX 750
To:
NVIDIA_DEV.13BA = "NVIDIA Quadro K2200"
Offline ngphucok
« Reply #1069 on: September 22, 2014, 07:31:03 pm »
maxpoz : NO :-BROKE
What do you mean ? Can you please tell me what did I read incorrectly?  Last Week, I tried to put on the VR 1k - 100K in the forth bit; however, the Device ID seems like it doesn't change when I turn to 5K or 60K.  Do I need to modify the BIOS firmware in order to make it work?
Thanks a lot for your advise !
Offline pradawny
« Reply #1070 on: September 25, 2014, 10:19:50 pm »
Hello,
Due to the limited space around the single pcie x16 slot, I'm thinking about purchasing GTX 760 "MINI" card. I found two models:
1) ASUS DirectCU Mini - GTX760-DCMOC-2GD5
2) MSI N760 2GD5/OC ITX
I wonder if someone has already managed to convert one of these "MINI" GTX 760 cards into the Grid K2? Looking at the attached pictures it seems that the resistors have been placed somewhere else.
Alternatively, what card would you recommend for virtualization purposes (vDGA / vSGA), which does not require a lot of soldering and would fit into the Intel S2600CP4 mainboard (graphics lenght is limited by memory slots ). It would be great if the card wouldn't be too loud.
« Last Edit: September 25, 2014, 10:52:08 pm by pradawny »
Offline justanothercanuck
  • Doing retro repairs...
« Reply #1071 on: September 27, 2014, 11:26:04 pm »
Looks like the days of softmods might be over...  :-//
"NVIDIA Alerts Nouveau: They're Starting To Sign/Validate GPU Firmware Images"
http://www.phoronix.com/scan.php?page=news_item&px=MTc5ODA
Maintain your old electronics!  If you don't preserve it, it could be lost forever!
Offline philyd
« Reply #1072 on: October 04, 2014, 01:01:55 am »
hey guys, made an account especially for this :)
so i've read  :blah: through most of the forum and decided im keen  :scared: to get my fingers into my MSI 660Ti Power Edition and turn it into a k5000. I mainly need it for ansys  :bullshit: and cad at home: unlocking would mean i could start using the card to solve, instead of having to use the cpu  :palm:
 From what ive read, i still havent been able to identify the resistors. would be awesome if anyone has any clues as to where they are. ive attached pics of where i think they might be  :-// .
Correct me if im wrong, but i can just use the same resistor values as for the 680, correct?
If there is still any mystery about the 660ti, id be willing to donate the card, if anyone wants to give it a shot :)
thanks guys, you're amazing  ;D
Offline deej78
« Reply #1073 on: October 06, 2014, 07:15:48 pm »
Hi Guys. I found this forum searching for 'Hack GTX 780 into quadro' on Google. Is it possible to hack a GTX 780 into anything? I was just about to buy a Quadro anyway so I don't mind trying. If someone can guide me through what I need to do.
Thank You
Daniel
Offline joe500
« Reply #1074 on: October 08, 2014, 04:31:58 pm »
Hello,
now that I have a gtx770 @ Grid K2 I tried some virtualisazion scenarios:
1. XenServer with XenDesktop: VDGA works, but with VSGA the VM's dont start.
2. ESXi with Horizon View VDGA: works, but no  VSGA.
3. Remote FX: I can enable Remote FX in the Win 8.1 Enterprise VM. Also a little bit of VRam(165 Mb) is allocated by the VM. Sadly there is no difference in performance between software gpu and the fake Grid K2.
The Host is a Windows Server 2012 with i5-3550 and 16Gb of Ram
The VM is a windows 8.1 Enterprise
Do I need to modify the bios or flash a modified bios from a K2 Grid to my moded Gtx 770 to get the full performance/features?
Please help me with this problem :-+
