Part D of
Ralf Brown's Interrupt List explains the following in
PORTS.B file for the hardware serial port registers:
PORT 03F8-03FF - Serial port (8250,8250A,8251,16450,16550,16550A,etc.) COM1
Range: PORT 02E8h-02EFh (COM2), PORT 02F8h-02FFh (typical non-PS/2 COM3), and
PORT 03E8h-03EFh (typical non-PS/2 COM4)
Note: chips overview:
8250 original PC, specified up to 56Kbd, but mostly runs
only 9600Bd, no scratchregister, bug: sometimes shots
ints without reasons
8250A, 16450, 16C451: ATs, most chips run up to 115KBd,
no bug: shots no causeless ints
8250B: PC,XT,AT, pseudo bug: shots one causeless int for
compatibility with 8250, runs up to 56KBd
16550, 16550N, 16550V: early PS/2, FIFO bugs
16550A,16550AF,16550AFN,16550C,16C551,16C552: PS/2, FIFO ok
82510: laptops & industry, multi emulation mode
(default=16450), special-FIFO.
8251: completely different synchronous SIO chip, not compatible!
SeeAlso: INT 14/AH=00h"SERIAL"
03F8 -W serial port, transmitter holding register (THR), which contains the
character to be sent. Bit 0 is sent first.
bit 7-0 data bits when DLAB=0 (Divisor Latch Access Bit)
03F8 R- receiver buffer register (RBR), which contains the received
character. Bit 0 is received first
03F8 RW divisor latch low byte (DLL) when DLAB=1 (see #P0876)
03F9 RW divisor latch high byte (DLM) when DLAB=1 (see #P0876)
03F9 RW interrupt enable register (IER) when DLAB=0 (see #P0877)
03FA R- interrupt identification register (see #P0878)
Information about a pending interrupt is stored here. When the ID
register is addressed, thehighest priority interrupt is held, and
no other interrupts are acknowledged until the CPU services that
interrupt.
03FA -W 16650 FIFO Control Register (FCR) (see #P0879)
03FB RW line control register (LCR) (see #P0880)
03FC RW modem control register (see #P0881)
03FD R- line status register (LSR) (see #P0882)
03FE R- modem status register (MSR) (see #P0883)
03FF RW scratch register (SCR)
(not used for serial I/O; available to any application using 16450,
16550) (not present on original 8250)
(Table P0876)
Values for serial port divisor latch registers:
Some baudrates (using standard 1.8432 Mhz clock):
baudrate divisor DLM DLL
50 2304 09h 00h
75 1536 06h 00h
110 1047 04h 17h
134,5 857 03h 59h
150 768 03h 00h
300 384 01h 80h
600 192 00h C0h
1200 96 00h 60h
1800 64 00h 40h
2000 58 00h 3Ah
2400 48 00h 30h
3600 32 00h 20h
4800 24 00h 18h
7200 16 00h 10h
9600 12 00h 0Ch
19200 6 00h 06h
38400 3 00h 03h
57600 2 00h 02h
115200 1 00h 01h
Note: MIDI baudrate 32250Bd with 4Mhz quarz for c't MIDI interface
following c't 01/1991: '14400' 00h 08h
Bitfields for serial port interrupt enable register (IER):
Bit(s) Description (Table P0877)
7-6 reserved (0)
5 (82510) "timer"
(other) reserved (0)
4 (82510) "transmit machine"
3 modem-status interrupt enable
2 receiver-line-status interrupt enable
1 transmitter-holding-register empty interrupt enable
0 received-data-available interrupt enable
(also 16550(A) timeout interrupt)
Note: 16550(A) will interrupt with a timeout if data exists in the FIFO
and isn't read within the time it takes to receive four bytes or if
no data is received within the time it takes to receive four bytes
SeeAlso: #P0878
Bitfields for serial port interrupt identification register (IIR):
Bit(s) Description (Table P0878)
7-6 =00 reserved on 8250, 8251, 16450
=01 if FIFO queues enabled but unusable (16550 only)
=11 if FIFO queues are enabled (16550A only) (see also #P0879)
6-5 used by 82510 for bank select (00 = default bank0)
5-4 reserved (0)
3-1 identify pending interrupt with the highest priority
110 (16550,82510) timeout interrupt pending
101 (82510) timer interrupt (see #P0877)
100 (82510) transmit machine (see #P0877)
011 receiver line status interrupt. priority=highest
010 received data available register interrupt. pr.=second
001 transmitter holding register empty interrupt. pr.=third
000 modem status interrupt. priority=fourth
0 =0 interrupt pending. contents of register can be used as a pointer
to the appropriate interrupt service routine
=1 no interrupt pending
Notes: interrupt pending flag uses reverse logic, 0=pending, 1=none
interrupt will occur if any of the line status bits are set
THRE bit is set when THRE register is emptied into the TSR
SeeAlso: #P0877
Bitfields for serial port FIFO control register (FCR):
Bit(s) Description (Table P0879)
7-6 received data available interrupt trigger level (16550)
00 1 byte
01 4 bytes
10 8 bytes
11 14 bytes
6-5 =00 (used to enable 4 byte Rx/Tx FIFOs on 82510???)
=10 ???
5-4 reserved (00)
3 change RXRDY TXRDY pins from mode 0 to mode 1
2 clear XMIT FIFO
1 clear RCVR FIFO
0 enable clear XMIT and RCVR FIFO queues
4-0 (other purpose on 82510???)
Notes: bit 0 must be set in order to write to other FCR bits
bit 1 when set the RCVR FIFO is cleared and this bit is reset
the receiver shift register is not cleared
bit 2 when set the XMIT FIFO is cleared and this bit is reset
the transmit shift register is not cleared
due to a hardware bug, 16550 FIFOs don't work correctly (this
was fixed in the 16550A)
SeeAlso: #P0878
Bitfields for serial port Line Control Register (LCR):
Bit(s) Description (Table P0880)
7 =1 divisor latch access bit (DLAB)
=0 receiver buffer, transmitter holding, or interrupt enable register
access
6 set break enable. serial ouput is forced to spacing state and remains
there.
5-3 PM2 PM1 PM0
x x 0 = no parity
0 0 1 = odd parity
0 1 1 = even parity
1 0 1 = high parity (sticky)
1 1 1 = low parity (sticky)
x x 1 = software parity
2 stop bit length (STB/SBL)
0 one stop bit
1 2 stop bits with (word length 6, 7, 8)
1.5 stop bits with word length 5
1-0 (WLS1-0, CL1-0)
00 word length is 5 bits
01 word length is 6 bits
10 word length is 7 bits
11 word length is 8 bits
SeeAlso: #P0881,#P0882,#P0883
Bitfields for serial port Modem Control Register (MCR):
Bit(s) Description (Table P0881)
7-6 reserved (0)
5 (82510 only) state of OUT0 pin
4 loopback mode for diagnostic testing of serial port
output of transmitter shift register is looped back to receiver
shift register input. In this mode, transmitted data is received
immediately so that the CPU can verify the transmit data/receive
data serial port paths.
If OUT2 is disabled, there is no official way to generate an IRQ
during loopback mode.
3 auxiliary user-designated output 2 (OUT2)
because of external circuity OUT2 must be 1 to master-intr-enableing.
BUG: Some Toshiba Laptops utilize this bit vice versa, newer Toshiba
machines allow assignment of the bit's polarity in system setup.
82050: This bit is only effective, if the chip is being used with an
externally-generated clock.
2 =1/0 auxiliary user-designated output 1 (OUT1)
should generally be cleared!!
Some external hardware, e.g. c't MIDI interface (and compatibles) use
this bit to change the 8250 input clock from 1,8432 MHz to 4Mhz
(enabling MIDI-conformant baudrates) and switching to
MIDI-compatible current loop connectors.
1 force request-to-send active (RTS)
0 force data-terminal-ready active (DTR)
SeeAlso: #P0880,#P0882,#P0883
Bitfields for serial port Line Status Register (LSR):
Bit(s) Description (Table P0882)
7 =0 reserved
=1 on some chips produced by UMC
6 transmitter shift and holding registers empty
5 transmitter holding register empty (THRE)
Controller is ready to accept a new character to send.
4 break interrupt. the received data input is held in the zero bit
state longer than the time of start bit + data bits + parity bit +
stop bits.
3 framing error (FE). the stop bit that follows the last parity or data
bit is a zero bit
2 parity error (PE). Character has wrong parity
1 overrun error (OE). a character was sent to the receiver buffer
before the previous character in the buffer could be read. This
destroys the previous character.
0 data ready. a complete incoming character has been received and sent
to the receiver buffer register.
SeeAlso: #P0880,#P0881,#P0883
Bitfields for serial port Modem Status Register (MSR):
Bit(s) Description (Table P0883)
7 data carrier detect (-DCD)
6 ring indicator (-RI)
5 data set ready (-DSR)
4 clear to send (-CTS)
3 delta data carrier detect (DDCD)
2 trailing edge ring indicator (TERI)
1 delta data set ready (DDSR)
0 delta clear to send (DCTS)
Notes: bits 0-3 are reset when the CPU reads the MSR
bit 4 is the Modem Control Register RTS during loopback test
bit 5 is the Modem Control Register DTR during loopback test
bit 6 is the Modem Control Register OUT1 during loopback test
bit 7 is the Modem Control Register OUT2 during loopback test
SeeAlso: #P0880,#P0881,#P0882
The most important one is the last table, explaining the eight bits of port 0x3FE, Modem Status Register (MSR):
- Bit 7 (128): DCD. This reflects the DCD pin state.
- Bit 6 (64): RI. This reflects the RI pin state.
- Bit 5 (32): DSR. This reflects the DSR pin state.
- Bit 4 (16): CTS. This reflects the CTS pin state.
- Bit 3 (8): Delta DCD. This is set when the DCD state has changed since last read of this register.
- Bit 2 (4): Trailing edge RI. This is set when RI has transitioned from low to high since this register was read last.
- Bit 1 (2): Delta DSR. This is set if DSR has changed since last read of this register.
- Bit 0 (1): Delta CTS. This is set if CTS has changed since last read of this register.
I'm no longer convinced I know whether the four high bits are inverted or not... so check that. However,
inb sets the environment variable value to
hexadecimal without a leading 0x, so the values you see (10, 11, 20, 23) are actually 0x10=16, 0x11=17, 0x20=32, 0x23=35. And yes, those values make perfect sense. (I hope this post explains why and how.)
if [ $com1 -eq 10 -o $com1 -eq 11]; then
Before you do this, you need to add
com1=0x$com1so that Grub parses it correctly as a hexadecimal number. It definitely is a hexadecimal number, as Grub uses
grub_snprintf(buf, sizeof (buf), "%x", value) to construct it.
The reason i have to check if port is 10 or 11 is because first time i read the port gives 11, sometimes other number and second time it gives the correct number.
Yes, this is because the four low bits (right-side hexadecimal digit) is a "delta" value, telling whether the status lines have changed since the last read of the register.
Essentially, if you read it twice in succession, and the input pin states do not change in between, the low bits should be all zeros (so you get 0x10, 0x20, 0x30, ..., 0xF0).
It is perfectly okay to read the register twice in succession, e.g.
inb -v com1 0x3FE inb -v com1 0x3FE com1=0x$com1to hopefully clear the low four bits that aren't that interesting. I don't think Grub has built-in arithmetic or binary operators, otherwise
com1=$[0x$com1 & 0xF0] would have been extremely useful for this. Also note that the value you are treating as a decimal is actually hexadecimal, because
inb does not set the leading 0x, the values you get just happen to look like normal decimal values!
We could rely on the regexp command, though:
inb -v com1 0x3FE regexp --set 1:com1 '^[0-9A-Fa-f]*([0-9A-Fa-f])[0-9A-Fa-f]$' 00$com1 com1=0x$com1in which case
com1 matches a number between 0-15, as if it had been divided by 16. The idea is that the
POSIX extended regular expression in single quotes matches any number of hex digits, then remembers one hex digit, then matches one hex digit; and the command stores the first parenthesized match back to
com1. The string it operates on has two zeros prepended, so that the regexp works correctly even when
com1 contains only a single hex digit. (But do check it for bugs, I haven't tested it.)
